NVIDIA GeForse 8500 Failing
MaDDogLV
Post by MaDDogLV »
Hello i`m realy want to fold on this card but somthing is lagging it and i cant find a problem so I turn 4 help to u guys :)
------------------------ LOG -------------------------------
07:49:17:WU00:FS01:Valid core signature
07:49:17:WARNING:WU00:FS01:FahCore has not changed since last download, aborting core update
07:49:17:WU00:FS01:Starting
07:49:17:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/beta/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 7228 -checkpoint 3 -gpu 0 -gpu-vendor nvidia -gpu 0 -forcegpu nvidia_g80
07:49:17:WU00:FS01:Started FahCore on PID 9832
07:49:17:WU00:FS01:Core PID:6636
07:49:17:WU00:FS01:FahCore 0x15 started
07:49:18:WU00:FS01:0x15:
07:49:18:WU00:FS01:0x15:*------------------------------*
07:49:18:WU00:FS01:0x15:Folding@Home GPU Core
07:49:18:WU00:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
07:49:18:WU00:FS01:0x15:Build host             AmoebaRemote
07:49:18:WU00:FS01:0x15:Board Type             NVIDIA/CUDA
07:49:18:WU00:FS01:0x15:Window's signal control handler registered.
07:49:18:WU00:FS01:0x15:Preparing to commence simulation
07:49:18:WU00:FS01:0x15:- Looking at optimizations...
07:49:18:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
07:49:18:WU00:FS01:0x15:- Created dyn
07:49:18:WU00:FS01:0x15:- Files status OK
07:49:18:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
07:49:18:WU00:FS01:0x15:- Expanded 124797 -> 501826 (decompressed 402.1 percent)
07:49:18:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=124797 data_size=501826, decompressed_data_size=501826 diff=0
07:49:18:WU00:FS01:0x15:- Digital signature verified
07:49:18:WU00:FS01:0x15:Project: 7623 (Run 72, Clone 0, Gen 224)
07:49:18:WU00:FS01:0x15:Assembly optimizations on if available.
07:49:18:WU00:FS01:0x15:Entering M.D.
07:49:19:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr:  2672790497 349948484 3834536736 3551304001 3087548353
07:49:19:WU00:FS01:0x15:GPU device id=0
07:49:19:WU00:FS01:0x15:Working on Protein
07:49:19:WU00:FS01:0x15:Client config unavailable.
07:49:20:WU00:FS01:0x15:Starting GUI Server
07:49:20:WU00:FS01:0x15:Finished fah_main status=59
07:49:20:WU00:FS01:0x15:mdrun_gpu returned 59
07:49:20:WU00:FS01:0x15:GPU memtest failure
07:49:20:WU00:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
07:49:20:WARNING:WU00:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
07:49:20:WU00:FS01:Starting
07:49:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/xxx/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/beta/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 7228 -checkpoint 3 -gpu 0 -gpu-vendor nvidia -gpu 0 -forcegpu nvidia_g80
07:49:20:WU00:FS01:Started FahCore on PID 10000
07:49:20:WU00:FS01:Core PID:10692
07:49:20:WU00:FS01:FahCore 0x15 started
07:49:21:WU00:FS01:0x15:
07:49:21:WU00:FS01:0x15:*------------------------------*
07:49:21:WU00:FS01:0x15:Folding@Home GPU Core
07:49:21:WU00:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
07:49:21:WU00:FS01:0x15:Build host             AmoebaRemote
07:49:21:WU00:FS01:0x15:Board Type             NVIDIA/CUDA
07:49:21:WU00:FS01:0x15:Core                   15
07:49:21:WU00:FS01:0x15:Window's signal control handler registered.
07:49:21:WU00:FS01:0x15:Preparing to commence simulation
07:49:21:WU00:FS01:0x15:- Looking at optimizations...
07:49:21:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
07:49:21:WU00:FS01:0x15:- Created dyn
07:49:21:WU00:FS01:0x15:- Files status OK
07:49:21:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
07:49:21:WU00:FS01:0x15:- Expanded 124797 -> 501826 (decompressed 402.1 percent)
07:49:21:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=124797 data_size=501826, decompressed_data_size=501826 diff=0
07:49:21:WU00:FS01:0x15:- Digital signature verified
07:49:21:WU00:FS01:0x15:Project: 7623 (Run 72, Clone 0, Gen 224)
07:49:21:WU00:FS01:0x15:Assembly optimizations on if available.
07:49:21:WU00:FS01:0x15:Entering M.D.
07:49:22:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr:  2672790497 349948484 3834536736 3551304001 3087548353
07:49:22:WU00:FS01:0x15:GPU device id=0
07:49:22:WU00:FS01:0x15:Working on Protein
07:49:22:WU00:FS01:0x15:Client config unavailable.
07:49:23:WU00:FS01:0x15:Starting GUI Server
07:49:23:WU00:FS01:0x15:Finished fah_main status=59
07:49:23:WU00:FS01:0x15:mdrun_gpu returned 59
07:49:23:WU00:FS01:0x15:GPU memtest failure
07:49:23:WU00:FS01:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
07:49:23:WARNING:WU00:FS01:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
I have 2 say i`m using 3 monitors but the used memory of nvidia is just 150 mb of 512.
tnx 4 your help in advance :)
Re: NVIDIA GeForse 8500 Failing
Support for using the beta flag is only given in the Beta Forum. If you are a member, you can post there. Otherwise it is read only if you are logged in. If you are interested in being a Beta Team member, please read and agree to the following post - viewtopic.php?f=16&t=8.
Otherwise, all Core_11 work that used to be assigned to GPU's of your card's vintage became unavailable a few months ago. Core_11 was announced to be end of life about a year before that. A trial of assigning Core_15 work to these older, pre-Fermi nVidia cards last year in general was discontinued after too many failures with no clear indication of which model cards could work and which did not.
MaDDogLV
Post by MaDDogLV »
Tnx 4 quick replay and Mod can close this thing up :) happy folding
