Folding on GTX 880m, Miniscule (4000) PPD?
Azathoth321
Post by Azathoth321 »
I have my laptop (Excellent cooling, cool ambient temperature, 65C peak) folding on its GTX 880m, which is slightly faster than a GTX 760. But I seem to only be getting ~4000 PPD?
Is this correct? Or is there a known issue with mobile chipsets?
Re: Folding on GTX 880m, Miniscule (4000) PPD?
Mobile chipsets are optimized to minimize battery power usage rather than to maximize performance.
Azathoth321
bruce wrote:Mobile chipsets are optimized to minimize battery power usage rather than to maximize performance.
The laptop is running off an Outlet, and the power draw is the same as if I was running a demanding game. (Shadow of Mordor) In which I get higher performance on than if I ran the game on my desktop GTX 750Ti.
---Slower desktop 750Ti -> 24K PPD
---Faster mobile 880m -> 4k PPD, 1/6th.
---Being fully utilized, as indicated by same power draw on a Kill-a-Watt reader.
heikosch
Hardware configuration: i7-3930K@4.1GHz
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
In fact the GTX 880M should be more powerful than a GTX 760. But I don´t know how long it can work at 100%.
Which F@H project using which Geforce driver version do you compare with the GTX 750 Ti?
Heiko
Image Image
Azathoth321
Both are doing Project 9201, and on Driver 344.60.
bollix47
Post by bollix47 »
Are you using a passkey?
Have you left 1 or 2 cpu threads available to feed the GPU?
Is your power setting at maximum or high performance with sleep and hibernation both turned off including for the display?
Can you show us your log including the System Info, Config and a few consecutive folding frames?
Azathoth321
bollix47 wrote:Are you using a passkey?
No Passkey.
Has access to 4 cores (8 Threads) at 3.5Ghz each.
Maximum performance, (Constant 3.5Ghz clock CPU, GPU at 1000Mhz)
*********************** Log Started 2014-11-09T22:26:26Z ***********************
22:26:26:************************* Folding@home Client *************************
22:26:26:      Website: http://folding.stanford.edu/
22:26:26:    Copyright: (c) 2009-2014 Stanford University
22:26:26:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:26:26:         Args: --open-web-control
22:26:26:       Config: C:/Users/Matt/AppData/Roaming/FAHClient/config.xml
22:26:26:******************************** Build ********************************
22:26:26:      Version: 7.4.4
22:26:26:         Date: Mar 4 2014
22:26:26:         Time: 20:26:54
22:26:26:      SVN Rev: 4130
22:26:26:       Branch: fah/trunk/client
22:26:26:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:26:26:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:26:26:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:26:26:     Platform: win32 XP
22:26:26:         Bits: 32
22:26:26:         Mode: Release
22:26:26:******************************* System ********************************
22:26:26:          CPU: Intel(R) Core(TM) i7-4810MQ CPU @ 2.80GHz
22:26:26:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
22:26:26:         CPUs: 8
22:26:26:       Memory: 11.92GiB
22:26:26:  Free Memory: 9.77GiB
22:26:26:      Threads: WINDOWS_THREADS
22:26:26:   OS Version: 6.1
22:26:26:  Has Battery: true
22:26:26:   On Battery: false
22:26:26:   UTC Offset: -5
22:26:26:          PID: 3440
22:26:26:          CWD: C:/Users/Matt/AppData/Roaming/FAHClient
22:26:26:           OS: Windows 7 Home Premium
22:26:26:      OS Arch: AMD64
22:26:26:         GPUs: 1
22:26:26:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 880M]
22:26:26:         CUDA: 3.0
22:26:26:  CUDA Driver: 6050
22:26:26:Win32 Service: false
22:26:26:***********************************************************************
22:26:26:<config>
22:26:26:  <!-- Network -->
22:26:26:  <proxy v=':8080'/>
22:26:26:
22:26:26:  <!-- Slot Control -->
22:26:26:  <power v='full'/>
22:26:26:
22:26:26:  <!-- User Information -->
22:26:26:  <user v='Azathoth321'/>
22:26:26:
22:26:26:  <!-- Folding Slots -->
22:26:26:  <slot id='1' type='GPU'>
22:26:26:    <paused v='true'/>
22:26:26:  </slot>
22:26:26:</config>
22:26:26:Trying to access database...
22:26:26:Successfully acquired database lock
22:26:26:Enabled folding slot 01: PAUSED gpu:0:GK104 [GeForce GTX 880M] (by user)
22:26:33:16:127.0.0.1:New Web connection
22:26:42:FS01:Unpaused
22:26:42:WU01:FS01:Starting
22:26:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Matt/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 3440 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
22:26:42:WU01:FS01:Started FahCore on PID 2004
22:26:42:WU01:FS01:Core PID:1216
22:26:42:WU01:FS01:FahCore 0x17 started
22:26:43:WU01:FS01:0x17:*********************** Log Started 2014-11-09T22:26:42Z ***********************
22:26:43:WU01:FS01:0x17:Project: 9201 (Run 308, Clone 3, Gen 16)
22:26:43:WU01:FS01:0x17:Unit: 0x0000001d6652edc45399e22cac95a809
22:26:43:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
22:26:43:WU01:FS01:0x17:Machine: 1
22:26:43:WU01:FS01:0x17:Digital signatures verified
22:26:43:WU01:FS01:0x17:Folding@home GPU core17
22:26:43:WU01:FS01:0x17:Version 0.0.52
22:26:43:WU01:FS01:0x17:  Found a checkpoint file
22:27:00:WU01:FS01:0x17:Completed 1450000 out of 5000000 steps (29%)
22:27:00:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:27:27:Saving configuration to config.xml
22:27:27:<config>
22:27:27:  <!-- Network -->
22:27:27:  <proxy v=':8080'/>
22:27:27:
22:27:27:  <!-- Slot Control -->
22:27:27:  <power v='full'/>
22:27:27:
22:27:27:  <!-- User Information -->
22:27:27:  <user v='Azathoth321'/>
22:27:27:
22:27:27:  <!-- Folding Slots -->
22:27:27:  <slot id='1' type='GPU'/>
22:27:27:</config>
mod edit: added code tags <-Thanks for the code tag, attempted [spoiler] tags to no avail but didn't know that was the function of this forums
 tag.
bollix47
Post by bollix47 »
Without a few frames we can't calculate the TPF so it's difficult to determine if 4K PPD is a correct estimate. I know that the TPF on my 750ti is ~4min28sec so if you can give us the actual TPF from the log or post a part of the log that shows a few frames on the 880m then we will be better equipped to compare and perhaps make more suggestions.
davidcoton
Post by davidcoton »
Do you have a passkey on the 750Ti system? That would account for the difference. If you are using the same user name, you can use the same passkey.
Azathoth321
bollix47 wrote:Without a few frames we can't calculate the TPF so it's difficult to determine if 4K PPD is a correct estimate. I know that the TPF on my 750ti is ~4min28sec so if you can give us the actual TPF from the log or post a part of the log that shows a few frames on the 880m then we will be better equipped to compare and perhaps make more suggestions.
My GTX 750Ti is doing ~4:30 TPF
GTX 880m is displaying 26:30 for each frame.
Just benchmarked my GTX 880m in Firestrike, 5600 Points. (Stock 750Ti scores 4000)
So, my GTX 880m is running properly, utilizing more power than my GTX 750Ti can, but is taking over 6x longer per frame.
