WU 6099 (0, 10, 363)
John_Weatherman
Post by John_Weatherman »
Can a kind Mod check on WU 6099 (0, 10, 363) which should have been uploaded but I got no ACK message (again - I think my IP is playing up)
*********************** Log Started 2014-08-11T18:35:45Z ***********************
18:35:45:Started thread 1 on PID 992
18:35:45:************************* Folding@home Client *************************
18:35:45:    Website: http://folding.stanford.edu/
18:35:45:  Copyright: (c) 2009-2013 Stanford University
18:35:45:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:35:45:       Args: --child --lifeline 986 /etc/fahclient/config.xml --run-as fahclient
18:35:45:             --pid-file=/var/run/fahclient.pid --daemon
18:35:45:     Config: /etc/fahclient/config.xml
18:35:45:******************************** Build ********************************
18:35:45:    Version: 7.3.6
18:35:45:       Date: Feb 18 2013
18:35:45:       Time: 07:24:09
18:35:45:    SVN Rev: 3923
18:35:45:     Branch: fah/trunk/client
18:35:45:   Compiler: GNU 4.1.2 20080704 (Red Hat 4.1.2-46)
18:35:45:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
18:35:45:             -fno-unsafe-math-optimizations -msse2
18:35:45:   Platform: linux2 2.6.18-164.11.1.el5
18:35:45:       Bits: 64
18:35:45:       Mode: Release
18:35:45:******************************* System ********************************
18:35:45:        CPU: Intel(R) Core(TM)2 Duo CPU T8300 @ 2.40GHz
18:35:45:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
18:35:45:       CPUs: 2
18:35:45:     Memory: 1.95GiB
18:35:45:Free Memory: 1.54GiB
18:35:45:    Threads: POSIX_THREADS
18:35:45:Has Battery: false
18:35:45: On Battery: false
18:35:45: UTC offset: 2
18:35:45:        PID: 992
18:35:45:        CWD: /var/lib/fahclient
18:35:45:         OS: Linux 3.12.10-300.fc20.x86_64 x86_64
18:35:45:    OS Arch: AMD64
18:35:45:       GPUs: 0
18:35:45:       CUDA: Not detected
18:35:45:***********************************************************************
18:35:45:<config>
18:35:45:  <!-- Client Control -->
18:35:45:  <client-threads v='4'/>
18:35:45:  <cycle-rate v='4'/>
18:35:45:  <cycles v='-1'/>
18:35:45:  <data-directory v='.'/>
18:35:45:  <disable-sleep-when-active v='true'/>
18:35:45:  <exec-directory v='/usr/bin'/>
18:35:45:  <exit-when-done v='false'/>
18:35:45:  <fold-anon v='false'/>
18:35:45:  <idle-seconds v='300'/>
18:35:45:  <open-web-control v='false'/>
18:35:45:
18:35:45:  <!-- Configuration -->
18:35:45:  <config-rotate v='true'/>
18:35:45:  <config-rotate-dir v='configs'/>
18:35:45:  <config-rotate-max v='16'/>
18:35:45:
18:35:45:  <!-- Debugging -->
18:35:45:  <assignment-servers>
18:35:45:    assign3.stanford.edu:8080 assign4.stanford.edu:80
18:35:45:  </assignment-servers>
18:35:45:  <capture-directory v='capture'/>
18:35:45:  <capture-on-error v='false'/>
18:35:45:  <capture-packets v='false'/>
18:35:45:  <capture-requests v='false'/>
18:35:45:  <capture-responses v='false'/>
18:35:45:  <capture-sockets v='false'/>
18:35:45:  <debug-sockets v='false'/>
18:35:45:  <exception-locations v='true'/>
18:35:45:  <gpu-assignment-servers>
18:35:45:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
18:35:45:  </gpu-assignment-servers>
18:35:45:  <stack-traces v='false'/>
18:35:45:
18:35:45:  <!-- Error Handling -->
18:35:45:  <max-slot-errors v='5'/>
18:35:45:  <max-unit-errors v='5'/>
18:35:45:
18:35:45:  <!-- Folding Core -->
18:35:45:  <checkpoint v='10'/>
18:35:45:  <core-dir v='cores'/>
18:35:45:  <core-priority v='low'/>
18:35:45:  <cpu-affinity v='false'/>
18:35:45:  <cpu-usage v='100'/>
18:35:45:  <gpu-usage v='100'/>
18:35:45:  <no-assembly v='false'/>
18:35:45:
18:35:45:  <!-- Folding Slot Configuration -->
18:35:45:  <cause v='ANY'/>
18:35:45:  <client-subtype v='LINUX'/>
18:35:45:  <client-type v='normal'/>
18:35:45:  <cpu-species v='X86_PENTIUM_II'/>
18:35:45:  <cpu-type v='AMD64'/>
18:35:45:  <cpus v='-1'/>
18:35:45:  <cuda-index v='0'/>
18:35:45:  <gpu v='false'/>
18:35:45:  <max-packet-size v='normal'/>
18:35:45:  <opencl-index v='0'/>
18:35:45:  <os-species v='UNKNOWN'/>
18:35:45:  <os-type v='LINUX'/>
18:35:45:  <power v='full'/>
18:35:45:  <project-key v='0'/>
18:35:45:  <smp v='true'/>
18:35:45:
18:35:45:  <!-- HTTP Server -->
18:35:45:  <allow v='127.0.0.1'/>
18:35:45:  <connection-timeout v='60'/>
18:35:45:  <deny v='0/0'/>
18:35:45:  <http-addresses v='0:7396'/>
18:35:45:  <https-addresses v=''/>
18:35:45:  <max-connect-time v='900'/>
18:35:45:  <max-connections v='800'/>
18:35:45:  <max-request-length v='52428800'/>
18:35:45:  <min-connect-time v='300'/>
18:35:45:  <threads v='2'/>
18:35:45:
18:35:45:  <!-- Logging -->
18:35:45:  <log v='log.txt'/>
18:35:45:  <log-color v='true'/>
18:35:45:  <log-crlf v='false'/>
18:35:45:  <log-date v='false'/>
18:35:45:  <log-date-periodically v='21600'/>
18:35:45:  <log-debug v='true'/>
18:35:45:  <log-domain v='false'/>
18:35:45:  <log-header v='true'/>
18:35:45:  <log-level v='true'/>
18:35:45:  <log-no-info-header v='true'/>
18:35:45:  <log-redirect v='false'/>
18:35:45:  <log-rotate v='true'/>
18:35:45:  <log-rotate-dir v='logs'/>
18:35:45:  <log-rotate-max v='16'/>
18:35:45:  <log-short-level v='false'/>
18:35:45:  <log-simple-domains v='true'/>
18:35:45:  <log-thread-id v='false'/>
18:35:45:  <log-thread-prefix v='true'/>
18:35:45:  <log-time v='true'/>
18:35:45:  <log-to-screen v='true'/>
18:35:45:  <log-truncate v='false'/>
18:35:45:  <verbosity v='5'/>
18:35:45:
18:35:45:  <!-- Network -->
18:35:45:  <proxy v=':8080'/>
18:35:45:  <proxy-enable v='false'/>
18:35:45:  <proxy-pass v=''/>
18:35:45:  <proxy-user v=''/>
18:35:45:
18:35:45:  <!-- Process Control -->
18:35:45:  <child v='true'/>
18:35:45:  <daemon v='true'/>
18:35:45:  <pid v='false'/>
18:35:45:  <pid-file v='/var/run/fahclient.pid'/>
18:35:45:  <respawn v='false'/>
18:35:45:  <service v='false'/>
18:35:45:
18:35:45:  <!-- Remote Command Server -->
18:35:45:  <command-address v='0.0.0.0'/>
18:35:45:  <command-allow-no-pass v='127.0.0.1'/>
18:35:45:  <command-deny-no-pass v='0/0'/>
18:35:45:  <command-port v='36330'/>
18:35:45:
18:35:45:  <!-- Slot Control -->
18:35:45:  <idle v='false'/>
18:35:45:  <max-shutdown-wait v='60'/>
18:35:45:  <pause-on-battery v='true'/>
18:35:45:  <pause-on-start v='false'/>
18:35:45:
18:35:45:  <!-- User Information -->
18:35:45:  <machine-id v='0'/>
18:35:45:  <passkey v='********************************'/>
18:35:45:  <team v='48913'/>
18:35:45:  <user v='John_Weatherman'/>
18:35:45:
18:35:45:  <!-- Web Server -->
18:35:45:  <session-timeout v='3600'/>
18:35:45:  <web-allow v='127.0.0.1'/>
18:35:45:  <web-deny v='0/0'/>
18:35:45:
18:35:45:  <!-- Work Unit Control -->
18:35:45:  <dump-after-deadline v='true'/>
18:35:45:  <max-queue v='16'/>
18:35:45:  <max-units v='0'/>
18:35:45:  <next-unit-percentage v='99'/>
18:35:45:
18:35:45:  <!-- Folding Slots -->
18:35:45:  <slot id='0' type='CPU'>
18:35:45:    <cpus v='2'/>
18:35:45:  </slot>
18:35:45:</config>
18:35:45:Switching to user fahclient
18:35:45:Trying to access database...
18:35:45:Successfully acquired database lock
18:35:45:Enabled folding slot 00: READY cpu:2
18:35:45:Started thread 5 on PID 992
18:35:45:WU01:FS00:Starting
18:35:45:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 01 -suffix 01 -version 703 -lifeline 992 -checkpoint 10 -np 2
18:35:45:WU01:FS00:Started FahCore on PID 1000
18:35:45:Started thread 6 on PID 992
18:35:45:Started thread 7 on PID 992
18:35:45:Started thread 8 on PID 992
18:35:45:Started thread 9 on PID 992
18:35:45:WU01:FS00:Core PID:1004
18:35:45:WU01:FS00:FahCore 0xa3 started
18:35:46:WU01:FS00:0xa3:
18:35:46:WU01:FS00:0xa3:*------------------------------*
18:35:46:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
18:35:46:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
18:35:46:WU01:FS00:0xa3:Preparing to commence simulation
18:35:46:WU01:FS00:0xa3:- Looking at optimizations...
18:35:46:WU01:FS00:0xa3:- Files status OK
18:35:46:WU01:FS00:0xa3:- Expanded 3810619 -> 4169428 (decompressed 109.4 percent)
18:35:46:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3810619 data_size=4169428, decompressed_data_size=4169428 diff=0
18:35:46:WU01:FS00:0xa3:- Digital signature verified
18:35:46:WU01:FS00:0xa3:Project: 6099 (Run 0, Clone 10, Gen 363)
18:35:46:WU01:FS00:0xa3:Assembly optimizations on if available.
18:35:46:WU01:FS00:0xa3:Entering M.D.
18:35:52:WU01:FS00:0xa3:Using Gromacs checkpoints
18:35:53:WU01:FS00:0xa3:Mapping NT from 2 to 2
18:35:54:WU01:FS00:0xa3:Resuming from checkpoint
18:35:54:WU01:FS00:0xa3:Verified 01/wudata_01.log
18:35:54:WU01:FS00:0xa3:Verified 01/wudata_01.trr
18:35:54:WU01:FS00:0xa3:Verified 01/wudata_01.edr
18:35:55:WU01:FS00:0xa3:Completed 469435 out of 500000 steps  (93%)
18:38:19:Started thread 10 on PID 992
18:40:18:WU01:FS00:0xa3:Completed 470000 out of 500000 steps  (94%)
19:18:45:WU01:FS00:0xa3:Completed 475000 out of 500000 steps  (95%)
19:55:22:WU01:FS00:0xa3:Completed 480000 out of 500000 steps  (96%)
20:36:15:WU01:FS00:0xa3:Completed 485000 out of 500000 steps  (97%)
21:15:41:WU01:FS00:0xa3:Completed 490000 out of 500000 steps  (98%)
21:15:42:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:15:42:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution
21:15:42:WU00:FS00:Connecting to assign4.stanford.edu:80
21:15:42:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Temporary failure in name resolution
21:15:42:ERROR:WU00:FS00:Exception: Could not get an assignment
21:16:42:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:16:42:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution
21:16:42:WU00:FS00:Connecting to assign4.stanford.edu:80
21:16:42:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Temporary failure in name resolution
21:16:42:ERROR:WU00:FS00:Exception: Could not get an assignment
21:18:20:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:18:20:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution
21:18:20:WU00:FS00:Connecting to assign4.stanford.edu:80
21:18:20:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Temporary failure in name resolution
21:18:20:ERROR:WU00:FS00:Exception: Could not get an assignment
21:20:57:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:20:57:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution
21:20:57:WU00:FS00:Connecting to assign4.stanford.edu:80
21:20:57:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Temporary failure in name resolution
21:20:57:ERROR:WU00:FS00:Exception: Could not get an assignment
21:25:11:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:25:11:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution
21:25:11:WU00:FS00:Connecting to assign4.stanford.edu:80
21:25:11:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Temporary failure in name resolution
21:25:11:ERROR:WU00:FS00:Exception: Could not get an assignment
21:32:03:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:32:03:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution
21:32:03:WU00:FS00:Connecting to assign4.stanford.edu:80
21:32:03:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Temporary failure in name resolution
21:32:03:ERROR:WU00:FS00:Exception: Could not get an assignment
21:43:08:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:43:18:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Name or service not known
21:43:18:WU00:FS00:Connecting to assign4.stanford.edu:80
21:43:33:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Name or service not known
21:43:33:ERROR:WU00:FS00:Exception: Could not get an assignment
21:52:50:WU01:FS00:0xa3:Completed 495000 out of 500000 steps  (99%)
21:55:08:Started thread 11 on PID 992
22:01:05:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:01:05:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Could not get IP address for assign3.stanford.edu: Temporary failure in name resolution
22:01:05:WU00:FS00:Connecting to assign4.stanford.edu:80
22:01:05:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Could not get IP address for assign4.stanford.edu: Temporary failure in name resolution
22:01:05:ERROR:WU00:FS00:Exception: Could not get an assignment
22:30:07:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:30:08:WU00:FS00:News: Welcome to Folding@Home
22:30:08:WU00:FS00:Assigned to work server 155.247.166.220
22:30:08:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.166.220
22:30:08:WU00:FS00:Connecting to 155.247.166.220:8080
22:30:09:WU00:FS00:Downloading 199.08KiB
22:30:09:WU00:FS00:Download complete
22:30:09:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6377 run:36 clone:1 gen:73 core:0xa4 unit:0x0000004b0002894c539a0adb3973b8d8
22:32:44:WU01:FS00:0xa3:Completed 500000 out of 500000 steps  (100%)
22:32:46:WU01:FS00:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
22:32:56:WU01:FS00:0xa3:
22:32:56:WU01:FS00:0xa3:Finished Work Unit:
22:32:56:WU01:FS00:0xa3:- Reading up to 12102336 from "01/wudata_01.trr": Read 12102336
22:32:57:WU01:FS00:0xa3:trr file hash check passed.
22:32:57:WU01:FS00:0xa3:edr file hash check passed.
22:32:57:WU01:FS00:0xa3:logfile size: 86746
22:32:57:WU01:FS00:0xa3:Leaving Run
22:32:59:WU01:FS00:0xa3:- Writing 12222758 bytes of core data to disk...
22:33:02:WU01:FS00:0xa3:Done: 12222246 -> 11290433 (compressed to 92.3 percent)
22:33:02:WU01:FS00:0xa3:  ... Done.
22:39:29:WU01:FS00:0xa3:- Shutting down core
22:39:29:WU01:FS00:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
22:40:16:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:40:16:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6099 run:0 clone:10 gen:363 core:0xa3 unit:0x000045b00a3b1e59513e873875178920
22:40:16:WU01:FS00:Uploading 10.77MiB to 128.143.231.202
22:40:16:WU01:FS00:Connecting to 128.143.231.202:8080
22:40:16:WU00:FS00:Starting
22:40:16:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 703 -lifeline 992 -checkpoint 10 -np 2
22:40:16:WU00:FS00:Started FahCore on PID 4621
22:40:16:Started thread 12 on PID 992
22:40:16:WU00:FS00:Core PID:4625
22:40:16:WU00:FS00:FahCore 0xa4 started
22:40:16:WU00:FS00:0xa4:
22:40:16:WU00:FS00:0xa4:*------------------------------*
22:40:16:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
22:40:16:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:40:16:WU00:FS00:0xa4:Preparing to commence simulation
22:40:16:WU00:FS00:0xa4:- Looking at optimizations...
22:40:16:WU00:FS00:0xa4:- Created dyn
22:40:16:WU00:FS00:0xa4:- Files status OK
22:40:16:WU00:FS00:0xa4:- Expanded 203349 -> 427936 (decompressed 210.4 percent)
22:40:16:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=203349 data_size=427936, decompressed_data_size=427936 diff=0
22:40:16:WU00:FS00:0xa4:- Digital signature verified
22:40:16:WU00:FS00:0xa4:Project: 6377 (Run 36, Clone 1, Gen 73)
22:40:16:WU00:FS00:0xa4:Assembly optimizations on if available.
22:40:16:WU00:FS00:0xa4:Entering M.D.
22:40:22:WU01:FS00:Upload 15.67%
22:40:23:WU00:FS00:0xa4:Completed 0 out of 2500000 steps  (0%)
22:40:28:WU01:FS00:Upload 27.28%
22:40:34:WU01:FS00:Upload 32.50%
22:40:40:WU01:FS00:Upload 37.15%
22:40:46:WU01:FS00:Upload 41.21%
22:40:52:WU01:FS00:Upload 47.60%
22:40:58:WU01:FS00:Upload 56.88%
22:41:04:WU01:FS00:Upload 71.97%
22:41:10:WU01:FS00:Upload 81.84%
22:41:16:WU01:FS00:Upload 87.64%
22:41:22:WU01:FS00:Upload 90.55%
22:41:28:WU01:FS00:Upload 92.29%
22:41:34:WU01:FS00:Upload 98.09%
22:48:34:WU00:FS00:0xa4:Completed 25000 out of 2500000 steps  (1%)
22:50:51:Started thread 13 on PID 992
22:55:42:WU00:FS00:0xa4:Completed 50000 out of 2500000 steps  (2%)
23:02:13:WU00:FS00:0xa4:Completed 75000 out of 2500000 steps  (3%)
bollix47
Re: WU 6099 (0, 10, 363)
Post by bollix47 »
Hi John_Weatherman (team 48913),
Your WU (P6099 R0 C10 G363) was added to the stats database on 2014-08-11 16:11:29 for 3992.23 points of credit.
John_Weatherman
Thanks! It did try to upload again after a reboot
04:28:52:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6099 run:0 clone:10 gen:363 core:0xa3 unit:0x000045b00a3b1e59513e873875178920
04:28:52:WU01:FS00:Uploading 10.77MiB to 128.143.231.202
04:28:52:WU01:FS00:Connecting to 128.143.231.202:8080
04:28:59:WU01:FS00:Upload 4.06%
04:29:05:WU01:FS00:Upload 6.97%
04:29:12:WU01:FS00:Upload 9.29%
04:29:18:WU01:FS00:Upload 11.61%
04:29:24:WU01:FS00:Upload 14.51%
04:29:30:WU01:FS00:Upload 20.90%
04:29:36:WU01:FS00:Upload 22.64%
04:29:42:WU01:FS00:Upload 26.12%
04:29:48:WU01:FS00:Upload 61.53%
04:29:52:WU01:FS00:Upload complete
04:29:52:WU01:FS00:Server responded GOT_ALREADY (434)
04:29:52:WARNING:WU01:FS00:Server did not like results, dumping
04:29:52:WU01:FS00:Cleaning up
So the system works! Now just to sort out why it happened in the first place ...
