SMP failing as soon as the file downloads
Turbo_T
Post by Turbo_T »
I have recently experienced a complete inability to run any SMP on my machine. I prefer the Tracker V2 but I have also tried the Ver 7 FAH client as well. Both are failing SMP as soon as the file loads. My system was folding in this configuration for weeks before this development. I have tried reloading the client software and deleting the cores so it would download new versions to ensure they weren't corrupted. See message log below,
[18:33:37] Verifying core Core_a4.fah...
[18:33:37] Signature is VALID
[18:33:37]
[18:33:37] Trying to unzip core FahCore_a4.exe
[18:33:38] Decompressed FahCore_a4.exe (10057216 bytes) successfully
[18:33:43] + Core successfully engaged
[18:33:43] Deleting current work unit & continuing...
[18:33:55] - Preparing to get new work unit...
[18:33:55] Cleaning up work directory
[18:33:55] + Attempting to get work packet
[18:33:55] Passkey found
[18:33:55] - Connecting to assignment server
[18:33:55] - Successful: assigned to (129.74.246.143).
[18:33:55] + News From Folding@Home:
[18:33:55] Loaded queue successfully.
[18:33:56] + Closed connections
[18:34:01]
[18:34:01] + Processing work unit
[18:34:01] A4 will attempt to use 16 threads.
[18:34:01] Core required: FahCore_a4.exe
[18:34:01] Core found.
[18:34:01] Working on queue slot 04 [December 6 18:34:01 UTC]
[18:34:01] + Working ...
[18:34:01]
[18:34:01] *------------------------------*
[18:34:01] Folding@Home Gromacs GB Core
[18:34:01] Version 2.27 (Dec. 15, 2010)
[18:34:01]
[18:34:01] Preparing to commence simulation
[18:34:01] - Assembly optimizations manually forced on.
[18:34:01] - Not checking prior termination.
[18:34:01] - Expanded 56075 -> 206228 (decompressed 367.7 percent)
[18:34:01] Called DecompressByteArray: compressed_data_size=56075 data_size=206228, decompressed_data_size=206228 diff=0
[18:34:01] - Digital signature verified
[18:34:01]
[18:34:01] Project: 10083 (Run 0, Clone 92, Gen 2)
[18:34:01]
[18:34:01] Assembly optimizations on if available.
[18:34:01] Entering M.D.
[18:34:07] Mapping NT from 16 to 16
[18:34:18] CoreStatus = C0000029 (-1073741783)
[18:34:18] Client-core communications error: ERROR 0xc0000029
[18:34:18] Deleting current work unit & continuing...
[18:34:30] - Preparing to get new work unit...
[18:34:30] Cleaning up work directory
[18:34:30] + Attempting to get work packet
[18:34:30] Passkey found
[18:34:30] - Connecting to assignment server
[18:34:30] - Successful: assigned to (129.74.246.143).
[18:34:30] + News From Folding@Home:
[18:34:31] Loaded queue successfully.
[18:34:32] + Closed connections
[18:34:37]
[18:34:37] + Processing work unit
[18:34:37] A4 will attempt to use 16 threads.
[18:34:37] Core required: FahCore_a4.exe
[18:34:37] Core found.
[18:34:37] Working on queue slot 05 [December 6 18:34:37 UTC]
[18:34:37] + Working ...
[18:34:37]
[18:34:37] *------------------------------*
[18:34:37] Folding@Home Gromacs GB Core
[18:34:37] Version 2.27 (Dec. 15, 2010)
[18:34:37]
[18:34:37] Preparing to commence simulation
[18:34:37] - Assembly optimizations manually forced on.
[18:34:37] - Not checking prior termination.
[18:34:37] - Expanded 56075 -> 206228 (decompressed 367.7 percent)
[18:34:37] Called DecompressByteArray: compressed_data_size=56075 data_size=206228, decompressed_data_size=206228 diff=0
[18:34:37] - Digital signature verified
[18:34:37]
[18:34:37] Project: 10083 (Run 0, Clone 92, Gen 2)
[18:34:37]
[18:34:37] Assembly optimizations on if available.
[18:34:37] Entering M.D.
[18:34:43] Mapping NT from 16 to 16
[18:34:51] CoreStatus = C0000029 (-1073741783)
[18:34:51] Client-core communications error: ERROR 0xc0000029
[18:34:51] Deleting current work unit & continuing...
[18:35:04] - Preparing to get new work unit...
[18:35:04] Cleaning up work directory
[18:35:04] + Attempting to get work packet
[18:35:04] Passkey found
[18:35:04] - Connecting to assignment server
[18:35:04] - Successful: assigned to (129.74.246.143).
[18:35:04] + News From Folding@Home:
Mod edit: Please enclose log file listings in Code tags
xandry
Re: SMP failing as soon as the file downloads
Post by xandry »
I have same problem with my amd fx-8320.
******************************* Date: 2015-03-31 *******************************
01:56:39:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
01:56:39:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741783 = 0xc0000029)
12:51:11:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
12:51:11:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741783 = 0xc0000029)
This first result from the forum search is applicable, but you'll need some mod help.
Welcome to the folding forum.
Which OS are you running, and are you running a 32 or 64 bit version of that OS? Additional information that will be useful is posting the first hundred or so lines of your log file as outlined in this topic - viewtopic.php?f=61&t=26036.
xandry
Post by xandry »
Windows 7 x64. I cannot reproduce bug if i set number of CPU threads manually. So if i stay "-1" value in settings, then fahcore is crashed, if i set 6 (for example), then it works fine.
First ~80 lines of log:
*********************** Log Started 2015-04-03T01:54:39Z ***********************
01:54:39:************************* Folding@home Client *************************
01:54:39:      Website: http://folding.stanford.edu/
01:54:39:    Copyright: (c) 2009-2014 Stanford University
01:54:39:       Author: Joseph Coffland
01:54:39:         Args: --open-web-control
01:54:39:       Config: C:/Users/xandry/AppData/Roaming/FAHClient/config.xml
01:54:39:******************************** Build ********************************
01:54:39:      Version: 7.4.4
01:54:39:         Date: Mar 4 2014
01:54:39:         Time: 20:26:54
01:54:39:      SVN Rev: 4130
01:54:39:       Branch: fah/trunk/client
01:54:39:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:54:39:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:54:39:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:54:39:     Platform: win32 XP
01:54:39:         Bits: 32
01:54:39:         Mode: Release
01:54:39:******************************* System ********************************
01:54:39:          CPU: AMD FX(tm)-8320 Eight-Core Processor
01:54:39:       CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
01:54:39:         CPUs: 8
01:54:39:       Memory: 7.98GiB
01:54:39:  Free Memory: 5.91GiB
01:54:39:      Threads: WINDOWS_THREADS
01:54:39:   OS Version: 6.1
01:54:39:  Has Battery: false
01:54:39:   On Battery: false
01:54:39:   UTC Offset: 5
01:54:39:          PID: 4844
01:54:39:          CWD: C:/Users/xandry/AppData/Roaming/FAHClient
01:54:39:           OS: Windows 7 Ultimate
01:54:39:      OS Arch: AMD64
01:54:39:         GPUs: 2
01:54:39:        GPU 0: ATI:5 Pitcairn PRO [Radeon HD 7800 Series]
01:54:39:        GPU 1: ATI:5 R575A [Radeon R7 250/HD 7700]
01:54:39:         CUDA: Not detected
01:54:39:Win32 Service: false
01:54:39:***********************************************************************
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:
01:54:39:Trying to access database...
01:54:39:Successfully acquired database lock
01:54:39:Enabled folding slot 00: READY cpu:6
01:54:39:Enabled folding slot 01: READY gpu:0:Pitcairn PRO [Radeon HD 7800 Series]
01:54:39:Enabled folding slot 02: READY gpu:1:R575A [Radeon R7 250/HD 7700]
01:54:39:WU01:FS01:Starting
01:54:39:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4844 -checkpoint 15 -gpu 0 -gpu-vendor ati
01:54:39:WU01:FS01:Started FahCore on PID 5160
01:54:39:WU01:FS01:Core PID:4680
01:54:39:WU01:FS01:FahCore 0x17 started
01:54:39:WU02:FS02:Starting
01:54:39:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 4844 -checkpoint 15 -gpu 1 -gpu-vendor ati
01:54:39:WU02:FS02:Started FahCore on PID 4324
01:54:39:WU02:FS02:Core PID:4256
01:54:39:WU02:FS02:FahCore 0x17 started
01:54:39:WU03:FS00:Starting
01:54:39:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 4844 -checkpoint 15 -np 6
01:54:39:WU03:FS00:Started FahCore on PID 3844
Only warnings and errors:
02:11:11:WARNING:WU03:FS00:Changed SMP threads from 6 to 5 this can cause some work units to fail
05:26:53:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:26:54:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:26:54:ERROR:WU00:FS01:Exception: Could not get an assignment
05:26:55:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:26:56:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:26:56:ERROR:WU00:FS01:Exception: Could not get an assignment
05:27:55:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:27:56:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:27:56:ERROR:WU00:FS01:Exception: Could not get an assignment
05:29:32:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:29:33:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:29:33:ERROR:WU00:FS01:Exception: Could not get an assignment
05:32:10:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:32:10:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:32:10:ERROR:WU00:FS01:Exception: Could not get an assignment
05:36:24:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:36:25:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:36:25:ERROR:WU00:FS01:Exception: Could not get an assignment
05:43:15:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:43:16:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:43:16:ERROR:WU00:FS01:Exception: Could not get an assignment
05:54:21:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
05:54:22:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
05:54:22:ERROR:WU00:FS01:Exception: Could not get an assignment
06:12:20:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
06:12:22:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
06:12:22:ERROR:WU00:FS01:Exception: Could not get an assignment
06:41:21:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
06:41:21:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
06:41:21:ERROR:WU00:FS01:Exception: Could not get an assignment
07:28:22:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
07:28:24:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
07:28:24:ERROR:WU00:FS01:Exception: Could not get an assignment
******************************* Date: 2015-04-03 *******************************
08:44:24:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
08:44:25:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:44:25:ERROR:WU00:FS01:Exception: Could not get an assignment
12:03:25:WARNING:WU03:FS00:Changed SMP threads from 5 to 6 this can cause some work units to fail
20:59:46:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
20:59:47:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:59:47:ERROR:WU01:FS01:Exception: Could not get an assignment
20:59:48:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
20:59:49:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:59:49:ERROR:WU01:FS01:Exception: Could not get an assignment
22:38:22:WARNING:WU00:FS02:Failed to get assignment from '171.67.108.200:80': Empty work server assignment
******************************* Date: 2015-04-04 *******************************
06:56:54:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
06:56:54:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741783 = 0xc0000029)
Is the first 80 lines above with the 6 core value or the -1 value set?
It would be helpful in trying to solve the problem if you posted the first 80 lines plus enough to let the slots complete a frame or crash, while using -1. Does it help if the CPU slot is paused, ie no error with -1 set? Does it error out as soon as it is unpaused?
7im wrote:... plus enough to let the slots complete a frame or crash, while using -1....
Specifically, we need to see the log from at least one of the WUs which issued the message WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741783 = 0xc0000029) beginning at, or before the WU was downloaded and ending after that message was issued.
(The message Empty work server assignment is not a crash and can be ignored, but you probably already know that.)
xandry
Post by xandry »
7im wrote:Is the first 80 lines above with the 6 core value or the -1 value set?
With "6" value. And yes, if i set cpu slot on pause, then problem is not... shows her self.
For compare, this is with "-1" value (tested today):
05:41:40:WU02:FS00:Starting
05:41:40:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
05:41:40:WU02:FS00:Started FahCore on PID 2436
05:41:40:WU02:FS00:Core PID:2900
05:41:40:WU02:FS00:FahCore 0xa4 started
05:41:40:WU02:FS00:0xa4:
05:41:40:WU02:FS00:0xa4:*------------------------------*
05:41:40:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
05:41:40:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:41:40:WU02:FS00:0xa4:Preparing to commence simulation
05:41:40:WU02:FS00:0xa4:- Looking at optimizations...
05:41:40:WU02:FS00:0xa4:- Created dyn
05:41:40:WU02:FS00:0xa4:- Files status OK
05:41:40:WU02:FS00:0xa4:- Expanded 923330 -> 1534204 (decompressed 166.1 percent)
05:41:40:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923330 data_size=1534204, decompressed_data_size=1534204 diff=0
05:41:40:WU02:FS00:0xa4:- Digital signature verified
05:41:40:WU02:FS00:0xa4:Project: 9014 (Run 17, Clone 5, Gen 113)
05:41:40:WU02:FS00:0xa4:Assembly optimizations on if available.
05:41:40:WU02:FS00:0xa4:Entering M.D.
05:41:46:WU02:FS00:0xa4:Mapping NT from 7 to 7
05:41:47:WU02:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
05:41:58:WU00:FS00:Upload complete
05:41:58:WU00:FS00:Server responded WORK_ACK (400)
05:41:58:WU00:FS00:Final credit estimate, 1370.00 points
05:41:58:WU00:FS00:Cleaning up
05:44:17:WU02:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
05:46:46:WU02:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
05:49:21:WU02:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
05:51:48:WU02:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
05:54:15:WU02:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
05:56:43:WU02:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
05:59:14:WU02:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
06:01:41:WU02:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
06:04:11:WU02:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
06:06:41:WU02:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
06:09:09:WU02:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
06:11:38:WU02:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
06:14:10:WU02:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
06:16:38:WU02:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
06:19:05:WU02:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
06:21:32:WU02:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
06:24:00:WU02:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
06:26:27:WU02:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
06:29:03:WU02:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
06:31:36:WU02:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
06:34:06:WU02:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
06:36:37:WU02:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
06:39:09:WU02:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
06:41:42:WU02:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
06:44:10:WU02:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
06:46:38:WU02:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
06:49:09:WU02:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
06:51:40:WU02:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
06:54:11:WU02:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
06:56:47:WU02:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
06:59:25:WU02:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
07:02:03:WU02:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
07:04:31:WU02:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
07:06:59:WU02:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
07:09:36:WU02:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
07:12:12:WU02:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
07:14:48:WU02:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
07:17:21:WU02:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
07:19:51:WU02:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
07:22:37:WU02:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
07:25:27:WU02:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
07:28:05:WU02:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
07:30:40:WU02:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
07:33:17:WU02:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
07:35:46:WU02:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
07:38:18:WU02:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
07:40:46:WU02:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
07:43:13:WU02:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
07:45:41:WU02:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
07:48:09:WU02:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
******************************* Date: 2015-04-05 *******************************
07:50:36:WU02:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
07:53:02:WU02:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
07:55:27:WU02:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
07:57:52:WU02:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
08:00:19:WU02:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
08:02:44:WU02:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
08:05:07:WU02:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
08:07:31:WU02:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
08:09:58:WU02:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
08:12:24:WU02:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
08:14:50:WU02:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
08:17:17:WU02:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
08:19:42:WU02:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
08:22:08:WU02:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
08:24:34:WU02:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
08:26:58:WU02:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
08:29:23:WU02:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
08:31:48:WU02:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
08:34:13:WU02:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
08:36:45:WU02:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
08:39:18:WU02:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
08:41:47:WU02:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
08:44:19:WU02:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
08:46:46:WU02:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
08:49:15:WU02:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
08:51:43:WU02:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
08:54:17:WU02:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
08:56:44:WU02:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
08:59:11:WU02:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
09:01:40:WU02:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
09:04:10:WU02:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
09:06:36:WU02:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
09:09:04:WU02:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
09:11:34:WU02:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
09:14:09:WU02:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
09:16:40:WU02:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
09:19:14:WU02:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
09:21:45:WU02:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
09:24:14:WU02:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
09:26:43:WU02:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
09:27:30:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:27:30:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741783 = 0xc0000029)
Full log:
*********************** Log Started 2015-04-04T19:46:29Z ***********************
19:46:29:************************* Folding@home Client *************************
19:46:29:      Website: http://folding.stanford.edu/
19:46:29:    Copyright: (c) 2009-2014 Stanford University
19:46:29:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:46:29:         Args: --open-web-control
19:46:29:       Config: C:/Users/xandry/AppData/Roaming/FAHClient/config.xml
19:46:29:******************************** Build ********************************
19:46:29:      Version: 7.4.4
19:46:29:         Date: Mar 4 2014
19:46:29:         Time: 20:26:54
19:46:29:      SVN Rev: 4130
19:46:29:       Branch: fah/trunk/client
19:46:29:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:46:29:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:46:29:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:46:29:     Platform: win32 XP
19:46:29:         Bits: 32
19:46:29:         Mode: Release
19:46:29:******************************* System ********************************
19:46:29:          CPU: AMD FX(tm)-8320 Eight-Core Processor
19:46:29:       CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
19:46:29:         CPUs: 8
19:46:29:       Memory: 7.98GiB
19:46:29:  Free Memory: 5.89GiB
19:46:29:      Threads: WINDOWS_THREADS
19:46:29:   OS Version: 6.1
19:46:29:  Has Battery: false
19:46:29:   On Battery: false
19:46:29:   UTC Offset: 5
19:46:29:          PID: 1936
19:46:29:          CWD: C:/Users/xandry/AppData/Roaming/FAHClient
19:46:29:           OS: Windows 7 Ultimate
19:46:29:      OS Arch: AMD64
19:46:29:         GPUs: 1
19:46:29:        GPU 0: ATI:5 Pitcairn PRO [Radeon HD 7800 Series]
19:46:29:         CUDA: Not detected
19:46:29:Win32 Service: false
19:46:29:***********************************************************************
19:46:29:<config>
19:46:29:  <!-- Network -->
19:46:29:  <proxy v=':8080'/>
19:46:29:
19:46:29:  <!-- Slot Control -->
19:46:29:  <power v='full'/>
19:46:29:
19:46:29:  <!-- User Information -->
19:46:29:  <passkey v='********************************'/>
19:46:29:  <team v='226728'/>
19:46:29:  <user v='176ZXsA526eRZuxMMCC4wEpZdJjadjvbdR'/>
19:46:29:
19:46:29:  <!-- Folding Slots -->
19:46:29:  <slot id='0' type='CPU'>
19:46:29:    <cpus v='6'/>
19:46:29:  </slot>
19:46:29:  <slot id='1' type='GPU'/>
19:46:29:</config>
19:46:29:Trying to access database...
19:46:29:Successfully acquired database lock
19:46:29:Enabled folding slot 00: READY cpu:6
19:46:29:Enabled folding slot 01: READY gpu:0:Pitcairn PRO [Radeon HD 7800 Series]
19:46:29:WARNING:WU00:Slot ID 2 no longer exists and there are no other matching slots, dumping
19:46:29:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:10467 run:0 clone:445 gen:87 core:0x17 unit:0x000000a2538b3db9538bc4b6acc55f54
19:46:29:WU00:Connecting to 140.163.4.233:8080
19:46:29:WU01:FS01:Starting
19:46:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:46:29:WU01:FS01:Started FahCore on PID 2144
19:46:29:WU01:FS01:Core PID:5112
19:46:29:WU01:FS01:FahCore 0x17 started
19:46:29:WU03:FS00:Starting
19:46:29:WARNING:WU03:FS00:Changed SMP threads from 4 to 6 this can cause some work units to fail
19:46:29:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 6
19:46:29:WU03:FS00:Started FahCore on PID 4192
19:46:29:WU03:FS00:Core PID:3436
19:46:29:WU03:FS00:FahCore 0xa4 started
19:46:30:WU03:FS00:0xa4:
19:46:30:WU03:FS00:0xa4:*------------------------------*
19:46:30:WU03:FS00:0xa4:Folding@Home Gromacs GB Core
19:46:30:WU03:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
19:46:30:WU03:FS00:0xa4:Preparing to commence simulation
19:46:30:WU03:FS00:0xa4:- Looking at optimizations...
19:46:30:WU03:FS00:0xa4:- Files status OK
19:46:30:WU03:FS00:0xa4:- Expanded 913208 -> 1513440 (decompressed 165.7 percent)
19:46:30:WU03:FS00:0xa4:Called DecompressByteArray: compressed_data_size=913208 data_size=1513440, decompressed_data_size=1513440 diff=0
19:46:30:WU03:FS00:0xa4:- Digital signature verified
19:46:30:WU03:FS00:0xa4:Project: 9012 (Run 122, Clone 4, Gen 52)
19:46:30:WU03:FS00:0xa4:Assembly optimizations on if available.
19:46:30:WU03:FS00:0xa4:Entering M.D.
19:46:30:WU01:FS01:0x17:*********************** Log Started 2015-04-04T19:46:29Z ***********************
19:46:30:WU01:FS01:0x17:Project: 10467 (Run 0, Clone 461, Gen 78)
19:46:30:WU01:FS01:0x17:Unit: 0x00000093538b3db9538bc51926e26599
19:46:30:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
19:46:30:WU01:FS01:0x17:Machine: 1
19:46:30:WU01:FS01:0x17:Digital signatures verified
19:46:30:WU01:FS01:0x17:Folding@home GPU core17
19:46:30:WU01:FS01:0x17:Version 0.0.52
19:46:30:WU01:FS01:0x17:  Found a checkpoint file
19:46:30:WU00:Server responded WORK_ACK (400)
19:46:30:WU00:Cleaning up
19:46:36:WU03:FS00:0xa4:Mapping NT from 6 to 6
19:46:38:WU03:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
19:46:38:16:127.0.0.1:New Web connection
19:49:07:WU03:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
19:49:50:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
19:49:50:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:51:17:WU03:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
19:51:53:Removing old file 'configs/config-20150331-151300.xml'
19:51:53:Saving configuration to config.xml
19:51:53:<config>
19:51:53:  <!-- Network -->
19:51:53:  <proxy v=':8080'/>
19:51:53:
19:51:53:  <!-- Slot Control -->
19:51:53:  <power v='full'/>
19:51:53:
19:51:53:  <!-- User Information -->
19:51:53:  <passkey v='********************************'/>
19:51:53:  <team v='226728'/>
19:51:53:  <user v='176ZXsA526eRZuxMMCC4wEpZdJjadjvbdR'/>
19:51:53:
19:51:53:  <!-- Folding Slots -->
19:51:53:  <slot id='0' type='CPU'/>
19:51:53:  <slot id='1' type='GPU'/>
19:51:53:</config>
19:51:53:FS00:Shutting core down
19:52:01:WU03:FS00:0xa4:Client no longer detected. Shutting down core
19:52:01:WU03:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
19:52:01:WU03:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:52:01:WU03:FS00:Starting
19:52:01:WARNING:WU03:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
19:52:01:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
19:52:01:WU03:FS00:Started FahCore on PID 6672
19:52:01:WU03:FS00:Core PID:6324
19:52:01:WU03:FS00:FahCore 0xa4 started
19:52:02:WU03:FS00:0xa4:
19:52:02:WU03:FS00:0xa4:*------------------------------*
19:52:02:WU03:FS00:0xa4:Folding@Home Gromacs GB Core
19:52:02:WU03:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
19:52:02:WU03:FS00:0xa4:Preparing to commence simulation
19:52:02:WU03:FS00:0xa4:- Looking at optimizations...
19:52:02:WU03:FS00:0xa4:- Files status OK
19:52:02:WU03:FS00:0xa4:- Expanded 913208 -> 1513440 (decompressed 165.7 percent)
19:52:02:WU03:FS00:0xa4:Called DecompressByteArray: compressed_data_size=913208 data_size=1513440, decompressed_data_size=1513440 diff=0
19:52:02:WU03:FS00:0xa4:- Digital signature verified
19:52:02:WU03:FS00:0xa4:Project: 9012 (Run 122, Clone 4, Gen 52)
19:52:02:WU03:FS00:0xa4:Assembly optimizations on if available.
19:52:02:WU03:FS00:0xa4:Entering M.D.
19:52:07:WU03:FS00:0xa4:Mapping NT from 7 to 7
19:52:08:WU03:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
19:52:35:Removing old file 'configs/config-20150402-132731.xml'
19:52:35:Saving configuration to config.xml
19:52:35:<config>
19:52:35:  <!-- Network -->
19:52:35:  <proxy v=':8080'/>
19:52:35:
19:52:35:  <!-- Slot Control -->
19:52:35:  <power v='full'/>
19:52:35:
19:52:35:  <!-- User Information -->
19:52:35:  <passkey v='********************************'/>
19:52:35:  <team v='226728'/>
19:52:35:  <user v='176ZXsA526eRZuxMMCC4wEpZdJjadjvbdR'/>
19:52:35:
19:52:35:  <!-- Folding Slots -->
19:52:35:  <slot id='0' type='CPU'/>
19:52:35:  <slot id='1' type='GPU'/>
19:52:35:</config>
19:54:59:WU03:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
19:57:29:WU03:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
19:59:59:WU03:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
20:02:32:WU03:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
20:05:04:WU03:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
20:06:16:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
20:07:34:WU03:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
20:10:05:WU03:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
20:12:53:WU03:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
20:15:25:WU03:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
20:17:55:WU03:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
20:20:26:WU03:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
20:22:57:WU03:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
20:25:25:WU03:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
20:27:54:WU03:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
20:30:24:WU03:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
20:32:55:WU03:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
20:35:26:WU03:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
20:37:58:WU03:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
20:40:27:WU03:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
20:42:56:WU03:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
20:45:28:WU03:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
20:48:00:WU03:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
20:50:33:WU03:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
20:53:05:WU03:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
20:55:38:WU03:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
20:58:08:WU03:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
21:00:38:WU03:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
21:03:09:WU03:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
21:05:41:WU03:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
21:08:14:WU03:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
21:10:45:WU03:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
21:13:17:WU03:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
21:15:50:WU03:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
21:18:23:WU03:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
21:20:56:WU03:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
21:23:27:WU03:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
21:25:57:WU03:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
21:28:28:WU03:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
21:30:58:WU03:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
21:33:29:WU03:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
21:36:01:WU03:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
21:38:33:WU03:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
21:41:02:WU03:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
21:43:33:WU03:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
21:46:04:WU03:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
21:48:32:WU03:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
21:51:00:WU03:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
21:53:29:WU03:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
21:55:58:WU03:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
21:58:30:WU03:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
22:01:00:WU03:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
22:03:32:WU03:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
22:06:04:WU03:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
22:08:34:WU03:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
22:11:03:WU03:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
22:13:34:WU03:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
22:16:04:WU03:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
22:18:35:WU03:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
22:21:03:WU03:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
22:23:33:WU03:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
22:26:04:WU03:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
22:28:35:WU03:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
22:31:06:WU03:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
22:33:38:WU03:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
22:36:10:WU03:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
22:38:42:WU03:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
22:41:12:WU03:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
22:43:43:WU03:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
22:46:16:WU03:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
22:48:47:WU03:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
22:51:18:WU03:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
22:53:49:WU03:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
22:56:18:WU03:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
22:58:48:WU03:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
23:01:15:WU03:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
23:03:43:WU03:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
23:06:13:WU03:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
23:08:43:WU03:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
23:11:15:WU03:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
23:13:44:WU03:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
23:16:15:WU03:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
23:18:45:WU03:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
23:21:14:WU03:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
23:23:42:WU03:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
23:26:14:WU03:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
23:28:47:WU03:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
23:31:20:WU03:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
23:33:53:WU03:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
23:36:24:WU03:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
23:38:56:WU03:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
23:41:25:WU03:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
23:43:54:WU03:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
23:46:25:WU03:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
23:48:57:WU03:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
23:51:30:WU03:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
23:54:05:WU03:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
23:56:39:WU03:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
23:59:17:WU03:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
00:01:49:WU03:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
00:01:52:WU00:FS00:Connecting to 171.67.108.200:8080
00:01:55:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:01:55:WU00:FS00:Connecting to 171.67.108.204:80
00:01:59:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:01:59:ERROR:WU00:FS00:Exception: Could not get an assignment
00:02:00:WU00:FS00:Connecting to 171.67.108.200:8080
00:02:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:02:00:WU00:FS00:Connecting to 171.67.108.204:80
00:02:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:02:06:ERROR:WU00:FS00:Exception: Could not get an assignment
00:03:00:WU00:FS00:Connecting to 171.67.108.200:8080
00:03:00:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:03:00:WU00:FS00:Connecting to 171.67.108.204:80
00:03:01:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:03:01:ERROR:WU00:FS00:Exception: Could not get an assignment
00:04:22:WU03:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
00:04:24:WU03:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
00:04:34:WU03:FS00:0xa4:
00:04:34:WU03:FS00:0xa4:Finished Work Unit:
00:04:34:WU03:FS00:0xa4:- Reading up to 905376 from "03/wudata_01.trr": Read 905376
00:04:34:WU03:FS00:0xa4:trr file hash check passed.
00:04:34:WU03:FS00:0xa4:- Reading up to 829360 from "03/wudata_01.xtc": Read 829360
00:04:34:WU03:FS00:0xa4:xtc file hash check passed.
00:04:34:WU03:FS00:0xa4:edr file hash check passed.
00:04:34:WU03:FS00:0xa4:logfile size: 24241
00:04:34:WU03:FS00:0xa4:Leaving Run
00:04:37:WU00:FS00:Connecting to 171.67.108.200:8080
00:04:38:WU03:FS00:0xa4:- Writing 1761465 bytes of core data to disk...
00:04:38:WU03:FS00:0xa4:Done: 1760953 -> 1703459 (compressed to 96.7 percent)
00:04:38:WU03:FS00:0xa4:  ... Done.
00:04:39:WU03:FS00:0xa4:- Shutting down core
00:04:39:WU03:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
00:04:39:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:04:39:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:9012 run:122 clone:4 gen:52 core:0xa4 unit:0x00000042664f2de4548af7ee27389e49
00:04:39:WU03:FS00:Uploading 1.63MiB to 171.64.65.124
00:04:39:WU03:FS00:Connecting to 171.64.65.124:8080
00:04:41:WARNING:WU03:FS00:WorkServer connection failed on port 8080 trying 80
00:04:41:WU03:FS00:Connecting to 171.64.65.124:80
00:04:58:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
00:04:58:WU00:FS00:Connecting to 171.67.108.204:80
00:05:02:WARNING:WU03:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.124:80: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
00:05:02:WU03:FS00:Trying to send results to collection server
00:05:02:WU03:FS00:Uploading 1.63MiB to 171.65.103.160
00:05:02:WU03:FS00:Connecting to 171.65.103.160:8080
00:05:17:WU03:FS00:Upload complete
00:05:17:WU03:FS00:Server responded WORK_ACK (400)
00:05:17:WU03:FS00:Final credit estimate, 1328.00 points
00:05:17:WU03:FS00:Cleaning up
00:05:19:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
00:05:19:ERROR:WU00:FS00:Exception: Could not get an assignment
00:07:14:WU00:FS00:Connecting to 171.67.108.200:8080
00:07:15:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:07:15:WU00:FS00:Connecting to 171.67.108.204:80
00:07:16:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:07:16:ERROR:WU00:FS00:Exception: Could not get an assignment
00:11:28:WU00:FS00:Connecting to 171.67.108.200:8080
00:11:29:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:11:29:WU00:FS00:Connecting to 171.67.108.204:80
00:11:30:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:11:30:ERROR:WU00:FS00:Exception: Could not get an assignment
00:18:20:WU00:FS00:Connecting to 171.67.108.200:8080
00:18:21:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:18:21:WU00:FS00:Connecting to 171.67.108.204:80
00:18:22:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:18:22:ERROR:WU00:FS00:Exception: Could not get an assignment
00:29:25:WU00:FS00:Connecting to 171.67.108.200:8080
00:29:26:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:29:26:WU00:FS00:Connecting to 171.67.108.204:80
00:29:27:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:29:27:ERROR:WU00:FS00:Exception: Could not get an assignment
00:47:23:WU00:FS00:Connecting to 171.67.108.200:8080
00:47:24:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
00:47:24:WU00:FS00:Connecting to 171.67.108.204:80
00:47:31:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
00:47:31:ERROR:WU00:FS00:Exception: Could not get an assignment
01:16:25:WU00:FS00:Connecting to 171.67.108.200:8080
01:16:27:WU00:FS00:Assigned to work server 171.64.65.124
01:16:27:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 171.64.65.124
01:16:27:WU00:FS00:Connecting to 171.64.65.124:8080
01:17:33:WU00:FS00:Downloading 892.85KiB
01:17:33:WU00:FS00:Download complete
01:17:33:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9012 run:187 clone:0 gen:265 core:0xa4 unit:0x00000131664f2de453c87be92fc11336
01:17:33:WU00:FS00:Starting
01:17:33:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
01:17:34:WU00:FS00:Started FahCore on PID 5196
01:17:34:WU00:FS00:Core PID:888
01:17:34:WU00:FS00:FahCore 0xa4 started
01:17:34:WU00:FS00:0xa4:
01:17:34:WU00:FS00:0xa4:*------------------------------*
01:17:34:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:17:34:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:17:34:WU00:FS00:0xa4:Preparing to commence simulation
01:17:34:WU00:FS00:0xa4:- Looking at optimizations...
01:17:34:WU00:FS00:0xa4:- Created dyn
01:17:34:WU00:FS00:0xa4:- Files status OK
01:17:34:WU00:FS00:0xa4:- Expanded 913770 -> 1513440 (decompressed 165.6 percent)
01:17:34:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=913770 data_size=1513440, decompressed_data_size=1513440 diff=0
01:17:34:WU00:FS00:0xa4:- Digital signature verified
01:17:34:WU00:FS00:0xa4:Project: 9012 (Run 187, Clone 0, Gen 265)
01:17:34:WU00:FS00:0xa4:Assembly optimizations on if available.
01:17:34:WU00:FS00:0xa4:Entering M.D.
01:17:40:WU00:FS00:0xa4:Mapping NT from 7 to 7
01:17:40:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
01:20:15:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
01:22:52:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
01:25:26:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
01:28:00:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
01:30:34:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
01:33:05:WU00:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
01:35:36:WU00:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
01:38:08:WU00:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
01:40:40:WU00:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
01:43:12:WU00:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
01:45:47:WU00:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
01:48:22:WU00:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
01:50:53:WU00:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
01:53:25:WU00:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
01:55:58:WU00:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
01:58:31:WU00:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
02:01:06:WU00:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
02:03:39:WU00:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
02:06:10:WU00:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
02:08:40:WU00:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
02:11:11:WU00:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
02:13:39:WU00:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
02:16:12:WU00:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
02:18:43:WU00:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
02:21:14:WU00:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
02:23:44:WU00:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
02:26:16:WU00:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
02:28:48:WU00:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
02:31:19:WU00:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
02:33:52:WU00:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
02:36:23:WU00:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
02:38:55:WU00:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
02:41:26:WU00:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
02:43:58:WU00:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
02:46:30:WU00:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
02:49:02:WU00:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
02:51:31:WU00:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
02:54:00:WU00:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
02:56:30:WU00:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
02:58:59:WU00:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
03:01:29:WU00:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
03:03:56:WU00:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
03:06:23:WU00:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
03:08:49:WU00:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
03:11:17:WU00:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
03:13:44:WU00:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
03:16:13:WU00:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
03:18:41:WU00:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
03:21:08:WU00:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
03:23:37:WU00:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
03:26:05:WU00:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
03:28:35:WU00:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
03:31:06:WU00:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
03:33:38:WU00:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
03:34:22:FS00:Shutting core down
03:34:22:FS01:Shutting core down
03:34:22:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 5112
03:34:22:WU01:FS01:0x17:Exiting, please wait. . .
03:34:28:WU00:FS00:0xa4:Client no longer detected. Shutting down core
03:34:28:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
03:34:28:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:34:29:WU00:FS00:Starting
03:34:29:WARNING:WU00:FS00:Changed SMP threads from 7 to 4 this can cause some work units to fail
03:34:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 4
03:34:29:WU00:FS00:Started FahCore on PID 7116
03:34:29:WU00:FS00:Core PID:5364
03:34:29:WU00:FS00:FahCore 0xa4 started
03:34:29:WU00:FS00:0xa4:
03:34:29:WU00:FS00:0xa4:*------------------------------*
03:34:29:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
03:34:29:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:34:29:WU00:FS00:0xa4:Preparing to commence simulation
03:34:29:WU00:FS00:0xa4:- Looking at optimizations...
03:34:29:WU00:FS00:0xa4:- Files status OK
03:34:29:WU00:FS00:0xa4:- Expanded 913770 -> 1513440 (decompressed 165.6 percent)
03:34:29:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=913770 data_size=1513440, decompressed_data_size=1513440 diff=0
03:34:29:WU00:FS00:0xa4:- Digital signature verified
03:34:29:WU00:FS00:0xa4:Project: 9012 (Run 187, Clone 0, Gen 265)
03:34:29:WU00:FS00:0xa4:Assembly optimizations on if available.
03:34:29:WU00:FS00:0xa4:Entering M.D.
03:34:35:WU00:FS00:0xa4:Using Gromacs checkpoints
03:34:35:WU00:FS00:0xa4:Mapping NT from 4 to 4
03:34:35:WU00:FS00:0xa4:Resuming from checkpoint
03:34:35:WU00:FS00:0xa4:Verified 00/wudata_01.log
03:34:35:WU00:FS00:0xa4:Verified 00/wudata_01.trr
03:34:35:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
03:34:35:WU00:FS00:0xa4:Verified 00/wudata_01.edr
03:34:35:WU00:FS00:0xa4:Completed 134050 out of 250000 steps  (53%)
03:35:10:Removing old file 'configs/config-20150402-132842.xml'
03:35:10:Saving configuration to config.xml
03:35:10:<config>
03:35:10:  <!-- Network -->
03:35:10:  <proxy v=':8080'/>
03:35:10:
03:35:10:  <!-- Slot Control -->
03:35:10:  <power v='light'/>
03:35:10:
03:35:10:  <!-- User Information -->
03:35:10:  <passkey v='********************************'/>
03:35:10:  <team v='226728'/>
03:35:10:  <user v='176ZXsA526eRZuxMMCC4wEpZdJjadjvbdR'/>
03:35:10:
03:35:10:  <!-- Folding Slots -->
03:35:10:  <slot id='0' type='CPU'/>
03:35:10:  <slot id='1' type='GPU'/>
03:35:10:</config>
03:35:23:WARNING:FS01:Killing WU01
03:35:23:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:35:31:WU00:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
03:37:57:WU00:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
03:40:22:WU00:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
03:42:47:WU00:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
03:45:14:WU00:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
03:47:42:WU00:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
03:50:08:WU00:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
03:52:35:WU00:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
03:55:00:WU00:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
03:57:24:WU00:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
03:59:48:WU00:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
04:02:13:WU00:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
04:04:36:WU00:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
04:06:53:WU00:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
04:09:09:WU00:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
04:11:25:WU00:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
04:13:39:WU00:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
04:16:16:WU00:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
04:18:54:WU00:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
04:21:29:WU00:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
04:24:04:WU00:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
04:26:43:WU00:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
04:27:04:FS00:Shutting core down
04:27:04:WU01:FS01:Starting
04:27:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -gpu 0 -gpu-vendor ati
04:27:04:WU01:FS01:Started FahCore on PID 6652
04:27:04:WU01:FS01:Core PID:2992
04:27:04:WU01:FS01:FahCore 0x17 started
04:27:05:WU01:FS01:0x17:*********************** Log Started 2015-04-05T04:27:05Z ***********************
04:27:05:WU01:FS01:0x17:Project: 10467 (Run 0, Clone 461, Gen 78)
04:27:05:WU01:FS01:0x17:Unit: 0x00000093538b3db9538bc51926e26599
04:27:05:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
04:27:05:WU01:FS01:0x17:Machine: 1
04:27:05:WU01:FS01:0x17:Digital signatures verified
04:27:05:WU01:FS01:0x17:Folding@home GPU core17
04:27:05:WU01:FS01:0x17:Version 0.0.52
04:27:05:WU01:FS01:0x17:  Found a checkpoint file
04:27:10:WU00:FS00:0xa4:Client no longer detected. Shutting down core
04:27:10:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
04:27:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:27:11:WU00:FS00:Starting
04:27:11:WARNING:WU00:FS00:Changed SMP threads from 4 to 7 this can cause some work units to fail
04:27:11:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
04:27:11:WU00:FS00:Started FahCore on PID 5084
04:27:11:WU00:FS00:Core PID:1212
04:27:11:WU00:FS00:FahCore 0xa4 started
04:27:11:WU00:FS00:0xa4:
04:27:11:WU00:FS00:0xa4:*------------------------------*
04:27:11:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
04:27:11:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
04:27:11:WU00:FS00:0xa4:Preparing to commence simulation
04:27:11:WU00:FS00:0xa4:- Looking at optimizations...
04:27:11:WU00:FS00:0xa4:- Files status OK
04:27:11:WU00:FS00:0xa4:- Expanded 913770 -> 1513440 (decompressed 165.6 percent)
04:27:11:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=913770 data_size=1513440, decompressed_data_size=1513440 diff=0
04:27:11:WU00:FS00:0xa4:- Digital signature verified
04:27:11:WU00:FS00:0xa4:Project: 9012 (Run 187, Clone 0, Gen 265)
04:27:11:WU00:FS00:0xa4:Assembly optimizations on if available.
04:27:11:WU00:FS00:0xa4:Entering M.D.
04:27:17:WU00:FS00:0xa4:Using Gromacs checkpoints
04:27:17:WU00:FS00:0xa4:Mapping NT from 7 to 7
04:27:17:WU00:FS00:0xa4:Resuming from checkpoint
04:27:17:WU00:FS00:0xa4:Verified 00/wudata_01.log
04:27:17:WU00:FS00:0xa4:Verified 00/wudata_01.trr
04:27:17:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
04:27:17:WU00:FS00:0xa4:Verified 00/wudata_01.edr
04:27:18:WU00:FS00:0xa4:Completed 180650 out of 250000 steps  (72%)
04:28:02:Removing old file 'configs/config-20150402-132923.xml'
04:28:02:Saving configuration to config.xml
04:28:02:<config>
04:28:02:  <!-- Network -->
04:28:02:  <proxy v=':8080'/>
04:28:02:
04:28:02:  <!-- Slot Control -->
04:28:02:  <power v='full'/>
04:28:02:
04:28:02:  <!-- User Information -->
04:28:02:  <passkey v='********************************'/>
04:28:02:  <team v='226728'/>
04:28:02:  <user v='176ZXsA526eRZuxMMCC4wEpZdJjadjvbdR'/>
04:28:02:
04:28:02:  <!-- Folding Slots -->
04:28:02:  <slot id='0' type='CPU'/>
04:28:02:  <slot id='1' type='GPU'/>
04:28:02:</config>
04:32:11:WU00:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
04:33:36:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
04:33:36:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:36:08:WU00:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
04:38:44:WU00:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
04:41:14:WU00:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
04:43:44:WU00:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
04:46:16:WU00:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
04:48:47:WU00:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
04:50:22:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
04:51:21:WU00:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
04:53:55:WU00:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
04:56:29:WU00:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
04:58:58:WU00:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
05:01:28:WU00:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
05:03:54:WU00:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
05:06:21:WU00:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
05:06:24:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
05:08:53:WU00:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
05:11:20:WU00:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
05:13:45:WU00:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
05:16:13:WU00:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
05:18:46:WU00:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
05:21:16:WU00:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
05:23:47:WU00:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
05:26:17:WU00:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
05:28:51:WU00:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
05:31:23:WU00:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
05:33:52:WU00:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
05:36:22:WU00:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
05:39:01:WU00:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
05:39:04:WU02:FS00:Connecting to 171.67.108.200:8080
05:39:06:WU02:FS00:Assigned to work server 171.64.65.124
05:39:06:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 171.64.65.124
05:39:06:WU02:FS00:Connecting to 171.64.65.124:8080
05:39:19:WU02:FS00:Downloading 902.19KiB
05:39:19:WU02:FS00:Download complete
05:39:19:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9014 run:17 clone:5 gen:113 core:0xa4 unit:0x0000008f664f2de453e556c47b051a48
05:41:27:WU00:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
05:41:29:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
05:41:39:WU00:FS00:0xa4:
05:41:39:WU00:FS00:0xa4:Finished Work Unit:
05:41:39:WU00:FS00:0xa4:- Reading up to 905376 from "00/wudata_01.trr": Read 905376
05:41:39:WU00:FS00:0xa4:trr file hash check passed.
05:41:39:WU00:FS00:0xa4:- Reading up to 829712 from "00/wudata_01.xtc": Read 829712
05:41:39:WU00:FS00:0xa4:xtc file hash check passed.
05:41:39:WU00:FS00:0xa4:edr file hash check passed.
05:41:39:WU00:FS00:0xa4:logfile size: 25690
05:41:39:WU00:FS00:0xa4:Leaving Run
05:41:39:WU00:FS00:0xa4:- Writing 1763266 bytes of core data to disk...
05:41:39:WU00:FS00:0xa4:Done: 1762754 -> 1703732 (compressed to 96.6 percent)
05:41:39:WU00:FS00:0xa4:  ... Done.
05:41:39:WU00:FS00:0xa4:- Shutting down core
05:41:39:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
05:41:40:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:41:40:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9012 run:187 clone:0 gen:265 core:0xa4 unit:0x00000131664f2de453c87be92fc11336
05:41:40:WU00:FS00:Uploading 1.63MiB to 171.64.65.124
05:41:40:WU00:FS00:Connecting to 171.64.65.124:8080
09:27:31:WU02:FS00:Starting
09:27:31:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xandry/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 1936 -checkpoint 15 -np 7
09:27:31:WU02:FS00:Started FahCore on PID 1152
09:27:31:WU02:FS00:Core PID:1428
09:27:31:WU02:FS00:FahCore 0xa4 started
09:27:31:WU02:FS00:0xa4:
09:27:31:WU02:FS00:0xa4:*------------------------------*
09:27:31:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
09:27:31:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
09:27:31:WU02:FS00:0xa4:Preparing to commence simulation
09:27:31:WU02:FS00:0xa4:- Ensuring status. Please wait.
09:27:40:WU02:FS00:0xa4:- Looking at optimizations...
09:27:40:WU02:FS00:0xa4:- Working with standard loops on this execution.
09:27:40:WU02:FS00:0xa4:- Previous termination of core was improper.
09:27:40:WU02:FS00:0xa4:- Files status OK
09:27:40:WU02:FS00:0xa4:- Expanded 923330 -> 1534204 (decompressed 166.1 percent)
09:27:40:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=923330 data_size=1534204, decompressed_data_size=1534204 diff=0
09:27:40:WU02:FS00:0xa4:- Digital signature verified
09:27:40:WU02:FS00:0xa4:Project: 9014 (Run 17, Clone 5, Gen 113)
09:27:40:WU02:FS00:0xa4:Entering M.D.
09:27:46:WU02:FS00:0xa4:Using Gromacs checkpoints
09:27:47:WU02:FS00:0xa4:Mapping NT from 7 to 7
09:27:47:WU02:FS00:0xa4:Resuming from checkpoint
09:27:47:WU02:FS00:0xa4:Verified 02/wudata_01.log
09:27:47:WU02:FS00:0xa4:Verified 02/wudata_01.trr
09:27:47:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
09:27:47:WU02:FS00:0xa4:Verified 02/wudata_01.edr
09:27:47:WU02:FS00:0xa4:Completed 225045 out of 250000 steps  (90%)
09:28:57:FS00:Shutting core down
09:28:57:FS01:Shutting core down
09:28:57:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 2992
09:28:57:WU01:FS01:0x17:Exiting, please wait. . .
09:29:58:WARNING:FS01:Killing WU01
09:29:58:Clean exit
Also here is Windows reporting tool log (through google translate):
Faulting application name: FahCore_a4.exe, version: 0.0.0.0, time stamp: 0x4d23eafc
The name of the failed module: ntdll.dll, version: 6.1.7601.18247, time stamp 0x521ea8e7
Exception code: 0xc0000029
Offset error: 0x00090892
ID of the failed process: 0xb54
Faulting application start time: 0x01d06f6330bf036d
Faulting application path:C:\Users\xandry\AppData\Roaming\FAHClient\cores\web.stanford.edu\~pande\Win32\AMD64\Core_a4.fah\FahCore_a4.exe
The path of the failed module: C: \ Windows \ SysWOW64 \ ntdll.dll
Report code: f1a794fc-db75-11e4-b20c-3085a9487d7c
The problem here is the value for CPU:7. GROMACS, including FahCore_a4, has a known problem when the number of CPUs being used is a "large prime" For people with 12 CPUs plus a GPU, if -1 is set, the client will use CPU:11, but 11 has been identified as "large" (and it's prime) so FahCore_a4 will re-map that to 10 and will process the assigned work units. The question becomes whether the prime number 7 is considered "large" or not. For the prime values 2, 3, and 5, WUs are successfully completed and they're not classified as "large." That leaves the value of 7 is in a gray area between "large" or "not large"
In fact, the failure rate for some projects is high enough that they're excluded from being assigned to machines reporting 7 CPUs, while the failure rate of other projects seem to low enough to assign them. I'm not sure if anyone has examined the failure rate of project 9014 on machines with 7 CPUs. In the case you posted, the WU did get to 90% before it failed. Does that warrant excluding all assignments to 7 CPU donors? Maybe/maybe not.
