geforce gtx 780ti folding extremely slow
I've searched around the forum for answers, but didnt actually get any recent or even descent answers.
Right now i'm running Folding at Full.
Sysinfo:
CPU: Intel Corei7 3930K (using 10 "cores" for folding)
GPU1: MSI Geforce GTX 780 TI Gaming
GPU2: ASUS Geforce GT 630 (PhysX)
GTX 780TI Score 1679 ???
GT 630 Score over 200000
So my question is, WHY does a tiny little card outperform a very powerfull one?
Please help!
Sysinfo:
Please help!
Machine #2:
Machine 3:
Re: geforce gtx 780ti folding extremely slow
The obvious is that the automatic detection has failed and switched the cards. You can manually correct it by assigning opencl-index values as extra slot options to the two cards. (-1) means automatic, while 0 is the first device and 1 is the second. Of course you do not know which card is the first and which is the second so if you do not succeed the first time switch the values between the cards.
I recently had the same thing happen with a GK106 [GTX 650 Ti] and a GM107 [GTX 750 Ti]. The "slow" card was faster than the "fast" card. I didn't see any point in convincing FAH to interchange the names to make it look right, since they were both getting the same assignments.
well obviously :p
I was actually thinking it could be that, when i tried playing a game an hour ago and it lagged like ****.
But still, thanks for reply
And i must say it's an Honor to be answered by both a Site-Mod AND Admin
Machine #2:
Machine 3:
It is best to pause folding before gaming and then when finished unpause.
With 2 GPUs, only pause the GPU used for gaming, and let the other keep folding.
Hi Folks,
I have the same problem here, i only get 1679 PPD (Core17) with a single 780Ti.
Spec:
CPU: 4790K
RAM: 32 Gig
GPU: 780 Ti
OS: Win 8.1
any recomendations what I can do?
PPDGuy
Spec:
CPU: 4790K
RAM: 32 Gig
GPU: 780 Ti
OS: Win 8.1
PPDGuy
Machine #2:
Machine 3:
Without a log we have little to go on other than guessing. Please copy & paste the folding log here, including the system and config portions (Click refresh first). The log will allow us to see what is actually going on.
There are lots of potential causes:
- Make sure you have a full CPU core dedicated to the 780Ti.
- Make sure you are giving it enough time to make an accurate estimate. Generally 3%-5% is the minimum before it gets reasonably accurate.
- Check the Windows system event logs to make sure you haven't gotten a video card reset that forced your clock rates very low.
- Check the folding log and compare it to the client to make sure that it matches the number of frames done.
- Run the client on full 24x7 (no running on idle) for you won't get the maximum PPD that your card is capable of if it is not running all the time
Thanks for the quick answer!P5-133XL wrote:Without a log we have little to go on other than guessing. Please copy & paste the folding log here, including the system and config portions (Click refresh first). The log will allow us to see what is actually going on.
- by adding a CPU slot my PPD increased - thanks - Make sure you are giving it enough time to make an accurate estimate. Generally 3%-5% is the minimum before it gets reasonably accurate.
- waited till 15% - Check the Windows system event logs to make sure you haven't gotten a video card reset that forced your clock rates very low.
- GPU is under perfect load (90% in GPU-Z) - Check the folding log and compare it to the client to make sure that it matches the number of frames done.
- matches - Run the client on full 24x7 (no running on idle) for you won't get the maximum PPD that your card is capable of if it is not running all the time [b] - is there a bonus for 24/7?[/b]
PPDGuy
Yes, there is a bonus. The faster the WU is returned, the higher the bonus. And the points curve is exponential, not linear. So the points will change significantly if running part time vs. full time.
good to know - thanks for your help7im wrote:Yes, there is a bonus. The faster the WU is returned, the higher the bonus. And the points curve is exponential, not linear. So the points will change significantly if running part time vs. full time.
PPDGuy
Machine #2:
Machine 3:
Adding a CPU slot, may increase your PPD (from the CPU also folding) but not to the GPU. What I was saying was that if the CPU folds or something else is using 100% of the CPU, you may need to manually decrease the number of CPU cores folding so that the GPU has at least full CPU core all to itself. If an Nvidia GPU does not get a full CPU core for its own exclusive use you will starve it and it will slow down and not use 100% of the GPU. It is generally good to have a little bit of CPU idle left.
The 90% GPU load is actually a little low. My experience is that it should be 95%-99% except for the very start of the WU, for several minutes, and periodic dropouts, every couple of frames, of a few seconds to 0% while it writes checkpoints. Are you sure that the GPU core isn't getting at least 100% of one CPU core?
Absolutely, there is a bonus for folding 24x7. It is called the quick return bonus (QRB) and it will generally produce far more points than the base point values, for your GPU, if you return the WU's as fast as they can i.e. run continuously and not part-time. Points are calculated based upon the download time, so if you shutdown in the middle the clock continues to run while there is no folding occurring thus your PPD is dropping when you are not folding and because of the QRB it is not a linear drop but an exponential one. If you need to shutdown, ideally what you do is click the finish button and wait to allow the WU to finish (Which can be a very long time) and send without getting a new one whereupon you can shut down without harming PPD.
What I did in the first place was to delete the CPU slot, because I didn't want the CPU to fold. This is where I got around 1700 estimated PPD with the GPU. Since I added the CPU slot again the estimated PPD is around 70k. Im sure there was enough CPU time for F@H (no other extensive processes runing).
Well, now it seems to work (on a Core 15 project 99% GPU load - with decreased CPU threads) - thanks to your information and help.
And I like the idea of the QRB so it will be 24x7 for me.... at least for a while
- Hardware configuration: Full Time:
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop - Location: Near Oxford, United Kingdom
No QRB on Core15 projects unfortunately, so you'll need to wait for a Core17 to see what it can really do for your PPD.PPDGuy wrote: Well, now it seems to work (on a Core 15 project 99% GPU load - with decreased CPU threads) - thanks to your information and help.
My (somewhat overclocked) 780 Ti returns 200k-240k PPD on Core17's.
For QRB you need to get a passkey and then return at least 10 WUs with 70% (from memory) success rate.
It is still helpful to post your log (including the system and config sections), so people here can see if there are any other reasons for low ppd.
I agree with billford about what a 780Ti can get
Edit by Mod: Correction. Your total successful returns of bonus-eligible WUs must be >80%
