http://fah-web.stanford.edu/cgi-bin/fah ... ned?p=6385
It says to contact root@localhost which is unlikely to get a response, so I'm posting here
Server error
The server encountered an internal error and was unable to complete your request.
Error message:
Premature end of script headers: index.php
Please consult the debugging documentation at: http://www.stanford.edu/services/cgi/debugging.html
Do you mean I have to run FAHClient.exe? After I run it then I can open the Web page?bollix47 wrote:Farwalker, there have been some recent problems at Stanford with any links that included folding.stanford.edu and fah-web.stanford.edu .
As you can see in the post above yours the problem is being worked on and hopefully will resume normal operations soon.
If you continue to have problems reaching Web Control ( folding.stanford.edu/client/ ) try using 127.0.0.1:7396 in the address location window of your browser which should avoid those troublesome links.
Also, please remember that the Client (Folding@home aka FAHClient) must be running before you can successfully reach the Web Control page. In earlier versions FAHControl would automatically start FAHClient but that has changed and FAHClient must be started before FAHControl or Web Control can connect. If you've set it up to automatically start folding after a Windows restart then there should be a Folding@home link in the Windows Startup folder, otherwise you have to start it manually. The Service install option won't work with GPU folding so that's an unlikely scenario.
p.s. the links involved appear to be working normally this morning
