I have a Dell XPS 8700 SE with Nvidia GTX 660. Its been working fine for over 9 months but recently noticed a PPD dropoff and find that the log is reporting "Failure To Access Core Package" and 21:38:18:WU01:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900.
Can anyone suggest a fix please?
Clint
CPU Failing to Load
ClintCruse
CPU Failing to Load
Dell XPS 8700 with i7 4770 8 core 3.4 ghz
CPU failing to load work packets. Seeing following in log:
01:08:18:FS00:Shutting core down
01:08:18:WU01:FS00:0x17:WARNING:Console control signal 1 on PID 8476
01:08:18:WU01:FS00:0x17:Exiting, please wait. . .
01:08:18:WU01:FS00:0x17:Folding@home Core Shutdown: INTERRUPTED
01:08:19:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:09:19:Removing old file 'configs/config-20140927-221648.xml'
01:09:19:Saving configuration to config.xml
01:09:19:<config>
Any suggestions?
Thanks
Clint
01:09:19:<config>
Any suggestions?
Thanks
Clint
Re: CPU Failing to Load
Welcome to the folding forum.
Your two posts have been merged into one topic as the same information is going to be needed to figure out what is not working on your setup. Please post your log after reading this topic - viewtopic.php?f=61&t=26036. We will need the beginning section of the log file that shows the client version, system information, and the current folding configuration. Also include enough after that to show the client attempting to download WU's or folding cores and the errors connected with those.
ClintCruse
CPU Loading Failure-Posting Log As Requested
*********************** Log Started 2014-10-22T03:28:49Z ***********************
03:28:49:************************* Folding@home Client *************************
03:28:49: Website: http://folding.stanford.edu/
03:28:49: Copyright: (c) 2009-2014 Stanford University
03:28:49: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:28:49: Args: --open-web-control
03:28:49: Config: C:/Users/Clint/AppData/Roaming/FAHClient/config.xml
03:28:49:******************************** Build ********************************
03:28:49: Version: 7.4.4
03:28:49: Date: Mar 4 2014
03:28:49: Time: 20:26:54
03:28:49: SVN Rev: 4130
03:28:49: Branch: fah/trunk/client
03:28:49: Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:28:49: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:28:49: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:28:49: Platform: win32 XP
03:28:49: Bits: 32
03:28:49: Mode: Release
03:28:49:******************************* System ********************************
03:28:49: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
03:28:49: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
03:28:49: CPUs: 8
03:28:49: Memory: 23.95GiB
03:28:49: Free Memory: 21.15GiB
03:28:49: Threads: WINDOWS_THREADS
03:28:49: OS Version: 6.2
03:28:49: Has Battery: false
03:28:49: On Battery: false
03:28:49: UTC Offset: -5
03:28:49: PID: 7536
03:28:49: CWD: C:/Users/Clint/AppData/Roaming/FAHClient
03:28:49: OS: Windows 8.1
03:28:49: OS Arch: AMD64
03:28:49: GPUs: 1
03:28:49: GPU 0: NVIDIA:3 GK106 [GeForce GTX 660]
03:28:49: CUDA: 3.0
03:28:49: CUDA Driver: 6050
03:28:49:Win32 Service: false
03:28:49:***********************************************************************
03:28:49:<config>
03:28:49: <!-- Folding Core -->
03:28:49: <checkpoint v='30'/>
03:28:49: <cpu-affinity v='true'/>
03:28:49: <no-assembly v='true'/>
03:28:49:
03:28:49: <!-- Network -->
03:28:49: <proxy v=':8080'/>
03:28:49:
03:28:49: <!-- Slot Control -->
03:28:49: <pause-on-battery v='false'/>
03:28:49:
03:28:49: <!-- User Information -->
03:28:49: <passkey v='********************************'/>
03:28:49: <user v='Clint_Cruse'/>
03:28:49:
03:28:49: <!-- Folding Slots -->
03:28:49: <slot id='0' type='GPU'>
03:28:49: <next-unit-percentage v='100'/>
03:28:49: </slot>
03:28:49: <slot id='1' type='CPU'>
03:28:49: </slot>
03:28:49:</config>
03:28:49:Trying to access database...
03:28:49:Successfully acquired database lock
03:28:49:Enabled folding slot 00: READY gpu:0:GK106 [GeForce GTX 660]
03:28:49:Enabled folding slot 01: READY cpu:6
03:28:50:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
03:28:50:WU00:FS01:Connecting to web.stanford.edu:80
03:28:50:WU01:FS00:Starting
03:28:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Clint/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 7536 -checkpoint 30 -noassembly -gpu 0 -gpu-vendor nvidia
03:28:50:WU01:FS00:Started FahCore on PID 2020
03:28:50:WU01:FS00:Core PID:7220
03:28:50:WU01:FS00:FahCore 0x17 started
03:28:50:WU01:FS00:0x17:*********************** Log Started 2014-10-22T03:28:50Z ***********************
03:28:50:WU01:FS00:0x17:Project: 13001 (Run 142, Clone 1, Gen 59)
03:28:50:WU01:FS00:0x17:Unit: 0x00000071538b3db7532877e287dd3fc3
03:28:50:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:28:50:WU01:FS00:0x17:Machine: 0
03:28:50:WU01:FS00:0x17:Digital signatures verified
03:28:50:WU01:FS00:0x17:Folding@home GPU core17
03:28:50:WU01:FS00:0x17:Version 0.0.52
03:28:50:WU01:FS00:0x17: Found a checkpoint file
03:28:51:ERROR:WU00:FS01:Exception: Failed to access core package.
03:28:53:8:127.0.0.1:New Web connection
03:29:50:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
03:29:50:WU00:FS01:Connecting to web.stanford.edu:80
03:29:50:ERROR:WU00:FS01:Exception: Failed to access core package.
03:30:56:WU01:FS00:0x17:Completed 2875000 out of 5000000 steps (57%)
03:30:56:WU01:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:31:27:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
03:31:27:WU00:FS01:Connecting to web.stanford.edu:80
03:31:27:ERROR:WU00:FS01:Exception: Failed to access core package.
03:31:45:FS00:Finishing
03:31:45:FS01:Finishing
03:31:52:Removing old file 'configs/config-20141005-141107.xml'
03:31:52:Saving configuration to config.xml
03:31:52:<config>
03:31:52: <!-- Folding Core -->
03:31:52: <checkpoint v='30'/>
03:31:52: <cpu-affinity v='true'/>
03:31:52: <no-assembly v='true'/>
03:31:52:
03:31:52: <!-- Network -->
03:31:52: <proxy v=':8080'/>
03:31:52:
03:31:52: <!-- Slot Control -->
03:31:52: <pause-on-battery v='false'/>
03:31:52: <power v='full'/>
03:31:52:
03:31:52: <!-- User Information -->
03:31:52: <passkey v='********************************'/>
03:31:52: <user v='Clint_Cruse'/>
03:31:52:
03:31:52: <!-- Folding Slots -->
03:31:52: <slot id='0' type='GPU'>
03:31:52: <next-unit-percentage v='100'/>
03:31:52: </slot>
03:31:52: <slot id='1' type='CPU'>
03:31:52: </slot>
03:31:52:</config>
03:34:04:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
03:34:04:WU00:FS01:Connecting to web.stanford.edu:80
03:34:05:ERROR:WU00:FS01:Exception: Failed to access core package.
03:38:18:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
03:38:18:WU00:FS01:Connecting to web.stanford.edu:80
03:38:19:ERROR:WU00:FS01:Exception: Failed to access core package.
03:45:10:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
03:45:10:WU00:FS01:Connecting to web.stanford.edu:80
03:45:10:ERROR:WU00:FS01:Exception: Failed to access core package.
03:45:36:WU01:FS00:0x17:Completed 2900000 out of 5000000 steps (58%)
03:56:15:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
03:56:15:WU00:FS01:Connecting to web.stanford.edu:80
03:56:16:ERROR:WU00:FS01:Exception: Failed to access core package.
04:14:12:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
04:14:12:WU00:FS01:Connecting to web.stanford.edu:80
04:14:12:ERROR:WU00:FS01:Exception: Failed to access core package.
04:14:30:WU01:FS00:0x17:Completed 2950000 out of 5000000 steps (59%)
04:43:14:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
04:43:14:WU00:FS01:Connecting to web.stanford.edu:80
04:43:14:ERROR:WU00:FS01:Exception: Failed to access core package.
04:43:23:WU01:FS00:0x17:Completed 3000000 out of 5000000 steps (60%)
05:12:29:WU01:FS00:0x17:Completed 3050000 out of 5000000 steps (61%)
05:30:13:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
05:30:13:WU00:FS01:Connecting to web.stanford.edu:80
05:30:13:ERROR:WU00:FS01:Exception: Failed to access core package.
05:41:24:WU01:FS00:0x17:Completed 3100000 out of 5000000 steps (62%)
06:10:31:WU01:FS00:0x17:Completed 3150000 out of 5000000 steps (63%)
06:39:27:WU01:FS00:0x17:Completed 3200000 out of 5000000 steps (64%)
06:46:14:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
06:46:14:WU00:FS01:Connecting to web.stanford.edu:80
06:46:14:ERROR:WU00:FS01:Exception: Failed to access core package.
07:08:23:WU01:FS00:0x17:Completed 3250000 out of 5000000 steps (65%)
07:37:27:WU01:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
08:06:20:WU01:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
08:35:23:WU01:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
08:49:13:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
08:49:13:WU00:FS01:Connecting to web.stanford.edu:80
08:49:14:ERROR:WU00:FS01:Exception: Failed to access core package.
09:04:16:WU01:FS00:0x17:Completed 3450000 out of 5000000 steps (69%)
******************************* Date: 2014-10-22 *******************************
09:33:09:WU01:FS00:0x17:Completed 3500000 out of 5000000 steps (70%)
10:02:18:WU01:FS00:0x17:Completed 3550000 out of 5000000 steps (71%)
10:31:13:WU01:FS00:0x17:Completed 3600000 out of 5000000 steps (72%)
11:00:19:WU01:FS00:0x17:Completed 3650000 out of 5000000 steps (73%)
11:29:14:WU01:FS00:0x17:Completed 3700000 out of 5000000 steps (74%)
11:58:09:WU01:FS00:0x17:Completed 3750000 out of 5000000 steps (75%)
12:08:14:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
12:08:14:WU00:FS01:Connecting to web.stanford.edu:80
12:08:14:ERROR:WU00:FS01:Exception: Failed to access core package.
12:27:13:WU01:FS00:0x17:Completed 3800000 out of 5000000 steps (76%)
12:56:06:WU01:FS00:0x17:Completed 3850000 out of 5000000 steps (77%)
13:25:11:WU01:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
13:54:04:WU01:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
14:22:56:WU01:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
14:52:02:WU01:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
15:20:57:WU01:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
15:50:04:WU01:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
16:18:59:WU01:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
16:47:54:WU01:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
17:16:58:WU01:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
17:30:14:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
17:30:14:WU00:FS01:Connecting to web.stanford.edu:80
17:30:15:ERROR:WU00:FS01:Exception: Failed to access core package.
17:45:51:WU01:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
18:14:56:WU01:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
18:43:49:WU01:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
19:12:42:WU01:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
19:41:48:WU01:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
20:10:43:WU01:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
20:39:49:WU01:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
21:08:45:WU01:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
21:37:40:WU01:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
22:06:45:WU01:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
22:35:38:WU01:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
23:04:43:WU01:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
23:30:14:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_b0.fah
23:30:14:WU00:FS01:Connecting to web.stanford.edu:80
23:30:16:ERROR:WU00:FS01:Exception: Failed to access core package.
23:33:36:WU01:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
00:02:29:WU01:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
00:02:30:WU02:FS00:Connecting to 171.67.108.200:80
00:02:31:WU02:FS00:Assigned to work server 140.163.4.231
00:02:31:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GK106 [GeForce GTX 660] from 140.163.4.231
00:02:31:WU02:FS00:Connecting to 140.163.4.231:8080
00:02:31:WU02:FS00:Downloading 4.84MiB
00:02:37:WU02:FS00:Download 96.92%
00:02:37:WU02:FS00:Download complete
00:02:37:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13001 run:43 clone:3 gen:33 core:0x17 unit:0x0000003e538b3db753285bf5406e0a77
00:02:41:WU01:FS00:0x17:Saving result file logfile_01.txt
00:02:41:WU01:FS00:0x17:Saving result file checkpointState.xml
00:02:43:WU01:FS00:0x17:Saving result file checkpt.crc
00:02:43:WU01:FS00:0x17:Saving result file log.txt
00:02:43:WU01:FS00:0x17:Saving result file positions.xtc
00:02:44:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
00:02:45:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:02:45:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13001 run:142 clone:1 gen:59 core:0x17 unit:0x00000071538b3db7532877e287dd3fc3
00:02:45:WU01:FS00:Uploading 12.82MiB to 140.163.4.231
00:02:45:WU01:FS00:Connecting to 140.163.4.231:8080
00:02:45:WU02:FS00:Starting
00:02:45:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Clint/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 7536 -checkpoint 30 -noassembly -gpu 0 -gpu-vendor nvidia
00:02:45:WU02:FS00:Started FahCore on PID 5892
00:02:45:WU02:FS00:Core PID:7260
00:02:45:WU02:FS00:FahCore 0x17 started
00:02:45:WU02:FS00:0x17:*********************** Log Started 2014-10-23T00:02:45Z ***********************
00:02:45:WU02:FS00:0x17:Project: 13001 (Run 43, Clone 3, Gen 33)
00:02:45:WU02:FS00:0x17:Unit: 0x0000003e538b3db753285bf5406e0a77
00:02:45:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:02:45:WU02:FS00:0x17:Machine: 0
00:02:45:WU02:FS00:0x17:Reading tar file state.xml
00:02:46:WU02:FS00:0x17:Reading tar file system.xml
00:02:46:WU02:FS00:0x17:Reading tar file integrator.xml
00:02:46:WU02:FS00:0x17:Reading tar file core.xml
00:02:46:WU02:FS00:0x17:Digital signatures verified
00:02:46:WU02:FS00:0x17:Folding@home GPU core17
00:02:46:WU02:FS00:0x17:Version 0.0.52
00:02:51:WU01:FS00:Upload 8.29%
00:02:57:WU01:FS00:Upload 16.57%
00:03:03:WU01:FS00:Upload 24.37%
00:03:09:WU01:FS00:Upload 32.65%
00:03:15:WU01:FS00:Upload 39.96%
00:03:21:WU01:FS00:Upload 48.25%
00:03:27:WU01:FS00:Upload 56.53%
00:03:33:WU01:FS00:Upload 64.33%
00:03:39:WU01:FS00:Upload 72.62%
00:03:45:WU01:FS00:Upload 80.42%
00:03:51:WU01:FS00:Upload 88.70%
00:03:57:WU01:FS00:Upload 96.50%
00:04:12:WU01:FS00:Upload complete
00:04:12:WU01:FS00:Server responded WORK_ACK (400)
00:04:12:WU01:FS00:Final credit estimate, 37080.00 points
00:04:12:WU01:FS00:Cleaning up
00:04:51:WU02:FS00:0x17:Completed 0 out of 5000000 steps (0%)
00:04:51:WU02:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:33:57:WU02:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
01:02:54:WU02:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
01:32:03:WU02:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
02:01:01:WU02:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
02:30:00:WU02:FS00:0x17:Completed 250000 out of 5000000 steps (5%)
02:59:12:WU02:FS00:0x17:Completed 300000 out of 5000000 steps (6%)
03:28:11:WU02:FS00:0x17:Completed 350000 out of 5000000 steps (7%)
03:49:50:FS00:Finishing
03:49:50:FS01:Finishing
03:50:06:FS00:Finishing
03:50:06:FS01:Finishing
04:01:17:WU02:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
There is no problem with your GPU folding, the error messages are all related to a problem connected with your CPU slot. A couple weeks ago an error in configuration of new Assignment Server code that was rolled out resulted in some machines being assigned work that was not supposed to be assigned to the V7 folding client. That is the attempt to download Core_b0 which is used by the NaCl Chrome client for folding.
The quickest way to fix this in your client is to remove the CPU folding slot and then recreate it. That will cause the client to dump the WU that was downloaded to use Core_b0 and then allow the client to download a WU that is appropriate for your CPU folding slot.
The message about "Temperature control disabled" is an informational messaged connected to your GPU slot and processing with Core_17. It is an optional item that can be enabled with Core_17 folding to throttle folding if the GPU temp gets past the set point. There were some issues found during testing of this option, so it is not enabled by default.
ClintCruse
Joe,
Thank you for the quick reply. I will remove and recreate the CPU slot. Hopefully that will fix the problem.
Clint
Clint
ClintCruse
Hi Joe,
Looks like that did the trick. CPU folding away again.
Thanks again,
Clint
Thanks again,
Clint
