R9 280X Issue
dev_enjoys
Hardware configuration: AMD X2 5600+ 2.8 Ghz MSI-K9NGM3 2GB Ram ATI 5670 1GB
R9 280X Issue
Post by dev_enjoys »
Hi
I had been folding on this rig for months. Suddenly one of the cards stopped and gave me the following issue:
WU02:FS01:0x17:ERROR:exception: Force RMSE error of 320.041 with threshold of 5
*********************** Log Started 2014-12-04T20:16:39Z ***********************
20:16:39:************************* Folding@home Client *************************
20:16:39:      Website: http://folding.stanford.edu/
20:16:39:    Copyright: (c) 2009-2014 Stanford University
20:16:39:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:16:39:         Args: --open-web-control
20:16:39:       Config: C:/ProgramData/FAHClient/config.xml
20:16:39:******************************** Build ********************************
20:16:39:      Version: 7.4.4
20:16:39:         Date: Mar 4 2014
20:16:39:         Time: 20:26:54
20:16:39:      SVN Rev: 4130
20:16:39:       Branch: fah/trunk/client
20:16:39:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:16:39:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:16:39:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:16:39:     Platform: win32 XP
20:16:39:         Bits: 32
20:16:39:         Mode: Release
20:16:39:******************************* System ********************************
20:16:39:          CPU: AMD FX(tm)-8120 Eight-Core Processor
20:16:39:       CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
20:16:39:         CPUs: 8
20:16:39:       Memory: 15.95GiB
20:16:39:  Free Memory: 10.04GiB
20:16:39:      Threads: WINDOWS_THREADS
20:16:39:   OS Version: 6.1
20:16:39:  Has Battery: false
20:16:39:   On Battery: false
20:16:39:   UTC Offset: 5
20:16:39:          PID: 712
20:16:39:          CWD: C:/ProgramData/FAHClient
20:16:39:           OS: Windows 7 Ultimate
20:16:39:      OS Arch: AMD64
20:16:39:         GPUs: 2
20:16:39:        GPU 0: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
20:16:39:        GPU 1: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
20:16:39:         CUDA: Not detected
20:16:39:Win32 Service: false
20:16:39:***********************************************************************
20:16:39:<config>
20:16:39:  <service-description v='Folding@home Client'/>
20:16:39:  <service-restart v='true'/>
20:16:39:  <service-restart-delay v='5000'/>
20:16:39:
20:16:39:  <!-- Client Control -->
20:16:39:  <client-threads v='6'/>
20:16:39:  <cycle-rate v='4'/>
20:16:39:  <cycles v='-1'/>
20:16:39:  <data-directory v='.'/>
20:16:39:  <disable-sleep-when-active v='true'/>
20:16:39:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
20:16:39:  <exit-when-done v='false'/>
20:16:39:  <fold-anon v='false'/>
20:16:39:  <open-web-control v='true'/>
20:16:39:
20:16:39:  <!-- Configuration -->
20:16:39:  <config-rotate v='true'/>
20:16:39:  <config-rotate-dir v='configs'/>
20:16:39:  <config-rotate-max v='16'/>
20:16:39:
20:16:39:  <!-- Debugging -->
20:16:39:  <assignment-servers>
20:16:39:    assign3.stanford.edu:8080 assign4.stanford.edu:80
20:16:39:  </assignment-servers>
20:16:39:  <auth-as v='true'/>
20:16:39:  <capture-directory v='capture'/>
20:16:39:  <capture-on-error v='false'/>
20:16:39:  <capture-packets v='false'/>
20:16:39:  <capture-requests v='false'/>
20:16:39:  <capture-responses v='false'/>
20:16:39:  <capture-sockets v='false'/>
20:16:39:  <core-exec v='FahCore_$type'/>
20:16:39:  <core-wrapper-exec v='FAHCoreWrapper'/>
20:16:39:  <debug-sockets v='false'/>
20:16:39:  <exception-locations v='true'/>
20:16:39:  <gpu-assignment-servers>
20:16:39:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
20:16:39:  </gpu-assignment-servers>
20:16:39:  <stack-traces v='false'/>
20:16:39:
20:16:39:  <!-- Error Handling -->
20:16:39:  <max-slot-errors v='10'/>
20:16:39:  <max-unit-errors v='5'/>
20:16:39:
20:16:39:  <!-- Folding Core -->
20:16:39:  <checkpoint v='15'/>
20:16:39:  <core-dir v='cores'/>
20:16:39:  <core-priority v='low'/>
20:16:39:  <cpu-affinity v='false'/>
20:16:39:  <cpu-usage v='100'/>
20:16:39:  <gpu-usage v='100'/>
20:16:39:  <no-assembly v='false'/>
20:16:39:
20:16:39:  <!-- Folding Slot Configuration -->
20:16:39:  <cause v='ANY'/>
20:16:39:  <client-subtype v='STDCLI'/>
20:16:39:  <client-type v='normal'/>
20:16:39:  <cpu-species v='X86_AMD'/>
20:16:39:  <cpu-type v='AMD64'/>
20:16:39:  <cpus v='-1'/>
20:16:39:  <gpu v='true'/>
20:16:39:  <max-packet-size v='normal'/>
20:16:39:  <os-species v='UNKNOWN'/>
20:16:39:  <os-type v='WIN32'/>
20:16:39:  <project-key v='0'/>
20:16:39:  <smp v='true'/>
20:16:39:
20:16:39:  <!-- GUI -->
20:16:39:  <gui-enabled v='true'/>
20:16:39:
20:16:39:  <!-- HTTP Server -->
20:16:39:  <allow v='127.0.0.1'/>
20:16:39:  <connection-timeout v='60'/>
20:16:39:  <deny v='0/0'/>
20:16:39:  <http-addresses v='0:7396'/>
20:16:39:  <https-addresses v=''/>
20:16:39:  <max-connect-time v='900'/>
20:16:39:  <max-connections v='800'/>
20:16:39:  <max-request-length v='52428800'/>
20:16:39:  <min-connect-time v='300'/>
20:16:39:  <threads v='8'/>
20:16:39:
20:16:39:  <!-- Logging -->
20:16:39:  <log v='log.txt'/>
20:16:39:  <log-color v='false'/>
20:16:39:  <log-crlf v='true'/>
20:16:39:  <log-date v='false'/>
20:16:39:  <log-date-periodically v='21600'/>
20:16:39:  <log-debug v='true'/>
20:16:39:  <log-domain v='false'/>
20:16:39:  <log-header v='true'/>
20:16:39:  <log-level v='true'/>
20:16:39:  <log-no-info-header v='true'/>
20:16:39:  <log-redirect v='false'/>
20:16:39:  <log-rotate v='true'/>
20:16:39:  <log-rotate-dir v='logs'/>
20:16:39:  <log-rotate-max v='16'/>
20:16:39:  <log-short-level v='false'/>
20:16:39:  <log-simple-domains v='true'/>
20:16:39:  <log-thread-id v='false'/>
20:16:39:  <log-thread-prefix v='true'/>
20:16:39:  <log-time v='true'/>
20:16:39:  <log-to-screen v='true'/>
20:16:39:  <log-truncate v='false'/>
20:16:39:  <verbosity v='5'/>
20:16:39:
20:16:39:  <!-- Network -->
20:16:39:  <proxy v=':8080'/>
20:16:39:  <proxy-enable v='false'/>
20:16:39:  <proxy-pass v=''/>
20:16:39:  <proxy-user v=''/>
20:16:39:
20:16:39:  <!-- Process Control -->
20:16:39:  <child v='false'/>
20:16:39:  <daemon v='false'/>
20:16:39:  <pid v='false'/>
20:16:39:  <pid-file v='Folding@home Client.pid'/>
20:16:39:  <respawn v='false'/>
20:16:39:  <service v='false'/>
20:16:39:
20:16:39:  <!-- Remote Command Server -->
20:16:39:  <command-address v='0.0.0.0'/>
20:16:39:  <command-allow-no-pass v='127.0.0.1'/>
20:16:39:  <command-deny-no-pass v='0/0'/>
20:16:39:  <command-enable v='true'/>
20:16:39:  <command-port v='36330'/>
20:16:39:
20:16:39:  <!-- Slot Control -->
20:16:39:  <idle v='false'/>
20:16:39:  <max-shutdown-wait v='60'/>
20:16:39:  <pause-on-battery v='true'/>
20:16:39:  <pause-on-start v='false'/>
20:16:39:  <paused v='false'/>
20:16:39:  <power v='full'/>
20:16:39:
20:16:39:  <!-- User Information -->
20:16:39:  <machine-id v='0'/>
20:16:39:  <passkey v='********************************'/>
20:16:39:  <team v='224497'/>
20:16:39:  <user v='dev_enjoys'/>
20:16:39:
20:16:39:  <!-- Web Server -->
20:16:39:  <web-allow v='127.0.0.1'/>
20:16:39:  <web-deny v='0/0'/>
20:16:39:  <web-enable v='true'/>
20:16:39:
20:16:39:  <!-- Web Server Sessions -->
20:16:39:  <session-cookie v='sid'/>
20:16:39:  <session-lifetime v='86400'/>
20:16:39:  <session-timeout v='3600'/>
20:16:39:
20:16:39:  <!-- Work Unit Control -->
20:16:39:  <dump-after-deadline v='true'/>
20:16:39:  <max-queue v='16'/>
20:16:39:  <max-units v='0'/>
20:16:39:  <next-unit-percentage v='99'/>
20:16:39:  <stall-detection-enabled v='false'/>
20:16:39:  <stall-percent v='5'/>
20:16:39:  <stall-timeout v='1800'/>
20:16:39:
20:16:39:  <!-- Folding Slots -->
20:16:39:  <slot id='1' type='GPU'/>
20:16:39:  <slot id='2' type='GPU'/>
20:16:39:</config>
20:16:39:Trying to access database...
20:16:39:Successfully acquired database lock
20:16:39:Enabled folding slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970]
20:16:39:Enabled folding slot 02: READY gpu:1:Tahiti XT [Radeon R9 200/HD 7900/8970]
20:16:39:Started thread 5 on PID 712
20:16:39:WU01:FS02:Starting
20:16:39:Started thread 7 on PID 712
20:16:39:Started thread 6 on PID 712
20:16:39:Started thread 8 on PID 712
20:16:39:Started thread 9 on PID 712
20:16:39:Started thread 4 on PID 712
20:16:39:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 1 -gpu-vendor ati
20:16:39:WU01:FS02:Started FahCore on PID 7580
20:16:39:Started thread 10 on PID 712
20:16:39:WU01:FS02:Core PID:6472
20:16:39:WU01:FS02:FahCore 0x17 started
20:16:39:WU01:FS02:0x17:*********************** Log Started 2014-12-04T20:16:39Z ***********************
20:16:39:WU01:FS02:0x17:Project: 13001 (Run 8, Clone 0, Gen 95)
20:16:39:WU01:FS02:0x17:Unit: 0x0000009f538b3db7532851ff6e33f8ac
20:16:39:WU01:FS02:0x17:CPU: 0x00000000000000000000000000000000
20:16:39:WU01:FS02:0x17:Machine: 2
20:16:39:WU01:FS02:0x17:Digital signatures verified
20:16:39:WU01:FS02:0x17:Folding@home GPU core17
20:16:39:WU01:FS02:0x17:Version 0.0.52
20:16:40:WU00:FS01:Connecting to 171.67.108.200:80
20:16:40:WU01:FS02:0x17:  Found a checkpoint file
20:16:41:1:127.0.0.1 GET /ping?_=1417724200988&callback=jQuery190032100889552384615_1417724200987
20:16:41:WU00:FS01:Assigned to work server 140.163.4.233
20:16:41:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 140.163.4.233
20:16:41:WU00:FS01:Connecting to 140.163.4.233:8080
20:16:41:2:127.0.0.1 GET /?nocache=0.6827461130451411
20:16:42:WU00:FS01:Downloading 4.92MiB
20:16:42:3:127.0.0.1 GET /api/updates/set?_=1417724202062&sid=11d29bd79b2c38bab35396654586049f&update_id=0&update_path=/api/basic&update_rate=1
20:16:42:4:127.0.0.1 GET /api/updates/set?_=1417724202063&sid=11d29bd79b2c38bab35396654586049f&update_id=1&update_path=/api/slots&update_rate=1
20:16:42:5:127.0.0.1 GET /api/configured?_=1417724202064&sid=11d29bd79b2c38bab35396654586049f
20:16:43:Started thread 11 on PID 712
20:16:43:6:127.0.0.1 GET /?nocache=0.6827461130451411
20:16:43:8:127.0.0.1 GET /api/updates?_=1417724202065&sid=11d29bd79b2c38bab35396654586049f
20:16:44:9:127.0.0.1 GET /css/normalize.css
20:16:44:10:127.0.0.1 GET /css/main.css
20:16:44:11:127.0.0.1 GET /images/mail.png
20:16:44:12:127.0.0.1 GET /images/facebook.png
20:16:44:13:127.0.0.1 GET /images/twitter.png
20:16:48:WU00:FS01:Download 21.59%
20:16:54:WU00:FS01:Download 46.98%
20:17:00:WU00:FS01:Download 69.84%
20:17:06:WU00:FS01:Download 93.96%
20:17:07:WU00:FS01:Download complete
20:17:07:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10469 run:0 clone:394 gen:49 core:0x17 unit:0x00000053538b3db9538f42df9c678208
20:17:07:WU00:FS01:Starting
20:17:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:17:07:WU00:FS01:Started FahCore on PID 9656
20:17:07:Started thread 12 on PID 712
20:17:07:WU00:FS01:Core PID:9668
20:17:07:WU00:FS01:FahCore 0x17 started
20:17:08:WU00:FS01:0x17:*********************** Log Started 2014-12-04T20:17:07Z ***********************
20:17:08:WU00:FS01:0x17:Project: 10469 (Run 0, Clone 394, Gen 49)
20:17:08:WU00:FS01:0x17:Unit: 0x00000053538b3db9538f42df9c678208
20:17:08:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:17:08:WU00:FS01:0x17:Machine: 1
20:17:08:WU00:FS01:0x17:Reading tar file state.xml
20:17:09:WU00:FS01:0x17:Reading tar file system.xml
20:17:09:WU00:FS01:0x17:Reading tar file integrator.xml
20:17:09:WU00:FS01:0x17:Reading tar file core.xml
20:17:09:WU00:FS01:0x17:Digital signatures verified
20:17:09:WU00:FS01:0x17:Folding@home GPU core17
20:17:09:WU00:FS01:0x17:Version 0.0.52
20:20:23:WU01:FS02:0x17:Completed 1500000 out of 5000000 steps (30%)
20:20:23:WU01:FS02:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:20:35:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 326.746 with threshold of 5
20:20:35:WU00:FS01:0x17:Saving result file logfile_01.txt
20:20:35:WU00:FS01:0x17:Saving result file log.txt
20:20:35:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:20:36:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:20:36:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10469 run:0 clone:394 gen:49 core:0x17 unit:0x00000053538b3db9538f42df9c678208
20:20:36:WU00:FS01:Uploading 2.28KiB to 140.163.4.233
20:20:36:WU00:FS01:Connecting to 140.163.4.233:8080
20:20:36:WU02:FS01:Connecting to 171.67.108.200:80
20:20:37:WU00:FS01:Upload complete
20:20:37:WU00:FS01:Server responded WORK_ACK (400)
20:20:37:WU00:FS01:Cleaning up
20:20:38:WU02:FS01:Assigned to work server 140.163.4.233
20:20:38:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 140.163.4.233
20:20:38:WU02:FS01:Connecting to 140.163.4.233:8080
20:20:39:WU02:FS01:Downloading 4.32MiB
20:20:45:WU02:FS01:Download 21.71%
20:20:51:WU02:FS01:Download 47.77%
20:20:57:WU02:FS01:Download 75.27%
20:21:03:WU02:FS01:Download 94.09%
20:21:05:WU02:FS01:Download complete
20:21:05:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10468 run:0 clone:6 gen:68 core:0x17 unit:0x00000075538b3db95388cf804c0d5a4e
20:21:05:WU02:FS01:Starting
20:21:05:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:21:05:WU02:FS01:Started FahCore on PID 6420
20:21:05:Started thread 13 on PID 712
20:21:05:WU02:FS01:Core PID:10048
20:21:05:WU02:FS01:FahCore 0x17 started
20:21:06:WU02:FS01:0x17:*********************** Log Started 2014-12-04T20:21:05Z ***********************
20:21:06:WU02:FS01:0x17:Project: 10468 (Run 0, Clone 6, Gen 68)
20:21:06:WU02:FS01:0x17:Unit: 0x00000075538b3db95388cf804c0d5a4e
20:21:06:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:21:06:WU02:FS01:0x17:Machine: 1
20:21:06:WU02:FS01:0x17:Reading tar file state.xml
20:21:07:WU02:FS01:0x17:Reading tar file system.xml
20:21:07:WU02:FS01:0x17:Reading tar file integrator.xml
20:21:07:WU02:FS01:0x17:Reading tar file core.xml
20:21:07:WU02:FS01:0x17:Digital signatures verified
20:21:07:WU02:FS01:0x17:Folding@home GPU core17
20:21:07:WU02:FS01:0x17:Version 0.0.52
20:23:37:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 311.41 with threshold of 5
20:23:37:WU02:FS01:0x17:Saving result file logfile_01.txt
20:23:37:WU02:FS01:0x17:Saving result file log.txt
20:23:37:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:23:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:23:38:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:10468 run:0 clone:6 gen:68 core:0x17 unit:0x00000075538b3db95388cf804c0d5a4e
20:23:38:WU02:FS01:Uploading 2.27KiB to 140.163.4.233
20:23:38:WU02:FS01:Connecting to 140.163.4.233:8080
20:23:38:WU00:FS01:Connecting to 171.67.108.200:80
20:23:38:WU02:FS01:Upload complete
20:23:38:WU02:FS01:Server responded WORK_ACK (400)
20:23:38:WU02:FS01:Cleaning up
20:23:39:WU00:FS01:Assigned to work server 171.67.108.52
20:23:39:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 171.67.108.52
20:23:39:WU00:FS01:Connecting to 171.67.108.52:8080
20:23:41:WU00:FS01:Downloading 1.52MiB
20:23:47:WU00:FS01:Download 53.30%
20:23:50:WU00:FS01:Download complete
20:23:50:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:795 clone:4 gen:47 core:0x17 unit:0x000000466652edc45399f552ee1337f7
20:23:50:WU00:FS01:Starting
20:23:50:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:23:50:WU00:FS01:Started FahCore on PID 4360
20:23:50:Started thread 14 on PID 712
20:23:50:WU00:FS01:Core PID:8448
20:23:50:WU00:FS01:FahCore 0x17 started
20:23:50:WU00:FS01:0x17:*********************** Log Started 2014-12-04T20:23:50Z ***********************
20:23:50:WU00:FS01:0x17:Project: 9201 (Run 795, Clone 4, Gen 47)
20:23:50:WU00:FS01:0x17:Unit: 0x000000466652edc45399f552ee1337f7
20:23:50:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:23:50:WU00:FS01:0x17:Machine: 1
20:23:50:WU00:FS01:0x17:Reading tar file state.xml
20:23:51:WU00:FS01:0x17:Reading tar file system.xml
20:23:51:WU00:FS01:0x17:Reading tar file integrator.xml
20:23:51:WU00:FS01:0x17:Reading tar file core.xml
20:23:51:WU00:FS01:0x17:Digital signatures verified
20:23:51:WU00:FS01:0x17:Folding@home GPU core17
20:23:51:WU00:FS01:0x17:Version 0.0.52
20:24:19:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 654.987 with threshold of 5
20:24:19:WU00:FS01:0x17:Saving result file logfile_01.txt
20:24:19:WU00:FS01:0x17:Saving result file log.txt
20:24:19:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:24:19:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:24:19:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:795 clone:4 gen:47 core:0x17 unit:0x000000466652edc45399f552ee1337f7
20:24:19:WU00:FS01:Uploading 2.32KiB to 171.67.108.52
20:24:19:WU00:FS01:Connecting to 171.67.108.52:8080
20:24:20:WU02:FS01:Connecting to 171.67.108.200:80
20:24:20:WU00:FS01:Upload complete
20:24:20:WU00:FS01:Server responded WORK_ACK (400)
20:24:20:WU00:FS01:Cleaning up
20:24:21:WU02:FS01:Assigned to work server 171.67.108.52
20:24:21:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 171.67.108.52
20:24:21:WU02:FS01:Connecting to 171.67.108.52:8080
20:24:23:WU02:FS01:Downloading 1.53MiB
20:24:29:WU02:FS01:Download 49.15%
20:24:32:WU02:FS01:Download complete
20:24:33:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:470 clone:2 gen:59 core:0x17 unit:0x000000516652edc45399e8863a233391
20:24:33:WU02:FS01:Starting
20:24:33:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:24:33:WU02:FS01:Started FahCore on PID 3564
20:24:33:Started thread 15 on PID 712
20:24:33:WU02:FS01:Core PID:768
20:24:33:WU02:FS01:FahCore 0x17 started
20:24:33:WU02:FS01:0x17:*********************** Log Started 2014-12-04T20:24:33Z ***********************
20:24:33:WU02:FS01:0x17:Project: 9201 (Run 470, Clone 2, Gen 59)
20:24:33:WU02:FS01:0x17:Unit: 0x000000516652edc45399e8863a233391
20:24:33:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:24:33:WU02:FS01:0x17:Machine: 1
20:24:33:WU02:FS01:0x17:Reading tar file state.xml
20:24:33:WU02:FS01:0x17:Reading tar file system.xml
20:24:33:WU02:FS01:0x17:Reading tar file integrator.xml
20:24:33:WU02:FS01:0x17:Reading tar file core.xml
20:24:33:WU02:FS01:0x17:Digital signatures verified
20:24:33:WU02:FS01:0x17:Folding@home GPU core17
20:24:33:WU02:FS01:0x17:Version 0.0.52
20:25:02:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 268.125 with threshold of 5
20:25:02:WU02:FS01:0x17:Saving result file logfile_01.txt
20:25:02:WU02:FS01:0x17:Saving result file log.txt
20:25:02:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:25:03:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:25:03:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:470 clone:2 gen:59 core:0x17 unit:0x000000516652edc45399e8863a233391
20:25:03:WU02:FS01:Uploading 2.32KiB to 171.67.108.52
20:25:03:WU02:FS01:Connecting to 171.67.108.52:8080
20:25:03:WU00:FS01:Connecting to 171.67.108.200:80
20:25:04:WU02:FS01:Upload complete
20:25:04:WU02:FS01:Server responded WORK_ACK (400)
20:25:04:WU02:FS01:Cleaning up
20:25:05:WU00:FS01:Assigned to work server 171.67.108.52
20:25:05:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 171.67.108.52
20:25:05:WU00:FS01:Connecting to 171.67.108.52:8080
20:25:06:WU00:FS01:Downloading 1.52MiB
20:25:12:WU00:FS01:Download 53.54%
20:25:18:WU00:FS01:Download 98.84%
20:25:18:WU00:FS01:Download complete
20:25:18:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:85 clone:3 gen:58 core:0x17 unit:0x000000516652edc45399d96149da25e2
20:25:18:WU00:FS01:Starting
20:25:18:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:25:18:WU00:FS01:Started FahCore on PID 5280
20:25:18:Started thread 16 on PID 712
20:25:18:WU00:FS01:Core PID:7428
20:25:18:WU00:FS01:FahCore 0x17 started
20:25:18:WU00:FS01:0x17:*********************** Log Started 2014-12-04T20:25:18Z ***********************
20:25:18:WU00:FS01:0x17:Project: 9201 (Run 85, Clone 3, Gen 58)
20:25:18:WU00:FS01:0x17:Unit: 0x000000516652edc45399d96149da25e2
20:25:18:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:25:18:WU00:FS01:0x17:Machine: 1
20:25:18:WU00:FS01:0x17:Reading tar file state.xml
20:25:18:WU00:FS01:0x17:Reading tar file system.xml
20:25:18:WU00:FS01:0x17:Reading tar file integrator.xml
20:25:18:WU00:FS01:0x17:Reading tar file core.xml
20:25:18:WU00:FS01:0x17:Digital signatures verified
20:25:18:WU00:FS01:0x17:Folding@home GPU core17
20:25:18:WU00:FS01:0x17:Version 0.0.52
20:25:48:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 710.448 with threshold of 5
20:25:48:WU00:FS01:0x17:Saving result file logfile_01.txt
20:25:48:WU00:FS01:0x17:Saving result file log.txt
20:25:48:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:25:48:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:25:48:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:85 clone:3 gen:58 core:0x17 unit:0x000000516652edc45399d96149da25e2
20:25:48:WU00:FS01:Uploading 2.33KiB to 171.67.108.52
20:25:48:WU00:FS01:Connecting to 171.67.108.52:8080
20:25:49:WU02:FS01:Connecting to 171.67.108.200:80
20:25:49:WU00:FS01:Upload complete
20:25:49:WU00:FS01:Server responded WORK_ACK (400)
20:25:49:WU00:FS01:Cleaning up
20:25:50:WU02:FS01:Assigned to work server 140.163.4.231
20:25:50:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 140.163.4.231
20:25:50:WU02:FS01:Connecting to 140.163.4.231:8080
20:25:51:WU02:FS01:Downloading 4.84MiB
20:25:57:WU02:FS01:Download 19.38%
20:26:03:WU02:FS01:Download 43.92%
20:26:09:WU02:FS01:Download 68.46%
20:26:15:WU02:FS01:Download 91.71%
20:26:17:WU02:FS01:Download complete
20:26:17:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13001 run:287 clone:1 gen:60 core:0x17 unit:0x00000077538b3db75328a10f18165e0f
20:26:17:WU02:FS01:Starting
20:26:17:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:26:17:WU02:FS01:Started FahCore on PID 9408
20:26:17:Started thread 17 on PID 712
20:26:17:WU02:FS01:Core PID:9468
20:26:17:WU02:FS01:FahCore 0x17 started
20:26:17:WU02:FS01:0x17:*********************** Log Started 2014-12-04T20:26:17Z ***********************
20:26:17:WU02:FS01:0x17:Project: 13001 (Run 287, Clone 1, Gen 60)
20:26:17:WU02:FS01:0x17:Unit: 0x00000077538b3db75328a10f18165e0f
20:26:17:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:26:17:WU02:FS01:0x17:Machine: 1
20:26:17:WU02:FS01:0x17:Reading tar file state.xml
20:26:18:WU02:FS01:0x17:Reading tar file system.xml
20:26:19:WU02:FS01:0x17:Reading tar file integrator.xml
20:26:19:WU02:FS01:0x17:Reading tar file core.xml
20:26:19:WU02:FS01:0x17:Digital signatures verified
20:26:19:WU02:FS01:0x17:Folding@home GPU core17
20:26:19:WU02:FS01:0x17:Version 0.0.52
20:28:21:WU01:FS02:0x17:Completed 1550000 out of 5000000 steps (31%)
20:29:36:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 290.872 with threshold of 5
20:29:36:WU02:FS01:0x17:Saving result file logfile_01.txt
20:29:36:WU02:FS01:0x17:Saving result file log.txt
20:29:36:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:29:36:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:29:36:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13001 run:287 clone:1 gen:60 core:0x17 unit:0x00000077538b3db75328a10f18165e0f
20:29:36:WU02:FS01:Uploading 2.34KiB to 140.163.4.231
20:29:36:WU02:FS01:Connecting to 140.163.4.231:8080
20:29:37:WU00:FS01:Connecting to 171.67.108.200:80
20:29:37:WU02:FS01:Upload complete
20:29:37:WU02:FS01:Server responded WORK_ACK (400)
20:29:37:WU02:FS01:Cleaning up
20:29:38:WU00:FS01:Assigned to work server 140.163.4.231
20:29:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 140.163.4.231
20:29:38:WU00:FS01:Connecting to 140.163.4.231:8080
20:29:39:WU00:FS01:Downloading 4.83MiB
20:29:45:WU00:FS01:Download 14.22%
20:29:51:WU00:FS01:Download 36.20%
20:29:57:WU00:FS01:Download 60.76%
20:30:03:WU00:FS01:Download 85.32%
20:30:06:WU00:FS01:Download complete
20:30:06:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13000 run:1903 clone:4 gen:44 core:0x17 unit:0x00000059538b3db75311b5fc1b9043bc
20:30:06:WU00:FS01:Starting
20:30:06:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:30:06:WU00:FS01:Started FahCore on PID 8680
20:30:06:Started thread 18 on PID 712
20:30:06:WU00:FS01:Core PID:2172
20:30:06:WU00:FS01:FahCore 0x17 started
20:30:07:WU00:FS01:0x17:*********************** Log Started 2014-12-04T20:30:07Z ***********************
20:30:07:WU00:FS01:0x17:Project: 13000 (Run 1903, Clone 4, Gen 44)
20:30:07:WU00:FS01:0x17:Unit: 0x00000059538b3db75311b5fc1b9043bc
20:30:07:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:30:07:WU00:FS01:0x17:Machine: 1
20:30:07:WU00:FS01:0x17:Reading tar file state.xml
20:30:08:WU00:FS01:0x17:Reading tar file system.xml
20:30:08:WU00:FS01:0x17:Reading tar file integrator.xml
20:30:08:WU00:FS01:0x17:Reading tar file core.xml
20:30:08:WU00:FS01:0x17:Digital signatures verified
20:30:08:WU00:FS01:0x17:Folding@home GPU core17
20:30:08:WU00:FS01:0x17:Version 0.0.52
20:33:23:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 216.823 with threshold of 5
20:33:23:WU00:FS01:0x17:Saving result file logfile_01.txt
20:33:23:WU00:FS01:0x17:Saving result file log.txt
20:33:23:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:33:23:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:33:23:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13000 run:1903 clone:4 gen:44 core:0x17 unit:0x00000059538b3db75311b5fc1b9043bc
20:33:23:WU00:FS01:Uploading 2.33KiB to 140.163.4.231
20:33:23:WU00:FS01:Connecting to 140.163.4.231:8080
20:33:23:WU02:FS01:Connecting to 171.67.108.200:80
20:33:24:WU00:FS01:Upload complete
20:33:24:WU00:FS01:Server responded WORK_ACK (400)
20:33:24:WU00:FS01:Cleaning up
20:33:25:WU02:FS01:Assigned to work server 171.67.108.52
20:33:25:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 171.67.108.52
20:33:25:WU02:FS01:Connecting to 171.67.108.52:8080
20:33:26:WU02:FS01:Downloading 1.53MiB
20:33:32:WU02:FS01:Download 40.93%
20:33:38:WU02:FS01:Download 73.67%
20:33:46:WU02:FS01:Download 85.95%
20:33:52:WU02:FS01:Download 98.22%
20:33:52:WU02:FS01:Download complete
20:33:52:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:468 clone:4 gen:64 core:0x17 unit:0x0000005e6652edc45399e8766f7c310f
20:33:52:WU02:FS01:Starting
20:33:52:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:33:52:WU02:FS01:Started FahCore on PID 9420
20:33:52:Started thread 19 on PID 712
20:33:52:WU02:FS01:Core PID:9852
20:33:52:WU02:FS01:FahCore 0x17 started
20:33:52:WU02:FS01:0x17:*********************** Log Started 2014-12-04T20:33:52Z ***********************
20:33:52:WU02:FS01:0x17:Project: 9201 (Run 468, Clone 4, Gen 64)
20:33:52:WU02:FS01:0x17:Unit: 0x0000005e6652edc45399e8766f7c310f
20:33:52:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:33:52:WU02:FS01:0x17:Machine: 1
20:33:52:WU02:FS01:0x17:Reading tar file state.xml
20:33:52:WU02:FS01:0x17:Reading tar file system.xml
20:33:53:WU02:FS01:0x17:Reading tar file integrator.xml
20:33:53:WU02:FS01:0x17:Reading tar file core.xml
20:33:53:WU02:FS01:0x17:Digital signatures verified
20:33:53:WU02:FS01:0x17:Folding@home GPU core17
20:33:53:WU02:FS01:0x17:Version 0.0.52
20:34:21:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 376.661 with threshold of 5
20:34:21:WU02:FS01:0x17:Saving result file logfile_01.txt
20:34:21:WU02:FS01:0x17:Saving result file log.txt
20:34:21:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:34:21:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:34:21:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9201 run:468 clone:4 gen:64 core:0x17 unit:0x0000005e6652edc45399e8766f7c310f
20:34:21:WU02:FS01:Uploading 2.33KiB to 171.67.108.52
20:34:21:WU02:FS01:Connecting to 171.67.108.52:8080
20:34:22:WU00:FS01:Connecting to 171.67.108.200:80
20:34:22:WU02:FS01:Upload complete
20:34:22:WU02:FS01:Server responded WORK_ACK (400)
20:34:22:WU02:FS01:Cleaning up
20:34:23:WU00:FS01:Assigned to work server 140.163.4.233
20:34:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 140.163.4.233
20:34:23:WU00:FS01:Connecting to 140.163.4.233:8080
20:34:24:WU00:FS01:Downloading 2.29MiB
20:34:30:WU00:FS01:Download 49.06%
20:34:35:WU00:FS01:Download complete
20:34:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10466 run:0 clone:157 gen:54 core:0x17 unit:0x00000079538b3db953822e2b8e715875
20:34:35:WU00:FS01:Starting
20:34:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:34:35:WU00:FS01:Started FahCore on PID 7756
20:34:35:Started thread 20 on PID 712
20:34:35:WU00:FS01:Core PID:9436
20:34:35:WU00:FS01:FahCore 0x17 started
20:34:36:WU00:FS01:0x17:*********************** Log Started 2014-12-04T20:34:36Z ***********************
20:34:36:WU00:FS01:0x17:Project: 10466 (Run 0, Clone 157, Gen 54)
20:34:36:WU00:FS01:0x17:Unit: 0x00000079538b3db953822e2b8e715875
20:34:36:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:34:36:WU00:FS01:0x17:Machine: 1
20:34:36:WU00:FS01:0x17:Reading tar file state.xml
20:34:36:WU00:FS01:0x17:Reading tar file system.xml
20:34:36:WU00:FS01:0x17:Reading tar file integrator.xml
20:34:36:WU00:FS01:0x17:Reading tar file core.xml
20:34:36:WU00:FS01:0x17:Digital signatures verified
20:34:36:WU00:FS01:0x17:Folding@home GPU core17
20:34:36:WU00:FS01:0x17:Version 0.0.52
20:35:26:WU00:FS01:0x17:ERROR:exception: Force RMSE error of 634.371 with threshold of 5
20:35:26:WU00:FS01:0x17:Saving result file logfile_01.txt
20:35:26:WU00:FS01:0x17:Saving result file log.txt
20:35:26:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:35:26:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:35:26:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10466 run:0 clone:157 gen:54 core:0x17 unit:0x00000079538b3db953822e2b8e715875
20:35:26:WU00:FS01:Uploading 2.27KiB to 140.163.4.233
20:35:26:WU00:FS01:Connecting to 140.163.4.233:8080
20:35:26:WU02:FS01:Connecting to 171.67.108.200:80
20:35:27:WU00:FS01:Upload complete
20:35:27:WU00:FS01:Server responded WORK_ACK (400)
20:35:27:WU00:FS01:Cleaning up
20:35:28:WU02:FS01:Assigned to work server 140.163.4.231
20:35:28:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 140.163.4.231
20:35:28:WU02:FS01:Connecting to 140.163.4.231:8080
20:35:30:WU02:FS01:Downloading 4.83MiB
20:35:36:WU02:FS01:Download 20.68%
20:35:42:WU02:FS01:Download 34.90%
20:35:48:WU02:FS01:Download 53.00%
20:35:54:WU02:FS01:Download 77.56%
20:35:59:WU02:FS01:Download complete
20:35:59:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13000 run:1927 clone:0 gen:64 core:0x17 unit:0x00000088538b3db75311bca752727201
20:35:59:WU02:FS01:Starting
20:35:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 712 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:35:59:WU02:FS01:Started FahCore on PID 8680
20:35:59:Started thread 21 on PID 712
20:35:59:WU02:FS01:Core PID:4480
20:35:59:WU02:FS01:FahCore 0x17 started
20:35:59:WU02:FS01:0x17:*********************** Log Started 2014-12-04T20:35:59Z ***********************
20:35:59:WU02:FS01:0x17:Project: 13000 (Run 1927, Clone 0, Gen 64)
20:35:59:WU02:FS01:0x17:Unit: 0x00000088538b3db75311bca752727201
20:35:59:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:35:59:WU02:FS01:0x17:Machine: 1
20:35:59:WU02:FS01:0x17:Reading tar file state.xml
20:36:00:WU02:FS01:0x17:Reading tar file system.xml
20:36:01:WU02:FS01:0x17:Reading tar file integrator.xml
20:36:01:WU02:FS01:0x17:Reading tar file core.xml
20:36:01:WU02:FS01:0x17:Digital signatures verified
20:36:01:WU02:FS01:0x17:Folding@home GPU core17
20:36:01:WU02:FS01:0x17:Version 0.0.52
20:36:01:WU01:FS02:0x17:Completed 1600000 out of 5000000 steps (32%)
20:39:15:WU02:FS01:0x17:ERROR:exception: Force RMSE error of 320.041 with threshold of 5
20:39:15:WU02:FS01:0x17:Saving result file logfile_01.txt
20:39:15:WU02:FS01:0x17:Saving result file log.txt
20:39:15:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:39:16:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:39:16:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:1927 clone:0 gen:64 core:0x17 unit:0x00000088538b3db75311bca752727201
20:39:16:WU02:FS01:Uploading 2.33KiB to 140.163.4.231
20:39:16:WU02:FS01:Connecting to 140.163.4.231:8080
20:39:16:WU02:FS01:Upload complete
20:39:17:WU02:FS01:Server responded WORK_ACK (400)
20:39:17:WU02:FS01:Cleaning up
20:44:03:WU01:FS02:0x17:Completed 1650000 out of 5000000 steps (33%)
20:51:48:WU01:FS02:0x17:Completed 1700000 out of 5000000 steps (34%)
20:59:34:WU01:FS02:0x17:Completed 1750000 out of 5000000 steps (35%)
21:07:39:WU01:FS02:0x17:Completed 1800000 out of 5000000 steps (36%)
21:15:25:WU01:FS02:0x17:Completed 1850000 out of 5000000 steps (37%)
21:23:29:WU01:FS02:0x17:Completed 1900000 out of 5000000 steps (38%)
21:31:15:WU01:FS02:0x17:Completed 1950000 out of 5000000 steps (39%)
21:36:09:Started thread 22 on PID 712
I have reinstalled the client after deleting all the old data, still nothing.
System specs:
