Failed to connect: Operation timed out
kmkelleher
Post by kmkelleher »
Hi,
Having trouble connecting to download and process WUs.
12:58:48:        CPU: Intel(R) Core(TM) i7-2675QM CPU @ 2.20GHz
12:58:48:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:58:48:       CPUs: 8
12:58:48:     Memory: 4.00GiB
12:58:48:Free Memory: 100.40MiB
12:58:48:    Threads: POSIX_THREADS
12:58:48: OS Version: 10.9
12:58:48:Has Battery: true
12:58:48: On Battery: false
12:58:48: UTC Offset: -6
12:58:48:        PID: 4253
12:58:48:        CWD: /Library/Application Support/FAHClient
12:58:48:         OS: Darwin 13.4.0 x86_64
12:58:48:    OS Arch: AMD64
12:58:48:       GPUs: 1
12:58:48:      GPU 0: ATI:4 Whistler [Radeon HD 6600M Series]
12:58:48:       CUDA: Not detected
12:58:48:  <slot id='0' type='CPU'/>
12:58:48:</config>
12:58:48:Trying to access database...
12:58:49:Successfully acquired database lock
12:58:49:Enabled folding slot 00: READY cpu:8
12:58:49:WU00:FS00:Connecting to 171.67.108.200:8080
12:58:58:17:127.0.0.1:New Web connection
13:00:05:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Failed to connect to 171.67.108.200:8080: Operation timed out
Tried uninstalling and reinstalling. Tried rebooting. No firewalls. No port blocking. Any advice?
Re: Failed to connect: Operation timed out
Can you open http://assign.stanford.edu:8080/ in your browser? If not, how about http://assign2.stanford.edu/
How do you connect to the internet?
kmkelleher
Connecting over WiFi (home network) pushing about 30MB download speed. No VPN, no proxies, and no custom configurations.
I am able to see the logo and version info on http://assign2.stanford.edu/, though I'm not able to click through to the login page. No joy on http://assign.stanford.edu:8080/ (connection timeout).
Trouble started a few days ago, but prior to that, I never had a problem connecting.
(You're not supposed to be able to login.)
There have been a couple of other reports of connection timeouts. Development will consider their options.
kmkelleher
Ok, thanks. Let me know if they could use any additional info from the logs or my machine.
