Missing Stats for Submitted Unit
vmlemon
Post by vmlemon »
Hi all,
I've just started folding again, after a long time (mostly since my current PC is actually capable of completing a WU within a finite time, and I wanted to participate in FoldingCoin), and so far I've submitted a grand total of 3 work units, if my client logs are to be believed...
However, it seems that I've only accrued stat points for 2 of these units (one of which I submitted, today; and the other of which was submitted on the 21th of this month), and not a unit that my client claims was WORK_ACK'd on the 25th of this month.
Any reason why, out of curiosity? (And I'll happily paste my log somewhere, if necessary).
Thank you in advance,
Tyson.
davidcoton
Re: Missing Stats for Submitted Unit
Post by davidcoton »
You'll need to post at least the project, run, clone, generation (prcg) numbers of the missing unit, and your folding name, so that a mod can check the credit. If in doubt post the log, including the header sections containing config info and the upload of the unit in question.
vmlemon
Post by vmlemon »
Thanks, David.
Apologies for forgetting to include my profile details (user 19CjNNy9VjsMMLmKeM7UePVpwMVwHpbhqv, team 226728).
Here's the log details for the final stretch of the work unit in question...
15:18:32:WU01:FS01:0x17:*********************** Log Started 2014-11-25T15:18:32Z ***********************
15:18:32:WU01:FS01:0x17:Project: 13001 (Run 155, Clone 6, Gen 53)
15:18:32:WU01:FS01:0x17:Unit: 0x0000005a538b3db753287bba73a97430
15:18:32:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
15:18:32:WU01:FS01:0x17:Machine: 1
15:18:32:WU01:FS01:0x17:Digital signatures verified
15:18:32:WU01:FS01:0x17:Folding@home GPU core17
15:18:32:WU01:FS01:0x17:Version 0.0.52
15:18:36:WU01:FS01:0x17:  Found a checkpoint file
15:18:38:WU02:FS00:0xa4:Using Gromacs checkpoints
15:18:38:WU02:FS00:0xa4:Mapping NT from 3 to 3
15:18:42:WU02:FS00:0xa4:Resuming from checkpoint
15:18:42:WU02:FS00:0xa4:Verified 02/wudata_01.log
15:18:42:WU02:FS00:0xa4:Verified 02/wudata_01.trr
15:18:42:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
15:18:42:WU02:FS00:0xa4:Verified 02/wudata_01.edr
15:18:43:WU02:FS00:0xa4:Completed 206730 out of 250000 steps  (82%)
15:19:09:Saving configuration to config.xml
15:19:09:<config>
15:19:09:  <!-- Slot Control -->
15:19:09:  <power v='full'/>
15:19:09:
15:19:09:  <!-- User Information -->
15:19:09:  <passkey v='********************************'/>
15:19:09:  <team v='226728'/>
15:19:09:  <user v='19CjNNy9VjsMMLmKeM7UePVpwMVwHpbhqv'/>
15:19:09:
15:19:09:  <!-- Folding Slots -->
15:19:09:  <slot id='0' type='CPU'/>
15:19:09:  <slot id='1' type='GPU'/>
15:19:09:</config>
15:21:00:WU02:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
15:30:36:WU01:FS01:0x17:Completed 125000 out of 5000000 steps (2%)
15:30:36:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:33:20:WU02:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
15:43:03:WU02:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
15:53:47:WU02:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
16:03:47:WU02:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
16:16:46:WU02:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
16:39:19:WU02:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
16:53:21:WU02:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
17:04:06:WU02:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
17:24:38:WU02:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
17:37:30:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
17:37:59:WU02:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
17:48:21:WU02:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
17:57:42:WU02:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
18:06:17:WU02:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
18:14:45:WU02:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
18:26:06:WU02:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
18:35:02:WU02:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
18:35:03:WU00:FS00:Connecting to 171.67.108.200:8080
18:35:03:WU00:FS00:Assigned to work server 171.64.65.124
18:35:03:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 171.64.65.124
18:35:03:WU00:FS00:Connecting to 171.64.65.124:8080
18:35:05:WU00:FS00:Downloading 808.84KiB
18:35:07:WU00:FS00:Download complete
18:35:07:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9007 run:256 clone:2 gen:129 core:0xa4 unit:0x00000093664f2de4533b346676883ac7
18:47:15:WU02:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
18:47:17:WU02:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
18:47:27:WU02:FS00:0xa4:
18:47:27:WU02:FS00:0xa4:Finished Work Unit:
18:47:27:WU02:FS00:0xa4:- Reading up to 905376 from "02/wudata_01.trr": Read 905376
18:47:27:WU02:FS00:0xa4:trr file hash check passed.
18:47:27:WU02:FS00:0xa4:- Reading up to 829520 from "02/wudata_01.xtc": Read 829520
18:47:27:WU02:FS00:0xa4:xtc file hash check passed.
18:47:27:WU02:FS00:0xa4:edr file hash check passed.
18:47:27:WU02:FS00:0xa4:logfile size: 33260
18:47:27:WU02:FS00:0xa4:Leaving Run
18:47:29:WU02:FS00:0xa4:- Writing 1770644 bytes of core data to disk...
18:47:31:WU02:FS00:0xa4:Done: 1770132 -> 1704488 (compressed to 96.2 percent)
18:47:31:WU02:FS00:0xa4:  ... Done.
18:47:32:WU02:FS00:0xa4:- Shutting down core
18:47:32:WU02:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
18:47:33:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:47:33:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9012 run:240 clone:0 gen:138 core:0xa4 unit:0x000000a2664f2de453c87c410279e7f6
18:47:33:WU02:FS00:Uploading 1.63MiB to 171.64.65.124
18:47:33:WU00:FS00:Starting
18:47:33:WU02:FS00:
18:47:33:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 8008 -checkpoint 15 -np 3
18:47:33:WU00:FS00:Started FahCore on PID 1184
18:47:34:WU00:FS00:Core PID:10568
18:47:34:WU00:FS00:FahCore 0xa4 started
18:47:34:WU00:FS00:0xa4:
18:47:34:WU00:FS00:0xa4:*------------------------------*
18:47:34:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
18:47:34:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
18:47:34:WU00:FS00:0xa4:Preparing to commence simulation
18:47:34:WU00:FS00:0xa4:- Looking at optimizations...
18:47:34:WU00:FS00:0xa4:- Created dyn
18:47:34:WU00:FS00:0xa4:- Files status OK
18:47:34:WU00:FS00:0xa4:- Expanded 827745 -> 1400900 (decompressed 169.2 percent)
18:47:34:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=827745 data_size=1400900, decompressed_data_size=1400900 diff=0
18:47:34:WU00:FS00:0xa4:- Digital signature verified
18:47:34:WU00:FS00:0xa4:Project: 9007 (Run 256, Clone 2, Gen 129)
18:47:34:WU00:FS00:0xa4:Assembly optimizations on if available.
18:47:34:WU00:FS00:0xa4:Entering M.D.
18:47:39:WU02:FS00:Upload 15.38%
18:47:40:WU00:FS00:0xa4:Mapping NT from 3 to 3
18:47:41:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
18:47:45:WU02:FS00:Upload 30.75%
18:47:52:WU02:FS00:Upload 49.97%
18:47:59:WU02:FS00:Upload 69.19%
18:48:06:WU02:FS00:Upload 84.56%
18:48:12:WU02:FS00:Upload 99.94%
18:48:14:WU02:FS00:Upload complete
18:48:14:WU02:FS00:Server responded WORK_ACK (400)
18:48:14:WU02:FS00:Final credit estimate, 301.00 points
18:48:14:WU02:FS00:Cleaning up
I hope that helps. Thanks once again.
There is no entry yet for this WU in the stats database. There is another report of a WU from this WS not making it into the database - viewtopic.php?f=19&t=27060, the manager for that WS is already looking into the problem. It looks like a results log was not processed, this has happened occasionally in the past and eventually they have tracked down the missing points and credited them. I will pass on your report as well.
vmlemon
Post by vmlemon »
Thanks for letting me know, Joe.
Glad to know that I'm not the only one in the same boat. :)
sryckbos
Pande Group Member
Post by sryckbos »
Just chased down the problem. It was the same results log that wasn't processed as in viewtopic.php?f=19&t=27060&p=271755#p271755. It should all be credited correctly now.
Sorry about this!
Steven
vmlemon
Post by vmlemon »
Hi Steven,
Thanks for letting me know that it's all fixed. Hoping to continue contributing in the future!
Take care,
Tyson.
