Failed to connect to assign-GPU.stanford.edu
heikosch
Hardware configuration: i7-3930K@4.1GHz
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
Since 14:36:52 (UTC):
ping to assign-GPU.stanford.edu is ok, but the server vsp10v-vz00.stanford.edu [171.67.108.200] is not listed in the server stats.
HTTP request from browser with pots 80 and 8080 => error
*********************** Log Started 2014-10-27T18:16:01Z ***********************
18:16:01:************************* Folding@home Client *************************
18:16:01:      Website: http://folding.stanford.edu/
18:16:01:    Copyright: (c) 2009-2012 Stanford University
18:16:01:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:16:01:         Args: --lifeline 660 --command-port=36330
18:16:01:       Config: C:/Program Files (x86)/FAHClient/config.xml
18:16:01:******************************** Build ********************************
18:16:01:      Version: 7.1.52
18:16:01:         Date: Mar 20 2012
18:16:01:         Time: 19:37:42
18:16:01:      SVN Rev: 3515
18:16:01:       Branch: fah/trunk/client
18:16:01:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:16:01:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:16:01:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
18:16:01:     Platform: win32 XP
18:16:01:         Bits: 32
18:16:01:         Mode: Release
18:16:01:******************************* System ********************************
18:16:01:          CPU: Intel(R) Core(TM)2 Quad CPU Q9300 @ 2.50GHz
18:16:01:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 7
18:16:01:         CPUs: 4
18:16:01:       Memory: 4.00GiB
18:16:01:  Free Memory: 2.39GiB
18:16:01:      Threads: WINDOWS_THREADS
18:16:01:   On Battery: false
18:16:01:   UTC offset: 1
18:16:01:          PID: 3976
18:16:01:          CWD: C:/Program Files (x86)/FAHClient
18:16:01:           OS: Windows 8.1 Pro
18:16:01:      OS Arch: AMD64
18:16:01:         GPUs: 1
18:16:01:        GPU 0: NVIDIA:4 GM204 [GeForce GTX 980]
18:16:01:         CUDA: 5.2
18:16:01:  CUDA Driver: 6050
18:16:01:Win32 Service: false
18:16:01:***********************************************************************
18:16:01:<config>
18:16:01:  <!-- FahCore Control -->
18:16:01:  <core-priority v='low'/>
18:16:01:
18:16:01:  <!-- Folding Slot Configuration -->
18:16:01:  <gpu v='true'/>
18:16:01:
18:16:01:  <!-- Network -->
18:16:01:  <proxy v=':8080'/>
18:16:01:
18:16:01:  <!-- Remote Command Server -->
18:16:01:  <password v='******'/>
18:16:01:
18:16:01:  <!-- User Information -->
18:16:01:  <passkey v='********************************'/>
18:16:01:  <team v='3'/>
18:16:01:  <user v='heikosch'/>
18:16:01:
18:16:01:  <!-- Folding Slots -->
18:16:01:  <slot id='0' type='GPU'/>
18:16:01:</config>
18:16:01:Trying to access database...
18:16:01:Successfully acquired database lock
18:16:01:Enabled folding slot 00: READY gpu:0:"GM204 [GeForce GTX 980] "
18:16:01:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:16:04:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
18:17:43:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
18:17:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
18:18:04:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
18:18:04:ERROR:WU00:FS00:Exception: Could not get an assignment
18:18:04:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:18:39:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
18:18:39:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
18:19:00:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
18:19:00:ERROR:WU00:FS00:Exception: Could not get an assignment
18:19:05:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:19:26:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
18:19:26:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
18:19:47:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
18:19:47:ERROR:WU00:FS00:Exception: Could not get an assignment
18:20:42:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:21:03:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
18:21:03:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
18:21:24:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
18:21:24:ERROR:WU00:FS00:Exception: Could not get an assignment
Image Image
Re: Failed to connect to assign-GPU.stanford.edu
I can open http://assign-gpu.stanford.edu/
Serverstat.html only shows Work Servers; not Assignment Servers. I'm not sure when (or why) they were removed, but most of the information on serverstat only applies to work servers.
heikosch
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz
Post by heikosch »
Now it also works for me. ;-)
It seems that someone fixed the problem.
Heiko
Image Image
The newest version of the F@H client supports using an alternate AS for GPU work. You may find it worthwhile to upgrade to 7.4.4. Additionally, there are some projects and WS's that require a minimum of 7.2.9 to assign work.
