New to folding , Points/ work type question
bob_b
Hardware configuration: I7-3970X Extreme, 6 core (overclocked to 4.5Mhz all cores ) 32Gb 1888mhz Ram, Intel 730 480Gb SSD, Two Zortac Amp! GTX 780 Ti's (overclocked to 1175 Mhz) Water cooled Windows 8.1
Post by bob_b »
Just started folding
Windows 8.1, CPU is an Intel I7-3970x 15mb cache extreme cpu overclocked to 4.5mhz all 6 cores, 32 Gb of 1888 mhz ram, I have two Nivida 780 Ti's both over clocked to 1150Mhz
based on what i have read, the 170K ppd with all of this running on full (high) all weekend seems low ? I know the points thing is just for fun I just want to make sure i have not done anything wrong installing the client
*********************** Log Started 2014-08-23T18:43:52Z ***********************
18:43:52:************************* Folding@home Client *************************
18:43:52:      Website: http://folding.stanford.edu/
18:43:52:    Copyright: (c) 2009-2014 Stanford University
18:43:52:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:43:52:         Args:
18:43:52:       Config: C:/ProgramData/FAHClient/config.xml
18:43:52:******************************** Build ********************************
18:43:52:      Version: 7.4.4
18:43:52:         Date: Mar 4 2014
18:43:52:         Time: 20:26:54
18:43:52:      SVN Rev: 4130
18:43:52:       Branch: fah/trunk/client
18:43:52:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:43:52:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:43:52:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:43:52:     Platform: win32 XP
18:43:52:         Bits: 32
18:43:52:         Mode: Release
18:43:52:******************************* System ********************************
18:43:52:          CPU: Intel(R) Core(TM) i7-3970X CPU @ 3.50GHz
18:43:52:       CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
18:43:52:         CPUs: 12
18:43:52:       Memory: 31.94GiB
18:43:52:  Free Memory: 28.87GiB
18:43:52:      Threads: WINDOWS_THREADS
18:43:52:   OS Version: 6.2
18:43:52:  Has Battery: false
18:43:52:   On Battery: false
18:43:52:   UTC Offset: -4
18:43:52:          PID: 3248
18:43:52:          CWD: C:/ProgramData/FAHClient
18:43:52:           OS: Windows 8.1
18:43:52:      OS Arch: AMD64
18:43:52:         GPUs: 2
18:43:52:        GPU 0: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
18:43:52:        GPU 1: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
18:43:52:         CUDA: 3.5
18:43:52:  CUDA Driver: 6050
18:43:52:Win32 Service: false
18:43:52:***********************************************************************
18:43:52:<config>
18:43:52:  <!-- Slot Control -->
18:43:52:  <power v='MEDIUM'/>
18:43:52:
18:43:52:  <!-- User Information -->
18:43:52:  <team v='2772'/>
18:43:52:  <user v='bob'/>
18:43:52:
18:43:52:  <!-- Folding Slots -->
18:43:52:  <slot id='0' type='CPU'/>
18:43:52:  <slot id='1' type='GPU'/>
18:43:52:  <slot id='2' type='GPU'/>
18:43:52:</config>
18:43:52:Trying to access database...
18:43:52:Successfully acquired database lock
18:43:52:Enabled folding slot 00: READY cpu:9
18:43:52:Enabled folding slot 01: READY gpu:0:GK110 [GeForce GTX 780 Ti]
18:43:52:Enabled folding slot 02: READY gpu:1:GK110 [GeForce GTX 780 Ti]
18:43:53:WU02:FS02:Starting
18:43:53:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
18:43:53:WU02:FS02:Started FahCore on PID 4484
18:43:53:WU02:FS02:Core PID:4496
18:43:53:WU02:FS02:FahCore 0x15 started
18:43:53:WU01:FS01:Starting
18:43:53:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
18:43:53:WU01:FS01:Started FahCore on PID 4504
18:43:53:WU01:FS01:Core PID:4516
18:43:53:WU01:FS01:FahCore 0x15 started
18:43:53:WU00:FS00:Starting
18:43:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -np 9
18:43:53:WU00:FS00:Started FahCore on PID 4524
18:43:53:WU00:FS00:Core PID:4536
18:43:53:WU00:FS00:FahCore 0xa3 started
18:43:54:WU02:FS02:0x15:
18:43:54:WU02:FS02:0x15:*------------------------------*
18:43:54:WU02:FS02:0x15:Folding@Home GPU Core
18:43:54:WU02:FS02:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
18:43:54:WU02:FS02:0x15:Build host             AmoebaRemote
18:43:54:WU02:FS02:0x15:Board Type             NVIDIA/CUDA
18:43:54:WU02:FS02:0x15:Core                   15
18:43:54:WU02:FS02:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
18:43:54:WU02:FS02:0x15:Window's signal control handler registered.
18:43:54:WU02:FS02:0x15:Preparing to commence simulation
18:43:54:WU02:FS02:0x15:- Ensuring status. Please wait.
18:43:54:WU00:FS00:0xa3:
18:43:54:WU01:FS01:0x15:
18:43:54:WU00:FS00:0xa3:*------------------------------*
18:43:54:WU01:FS01:0x15:*------------------------------*
18:43:54:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
18:43:54:WU01:FS01:0x15:Folding@Home GPU Core
18:43:54:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
18:43:54:WU01:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
18:43:54:WU01:FS01:0x15:Build host             AmoebaRemote
18:43:54:WU00:FS00:0xa3:Preparing to commence simulation
18:43:54:WU01:FS01:0x15:Board Type             NVIDIA/CUDA
18:43:54:WU00:FS00:0xa3:- Ensuring status. Please wait.
18:43:54:WU01:FS01:0x15:Core                   15
18:43:54:WU01:FS01:0x15:Window's signal control handler registered.
18:43:54:WU01:FS01:0x15:Preparing to commence simulation
18:43:54:WU01:FS01:0x15:- Ensuring status. Please wait.
18:44:03:WU02:FS02:0x15:- Looking at optimizations...
18:44:03:WU02:FS02:0x15:- Working with standard loops on this execution.
18:44:03:WU02:FS02:0x15:- Previous termination of core was improper.
18:44:03:WU02:FS02:0x15:- Files status OK
18:44:03:WU02:FS02:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
18:44:03:WU02:FS02:0x15:- Expanded 124822 -> 501826 (decompressed 402.0 percent)
18:44:03:WU02:FS02:0x15:Called DecompressByteArray: compressed_data_size=124822 data_size=501826, decompressed_data_size=501826 diff=0
18:44:03:WU02:FS02:0x15:- Digital signature verified
18:44:03:WU02:FS02:0x15:Project: 7622 (Run 534, Clone 0, Gen 224)
18:44:03:WU02:FS02:0x15:Entering M.D.
18:44:03:WU00:FS00:0xa3:- Looking at optimizations...
18:44:03:WU01:FS01:0x15:- Looking at optimizations...
18:44:03:WU00:FS00:0xa3:- Working with standard loops on this execution.
18:44:03:WU01:FS01:0x15:- Working with standard loops on this execution.
18:44:03:WU00:FS00:0xa3:- Previous termination of core was improper.
18:44:03:WU01:FS01:0x15:- Previous termination of core was improper.
18:44:03:WU00:FS00:0xa3:- Going to use standard loops.
18:44:03:WU01:FS01:0x15:- Files status OK
18:44:03:WU00:FS00:0xa3:- Files status OK
18:44:03:WU01:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
18:44:03:WU01:FS01:0x15:- Expanded 124779 -> 501826 (decompressed 402.1 percent)
18:44:03:WU01:FS01:0x15:Called DecompressByteArray: compressed_data_size=124779 data_size=501826, decompressed_data_size=501826 diff=0
18:44:03:WU01:FS01:0x15:- Digital signature verified
18:44:03:WU01:FS01:0x15:Project: 7623 (Run 378, Clone 0, Gen 207)
18:44:03:WU01:FS01:0x15:Entering M.D.
18:44:03:WU00:FS00:0xa3:- Expanded 3815513 -> 4182748 (decompressed 109.6 percent)
18:44:03:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3815513 data_size=4182748, decompressed_data_size=4182748 diff=0
18:44:03:WU00:FS00:0xa3:- Digital signature verified
18:44:03:WU00:FS00:0xa3:Project: 6095 (Run 28, Clone 41, Gen 5)
18:44:03:WU00:FS00:0xa3:Entering M.D.
18:44:05:WU02:FS02:0x15:Will resume from checkpoint file 02/wudata_01.ckp
18:44:05:WU02:FS02:0x15:Tpr hash 02/wudata_01.tpr:  2820184024 3775739376 682290313 3662373393 1586958964
18:44:05:WU02:FS02:0x15:GPU device id=1
18:44:05:WU02:FS02:0x15:Working on Protein
18:44:05:WU02:FS02:0x15:Client config unavailable.
18:44:05:WU02:FS02:0x15:Starting GUI Server
18:44:05:WU01:FS01:0x15:Will resume from checkpoint file 01/wudata_01.ckp
18:44:05:WU01:FS01:0x15:Tpr hash 01/wudata_01.tpr:  899717329 4252710682 3005581109 1213233078 1484980793
18:44:05:WU01:FS01:0x15:GPU device id=0
18:44:05:WU01:FS01:0x15:Working on Protein
18:44:05:WU01:FS01:0x15:Client config unavailable.
18:44:05:WU01:FS01:0x15:Starting GUI Server
18:44:09:WU00:FS00:0xa3:Using Gromacs checkpoints
18:44:09:WU00:FS00:0xa3:Mapping NT from 9 to 9
18:44:10:WU00:FS00:0xa3:Resuming from checkpoint
18:44:10:WU00:FS00:0xa3:Verified 00/wudata_01.log
18:44:10:WU00:FS00:0xa3:Verified 00/wudata_01.trr
18:44:10:WU00:FS00:0xa3:Verified 00/wudata_01.edr
18:44:10:WU00:FS00:0xa3:Completed 312670 out of 500000 steps  (62%)
18:45:07:WU02:FS02:0x15:Resuming from checkpoint
18:45:07:WU02:FS02:0x15:fcCheckPointResume: retreived and current tpr file hash:
18:45:07:WU02:FS02:0x15:   0   2820184024   2820184024
18:45:07:WU02:FS02:0x15:   1   3775739376   3775739376
18:45:07:WU02:FS02:0x15:   2    682290313    682290313
18:45:07:WU02:FS02:0x15:   3   3662373393   3662373393
18:45:07:WU02:FS02:0x15:   4   1586958964   1586958964
18:45:07:WU02:FS02:0x15:fcCheckPointResume: file hashes same.
18:45:07:WU02:FS02:0x15:fcCheckPointResume: state restored.
18:45:07:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.log Verified 02/wudata_01.log
18:45:07:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.trr Verified 02/wudata_01.trr
18:45:07:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.xtc Verified 02/wudata_01.xtc
18:45:07:WU02:FS02:0x15:fcCheckPointResume: name 02/wudata_01.edr Verified 02/wudata_01.edr
18:45:07:WU02:FS02:0x15:fcCheckPointResume: state restored 2
18:45:07:WU02:FS02:0x15:Resumed from checkpoint
18:45:07:WU02:FS02:0x15:Setting checkpoint frequency: 400000
18:45:07:WU02:FS02:0x15:Completed  14000001 out of 40000000 steps (35%).
18:45:09:WU01:FS01:0x15:Resuming from checkpoint
18:45:09:WU01:FS01:0x15:fcCheckPointResume: retreived and current tpr file hash:
18:45:09:WU01:FS01:0x15:   0    899717329    899717329
18:45:09:WU01:FS01:0x15:   1   4252710682   4252710682
18:45:09:WU01:FS01:0x15:   2   3005581109   3005581109
18:45:09:WU01:FS01:0x15:   3   1213233078   1213233078
18:45:09:WU01:FS01:0x15:   4   1484980793   1484980793
18:45:09:WU01:FS01:0x15:fcCheckPointResume: file hashes same.
18:45:09:WU01:FS01:0x15:fcCheckPointResume: state restored.
18:45:09:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
18:45:09:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
18:45:09:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
18:45:09:WU01:FS01:0x15:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
18:45:09:WU01:FS01:0x15:fcCheckPointResume: state restored 2
18:45:09:WU01:FS01:0x15:Resumed from checkpoint
18:45:09:WU01:FS01:0x15:Setting checkpoint frequency: 400000
18:45:09:WU01:FS01:0x15:Completed  13200001 out of 40000000 steps (33%).
18:45:56:16:127.0.0.1:New Web connection
18:47:01:WU00:FS00:0xa3:Completed 315000 out of 500000 steps  (63%)
18:48:40:WU01:FS01:0x15:Completed  13600000 out of 40000000 steps (34%).
18:48:51:WU02:FS02:0x15:Completed  14400000 out of 40000000 steps (36%).
18:52:14:WU01:FS01:0x15:Completed  14000000 out of 40000000 steps (35%).
18:52:36:WU02:FS02:0x15:Completed  14800000 out of 40000000 steps (37%).
18:53:06:WU00:FS00:0xa3:Completed 320000 out of 500000 steps  (64%)
18:55:47:WU01:FS01:0x15:Completed  14400000 out of 40000000 steps (36%).
18:56:21:WU02:FS02:0x15:Completed  15200000 out of 40000000 steps (38%).
18:59:12:WU00:FS00:0xa3:Completed 325000 out of 500000 steps  (65%)
18:59:21:WU01:FS01:0x15:Completed  14800000 out of 40000000 steps (37%).
19:00:05:WU02:FS02:0x15:Completed  15600000 out of 40000000 steps (39%).
19:02:55:WU01:FS01:0x15:Completed  15200000 out of 40000000 steps (38%).
19:03:50:WU02:FS02:0x15:Completed  16000000 out of 40000000 steps (40%).
19:05:18:WU00:FS00:0xa3:Completed 330000 out of 500000 steps  (66%)
19:06:28:WU01:FS01:0x15:Completed  15600000 out of 40000000 steps (39%).
19:07:35:WU02:FS02:0x15:Completed  16400000 out of 40000000 steps (41%).
19:10:02:WU01:FS01:0x15:Completed  16000000 out of 40000000 steps (40%).
19:11:19:WU02:FS02:0x15:Completed  16800000 out of 40000000 steps (42%).
19:11:24:WU00:FS00:0xa3:Completed 335000 out of 500000 steps  (67%)
19:13:35:WU01:FS01:0x15:Completed  16400000 out of 40000000 steps (41%).
19:15:04:WU02:FS02:0x15:Completed  17200000 out of 40000000 steps (43%).
19:17:09:WU01:FS01:0x15:Completed  16800000 out of 40000000 steps (42%).
19:17:29:WU00:FS00:0xa3:Completed 340000 out of 500000 steps  (68%)
19:18:49:WU02:FS02:0x15:Completed  17600000 out of 40000000 steps (44%).
19:20:42:WU01:FS01:0x15:Completed  17200000 out of 40000000 steps (43%).
19:22:34:WU02:FS02:0x15:Completed  18000000 out of 40000000 steps (45%).
19:23:35:WU00:FS00:0xa3:Completed 345000 out of 500000 steps  (69%)
19:24:16:WU01:FS01:0x15:Completed  17600000 out of 40000000 steps (44%).
19:26:18:WU02:FS02:0x15:Completed  18400000 out of 40000000 steps (46%).
19:27:49:WU01:FS01:0x15:Completed  18000000 out of 40000000 steps (45%).
19:29:41:WU00:FS00:0xa3:Completed 350000 out of 500000 steps  (70%)
19:30:03:WU02:FS02:0x15:Completed  18800000 out of 40000000 steps (47%).
19:31:23:WU01:FS01:0x15:Completed  18400000 out of 40000000 steps (46%).
19:33:48:WU02:FS02:0x15:Completed  19200000 out of 40000000 steps (48%).
19:34:56:WU01:FS01:0x15:Completed  18800000 out of 40000000 steps (47%).
19:35:46:WU00:FS00:0xa3:Completed 355000 out of 500000 steps  (71%)
19:37:33:WU02:FS02:0x15:Completed  19600000 out of 40000000 steps (49%).
19:38:30:WU01:FS01:0x15:Completed  19200000 out of 40000000 steps (48%).
19:41:17:WU02:FS02:0x15:Completed  20000000 out of 40000000 steps (50%).
19:41:52:WU00:FS00:0xa3:Completed 360000 out of 500000 steps  (72%)
19:42:02:WU01:FS01:0x15:Completed  19600000 out of 40000000 steps (49%).
19:45:00:WU02:FS02:0x15:Completed  20400000 out of 40000000 steps (51%).
19:45:33:WU01:FS01:0x15:Completed  20000000 out of 40000000 steps (50%).
19:47:57:WU00:FS00:0xa3:Completed 365000 out of 500000 steps  (73%)
19:48:42:WU02:FS02:0x15:Completed  20800000 out of 40000000 steps (52%).
19:49:05:WU01:FS01:0x15:Completed  20400000 out of 40000000 steps (51%).
19:52:29:WU02:FS02:0x15:Completed  21200000 out of 40000000 steps (53%).
19:52:39:WU01:FS01:0x15:Completed  20800000 out of 40000000 steps (52%).
19:54:03:WU00:FS00:0xa3:Completed 370000 out of 500000 steps  (74%)
19:56:11:WU01:FS01:0x15:Completed  21200000 out of 40000000 steps (53%).
19:56:13:WU02:FS02:0x15:Completed  21600000 out of 40000000 steps (54%).
19:59:42:WU01:FS01:0x15:Completed  21600000 out of 40000000 steps (54%).
19:59:55:WU02:FS02:0x15:Completed  22000000 out of 40000000 steps (55%).
20:00:09:WU00:FS00:0xa3:Completed 375000 out of 500000 steps  (75%)
20:03:13:WU01:FS01:0x15:Completed  22000000 out of 40000000 steps (55%).
20:03:38:WU02:FS02:0x15:Completed  22400000 out of 40000000 steps (56%).
20:06:15:WU00:FS00:0xa3:Completed 380000 out of 500000 steps  (76%)
20:06:44:WU01:FS01:0x15:Completed  22400000 out of 40000000 steps (56%).
20:07:21:WU02:FS02:0x15:Completed  22800000 out of 40000000 steps (57%).
20:10:15:WU01:FS01:0x15:Completed  22800000 out of 40000000 steps (57%).
20:11:03:WU02:FS02:0x15:Completed  23200000 out of 40000000 steps (58%).
20:12:20:WU00:FS00:0xa3:Completed 385000 out of 500000 steps  (77%)
20:13:45:WU01:FS01:0x15:Completed  23200000 out of 40000000 steps (58%).
20:14:46:WU02:FS02:0x15:Completed  23600000 out of 40000000 steps (59%).
20:17:16:WU01:FS01:0x15:Completed  23600000 out of 40000000 steps (59%).
20:18:26:WU00:FS00:0xa3:Completed 390000 out of 500000 steps  (78%)
20:18:28:WU02:FS02:0x15:Completed  24000000 out of 40000000 steps (60%).
20:20:47:WU01:FS01:0x15:Completed  24000000 out of 40000000 steps (60%).
20:22:07:WU02:FS02:0x15:Completed  24400000 out of 40000000 steps (61%).
20:24:16:WU01:FS01:0x15:Completed  24400000 out of 40000000 steps (61%).
20:24:31:WU00:FS00:0xa3:Completed 395000 out of 500000 steps  (79%)
20:25:46:WU02:FS02:0x15:Completed  24800000 out of 40000000 steps (62%).
20:27:46:WU01:FS01:0x15:Completed  24800000 out of 40000000 steps (62%).
20:29:27:WU02:FS02:0x15:Completed  25200000 out of 40000000 steps (63%).
20:30:37:WU00:FS00:0xa3:Completed 400000 out of 500000 steps  (80%)
20:31:16:WU01:FS01:0x15:Completed  25200000 out of 40000000 steps (63%).
20:33:07:WU02:FS02:0x15:Completed  25600000 out of 40000000 steps (64%).
20:34:47:WU01:FS01:0x15:Completed  25600000 out of 40000000 steps (64%).
20:36:43:WU00:FS00:0xa3:Completed 405000 out of 500000 steps  (81%)
20:36:49:WU02:FS02:0x15:Completed  26000000 out of 40000000 steps (65%).
20:38:17:WU01:FS01:0x15:Completed  26000000 out of 40000000 steps (65%).
20:40:32:WU02:FS02:0x15:Completed  26400000 out of 40000000 steps (66%).
20:41:48:WU01:FS01:0x15:Completed  26400000 out of 40000000 steps (66%).
20:42:49:WU00:FS00:0xa3:Completed 410000 out of 500000 steps  (82%)
20:44:17:WU02:FS02:0x15:Completed  26800000 out of 40000000 steps (67%).
20:45:18:WU01:FS01:0x15:Completed  26800000 out of 40000000 steps (67%).
20:47:56:WU02:FS02:0x15:Completed  27200000 out of 40000000 steps (68%).
20:48:47:WU01:FS01:0x15:Completed  27200000 out of 40000000 steps (68%).
20:48:55:WU00:FS00:0xa3:Completed 415000 out of 500000 steps  (83%)
20:51:34:WU02:FS02:0x15:Completed  27600000 out of 40000000 steps (69%).
20:52:16:WU01:FS01:0x15:Completed  27600000 out of 40000000 steps (69%).
20:55:01:WU00:FS00:0xa3:Completed 420000 out of 500000 steps  (84%)
20:55:13:WU02:FS02:0x15:Completed  28000000 out of 40000000 steps (70%).
20:55:46:WU01:FS01:0x15:Completed  28000000 out of 40000000 steps (70%).
20:58:52:WU02:FS02:0x15:Completed  28400000 out of 40000000 steps (71%).
20:59:15:WU01:FS01:0x15:Completed  28400000 out of 40000000 steps (71%).
21:01:06:WU00:FS00:0xa3:Completed 425000 out of 500000 steps  (85%)
21:02:31:WU02:FS02:0x15:Completed  28800000 out of 40000000 steps (72%).
21:02:44:WU01:FS01:0x15:Completed  28800000 out of 40000000 steps (72%).
21:06:10:WU02:FS02:0x15:Completed  29200000 out of 40000000 steps (73%).
21:06:13:WU01:FS01:0x15:Completed  29200000 out of 40000000 steps (73%).
21:07:12:WU00:FS00:0xa3:Completed 430000 out of 500000 steps  (86%)
21:09:42:WU01:FS01:0x15:Completed  29600000 out of 40000000 steps (74%).
21:09:49:WU02:FS02:0x15:Completed  29600000 out of 40000000 steps (74%).
21:13:11:WU01:FS01:0x15:Completed  30000000 out of 40000000 steps (75%).
21:13:17:WU00:FS00:0xa3:Completed 435000 out of 500000 steps  (87%)
21:13:27:WU02:FS02:0x15:Completed  30000000 out of 40000000 steps (75%).
21:16:40:WU01:FS01:0x15:Completed  30400000 out of 40000000 steps (76%).
21:17:06:WU02:FS02:0x15:Completed  30400000 out of 40000000 steps (76%).
21:19:23:WU00:FS00:0xa3:Completed 440000 out of 500000 steps  (88%)
21:20:09:WU01:FS01:0x15:Completed  30800000 out of 40000000 steps (77%).
21:20:45:WU02:FS02:0x15:Completed  30800000 out of 40000000 steps (77%).
21:23:38:WU01:FS01:0x15:Completed  31200000 out of 40000000 steps (78%).
21:24:24:WU02:FS02:0x15:Completed  31200000 out of 40000000 steps (78%).
21:25:29:WU00:FS00:0xa3:Completed 445000 out of 500000 steps  (89%)
21:27:07:WU01:FS01:0x15:Completed  31600000 out of 40000000 steps (79%).
21:28:03:WU02:FS02:0x15:Completed  31600000 out of 40000000 steps (79%).
21:30:36:WU01:FS01:0x15:Completed  32000000 out of 40000000 steps (80%).
21:31:34:WU00:FS00:0xa3:Completed 450000 out of 500000 steps  (90%)
21:31:42:WU02:FS02:0x15:Completed  32000000 out of 40000000 steps (80%).
21:34:05:WU01:FS01:0x15:Completed  32400000 out of 40000000 steps (81%).
21:35:21:WU02:FS02:0x15:Completed  32400000 out of 40000000 steps (81%).
21:37:34:WU01:FS01:0x15:Completed  32800000 out of 40000000 steps (82%).
21:37:39:WU00:FS00:0xa3:Completed 455000 out of 500000 steps  (91%)
21:39:01:WU02:FS02:0x15:Completed  32800000 out of 40000000 steps (82%).
21:41:04:WU01:FS01:0x15:Completed  33200000 out of 40000000 steps (83%).
21:42:42:WU02:FS02:0x15:Completed  33200000 out of 40000000 steps (83%).
21:43:44:WU00:FS00:0xa3:Completed 460000 out of 500000 steps  (92%)
21:44:33:WU01:FS01:0x15:Completed  33600000 out of 40000000 steps (84%).
21:46:22:WU02:FS02:0x15:Completed  33600000 out of 40000000 steps (84%).
21:48:02:WU01:FS01:0x15:Completed  34000000 out of 40000000 steps (85%).
21:49:49:WU00:FS00:0xa3:Completed 465000 out of 500000 steps  (93%)
21:50:02:WU02:FS02:0x15:Completed  34000000 out of 40000000 steps (85%).
21:51:32:WU01:FS01:0x15:Completed  34400000 out of 40000000 steps (86%).
21:53:44:WU02:FS02:0x15:Completed  34400000 out of 40000000 steps (86%).
21:55:02:WU01:FS01:0x15:Completed  34800000 out of 40000000 steps (87%).
21:55:55:WU00:FS00:0xa3:Completed 470000 out of 500000 steps  (94%)
21:57:24:WU02:FS02:0x15:Completed  34800000 out of 40000000 steps (87%).
21:58:33:WU01:FS01:0x15:Completed  35200000 out of 40000000 steps (88%).
22:01:01:WU02:FS02:0x15:Completed  35200000 out of 40000000 steps (88%).
22:02:01:WU00:FS00:0xa3:Completed 475000 out of 500000 steps  (95%)
22:02:02:WU01:FS01:0x15:Completed  35600000 out of 40000000 steps (89%).
22:04:37:WU02:FS02:0x15:Completed  35600000 out of 40000000 steps (89%).
22:05:32:WU01:FS01:0x15:Completed  36000000 out of 40000000 steps (90%).
22:08:08:WU00:FS00:0xa3:Completed 480000 out of 500000 steps  (96%)
22:08:14:WU02:FS02:0x15:Completed  36000000 out of 40000000 steps (90%).
22:09:02:WU01:FS01:0x15:Completed  36400000 out of 40000000 steps (91%).
22:11:51:WU02:FS02:0x15:Completed  36400000 out of 40000000 steps (91%).
22:12:32:WU01:FS01:0x15:Completed  36800000 out of 40000000 steps (92%).
22:14:14:WU00:FS00:0xa3:Completed 485000 out of 500000 steps  (97%)
22:15:28:WU02:FS02:0x15:Completed  36800000 out of 40000000 steps (92%).
22:16:01:WU01:FS01:0x15:Completed  37200000 out of 40000000 steps (93%).
22:19:05:WU02:FS02:0x15:Completed  37200000 out of 40000000 steps (93%).
22:19:31:WU01:FS01:0x15:Completed  37600000 out of 40000000 steps (94%).
22:20:21:WU00:FS00:0xa3:Completed 490000 out of 500000 steps  (98%)
22:22:41:WU02:FS02:0x15:Completed  37600000 out of 40000000 steps (94%).
22:23:01:WU01:FS01:0x15:Completed  38000000 out of 40000000 steps (95%).
22:26:18:WU02:FS02:0x15:Completed  38000000 out of 40000000 steps (95%).
22:26:27:WU00:FS00:0xa3:Completed 495000 out of 500000 steps  (99%)
22:26:28:WU03:FS00:Connecting to 171.67.108.200:8080
22:26:28:WU03:FS00:Assigned to work server 171.67.108.60
22:26:28:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:9 from 171.67.108.60
22:26:28:WU03:FS00:Connecting to 171.67.108.60:8080
22:26:29:WU03:FS00:Downloading 532.42KiB
22:26:30:WU03:FS00:Download complete
22:26:30:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9500 run:1443 clone:1 gen:421 core:0xa4 unit:0x000001c46652edcc53642d9c3074cdc8
22:26:31:WU01:FS01:0x15:Completed  38400000 out of 40000000 steps (96%).
22:29:55:WU02:FS02:0x15:Completed  38400000 out of 40000000 steps (96%).
22:30:00:WU01:FS01:0x15:Completed  38800000 out of 40000000 steps (97%).
22:32:34:WU00:FS00:0xa3:Completed 500000 out of 500000 steps  (100%)
22:32:35:WU00:FS00:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
22:32:45:WU00:FS00:0xa3:
22:32:45:WU00:FS00:0xa3:Finished Work Unit:
22:32:45:WU00:FS00:0xa3:- Reading up to 12092904 from "00/wudata_01.trr": Read 12092904
22:32:45:WU00:FS00:0xa3:trr file hash check passed.
22:32:45:WU00:FS00:0xa3:edr file hash check passed.
22:32:45:WU00:FS00:0xa3:logfile size: 58333
22:32:45:WU00:FS00:0xa3:Leaving Run
22:32:48:WU00:FS00:0xa3:- Writing 12184913 bytes of core data to disk...
22:32:50:WU00:FS00:0xa3:Done: 12184401 -> 11291252 (compressed to 92.6 percent)
22:32:50:WU00:FS00:0xa3:  ... Done.
22:32:51:WU00:FS00:0xa3:- Shutting down core
22:32:51:WU00:FS00:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
22:32:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:32:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:6095 run:28 clone:41 gen:5 core:0xa3 unit:0x000000050a3b1e594f25ce720b7aafaa
22:32:51:WU00:FS00:Uploading 10.77MiB to 128.143.231.202
22:32:51:WU03:FS00:Starting
22:32:51:WU00:FS00:Connecting to 128.143.231.202:8080
22:32:51:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -np 9
22:32:51:WU03:FS00:Started FahCore on PID 2056
22:32:51:WU03:FS00:Core PID:6136
22:32:51:WU03:FS00:FahCore 0xa4 started
22:32:52:WU03:FS00:0xa4:
22:32:52:WU03:FS00:0xa4:*------------------------------*
22:32:52:WU03:FS00:0xa4:Folding@Home Gromacs GB Core
22:32:52:WU03:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:32:52:WU03:FS00:0xa4:Preparing to commence simulation
22:32:52:WU03:FS00:0xa4:- Looking at optimizations...
22:32:52:WU03:FS00:0xa4:- Created dyn
22:32:52:WU03:FS00:0xa4:- Files status OK
22:32:52:WU03:FS00:0xa4:- Expanded 544689 -> 1305980 (decompressed 239.7 percent)
22:32:52:WU03:FS00:0xa4:Called DecompressByteArray: compressed_data_size=544689 data_size=1305980, decompressed_data_size=1305980 diff=0
22:32:52:WU03:FS00:0xa4:- Digital signature verified
22:32:52:WU03:FS00:0xa4:Project: 9500 (Run 1443, Clone 1, Gen 421)
22:32:52:WU03:FS00:0xa4:Assembly optimizations on if available.
22:32:52:WU03:FS00:0xa4:Entering M.D.
22:32:57:WU00:FS00:Upload 17.41%
22:32:57:WU03:FS00:0xa4:Mapping NT from 9 to 9
22:32:57:WU03:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
22:33:03:WU00:FS00:Upload 36.56%
22:33:09:WU00:FS00:Upload 55.72%
22:33:15:WU00:FS00:Upload 74.87%
22:33:21:WU00:FS00:Upload 94.02%
22:33:24:WU03:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
22:33:25:WU00:FS00:Upload complete
22:33:25:WU00:FS00:Server responded WORK_ACK (400)
22:33:25:WU00:FS00:Final credit estimate, 10238.00 points
22:33:25:WU00:FS00:Cleaning up
22:33:31:WU01:FS01:0x15:Completed  39200000 out of 40000000 steps (98%).
22:33:33:WU02:FS02:0x15:Completed  38800000 out of 40000000 steps (97%).
22:33:52:WU03:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
22:34:19:WU03:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
22:34:46:WU03:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
22:35:13:WU03:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
22:35:40:WU03:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
22:36:07:WU03:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
22:36:34:WU03:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
22:37:01:WU03:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
22:37:02:WU01:FS01:0x15:Completed  39600000 out of 40000000 steps (99%).
22:37:02:WU00:FS01:Connecting to 171.67.108.201:80
22:37:02:WU00:FS01:Assigned to work server 171.64.65.105
22:37:02:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GK110 [GeForce GTX 780 Ti] from 171.64.65.105
22:37:02:WU00:FS01:Connecting to 171.64.65.105:8080
22:37:03:WU00:FS01:Downloading 123.88KiB
22:37:03:WU00:FS01:Download complete
22:37:04:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7626 run:374 clone:0 gen:428 core:0x15 unit:0x00000302664f2dd14fe61be6289ed89d
22:37:12:WU02:FS02:0x15:Completed  39200000 out of 40000000 steps (98%).
22:37:28:WU03:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
22:37:55:WU03:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
22:38:22:WU03:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
22:38:49:WU03:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
22:39:16:WU03:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
22:39:43:WU03:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
22:40:10:WU03:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
22:40:32:WU01:FS01:0x15:Completed  40000000 out of 40000000 steps (100%).
22:40:33:WU01:FS01:0x15:Finished fah_main status=0
22:40:33:WU01:FS01:0x15:Successful run
22:40:33:WU01:FS01:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
22:40:37:WU03:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
22:40:43:WU01:FS01:0x15:Reserved 760328 bytes for xtc file; Cosm status=0
22:40:43:WU01:FS01:0x15:Allocated 760328 bytes for xtc file
22:40:43:WU01:FS01:0x15:- Reading up to 760328 from "01/wudata_01.xtc": Read 760328
22:40:43:WU01:FS01:0x15:Read 760328 bytes from xtc file; available packet space=785670136
22:40:43:WU01:FS01:0x15:xtc file hash check passed.
22:40:43:WU01:FS01:0x15:Reserved 47688 47688 785670136 bytes for arc file=<01/wudata_01.trr> Cosm status=0
22:40:43:WU01:FS01:0x15:Allocated 47688 bytes for arc file
22:40:43:WU01:FS01:0x15:- Reading up to 47688 from "01/wudata_01.trr": Read 47688
22:40:43:WU01:FS01:0x15:Read 47688 bytes from arc file; available packet space=785622448
22:40:43:WU01:FS01:0x15:trr file hash check passed.
22:40:43:WU01:FS01:0x15:Allocated 544 bytes for edr file
22:40:43:WU01:FS01:0x15:Read bedfile
22:40:43:WU01:FS01:0x15:edr file hash check passed.
22:40:43:WU01:FS01:0x15:Allocated 36955 bytes for logfile
22:40:43:WU01:FS01:0x15:Read logfile
22:40:43:WU01:FS01:0x15:GuardedRun: success in DynamicWrapper
22:40:43:WU01:FS01:0x15:GuardedRun: done
22:40:43:WU01:FS01:0x15:Run: GuardedRun completed.
22:40:43:WU01:FS01:0x15:+ Opened results file
22:40:43:WU01:FS01:0x15:- Writing 846027 bytes of core data to disk...
22:40:43:WU01:FS01:0x15:Done: 845515 -> 817190 (compressed to 96.6 percent)
22:40:43:WU01:FS01:0x15:  ... Done.
22:40:43:WU01:FS01:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
22:40:43:WU01:FS01:0x15:Shutting down core
22:40:43:WU01:FS01:0x15:Folding@home Core Shutdown: FINISHED_UNIT
22:40:44:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:40:44:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:7623 run:378 clone:0 gen:207 core:0x15 unit:0x00000125664f2dd14fe4fa9403cbdb81
22:40:44:WU01:FS01:Uploading 798.54KiB to 171.64.65.105
22:40:44:WU00:FS01:Starting
22:40:44:WU01:FS01:Connecting to 171.64.65.105:8080
22:40:44:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
22:40:44:WU00:FS01:Started FahCore on PID 3180
22:40:44:WU00:FS01:Core PID:1852
22:40:44:WU00:FS01:FahCore 0x15 started
22:40:44:WU00:FS01:0x15:
22:40:44:WU00:FS01:0x15:*------------------------------*
22:40:44:WU00:FS01:0x15:Folding@Home GPU Core
22:40:44:WU00:FS01:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
22:40:44:WU00:FS01:0x15:Build host             AmoebaRemote
22:40:44:WU00:FS01:0x15:Board Type             NVIDIA/CUDA
22:40:44:WU00:FS01:0x15:Core                   15
22:40:44:WU00:FS01:0x15:Window's signal control handler registered.
22:40:44:WU00:FS01:0x15:Preparing to commence simulation
22:40:44:WU00:FS01:0x15:- Looking at optimizations...
22:40:44:WU00:FS01:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
22:40:44:WU00:FS01:0x15:- Created dyn
22:40:44:WU00:FS01:0x15:- Files status OK
22:40:44:WU00:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
22:40:44:WU00:FS01:0x15:- Expanded 126339 -> 507182 (decompressed 401.4 percent)
22:40:44:WU00:FS01:0x15:Called DecompressByteArray: compressed_data_size=126339 data_size=507182, decompressed_data_size=507182 diff=0
22:40:44:WU00:FS01:0x15:- Digital signature verified
22:40:44:WU00:FS01:0x15:Project: 7626 (Run 374, Clone 0, Gen 428)
22:40:44:WU00:FS01:0x15:Assembly optimizations on if available.
22:40:44:WU00:FS01:0x15:Entering M.D.
22:40:46:WU00:FS01:0x15:Tpr hash 00/wudata_01.tpr:  3683414585 2888267063 1212468587 2765108266 744611744
22:40:46:WU00:FS01:0x15:GPU device id=0
22:40:46:WU00:FS01:0x15:Working on Protein
22:40:46:WU00:FS01:0x15:Client config unavailable.
22:40:46:WU00:FS01:0x15:Starting GUI Server
22:40:47:WU01:FS01:Upload complete
22:40:47:WU01:FS01:Server responded WORK_ACK (400)
22:40:47:WU01:FS01:Final credit estimate, 14093.00 points
22:40:47:WU01:FS01:Cleaning up
22:40:51:WU02:FS02:0x15:Completed  39600000 out of 40000000 steps (99%).
22:40:52:WU01:FS02:Connecting to 171.67.108.201:80
22:40:52:WU01:FS02:Assigned to work server 171.64.65.105
22:40:52:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GK110 [GeForce GTX 780 Ti] from 171.64.65.105
22:40:52:WU01:FS02:Connecting to 171.64.65.105:8080
22:40:53:WU01:FS02:Downloading 121.94KiB
22:40:53:WU01:FS02:Download complete
22:40:53:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7623 run:31 clone:0 gen:264 core:0x15 unit:0x00000168664f2dd14fe4f8a9b2066906
22:41:04:WU03:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
22:41:31:WU03:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
22:41:47:WU00:FS01:0x15:Setting checkpoint frequency: 400000
22:41:47:WU00:FS01:0x15:Completed         3 out of 40000000 steps (0%).
22:41:58:WU03:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
22:42:25:WU03:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
22:42:52:WU03:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
22:43:19:WU03:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
22:43:46:WU03:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
22:44:13:WU03:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
22:44:30:WU02:FS02:0x15:Completed  40000000 out of 40000000 steps (100%).
22:44:30:WU02:FS02:0x15:Finished fah_main status=0
22:44:30:WU02:FS02:0x15:Successful run
22:44:30:WU02:FS02:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
22:44:40:WU02:FS02:0x15:Reserved 760092 bytes for xtc file; Cosm status=0
22:44:40:WU02:FS02:0x15:Allocated 760092 bytes for xtc file
22:44:40:WU02:FS02:0x15:- Reading up to 760092 from "02/wudata_01.xtc": Read 760092
22:44:40:WU02:FS02:0x15:Read 760092 bytes from xtc file; available packet space=785670372
22:44:40:WU02:FS02:0x15:xtc file hash check passed.
22:44:40:WU02:FS02:0x15:Reserved 47688 47688 785670372 bytes for arc file=<02/wudata_01.trr> Cosm status=0
22:44:40:WU02:FS02:0x15:Allocated 47688 bytes for arc file
22:44:40:WU02:FS02:0x15:- Reading up to 47688 from "02/wudata_01.trr": Read 47688
22:44:40:WU02:FS02:0x15:Read 47688 bytes from arc file; available packet space=785622684
22:44:40:WU02:FS02:0x15:trr file hash check passed.
22:44:40:WU02:FS02:0x15:Allocated 544 bytes for edr file
22:44:40:WU02:FS02:0x15:Read bedfile
22:44:40:WU02:FS02:0x15:edr file hash check passed.
22:44:40:WU02:FS02:0x15:Allocated 36955 bytes for logfile
22:44:40:WU02:FS02:0x15:Read logfile
22:44:40:WU02:FS02:0x15:GuardedRun: success in DynamicWrapper
22:44:40:WU02:FS02:0x15:GuardedRun: done
22:44:40:WU02:FS02:0x15:Run: GuardedRun completed.
22:44:40:WU03:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
22:44:43:WU02:FS02:0x15:+ Opened results file
22:44:43:WU02:FS02:0x15:- Writing 845791 bytes of core data to disk...
22:44:43:WU02:FS02:0x15:Done: 845279 -> 817107 (compressed to 96.6 percent)
22:44:43:WU02:FS02:0x15:  ... Done.
22:44:43:WU02:FS02:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
22:44:43:WU02:FS02:0x15:Shutting down core
22:44:43:WU02:FS02:0x15:Folding@home Core Shutdown: FINISHED_UNIT
22:44:44:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:44:44:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:7622 run:534 clone:0 gen:224 core:0x15 unit:0x00000104664f2dd14edd599b39de606b
22:44:44:WU02:FS02:Uploading 798.46KiB to 171.64.65.105
22:44:44:WU01:FS02:Starting
22:44:44:WU02:FS02:Connecting to 171.64.65.105:8080
22:44:44:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
22:44:44:WU01:FS02:Started FahCore on PID 2264
22:44:44:WU01:FS02:Core PID:1940
22:44:44:WU01:FS02:FahCore 0x15 started
22:44:44:WU01:FS02:0x15:
22:44:44:WU01:FS02:0x15:*------------------------------*
22:44:44:WU01:FS02:0x15:Folding@Home GPU Core
22:44:44:WU01:FS02:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
22:44:44:WU01:FS02:0x15:Build host             AmoebaRemote
22:44:44:WU01:FS02:0x15:Board Type             NVIDIA/CUDA
22:44:44:WU01:FS02:0x15:Core                   15
22:44:44:WU01:FS02:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
22:44:44:WU01:FS02:0x15:Window's signal control handler registered.
22:44:44:WU01:FS02:0x15:Preparing to commence simulation
22:44:44:WU01:FS02:0x15:- Looking at optimizations...
22:44:44:WU01:FS02:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
22:44:44:WU01:FS02:0x15:- Created dyn
22:44:44:WU01:FS02:0x15:- Files status OK
22:44:44:WU01:FS02:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
22:44:44:WU01:FS02:0x15:- Expanded 124357 -> 501826 (decompressed 403.5 percent)
22:44:44:WU01:FS02:0x15:Called DecompressByteArray: compressed_data_size=124357 data_size=501826, decompressed_data_size=501826 diff=0
22:44:44:WU01:FS02:0x15:- Digital signature verified
22:44:44:WU01:FS02:0x15:Project: 7623 (Run 31, Clone 0, Gen 264)
22:44:44:WU01:FS02:0x15:Assembly optimizations on if available.
22:44:44:WU01:FS02:0x15:Entering M.D.
22:44:46:WU01:FS02:0x15:Tpr hash 01/wudata_01.tpr:  3226238486 1586144936 355342816 65659271 2790559096
22:44:46:WU01:FS02:0x15:GPU device id=1
22:44:46:WU01:FS02:0x15:Working on Protein
22:44:46:WU01:FS02:0x15:Client config unavailable.
22:44:46:WU01:FS02:0x15:Starting GUI Server
22:44:47:WU02:FS02:Upload complete
22:44:47:WU02:FS02:Server responded WORK_ACK (400)
22:44:47:WU02:FS02:Final credit estimate, 14093.00 points
22:44:47:WU02:FS02:Cleaning up
22:45:08:WU03:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
22:45:20:WU00:FS01:0x15:Completed    400000 out of 40000000 steps (1%).
22:45:35:WU03:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
22:45:48:WU01:FS02:0x15:Setting checkpoint frequency: 400000
22:45:48:WU01:FS02:0x15:Completed         3 out of 40000000 steps (0%).
22:46:02:WU03:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
22:46:29:WU03:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
22:46:56:WU03:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
22:47:23:WU03:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
22:47:50:WU03:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
22:48:18:WU03:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
22:48:45:WU03:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
22:48:53:WU00:FS01:0x15:Completed    800000 out of 40000000 steps (2%).
22:49:12:WU03:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
22:49:27:WU01:FS02:0x15:Completed    400000 out of 40000000 steps (1%).
22:49:39:WU03:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
22:50:06:WU03:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
22:50:33:WU03:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
22:51:01:WU03:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
22:51:28:WU03:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
22:51:55:WU03:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
22:52:22:WU03:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
22:52:26:WU00:FS01:0x15:Completed   1200000 out of 40000000 steps (3%).
22:52:49:WU03:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
22:53:06:WU01:FS02:0x15:Completed    800000 out of 40000000 steps (2%).
22:53:16:WU03:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
22:53:43:WU03:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
22:54:10:WU03:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
22:54:37:WU03:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
22:55:04:WU03:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
22:55:31:WU03:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
22:55:59:WU03:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
22:55:59:WU00:FS01:0x15:Completed   1600000 out of 40000000 steps (4%).
22:56:26:WU03:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
22:56:45:WU01:FS02:0x15:Completed   1200000 out of 40000000 steps (3%).
22:56:53:WU03:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
22:57:20:WU03:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
22:57:47:WU03:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
22:58:14:WU03:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
22:58:41:WU03:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
22:59:08:WU03:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
22:59:32:WU00:FS01:0x15:Completed   2000000 out of 40000000 steps (5%).
22:59:36:WU03:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
23:00:03:WU03:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
23:00:23:WU01:FS02:0x15:Completed   1600000 out of 40000000 steps (4%).
23:00:30:WU03:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
23:00:57:WU03:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
23:01:24:WU03:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
23:01:51:WU03:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
23:02:19:WU03:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
23:02:46:WU03:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
23:03:05:WU00:FS01:0x15:Completed   2400000 out of 40000000 steps (6%).
23:03:13:WU03:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
23:03:40:WU03:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
23:04:02:WU01:FS02:0x15:Completed   2000000 out of 40000000 steps (5%).
23:04:07:WU03:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
23:04:34:WU03:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
23:05:02:WU03:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
23:05:29:WU03:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
23:05:56:WU03:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
23:06:23:WU03:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
23:06:38:WU00:FS01:0x15:Completed   2800000 out of 40000000 steps (7%).
23:06:50:WU03:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
23:07:18:WU03:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
23:07:41:WU01:FS02:0x15:Completed   2400000 out of 40000000 steps (6%).
23:07:45:WU03:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
23:08:12:WU03:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
23:08:39:WU03:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
23:09:06:WU03:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
23:09:33:WU03:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
23:10:00:WU03:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
23:10:12:WU00:FS01:0x15:Completed   3200000 out of 40000000 steps (8%).
23:10:28:WU03:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
23:10:55:WU03:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
23:11:20:WU01:FS02:0x15:Completed   2800000 out of 40000000 steps (7%).
23:11:22:WU03:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
23:11:49:WU03:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
23:12:16:WU03:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
23:12:44:WU03:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
23:13:11:WU03:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
23:13:38:WU03:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
23:13:45:WU00:FS01:0x15:Completed   3600000 out of 40000000 steps (9%).
23:14:05:WU03:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
23:14:33:WU03:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
23:14:59:WU01:FS02:0x15:Completed   3200000 out of 40000000 steps (8%).
23:15:00:WU03:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
23:15:27:WU03:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
23:15:54:WU03:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
23:16:21:WU03:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
23:16:49:WU03:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
23:17:16:WU03:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
23:17:18:WU00:FS01:0x15:Completed   4000000 out of 40000000 steps (10%).
23:17:43:WU03:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
23:17:44:WU02:FS00:Connecting to 171.67.108.200:8080
23:17:44:WU02:FS00:Assigned to work server 171.67.108.60
23:17:44:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:9 from 171.67.108.60
23:17:44:WU02:FS00:Connecting to 171.67.108.60:8080
23:17:45:WU02:FS00:Downloading 532.77KiB
23:17:46:WU02:FS00:Download complete
23:17:46:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9500 run:1997 clone:0 gen:269 core:0xa4 unit:0x000001256652edcc53642ea3b6770a54
23:18:11:WU03:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
23:18:11:WU03:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
23:18:21:WU03:FS00:0xa4:
23:18:21:WU03:FS00:0xa4:Finished Work Unit:
23:18:21:WU03:FS00:0xa4:- Reading up to 513504 from "03/wudata_01.trr": Read 513504
23:18:21:WU03:FS00:0xa4:trr file hash check passed.
23:18:21:WU03:FS00:0xa4:- Reading up to 456548 from "03/wudata_01.xtc": Read 456548
23:18:21:WU03:FS00:0xa4:xtc file hash check passed.
23:18:21:WU03:FS00:0xa4:edr file hash check passed.
23:18:21:WU03:FS00:0xa4:logfile size: 22647
23:18:21:WU03:FS00:0xa4:Leaving Run
23:18:21:WU03:FS00:0xa4:- Writing 998103 bytes of core data to disk...
23:18:22:WU03:FS00:0xa4:Done: 997591 -> 959542 (compressed to 96.1 percent)
23:18:22:WU03:FS00:0xa4:  ... Done.
23:18:22:WU03:FS00:0xa4:- Shutting down core
23:18:22:WU03:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
23:18:22:WU03:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:18:22:WU03:FS00:Sending unit results: id:03 state:SEND error:NO_ERROR project:9500 run:1443 clone:1 gen:421 core:0xa4 unit:0x000001c46652edcc53642d9c3074cdc8
23:18:22:WU03:FS00:Uploading 937.55KiB to 171.67.108.60
23:18:22:WU03:FS00:Connecting to 171.67.108.60:8080
23:18:22:WU02:FS00:Starting
23:18:22:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -np 9
23:18:22:WU02:FS00:Started FahCore on PID 5248
23:18:22:WU02:FS00:Core PID:1640
23:18:22:WU02:FS00:FahCore 0xa4 started
23:18:23:WU02:FS00:0xa4:
23:18:23:WU02:FS00:0xa4:*------------------------------*
23:18:23:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
23:18:23:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
23:18:23:WU02:FS00:0xa4:Preparing to commence simulation
23:18:23:WU02:FS00:0xa4:- Looking at optimizations...
23:18:23:WU02:FS00:0xa4:- Created dyn
23:18:23:WU02:FS00:0xa4:- Files status OK
23:18:23:WU02:FS00:0xa4:- Expanded 545047 -> 1307132 (decompressed 239.8 percent)
23:18:23:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=545047 data_size=1307132, decompressed_data_size=1307132 diff=0
23:18:23:WU02:FS00:0xa4:- Digital signature verified
23:18:23:WU02:FS00:0xa4:Project: 9500 (Run 1997, Clone 0, Gen 269)
23:18:23:WU02:FS00:0xa4:Assembly optimizations on if available.
23:18:23:WU02:FS00:0xa4:Entering M.D.
23:18:26:WU03:FS00:Upload complete
23:18:26:WU03:FS00:Server responded WORK_ACK (400)
23:18:26:WU03:FS00:Final credit estimate, 918.00 points
23:18:26:WU03:FS00:Cleaning up
23:18:28:WU02:FS00:0xa4:Mapping NT from 9 to 9
23:18:28:WU02:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
23:18:37:WU01:FS02:0x15:Completed   3600000 out of 40000000 steps (9%).
23:18:56:WU02:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
23:19:23:WU02:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
23:19:50:WU02:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
23:20:17:WU02:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
23:20:45:WU02:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
23:20:51:WU00:FS01:0x15:Completed   4400000 out of 40000000 steps (11%).
23:21:12:WU02:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
23:21:39:WU02:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
23:22:06:WU02:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
23:22:16:WU01:FS02:0x15:Completed   4000000 out of 40000000 steps (10%).
23:22:34:WU02:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
23:23:01:WU02:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
23:23:28:WU02:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
23:23:56:WU02:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
23:24:23:WU02:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
23:24:24:WU00:FS01:0x15:Completed   4800000 out of 40000000 steps (12%).
23:24:50:WU02:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
23:25:18:WU02:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
23:25:45:WU02:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
23:25:56:WU01:FS02:0x15:Completed   4400000 out of 40000000 steps (11%).
23:26:13:WU02:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
23:26:40:WU02:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
23:27:07:WU02:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
23:27:35:WU02:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
23:27:58:WU00:FS01:0x15:Completed   5200000 out of 40000000 steps (13%).
23:28:02:WU02:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
23:28:30:WU02:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
23:28:57:WU02:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
23:29:24:WU02:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
23:29:35:WU01:FS02:0x15:Completed   4800000 out of 40000000 steps (12%).
23:29:52:WU02:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
23:30:19:WU02:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
23:30:46:WU02:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
23:31:14:WU02:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
23:31:31:WU00:FS01:0x15:Completed   5600000 out of 40000000 steps (14%).
23:31:41:WU02:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
23:32:08:WU02:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
23:32:36:WU02:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
23:33:03:WU02:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
23:33:13:WU01:FS02:0x15:Completed   5200000 out of 40000000 steps (13%).
23:33:31:WU02:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
23:33:58:WU02:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
23:34:26:WU02:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
23:34:53:WU02:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
23:35:04:WU00:FS01:0x15:Completed   6000000 out of 40000000 steps (15%).
23:35:20:WU02:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
23:35:48:WU02:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
23:36:15:WU02:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
23:36:43:WU02:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
23:36:52:WU01:FS02:0x15:Completed   5600000 out of 40000000 steps (14%).
23:37:10:WU02:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
23:37:37:WU02:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
23:38:05:WU02:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
23:38:32:WU02:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
23:38:37:WU00:FS01:0x15:Completed   6400000 out of 40000000 steps (16%).
23:39:00:WU02:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
23:39:27:WU02:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
23:39:55:WU02:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
23:40:22:WU02:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
23:40:31:WU01:FS02:0x15:Completed   6000000 out of 40000000 steps (15%).
23:40:49:WU02:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
23:41:17:WU02:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
23:41:44:WU02:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
23:42:10:WU00:FS01:0x15:Completed   6800000 out of 40000000 steps (17%).
23:42:12:WU02:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
23:42:39:WU02:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
23:43:07:WU02:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
23:43:34:WU02:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
23:44:01:WU02:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
23:44:10:WU01:FS02:0x15:Completed   6400000 out of 40000000 steps (16%).
23:44:29:WU02:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
23:44:56:WU02:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
23:45:24:WU02:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
23:45:44:WU00:FS01:0x15:Completed   7200000 out of 40000000 steps (18%).
23:45:51:WU02:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
23:46:19:WU02:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
23:46:46:WU02:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
23:47:13:WU02:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
23:47:41:WU02:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
23:47:49:WU01:FS02:0x15:Completed   6800000 out of 40000000 steps (17%).
23:48:08:WU02:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
23:48:36:WU02:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
23:49:03:WU02:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
23:49:17:WU00:FS01:0x15:Completed   7600000 out of 40000000 steps (19%).
23:49:30:WU02:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
23:49:58:WU02:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
23:50:25:WU02:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
23:50:52:WU02:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
23:51:20:WU02:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
23:51:28:WU01:FS02:0x15:Completed   7200000 out of 40000000 steps (18%).
23:51:47:WU02:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
23:52:14:WU02:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
23:52:42:WU02:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
23:52:50:WU00:FS01:0x15:Completed   8000000 out of 40000000 steps (20%).
23:53:09:WU02:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
23:53:36:WU02:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
23:54:04:WU02:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
23:54:31:WU02:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
23:54:58:WU02:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
23:55:06:WU01:FS02:0x15:Completed   7600000 out of 40000000 steps (19%).
23:55:26:WU02:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
23:55:53:WU02:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
23:56:20:WU02:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
23:56:23:WU00:FS01:0x15:Completed   8400000 out of 40000000 steps (21%).
23:56:48:WU02:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
23:57:15:WU02:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
23:57:43:WU02:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
23:58:10:WU02:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
23:58:37:WU02:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
23:58:45:WU01:FS02:0x15:Completed   8000000 out of 40000000 steps (20%).
23:59:05:WU02:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
23:59:32:WU02:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
23:59:56:WU00:FS01:0x15:Completed   8800000 out of 40000000 steps (22%).
00:00:00:WU02:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
00:00:27:WU02:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
00:00:54:WU02:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
00:01:22:WU02:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
00:01:49:WU02:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
00:02:16:WU02:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
00:02:24:WU01:FS02:0x15:Completed   8400000 out of 40000000 steps (21%).
00:02:44:WU02:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
00:03:12:WU02:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
00:03:29:WU00:FS01:0x15:Completed   9200000 out of 40000000 steps (23%).
00:03:39:WU02:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
00:03:40:WU03:FS00:Connecting to 171.67.108.200:8080
00:03:40:WU03:FS00:Assigned to work server 155.247.166.219
00:03:40:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:9 from 155.247.166.219
00:03:40:WU03:FS00:Connecting to 155.247.166.219:8080
00:03:40:WU03:FS00:Downloading 115.09KiB
00:03:41:WU03:FS00:Download complete
00:03:41:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:6370 run:11 clone:0 gen:136 core:0xa4 unit:0x0000009c0002894b53343343393309dd
00:04:06:WU02:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
00:04:07:WU02:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
00:04:17:WU02:FS00:0xa4:
00:04:17:WU02:FS00:0xa4:Finished Work Unit:
00:04:17:WU02:FS00:0xa4:- Reading up to 514080 from "02/wudata_01.trr": Read 514080
00:04:17:WU02:FS00:0xa4:trr file hash check passed.
00:04:17:WU02:FS00:0xa4:- Reading up to 457276 from "02/wudata_01.xtc": Read 457276
00:04:17:WU02:FS00:0xa4:xtc file hash check passed.
00:04:17:WU02:FS00:0xa4:edr file hash check passed.
00:04:17:WU02:FS00:0xa4:logfile size: 22635
00:04:17:WU02:FS00:0xa4:Leaving Run
00:04:17:WU02:FS00:0xa4:- Writing 999395 bytes of core data to disk...
00:04:17:WU02:FS00:0xa4:Done: 998883 -> 960812 (compressed to 96.1 percent)
00:04:17:WU02:FS00:0xa4:  ... Done.
00:04:18:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:04:18:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9500 run:1997 clone:0 gen:269 core:0xa4 unit:0x000001256652edcc53642ea3b6770a54
00:04:18:WU02:FS00:Uploading 938.79KiB to 171.67.108.60
00:04:18:WU02:FS00:Connecting to 171.67.108.60:8080
00:04:18:WU03:FS00:Starting
00:04:18:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 3248 -checkpoint 15 -np 9
00:04:18:WU03:FS00:Started FahCore on PID 2248
00:04:18:WU03:FS00:Core PID:2352
00:04:18:WU03:FS00:FahCore 0xa4 started
00:04:18:WU03:FS00:0xa4:
00:04:18:WU03:FS00:0xa4:*------------------------------*
00:04:18:WU03:FS00:0xa4:Folding@Home Gromacs GB Core
00:04:18:WU03:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:04:18:WU03:FS00:0xa4:Preparing to commence simulation
00:04:18:WU03:FS00:0xa4:- Looking at optimizations...
00:04:18:WU03:FS00:0xa4:- Created dyn
00:04:18:WU03:FS00:0xa4:- Files status OK
00:04:18:WU03:FS00:0xa4:- Expanded 117339 -> 264000 (decompressed 224.9 percent)
00:04:18:WU03:FS00:0xa4:Called DecompressByteArray: compressed_data_size=117339 data_size=264000, decompressed_data_size=264000 diff=0
00:04:18:WU03:FS00:0xa4:- Digital signature verified
bob_b
Re: New to folding , Points/ work type question
Post by bob_b »
Ps. The log shows medium but after four or five hours of everything running stable, i switched it to FULL... Folded @ full all day sunday and into today... all stable, temps or CPU & both GPU's are fine...
To get full points you need to set a passkey. Without a passkey you are getting just the base points awarded for the WU's processed. Once you set a passkey and complete 10 WU's downloaded after starting to fold with the passkey, then you will get a much higher points award. See the Passkey FAQ. The first 10 WU's folded with a passkey will show an estimated points credit based on having a passkey, but you will get just the base points in the official stats. Once an username and passkey combination is qualified, as long as you maintain an 80% successful completion rate after that you will get the points based on the Quick Return Bonus(QRB).
P.S. Also I noticed that the GPU WU's shown in your log were being processed with Core_15. These older projects are not eligible for the QRB. GPU projects using later cores such as Core_17 do get QRB awards. For now you should be getting a mix of the two cores to process, eventually Core_15 work will be finished or reached a point that it gets lower priority.
bob_b
Post by bob_b »
I got and put my passkey in after 14 successful WU's I've completed 46 as of this writing so i guess I have something messed up ? Oh well... The CPU and two GPU's are some serious hardware and being both 20% overclocked they are folding up a storm... guess that's what really counts, not the points...
bob_b
Post by bob_b »
Joe thank you. I see now. I am getting jobs with a 48 day time to complete and the GPU's are chewing through them in like 3 hours !!! I'm happy to help and do the older WU's. I think everything is running just fine.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Those older Core_15 WU's do not give QRB points. Only newer Core_17 projects get them. However, you have little control over the WU's you get assigned.
Once you start getting Core_17's then your passkey will start being qualified. You need to get 10 of them qualify your passkey and maintain an 80% successful return rate to get QRB points on Core_17's.
However, Core_17's also detect calculation errors caused by OC'ing much more frequently than earlier cores. You will need to monitor failures and adjust your OC if you see any failures. The earlier you fix any problem with the OC the faster you will qualify the passkey because of that minimum 80% successful return rate requirement.
bob_b
Hardware configuration: I7-3970X Extreme, 6 core (overclocked to 4.5Mhz all cores ) 32Gb 1888mhz Ram, Intel 730 480Gb SSD, Two Zortac Amp! GTX 780 Ti's (overclocked to 1175 Mhz) Water cooled Windows 8.1
Post by bob_b »
Will the log show error's ? ( if i have any during the folding )
I refreshed and copy and pasted my log into a document and searched error... all i found throughout the log was no_error
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Yes, do note the error check box...
The risk for OC'ing is when you start getting Core_17 WU's which detects many more calculation errors. The log you showed were just of Core_15's. So keep monitoring for those errors.
The CPU jobs using the A3 and A4 cores will also work towards qualifying you for the QRB points. WU's that fail due to overclocking or other reasons will have an error report sent, you can also search for a Fail notice. Once you have done restarts of the client, older log files (default is up to 16) are kept in a logs folder in the same directory as the current log.txt file.
bob_b
Post by bob_b »
I turned down the overclocking and in the past 2 days i got one error (overclocked) (below) i'll check on a daily basis to make sure once I start receiving Core_17 Wu's that all is ok Thanks guys for all the suggestions
06:08:23:WARNING:WU02:FS02:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
06:09:28:WARNING:WU02:FS02:Detected clock skew (1 mins 05 secs), adjusting time estimates
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Don't worry about clock skew messages
Nert
Post by Nert »
Bob_B
That's some serious processing power there. I'm always happy to see more cycles being devoted to this project. :D Thanks !
I've been doing this for several years and your rig will probably pass up my total in short order. Well Done
bob_b
Post by bob_b »
Nert, I won this computer by chance in a contest. It could run a small country ( lol ) so i decided i'll try as much as I can to let it fold 24/7 so it is used for something useful. Not sure if WU's are assigned randomly and i don't know who to contact to let them know it's available
bob_b
Post by bob_b »
Is there anyway I can get a core_17 assigned to one of my GPU's to make sure my rig is going to run error free ? 47 Wu's and not one core_17 assigned to either GPU ... ?? thats not random as a previous poster suggested
There is no switch specific to getting core_17. You will get some eventually.
