Most of my log is about the CPU slot that's running fine. Here's all it has about my GPU folding slot:
21:39:48:WU00:FS00:Connecting to 171.67.108.200:80
21:39:48:WU00:FS00:Assigned to work server 140.163.4.231
21:39:48:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Pitcairn [] from 140.163.4.231
21:39:48:WU00:FS00:Connecting to 140.163.4.231:8080
21:39:50:8:127.0.0.1:New Web connectionCode: Select all
*********************** Log Started 2014-10-29T21:39:47Z ***********************
21:39:47:************************* Folding@home Client *************************
21:39:47: Website: http://folding.stanford.edu/
21:39:47: Copyright: (c) 2009-2014 Stanford University
21:39:47: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:39:47: Args: --open-web-control
21:39:47: Config: C:/Users/Bjarne/AppData/Roaming/FAHClient/config.xml
21:39:47:******************************** Build ********************************
21:39:47: Version: 7.4.4
21:39:47: Date: Mar 4 2014
21:39:47: Time: 20:26:54
21:39:47: SVN Rev: 4130
21:39:47: Branch: fah/trunk/client
21:39:47: Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:39:47: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:39:47: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
21:39:47: Platform: win32 XP
21:39:47: Bits: 32
21:39:47: Mode: Release
21:39:47:******************************* System ********************************
21:39:47: CPU: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
21:39:47: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
21:39:47: CPUs: 4
21:39:47: Memory: 7.96GiB
21:39:47: Free Memory: 5.71GiB
21:39:47: Threads: WINDOWS_THREADS
21:39:47: OS Version: 6.1
21:39:47: Has Battery: false
21:39:47: On Battery: false
21:39:47: UTC Offset: 1
21:39:47: PID: 2528
21:39:47: CWD: C:/Users/Bjarne/AppData/Roaming/FAHClient
21:39:47: OS: Windows 7 Home Premium
21:39:47: OS Arch: AMD64
21:39:47: GPUs: 1
21:39:47: GPU 0: ATI:5 Pitcairn []
21:39:47: CUDA: Not detected
21:39:47:Win32 Service: false
21:39:47:***********************************************************************
21:39:47:<config>
21:39:47: <!-- Network -->
21:39:47: <proxy v=':8080'/>
21:39:47:
21:39:47: <!-- Slot Control -->
21:39:47: <pause-on-battery v='false'/>
21:39:47:
21:39:47: <!-- User Information -->
21:39:47: <passkey v='********************************'/>
21:39:47: <team v='40051'/>
21:39:47: <user v='Sakkura'/>
21:39:47:
21:39:47: <!-- Folding Slots -->
21:39:47: <slot id='0' type='GPU'/>
21:39:47: <slot id='1' type='CPU'/>
21:39:47:</config>
21:39:47:Trying to access database...
21:39:47:Successfully acquired database lock
21:39:47:Enabled folding slot 00: READY gpu:0:Pitcairn []
21:39:47:Enabled folding slot 01: READY cpu:2
21:39:47:WU02:FS01:Starting
21:39:47:WARNING:WU02:FS01:Changed SMP threads from 3 to 2 this can cause some work units to fail
21:39:47:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bjarne/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 2528 -checkpoint 15 -np 2
21:39:47:WU02:FS01:Started FahCore on PID 2144
21:39:47:WU02:FS01:Core PID:5660
21:39:47:WU02:FS01:FahCore 0xa4 started
21:39:47:WU02:FS01:0xa4:
21:39:47:WU02:FS01:0xa4:*------------------------------*
21:39:47:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
21:39:47:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:39:47:WU02:FS01:0xa4:Preparing to commence simulation
21:39:47:WU02:FS01:0xa4:- Looking at optimizations...
21:39:47:WU02:FS01:0xa4:- Files status OK
21:39:47:WU02:FS01:0xa4:- Expanded 1224358 -> 2731536 (decompressed 223.0 percent)
21:39:47:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1224358 data_size=2731536, decompressed_data_size=2731536 diff=0
21:39:47:WU02:FS01:0xa4:- Digital signature verified
21:39:47:WU02:FS01:0xa4:Project: 10184 (Run 146, Clone 0, Gen 48)
21:39:47:WU02:FS01:0xa4:Assembly optimizations on if available.
21:39:47:WU02:FS01:0xa4:Entering M.D.
21:39:53:WU02:FS01:0xa4:Using Gromacs checkpoints
21:39:53:WU02:FS01:0xa4:Mapping NT from 2 to 2
21:39:53:WU02:FS01:0xa4:Resuming from checkpoint
21:39:53:WU02:FS01:0xa4:Verified 02/wudata_01.log
21:39:53:WU02:FS01:0xa4:Verified 02/wudata_01.trr
21:39:53:WU02:FS01:0xa4:Verified 02/wudata_01.xtc
21:39:53:WU02:FS01:0xa4:Verified 02/wudata_01.edr
21:39:53:WU02:FS01:0xa4:Completed 410250 out of 500000 steps (82%)
21:40:16:FS01:Shutting core down
21:40:17:WU02:FS01:0xa4:Client no longer detected. Shutting down core
21:40:17:WU02:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
21:40:17:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:40:17:WU02:FS01:Starting
21:40:17:WARNING:WU02:FS01:Changed SMP threads from 2 to 3 this can cause some work units to fail
21:40:17:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bjarne/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 2528 -checkpoint 15 -np 3
21:40:17:WU02:FS01:Started FahCore on PID 2336
21:40:17:WU02:FS01:Core PID:6204
21:40:17:WU02:FS01:FahCore 0xa4 started
21:40:18:WU02:FS01:0xa4:
21:40:18:WU02:FS01:0xa4:*------------------------------*
21:40:18:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
21:40:18:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
21:40:18:WU02:FS01:0xa4:Preparing to commence simulation
21:40:18:WU02:FS01:0xa4:- Looking at optimizations...
21:40:18:WU02:FS01:0xa4:- Files status OK
21:40:18:WU02:FS01:0xa4:- Expanded 1224358 -> 2731536 (decompressed 223.0 percent)
21:40:18:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1224358 data_size=2731536, decompressed_data_size=2731536 diff=0
21:40:18:WU02:FS01:0xa4:- Digital signature verified
21:40:18:WU02:FS01:0xa4:Project: 10184 (Run 146, Clone 0, Gen 48)
21:40:18:WU02:FS01:0xa4:Assembly optimizations on if available.
21:40:18:WU02:FS01:0xa4:Entering M.D.
21:40:24:WU02:FS01:0xa4:Using Gromacs checkpoints
21:40:24:WU02:FS01:0xa4:Mapping NT from 3 to 3
21:40:24:WU02:FS01:0xa4:Resuming from checkpoint
21:40:24:WU02:FS01:0xa4:Verified 02/wudata_01.log
21:40:24:WU02:FS01:0xa4:Verified 02/wudata_01.trr
21:40:24:WU02:FS01:0xa4:Verified 02/wudata_01.xtc
21:40:24:WU02:FS01:0xa4:Verified 02/wudata_01.edr
21:40:24:WU02:FS01:0xa4:Completed 410250 out of 500000 steps (82%)
21:40:48:Removing old file 'configs/config-20140408-232430.xml'
21:40:48:Saving configuration to config.xml
21:40:48:<config>
21:40:48: <!-- Network -->
21:40:48: <proxy v=':8080'/>
21:40:48:
21:40:48: <!-- Slot Control -->
21:40:48: <pause-on-battery v='false'/>
21:40:48: <power v='full'/>
21:40:48:
21:40:48: <!-- User Information -->
21:40:48: <passkey v='********************************'/>
21:40:48: <team v='40051'/>
21:40:48: <user v='Sakkura'/>
21:40:48:
21:40:48: <!-- Folding Slots -->
21:40:48: <slot id='0' type='GPU'/>
21:40:48: <slot id='1' type='CPU'/>
21:40:48:</config>
21:44:19:WU02:FS01:0xa4:Completed 415000 out of 500000 steps (83%)
21:48:24:WU02:FS01:0xa4:Completed 420000 out of 500000 steps (84%)
21:52:27:WU02:FS01:0xa4:Completed 425000 out of 500000 steps (85%)
21:56:30:WU02:FS01:0xa4:Completed 430000 out of 500000 steps (86%)
