Project 10475 (R0, C83, G18) on GTX980
SwingOp3
Post by SwingOp3 »
Just picked up a P10475 on Windows 7/Nvidia GTX980.
Since I can't post in the beta forum I thought I'd post my observations here. Not necessarily an issue just info.
With a clock offset of 160 Mhz and a GPU temp of 60 degrees the utilization hovers around 80% with an intermittent dip for approximately 10 seconds down to 40%.
Ppd varies from 290,000 to 325,000.
bollix47
Re: Project 10475 (R0, C83, G18) on GTX980
Post by bollix47 »
Just an FYI:
P10475 has been on full fah since early September: viewtopic.php?p=268482#p268482
i.e. there is no longer a requirement to post in the beta forum for the core 18 projects mentioned in that announcement.
Thanks for your report ... impressive PPD.
SwingOp3 wrote:With a clock offset of 160 Mhz and a GPU temp of 60 degrees the utilization hovers around 80% with an intermittent dip for approximately 10 seconds down to 40%.
When I see the GPU throughput dip, I also see a spike in CPU utilization so the GPU is partially waiting on my CPU. YMMV.
Rel25917
Post by Rel25917 »
The dips are usually caused by the core writing a checkpoint.
Kjetil
Post by Kjetil »
SwingOp3 wrote:Just picked up a P10475 on Windows 7/Nvidia GTX980.
Thats very good PPD, how about 10473 at 980 now? I have only PPD 87K and TPF is 10m and 27second?
