I need help troubleshooting QRB points
Brainiac5
Post by Brainiac5 »
So I have been folding with a passkey now for awhile and feel like I should be getting QRB points but I don't think I am can anyone help me? I think I have folded more than 10 fahcore 17 work units and I know I haven't failed to turn any in.
ChristianVirtual
Re: I need help troubleshooting QRB points
Post by ChristianVirtual »
Welcome to the world of folding
First make sure the passkey is entered exact the way as provided, no space at the end or anything (can happen when copy&paste). To make sure: those 10 WU where done with the same passkey ?
Can you share you config ? First lines of log file ? Until those line where foldin starts.
What projects did you got assigned and what points did you received ?
Brainiac5
Post by Brainiac5 »
How do I wrap code?
Edit:
*********************** Log Started 2014-09-20T14:17:06Z ***********************
14:17:06:************************* Folding@home Client *************************
14:17:06:      Website: http://folding.stanford.edu/
14:17:06:    Copyright: (c) 2009-2014 Stanford University
14:17:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:17:06:         Args:
14:17:06:       Config: S:/Users/Drew/AppData/Roaming/FAHClient/config.xml
14:17:06:******************************** Build ********************************
14:17:06:      Version: 7.4.4
14:17:06:         Date: Mar 4 2014
14:17:06:         Time: 20:26:54
14:17:06:      SVN Rev: 4130
14:17:06:       Branch: fah/trunk/client
14:17:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:17:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:17:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:17:06:     Platform: win32 XP
14:17:06:         Bits: 32
14:17:06:         Mode: Release
14:17:06:******************************* System ********************************
14:17:06:          CPU: Intel(R) Core(TM) i7 CPU 970 @ 3.20GHz
14:17:06:       CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
14:17:06:         CPUs: 12
14:17:06:       Memory: 11.99GiB
14:17:06:  Free Memory: 8.87GiB
14:17:06:      Threads: WINDOWS_THREADS
14:17:06:   OS Version: 6.1
14:17:06:  Has Battery: false
14:17:06:   On Battery: false
14:17:06:   UTC Offset: -4
14:17:06:          PID: 5008
14:17:06:          CWD: S:/Users/Drew/AppData/Roaming/FAHClient
14:17:06:           OS: Windows 7 Home Premium
14:17:06:      OS Arch: AMD64
14:17:06:         GPUs: 1
14:17:06:        GPU 0: NVIDIA:3 GK110 [GeForce GTX 780]
14:17:06:         CUDA: 3.5
14:17:06:  CUDA Driver: 6050
14:17:06:Win32 Service: false
14:17:06:***********************************************************************
14:17:06:<config>
14:17:06:  <service-description v='Folding@home Client'/>
14:17:06:  <service-restart v='true'/>
14:17:06:  <service-restart-delay v='5000'/>
14:17:06:
14:17:06:  <!-- Client Control -->
14:17:06:  <client-threads v='6'/>
14:17:06:  <cycle-rate v='4'/>
14:17:06:  <cycles v='-1'/>
14:17:06:  <data-directory v='.'/>
14:17:06:  <disable-sleep-when-active v='true'/>
14:17:06:  <exec-directory v='S:\Program Files (x86)\FAHClient'/>
14:17:06:  <exit-when-done v='false'/>
14:17:06:  <fold-anon v='false'/>
14:17:06:  <open-web-control v='false'/>
14:17:06:
14:17:06:  <!-- Configuration -->
14:17:06:  <config-rotate v='true'/>
14:17:06:  <config-rotate-dir v='configs'/>
14:17:06:  <config-rotate-max v='16'/>
14:17:06:
14:17:06:  <!-- Debugging -->
14:17:06:  <assignment-servers>
14:17:06:    assign3.stanford.edu:8080 assign4.stanford.edu:80
14:17:06:  </assignment-servers>
14:17:06:  <auth-as v='true'/>
14:17:06:  <capture-directory v='capture'/>
14:17:06:  <capture-on-error v='false'/>
14:17:06:  <capture-packets v='false'/>
14:17:06:  <capture-requests v='false'/>
14:17:06:  <capture-responses v='false'/>
14:17:06:  <capture-sockets v='false'/>
14:17:06:  <core-exec v='FahCore_$type'/>
14:17:06:  <core-wrapper-exec v='FAHCoreWrapper'/>
14:17:06:  <debug-sockets v='false'/>
14:17:06:  <exception-locations v='true'/>
14:17:06:  <gpu-assignment-servers>
14:17:06:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
14:17:06:  </gpu-assignment-servers>
14:17:06:  <stack-traces v='false'/>
14:17:06:
14:17:06:  <!-- Error Handling -->
14:17:06:  <max-slot-errors v='10'/>
14:17:06:  <max-unit-errors v='5'/>
14:17:06:
14:17:06:  <!-- Folding Core -->
14:17:06:  <checkpoint v='30'/>
14:17:06:  <core-dir v='cores'/>
14:17:06:  <core-priority v='idle'/>
14:17:06:  <cpu-affinity v='false'/>
14:17:06:  <cpu-usage v='100'/>
14:17:06:  <gpu-usage v='100'/>
14:17:06:  <no-assembly v='false'/>
14:17:06:
14:17:06:  <!-- Folding Slot Configuration -->
14:17:06:  <cause v='ANY'/>
14:17:06:  <client-subtype v='STDCLI'/>
14:17:06:  <client-type v='normal'/>
14:17:06:  <cpu-species v='X86_PENTIUM_II'/>
14:17:06:  <cpu-type v='AMD64'/>
14:17:06:  <cpus v='-1'/>
14:17:06:  <gpu v='true'/>
14:17:06:  <max-packet-size v='normal'/>
14:17:06:  <os-species v='UNKNOWN'/>
14:17:06:  <os-type v='WIN32'/>
14:17:06:  <project-key v='0'/>
14:17:06:  <smp v='true'/>
14:17:06:
14:17:06:  <!-- GUI -->
14:17:06:  <gui-enabled v='true'/>
14:17:06:
14:17:06:  <!-- HTTP Server -->
14:17:06:  <allow v='127.0.0.1'/>
14:17:06:  <connection-timeout v='60'/>
14:17:06:  <deny v='0/0'/>
14:17:06:  <http-addresses v='0:7396'/>
14:17:06:  <https-addresses v=''/>
14:17:06:  <max-connect-time v='900'/>
14:17:06:  <max-connections v='800'/>
14:17:06:  <max-request-length v='52428800'/>
14:17:06:  <min-connect-time v='300'/>
14:17:06:  <threads v='12'/>
14:17:06:
14:17:06:  <!-- Logging -->
14:17:06:  <log v='log.txt'/>
14:17:06:  <log-color v='false'/>
14:17:06:  <log-crlf v='true'/>
14:17:06:  <log-date v='false'/>
14:17:06:  <log-date-periodically v='21600'/>
14:17:06:  <log-debug v='true'/>
14:17:06:  <log-domain v='false'/>
14:17:06:  <log-header v='true'/>
14:17:06:  <log-level v='true'/>
14:17:06:  <log-no-info-header v='true'/>
14:17:06:  <log-redirect v='false'/>
14:17:06:  <log-rotate v='true'/>
14:17:06:  <log-rotate-dir v='logs'/>
14:17:06:  <log-rotate-max v='16'/>
14:17:06:  <log-short-level v='false'/>
14:17:06:  <log-simple-domains v='true'/>
14:17:06:  <log-thread-id v='false'/>
14:17:06:  <log-thread-prefix v='true'/>
14:17:06:  <log-time v='true'/>
14:17:06:  <log-to-screen v='true'/>
14:17:06:  <log-truncate v='false'/>
14:17:06:  <verbosity v='5'/>
14:17:06:
14:17:06:  <!-- Network -->
14:17:06:  <proxy v=':8080'/>
14:17:06:  <proxy-enable v='false'/>
14:17:06:  <proxy-pass v=''/>
14:17:06:  <proxy-user v=''/>
14:17:06:
14:17:06:  <!-- Process Control -->
14:17:06:  <child v='false'/>
14:17:06:  <daemon v='false'/>
14:17:06:  <pid v='false'/>
14:17:06:  <pid-file v='Folding@home Client.pid'/>
14:17:06:  <respawn v='false'/>
14:17:06:  <service v='false'/>
14:17:06:
14:17:06:  <!-- Remote Command Server -->
14:17:06:  <command-address v='0.0.0.0'/>
14:17:06:  <command-allow-no-pass v='127.0.0.1'/>
14:17:06:  <command-deny-no-pass v='0/0'/>
14:17:06:  <command-enable v='true'/>
14:17:06:  <command-port v='36330'/>
14:17:06:
14:17:06:  <!-- Slot Control -->
14:17:06:  <idle v='false'/>
14:17:06:  <max-shutdown-wait v='60'/>
14:17:06:  <pause-on-battery v='true'/>
14:17:06:  <pause-on-start v='false'/>
14:17:06:  <paused v='false'/>
14:17:06:  <power v='full'/>
14:17:06:
14:17:06:  <!-- User Information -->
14:17:06:  <machine-id v='0'/>
14:17:06:  <passkey v='********************************'/>
14:17:06:  <team v='98860'/>
14:17:06:  <user v='DrewWeeks'/>
14:17:06:
14:17:06:  <!-- Web Server -->
14:17:06:  <web-allow v='127.0.0.1'/>
14:17:06:  <web-deny v='0/0'/>
14:17:06:  <web-enable v='true'/>
14:17:06:
14:17:06:  <!-- Web Server Sessions -->
14:17:06:  <session-cookie v='sid'/>
14:17:06:  <session-lifetime v='86400'/>
14:17:06:  <session-timeout v='3600'/>
14:17:06:
14:17:06:  <!-- Work Unit Control -->
14:17:06:  <dump-after-deadline v='true'/>
14:17:06:  <max-queue v='16'/>
14:17:06:  <max-units v='0'/>
14:17:06:  <next-unit-percentage v='99'/>
14:17:06:  <stall-detection-enabled v='false'/>
14:17:06:  <stall-percent v='5'/>
14:17:06:  <stall-timeout v='1800'/>
14:17:06:
14:17:06:  <!-- Folding Slots -->
14:17:06:  <slot id='1' type='GPU'>
14:17:06:    <client-type v='beta'/>
14:17:06:    <paused v='true'/>
14:17:06:  </slot>
14:17:06:</config>
14:17:06:Trying to access database...
14:17:06:Successfully acquired database lock
14:17:06:Enabled folding slot 01: PAUSED gpu:0:GK110 [GeForce GTX 780] (by user)
14:17:06:Started thread 6 on PID 5008
14:17:06:Started thread 5 on PID 5008
14:17:06:Started thread 8 on PID 5008
14:17:06:Started thread 9 on PID 5008
14:17:06:Started thread 7 on PID 5008
14:17:06:Started thread 4 on PID 5008
14:17:14:Started thread 10 on PID 5008
14:17:22:FS01:Unpaused
14:17:22:WU00:FS01:Connecting to 171.67.108.201:80
14:17:22:WU00:FS01:Assigned to work server 171.64.65.104
14:17:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GK110 [GeForce GTX 780] from 171.64.65.104
14:17:22:WU00:FS01:Connecting to 171.64.65.104:8080
14:17:23:WU00:FS01:Downloading 1.54MiB
14:17:24:WU00:FS01:Download complete
14:17:24:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9202 run:113 clone:0 gen:46 core:0x17 unit:0x00000040664f2dd0539ff0b93ab63f01
14:17:24:WU00:FS01:Starting
14:17:24:WU00:FS01:Running FahCore: "S:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" S:/Users/Drew/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5008 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
14:17:25:WU00:FS01:Started FahCore on PID 7576
14:17:25:Started thread 11 on PID 5008
14:17:26:WU00:FS01:Core PID:5308
14:17:26:WU00:FS01:FahCore 0x17 started
I folded 9202 work units and 9406 I believe. They both used core 17. Everything was done with the same passkey. Double checked passkey is correct.
Yes, you are receiving QRB points. The one WU shown being started in the log has since been turned in and received just under 32K points on a WU that gets a base point credit of 8K points.
One note, please return the logging verbosity level to the default of 3. Higher levels do not provide any additional useful information in most cases, and make determining what is going on in the client much more difficult.
Brainiac5
Post by Brainiac5 »
I returned verbosity to level 3. Thank you for the help. =)
bob_b
Hardware configuration: I7-3970X Extreme, 6 core (overclocked to 4.5Mhz all cores ) 32Gb 1888mhz Ram, Intel 730 480Gb SSD, Two Zortac Amp! GTX 780 Ti's (overclocked to 1175 Mhz) Water cooled Windows 8.1
0x15 project 7620 work units only offer base points ?
Post by bob_b »
Is there a reason 0x15 project 7620 work units only offer base points ? ( 14093 ) The previous 0x17 Project 1300 was :Final credit estimate, 85103.00 points
23:30:08:WU00:FS02:Assigned to work server 171.64.65.105
23:30:08:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:0:GK110 [GeForce GTX 780 Ti] from 171.64.65.105
23:30:08:WU00:FS02:Downloading 122.70KiB
23:30:09:WU00:FS02:Download complete
23:30:09:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7620 run:17 clone:0 gen:296 core:0x15 unit:0x0000015f664f2dd14e42f3cae5ac9069
23:30:14:WU02:FS00:0xa3:Completed 350000 out of 500000 steps  (70%)
23:30:16:WU03:FS02:0x17:Saving result file logfile_01.txt
23:30:16:WU03:FS02:0x17:Saving result file checkpointState.xml
23:30:18:WU03:FS02:0x17:Saving result file checkpt.crc
23:30:18:WU03:FS02:0x17:Saving result file log.txt
23:30:18:WU03:FS02:0x17:Saving result file positions.xtc
23:30:20:WU03:FS02:0x17:Folding@home Core Shutdown: FINISHED_UNIT
23:30:20:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:30:20:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:13000 run:191 clone:0 gen:66 core:0x17 unit:0x0000006b538b3db7530fd1e0f9aed399
23:30:20:WU03:FS02:Uploading 12.83MiB to 140.163.4.231
23:30:21:WU00:FS02:Starting
23:30:21:WU00:FS02:Core PID:3404
23:30:21:WU00:FS02:FahCore 0x15 started
23:30:21:WU00:FS02:0x15:
23:30:21:WU00:FS02:0x15:*------------------------------*
23:30:21:WU00:FS02:0x15:Folding@Home GPU Core
23:30:21:WU00:FS02:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:30:21:WU00:FS02:0x15:Build host             AmoebaRemote
23:30:21:WU00:FS02:0x15:Board Type             NVIDIA/CUDA
23:30:21:WU00:FS02:0x15:Core                   15
23:30:21:WU00:FS02:0x15:Window's signal control handler registered.
23:30:21:WU00:FS02:0x15:Preparing to commence simulation
23:30:21:WU00:FS02:0x15:- Looking at optimizations...
23:30:21:WU00:FS02:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
23:30:21:WU00:FS02:0x15:- Created dyn
23:30:21:WU00:FS02:0x15:- Files status OK
23:30:21:WU00:FS02:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:30:21:WU00:FS02:0x15:- Expanded 125128 -> 501826 (decompressed 401.0 percent)
23:30:21:WU00:FS02:0x15:Called DecompressByteArray: compressed_data_size=125128 data_size=501826, decompressed_data_size=501826 diff=0
23:30:21:WU00:FS02:0x15:- Digital signature verified
23:30:21:WU00:FS02:0x15:Project: 7620 (Run 17, Clone 0, Gen 296)
23:30:21:WU00:FS02:0x15:Assembly optimizations on if available.
23:30:21:WU00:FS02:0x15:Entering M.D.
23:30:23:WU00:FS02:0x15:Tpr hash 00/wudata_01.tpr:  2895906203 1453162952 111936397 496142892 2668355140
23:30:23:WU00:FS02:0x15:GPU device id=0
23:30:23:WU00:FS02:0x15:Working on Protein
23:30:23:WU00:FS02:0x15:Client config unavailable.
23:30:23:WU00:FS02:0x15:Starting GUI Server
23:30:26:WU03:FS02:Upload 13.64%
23:30:32:WU03:FS02:Upload 29.22%
23:30:38:WU03:FS02:Upload 44.32%
23:30:44:WU03:FS02:Upload 59.41%
23:30:50:WU03:FS02:Upload 74.51%
23:30:56:WU03:FS02:Upload 89.61%
23:31:10:WU03:FS02:Upload complete
23:31:10:WU03:FS02:Server responded WORK_ACK (400)
23:31:10:WU03:FS02:Final credit estimate, 85103.00 points
23:31:10:WU03:FS02:Cleaning up
Mod edit: Added Code tags to log
Yes, Core_15 WU's are not eligible for the Quick Return Bonus. That is the reason they get only base points. PG did re-benchmark the older Core_15 projects to reflect a change in policy on points for GPU processing of WU's. But only Core_17 and later GPU processing cores will get the QRB. Eventually all the Core_15 projects will be finished, end of life has been announced for GPU projects using that folding core.
bob_b
Post by bob_b »
Thank you Joe. I'll fold what i'm assigned
