empty work server as'gnmt - server not listed? [Resolved]
FritzV
Post by FritzV »
Since yestedrday I get for my CPUs no assignnent, both Linux and Windows.
According to the server-stats they seem not to exist.
11:14:51:WU00:FS00:Connecting to 171.64.65.121:80
11:14:52:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.121:80': Empty work server assignment
11:14:52:ERROR:WU00:FS00:Exception: Could not get an assignment
11:25:56:WU00:FS00:Connecting to 171.67.108.200:8080
11:25:56:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.200:8080': Empty work server assignment
The mentioned servers are not listed in http://fah-web.stanford.edu/pybeta/serverstat.html.
I'm running V 7.4.4 and everything has been well until 2014-09-29, 21:00:00 UTC. Since then the failure as above occurs.
Any ideas? Thanks in advance.
Fritz
Re: empty work server assignment - server not listed?
You have not provided enough information to debug this problem.
* Which client version are you running?
* What hardware are you running? (Preferably paste the portion of the log that shows the detection of your hardware.)
msgclb
Post by msgclb »
I'm running a 280X with these settings...
07:43:06:******************************** Build ********************************
07:43:06:      Version: 7.3.6
07:43:06:         Date: Feb 18 2013
07:43:06:         Time: 15:25:17
07:43:06:      SVN Rev: 3923
07:43:06:       Branch: fah/trunk/client
07:43:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
07:43:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
07:43:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
07:43:06:     Platform: win32 XP
07:43:06:         Bits: 32
07:43:06:         Mode: Release
07:43:06:******************************* System ********************************
07:43:06:          CPU: AMD Phenom(tm) II X6 1100T Processor
07:43:06:       CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
07:43:06:         CPUs: 6
07:43:06:       Memory: 7.96GiB
07:43:06:  Free Memory: 6.66GiB
07:43:06:      Threads: WINDOWS_THREADS
07:43:06:  Has Battery: false
07:43:06:   On Battery: false
07:43:06:   UTC offset: -5
07:43:06:          PID: 3856
07:43:06:          CWD: C:/Users/corwin/Downloads/Installed/Software/FAH/FAHV7Data
07:43:06:           OS: Windows 7 Home Premium
07:43:06:      OS Arch: AMD64
07:43:06:         GPUs: 1
07:43:06:        GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
07:43:06:         CUDA: Not detected
07:43:06:Win32 Service: false
07:43:06:***********************************************************************
07:43:06:<config>
07:43:06:  <!-- Folding Slot Configuration -->
07:43:06:  <power v='full'/>
07:43:06:
07:43:06:  <!-- HTTP Server -->
07:43:06:  <allow v='127.0.0.1 127.0.0.1 192.168.1.100-192.168.1.149'/>
07:43:06:
07:43:06:  <!-- Network -->
07:43:06:  <proxy v=':8080'/>
07:43:06:
07:43:06:  <!-- Remote Command Server -->
07:43:06:  <command-allow-no-pass v='127.0.0.1 127.0.0.1 192.168.1.100-192.168.1.149'/>
07:43:06:
07:43:06:  <!-- User Information -->
07:43:06:  <passkey v='********************************'/>
07:43:06:  <team v='37726'/>
07:43:06:  <user v='Rockhopper'/>
07:43:06:
07:43:06:  <!-- Folding Slots -->
07:43:06:  <slot id='0' type='GPU'>
07:43:06:    <client-type v='normal'/>
07:43:06:    <next-unit-percentage v='100'/>
07:43:06:  </slot>
07:43:06:</config>
When I finished the following WU I got this...
17:07:11:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10468 run:0 clone:177 gen:26 core:0x17 unit:0x00000033538b3db9538caf0ae3d2bc68
17:07:11:WU00:FS00:Uploading 12.68MiB to 140.163.4.233
17:07:11:WU00:FS00:Connecting to 140.163.4.233:8080
17:07:17:WU00:FS00:Upload 6.41%
17:08:47:WU00:FS00:Upload complete
17:08:47:WU00:FS00:Server responded WORK_ACK (400)
17:08:47:WU00:FS00:Final credit estimate, 70001.00 points
17:08:47:WU00:FS00:Cleaning up
17:09:59:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
17:09:59:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
17:11:17:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': 10002: Received short response, expected 272 bytes, got 0
17:11:17:ERROR:WU01:FS00:Exception: Could not get an assignment
17:11:17:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
17:14:26:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
17:14:26:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
17:14:47:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:14:47:ERROR:WU01:FS00:Exception: Could not get an assignment
17:14:48:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
17:17:57:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
17:17:57:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
17:18:18:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:18:18:ERROR:WU01:FS00:Exception: Could not get an assignment
17:18:18:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
17:21:27:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': 10002: Received short response, expected 272 bytes, got 0
17:21:27:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
Any ideas?
FritzV
Post by FritzV »
O sorry, I forgot.
06:20:30:      Version: 7.4.4
06:20:30:         Date: Mar 4 2014
06:20:30:         Time: 20:26:54
06:20:30:      SVN Rev: 4130
06:20:30:       Branch: fah/trunk/client
06:20:30:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:20:30:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:20:30:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:20:30:     Platform: win32 XP
06:20:30:         Bits: 32
06:20:30:         Mode: Release
06:20:30:******************************* System ********************************
06:20:30:          CPU: AMD Phenom(tm) II X3 720 Processor
06:20:30:       CPU ID: AuthenticAMD Family 16 Model 4 Stepping 2
06:20:30:         CPUs: 3
06:20:30:       Memory: 8.00GiB
06:20:30:  Free Memory: 5.55GiB
06:20:30:      Threads: WINDOWS_THREADS
06:20:30:   OS Version: 6.1
06:20:30:  Has Battery: false
06:20:30:   On Battery: false
06:20:30:   UTC Offset: 2
06:20:30:          PID: 7092
06:20:30:          CWD: E:/Programme64/FoldingAtHome/Daten
06:20:30:           OS: Windows 7 Professional
06:20:30:      OS Arch: AMD64
06:20:30:         GPUs: 1
06:20:30:        GPU 0: ATI:5 Hawaii [Radeon R7 200 Series]
06:20:30:         CUDA: Not detected
06:20:30:Win32 Service: false
GPU is running fine, but CPU gets no WU.
Fritz
06:20:30:***********************************************************************
msgclb wrote:I'm running a 280X with these settings...
snip
Any ideas?
Does the latest v7.4.4 client work for you?
You can install it over the top of the existing version.
FritzV wrote:Since yestedrday I get for my CPUs no assignnent, both Linux and Windows.
They exist, but only Work Servers appear on serverstat; the Assignment Servers are not listed.
The function of the AS is to redirect (or "assign") your client to a WS that can issue a WU for your configuration. The "Empty work server" message means that at that time, no work server could be found that had WUs that satisfied the requirements of your client.
There was a temporary shortage of WUs for uniprocessors. I suspect that has been resolved.
FritzV
Post by FritzV »
Hi,
and thanks for the answer.
It was right: I'm trying to run 2 uniprocessor WUs - but until now there were no new one. Changing to AUTO got immediatly a WU for 2 processors.
So I will watch out for new uniprocessor WUs.
Fritz
