I can't seem to get this bad boy to receive a work unit. Following your instructions for listing a new device and this is what was listed. (These instructions: viewtopic.php?f=83&t=26208)
0x10de:0x1189:NVIDIA Corporation:GK104 [GeForce GTX 670]Code: Select all
*********************** Log Started 2014-10-18T13:41:44Z ***********************
13:41:44:************************* Folding@home Client *************************
13:41:44: Website: http://folding.stanford.edu/
13:41:44: Copyright: (c) 2009-2014 Stanford University
13:41:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:41:44: Args:
13:41:44: Config: C:/ProgramData/FAHClient/config.xml
13:41:44:******************************** Build ********************************
13:41:44: Version: 7.4.4
13:41:44: Date: Mar 4 2014
13:41:44: Time: 20:26:54
13:41:44: SVN Rev: 4130
13:41:44: Branch: fah/trunk/client
13:41:44: Compiler: Intel(R) C++ MSVC 1500 mode 1200
13:41:44: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
13:41:44: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
13:41:44: Platform: win32 XP
13:41:44: Bits: 32
13:41:44: Mode: Release
13:41:44:******************************* System ********************************
13:41:44: CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
13:41:44: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
13:41:44: CPUs: 4
13:41:44: Memory: 11.96GiB
13:41:44: Free Memory: 9.66GiB
13:41:44: Threads: WINDOWS_THREADS
13:41:44: OS Version: 6.1
13:41:44: Has Battery: false
13:41:44: On Battery: false
13:41:44: UTC Offset: -4
13:41:44: PID: 4740
13:41:44: CWD: C:/ProgramData/FAHClient
13:41:44: OS: Windows 7 Home Premium
13:41:44: OS Arch: AMD64
13:41:44: GPUs: 1
13:41:44: GPU 0: NVIDIA:3 GK104 [GeForce GTX 670]
13:41:44: CUDA: 3.0
13:41:44: CUDA Driver: 6050
13:41:44:Win32 Service: false
13:41:44:***********************************************************************
13:41:44:<config>
13:41:44: <!-- Network -->
13:41:44: <proxy v=':8080'/>
13:41:44:
13:41:44: <!-- Slot Control -->
13:41:44: <power v='FULL'/>
13:41:44:
13:41:44: <!-- User Information -->
13:41:44: <passkey v='********************************'/>
13:41:44: <user v='JumpyCrunch'/>
13:41:44:
13:41:44: <!-- Folding Slots -->
13:41:44: <slot id='1' type='GPU'/>
13:41:44: <slot id='0' type='CPU'/>
13:41:44:</config>
13:41:44:Trying to access database...
13:41:45:Successfully acquired database lock
13:41:46:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 670]
13:41:46:Enabled folding slot 00: READY cpu:3
14:09:18:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 4740 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
14:09:18:WU01:FS01:Started FahCore on PID 4904
14:09:18:WU01:FS01:Core PID:5396
14:09:18:WU01:FS01:FahCore 0x18 started
14:09:18:WARNING:WU01:FS01:FahCore returned: CORE_OUTDATED (110 = 0x6e)
