Ubuntu - GPU just downloads, sends, downloads, sends
runpaint
Post by runpaint »
I have installed FAH on Windows machines since 2007,
but I've notice some slight differences with Linux.
The main difference is that I can't get it to work.
I just got this 2U blade server with Ubuntu, and I've never used Linux before.
It had FAH installed and running, but very slowly on this old i7 and GTX560ti,
with NVIDIA version 343.13, and 4 case fans that sound like a crashing airplane.
So I replaced the 560ti with a new 750ti, but then it wouldn't work with GPU.
So I put back in the 560ti, but then it still wouldn't work with GPU.
So I uninstalled FAHClient, FAHControl, and FAHViewer,
and then reinstalled all of them. But then it wouldn't even work with CPU.
It's a 64 bit system, but then I tried the 32 bit version just to see if it would work.
It didn't work. Then I uninstalled and reinstalled 2 or 3 more times,
and eventually I got it to work with CPU again, but it only loads FAHControl on startup,
and I have to start FAHClient in a terminal.
I've also tried starting FAHCoreWrapper in a terminal,
before or after I start FAHClient, but it doesn't seem to make a difference.
So I figured if it's going to be complicated anyway, I might as well do it like I want,
and I put the 750ti back in, downgraded the drivers to 340.32
because that's the official recommended version for my card,
and I removed the CPU slot because it's too slow, the fans are much too loud,
and it's not worth running 7 cores for 7 days per WU @ >200ppd and missing the Timeout.
Then it still wouldn't recognize the GPU, so i had to add the GPU.txt file,
but I didn't have root permission, so I had to find out how to run Nautilus,
but then I first had to install gksu, so I did, and I put the GPU.txt in the folder,
and that is the story of how I added a GPU slot, but it won't fold.
So I changed the drivers back to 343.13, and it won't fold,
so I finally registered for an account after reading a lot of advice here,
and hopefully the way you post logs is by putting them in quote brackets.
03:54:37:Removing old file 'configs/config-20140824-023313.xml'
03:54:37:Saving configuration to /etc/fahclient/config.xml
03:54:37:<config>
03:54:37:  <!-- Folding Core -->
03:54:37:  <checkpoint v='30'/>
03:54:37:  <core-priority v='low'/>
03:54:37:
03:54:37:  <!-- Network -->
03:54:37:  <proxy v=':8080'/>
03:54:37:
03:54:37:  <!-- Slot Control -->
03:54:37:  <power v='full'/>
03:54:37:
03:54:37:  <!-- User Information -->
03:54:37:  <passkey v='********************************'/>
03:54:37:  <team v='66731'/>
03:54:37:  <user v='Adam_Hornbuckle'/>
03:54:37:
03:54:37:  <!-- Folding Slots -->
03:54:37:  <slot id='0' type='GPU'>
03:54:37:    <paused v='true'/>
03:54:37:  </slot>
03:54:37:</config>
03:54:39:FS00:Unpaused
03:54:39:WU01:FS00:Starting
03:54:39:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 2332 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
03:54:39:WU01:FS00:Started FahCore on PID 2558
03:54:39:WU01:FS00:Core PID:2562
03:54:39:WU01:FS00:FahCore 0x17 started
03:54:39:WU01:FS00:0x17:*********************** Log Started 2014-08-24T03:54:39Z ***********************
03:54:39:WU01:FS00:0x17:Project: 9201 (Run 691, Clone 1, Gen 31)
03:54:39:WU01:FS00:0x17:Unit: 0x000000316652edc45399f1364772a792
03:54:39:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:54:39:WU01:FS00:0x17:Machine: 0
03:54:39:WU01:FS00:0x17:Reading tar file state.xml
03:54:39:WU01:FS00:0x17:Reading tar file system.xml
03:54:39:WU01:FS00:0x17:Reading tar file integrator.xml
03:54:39:WU01:FS00:0x17:Reading tar file core.xml
03:54:39:WU01:FS00:0x17:Digital signatures verified
03:54:39:WU01:FS00:0x17:ERROR:exception: Bad platformId size.
03:54:39:WU01:FS00:0x17:Saving result file logfile_01.txt
03:54:39:WU01:FS00:0x17:Saving result file log.txt
03:54:39:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
03:54:40:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:54:40:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9201 run:691 clone:1 gen:31 core:0x17 unit:0x000000316652edc45399f1364772a792
03:54:40:WU01:FS00:Uploading 1.81KiB to 171.67.108.52
03:54:40:WU01:FS00:Connecting to 171.67.108.52:8080
03:54:40:WU01:FS00:Upload complete
03:54:40:WU01:FS00:Server responded WORK_ACK (400)
03:54:40:WU01:FS00:Cleaning up
03:54:40:WU00:FS00:Connecting to 171.67.108.201:80
03:54:41:WU00:FS00:Assigned to work server 171.67.108.52
03:54:41:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 171.67.108.52
03:54:41:WU00:FS00:Connecting to 171.67.108.52:8080
03:54:41:WU00:FS00:Downloading 1.53MiB
03:54:47:WU00:FS00:Download 20.49%
03:54:53:WU00:FS00:Download 40.98%
03:54:59:WU00:FS00:Download 86.06%
03:55:01:WU00:FS00:Download complete
03:55:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:600 clone:0 gen:108 core:0x17 unit:0x0000009d6652edc45399ed9975c7dd8e
03:55:01:WU00:FS00:Starting
03:55:01:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 2332 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
03:55:01:WU00:FS00:Started FahCore on PID 2565
03:55:01:WU00:FS00:Core PID:2569
03:55:01:WU00:FS00:FahCore 0x17 started
03:55:01:WU00:FS00:0x17:*********************** Log Started 2014-08-24T03:55:01Z ***********************
03:55:01:WU00:FS00:0x17:Project: 9201 (Run 600, Clone 0, Gen 108)
03:55:01:WU00:FS00:0x17:Unit: 0x0000009d6652edc45399ed9975c7dd8e
03:55:01:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:55:01:WU00:FS00:0x17:Machine: 0
03:55:01:WU00:FS00:0x17:Reading tar file state.xml
03:55:01:WU00:FS00:0x17:Reading tar file system.xml
03:55:01:WU00:FS00:0x17:Reading tar file integrator.xml
03:55:01:WU00:FS00:0x17:Reading tar file core.xml
03:55:01:WU00:FS00:0x17:Digital signatures verified
03:55:01:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
03:55:01:WU00:FS00:0x17:Saving result file logfile_01.txt
03:55:01:WU00:FS00:0x17:Saving result file log.txt
03:55:01:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
03:55:02:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:55:02:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:600 clone:0 gen:108 core:0x17 unit:0x0000009d6652edc45399ed9975c7dd8e
03:55:02:WU00:FS00:Uploading 1.82KiB to 171.67.108.52
03:55:02:WU00:FS00:Connecting to 171.67.108.52:8080
03:55:02:WU01:FS00:Connecting to 171.67.108.201:80
03:55:02:WU00:FS00:Upload complete
03:55:03:WU00:FS00:Server responded WORK_ACK (400)
03:55:03:WU00:FS00:Cleaning up
03:55:03:WU01:FS00:Assigned to work server 171.67.108.52
03:55:03:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 171.67.108.52
03:55:03:WU01:FS00:Connecting to 171.67.108.52:8080
03:55:04:WU01:FS00:Downloading 1.52MiB
03:55:10:WU01:FS00:Download 40.99%
03:55:16:WU01:FS00:Download 65.59%
03:55:20:WU01:FS00:Download complete
03:55:20:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:717 clone:1 gen:57 core:0x17 unit:0x0000005c6652edc45399f23ad5a15452
03:55:20:WU01:FS00:Starting
03:55:20:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 2332 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
03:55:20:WU01:FS00:Started FahCore on PID 2572
03:55:20:WU01:FS00:Core PID:2576
03:55:20:WU01:FS00:FahCore 0x17 started
03:55:21:WU01:FS00:0x17:*********************** Log Started 2014-08-24T03:55:20Z ***********************
03:55:21:WU01:FS00:0x17:Project: 9201 (Run 717, Clone 1, Gen 57)
03:55:21:WU01:FS00:0x17:Unit: 0x0000005c6652edc45399f23ad5a15452
03:55:21:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:55:21:WU01:FS00:0x17:Machine: 0
03:55:21:WU01:FS00:0x17:Reading tar file state.xml
03:55:21:WU01:FS00:0x17:Reading tar file system.xml
03:55:21:WU01:FS00:0x17:Reading tar file integrator.xml
03:55:21:WU01:FS00:0x17:Reading tar file core.xml
03:55:21:WU01:FS00:0x17:Digital signatures verified
03:55:21:WU01:FS00:0x17:ERROR:exception: Bad platformId size.
03:55:21:WU01:FS00:0x17:Saving result file logfile_01.txt
03:55:21:WU01:FS00:0x17:Saving result file log.txt
03:55:21:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
03:55:21:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:55:21:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9201 run:717 clone:1 gen:57 core:0x17 unit:0x0000005c6652edc45399f23ad5a15452
03:55:21:WU01:FS00:Uploading 1.81KiB to 171.67.108.52
03:55:21:WU01:FS00:Connecting to 171.67.108.52:8080
03:55:21:WU00:FS00:Connecting to 171.67.108.201:80
03:55:21:WU01:FS00:Upload complete
03:55:21:WU01:FS00:Server responded WORK_ACK (400)
03:55:21:WU01:FS00:Cleaning up
03:55:22:Removing old file 'configs/config-20140824-023717.xml'
03:55:22:Saving configuration to /etc/fahclient/config.xml
03:55:22:<config>
03:55:22:  <!-- Folding Core -->
03:55:22:  <checkpoint v='30'/>
03:55:22:  <core-priority v='low'/>
03:55:22:
03:55:22:  <!-- Network -->
03:55:22:  <proxy v=':8080'/>
03:55:22:
03:55:22:  <!-- Slot Control -->
03:55:22:  <power v='full'/>
03:55:22:
03:55:22:  <!-- User Information -->
03:55:22:  <passkey v='********************************'/>
03:55:22:  <team v='66731'/>
03:55:22:  <user v='Adam_Hornbuckle'/>
03:55:22:
03:55:22:  <!-- Folding Slots -->
03:55:22:  <slot id='0' type='GPU'/>
03:55:22:</config>
03:55:22:WU00:FS00:Assigned to work server 171.67.108.52
03:55:22:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 171.67.108.52
03:55:22:WU00:FS00:Connecting to 171.67.108.52:8080
03:55:23:WU00:FS00:Downloading 1.52MiB
03:55:26:FS00:Paused
03:55:32:WU00:FS00:Download 12.37%
03:55:38:WU00:FS00:Download 57.70%
03:55:44:WU00:FS00:Download 86.56%
03:55:46:WU00:FS00:Download complete
03:55:46:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:255 clone:1 gen:34 core:0x17 unit:0x0000004a6652edc45399e0096a720f15
03:56:23:Removing old file 'configs/config-20140824-023720.xml'
03:56:23:Saving configuration to /etc/fahclient/config.xml
03:56:23:<config>
03:56:23:  <!-- Folding Core -->
03:56:23:  <checkpoint v='30'/>
03:56:23:  <core-priority v='low'/>
03:56:23:
03:56:23:  <!-- Network -->
03:56:23:  <proxy v=':8080'/>
03:56:23:
03:56:23:  <!-- Slot Control -->
03:56:23:  <power v='full'/>
03:56:23:
03:56:23:  <!-- User Information -->
03:56:23:  <passkey v='********************************'/>
03:56:23:  <team v='66731'/>
03:56:23:  <user v='Adam_Hornbuckle'/>
03:56:23:
03:56:23:  <!-- Folding Slots -->
03:56:23:  <slot id='0' type='GPU'>
03:56:23:    <paused v='true'/>
03:56:23:  </slot>
03:56:23:</config>
04:26:30:FS00:Unpaused
04:26:30:WU00:FS00:Starting
04:26:30:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 2332 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
04:26:30:WU00:FS00:Started FahCore on PID 2695
04:26:30:WU00:FS00:Core PID:2699
04:26:30:WU00:FS00:FahCore 0x17 started
04:26:31:WU00:FS00:0x17:*********************** Log Started 2014-08-24T04:26:30Z ***********************
04:26:31:WU00:FS00:0x17:Project: 9201 (Run 255, Clone 1, Gen 34)
04:26:31:WU00:FS00:0x17:Unit: 0x0000004a6652edc45399e0096a720f15
04:26:31:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
04:26:31:WU00:FS00:0x17:Machine: 0
04:26:31:WU00:FS00:0x17:Reading tar file state.xml
04:26:31:WU00:FS00:0x17:Reading tar file system.xml
04:26:31:WU00:FS00:0x17:Reading tar file integrator.xml
04:26:31:WU00:FS00:0x17:Reading tar file core.xml
04:26:31:WU00:FS00:0x17:Digital signatures verified
04:26:31:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
04:26:31:WU00:FS00:0x17:Saving result file logfile_01.txt
04:26:31:WU00:FS00:0x17:Saving result file log.txt
04:26:31:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
04:26:31:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:26:31:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:255 clone:1 gen:34 core:0x17 unit:0x0000004a6652edc45399e0096a720f15
04:26:31:WU00:FS00:Uploading 1.81KiB to 171.67.108.52
04:26:31:WU00:FS00:Connecting to 171.67.108.52:8080
04:26:31:WU00:FS00:Upload complete
04:26:31:WU00:FS00:Server responded WORK_ACK (400)
04:26:31:WU00:FS00:Cleaning up
04:26:32:WU01:FS00:Connecting to 171.67.108.201:80
04:26:32:WU01:FS00:Assigned to work server 171.67.108.52
04:26:32:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 171.67.108.52
04:26:32:WU01:FS00:Connecting to 171.67.108.52:8080
04:26:33:WU01:FS00:Downloading 1.52MiB
04:26:39:WU01:FS00:Download 41.03%
04:26:45:WU01:FS00:Download 73.86%
04:26:48:WU01:FS00:Download complete
04:26:48:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:4 clone:1 gen:30 core:0x17 unit:0x000000436652edc45399d6349bc04125
04:26:48:WU01:FS00:Starting
04:26:48:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 2332 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
04:26:48:WU01:FS00:Started FahCore on PID 2702
04:26:48:WU01:FS00:Core PID:2706
04:26:48:WU01:FS00:FahCore 0x17 started
04:26:49:WU01:FS00:0x17:*********************** Log Started 2014-08-24T04:26:48Z ***********************
04:26:49:WU01:FS00:0x17:Project: 9201 (Run 4, Clone 1, Gen 30)
04:26:49:WU01:FS00:0x17:Unit: 0x000000436652edc45399d6349bc04125
04:26:49:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
04:26:49:WU01:FS00:0x17:Machine: 0
04:26:49:WU01:FS00:0x17:Reading tar file state.xml
04:26:49:WU01:FS00:0x17:Reading tar file system.xml
04:26:49:WU01:FS00:0x17:Reading tar file integrator.xml
04:26:49:WU01:FS00:0x17:Reading tar file core.xml
04:26:49:WU01:FS00:0x17:Digital signatures verified
04:26:49:WU01:FS00:0x17:ERROR:exception: Bad platformId size.
04:26:49:WU01:FS00:0x17:Saving result file logfile_01.txt
04:26:49:WU01:FS00:0x17:Saving result file log.txt
04:26:49:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
04:26:49:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:26:49:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9201 run:4 clone:1 gen:30 core:0x17 unit:0x000000436652edc45399d6349bc04125
04:26:49:WU01:FS00:Uploading 1.80KiB to 171.67.108.52
04:26:49:WU01:FS00:Connecting to 171.67.108.52:8080
04:26:50:WU00:FS00:Connecting to 171.67.108.201:80
04:26:50:WU01:FS00:Upload complete
04:26:50:WU01:FS00:Server responded WORK_ACK (400)
04:26:50:WU01:FS00:Cleaning up
04:26:50:WU00:FS00:Assigned to work server 171.67.108.52
04:26:50:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 171.67.108.52
04:26:50:WU00:FS00:Connecting to 171.67.108.52:8080
04:26:51:WU00:FS00:Downloading 1.52MiB
04:26:53:Removing old file 'configs/config-20140824-023818.xml'
04:26:53:Saving configuration to /etc/fahclient/config.xml
04:26:53:<config>
04:26:53:  <!-- Folding Core -->
04:26:53:  <checkpoint v='30'/>
04:26:53:  <core-priority v='low'/>
04:26:53:
04:26:53:  <!-- Network -->
04:26:53:  <proxy v=':8080'/>
04:26:53:
04:26:53:  <!-- Slot Control -->
04:26:53:  <power v='full'/>
04:26:53:
04:26:53:  <!-- User Information -->
04:26:53:  <passkey v='********************************'/>
04:26:53:  <team v='66731'/>
04:26:53:  <user v='Adam_Hornbuckle'/>
04:26:53:
04:26:53:  <!-- Folding Slots -->
04:26:53:  <slot id='0' type='GPU'/>
04:26:53:</config>
04:26:57:WU00:FS00:Download 41.07%
04:27:03:WU00:FS00:Download 73.92%
04:27:08:WU00:FS00:Download complete
04:27:08:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:608 clone:1 gen:29 core:0x17 unit:0x0000003c6652edc45399edeebb93d5d7
04:27:08:WU00:FS00:Starting
04:27:08:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 2332 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
04:27:08:WU00:FS00:Started FahCore on PID 2709
04:27:08:WU00:FS00:Core PID:2713
04:27:08:WU00:FS00:FahCore 0x17 started
04:27:09:WU00:FS00:0x17:*********************** Log Started 2014-08-24T04:27:08Z ***********************
04:27:09:WU00:FS00:0x17:Project: 9201 (Run 608, Clone 1, Gen 29)
04:27:09:WU00:FS00:0x17:Unit: 0x0000003c6652edc45399edeebb93d5d7
04:27:09:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
04:27:09:WU00:FS00:0x17:Machine: 0
04:27:09:WU00:FS00:0x17:Reading tar file state.xml
04:27:09:WU00:FS00:0x17:Reading tar file system.xml
04:27:09:WU00:FS00:0x17:Reading tar file integrator.xml
04:27:09:WU00:FS00:0x17:Reading tar file core.xml
04:27:09:WU00:FS00:0x17:Digital signatures verified
04:27:09:WU00:FS00:0x17:ERROR:exception: Bad platformId size.
04:27:09:WU00:FS00:0x17:Saving result file logfile_01.txt
04:27:09:WU00:FS00:0x17:Saving result file log.txt
04:27:09:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
04:27:09:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:27:09:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9201 run:608 clone:1 gen:29 core:0x17 unit:0x0000003c6652edc45399edeebb93d5d7
04:27:09:WU00:FS00:Uploading 1.82KiB to 171.67.108.52
04:27:09:WU00:FS00:Connecting to 171.67.108.52:8080
04:27:09:WU01:FS00:Connecting to 171.67.108.201:80
04:27:09:WU00:FS00:Upload complete
04:27:09:WU00:FS00:Server responded WORK_ACK (400)
04:27:09:WU00:FS00:Cleaning up
04:27:10:WU01:FS00:Assigned to work server 171.67.108.52
04:27:10:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GM107 [GeForce GTX 750 Ti] from 171.67.108.52
04:27:10:WU01:FS00:Connecting to 171.67.108.52:8080
04:27:10:WU01:FS00:Downloading 1.53MiB
04:27:16:WU01:FS00:Download 24.58%
04:27:16:FS00:Paused
04:27:22:WU01:FS00:Download 81.92%
04:27:24:WU01:FS00:Download complete
04:27:24:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:205 clone:1 gen:27 core:0x17 unit:0x0000003f6652edc45399de104511e185
Mod edit: changed Quote tags to Code tags on log
P5-133XL
Machine #2:
Machine 3:
Re: Ubuntu - GPU just downloads, sends, downloads, sends
Post by P5-133XL »
Bad platformID size is an error associated with having video drivers that do not support OpenCL fully.
runpaint
Post by runpaint »
Thanks for the info, and thanks to the moderator for fixing my quotes.
And I appreciate it even more since you're in the top 500 folders and top 100 teams.
runpaint
Post by runpaint »
OK, since 340.32 didn't work, and 343.13 didn't work, I purged the Nvidia drivers.
Then I reinstalled the desktop after the purge, then I downloaded Nvidia 331.
That didn't work, so I downloaded Nvidia 337.25, then that didn't work, so I put it back to 340.32.
Here are the terminal commands I used:
sudo apt-get purge nvidia*
sudo apt-get install ubuntu-desktop
sudo add-apt-repository ppa:xorg-edgers/ppa -y
sudo apt-get update
sudo apt-get install nvidia-331
Then I rebooted.
Then I went to Drivers, Additional Drivers, and I was going to select Nvidia 331,
but it was selected to x-org Nouveau driver without a version number,
and version 331 wasn't in the list, but 340 and 343 were,
when I thought they'd be gone after the purge,
and the GPU still wouldn't fold.
So I downloaded 337.25 from Nvidia, because it said the latest long-branch
was 340.32, which already didn't work for me, so I got the latest short-branch version
even though I don't know what that means. But then 337 also didn't show up in my driver list,
so I put it back on 340 and rebooted. The screen came up low-resolution, so something had changed,
but I went into Additional Drivers and it was selected back on Nouveau driver.
So I installed 340 in a terminal with sudo apt-get install nvidia-340,
and just for good measure I gave it the old sudo apt-get --purge remove xserver-xorg-video-nouveau.
Then I rebooted, then:
FAHCoreWrapper start
sudo /etc/init.d/FAHClient start
And it's still saying bad platform ID size.
bollix47
Post by bollix47 »
Welcome to the folding@home support forum runpaint.
What version of Ubuntu are you using and was it a clean install or an upgrade.
The minimum driver version for a 750ti in Linux is 334.21 so installing 331 may have caused an initial problem and without purging them before trying a later version that problem may still be there.
Try this:
Go to Additional Drivers and select 334.21 or higher ... usually the words "proprietary" and "tested", not "nouveau" or "updates", will be displayed after the entry that should be selected although I'm not sure with xorg-edgers since I don't use it because all my GPUs are supported in Ubuntu 14.04 ... I don't have a 750ti currently.
Reboot.
Try again. :ewink:
runpaint
Post by runpaint »
OK, I did that again, and the same thing happened again.
Actually, purge nvidia* didn't do anything, so I tried sudo purge nvidia*, and that didn't do anything,
so I tried sudo apt-get purge nvidia*, and that one worked.
I'm running Ubuntu 14.04 LTS. I don't know if it was a clean install,
I bought it used and it was already running FAH when I got it,
and the CPU and GPU work units were working properly when I got it,
but the GPU hasn't worked since I put in the 750ti.
bollix47
Post by bollix47 »
Sorry for not giving you the entire command ... you'd already used it so I didn't think you needed it spelled out ... fixed in previous post ... you got there eventually.
(Was 14.04 a new install or an upgrade from a previous version?
If it was an upgrade and you didn't purge xorg-edgers before upgrading you may need to reinstall a clean version of Ubuntu 14.04.)
Noticed your edit so the above may not be applicable.
What versions are available in Additional Drivers?
Was xorg-edgers installed when you got it or did you install it after?
If you open a terminal and type nvidia-settings does a graphic window open and is the driver version shown what you expect?
runpaint
Post by runpaint »
When I got it, it had Nouveau available in the drivers list but 343.13 was installed.
At one point I used the lspci command to verify that the kernel driver was nvidia,
and Nvidia settings shows the 750ti and driver 343.13.
davidcoton
Post by davidcoton »
One thought -- does the Maxwell GPU need the latest (0.0.55?) Core_17? Is it available for Ubuntu?
If it is needed, and if as I think it's Windows only, then I don't think a 750Ti will fold under Ubuntu yet.
runpaint
Post by runpaint »
Well that would explain why it's not working.
I'll shelf that project and continue with Plan B, which involves trying to run 6 graphics cards in one computer.
Or I guess I could at least put the 560ti back in and run that.
runpaint
Post by runpaint »
I put the 560ti back in, and the control panel just freaked out,
switching back and forth between "ready" and "running" several times per second,
with all the fields and values just changing and flashing.
So, that's it.
The first time I put the 560 back in after I took it out,
I probably didn't have it plugged in right,
and that's probably the only reason it didn't work,
so I probably shouldn't have uninstalled or reinstalled anything,
and it would probably still be working if I hadn't done anything at all.
Oh well, at least I learned a little about Linux.
Right, 750 won't run in Linux yet.
When swapping cards, you need to reinstall the client for it to detect the change correctly.
And the Linux installation is much simpler following the Linux Install Guide on the fah web page, and using the gdebi package installer.
sqook
Post by sqook »
You'll also need to apt-get the package nvidia-opencl-icd-331. It's not installed by default with the nvidia-331 package.
runpaint
Post by runpaint »
Update -
I decided to remove the gpu slot for now, and I'm running the CPU on 8 cores at 12,000ppd.
Thanks to everyone for your help!
