Project: 2653 (Run 19, Clone 107, Gen 46)
DocJonz
Post by DocJonz »
My machine has been waiting for a new WU, and it picked up the above - is it a 'duffer' (see log)?
--- Opening Log file [May 20 16:55:34]
# SMP Client ##################################################################
                       Folding@Home Client Version 5.91beta6
                          http://folding.stanford.edu
Launch directory: D:\Folding@Home\F@HWinSMP1
Executable: D:\Folding@Home\F@HWinSMP1\fah.exe
Arguments: -forceasm
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[16:55:34] - Ask before connecting: No
[16:55:34] - User name: DocJonz (Team 35947)
[16:55:34] - User ID: 6739B4F6088136EE
[16:55:34] - Machine ID: 1
[16:55:34]
[16:55:34] Loaded queue successfully.
[16:55:34] - Preparing to get new work unit...
[16:55:34] + Attempting to get work packet
[16:55:34] - Connecting to assignment server
[16:55:35] - Successful: assigned to (0.0.0.0).
[16:55:35] + News From Folding@Home: Welcome to Folding@Home
[16:55:35] Work Unit has an invalid address.
[16:55:35] - Error: Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[16:55:52] + Attempting to get work packet
[16:55:52] - Connecting to assignment server
[16:55:53] - Successful: assigned to (0.0.0.0).
[16:55:53] + News From Folding@Home: Welcome to Folding@Home
[16:55:53] Work Unit has an invalid address.
[16:55:53] - Error: Attempt #2  to get work failed, and no other work to do.
[16:56:16] + Attempting to get work packet
[16:56:16] - Connecting to assignment server
[16:56:17] - Successful: assigned to (171.64.65.64).
[16:56:17] + News From Folding@Home: Welcome to Folding@Home
[16:56:17] Loaded queue successfully.
[16:57:41] + Closed connections
[16:57:41]
[16:57:41] + Processing work unit
[16:57:41] Core required: FahCore_a1.exe
[16:57:41] Core found.
[16:57:41] Working on Unit 07 [May 20 16:57:41]
[16:57:41] + Working ...
[16:57:41]
[16:57:41] *------------------------------*
[16:57:41] Folding@Home Gromacs SMP Core
[16:57:41] Version 1.74 (March 10, 2007)
[16:57:41]
[16:57:41] Preparing to commence simulation
[16:57:41] - Ensuring status. Please wait.
[16:57:58] - Assembly optimizations manually forced on.
[16:57:58] - Not checking prior termination.
[16:58:02] - Expanded 2432663 -> 12862801 (decompressed 528.7 percent)
[16:58:02] - Starting from initial work packet
[16:58:02]
[16:58:02] Project: 2653 (Run 19, Clone 107, Gen 46)
[16:58:02]
[16:58:03] ing:  check for stray files
[16:58:03] - Starting from initial wWarning:  check for stray files
[16:58:03] - Starting from initial work packet
[16:58:03]
[16:58:03] Project: 2653 (Run 19, Clone 107, Gen 46)
[16:58:03]
[16:58:04] Assembly optimizations on if available.
[16:58:04] Entering M.D.
[16:58:11] Protein: Protein in POPC
[16:58:11] Writing local files
[16:58:11] Extra SSE boost OK.
[16:58:12] e: 7483
[16:58:12] - Writing 8019 bytes of core data to disk...
[16:58:12]   ... Done.
[16:58:12] - Failed to delete work/wudata_07.arc
[16:58:12] te work/wudata_07.arc
[16:58:12] isk...
[16:58:12] - Failed to delete work/wudata_07.xtc
[16:58:13] Warning:  check Warning:  check for stray files
[16:58:13] a_07.bed
[16:58:13] - Failed to delete work/wudata_07.sas
[16:58:13] - Failed to delete work/wudata_07.goe
[16:58:13] - Failed to delete work/wudata_07.xvg
[16:58:13] Warning:  check for stray files
[16:58:13]
[16:58:13] Folding@home Core Shutdown: EARLY_UNIT_END
[16:58:13] Finalizing output
[17:00:16] CoreStatus = 7B (123)
[17:00:16] Client-core communications error: ERROR 0x7b
[17:00:16] Deleting current work unit & continuing...
[17:02:36] - Preparing to get new work unit...
[17:02:36] + Attempting to get work packet
[17:02:36] - Connecting to assignment server
[17:02:36] - Successful: assigned to (171.64.65.64).
[17:02:36] + News From Folding@Home: Welcome to Folding@Home
[17:02:36] Loaded queue successfully.
[17:03:58] + Closed connections
[17:04:03]
[17:04:03] + Processing work unit
[17:04:03] Core required: FahCore_a1.exe
[17:04:03] Core found.
[17:04:03] Working on Unit 08 [May 20 17:04:03]
[17:04:03] + Working ...
[17:04:03]
[17:04:03] *------------------------------*
[17:04:03] Folding@Home Gromacs SMP Core
[17:04:03] Version 1.74 (March 10, 2007)
[17:04:03]
[17:04:03] Preparing to commence simulation
[17:04:03] - Ensuring status. Please wait.
[17:04:20] - Assembly optimizations manually forced on.
[17:04:20] - Not checking prior termination.
[17:04:24] - Expanded 2432663 -> 12862801 (decompressed 528.7 percent)
[17:04:24] - Starting from initial work packet
[17:04:25] e
[17:04:25] Warning:  check for stray files
[17:04:25] - StarWarning:  check for stray file
[17:04:25] Project: 2653 (Run 19, Clone 107, Gen
[17:04:25] Project: 2653 (Run 19, Clone 107, Gen 46)
[17:04:25]
[17:04:26] .
[17:04:26] Entering M.D.
[17:04:26] ations on if available.
[17:04:33] Protein: Protein in POPC
[17:04:33] Writing local files
[17:04:33] Extra SSE boost OK.
[17:04:35] of core data to disk...
[17:04:35]   ... Done.
[17:04:35] e size: 74log- Writing 8019 b- Writing 8829 bytes of core data to disk- Failed to dele- Failed to delete work/wudata_08.arc
[17:04:35] No C.P. to delete.
[17:04:35] Warning:  check for stray files
[17:04:35] o delete work/wudata_08.sas
[17:04:35] - Failed to delete work/wudata_08.pdo
[17:04:35] - Failed to delete work/wudata_08.xvg
[17:04:35]
[17:04:35] Folding@home Core Shutdown: EARLY_UNIT_END
[17:04:35] Finalizing output
Re: Project (Run 19, Clone 107, Gen 46)
You can submit partial result with qfix : viewtopic.php?f=8&t=191 ;)
ChelseaOilman
Post by ChelseaOilman »
toTOW wrote:You can submit partial result with qfix : viewtopic.php?f=8&t=191 ;)
Not for this WU. There's no wuresults_0x.dat file created.
I've received this WU many times and get the same results each time.
A thread for this WU has already been created here.
Flathead74
Post by Flathead74 »
Would someone please be so kind as to add the project number (2653) to the title?
Thank you.
DocJonz
Post by DocJonz »
Flathead74 wrote:Would someone please be so kind as to add the project number (2653) to the title?
Thank you.
Oops, I thought I did :oops:
If the WU is known to give problems, why is it still being dished out??
Re: Project: 2653 (Run 19, Clone 107, Gen 46)
I've just got the exact same WU on a linux Quad ... it's definitely a bed WU :
[14:31:30] Project: 2653 (Run 19, Clone 107, Gen 46)
[14:31:30]
[14:31:30] Assembly optimizations on if available.
[14:31:30] Entering M.D.
[14:31:47] l work packet
[14:31:47]
[14:31:47] Project: 2653 (Run 19, Clone 107, Gen 46)
[14:31:47]
[14:31:47] Entering M.D.
[14:31:47] ne 107, Gen 46)
[14:31:47]
[14:31:53] rotein in POPC
[14:31:53] Writing local files
[14:31:53] Extra SSE boost OK.
[14:31:53] boost OK.
[14:31:54] cal files
[14:31:54] Completed 0 out of 500000 steps (0 percent)
[14:31:58] CoreStatus = 0 (0)
[14:31:58] Client-core communications error: ERROR 0x0
[14:31:58] Deleting current work unit & continuing...
rbrandman
Pande Group Member
Post by rbrandman »
Thanks for your post. I've alerted the researcher in charge of this project.
Relly
