I have successfully got F@H running on my laptop, but when I try to run it on my desktop it always hangs at 'loading protein' in the visualizer.  The log gives me the above error.  Any help would be appreciated.  My machine:
FX 8320 @ 4.1 GHz (not sure if an overclock will mess with settings)
MSI R9 270x
8GB Team Vulcan RAM @ 1600mhz
Windows 8.1 Enterprise
LOG:
04:41:03:Saving configuration to config.xml
04:41:03:<config>
04:41:03:  <!-- Folding Core -->
04:41:03:  <core-priority v='low'/>
04:41:03:
04:41:03:  <!-- Network -->
04:41:03:  <proxy v=':8080'/>
04:41:03:
04:41:03:  <!-- Slot Control -->
04:41:03:  <power v='full'/>
04:41:03:
04:41:03:  <!-- User Information -->
04:41:03:  <passkey v='********************************'/>
04:41:03:  <team v='111065'/>
04:41:03:  <user v='ArrogantCabbage'/>
04:41:03:
04:41:03:  <!-- Folding Slots -->
04:41:03:  <slot id='0' type='CPU'/>
04:41:03:  <slot id='1' type='GPU'/>
04:41:03:</config>
04:41:18:Saving configuration to config.xml
04:41:18:<config>
04:41:18:  <!-- Folding Core -->
04:41:18:  <core-priority v='low'/>
04:41:18:
04:41:18:  <!-- Network -->
04:41:18:  <proxy v=':8080'/>
04:41:18:
04:41:18:  <!-- Slot Control -->
04:41:18:  <power v='full'/>
04:41:18:
04:41:18:  <!-- User Information -->
04:41:18:  <passkey v='********************************'/>
04:41:18:  <team v='111065'/>
04:41:18:  <user v='ArrogantCabbage'/>
04:41:18:
04:41:18:  <!-- Folding Slots -->
04:41:18:  <slot id='0' type='CPU'/>
04:41:18:  <slot id='1' type='GPU'/>
04:41:18:</config>
04:41:38:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
04:41:38:WU00:FS00:Connecting to web.stanford.edu:80
04:41:38:ERROR:WU00:FS00:Exception: Failed reading core package header.
04:41:39:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AM ... ore_17.fah
04:41:39:WU01:FS01:Connecting to web.stanford.edu:80
04:41:39:ERROR:WU01:FS01:Exception: Failed reading core package header.
In the 'status' tab of advanced control it says it is waiting on 'fahCore update'
													02:59:06:ERROR:WU01:FS01:Exception: Failed reading core pack
				ArrogantCabbage
					Last edited by ArrogantCabbage on Tue Oct 28, 2014 4:48 am, edited 1 time in total.
						Re: 02:59:06:ERROR:WU01:FS01:Exception: Failed reading core
Welcome to foldingforum, ArrogantCabbage.
There are a couple of things that might cause this. See the signature portion of my post for how to provide some more info so we give you the best answer.
				ChristianVirtual
Beside the core upgrade error please also keep in mind that core 17 (GPU) is not providing data to FAHViewer ... There is an incident ticket for it raised.
				ArrogantCabbage
So the client isn't recognizing either my CPU or my GPU? How would I go about troubleshooting / fixing this?  I've tried searching the forums / google and I'm having trouble finding info.
				davidcoton
As Bruce said, follow the link at the end of his post and provide the information it suggests.
