Corrupted Units?
Rick9399
Corrupted Units?
Post by Rick9399 »
Hi. :)
I'm not really a new donor. I've been folding for a looooooong time, but with breaks (each during about 2 years), so I'll just post the problem i'm having here. Because it's probably not a very intelligent question.
A while ago, I started folding... Again. The first two units went well, but the third, fourth and fifth units somehow got stuck in the sending fase. The sixth and seventh just got send without any problems though. So now I have 3 finished work units that just won't get out of my Advanced Control thingy. And everytime it tries to send them again, it stops at about 20%, giving me this error:
14:45:10:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed.
Here's what I think the problem is: I used to have a child lock on my internet access, so I wasn't able to access anything on the internet between 20:00 and 08:00. I have full internet access now (I think), but when I open Web Control after 20:00, it sais the web page is missing or something similar. Every other website and the Advanced Control seem to work though. So I think the client completed those units between 20:00 and 08:00, then tried to send them, but returned an error because it somehow might not have full access to the internet without me knowing about it. Could this cause units to be somehow 'corrupted'? Or doesn't that make any sense because it also folded at night the days before?
Please help! :(
Re: Corrupted Units?
Welcome to foldingforum.org, Rick9399 (even if you've been folding a long time).
Your explanation makes sense but there are other possibilities, too. If you post your log, we may be able to give you more information, but my first question is how long have you waited. Assume a WU was finished while your internet was blocked. FAHClient will retry repeatedly and eventually it should retry after 08:00 and succeed. It should be noted that every time it retries, the retry interval gets longer and longer, so don't expect it to retry soon after 08:00 if it has been retrying all night.
You can also restart everything which forces a prompt retry, but I'd just wait and see what happens.
Rick9399
Post by Rick9399 »
I've been waiting for about a week now, and I can see when it will try to send it again. It has tried to send it so many times (at daytime) I just don't think they will send at all if I don't do something. And I don't want them to disappear. :(
Anyways, the log:
*********************** Log Started 2014-08-01T08:09:07Z ***********************
08:09:07:************************* Folding@home Client *************************
08:09:07:      Website: http://folding.stanford.edu/
08:09:07:    Copyright: (c) 2009-2014 Stanford University
08:09:07:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:09:07:         Args:
08:09:07:       Config: C:/Users/Gaming/AppData/Roaming/FAHClient/config.xml
08:09:07:******************************** Build ********************************
08:09:07:      Version: 7.4.4
08:09:07:         Date: Mar 4 2014
08:09:07:         Time: 20:26:54
08:09:07:      SVN Rev: 4130
08:09:07:       Branch: fah/trunk/client
08:09:07:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
08:09:07:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
08:09:07:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
08:09:07:     Platform: win32 XP
08:09:07:         Bits: 32
08:09:07:         Mode: Release
08:09:07:******************************* System ********************************
08:09:07:          CPU: AMD Athlon(tm) Dual Core Processor 4450e
08:09:07:       CPU ID: AuthenticAMD Family 15 Model 107 Stepping 2
08:09:07:         CPUs: 2
08:09:07:       Memory: 3.00GiB
08:09:07:  Free Memory: 1.36GiB
08:09:07:      Threads: WINDOWS_THREADS
08:09:07:   OS Version: 6.0
08:09:07:  Has Battery: false
08:09:07:   On Battery: false
08:09:07:   UTC Offset: 2
08:09:07:          PID: 5752
08:09:07:          CWD: C:/Users/Gaming/AppData/Roaming/FAHClient
08:09:07:           OS: Windows Vista (TM) Home Premium Service Pack 2
08:09:07:      OS Arch: X86
08:09:07:         GPUs: 1
08:09:07:        GPU 0: NVIDIA:1 G98 [GeForce 9300 GE]
08:09:07:         CUDA: Not detected
08:09:07:Win32 Service: false
08:09:07:***********************************************************************
08:09:12:<config>
08:09:12:  <!-- Folding Core -->
08:09:12:  <checkpoint v='30'/>
08:09:12:  <core-priority v='low'/>
08:09:12:
08:09:12:  <!-- Logging -->
08:09:12:  <verbosity v='2'/>
08:09:12:
08:09:12:  <!-- Network -->
08:09:12:  <proxy v=':8080'/>
08:09:12:
08:09:12:  <!-- Slot Control -->
08:09:12:  <pause-on-battery v='false'/>
08:09:12:  <power v='FULL'/>
08:09:12:
08:09:12:  <!-- User Information -->
08:09:12:  <team v='143016'/>
08:09:12:  <user v='Rick9399'/>
08:09:12:
08:09:12:  <!-- Folding Slots -->
08:09:12:  <slot id='0' type='CPU'>
08:09:12:    <paused v='true'/>
08:09:12:  </slot>
08:09:12:</config>
08:09:12:Trying to access database...
08:09:12:Enabled folding slot 00: PAUSED cpu:2 (by user)
08:09:12:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
08:09:12:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
08:09:12:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
08:09:12:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
08:09:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
08:09:12:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
08:11:02:FS00:Unpaused
08:11:02:WU05:FS00:Starting
08:11:02:WU05:FS00:Core PID:4796
08:11:02:WU05:FS00:FahCore 0xa4 started
08:11:02:WU05:FS00:0xa4:
08:11:02:WU05:FS00:0xa4:*------------------------------*
08:11:02:WU05:FS00:0xa4:Folding@Home Gromacs GB Core
08:11:02:WU05:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
08:11:02:WU05:FS00:0xa4:Preparing to commence simulation
08:11:02:WU05:FS00:0xa4:- Looking at optimizations...
08:11:02:WU05:FS00:0xa4:- Files status OK
08:11:02:WU05:FS00:0xa4:- Expanded 117456 -> 266072 (decompressed 226.5 percent)
08:11:02:WU05:FS00:0xa4:Called DecompressByteArray: compressed_data_size=117456 data_size=266072, decompressed_data_size=266072 diff=0
08:11:02:WU05:FS00:0xa4:- Digital signature verified
08:11:02:WU05:FS00:0xa4:Project: 6369 (Run 71, Clone 33, Gen 58)
08:11:02:WU05:FS00:0xa4:Assembly optimizations on if available.
08:11:02:WU05:FS00:0xa4:Entering M.D.
08:11:08:WU05:FS00:0xa4:Using Gromacs checkpoints
08:11:08:WU05:FS00:0xa4:Mapping NT from 1 to 1
08:11:08:WU05:FS00:0xa4:Resuming from checkpoint
08:11:08:WU05:FS00:0xa4:Verified 05/wudata_01.log
08:11:08:WU05:FS00:0xa4:Verified 05/wudata_01.trr
08:11:08:WU05:FS00:0xa4:Verified 05/wudata_01.xtc
08:11:08:WU05:FS00:0xa4:Verified 05/wudata_01.edr
08:11:08:WU05:FS00:0xa4:Completed 4402600 out of 5000000 steps  (88%)
08:11:14:Saving configuration to config.xml
08:11:14:<config>
08:11:14:  <!-- Folding Core -->
08:11:14:  <checkpoint v='30'/>
08:11:14:  <core-priority v='low'/>
08:11:14:
08:11:14:  <!-- Logging -->
08:11:14:  <verbosity v='2'/>
08:11:14:
08:11:14:  <!-- Network -->
08:11:14:  <proxy v=':8080'/>
08:11:14:
08:11:14:  <!-- Slot Control -->
08:11:14:  <pause-on-battery v='false'/>
08:11:14:  <power v='FULL'/>
08:11:14:
08:11:14:  <!-- User Information -->
08:11:14:  <team v='143016'/>
08:11:14:  <user v='Rick9399'/>
08:11:14:
08:11:14:  <!-- Folding Slots -->
08:11:14:  <slot id='0' type='CPU'/>
08:11:14:</config>
08:15:42:WU04:FS00:Upload 1.00%
08:17:25:WU04:FS00:Upload 2.01%
08:17:54:WU04:FS00:Upload 3.01%
08:18:01:WU00:FS00:Upload 1.00%
08:18:03:WU02:FS00:Upload 1.01%
08:18:14:WU04:FS00:Upload 4.01%
08:18:25:WU00:FS00:Upload 2.00%
08:18:25:WU02:FS00:Upload 2.02%
08:18:48:WU00:FS00:Upload 3.01%
08:18:48:WU02:FS00:Upload 3.02%
08:19:10:WU02:FS00:Upload 4.03%
08:19:11:WU00:FS00:Upload 4.01%
08:19:33:WU02:FS00:Upload 5.04%
08:19:34:WU00:FS00:Upload 5.01%
08:19:56:WU04:FS00:Upload 5.02%
08:20:04:WU00:FS00:Upload 6.01%
08:20:25:WU00:FS00:Upload 7.02%
08:20:28:WU04:FS00:Upload 6.02%
08:20:47:WU00:FS00:Upload 8.02%
08:21:08:WU00:FS00:Upload 9.02%
08:21:29:WU00:FS00:Upload 10.02%
08:21:32:WU02:FS00:Upload 6.05%
08:21:48:WU00:FS00:Upload 11.03%
08:21:56:WU02:FS00:Upload 7.06%
08:22:06:WU04:FS00:Upload 7.02%
08:22:08:WU00:FS00:Upload 12.03%
08:22:17:WU02:FS00:Upload 8.07%
08:22:26:WU00:FS00:Upload 13.03%
08:22:35:WU04:FS00:Upload 8.03%
08:22:39:WU02:FS00:Upload 9.07%
08:22:45:WU00:FS00:Upload 14.03%
08:23:01:WU02:FS00:Upload 10.08%
08:23:03:WU00:FS00:Upload 15.03%
08:23:20:WU02:FS00:Upload 11.09%
08:23:21:WU00:FS00:Upload 16.04%
08:23:39:WU02:FS00:Upload 12.10%
08:23:40:WU00:FS00:Upload 17.04%
08:23:58:WU02:FS00:Upload 13.11%
08:23:58:WU00:FS00:Upload 18.04%
08:24:13:WU02:FS00:Upload 14.12%
08:24:13:WU00:FS00:Upload 19.04%
08:24:13:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
08:24:14:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
08:24:14:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
08:24:14:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
08:24:14:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
08:24:14:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
08:24:25:WU04:FS00:Upload 9.03%
08:24:25:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
08:24:25:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
08:24:25:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
08:24:26:WU02:FS00:Upload 1.01%
08:24:42:WU02:FS00:Upload 2.02%
08:24:57:WU02:FS00:Upload 3.02%
08:25:12:WU02:FS00:Upload 4.03%
08:25:28:WU02:FS00:Upload 5.04%
08:25:43:WU02:FS00:Upload 6.05%
08:25:58:WU02:FS00:Upload 7.06%
08:26:14:WU02:FS00:Upload 8.07%
08:26:29:WU02:FS00:Upload 9.07%
08:26:45:WU02:FS00:Upload 10.08%
08:27:05:WU02:FS00:Upload 11.09%
08:27:27:WU02:FS00:Upload 12.10%
08:27:48:WU02:FS00:Upload 13.11%
08:28:10:WU02:FS00:Upload 14.12%
08:28:32:WU02:FS00:Upload 15.12%
08:28:37:WU00:FS00:Upload 1.00%
08:28:37:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
08:28:37:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
08:28:37:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
08:29:25:WU02:FS00:Upload 16.13%
08:29:46:WU02:FS00:Upload 17.14%
08:30:10:WU02:FS00:Upload 18.15%
08:30:32:WU02:FS00:Upload 19.16%
08:30:54:WU02:FS00:Upload 20.17%
08:31:16:WU02:FS00:Upload 21.17%
08:31:37:WU02:FS00:Upload 22.18%
08:31:51:WU04:FS00:Upload 1.00%
08:31:51:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
08:31:51:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
08:31:51:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
08:32:01:WU02:FS00:Upload 23.19%
08:32:08:WU04:FS00:Upload 1.00%
08:32:23:WU02:FS00:Upload 24.20%
08:32:27:WU04:FS00:Upload 2.01%
08:32:45:WU02:FS00:Upload 25.21%
08:32:45:WU04:FS00:Upload 3.01%
08:33:07:WU02:FS00:Upload 26.22%
08:33:29:WU02:FS00:Upload 27.22%
08:33:51:WU02:FS00:Upload 28.23%
08:34:13:WU02:FS00:Upload 29.24%
08:34:34:WU02:FS00:Upload 30.25%
08:35:02:WU02:FS00:Upload 31.26%
08:35:22:WU02:FS00:Upload 32.27%
08:35:39:WU02:FS00:Upload 33.27%
08:35:40:WU05:FS00:0xa4:Completed 4450000 out of 5000000 steps  (89%)
08:35:56:WU02:FS00:Upload 34.28%
08:36:13:WU02:FS00:Upload 35.29%
08:36:31:WU02:FS00:Upload 36.30%
08:36:47:WU02:FS00:Upload 37.31%
08:37:06:WU02:FS00:Upload 38.31%
08:37:23:WU02:FS00:Upload 39.32%
08:37:44:WU02:FS00:Upload 40.33%
08:38:10:WU02:FS00:Upload 41.34%
08:38:28:WU04:FS00:Upload 4.01%
08:38:31:WU02:FS00:Upload 42.35%
08:38:50:WU04:FS00:Upload 5.02%
08:38:54:WU02:FS00:Upload 43.36%
08:39:12:WU04:FS00:Upload 6.02%
08:39:13:WU00:FS00:Upload 1.00%
08:39:15:WU02:FS00:Upload 44.36%
08:39:15:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
08:39:16:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
08:39:16:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
08:39:30:WU02:FS00:Upload 1.01%
08:39:33:WU00:FS00:Upload 2.00%
08:39:34:WU04:FS00:Upload 7.02%
08:39:45:WU02:FS00:Upload 2.02%
08:39:52:WU00:FS00:Upload 3.01%
08:39:59:WU02:FS00:Upload 3.02%
08:40:02:WU04:FS00:Upload 8.03%
08:40:11:WU00:FS00:Upload 4.01%
08:40:14:WU02:FS00:Upload 4.03%
08:40:23:WU04:FS00:Upload 9.03%
08:40:29:WU02:FS00:Upload 5.04%
08:40:30:WU00:FS00:Upload 5.01%
08:40:41:WU04:FS00:Upload 10.03%
08:40:44:WU02:FS00:Upload 6.05%
08:40:50:WU00:FS00:Upload 6.01%
08:40:59:WU02:FS00:Upload 7.06%
08:41:04:WU04:FS00:Upload 11.04%
08:41:09:WU00:FS00:Upload 7.02%
08:41:14:WU02:FS00:Upload 8.07%
08:41:21:WU04:FS00:Upload 12.04%
08:41:25:WU00:FS00:Upload 8.02%
08:41:29:WU02:FS00:Upload 9.07%
08:41:39:WU04:FS00:Upload 13.04%
08:41:42:WU00:FS00:Upload 9.02%
08:41:44:WU02:FS00:Upload 10.08%
08:41:57:WU04:FS00:Upload 14.04%
08:41:59:WU02:FS00:Upload 11.09%
08:42:07:WU00:FS00:Upload 10.02%
08:42:15:WU04:FS00:Upload 15.05%
08:42:16:WU02:FS00:Upload 12.10%
08:42:26:WU00:FS00:Upload 11.03%
08:42:34:WU02:FS00:Upload 13.11%
08:42:45:WU00:FS00:Upload 12.03%
08:42:52:WU02:FS00:Upload 14.12%
08:43:05:WU00:FS00:Upload 13.03%
08:43:10:WU02:FS00:Upload 15.12%
08:43:25:WU00:FS00:Upload 14.03%
08:43:30:WU02:FS00:Upload 16.13%
08:43:46:WU00:FS00:Upload 15.03%
08:43:46:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
08:43:46:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
08:43:46:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
08:43:49:WU02:FS00:Upload 17.14%
08:43:50:WU04:FS00:Upload 16.05%
08:43:50:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
08:43:50:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
08:43:50:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
08:44:04:WU04:FS00:Upload 1.00%
08:44:07:WU02:FS00:Upload 18.15%
08:44:28:WU04:FS00:Upload 2.01%
08:44:46:WU04:FS00:Upload 3.01%
08:44:57:WU00:FS00:Upload 1.00%
08:44:57:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
08:45:05:WU04:FS00:Upload 4.01%
08:46:43:WU04:FS00:Upload 5.02%
08:47:05:WU04:FS00:Upload 6.02%
08:47:12:WU02:FS00:Upload 19.16%
08:47:26:WU04:FS00:Upload 7.02%
08:47:34:WU02:FS00:Upload 20.17%
08:47:48:WU04:FS00:Upload 8.03%
08:47:57:WU02:FS00:Upload 21.17%
08:48:00:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
08:48:00:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
08:48:12:WU04:FS00:Upload 9.03%
08:48:24:WU02:FS00:Upload 22.18%
08:48:30:WU04:FS00:Upload 10.03%
08:48:46:WU02:FS00:Upload 23.19%
08:48:47:WU04:FS00:Upload 11.04%
08:49:06:WU04:FS00:Upload 12.04%
08:49:09:WU02:FS00:Upload 24.20%
08:49:24:WU04:FS00:Upload 13.04%
08:49:31:WU02:FS00:Upload 25.21%
08:49:42:WU04:FS00:Upload 14.04%
08:49:53:WU02:FS00:Upload 26.22%
08:49:59:WU04:FS00:Upload 15.05%
08:50:05:WU00:FS00:Upload 1.00%
08:50:15:WU02:FS00:Upload 27.22%
08:50:17:WU04:FS00:Upload 16.05%
08:50:18:WU00:FS00:Upload 2.00%
08:50:33:WU00:FS00:Upload 3.01%
08:50:34:WU04:FS00:Upload 17.05%
08:50:37:WU02:FS00:Upload 28.23%
08:50:46:WU00:FS00:Upload 4.01%
08:50:52:WU04:FS00:Upload 18.06%
08:50:59:WU02:FS00:Upload 29.24%
08:51:04:WU00:FS00:Upload 5.01%
08:51:09:WU04:FS00:Upload 19.06%
08:51:21:WU02:FS00:Upload 30.25%
08:51:23:WU00:FS00:Upload 6.01%
08:51:26:WU04:FS00:Upload 20.06%
08:51:41:WU02:FS00:Upload 31.26%
08:51:42:WU00:FS00:Upload 7.02%
08:51:43:WU04:FS00:Upload 21.07%
08:52:01:WU04:FS00:Upload 22.07%
08:52:03:WU02:FS00:Upload 32.27%
08:52:17:WU04:FS00:Upload 23.07%
08:52:21:WU02:FS00:Upload 33.27%
08:52:34:WU04:FS00:Upload 24.08%
08:52:38:WU02:FS00:Upload 34.28%
08:52:48:WU04:FS00:Upload 25.08%
08:52:57:WU02:FS00:Upload 35.29%
08:53:10:WU04:FS00:Upload 26.08%
08:53:14:WU02:FS00:Upload 36.30%
08:53:27:WU04:FS00:Upload 27.09%
08:53:31:WU02:FS00:Upload 37.31%
08:53:44:WU04:FS00:Upload 28.09%
08:53:48:WU00:FS00:Upload 8.02%
08:53:49:WU02:FS00:Upload 38.31%
08:54:03:WU04:FS00:Upload 29.09%
08:54:07:WU02:FS00:Upload 39.32%
08:54:11:WU00:FS00:Upload 9.02%
08:54:17:WU02:FS00:Upload 40.33%
08:54:18:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
08:54:18:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
08:54:18:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
08:54:21:WU04:FS00:Upload 30.10%
08:54:29:WU00:FS00:Upload 10.02%
08:54:32:WU02:FS00:Upload 1.01%
08:54:38:WU04:FS00:Upload 31.10%
08:54:46:WU00:FS00:Upload 11.03%
08:54:48:WU02:FS00:Upload 2.02%
08:55:01:WU04:FS00:Upload 32.10%
08:55:03:WU02:FS00:Upload 3.02%
08:55:10:WU00:FS00:Upload 12.03%
08:55:18:WU04:FS00:Upload 33.11%
08:55:19:WU02:FS00:Upload 4.03%
08:55:26:WU00:FS00:Upload 13.03%
08:55:43:WU00:FS00:Upload 14.03%
08:55:58:WU04:FS00:Upload 34.11%
08:56:17:WU04:FS00:Upload 35.11%
08:56:34:WU04:FS00:Upload 36.12%
08:56:51:WU04:FS00:Upload 37.12%
08:57:08:WU04:FS00:Upload 38.12%
08:57:25:WU04:FS00:Upload 39.13%
08:57:42:WU04:FS00:Upload 40.13%
08:57:59:WU04:FS00:Upload 41.13%
08:58:16:WU04:FS00:Upload 42.13%
08:58:33:WU04:FS00:Upload 43.14%
08:58:40:WU00:FS00:Upload 15.03%
08:58:52:WU04:FS00:Upload 44.14%
08:58:52:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
08:58:53:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
08:58:53:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
08:59:05:WU00:FS00:Upload 16.04%
08:59:27:WU00:FS00:Upload 17.04%
08:59:30:WU04:FS00:Upload 1.00%
08:59:44:WU04:FS00:Upload 2.01%
08:59:48:WU00:FS00:Upload 18.04%
08:59:57:WU04:FS00:Upload 3.01%
09:00:02:WU05:FS00:0xa4:Completed 4500000 out of 5000000 steps  (90%)
09:00:08:WU00:FS00:Upload 19.04%
09:00:23:WU04:FS00:Upload 4.01%
09:00:25:WU00:FS00:Upload 20.05%
09:00:38:WU02:FS00:Upload 5.04%
09:00:46:WU04:FS00:Upload 5.02%
09:00:46:WU00:FS00:Upload 21.05%
09:00:56:WU02:FS00:Upload 6.05%
09:01:03:WU00:FS00:Upload 22.05%
09:01:10:WU04:FS00:Upload 6.02%
09:01:15:WU02:FS00:Upload 7.06%
09:01:21:WU00:FS00:Upload 23.05%
09:01:31:WU04:FS00:Upload 7.02%
09:01:36:WU02:FS00:Upload 8.07%
09:01:38:WU00:FS00:Upload 24.06%
09:01:54:WU02:FS00:Upload 9.07%
09:01:54:WU04:FS00:Upload 8.03%
09:02:01:WU00:FS00:Upload 25.06%
09:02:11:WU02:FS00:Upload 10.08%
09:02:15:WU04:FS00:Upload 9.03%
09:02:23:WU00:FS00:Upload 26.06%
09:02:33:WU02:FS00:Upload 11.09%
09:02:37:WU04:FS00:Upload 10.03%
09:02:45:WU00:FS00:Upload 27.06%
09:02:50:WU02:FS00:Upload 12.10%
09:03:01:WU04:FS00:Upload 11.04%
09:03:02:WU00:FS00:Upload 28.07%
09:03:02:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
09:03:02:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
09:03:02:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
09:03:23:WU04:FS00:Upload 12.04%
09:03:44:WU04:FS00:Upload 13.04%
09:04:06:WU04:FS00:Upload 14.04%
09:04:28:WU04:FS00:Upload 15.05%
09:04:49:WU04:FS00:Upload 16.05%
09:05:11:WU04:FS00:Upload 17.05%
09:05:33:WU04:FS00:Upload 18.06%
09:05:55:WU04:FS00:Upload 19.06%
09:06:17:WU04:FS00:Upload 20.06%
09:06:26:WU02:FS00:Upload 13.11%
09:06:40:WU04:FS00:Upload 21.07%
09:06:48:WU02:FS00:Upload 14.12%
09:06:52:WU00:FS00:Upload 1.00%
09:06:52:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
09:07:03:WU04:FS00:Upload 22.07%
09:07:11:WU02:FS00:Upload 15.12%
09:07:27:WU04:FS00:Upload 23.07%
09:07:32:WU02:FS00:Upload 16.13%
09:07:51:WU04:FS00:Upload 24.08%
09:07:55:WU02:FS00:Upload 17.14%
09:08:14:WU04:FS00:Upload 25.08%
09:08:17:WU02:FS00:Upload 18.15%
09:08:34:WU04:FS00:Upload 26.08%
09:08:40:WU02:FS00:Upload 19.16%
09:08:59:WU04:FS00:Upload 27.09%
09:09:02:WU02:FS00:Upload 20.17%
09:09:19:WU04:FS00:Upload 28.09%
09:09:19:WU02:FS00:Upload 21.17%
09:09:19:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
09:09:19:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
09:09:19:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
09:09:31:WU04:FS00:Upload 29.09%
09:09:45:WU04:FS00:Upload 30.10%
09:09:58:WU04:FS00:Upload 31.10%
09:10:11:WU04:FS00:Upload 32.10%
09:10:23:WU04:FS00:Upload 33.11%
09:10:36:WU04:FS00:Upload 34.11%
09:10:50:WU04:FS00:Upload 35.11%
09:11:57:WU04:FS00:Upload 36.12%
09:12:17:WU04:FS00:Upload 37.12%
09:12:39:WU04:FS00:Upload 38.12%
09:12:58:WU04:FS00:Upload 39.13%
09:13:54:WU04:FS00:Upload 40.13%
09:13:54:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
09:13:55:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
09:13:55:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
09:14:07:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
09:14:08:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
09:14:09:WU04:FS00:Upload 1.00%
09:14:32:WU04:FS00:Upload 2.01%
09:14:49:WU04:FS00:Upload 3.01%
09:15:07:WU04:FS00:Upload 4.01%
09:15:25:WU04:FS00:Upload 5.02%
09:15:43:WU04:FS00:Upload 6.02%
09:16:00:WU04:FS00:Upload 7.02%
09:16:11:WU00:FS00:Upload 1.00%
09:16:18:WU04:FS00:Upload 8.03%
09:16:29:WU00:FS00:Upload 2.00%
09:16:35:WU04:FS00:Upload 9.03%
09:16:48:WU00:FS00:Upload 3.01%
09:16:54:WU04:FS00:Upload 10.03%
09:17:08:WU00:FS00:Upload 4.01%
09:17:11:WU04:FS00:Upload 11.04%
09:17:26:WU00:FS00:Upload 5.01%
09:17:28:WU04:FS00:Upload 12.04%
09:17:45:WU04:FS00:Upload 13.04%
09:17:45:WU00:FS00:Upload 6.01%
09:17:52:WU02:FS00:Upload 1.01%
09:18:02:WU04:FS00:Upload 14.04%
09:18:14:WU02:FS00:Upload 2.02%
09:18:19:WU04:FS00:Upload 15.05%
09:18:23:WU00:FS00:Upload 7.02%
09:18:40:WU04:FS00:Upload 16.05%
09:18:43:WU02:FS00:Upload 3.02%
09:19:03:WU04:FS00:Upload 17.05%
09:19:25:WU04:FS00:Upload 18.06%
09:19:48:WU04:FS00:Upload 19.06%
09:21:22:WU00:FS00:Upload 8.02%
09:21:42:WU00:FS00:Upload 9.02%
09:21:59:WU00:FS00:Upload 10.02%
09:22:09:WU02:FS00:Upload 4.03%
09:22:09:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
09:22:09:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
09:22:09:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
09:22:15:WU00:FS00:Upload 11.03%
09:22:28:WU04:FS00:Upload 20.06%
09:22:49:WU04:FS00:Upload 21.07%
09:23:13:WU04:FS00:Upload 22.07%
09:23:35:WU04:FS00:Upload 23.07%
09:23:59:WU04:FS00:Upload 24.08%
09:24:20:WU04:FS00:Upload 25.08%
09:24:42:WU04:FS00:Upload 26.08%
09:25:08:WU04:FS00:Upload 27.09%
09:25:29:WU04:FS00:Upload 28.09%
09:25:33:WU05:FS00:0xa4:Completed 4550000 out of 5000000 steps  (91%)
09:25:40:WU00:FS00:Upload 12.03%
09:25:52:WU04:FS00:Upload 29.09%
09:26:16:WU04:FS00:Upload 30.10%
09:26:38:WU04:FS00:Upload 31.10%
09:26:59:WU04:FS00:Upload 32.10%
09:27:21:WU04:FS00:Upload 33.11%
09:27:43:WU04:FS00:Upload 34.11%
09:28:38:WU00:FS00:Upload 13.03%
09:28:56:WU04:FS00:Upload 35.11%
09:28:56:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
09:28:56:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
09:28:56:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
09:29:09:WU00:FS00:Upload 14.03%
09:29:09:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
09:30:43:WU02:FS00:Upload 1.01%
09:31:06:WU02:FS00:Upload 2.02%
09:31:31:WU02:FS00:Upload 3.02%
09:31:43:WU02:FS00:Upload 4.03%
09:31:58:WU02:FS00:Upload 6.05%
09:32:04:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
09:32:04:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
09:32:06:WU02:FS00:Upload 8.07%
09:32:22:WU04:FS00:Upload 1.00%
09:32:22:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
09:32:22:WU02:FS00:Upload 10.08%
09:32:42:WU00:FS00:Upload 3.01%
09:32:45:WU02:FS00:Upload 11.09%
09:33:06:WU02:FS00:Upload 12.10%
09:33:36:WU02:FS00:Upload 13.11%
09:33:42:WU00:FS00:Upload 4.01%
09:34:23:WU02:FS00:Upload 14.12%
09:34:35:WU02:FS00:Upload 15.12%
09:34:45:WU00:FS00:Upload 5.01%
09:34:55:WU02:FS00:Upload 16.13%
09:35:02:WU02:FS00:Upload 17.14%
09:35:19:WU00:FS00:Upload 6.01%
09:35:24:WU02:FS00:Upload 18.15%
09:35:40:WU00:FS00:Upload 7.02%
09:35:45:WU02:FS00:Upload 19.16%
09:36:03:WU00:FS00:Upload 8.02%
09:36:07:WU02:FS00:Upload 20.17%
09:36:22:WU00:FS00:Upload 9.02%
09:36:29:WU02:FS00:Upload 21.17%
09:36:46:WU00:FS00:Upload 10.02%
09:36:55:WU02:FS00:Upload 22.18%
09:37:10:WU02:FS00:Upload 23.19%
09:37:10:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
09:37:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
09:37:10:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
09:37:13:WU00:FS00:Upload 11.03%
09:37:31:WU00:FS00:Upload 12.03%
09:37:50:WU00:FS00:Upload 13.03%
09:38:13:WU00:FS00:Upload 14.03%
09:38:35:WU00:FS00:Upload 15.03%
09:39:01:WU00:FS00:Upload 16.04%
09:39:08:WU00:FS00:Upload 17.04%
09:39:26:WU00:FS00:Upload 18.04%
09:39:38:WU00:FS00:Upload 19.04%
09:39:50:WU00:FS00:Upload 20.05%
09:40:02:WU00:FS00:Upload 21.05%
09:40:14:WU00:FS00:Upload 22.05%
09:40:26:WU00:FS00:Upload 23.05%
09:40:38:WU00:FS00:Upload 24.06%
09:40:50:WU00:FS00:Upload 25.06%
09:41:02:WU00:FS00:Upload 26.06%
09:41:14:WU00:FS00:Upload 27.06%
09:41:26:WU00:FS00:Upload 28.07%
09:41:34:WU02:FS00:Upload 1.01%
09:41:34:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
09:41:38:WU00:FS00:Upload 29.07%
09:41:50:WU00:FS00:Upload 30.07%
09:42:02:WU00:FS00:Upload 31.07%
09:42:14:WU00:FS00:Upload 32.07%
09:42:26:WU00:FS00:Upload 33.08%
09:42:37:WU00:FS00:Upload 34.08%
09:42:58:WU00:FS00:Upload 35.08%
09:43:21:WU00:FS00:Upload 36.08%
09:43:43:WU00:FS00:Upload 37.09%
09:44:05:WU00:FS00:Upload 38.09%
09:44:26:WU00:FS00:Upload 39.09%
09:44:48:WU00:FS00:Upload 40.09%
09:45:10:WU00:FS00:Upload 41.10%
09:45:31:WU00:FS00:Upload 42.10%
09:45:54:WU00:FS00:Upload 43.10%
09:46:15:WU00:FS00:Upload 44.10%
09:46:37:WU00:FS00:Upload 45.10%
09:46:53:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
09:46:53:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
09:47:00:WU00:FS00:Upload 46.11%
09:47:06:WU00:FS00:Upload 47.11%
09:47:07:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
09:50:46:WU04:FS00:Upload 1.00%
09:51:44:WU05:FS00:0xa4:Completed 4600000 out of 5000000 steps  (92%)
09:54:40:WU04:FS00:Upload 2.01%
09:55:07:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
09:55:07:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
10:01:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
10:01:06:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
10:01:35:WU04:FS00:Upload 3.01%
10:01:54:WU04:FS00:Upload 4.01%
10:01:54:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
10:03:47:WU02:FS00:Upload 1.01%
10:04:06:WU02:FS00:Upload 2.02%
10:04:26:WU02:FS00:Upload 3.02%
10:04:46:WU02:FS00:Upload 4.03%
10:05:05:WU02:FS00:Upload 5.04%
10:05:25:WU02:FS00:Upload 6.05%
10:05:30:WU00:FS00:Upload 1.00%
10:05:30:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
10:05:44:WU02:FS00:Upload 7.06%
10:06:04:WU02:FS00:Upload 8.07%
10:06:23:WU02:FS00:Upload 9.07%
10:06:42:WU02:FS00:Upload 10.08%
10:07:00:WU02:FS00:Upload 11.09%
10:07:17:WU02:FS00:Upload 12.10%
10:07:35:WU02:FS00:Upload 13.11%
10:07:53:WU02:FS00:Upload 14.12%
10:08:10:WU02:FS00:Upload 15.12%
10:08:28:WU02:FS00:Upload 16.13%
10:08:45:WU02:FS00:Upload 17.14%
10:09:03:WU02:FS00:Upload 18.15%
10:09:21:WU02:FS00:Upload 19.16%
10:09:38:WU02:FS00:Upload 20.17%
10:09:58:WU02:FS00:Upload 21.17%
10:10:09:WU02:FS00:Upload 22.18%
10:10:09:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
10:15:55:WU05:FS00:0xa4:Completed 4650000 out of 5000000 steps  (93%)
10:15:55:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
10:15:55:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
10:19:20:WU04:FS00:Upload 1.00%
10:19:20:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
10:24:09:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
10:24:09:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
10:32:43:WU02:FS00:Upload 1.01%
10:33:00:WU02:FS00:Upload 2.02%
10:33:17:WU02:FS00:Upload 3.02%
10:33:34:WU02:FS00:Upload 4.03%
10:33:51:WU02:FS00:Upload 5.04%
10:34:08:WU02:FS00:Upload 6.05%
10:34:25:WU02:FS00:Upload 7.06%
10:34:42:WU02:FS00:Upload 8.07%
10:34:59:WU02:FS00:Upload 9.07%
10:35:22:WU02:FS00:Upload 10.08%
10:35:44:WU02:FS00:Upload 11.09%
10:36:06:WU02:FS00:Upload 12.10%
10:36:27:WU02:FS00:Upload 13.11%
10:36:49:WU02:FS00:Upload 14.12%
10:37:11:WU02:FS00:Upload 15.12%
10:37:33:WU02:FS00:Upload 16.13%
10:37:42:WU05:FS00:0xa4:Completed 4700000 out of 5000000 steps  (94%)
10:37:55:WU02:FS00:Upload 17.14%
10:38:16:WU02:FS00:Upload 18.15%
10:38:38:WU02:FS00:Upload 19.16%
10:39:00:WU02:FS00:Upload 20.17%
10:39:11:WU02:FS00:Upload 21.17%
10:39:11:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
10:48:05:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
10:48:05:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
10:56:39:WU00:FS00:Upload 1.00%
10:56:56:WU00:FS00:Upload 2.00%
10:57:13:WU00:FS00:Upload 3.01%
10:57:30:WU00:FS00:Upload 4.01%
10:57:47:WU00:FS00:Upload 5.01%
10:58:04:WU00:FS00:Upload 6.01%
10:58:21:WU00:FS00:Upload 7.02%
10:58:38:WU00:FS00:Upload 8.02%
10:59:31:WU05:FS00:0xa4:Completed 4750000 out of 5000000 steps  (95%)
11:01:38:WU00:FS00:Upload 9.02%
11:02:54:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
11:02:54:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
11:03:06:WU00:FS00:Upload 10.02%
11:03:06:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
11:11:08:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
11:11:08:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
11:11:26:WU04:FS00:Upload 1.00%
11:11:48:WU04:FS00:Upload 2.01%
11:12:10:WU04:FS00:Upload 3.01%
11:12:31:WU04:FS00:Upload 4.01%
11:12:53:WU04:FS00:Upload 5.02%
11:13:15:WU04:FS00:Upload 6.02%
11:13:36:WU04:FS00:Upload 7.02%
11:13:58:WU04:FS00:Upload 8.03%
11:14:19:WU04:FS00:Upload 9.03%
11:14:42:WU04:FS00:Upload 10.03%
11:15:03:WU04:FS00:Upload 11.04%
11:15:24:WU04:FS00:Upload 12.04%
11:15:45:WU04:FS00:Upload 13.04%
11:16:06:WU04:FS00:Upload 14.04%
11:16:27:WU04:FS00:Upload 15.05%
11:16:49:WU04:FS00:Upload 16.05%
11:17:10:WU04:FS00:Upload 17.05%
11:17:31:WU04:FS00:Upload 18.06%
11:17:32:WU02:FS00:Upload 1.01%
11:17:32:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
11:17:52:WU04:FS00:Upload 19.06%
11:17:56:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
11:21:22:WU05:FS00:0xa4:Completed 4800000 out of 5000000 steps  (96%)
11:43:09:WU05:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
12:04:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
12:04:06:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
12:04:57:WU05:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
12:12:40:WU00:FS00:Upload 1.00%
12:12:58:WU00:FS00:Upload 2.00%
12:13:15:WU00:FS00:Upload 3.01%
12:13:33:WU00:FS00:Upload 4.01%
12:13:50:WU00:FS00:Upload 5.01%
12:14:08:WU00:FS00:Upload 6.01%
12:14:25:WU00:FS00:Upload 7.02%
12:14:43:WU00:FS00:Upload 8.02%
12:15:00:WU00:FS00:Upload 9.02%
12:15:22:WU00:FS00:Upload 10.02%
12:15:44:WU00:FS00:Upload 11.03%
12:16:06:WU00:FS00:Upload 12.03%
12:16:27:WU00:FS00:Upload 13.03%
12:16:49:WU00:FS00:Upload 14.03%
12:17:11:WU00:FS00:Upload 15.03%
12:17:33:WU00:FS00:Upload 16.04%
12:17:54:WU00:FS00:Upload 17.04%
12:18:16:WU00:FS00:Upload 18.04%
12:18:38:WU00:FS00:Upload 19.04%
12:18:55:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
12:18:55:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
12:18:59:WU00:FS00:Upload 20.05%
12:19:07:WU00:FS00:Upload 21.05%
12:19:07:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
12:26:44:WU05:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
12:26:46:WU01:FS00:Assigned to work server 128.143.231.202
12:26:46:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 128.143.231.202
12:26:47:WU01:FS00:Downloading 3.67MiB
12:26:53:WU01:FS00:Download 69.80%
12:26:54:WU01:FS00:Download complete
12:26:55:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8575 run:1 clone:2 gen:460 core:0xa3 unit:0x00005fb10a3b1e59522885a89a386a4a
12:26:55:WU01:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/x86/Core_a3.fah
12:26:55:WU01:FS00:FahCore a3: Downloading 2.89MiB
12:27:01:WU01:FS00:FahCore a3: 36.79%
12:27:07:WU01:FS00:FahCore a3: 77.91%
12:27:09:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
12:27:09:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
12:27:10:WU01:FS00:FahCore a3: Download complete
12:27:10:WU01:FS00:Valid core signature
12:27:31:WU04:FS00:Upload 1.00%
12:27:53:WU04:FS00:Upload 2.01%
12:28:14:WU04:FS00:Upload 3.01%
12:28:36:WU04:FS00:Upload 4.01%
12:28:58:WU04:FS00:Upload 5.02%
12:29:19:WU04:FS00:Upload 6.02%
12:29:40:WU04:FS00:Upload 7.02%
12:30:02:WU04:FS00:Upload 8.03%
12:30:23:WU04:FS00:Upload 9.03%
12:31:58:WU02:FS00:Upload 1.01%
12:32:21:WU02:FS00:Upload 2.02%
12:34:12:WU04:FS00:Upload 10.03%
12:34:12:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
12:39:03:WU02:FS00:Upload 3.02%
12:39:24:WU02:FS00:Upload 4.03%
12:39:45:WU02:FS00:Upload 5.04%
12:40:06:WU02:FS00:Upload 6.05%
12:40:27:WU02:FS00:Upload 7.06%
12:40:48:WU02:FS00:Upload 8.07%
12:41:10:WU02:FS00:Upload 9.07%
12:42:33:WU02:FS00:Upload 10.08%
12:42:34:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
12:48:31:WU05:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
12:48:31:WU05:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:48:41:WU05:FS00:0xa4:
12:48:41:WU05:FS00:0xa4:Finished Work Unit:
12:48:41:WU05:FS00:0xa4:- Reading up to 1251624 from "05/wudata_01.trr": Read 1251624
12:48:41:WU05:FS00:0xa4:trr file hash check passed.
12:48:41:WU05:FS00:0xa4:- Reading up to 105220 from "05/wudata_01.xtc": Read 105220
12:48:41:WU05:FS00:0xa4:xtc file hash check passed.
12:48:41:WU05:FS00:0xa4:edr file hash check passed.
12:48:41:WU05:FS00:0xa4:logfile size: 86485
12:48:41:WU05:FS00:0xa4:Leaving Run
12:48:43:WU05:FS00:0xa4:- Writing 1515229 bytes of core data to disk...
12:48:43:WU05:FS00:0xa4:Done: 1514717 -> 1282901 (compressed to 84.6 percent)
12:48:44:WU05:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:48:44:WU05:FS00:Sending unit results: id:05 state:SEND error:NO_ERROR project:6369 run:71 clone:33 gen:58 core:0xa4 unit:0x000000460002894b53276998196482aa
12:48:44:WU05:FS00:Uploading 1.22MiB to 155.247.166.219
12:48:44:WU01:FS00:Starting
12:48:44:WU01:FS00:Core PID:2204
12:48:44:WU01:FS00:FahCore 0xa3 started
12:48:44:WU01:FS00:0xa3:
12:48:44:WU01:FS00:0xa3:*------------------------------*
12:48:44:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
12:48:44:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
12:48:44:WU01:FS00:0xa3:Preparing to commence simulation
12:48:44:WU01:FS00:0xa3:- Looking at optimizations...
12:48:44:WU01:FS00:0xa3:- Created dyn
12:48:44:WU01:FS00:0xa3:- Files status OK
12:48:45:WU01:FS00:0xa3:- Expanded 3849141 -> 4383200 (decompressed 113.8 percent)
12:48:45:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3849141 data_size=4383200, decompressed_data_size=4383200 diff=0
12:48:45:WU01:FS00:0xa3:- Digital signature verified
12:48:45:WU01:FS00:0xa3:Project: 8575 (Run 1, Clone 2, Gen 460)
12:48:45:WU01:FS00:0xa3:Assembly optimizations on if available.
12:48:45:WU01:FS00:0xa3:Entering M.D.
12:48:51:WU01:FS00:0xa3:Mapping NT from 2 to 2
12:48:53:WU01:FS00:0xa3:Completed 0 out of 500000 steps  (0%)
12:56:55:WU05:FS00:Upload 5.11%
12:57:05:WU05:FS00:Upload 10.21%
12:57:16:WU05:FS00:Upload 15.32%
12:57:26:WU05:FS00:Upload 20.43%
12:57:37:WU05:FS00:Upload 25.53%
12:57:47:WU05:FS00:Upload 30.64%
12:57:58:WU05:FS00:Upload 35.74%
12:58:08:WU05:FS00:Upload 40.85%
12:58:19:WU05:FS00:Upload 45.96%
12:58:31:WU05:FS00:Upload 51.06%
12:58:41:WU05:FS00:Upload 56.17%
12:58:52:WU05:FS00:Upload 61.28%
12:59:03:WU05:FS00:Upload 66.38%
12:59:13:WU05:FS00:Upload 71.49%
12:59:24:WU05:FS00:Upload 76.60%
12:59:34:WU05:FS00:Upload 81.70%
12:59:45:WU05:FS00:Upload 86.81%
12:59:56:WU05:FS00:Upload 91.91%
13:00:06:WU05:FS00:Upload 97.02%
13:00:13:WU05:FS00:Upload 100.00%
13:00:15:WU05:FS00:Upload complete
13:00:15:WU05:FS00:Server responded WORK_ACK (400)
13:00:15:WU05:FS00:Final credit estimate, 564.00 points
13:00:15:WU05:FS00:Cleaning up
13:57:49:WU01:FS00:0xa3:Completed 5000 out of 500000 steps  (1%)
14:07:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
14:07:06:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
******************************* Date: 2014-08-01 *******************************
14:15:40:WU00:FS00:Upload 1.00%
14:16:02:WU00:FS00:Upload 2.00%
14:16:24:WU00:FS00:Upload 3.01%
14:16:46:WU00:FS00:Upload 4.01%
14:17:08:WU00:FS00:Upload 5.01%
14:17:30:WU00:FS00:Upload 6.01%
14:17:52:WU00:FS00:Upload 7.02%
14:18:14:WU00:FS00:Upload 8.02%
14:18:35:WU00:FS00:Upload 9.02%
14:18:58:WU00:FS00:Upload 10.02%
14:19:19:WU00:FS00:Upload 11.03%
14:19:40:WU00:FS00:Upload 12.03%
14:20:01:WU00:FS00:Upload 13.03%
14:20:22:WU00:FS00:Upload 14.03%
14:20:43:WU00:FS00:Upload 15.03%
14:21:04:WU00:FS00:Upload 16.04%
14:21:25:WU00:FS00:Upload 17.04%
14:21:46:WU00:FS00:Upload 18.04%
14:21:55:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
14:21:55:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
14:22:07:WU00:FS00:Upload 19.04%
14:22:07:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
14:30:08:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
14:30:08:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
14:30:28:WU04:FS00:Upload 1.00%
14:30:57:WU04:FS00:Upload 2.01%
14:31:32:WU04:FS00:Upload 3.01%
14:31:57:WU04:FS00:Upload 4.01%
14:32:21:WU04:FS00:Upload 5.02%
14:32:46:WU04:FS00:Upload 6.02%
14:33:10:WU04:FS00:Upload 7.02%
14:33:35:WU04:FS00:Upload 8.03%
14:33:59:WU04:FS00:Upload 9.03%
14:34:22:WU04:FS00:Upload 10.03%
14:34:43:WU04:FS00:Upload 11.04%
14:35:04:WU04:FS00:Upload 12.04%
14:35:25:WU04:FS00:Upload 13.04%
14:35:47:WU04:FS00:Upload 14.04%
14:36:08:WU04:FS00:Upload 15.05%
14:36:29:WU04:FS00:Upload 16.05%
14:36:51:WU04:FS00:Upload 17.05%
14:36:56:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
14:38:44:WU02:FS00:Upload 1.01%
14:39:05:WU02:FS00:Upload 2.02%
14:39:26:WU02:FS00:Upload 3.02%
14:39:47:WU02:FS00:Upload 4.03%
14:40:09:WU02:FS00:Upload 5.04%
14:40:30:WU02:FS00:Upload 6.05%
14:40:51:WU02:FS00:Upload 7.06%
14:41:12:WU02:FS00:Upload 8.07%
14:41:32:WU02:FS00:Upload 9.07%
14:41:55:WU02:FS00:Upload 10.08%
14:42:16:WU02:FS00:Upload 11.09%
14:42:37:WU02:FS00:Upload 12.10%
14:42:58:WU02:FS00:Upload 13.11%
14:43:19:WU02:FS00:Upload 14.12%
14:43:40:WU02:FS00:Upload 15.12%
14:44:01:WU02:FS00:Upload 16.13%
14:44:22:WU02:FS00:Upload 17.14%
14:44:43:WU02:FS00:Upload 18.15%
14:45:04:WU02:FS00:Upload 19.16%
14:45:10:WU02:FS00:Upload 20.17%
15:09:05:WU01:FS00:0xa3:Completed 10000 out of 500000 steps  (2%)
16:36:18:WU01:FS00:0xa3:Completed 15000 out of 500000 steps  (3%)
17:26:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
17:26:06:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
17:34:40:WU00:FS00:Upload 1.00%
17:35:00:WU00:FS00:Upload 2.00%
17:35:20:WU00:FS00:Upload 3.01%
17:35:46:WU00:FS00:Upload 4.01%
17:36:06:WU00:FS00:Upload 5.01%
17:36:26:WU00:FS00:Upload 6.01%
17:36:46:WU00:FS00:Upload 7.02%
17:37:10:WU00:FS00:Upload 8.02%
17:37:29:WU00:FS00:Upload 9.02%
17:37:51:WU00:FS00:Upload 10.02%
17:38:11:WU00:FS00:Upload 11.03%
17:38:31:WU00:FS00:Upload 12.03%
17:38:58:WU00:FS00:Upload 13.03%
17:39:17:WU00:FS00:Upload 14.03%
17:39:38:WU00:FS00:Upload 15.03%
17:40:55:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
17:40:55:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
17:41:07:WU00:FS00:Upload 16.04%
17:41:08:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
17:49:09:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10179 run:453 clone:0 gen:4 core:0xa4 unit:0x00000005f0af421253a31d4ea8be62fd
17:49:09:WU02:FS00:Uploading 6.20MiB to 169.229.194.42
17:49:24:WU02:FS00:Upload 1.01%
17:49:31:WU04:FS00:Upload 1.00%
17:49:40:WU02:FS00:Upload 2.02%
17:49:53:WU04:FS00:Upload 2.01%
17:49:56:WU02:FS00:Upload 3.02%
17:50:11:WU02:FS00:Upload 4.03%
17:50:15:WU04:FS00:Upload 3.01%
17:50:27:WU02:FS00:Upload 5.04%
17:50:37:WU04:FS00:Upload 4.01%
17:50:43:WU02:FS00:Upload 6.05%
17:50:59:WU02:FS00:Upload 7.06%
17:51:01:WU04:FS00:Upload 5.02%
17:51:13:WU02:FS00:Upload 8.07%
17:51:21:WU04:FS00:Upload 6.02%
17:51:30:WU02:FS00:Upload 9.07%
17:51:40:WU04:FS00:Upload 7.02%
17:51:49:WU02:FS00:Upload 10.08%
17:51:59:WU04:FS00:Upload 8.03%
17:52:07:WU02:FS00:Upload 11.09%
17:52:18:WU04:FS00:Upload 9.03%
17:52:25:WU02:FS00:Upload 12.10%
17:52:40:WU04:FS00:Upload 10.03%
17:52:43:WU02:FS00:Upload 13.11%
17:53:00:WU04:FS00:Upload 11.04%
17:53:02:WU02:FS00:Upload 14.12%
17:53:19:WU04:FS00:Upload 12.04%
17:53:20:WU02:FS00:Upload 15.12%
17:53:39:WU04:FS00:Upload 13.04%
17:53:40:WU02:FS00:Upload 16.13%
17:53:58:WU02:FS00:Upload 17.14%
17:54:00:WU04:FS00:Upload 14.04%
17:54:17:WU02:FS00:Upload 18.15%
17:54:20:WU04:FS00:Upload 15.05%
17:54:52:WU04:FS00:Upload 16.05%
17:55:21:WU04:FS00:Upload 17.05%
17:55:43:WU04:FS00:Upload 18.06%
17:55:57:WU04:FS00:Upload 19.06%
17:55:57:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
17:57:19:WU02:FS00:Upload 19.16%
17:57:39:WU02:FS00:Upload 20.17%
17:57:59:WU02:FS00:Upload 21.17%
17:58:20:WU02:FS00:Upload 22.18%
17:58:40:WU02:FS00:Upload 23.19%
17:59:00:WU02:FS00:Upload 24.20%
17:59:21:WU02:FS00:Upload 25.21%
17:59:42:WU02:FS00:Upload 26.22%
18:00:02:WU02:FS00:Upload 27.22%
18:00:22:WU02:FS00:Upload 28.23%
18:00:43:WU02:FS00:Upload 29.24%
18:01:03:WU02:FS00:Upload 30.25%
18:01:23:WU02:FS00:Upload 31.26%
18:01:42:WU02:FS00:Upload 32.27%
18:01:58:WU02:FS00:Upload 33.27%
18:02:14:WU02:FS00:Upload 34.28%
18:02:31:WU02:FS00:Upload 35.29%
18:02:47:WU02:FS00:Upload 36.30%
18:03:04:WU02:FS00:Upload 37.31%
18:03:21:WU02:FS00:Upload 38.31%
18:03:37:WU02:FS00:Upload 39.32%
18:03:55:WU02:FS00:Upload 40.33%
18:04:10:WU02:FS00:Upload 41.34%
18:04:10:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
18:42:53:WU01:FS00:0xa3:Completed 20000 out of 500000 steps  (4%)
19:51:27:WU01:FS00:0xa3:Completed 25000 out of 500000 steps  (5%)
20:27:24:WARNING:WU02:FS00:Past final deadline 2014-08-01T20:27:23Z, dumping
20:27:24:WU02:FS00:Cleaning up
21:00:11:WU01:FS00:0xa3:Completed 30000 out of 500000 steps  (6%)
22:08:46:WU01:FS00:0xa3:Completed 35000 out of 500000 steps  (7%)
22:48:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
22:48:06:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
22:56:40:WU00:FS00:Upload 1.00%
22:56:57:WU00:FS00:Upload 2.00%
22:57:15:WU00:FS00:Upload 3.01%
22:57:32:WU00:FS00:Upload 4.01%
22:57:50:WU00:FS00:Upload 5.01%
22:58:08:WU00:FS00:Upload 6.01%
22:58:25:WU00:FS00:Upload 7.02%
22:58:43:WU00:FS00:Upload 8.02%
22:59:00:WU00:FS00:Upload 9.02%
22:59:23:WU00:FS00:Upload 10.02%
22:59:44:WU00:FS00:Upload 11.03%
23:00:05:WU00:FS00:Upload 12.03%
23:00:26:WU00:FS00:Upload 13.03%
23:00:47:WU00:FS00:Upload 14.03%
23:01:09:WU00:FS00:Upload 15.03%
23:01:30:WU00:FS00:Upload 16.04%
23:01:51:WU00:FS00:Upload 17.04%
23:02:13:WU00:FS00:Upload 18.04%
23:02:34:WU00:FS00:Upload 19.04%
23:02:55:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
23:02:55:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
23:02:56:WU00:FS00:Upload 20.05%
23:03:07:WU00:FS00:Upload 21.05%
23:03:07:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
23:11:31:WU04:FS00:Upload 1.00%
23:11:53:WU04:FS00:Upload 2.01%
23:12:14:WU04:FS00:Upload 3.01%
23:12:35:WU04:FS00:Upload 4.01%
23:12:56:WU04:FS00:Upload 5.02%
23:13:17:WU04:FS00:Upload 6.02%
23:13:38:WU04:FS00:Upload 7.02%
23:13:59:WU04:FS00:Upload 8.03%
23:14:20:WU04:FS00:Upload 9.03%
23:14:42:WU04:FS00:Upload 10.03%
23:15:03:WU04:FS00:Upload 11.04%
23:15:24:WU04:FS00:Upload 12.04%
23:15:45:WU04:FS00:Upload 13.04%
23:16:06:WU04:FS00:Upload 14.04%
23:16:27:WU04:FS00:Upload 15.05%
23:16:48:WU04:FS00:Upload 16.05%
23:17:09:WU04:FS00:Upload 17.05%
23:17:24:WU01:FS00:0xa3:Completed 40000 out of 500000 steps  (8%)
23:17:30:WU04:FS00:Upload 18.06%
23:17:52:WU04:FS00:Upload 19.06%
23:17:57:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
00:26:20:WU01:FS00:0xa3:Completed 45000 out of 500000 steps  (9%)
01:35:26:WU01:FS00:0xa3:Completed 50000 out of 500000 steps  (10%)
******************************* Date: 2014-08-02 *******************************
02:48:09:WU01:FS00:0xa3:Completed 55000 out of 500000 steps  (11%)
03:56:44:WU01:FS00:0xa3:Completed 60000 out of 500000 steps  (12%)
04:48:06:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10180 run:499 clone:1 gen:22 core:0xa4 unit:0x00000017f0af421253a32053fe5123fc
04:48:06:WU00:FS00:Uploading 6.24MiB to 169.229.194.42
04:56:40:WU00:FS00:Upload 1.00%
04:56:58:WU00:FS00:Upload 2.00%
04:57:15:WU00:FS00:Upload 3.01%
04:57:33:WU00:FS00:Upload 4.01%
04:57:50:WU00:FS00:Upload 5.01%
04:58:08:WU00:FS00:Upload 6.01%
04:58:25:WU00:FS00:Upload 7.02%
04:58:43:WU00:FS00:Upload 8.02%
04:59:00:WU00:FS00:Upload 9.02%
04:59:23:WU00:FS00:Upload 10.02%
04:59:45:WU00:FS00:Upload 11.03%
05:00:06:WU00:FS00:Upload 12.03%
05:00:27:WU00:FS00:Upload 13.03%
05:00:49:WU00:FS00:Upload 14.03%
05:01:10:WU00:FS00:Upload 15.03%
05:01:32:WU00:FS00:Upload 16.04%
05:01:53:WU00:FS00:Upload 17.04%
05:02:15:WU00:FS00:Upload 18.04%
05:02:37:WU00:FS00:Upload 19.04%
05:02:55:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:10180 run:63 clone:2 gen:20 core:0xa4 unit:0x00000016f0af421253a31de55a411f16
05:02:55:WU04:FS00:Uploading 6.23MiB to 169.229.194.42
05:02:58:WU00:FS00:Upload 20.05%
05:03:08:WU00:FS00:Upload 21.05%
05:03:08:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:05:30:WU01:FS00:0xa3:Completed 65000 out of 500000 steps  (13%)
05:11:30:WU04:FS00:Upload 1.00%
05:11:52:WU04:FS00:Upload 2.01%
05:12:13:WU04:FS00:Upload 3.01%
05:12:34:WU04:FS00:Upload 4.01%
05:12:55:WU04:FS00:Upload 5.02%
05:13:16:WU04:FS00:Upload 6.02%
05:13:37:WU04:FS00:Upload 7.02%
05:13:58:WU04:FS00:Upload 8.03%
05:14:18:WU04:FS00:Upload 9.03%
05:14:41:WU04:FS00:Upload 10.03%
05:15:02:WU04:FS00:Upload 11.04%
05:15:23:WU04:FS00:Upload 12.04%
05:15:44:WU04:FS00:Upload 13.04%
05:16:05:WU04:FS00:Upload 14.04%
05:16:26:WU04:FS00:Upload 15.05%
05:16:47:WU04:FS00:Upload 16.05%
05:17:12:WU04:FS00:Upload 17.05%
05:18:49:WU04:FS00:Upload 18.06%
05:18:49:WARNING:WU04:FS00:Exception: Failed to send results to work server: Transfer failed
06:14:09:WU01:FS00:0xa3:Completed 70000 out of 500000 steps  (14%)
07:22:48:WU01:FS00:0xa3:Completed 75000 out of 500000 steps  (15%)
08:31:28:WU01:FS00:0xa3:Completed 80000 out of 500000 steps  (16%).
Mod edit: added code tags
Rick9399
Post by Rick9399 »
One of them just disappeared. :(
I don't think retrying solves anything as my computer is... Bad, and probably wouldn't finish them in time. Also my GPU never went any further than 0.00%, I've seen others have this problem, but couldn't find a solution. Do you know any?
davidcoton
Post by davidcoton »
Have you tried rebooting the router? It sometimes works...
Rick9399
Post by Rick9399 »
No I haven't, I'll try that soon. Thanks! :)
The log says you have three WUs to upload, WU00, WU02, and WU04. Each one is 6.2MiB. One of the problems with V7 is that it attempts to send them all simultaneously, interleaving the packets ... and they're all going to the same server (which probably isn't important). Given the speed of your internet connection, how long do you expect it to take to upload almost 19 MB? Do you have any other bandwidth hogs running (e.g. a torrent) that could be suspended temporarily?
What is your rated internet upload speed?
There's an enhancement request to modify the upload logic of V7, but it doesn't look like the Pande Group will get around to making that change. Meanwhile, the servers to have a fixed timeout which aborts connections that take longer than X minutes to upload. You're probably being bit by that limitation, though that's not entirely clear.
If that's true, there's no easy way to manually serialize the WUs, nor is it really clear that any one of the WUs would upload at your connection speed within the server timeout.
Let me discuss it with the appropriate members of the Pande Group and get a good recommendation.
Rick9399
Post by Rick9399 »
bruce wrote:The log says you have three WUs to upload, WU00, WU02, and WU04. Each one is 6.2MiB. One of the problems with V7 is that it attempts to send them all simultaneously, interleaving the packets ... and they're all going to the same server (which probably isn't important). Given the speed of your internet connection, how long do you expect it to take to upload almost 19 MB? Do you have any other bandwidth hogs running (e.g. a torrent) that could be suspended temporarily?
Sorry for the late reaction. But after the first two disappeared, I paused my current WU so it could focus on sending the last one, without success. Also I took a break from using f@h, again. This time the break only lasted a week. But when I downloaded it again today, it said I have almost 4 million points on my browser, while I only had about 5k. And when I click on my name: http://fah-web.stanford.edu/cgi-bin/mai ... e=Rick9399, it sais I have 5k point like it should be. Why does it do that?
Also, is there any way to see my PPD if I use chrome to fold?
