GTX 460 Errors
TemurAmir
GTX 460 Errors
Post by TemurAmir »
Hi, I've tried adding a gpu slot with my gtx 460. Folding will not initiate, and when I attempt to run, an error message pops saying that FAH_Core17 has stopped responding. Folding with cpu still proceeds normally. My current driver version is 344.75.
*********************** Log Started 2014-11-29T19:12:20Z ***********************
19:15:44:WARNING:WU01:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail
19:15:50:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:15:50:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
19:15:54:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:15:54:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
19:16:54:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:16:54:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
19:17:54:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:17:54:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073740940 = 0xc0000374)
]Image
ChristianVirtual
Re: GTX 460 Errors
Post by ChristianVirtual »
Could you please send more log file ... First lines with system info and config, also what WU go assigned and failed.
Plus for older cards the older driver most work better (like 30x.x)
And please put the inside [ code ] elements you can get via "Full Editor"
Re: GTX 460 Errors
How much is the 460 overclocked?
