Can't run FAH after restart
craigman
Post by craigman »
I restarted my computer for a system update. Now when I click on the FAH icon on my desktop, nothing happens. How do i get FAH up and running again? If uninstall and reinstall FAH, will it mess up the folding operation my computer was doing when I restarted?
I'm running FAH on an older HP Desktop running Windows Vista with Service pack 2.
Re: Can't run FAH after restart
Without additional information, it's difficult to give you an accurate answer. (See instructions linked in my Signature).
FAH may already be running. If so, starting a second copy doesn't do a good job of reporting that information.
The normal installation of FAH's V7 client hides the FAHClient, starting it running in in the background when you reboot. Have you tried starting either the WebControl program or the FAHControl program? Does either of them show an active Work Unit?
craigman
Post by craigman »
Here is what was sitting out lose in the AppData folder under log.txt:
*********************** Log Started 2014-08-22T05:14:44Z ***********************
05:14:44:************************* Folding@home Client *************************
05:14:44:      Website: http://folding.stanford.edu/
05:14:44:    Copyright: (c) 2009-2014 Stanford University
05:14:44:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:14:44:         Args:
05:14:44:       Config: C:/Users/Owner/AppData/Roaming/FAHClient/config.xml
05:14:44:******************************** Build ********************************
05:14:44:      Version: 7.4.4
05:14:44:         Date: Mar 4 2014
05:14:44:         Time: 20:26:54
05:14:44:      SVN Rev: 4130
05:14:44:       Branch: fah/trunk/client
05:14:44:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
05:14:44:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
05:14:44:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
05:14:44:     Platform: win32 XP
05:14:44:         Bits: 32
05:14:44:         Mode: Release
05:14:44:******************************* System ********************************
05:14:44:          CPU: AMD Phenom(tm) 9150e Quad-Core Processor
05:14:44:       CPU ID: AuthenticAMD Family 16 Model 2 Stepping 3
05:14:44:         CPUs: 4
05:14:44:       Memory: 5.00GiB
05:14:44:  Free Memory: 2.74GiB
05:14:44:      Threads: WINDOWS_THREADS
05:14:44:   OS Version: 6.0
05:14:44:  Has Battery: false
05:14:44:   On Battery: false
05:14:44:   UTC Offset: -4
05:14:44:          PID: 4600
05:14:44:          CWD: C:/Users/Owner/AppData/Roaming/FAHClient
05:14:44:           OS: Windows (TM) Vista Home Premium
05:14:44:      OS Arch: AMD64
05:14:44:         GPUs: 1
05:14:44:        GPU 0: UNSUPPORTED: Mobility [Radeon HD 3600 Series]
05:14:44:         CUDA: Not detected
05:14:44:Win32 Service: false
05:14:44:***********************************************************************
05:14:44:<config>
05:14:44:  <!-- User Information -->
05:14:44:  <passkey v='********************************'/>
05:14:44:  <user v='Craigman'/>
05:14:44:
05:14:44:  <!-- Folding Slots -->
05:14:44:  <slot id='0' type='CPU'>
05:14:44:    <paused v='true'/>
05:14:44:  </slot>
05:14:44:</config>
05:14:44:Trying to access database...
05:14:50:Successfully acquired database lock
05:14:51:Enabled folding slot 00: PAUSED cpu:3 (by user)
craigman
Post by craigman »
Here is the only file that was in the logs folder:
*********************** Log Started 2014-08-11T14:39:21Z ***********************
14:39:21:************************* Folding@home Client *************************
14:39:21:      Website: http://folding.stanford.edu/
14:39:21:    Copyright: (c) 2009-2014 Stanford University
14:39:21:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:39:21:         Args: --open-web-control
14:39:21:       Config: <none>
14:39:21:******************************** Build ********************************
14:39:21:      Version: 7.4.4
14:39:21:         Date: Mar 4 2014
14:39:21:         Time: 20:26:54
14:39:21:      SVN Rev: 4130
14:39:21:       Branch: fah/trunk/client
14:39:21:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:39:21:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:39:21:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:39:21:     Platform: win32 XP
14:39:21:         Bits: 32
14:39:21:         Mode: Release
14:39:21:******************************* System ********************************
14:39:21:          CPU: AMD Phenom(tm) 9150e Quad-Core Processor
14:39:21:       CPU ID: AuthenticAMD Family 16 Model 2 Stepping 3
14:39:21:         CPUs: 4
14:39:21:       Memory: 5.00GiB
14:39:21:  Free Memory: 2.07GiB
14:39:21:      Threads: WINDOWS_THREADS
14:39:21:   OS Version: 6.0
14:39:21:  Has Battery: false
14:39:21:   On Battery: false
14:39:21:   UTC Offset: -4
14:39:21:          PID: 7808
14:39:21:          CWD: C:/Users/Owner/AppData/Roaming/FAHClient
14:39:21:           OS: Windows (TM) Vista Home Premium
14:39:21:      OS Arch: AMD64
14:39:21:         GPUs: 1
14:39:21:        GPU 0: UNSUPPORTED: Mobility [Radeon HD 3600 Series]
14:39:21:         CUDA: Not detected
14:39:21:Win32 Service: false
14:39:21:***********************************************************************
14:39:21:<config>
14:39:21:  <!-- Folding Slots -->
14:39:21:</config>
14:39:21:Connecting to assign-GPU.stanford.edu:80
14:39:22:Updated GPUs.txt
14:39:22:Read GPUs.txt
14:39:22:Trying to access database...
14:39:22:Successfully acquired database lock
14:39:22:Enabled folding slot 00: PAUSED cpu:3 (not configured)
14:39:27:8:127.0.0.1:New Web connection
14:40:23:Saving configuration to config.xml
14:40:23:<config>
14:40:23:  <!-- Folding Slots -->
14:40:23:  <slot id='0' type='CPU'/>
14:40:23:</config>
14:40:23:Set client configured
14:40:23:WU00:FS00:Connecting to 171.67.108.200:8080
14:40:23:WU00:FS00:Assigned to work server 171.64.65.81
14:40:23:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 171.64.65.81
14:40:23:WU00:FS00:Connecting to 171.64.65.81:8080
14:40:24:WU00:FS00:Downloading 368.01KiB
14:40:25:WU00:FS00:Download complete
14:40:25:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10450 run:52 clone:0 gen:356 core:0xa4 unit:0x00000a780a3b1e7550a539e3eacf1c21
14:40:25:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
14:40:25:WU00:FS00:Connecting to web.stanford.edu:80
14:40:26:WU00:FS00:FahCore a4: Downloading 2.89MiB
14:40:32:WU00:FS00:FahCore a4: 60.60%
14:40:35:WU00:FS00:FahCore a4: Download complete
14:40:35:WU00:FS00:Valid core signature
14:40:35:WU00:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
14:40:35:WU00:FS00:Starting
14:40:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owner/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 7808 -checkpoint 15 -np 3
14:40:35:WU00:FS00:Started FahCore on PID 10248
14:40:35:WU00:FS00:Core PID:7816
14:40:35:WU00:FS00:FahCore 0xa4 started
14:40:36:WU00:FS00:0xa4:
14:40:36:WU00:FS00:0xa4:*------------------------------*
14:40:36:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
14:40:36:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:40:36:WU00:FS00:0xa4:Preparing to commence simulation
14:40:36:WU00:FS00:0xa4:- Looking at optimizations...
14:40:36:WU00:FS00:0xa4:- Created dyn
14:40:36:WU00:FS00:0xa4:- Files status OK
14:40:36:WU00:FS00:0xa4:- Expanded 376327 -> 690140 (decompressed 183.3 percent)
14:40:36:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=376327 data_size=690140, decompressed_data_size=690140 diff=0
14:40:36:WU00:FS00:0xa4:- Digital signature verified
14:40:36:WU00:FS00:0xa4:Project: 10450 (Run 52, Clone 0, Gen 356)
14:40:36:WU00:FS00:0xa4:Assembly optimizations on if available.
14:40:36:WU00:FS00:0xa4:Entering M.D.
14:40:42:WU00:FS00:0xa4:Mapping NT from 3 to 3
14:40:42:WU00:FS00:0xa4:Completed 0 out of 2000000 steps  (0%)
14:52:35:WU00:FS00:0xa4:Completed 20000 out of 2000000 steps  (1%)
15:04:33:WU00:FS00:0xa4:Completed 40000 out of 2000000 steps  (2%)
15:16:44:WU00:FS00:0xa4:Completed 60000 out of 2000000 steps  (3%)
15:28:37:WU00:FS00:0xa4:Completed 80000 out of 2000000 steps  (4%)
15:40:24:WU00:FS00:0xa4:Completed 100000 out of 2000000 steps  (5%)
15:52:18:WU00:FS00:0xa4:Completed 120000 out of 2000000 steps  (6%)
16:05:18:WU00:FS00:0xa4:Completed 140000 out of 2000000 steps  (7%)
16:28:13:WU00:FS00:0xa4:Completed 160000 out of 2000000 steps  (8%)
16:40:21:WU00:FS00:0xa4:Completed 180000 out of 2000000 steps  (9%)
16:52:10:WU00:FS00:0xa4:Completed 200000 out of 2000000 steps  (10%)
17:04:10:WU00:FS00:0xa4:Completed 220000 out of 2000000 steps  (11%)
17:15:51:WU00:FS00:0xa4:Completed 240000 out of 2000000 steps  (12%)
17:27:22:WU00:FS00:0xa4:Completed 260000 out of 2000000 steps  (13%)
17:38:56:WU00:FS00:0xa4:Completed 280000 out of 2000000 steps  (14%)
17:50:26:WU00:FS00:0xa4:Completed 300000 out of 2000000 steps  (15%)
18:03:00:WU00:FS00:0xa4:Completed 320000 out of 2000000 steps  (16%)
18:16:13:WU00:FS00:0xa4:Completed 340000 out of 2000000 steps  (17%)
18:20:04:76:127.0.0.1:New Web connection
18:29:20:WU00:FS00:0xa4:Completed 360000 out of 2000000 steps  (18%)
18:42:33:WU00:FS00:0xa4:Completed 380000 out of 2000000 steps  (19%)
18:54:26:WU00:FS00:0xa4:Completed 400000 out of 2000000 steps  (20%)
19:06:21:WU00:FS00:0xa4:Completed 420000 out of 2000000 steps  (21%)
19:18:19:WU00:FS00:0xa4:Completed 440000 out of 2000000 steps  (22%)
19:30:12:WU00:FS00:0xa4:Completed 460000 out of 2000000 steps  (23%)
19:42:08:WU00:FS00:0xa4:Completed 480000 out of 2000000 steps  (24%)
19:54:16:WU00:FS00:0xa4:Completed 500000 out of 2000000 steps  (25%)
20:05:47:WU00:FS00:0xa4:Completed 520000 out of 2000000 steps  (26%)
20:17:19:WU00:FS00:0xa4:Completed 540000 out of 2000000 steps  (27%)
20:28:59:WU00:FS00:0xa4:Completed 560000 out of 2000000 steps  (28%)
******************************* Date: 2014-08-11 *******************************
20:40:32:WU00:FS00:0xa4:Completed 580000 out of 2000000 steps  (29%)
20:52:11:WU00:FS00:0xa4:Completed 600000 out of 2000000 steps  (30%)
21:03:35:107:127.0.0.1:New Web connection
21:04:35:WU00:FS00:0xa4:Completed 620000 out of 2000000 steps  (31%)
21:16:05:WU00:FS00:0xa4:Completed 640000 out of 2000000 steps  (32%)
21:27:19:WU00:FS00:0xa4:Completed 660000 out of 2000000 steps  (33%)
21:39:21:WU00:FS00:0xa4:Completed 680000 out of 2000000 steps  (34%)
21:50:52:WU00:FS00:0xa4:Completed 700000 out of 2000000 steps  (35%)
22:02:24:WU00:FS00:0xa4:Completed 720000 out of 2000000 steps  (36%)
22:13:48:WU00:FS00:0xa4:Completed 740000 out of 2000000 steps  (37%)
22:25:15:WU00:FS00:0xa4:Completed 760000 out of 2000000 steps  (38%)
22:36:50:WU00:FS00:0xa4:Completed 780000 out of 2000000 steps  (39%)
22:48:19:WU00:FS00:0xa4:Completed 800000 out of 2000000 steps  (40%)
22:59:44:WU00:FS00:0xa4:Completed 820000 out of 2000000 steps  (41%)
23:11:09:WU00:FS00:0xa4:Completed 840000 out of 2000000 steps  (42%)
23:22:32:WU00:FS00:0xa4:Completed 860000 out of 2000000 steps  (43%)
23:35:25:WU00:FS00:0xa4:Completed 880000 out of 2000000 steps  (44%)
23:53:12:WU00:FS00:0xa4:Completed 900000 out of 2000000 steps  (45%)
23:55:42:FS00:Paused
23:55:42:FS00:Shutting core down
23:55:51:WU00:FS00:0xa4:Client no longer detected. Shutting down core
23:55:51:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
23:55:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:56:30:Saving configuration to config.xml
23:56:30:<config>
23:56:30:  <!-- Folding Slots -->
23:56:30:  <slot id='0' type='CPU'>
23:56:30:    <paused v='true'/>
23:56:30:  </slot>
23:56:30:</config>
******************************* Date: 2014-08-12 *******************************
04:20:48:FS00:Unpaused
04:20:48:WU00:FS00:Starting
04:20:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owner/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 7808 -checkpoint 15 -np 3
04:20:48:WU00:FS00:Started FahCore on PID 3836
04:20:49:WU00:FS00:Core PID:4968
04:20:49:WU00:FS00:FahCore 0xa4 started
04:20:49:WU00:FS00:0xa4:
04:20:49:WU00:FS00:0xa4:*------------------------------*
04:20:49:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
04:20:49:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
04:20:49:WU00:FS00:0xa4:Preparing to commence simulation
04:20:49:WU00:FS00:0xa4:- Looking at optimizations...
04:20:49:WU00:FS00:0xa4:- Files status OK
04:20:49:WU00:FS00:0xa4:- Expanded 376327 -> 690140 (decompressed 183.3 percent)
04:20:49:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=376327 data_size=690140, decompressed_data_size=690140 diff=0
04:20:49:WU00:FS00:0xa4:- Digital signature verified
04:20:49:WU00:FS00:0xa4:Project: 10450 (Run 52, Clone 0, Gen 356)
04:20:49:WU00:FS00:0xa4:Assembly optimizations on if available.
04:20:49:WU00:FS00:0xa4:Entering M.D.
04:20:50:Saving configuration to config.xml
04:20:50:<config>
04:20:50:  <!-- Folding Slots -->
04:20:50:  <slot id='0' type='CPU'/>
04:20:50:</config>
04:20:55:WU00:FS00:0xa4:Using Gromacs checkpoints
04:20:55:WU00:FS00:0xa4:Mapping NT from 3 to 3
04:20:56:WU00:FS00:0xa4:Resuming from checkpoint
04:20:56:WU00:FS00:0xa4:Verified 00/wudata_01.log
04:20:56:WU00:FS00:0xa4:Verified 00/wudata_01.trr
04:20:56:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
04:20:56:WU00:FS00:0xa4:Verified 00/wudata_01.edr
04:20:56:WU00:FS00:0xa4:Completed 902530 out of 2000000 steps  (45%)
04:21:07:148:127.0.0.1:New Web connection
04:30:54:WU00:FS00:0xa4:Completed 920000 out of 2000000 steps  (46%)
04:42:11:WU00:FS00:0xa4:Completed 940000 out of 2000000 steps  (47%)
04:53:37:WU00:FS00:0xa4:Completed 960000 out of 2000000 steps  (48%)
05:06:15:WU00:FS00:0xa4:Completed 980000 out of 2000000 steps  (49%)
05:18:48:WU00:FS00:0xa4:Completed 1000000 out of 2000000 steps  (50%)
05:31:13:WU00:FS00:0xa4:Completed 1020000 out of 2000000 steps  (51%)
05:43:27:WU00:FS00:0xa4:Completed 1040000 out of 2000000 steps  (52%)
05:55:41:WU00:FS00:0xa4:Completed 1060000 out of 2000000 steps  (53%)
06:07:22:WU00:FS00:0xa4:Completed 1080000 out of 2000000 steps  (54%)
06:19:15:WU00:FS00:0xa4:Completed 1100000 out of 2000000 steps  (55%)
06:31:01:WU00:FS00:0xa4:Completed 1120000 out of 2000000 steps  (56%)
06:42:38:WU00:FS00:0xa4:Completed 1140000 out of 2000000 steps  (57%)
06:54:42:WU00:FS00:0xa4:Completed 1160000 out of 2000000 steps  (58%)
07:06:21:WU00:FS00:0xa4:Completed 1180000 out of 2000000 steps  (59%)
07:18:01:WU00:FS00:0xa4:Completed 1200000 out of 2000000 steps  (60%)
07:29:20:WU00:FS00:0xa4:Completed 1220000 out of 2000000 steps  (61%)
07:40:33:WU00:FS00:0xa4:Completed 1240000 out of 2000000 steps  (62%)
07:51:45:WU00:FS00:0xa4:Completed 1260000 out of 2000000 steps  (63%)
08:02:57:WU00:FS00:0xa4:Completed 1280000 out of 2000000 steps  (64%)
08:14:10:WU00:FS00:0xa4:Completed 1300000 out of 2000000 steps  (65%)
08:25:23:WU00:FS00:0xa4:Completed 1320000 out of 2000000 steps  (66%)
08:36:34:WU00:FS00:0xa4:Completed 1340000 out of 2000000 steps  (67%)
08:47:45:WU00:FS00:0xa4:Completed 1360000 out of 2000000 steps  (68%)
08:58:55:WU00:FS00:0xa4:Completed 1380000 out of 2000000 steps  (69%)
09:10:06:WU00:FS00:0xa4:Completed 1400000 out of 2000000 steps  (70%)
09:21:16:WU00:FS00:0xa4:Completed 1420000 out of 2000000 steps  (71%)
09:32:27:WU00:FS00:0xa4:Completed 1440000 out of 2000000 steps  (72%)
09:43:38:WU00:FS00:0xa4:Completed 1460000 out of 2000000 steps  (73%)
09:54:52:WU00:FS00:0xa4:Completed 1480000 out of 2000000 steps  (74%)
10:06:05:WU00:FS00:0xa4:Completed 1500000 out of 2000000 steps  (75%)
10:17:19:WU00:FS00:0xa4:Completed 1520000 out of 2000000 steps  (76%)
10:28:33:WU00:FS00:0xa4:Completed 1540000 out of 2000000 steps  (77%)
10:39:45:WU00:FS00:0xa4:Completed 1560000 out of 2000000 steps  (78%)
10:50:59:WU00:FS00:0xa4:Completed 1580000 out of 2000000 steps  (79%)
11:02:11:WU00:FS00:0xa4:Completed 1600000 out of 2000000 steps  (80%)
11:13:24:WU00:FS00:0xa4:Completed 1620000 out of 2000000 steps  (81%)
11:24:39:WU00:FS00:0xa4:Completed 1640000 out of 2000000 steps  (82%)
11:35:53:WU00:FS00:0xa4:Completed 1660000 out of 2000000 steps  (83%)
11:47:05:WU00:FS00:0xa4:Completed 1680000 out of 2000000 steps  (84%)
11:58:15:WU00:FS00:0xa4:Completed 1700000 out of 2000000 steps  (85%)
12:09:27:WU00:FS00:0xa4:Completed 1720000 out of 2000000 steps  (86%)
12:20:39:WU00:FS00:0xa4:Completed 1740000 out of 2000000 steps  (87%)
12:31:53:WU00:FS00:0xa4:Completed 1760000 out of 2000000 steps  (88%)
12:43:06:WU00:FS00:0xa4:Completed 1780000 out of 2000000 steps  (89%)
12:54:20:WU00:FS00:0xa4:Completed 1800000 out of 2000000 steps  (90%)
13:05:34:WU00:FS00:0xa4:Completed 1820000 out of 2000000 steps  (91%)
13:16:54:WU00:FS00:0xa4:Completed 1840000 out of 2000000 steps  (92%)
13:28:07:WU00:FS00:0xa4:Completed 1860000 out of 2000000 steps  (93%)
13:39:19:WU00:FS00:0xa4:Completed 1880000 out of 2000000 steps  (94%)
13:50:30:WU00:FS00:0xa4:Completed 1900000 out of 2000000 steps  (95%)
14:01:40:WU00:FS00:0xa4:Completed 1920000 out of 2000000 steps  (96%)
14:12:50:WU00:FS00:0xa4:Completed 1940000 out of 2000000 steps  (97%)
14:24:19:WU00:FS00:0xa4:Completed 1960000 out of 2000000 steps  (98%)
14:36:01:WU00:FS00:0xa4:Completed 1980000 out of 2000000 steps  (99%)
14:36:02:WU01:FS00:Connecting to 171.67.108.200:8080
14:36:02:WU01:FS00:Assigned to work server 128.143.231.202
14:36:02:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 128.143.231.202
14:36:02:WU01:FS00:Connecting to 128.143.231.202:8080
14:36:04:WU01:FS00:Downloading 3.64MiB
14:36:06:WU01:FS00:Download complete
14:36:07:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:6098 run:6 clone:95 gen:471 core:0xa3 unit:0x00000a7a0a3b1e594e91df02998aa941
14:36:07:WU01:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah
14:36:07:WU01:FS00:Connecting to web.stanford.edu:80
14:36:10:WU01:FS00:FahCore a3: Downloading 2.89MiB
14:36:16:WU01:FS00:FahCore a3: 58.43%
14:36:19:WU01:FS00:FahCore a3: Download complete
14:36:19:WU01:FS00:Valid core signature
14:36:19:WU01:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe
14:47:54:WU00:FS00:0xa4:Completed 2000000 out of 2000000 steps  (100%)
14:47:54:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:48:04:WU00:FS00:0xa4:
14:48:04:WU00:FS00:0xa4:Finished Work Unit:
14:48:04:WU00:FS00:0xa4:- Reading up to 3558984 from "00/wudata_01.trr": Read 3558984
14:48:04:WU00:FS00:0xa4:trr file hash check passed.
14:48:04:WU00:FS00:0xa4:- Reading up to 530752 from "00/wudata_01.xtc": Read 530752
14:48:04:WU00:FS00:0xa4:xtc file hash check passed.
14:48:04:WU00:FS00:0xa4:edr file hash check passed.
14:48:04:WU00:FS00:0xa4:logfile size: 86537
14:48:04:WU00:FS00:0xa4:Leaving Run
14:48:07:WU00:FS00:0xa4:- Writing 4184197 bytes of core data to disk...
14:48:10:WU00:FS00:0xa4:Done: 4183685 -> 3925590 (compressed to 93.8 percent)
14:48:10:WU00:FS00:0xa4:  ... Done.
14:48:10:WU00:FS00:0xa4:- Shutting down core
14:48:10:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:48:11:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:48:11:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10450 run:52 clone:0 gen:356 core:0xa4 unit:0x00000a780a3b1e7550a539e3eacf1c21
14:48:11:WU00:FS00:Uploading 3.74MiB to 171.64.65.81
14:48:11:WU00:FS00:Connecting to 171.64.65.81:8080
14:48:11:WU01:FS00:Starting
14:48:11:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owner/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 7808 -checkpoint 15 -np 3
14:48:11:WU01:FS00:Started FahCore on PID 6416
14:48:11:WU01:FS00:Core PID:8568
14:48:11:WU01:FS00:FahCore 0xa3 started
14:48:12:WU01:FS00:0xa3:
14:48:12:WU01:FS00:0xa3:*------------------------------*
14:48:12:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
14:48:12:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
14:48:12:WU01:FS00:0xa3:Preparing to commence simulation
14:48:12:WU01:FS00:0xa3:- Looking at optimizations...
14:48:12:WU01:FS00:0xa3:- Created dyn
14:48:12:WU01:FS00:0xa3:- Files status OK
14:48:12:WU01:FS00:0xa3:- Expanded 3811069 -> 4136808 (decompressed 108.5 percent)
14:48:12:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3811069 data_size=4136808, decompressed_data_size=4136808 diff=0
14:48:12:WU01:FS00:0xa3:- Digital signature verified
14:48:12:WU01:FS00:0xa3:Project: 6098 (Run 6, Clone 95, Gen 471)
14:48:12:WU01:FS00:0xa3:Assembly optimizations on if available.
14:48:12:WU01:FS00:0xa3:Entering M.D.
14:48:17:WU00:FS00:Upload 83.46%
14:48:18:WU01:FS00:0xa3:Mapping NT from 3 to 3
14:48:19:WU00:FS00:Upload complete
14:48:19:WU00:FS00:Server responded WORK_ACK (400)
14:48:19:WU00:FS00:Final credit estimate, 1120.00 points
14:48:19:WU00:FS00:Cleaning up
14:48:20:WU01:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
15:38:59:WU01:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
16:29:43:WU01:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
17:20:43:WU01:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
18:08:57:WU01:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
18:54:26:WU01:FS00:0xa3:Completed 25000 out of 500000 steps  (5%)
19:41:50:WU01:FS00:0xa3:Completed 30000 out of 500000 steps  (6%)
19:55:27:175:127.0.0.1:New Web connection
20:00:14:Saving configuration to config.xml
20:00:14:<config>
20:00:14:  <!-- User Information -->
20:00:14:  <passkey v='********************************'/>
20:00:14:  <user v='Craigman'/>
20:00:14:
20:00:14:  <!-- Folding Slots -->
20:00:14:  <slot id='0' type='CPU'/>
20:00:14:</config>
20:33:23:WU01:FS00:0xa3:Completed 35000 out of 500000 steps  (7%)
21:20:16:WU01:FS00:0xa3:Completed 40000 out of 500000 steps  (8%)
22:08:18:WU01:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
22:54:32:WU01:FS00:0xa3:Completed 50000 out of 500000 steps  (10%)
23:46:39:WU01:FS00:0xa3:Completed 55000 out of 500000 steps  (11%)
00:56:32:WU01:FS00:0xa3:Completed 60000 out of 500000 steps  (12%)
02:02:06:WU01:FS00:0xa3:Completed 65000 out of 500000 steps  (13%)
03:04:37:WU01:FS00:0xa3:Completed 70000 out of 500000 steps  (14%)
04:08:52:WU01:FS00:0xa3:Completed 75000 out of 500000 steps  (15%)
******************************* Date: 2014-08-13 *******************************
04:58:03:WU01:FS00:0xa3:Completed 80000 out of 500000 steps  (16%)
05:46:38:WU01:FS00:0xa3:Completed 85000 out of 500000 steps  (17%)
06:35:25:WU01:FS00:0xa3:Completed 90000 out of 500000 steps  (18%)
07:21:32:WU01:FS00:0xa3:Completed 95000 out of 500000 steps  (19%)
08:06:38:WU01:FS00:0xa3:Completed 100000 out of 500000 steps  (20%)
08:51:41:WU01:FS00:0xa3:Completed 105000 out of 500000 steps  (21%)
09:40:42:WU01:FS00:0xa3:Completed 110000 out of 500000 steps  (22%)
10:27:39:WU01:FS00:0xa3:Completed 115000 out of 500000 steps  (23%)
11:15:16:WU01:FS00:0xa3:Completed 120000 out of 500000 steps  (24%)
12:07:02:WU01:FS00:0xa3:Completed 125000 out of 500000 steps  (25%)
13:00:00:WU01:FS00:0xa3:Completed 130000 out of 500000 steps  (26%)
13:45:08:WU01:FS00:0xa3:Completed 135000 out of 500000 steps  (27%)
14:30:21:WU01:FS00:0xa3:Completed 140000 out of 500000 steps  (28%)
15:19:27:WU01:FS00:0xa3:Completed 145000 out of 500000 steps  (29%)
16:05:43:WU01:FS00:0xa3:Completed 150000 out of 500000 steps  (30%)
16:52:13:WU01:FS00:0xa3:Completed 155000 out of 500000 steps  (31%)
17:38:55:WU01:FS00:0xa3:Completed 160000 out of 500000 steps  (32%)
18:27:13:WU01:FS00:0xa3:Completed 165000 out of 500000 steps  (33%)
18:58:49:204:127.0.0.1:New Web connection
19:12:56:WU01:FS00:0xa3:Completed 170000 out of 500000 steps  (34%)
19:59:36:WU01:FS00:0xa3:Completed 175000 out of 500000 steps  (35%)
20:46:41:WU01:FS00:0xa3:Completed 180000 out of 500000 steps  (36%)
21:32:08:WU01:FS00:0xa3:Completed 185000 out of 500000 steps  (37%)
22:17:23:WU01:FS00:0xa3:Completed 190000 out of 500000 steps  (38%)
23:02:47:WU01:FS00:0xa3:Completed 195000 out of 500000 steps  (39%)
23:47:58:WU01:FS00:0xa3:Completed 200000 out of 500000 steps  (40%)
00:33:13:WU01:FS00:0xa3:Completed 205000 out of 500000 steps  (41%)
01:18:21:WU01:FS00:0xa3:Completed 210000 out of 500000 steps  (42%)
01:54:55:FS00:Paused
01:54:59:FS00:Shutting core down
01:55:00:WU01:FS00:0xa3:Client no longer detected. Shutting down core
01:55:00:WU01:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
01:55:01:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:55:40:Saving configuration to config.xml
01:55:40:<config>
01:55:40:  <!-- User Information -->
01:55:40:  <passkey v='********************************'/>
01:55:40:  <user v='Craigman'/>
01:55:40:
01:55:40:  <!-- Folding Slots -->
01:55:40:  <slot id='0' type='CPU'>
01:55:40:    <paused v='true'/>
01:55:40:  </slot>
01:55:40:</config>
******************************* Date: 2014-08-14 *******************************
06:38:11:FS00:Unpaused
06:38:11:WU01:FS00:Starting
06:38:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owner/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 7808 -checkpoint 15 -np 3
06:38:15:WU01:FS00:Started FahCore on PID 6456
06:38:17:WU01:FS00:Core PID:9768
06:38:17:WU01:FS00:FahCore 0xa3 started
06:38:18:Saving configuration to config.xml
06:38:18:<config>
06:38:18:  <!-- User Information -->
06:38:18:  <passkey v='********************************'/>
06:38:18:  <user v='Craigman'/>
06:38:18:
06:38:18:  <!-- Folding Slots -->
06:38:18:  <slot id='0' type='CPU'/>
06:38:18:</config>
06:38:18:WU01:FS00:0xa3:
06:38:18:WU01:FS00:0xa3:*------------------------------*
06:38:18:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
06:38:18:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
06:38:18:WU01:FS00:0xa3:Preparing to commence simulation
06:38:18:WU01:FS00:0xa3:- Looking at optimizations...
06:38:18:WU01:FS00:0xa3:- Files status OK
06:38:19:WU01:FS00:0xa3:- Expanded 3811069 -> 4136808 (decompressed 108.5 percent)
06:38:19:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3811069 data_size=4136808, decompressed_data_size=4136808 diff=0
06:38:19:WU01:FS00:0xa3:- Digital signature verified
06:38:19:WU01:FS00:0xa3:Project: 6098 (Run 6, Clone 95, Gen 471)
06:38:19:WU01:FS00:0xa3:Assembly optimizations on if available.
06:38:19:WU01:FS00:0xa3:Entering M.D.
06:38:25:WU01:FS00:0xa3:Using Gromacs checkpoints
06:38:26:WU01:FS00:0xa3:Mapping NT from 3 to 3
06:38:28:WU01:FS00:0xa3:Resuming from checkpoint
06:38:28:WU01:FS00:0xa3:Verified 01/wudata_01.log
06:38:29:WU01:FS00:0xa3:Verified 01/wudata_01.trr
06:38:29:WU01:FS00:0xa3:Verified 01/wudata_01.edr
06:38:30:WU01:FS00:0xa3:Completed 213040 out of 500000 steps  (42%)
06:38:44:237:127.0.0.1:New Web connection
06:57:32:WU01:FS00:0xa3:Completed 215000 out of 500000 steps  (43%)
07:46:03:WU01:FS00:0xa3:Completed 220000 out of 500000 steps  (44%)
08:32:39:WU01:FS00:0xa3:Completed 225000 out of 500000 steps  (45%)
09:17:38:WU01:FS00:0xa3:Completed 230000 out of 500000 steps  (46%)
10:02:46:WU01:FS00:0xa3:Completed 235000 out of 500000 steps  (47%)
10:47:51:WU01:FS00:0xa3:Completed 240000 out of 500000 steps  (48%)
11:32:58:WU01:FS00:0xa3:Completed 245000 out of 500000 steps  (49%)
12:18:06:WU01:FS00:0xa3:Completed 250000 out of 500000 steps  (50%)
13:03:11:WU01:FS00:0xa3:Completed 255000 out of 500000 steps  (51%)
13:48:25:WU01:FS00:0xa3:Completed 260000 out of 500000 steps  (52%)
14:33:31:WU01:FS00:0xa3:Completed 265000 out of 500000 steps  (53%)
15:18:39:WU01:FS00:0xa3:Completed 270000 out of 500000 steps  (54%)
16:03:52:WU01:FS00:0xa3:Completed 275000 out of 500000 steps  (55%)
16:50:44:WU01:FS00:0xa3:Completed 280000 out of 500000 steps  (56%)
17:39:46:WU01:FS00:0xa3:Completed 285000 out of 500000 steps  (57%)
18:30:18:WU01:FS00:0xa3:Completed 290000 out of 500000 steps  (58%)
19:04:55:FS00:Paused
19:04:55:FS00:Shutting core down
19:05:01:WU01:FS00:0xa3:Client no longer detected. Shutting down core
19:05:01:WU01:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
19:05:01:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:05:33:Saving configuration to config.xml
19:05:33:<config>
19:05:33:  <!-- User Information -->
19:05:33:  <passkey v='********************************'/>
19:05:33:  <user v='Craigman'/>
19:05:33:
19:05:33:  <!-- Folding Slots -->
19:05:33:  <slot id='0' type='CPU'>
19:05:33:    <paused v='true'/>
19:05:33:  </slot>
19:05:33:</config>
******************************* Date: 2014-08-15 *******************************
19:38:58:FS00:Unpaused
19:38:58:WU01:FS00:Starting
19:38:58:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owner/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 7808 -checkpoint 15 -np 3
19:38:58:WU01:FS00:Started FahCore on PID 10728
19:38:59:WU01:FS00:Core PID:10868
19:38:59:WU01:FS00:FahCore 0xa3 started
19:39:00:WU01:FS00:0xa3:
19:39:00:WU01:FS00:0xa3:*------------------------------*
19:39:00:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
19:39:00:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
19:39:00:WU01:FS00:0xa3:Preparing to commence simulation
19:39:00:WU01:FS00:0xa3:- Looking at optimizations...
19:39:00:WU01:FS00:0xa3:- Files status OK
19:39:00:WU01:FS00:0xa3:- Expanded 3811069 -> 4136808 (decompressed 108.5 percent)
19:39:01:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3811069 data_size=4136808, decompressed_data_size=4136808 diff=0
19:39:01:WU01:FS00:0xa3:- Digital signature verified
19:39:01:WU01:FS00:0xa3:Project: 6098 (Run 6, Clone 95, Gen 471)
19:39:01:WU01:FS00:0xa3:Assembly optimizations on if available.
19:39:01:WU01:FS00:0xa3:Entering M.D.
19:39:07:WU01:FS00:0xa3:Using Gromacs checkpoints
19:39:07:WU01:FS00:0xa3:Mapping NT from 3 to 3
19:39:08:WU01:FS00:0xa3:Resuming from checkpoint
19:39:08:WU01:FS00:0xa3:Verified 01/wudata_01.log
19:39:08:WU01:FS00:0xa3:Verified 01/wudata_01.trr
19:39:08:WU01:FS00:0xa3:Verified 01/wudata_01.edr
19:39:09:WU01:FS00:0xa3:Completed 292530 out of 500000 steps  (58%)
19:39:43:Saving configuration to config.xml
19:39:43:<config>
19:39:43:  <!-- User Information -->
19:39:43:  <passkey v='********************************'/>
19:39:43:  <user v='Craigman'/>
19:39:43:
19:39:43:  <!-- Folding Slots -->
19:39:43:  <slot id='0' type='CPU'/>
19:39:43:</config>
20:01:58:WU01:FS00:0xa3:Completed 295000 out of 500000 steps  (59%)
20:47:09:WU01:FS00:0xa3:Completed 300000 out of 500000 steps  (60%)
21:32:32:WU01:FS00:0xa3:Completed 305000 out of 500000 steps  (61%)
22:17:38:WU01:FS00:0xa3:Completed 310000 out of 500000 steps  (62%)
23:02:45:WU01:FS00:0xa3:Completed 315000 out of 500000 steps  (63%)
23:55:43:WU01:FS00:0xa3:Completed 320000 out of 500000 steps  (64%)
01:04:42:WU01:FS00:0xa3:Completed 325000 out of 500000 steps  (65%)
******************************* Date: 2014-08-16 *******************************
02:09:54:WU01:FS00:0xa3:Completed 330000 out of 500000 steps  (66%)
03:18:37:WU01:FS00:0xa3:Completed 335000 out of 500000 steps  (67%)
03:45:43:FS00:Paused
03:45:43:FS00:Shutting core down
03:45:51:WU01:FS00:0xa3:Client no longer detected. Shutting down core
03:45:51:WU01:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
03:45:51:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:46:42:Saving configuration to config.xml
03:46:42:<config>
03:46:42:  <!-- User Information -->
03:46:42:  <passkey v='********************************'/>
03:46:42:  <user v='Craigman'/>
03:46:42:
03:46:42:  <!-- Folding Slots -->
03:46:42:  <slot id='0' type='CPU'>
03:46:42:    <paused v='true'/>
03:46:42:  </slot>
03:46:42:</config>
******************************* Date: 2014-08-20 *******************************
21:54:55:FS00:Unpaused
21:54:55:WU01:FS00:Starting
21:54:55:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owner/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 7808 -checkpoint 15 -np 3
21:54:56:WU01:FS00:Started FahCore on PID 5056
21:54:56:WU01:FS00:Core PID:5300
21:54:56:WU01:FS00:FahCore 0xa3 started
21:54:57:WU01:FS00:0xa3:
21:54:57:WU01:FS00:0xa3:*------------------------------*
21:54:57:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
21:54:57:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
21:54:57:WU01:FS00:0xa3:Preparing to commence simulation
21:54:57:WU01:FS00:0xa3:- Looking at optimizations...
21:54:57:WU01:FS00:0xa3:- Files status OK
21:54:58:Saving configuration to config.xml
21:54:58:<config>
21:54:58:  <!-- User Information -->
21:54:58:  <passkey v='********************************'/>
21:54:58:  <user v='Craigman'/>
21:54:58:
21:54:58:  <!-- Folding Slots -->
21:54:58:  <slot id='0' type='CPU'/>
21:54:58:</config>
21:54:58:WU01:FS00:0xa3:- Expanded 3811069 -> 4136808 (decompressed 108.5 percent)
21:54:58:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3811069 data_size=4136808, decompressed_data_size=4136808 diff=0
21:54:58:WU01:FS00:0xa3:- Digital signature verified
21:54:58:WU01:FS00:0xa3:Project: 6098 (Run 6, Clone 95, Gen 471)
21:54:58:WU01:FS00:0xa3:Assembly optimizations on if available.
21:54:58:WU01:FS00:0xa3:Entering M.D.
21:55:04:WU01:FS00:0xa3:Using Gromacs checkpoints
21:55:04:WU01:FS00:0xa3:Mapping NT from 3 to 3
21:55:05:WU01:FS00:0xa3:Resuming from checkpoint
21:55:05:WU01:FS00:0xa3:Verified 01/wudata_01.log
21:55:06:WU01:FS00:0xa3:Verified 01/wudata_01.trr
21:55:06:WU01:FS00:0xa3:Verified 01/wudata_01.edr
21:55:06:WU01:FS00:0xa3:Completed 336565 out of 500000 steps  (67%)
22:27:43:WU01:FS00:0xa3:Completed 340000 out of 500000 steps  (68%)
23:15:31:WU01:FS00:0xa3:Completed 345000 out of 500000 steps  (69%)
00:16:06:WU01:FS00:0xa3:Completed 350000 out of 500000 steps  (70%)
01:24:58:FS00:Paused
01:24:58:FS00:Shutting core down
01:25:07:WU01:FS00:0xa3:Client no longer detected. Shutting down core
01:25:07:WU01:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
01:25:08:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:25:25:Saving configuration to config.xml
01:25:25:<config>
01:25:25:  <!-- User Information -->
01:25:25:  <passkey v='********************************'/>
01:25:25:  <user v='Craigman'/>
01:25:25:
01:25:25:  <!-- Folding Slots -->
01:25:25:  <slot id='0' type='CPU'>
01:25:25:    <paused v='true'/>
01:25:25:  </slot>
01:25:25:</config>
******************************* Date: 2014-08-21 *******************************
05:24:36:FS00:Unpaused
05:24:36:WU01:FS00:Starting
05:24:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Owner/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 704 -lifeline 7808 -checkpoint 15 -np 3
05:24:36:WU01:FS00:Started FahCore on PID 12128
05:24:36:WU01:FS00:Core PID:5232
05:24:36:WU01:FS00:FahCore 0xa3 started
05:24:37:WU01:FS00:0xa3:
05:24:37:WU01:FS00:0xa3:*------------------------------*
05:24:37:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
05:24:37:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
05:24:37:WU01:FS00:0xa3:Preparing to commence simulation
05:24:37:WU01:FS00:0xa3:- Looking at optimizations...
05:24:37:WU01:FS00:0xa3:- Files status OK
05:24:37:WU01:FS00:0xa3:- Expanded 3811069 -> 4136808 (decompressed 108.5 percent)
05:24:37:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3811069 data_size=4136808, decompressed_data_size=4136808 diff=0
05:24:37:WU01:FS00:0xa3:- Digital signature verified
05:24:37:WU01:FS00:0xa3:Project: 6098 (Run 6, Clone 95, Gen 471)
05:24:37:WU01:FS00:0xa3:Assembly optimizations on if available.
05:24:37:WU01:FS00:0xa3:Entering M.D.
05:24:43:WU01:FS00:0xa3:Using Gromacs checkpoints
05:24:44:WU01:FS00:0xa3:Mapping NT from 3 to 3
05:24:45:WU01:FS00:0xa3:Resuming from checkpoint
05:24:45:WU01:FS00:0xa3:Verified 01/wudata_01.log
05:24:45:WU01:FS00:0xa3:Verified 01/wudata_01.trr
05:24:45:WU01:FS00:0xa3:Verified 01/wudata_01.edr
05:24:47:WU01:FS00:0xa3:Completed 353770 out of 500000 steps  (70%)
05:25:21:Saving configuration to config.xml
05:25:21:<config>
05:25:21:  <!-- User Information -->
05:25:21:  <passkey v='********************************'/>
05:25:21:  <user v='Craigman'/>
05:25:21:
05:25:21:  <!-- Folding Slots -->
05:25:21:  <slot id='0' type='CPU'/>
05:25:21:</config>
05:37:41:WU01:FS00:0xa3:Completed 355000 out of 500000 steps  (71%)
06:28:16:WU01:FS00:0xa3:Completed 360000 out of 500000 steps  (72%)
07:00:14:263:127.0.0.1:New Web connection
07:14:56:WU01:FS00:0xa3:Completed 365000 out of 500000 steps  (73%)
08:00:09:WU01:FS00:0xa3:Completed 370000 out of 500000 steps  (74%)
08:45:22:WU01:FS00:0xa3:Completed 375000 out of 500000 steps  (75%)
09:30:39:WU01:FS00:0xa3:Completed 380000 out of 500000 steps  (76%)
10:16:31:WU01:FS00:0xa3:Completed 385000 out of 500000 steps  (77%)
11:01:55:WU01:FS00:0xa3:Completed 390000 out of 500000 steps  (78%)
11:47:17:WU01:FS00:0xa3:Completed 395000 out of 500000 steps  (79%)
12:32:37:WU01:FS00:0xa3:Completed 400000 out of 500000 steps  (80%)
13:17:56:WU01:FS00:0xa3:Completed 405000 out of 500000 steps  (81%)
14:03:12:WU01:FS00:0xa3:Completed 410000 out of 500000 steps  (82%)
14:48:28:WU01:FS00:0xa3:Completed 415000 out of 500000 steps  (83%)
15:36:32:WU01:FS00:0xa3:Completed 420000 out of 500000 steps  (84%)
15:42:38:296:127.0.0.1:New Web connection
16:25:12:WU01:FS00:0xa3:Completed 425000 out of 500000 steps  (85%)
17:18:17:WU01:FS00:0xa3:Completed 430000 out of 500000 steps  (86%)
18:05:37:WU01:FS00:0xa3:Completed 435000 out of 500000 steps  (87%)
18:55:24:WU01:FS00:0xa3:Completed 440000 out of 500000 steps  (88%)
19:43:10:WU01:FS00:0xa3:Completed 445000 out of 500000 steps  (89%)
20:28:33:WU01:FS00:0xa3:Completed 450000 out of 500000 steps  (90%)
21:17:05:WU01:FS00:0xa3:Completed 455000 out of 500000 steps  (91%)
22:04:48:WU01:FS00:0xa3:Completed 460000 out of 500000 steps  (92%)
22:53:11:WU01:FS00:0xa3:Completed 465000 out of 500000 steps  (93%)
23:41:14:WU01:FS00:0xa3:Completed 470000 out of 500000 steps  (94%)
******************************* Date: 2014-08-22 *******************************
00:29:20:WU01:FS00:0xa3:Completed 475000 out of 500000 steps  (95%)
01:17:31:WU01:FS00:0xa3:Completed 480000 out of 500000 steps  (96%)
01:44:48:333:127.0.0.1:New Web connection
01:53:01:FS00:Paused
01:53:01:FS00:Shutting core down
01:53:08:WU01:FS00:0xa3:Client no longer detected. Shutting down core
01:53:08:WU01:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
01:53:08:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:53:29:Saving configuration to config.xml
01:53:29:<config>
01:53:29:  <!-- User Information -->
01:53:29:  <passkey v='********************************'/>
01:53:29:  <user v='Craigman'/>
01:53:29:
01:53:29:  <!-- Folding Slots -->
01:53:29:  <slot id='0' type='CPU'>
01:53:29:    <paused v='true'/>
01:53:29:  </slot>
01:53:29:</config>
03:05:44:365:127.0.0.1:New Web connection
05:01:19:WARNING:Console control signal 6 on PID 7808
05:01:19:Exiting, please wait. . .
Zagen30
Post by Zagen30 »
It appears you paused the client a few hours before the reboot, and pause normally sticks through a restart. Open up either Web Control or Advanced Control and select Fold/Start Folding to get the slot running again.
craigman wrote:Here is what was sitting out lose in the AppData folder under log.txt:
You probably mean it was in the directory C:/Users/Owner/AppData/Roaming/FAHClient, not the AppData folder. Either that or you're not using the shortcut provided by the install.
Using either FAHControl or WebControl to unpause (aka, "Fold") should solve your primary problem. There's no need to pause FAH before rebooting or shutting down.
On a different subject, you may want to adjust the number of CPUs allocated for folding from "-1" or "3" to "4" since your GPU is unsupported as a folding device. (That will increase your throughput and shouldn't cause a noticeable screen lag.)
craigman
Post by craigman »
I pause folding when I am playing Second Life which puts a lot of demands on my computer in combat. Do I need to do that?
Zagen30
Post by Zagen30 »
Your experience with your hardware is the best answer for that question. CPU folding is executed at the lowest priority level, so pretty much any other task will take precedence. People normally don't see any lag when CPU folding and doing something else that's CPU-intensive, but it's possible. Try it for yourself and see if you notice any performance issues.
