Hello, I started folding today with my i5 4690k + nvidia gtx 770.
I get about 16k PPD with my CPU, yet my GPU is only getting 1679PPD.
Why is it running horribly? I thought the GPU should run 20-30x faster than my CPU.
I'm running most recent video drivers.
Folding problem with GPU
ChristianVirtual
Re: Folding problem with GPU
Welcome shd0w2
Could you please share the log file and config with us ? Each GPU need one CPU core for the driver. Might be your CPU slot require too many cores.
Also have a look at http://folding.stanford.edu/home/faq/faq-passkey/ and make sure to apply for a passkey.
Keep in mind that for the first frames the PPD is also not precise. After 5 frames it gets better
*********************** Log Started 2014-07-27T20:24:25Z ***********************
20:24:25:************************* Folding@home Client *************************
20:24:25: Website: http://folding.stanford.edu/
20:24:25: Copyright: (c) 2009-2014 Stanford University
20:24:25: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:24:25: Args: --open-web-control
20:24:25: Config: <none>
20:24:25:******************************** Build ********************************
20:24:25: Version: 7.4.4
20:24:25: Date: Mar 4 2014
20:24:25: Time: 20:26:54
20:24:25: SVN Rev: 4130
20:24:25: Branch: fah/trunk/client
20:24:25: Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:24:25: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:24:25: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:24:25: Platform: win32 XP
20:24:25: Bits: 32
20:24:25: Mode: Release
20:24:25:******************************* System ********************************
20:24:25: CPU: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
20:24:25: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
20:24:25: CPUs: 4
20:24:25: Memory: 15.94GiB
20:24:25: Free Memory: 9.12GiB
20:24:25: Threads: WINDOWS_THREADS
20:24:25: OS Version: 6.1
20:24:25: Has Battery: false
20:24:25: On Battery: false
20:24:25: UTC Offset: -6
20:24:25: PID: 8172
20:24:25: CWD: C:/Users/Cyrus/AppData/Roaming/FAHClient
20:24:25: OS: Windows 7 Professional
20:24:25: OS Arch: AMD64
20:24:25: GPUs: 1
20:24:25: GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
20:24:25: CUDA: 3.0
20:24:25: CUDA Driver: 6000
20:24:25:Win32 Service: false
20:24:25:***********************************************************************
20:24:25:<config>
20:24:25: <!-- Folding Slots -->
20:24:25:</config>
20:24:25:Connecting to assign-GPU.stanford.edu:80
20:24:25:Updated GPUs.txt
20:24:25:Read GPUs.txt
20:24:25:Trying to access database...
20:24:26:Successfully acquired database lock
20:24:26:Enabled folding slot 00: PAUSED cpu:2 (not configured)
20:24:26:Enabled folding slot 01: PAUSED gpu:0:GK104 [GeForce GTX 770] (not configured)
20:24:28:12:127.0.0.1:New Web connection
20:25:27:Saving configuration to config.xml
20:25:27:<config>
20:25:27: <!-- Folding Slots -->
20:25:27: <slot id='0' type='CPU'/>
20:25:27: <slot id='1' type='GPU'/>
20:25:27:</config>
20:25:27:Set client configured
20:25:27:WU00:FS00:Connecting to 171.67.108.200:8080
20:25:27:WU01:FS01:Connecting to 171.67.108.200:8080
20:25:27:WU01:FS01:Connecting to 171.67.108.201:80
20:25:28:WU00:FS00:Assigned to work server 128.143.231.202
20:25:28:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.143.231.202
20:25:28:WU00:FS00:Connecting to 128.143.231.202:8080
20:25:28:WU01:FS01:Assigned to work server 140.163.4.233
20:25:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GK104 [GeForce GTX 770] from 140.163.4.233
20:25:28:WU01:FS01:Connecting to 140.163.4.233:8080
20:25:28:WU01:FS01:Downloading 4.31MiB
20:25:29:WU00:FS00:Downloading 3.64MiB
20:25:30:WU01:FS01:Download complete
20:25:30:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10468 run:0 clone:202 gen:16 core:0x17 unit:0x0000001d538b3db9538cafab84d18080
20:25:30:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah
20:25:30:WU01:FS01:Connecting to web.stanford.edu:80
20:25:30:WU01:FS01:FahCore 17: Downloading 2.55MiB
20:25:30:WU00:FS00:Download complete
20:25:30:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6099 run:4 clone:90 gen:491 core:0xa3 unit:0x00000a980a3b1e594e91e053dcb86097
20:25:30:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah
20:25:30:WU00:FS00:Connecting to web.stanford.edu:80
20:25:31:WU00:FS00:FahCore a3: Downloading 2.89MiB
20:25:36:WU01:FS01:FahCore 17: 100.00%
20:25:36:WU01:FS01:FahCore 17: Download complete
20:25:36:WU01:FS01:Valid core signature
20:25:36:WU01:FS01:Unpacked 8.60MiB to cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe
20:25:36:WU01:FS01:Starting
20:25:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:25:36:WU01:FS01:Started FahCore on PID 7328
20:25:36:WU01:FS01:Core PID:1936
20:25:36:WU01:FS01:FahCore 0x17 started
20:25:36:WU01:FS01:0x17:*********************** Log Started 2014-07-27T20:25:36Z ***********************
20:25:36:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
20:25:36:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
20:25:36:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:25:36:WU01:FS01:0x17:Machine: 1
20:25:36:WU01:FS01:0x17:Reading tar file state.xml
20:25:37:WU00:FS00:FahCore a3: 84.41%
20:25:37:WU01:FS01:0x17:Reading tar file system.xml
20:25:37:WU01:FS01:0x17:Reading tar file integrator.xml
20:25:37:WU01:FS01:0x17:Reading tar file core.xml
20:25:37:WU01:FS01:0x17:Digital signatures verified
20:25:37:WU01:FS01:0x17:Folding@home GPU core17
20:25:37:WU01:FS01:0x17:Version 0.0.52
20:25:37:WU00:FS00:FahCore a3: Download complete
20:25:38:WU00:FS00:Valid core signature
20:25:38:WU00:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe
20:25:38:WU00:FS00:Starting
20:25:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 2
20:25:38:WU00:FS00:Started FahCore on PID 7452
20:25:38:WU00:FS00:Core PID:7836
20:25:38:WU00:FS00:FahCore 0xa3 started
20:25:38:WU00:FS00:0xa3:
20:25:38:WU00:FS00:0xa3:*------------------------------*
20:25:38:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:25:38:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:25:38:WU00:FS00:0xa3:Preparing to commence simulation
20:25:38:WU00:FS00:0xa3:- Looking at optimizations...
20:25:38:WU00:FS00:0xa3:- Created dyn
20:25:38:WU00:FS00:0xa3:- Files status OK
20:25:38:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
20:25:38:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
20:25:38:WU00:FS00:0xa3:- Digital signature verified
20:25:38:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
20:25:38:WU00:FS00:0xa3:Assembly optimizations on if available.
20:25:38:WU00:FS00:0xa3:Entering M.D.
20:25:44:WU00:FS00:0xa3:Mapping NT from 2 to 2
20:25:45:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
20:27:32:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
20:27:32:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:30:32:Saving configuration to config.xml
20:30:32:<config>
20:30:32: <!-- User Information -->
20:30:32: <passkey v='********************************'/>
20:30:32: <user v='shd0w2'/>
20:30:32:
20:30:32: <!-- Folding Slots -->
20:30:32: <slot id='0' type='CPU'/>
20:30:32: <slot id='1' type='GPU'/>
20:30:32:</config>
20:30:34:FS00:Paused
20:30:34:FS01:Paused
20:30:34:FS00:Shutting core down
20:30:34:FS01:Shutting core down
20:30:35:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 1936
20:30:35:WU01:FS01:0x17:Exiting, please wait. . .
20:30:35:WU01:FS01:0x17:Folding@home Core Shutdown: INTERRUPTED
20:30:35:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:30:39:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:31:33:Saving configuration to config.xml
20:31:33:<config>
20:31:33: <!-- Slot Control -->
20:31:33: <power v='FULL'/>
20:31:33:
20:31:33: <!-- User Information -->
20:31:33: <passkey v='********************************'/>
20:31:33: <user v='shd0w2'/>
20:31:33:
20:31:33: <!-- Folding Slots -->
20:31:33: <slot id='0' type='CPU'>
20:31:33: <paused v='true'/>
20:31:33: </slot>
20:31:33: <slot id='1' type='GPU'>
20:31:33: </slot>
20:31:33:</config>
20:33:35:Saving configuration to config.xml
20:33:35:<config>
20:33:35: <!-- Slot Control -->
20:33:35: <power v='FULL'/>
20:33:35:
20:33:35: <!-- User Information -->
20:33:35: <passkey v='********************************'/>
20:33:35: <team v='223518'/>
20:33:35: <user v='shd0w2'/>
20:33:35:
20:33:35: <!-- Folding Slots -->
20:33:35: <slot id='0' type='CPU'>
20:33:35: <paused v='true'/>
20:33:35: </slot>
20:33:35: <slot id='1' type='GPU'>
20:33:35: </slot>
20:33:35:</config>
20:33:38:FS00:Unpaused
20:33:38:FS01:Unpaused
20:33:39:WU00:FS00:Starting
20:33:39:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
20:33:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
20:33:39:WU00:FS00:Started FahCore on PID 7732
20:33:39:WU00:FS00:Core PID:7376
20:33:39:WU00:FS00:FahCore 0xa3 started
20:33:39:WU01:FS01:Starting
20:33:39:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:33:39:WU01:FS01:Started FahCore on PID 1048
20:33:39:WU01:FS01:Core PID:3496
20:33:39:WU01:FS01:FahCore 0x17 started
20:33:39:WU00:FS00:0xa3:
20:33:39:WU00:FS00:0xa3:*------------------------------*
20:33:39:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:33:39:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:33:39:WU00:FS00:0xa3:Preparing to commence simulation
20:33:39:WU00:FS00:0xa3:- Looking at optimizations...
20:33:39:WU00:FS00:0xa3:- Files status OK
20:33:39:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
20:33:39:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
20:33:39:WU00:FS00:0xa3:- Digital signature verified
20:33:39:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
20:33:39:WU00:FS00:0xa3:Assembly optimizations on if available.
20:33:39:WU00:FS00:0xa3:Entering M.D.
20:33:39:WU01:FS01:0x17:*********************** Log Started 2014-07-27T20:33:39Z ***********************
20:33:39:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
20:33:39:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
20:33:39:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:33:39:WU01:FS01:0x17:Machine: 1
20:33:39:WU01:FS01:0x17:Digital signatures verified
20:33:39:WU01:FS01:0x17:Folding@home GPU core17
20:33:39:WU01:FS01:0x17:Version 0.0.52
20:33:45:WU00:FS00:0xa3:Mapping NT from 3 to 3
20:33:46:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
20:34:09:FS00:Shutting core down
20:34:09:FS01:Shutting core down
20:34:10:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 3496
20:34:10:WU01:FS01:0x17:Exiting, please wait. . .
20:34:14:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:34:36:Saving configuration to config.xml
20:34:36:<config>
20:34:36: <!-- Slot Control -->
20:34:36: <power v='FULL'/>
20:34:36:
20:34:36: <!-- User Information -->
20:34:36: <passkey v='********************************'/>
20:34:36: <team v='223518'/>
20:34:36: <user v='shd0w2'/>
20:34:36:
20:34:36: <!-- Folding Slots -->
20:34:36: <slot id='0' type='CPU'/>
20:34:36: <slot id='1' type='GPU'/>
20:34:36:</config>
20:34:39:WU00:FS00:Starting
20:34:39:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
20:34:39:WU00:FS00:Started FahCore on PID 5000
20:34:39:WU00:FS00:Core PID:5900
20:34:39:WU00:FS00:FahCore 0xa3 started
20:34:39:WU00:FS00:0xa3:
20:34:39:WU00:FS00:0xa3:*------------------------------*
20:34:39:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:34:39:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:34:39:WU00:FS00:0xa3:Preparing to commence simulation
20:34:39:WU00:FS00:0xa3:- Looking at optimizations...
20:34:39:WU00:FS00:0xa3:- Files status OK
20:34:39:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
20:34:39:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
20:34:39:WU00:FS00:0xa3:- Digital signature verified
20:34:39:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
20:34:39:WU00:FS00:0xa3:Assembly optimizations on if available.
20:34:39:WU00:FS00:0xa3:Entering M.D.
20:34:45:WU00:FS00:0xa3:Mapping NT from 3 to 3
20:34:47:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
20:35:25:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
20:35:25:WU01:FS01:0x17:Lost lifeline PID 1048, exiting
20:35:25:WU01:FS01:0x17:ERROR:103: Lost client lifeline
20:35:25:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
20:35:26:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:35:26:WU01:FS01:Starting
20:35:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:35:26:WU01:FS01:Started FahCore on PID 7568
20:35:26:WU01:FS01:Core PID:3732
20:35:26:WU01:FS01:FahCore 0x17 started
20:35:26:WU01:FS01:0x17:*********************** Log Started 2014-07-27T20:35:26Z ***********************
20:35:26:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
20:35:26:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
20:35:26:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:35:26:WU01:FS01:0x17:Machine: 1
20:35:26:WU01:FS01:0x17:Digital signatures verified
20:35:26:WU01:FS01:0x17:Folding@home GPU core17
20:35:26:WU01:FS01:0x17:Version 0.0.52
20:37:43:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
20:37:43:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:38:21:FS00:Paused
20:38:21:FS01:Paused
20:38:22:FS00:Shutting core down
20:38:22:FS01:Shutting core down
20:38:22:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 3732
20:38:22:WU01:FS01:0x17:Exiting, please wait. . .
20:38:22:WU01:FS01:0x17:Lost lifeline PID 7568, exiting
20:38:22:WU01:FS01:0x17:ERROR:103: Lost client lifeline
20:38:22:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
20:38:23:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:38:27:WU00:FS00:0xa3:Client no longer detected. Shutting down core
20:38:27:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
20:38:27:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:38:40:Saving configuration to config.xml
20:38:40:<config>
20:38:40: <!-- Slot Control -->
20:38:40: <power v='FULL'/>
20:38:40:
20:38:40: <!-- User Information -->
20:38:40: <passkey v='********************************'/>
20:38:40: <team v='223518'/>
20:38:40: <user v='shd0w2'/>
20:38:40:
20:38:40: <!-- Folding Slots -->
20:38:40: <slot id='0' type='CPU'>
20:38:40: <paused v='true'/>
20:38:40: </slot>
20:38:40: <slot id='1' type='GPU'>
20:38:40: </slot>
20:38:40:</config>
20:43:03:FS00:Unpaused
20:43:03:FS01:Unpaused
20:43:04:WU00:FS00:Starting
20:43:04:WARNING:WU00:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
20:43:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 2
20:43:04:WU00:FS00:Started FahCore on PID 2912
20:43:04:WU00:FS00:Core PID:7408
20:43:04:WU00:FS00:FahCore 0xa3 started
20:43:04:WU00:FS00:0xa3:
20:43:04:WU00:FS00:0xa3:*------------------------------*
20:43:04:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:43:04:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:43:04:WU00:FS00:0xa3:Preparing to commence simulation
20:43:04:WU00:FS00:0xa3:- Looking at optimizations...
20:43:04:WU00:FS00:0xa3:- Files status OK
20:43:04:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
20:43:04:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
20:43:04:WU00:FS00:0xa3:- Digital signature verified
20:43:04:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
20:43:04:WU00:FS00:0xa3:Assembly optimizations on if available.
20:43:04:WU00:FS00:0xa3:Entering M.D.
20:43:10:WU00:FS00:0xa3:Mapping NT from 2 to 2
20:43:11:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
20:43:45:Saving configuration to config.xml
20:43:45:<config>
20:43:45: <!-- Slot Control -->
20:43:45: <power v='LIGHT'/>
20:43:45:
20:43:45: <!-- User Information -->
20:43:45: <passkey v='********************************'/>
20:43:45: <team v='223518'/>
20:43:45: <user v='shd0w2'/>
20:43:45:
20:43:45: <!-- Folding Slots -->
20:43:45: <slot id='0' type='CPU'/>
20:43:45: <slot id='1' type='GPU'/>
20:43:45:</config>
20:47:31:FS00:Shutting core down
20:47:31:WU01:FS01:Starting
20:47:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:47:31:WU01:FS01:Started FahCore on PID 7608
20:47:31:WU01:FS01:Core PID:3860
20:47:31:WU01:FS01:FahCore 0x17 started
20:47:32:WU01:FS01:0x17:*********************** Log Started 2014-07-27T20:47:31Z ***********************
20:47:32:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
20:47:32:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
20:47:32:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:47:32:WU01:FS01:0x17:Machine: 1
20:47:32:WU01:FS01:0x17:Digital signatures verified
20:47:32:WU01:FS01:0x17:Folding@home GPU core17
20:47:32:WU01:FS01:0x17:Version 0.0.52
20:47:34:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:47:35:WU00:FS00:Starting
20:47:35:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
20:47:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
20:47:35:WU00:FS00:Started FahCore on PID 7284
20:47:35:WU00:FS00:Core PID:3252
20:47:35:WU00:FS00:FahCore 0xa3 started
20:47:35:WU00:FS00:0xa3:
20:47:35:WU00:FS00:0xa3:*------------------------------*
20:47:35:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:47:35:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:47:35:WU00:FS00:0xa3:Preparing to commence simulation
20:47:35:WU00:FS00:0xa3:- Looking at optimizations...
20:47:35:WU00:FS00:0xa3:- Files status OK
20:47:35:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
20:47:35:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
20:47:35:WU00:FS00:0xa3:- Digital signature verified
20:47:35:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
20:47:35:WU00:FS00:0xa3:Assembly optimizations on if available.
20:47:35:WU00:FS00:0xa3:Entering M.D.
20:47:39:FS00:Paused
20:47:39:FS01:Paused
20:47:39:FS00:Shutting core down
20:47:39:FS01:Shutting core down
20:47:39:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 3860
20:47:39:WU01:FS01:0x17:Exiting, please wait. . .
20:47:41:WU00:FS00:0xa3:Mapping NT from 3 to 3
20:47:42:FS00:Shutting core down
20:47:42:FS01:Shutting core down
20:47:42:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
20:47:44:FS00:Shutting core down
20:47:44:FS01:Shutting core down
20:47:47:FS00:Shutting core down
20:47:47:FS01:Shutting core down
20:47:49:Saving configuration to config.xml
20:47:49:<config>
20:47:49: <!-- Slot Control -->
20:47:49: <power v='FULL'/>
20:47:49:
20:47:49: <!-- User Information -->
20:47:49: <passkey v='********************************'/>
20:47:49: <team v='223518'/>
20:47:49: <user v='shd0w2'/>
20:47:49:
20:47:49: <!-- Folding Slots -->
20:47:49: <slot id='0' type='CPU'>
20:47:49: <idle v='true'/>
20:47:49: <paused v='true'/>
20:47:49: </slot>
20:47:49: <slot id='1' type='GPU'>
20:47:49: </slot>
20:47:49:</config>
20:47:51:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:48:09:FS00:Unpaused
20:48:09:FS01:Unpaused
20:48:09:FS01:Shutting core down
20:48:20:FS01:Shutting core down
20:48:27:FS01:Shutting core down
20:48:35:WU00:FS00:Starting
20:48:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
20:48:35:WU00:FS00:Started FahCore on PID 3264
20:48:35:WU00:FS00:Core PID:3340
20:48:35:WU00:FS00:FahCore 0xa3 started
20:48:35:WU00:FS00:0xa3:
20:48:35:WU00:FS00:0xa3:*------------------------------*
20:48:35:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:48:35:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:48:35:WU00:FS00:0xa3:Preparing to commence simulation
20:48:35:WU00:FS00:0xa3:- Looking at optimizations...
20:48:35:WU00:FS00:0xa3:- Files status OK
20:48:35:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
20:48:35:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
20:48:35:WU00:FS00:0xa3:- Digital signature verified
20:48:35:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
20:48:35:WU00:FS00:0xa3:Assembly optimizations on if available.
20:48:35:WU00:FS00:0xa3:Entering M.D.
20:48:41:WU00:FS00:0xa3:Mapping NT from 3 to 3
20:48:42:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
20:48:50:Saving configuration to config.xml
20:48:50:<config>
20:48:50: <!-- Slot Control -->
20:48:50: <power v='FULL'/>
20:48:50:
20:48:50: <!-- User Information -->
20:48:50: <passkey v='********************************'/>
20:48:50: <team v='223518'/>
20:48:50: <user v='shd0w2'/>
20:48:50:
20:48:50: <!-- Folding Slots -->
20:48:50: <slot id='0' type='CPU'/>
20:48:50: <slot id='1' type='GPU'/>
20:48:50:</config>
20:49:19:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
20:49:19:WU01:FS01:0x17:Lost lifeline PID 7608, exiting
20:49:19:WU01:FS01:0x17:ERROR:103: Lost client lifeline
20:49:19:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
20:49:19:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:49:20:WU01:FS01:Starting
20:49:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:49:20:WU01:FS01:Started FahCore on PID 7244
20:49:20:WU01:FS01:Core PID:6400
20:49:20:WU01:FS01:FahCore 0x17 started
20:49:20:WU01:FS01:0x17:*********************** Log Started 2014-07-27T20:49:20Z ***********************
20:49:20:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
20:49:20:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
20:49:20:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:49:20:WU01:FS01:0x17:Machine: 1
20:49:20:WU01:FS01:0x17:Digital signatures verified
20:49:20:WU01:FS01:0x17:Folding@home GPU core17
20:49:20:WU01:FS01:0x17:Version 0.0.52
20:50:58:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
20:50:58:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:51:18:FS00:Shutting core down
20:51:18:FS01:Shutting core down
20:51:18:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 6400
20:51:18:WU01:FS01:0x17:Exiting, please wait. . .
20:51:18:WU01:FS01:0x17:Folding@home Core Shutdown: INTERRUPTED
20:51:18:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:51:23:WU00:FS00:0xa3:Client no longer detected. Shutting down core
20:51:23:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
20:51:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:51:53:Saving configuration to config.xml
20:51:53:<config>
20:51:53: <!-- Slot Control -->
20:51:53: <power v='FULL'/>
20:51:53:
20:51:53: <!-- User Information -->
20:51:53: <passkey v='********************************'/>
20:51:53: <team v='223518'/>
20:51:53: <user v='shd0w2'/>
20:51:53:
20:51:53: <!-- Folding Slots -->
20:51:53: <slot id='0' type='CPU'>
20:51:53: <idle v='true'/>
20:51:53: </slot>
20:51:53: <slot id='1' type='GPU'>
20:51:53: </slot>
20:51:53:</config>
20:55:32:WU00:FS00:Starting
20:55:32:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
20:55:32:WU00:FS00:Started FahCore on PID 7520
20:55:32:WU00:FS00:Core PID:7272
20:55:32:WU00:FS00:FahCore 0xa3 started
20:55:32:WU01:FS01:Starting
20:55:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:55:32:WU01:FS01:Started FahCore on PID 2220
20:55:32:WU01:FS01:Core PID:7440
20:55:32:WU01:FS01:FahCore 0x17 started
20:55:32:WU00:FS00:0xa3:
20:55:32:WU00:FS00:0xa3:*------------------------------*
20:55:32:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
20:55:32:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
20:55:32:WU00:FS00:0xa3:Preparing to commence simulation
20:55:32:WU00:FS00:0xa3:- Looking at optimizations...
20:55:32:WU00:FS00:0xa3:- Files status OK
20:55:32:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
20:55:32:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
20:55:32:WU00:FS00:0xa3:- Digital signature verified
20:55:32:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
20:55:32:WU00:FS00:0xa3:Assembly optimizations on if available.
20:55:32:WU00:FS00:0xa3:Entering M.D.
20:55:33:WU01:FS01:0x17:*********************** Log Started 2014-07-27T20:55:32Z ***********************
20:55:33:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
20:55:33:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
20:55:33:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:55:33:WU01:FS01:0x17:Machine: 1
20:55:33:WU01:FS01:0x17:Digital signatures verified
20:55:33:WU01:FS01:0x17:Folding@home GPU core17
20:55:33:WU01:FS01:0x17:Version 0.0.52
20:55:38:WU00:FS00:0xa3:Mapping NT from 3 to 3
20:55:39:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
20:55:57:Saving configuration to config.xml
20:55:57:<config>
20:55:57: <!-- Slot Control -->
20:55:57: <power v='FULL'/>
20:55:57:
20:55:57: <!-- User Information -->
20:55:57: <passkey v='********************************'/>
20:55:57: <team v='223518'/>
20:55:57: <user v='shd0w2'/>
20:55:57:
20:55:57: <!-- Folding Slots -->
20:55:57: <slot id='0' type='CPU'/>
20:55:57: <slot id='1' type='GPU'/>
20:55:57:</config>
20:57:15:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
20:57:15:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:11:18:WU00:FS00:0xa3:Completed 5000 out of 500000 steps (1%)
21:12:46:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
21:21:34:FS00:Shutting core down
21:21:38:FS00:Shutting core down
21:21:38:FS01:Shutting core down
21:21:38:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 7440
21:21:38:WU01:FS01:0x17:Exiting, please wait. . .
21:21:39:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:21:42:WU00:FS00:0xa3:Client no longer detected. Shutting down core
21:21:42:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
21:21:43:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:21:43:WU00:FS00:Starting
21:21:43:WARNING:WU00:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
21:21:43:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 2
21:21:43:WU00:FS00:Started FahCore on PID 5048
21:21:43:WU00:FS00:Core PID:3236
21:21:43:WU00:FS00:FahCore 0xa3 started
21:21:43:WU00:FS00:0xa3:
21:21:43:WU00:FS00:0xa3:*------------------------------*
21:21:43:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
21:21:43:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
21:21:43:WU00:FS00:0xa3:Preparing to commence simulation
21:21:43:WU00:FS00:0xa3:- Looking at optimizations...
21:21:43:WU00:FS00:0xa3:- Files status OK
21:21:43:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
21:21:43:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
21:21:43:WU00:FS00:0xa3:- Digital signature verified
21:21:43:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
21:21:43:WU00:FS00:0xa3:Assembly optimizations on if available.
21:21:43:WU00:FS00:0xa3:Entering M.D.
21:21:49:WU00:FS00:0xa3:Using Gromacs checkpoints
21:21:49:WU00:FS00:0xa3:Mapping NT from 2 to 2
21:21:50:WU00:FS00:0xa3:Resuming from checkpoint
21:21:50:WU00:FS00:0xa3:Verified 00/wudata_01.log
21:21:50:WU00:FS00:0xa3:Verified 00/wudata_01.trr
21:21:50:WU00:FS00:0xa3:Verified 00/wudata_01.edr
21:21:50:WU00:FS00:0xa3:Completed 4805 out of 500000 steps (0%)
21:21:57:FS00:Shutting core down
21:21:57:WU01:FS01:Starting
21:21:57:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:21:57:WU01:FS01:Started FahCore on PID 3320
21:21:57:WU01:FS01:Core PID:3436
21:21:57:WU01:FS01:FahCore 0x17 started
21:21:57:WU01:FS01:0x17:*********************** Log Started 2014-07-27T21:21:57Z ***********************
21:21:57:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
21:21:57:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
21:21:57:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:21:57:WU01:FS01:0x17:Machine: 1
21:21:57:WU01:FS01:0x17:Digital signatures verified
21:21:57:WU01:FS01:0x17:Folding@home GPU core17
21:21:57:WU01:FS01:0x17:Version 0.0.52
21:22:03:WU00:FS00:0xa3:Client no longer detected. Shutting down core
21:22:03:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
21:22:04:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:22:43:WU00:FS00:Starting
21:22:43:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
21:22:43:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
21:22:43:WU00:FS00:Started FahCore on PID 7452
21:22:43:WU00:FS00:Core PID:6416
21:22:43:WU00:FS00:FahCore 0xa3 started
21:22:43:WU00:FS00:0xa3:
21:22:43:WU00:FS00:0xa3:*------------------------------*
21:22:43:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
21:22:43:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
21:22:43:WU00:FS00:0xa3:Preparing to commence simulation
21:22:43:WU00:FS00:0xa3:- Looking at optimizations...
21:22:43:WU00:FS00:0xa3:- Files status OK
21:22:43:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
21:22:43:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
21:22:43:WU00:FS00:0xa3:- Digital signature verified
21:22:43:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
21:22:43:WU00:FS00:0xa3:Assembly optimizations on if available.
21:22:43:WU00:FS00:0xa3:Entering M.D.
21:22:49:WU00:FS00:0xa3:Using Gromacs checkpoints
21:22:49:WU00:FS00:0xa3:Mapping NT from 3 to 3
21:22:50:WU00:FS00:0xa3:Resuming from checkpoint
21:22:50:WU00:FS00:0xa3:Verified 00/wudata_01.log
21:22:50:WU00:FS00:0xa3:Verified 00/wudata_01.trr
21:22:50:WU00:FS00:0xa3:Verified 00/wudata_01.edr
21:22:50:WU00:FS00:0xa3:Completed 4805 out of 500000 steps (0%)
21:23:17:FS00:Paused
21:23:17:FS01:Paused
21:23:17:FS00:Shutting core down
21:23:17:FS01:Shutting core down
21:23:17:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 3436
21:23:17:WU01:FS01:0x17:Exiting, please wait. . .
21:23:24:Saving configuration to config.xml
21:23:24:<config>
21:23:24: <!-- Slot Control -->
21:23:24: <power v='FULL'/>
21:23:24:
21:23:24: <!-- User Information -->
21:23:24: <passkey v='********************************'/>
21:23:24: <team v='223518'/>
21:23:24: <user v='shd0w2'/>
21:23:24:
21:23:24: <!-- Folding Slots -->
21:23:24: <slot id='0' type='CPU'>
21:23:24: <paused v='true'/>
21:23:24: </slot>
21:23:24: <slot id='1' type='GPU'>
21:23:24: </slot>
21:23:24:</config>
21:23:30:FS00:Unpaused
21:23:30:FS01:Unpaused
21:23:37:WU00:FS00:0xa3:Client no longer detected. Shutting down core
21:23:37:WU00:FS00:0xa3:Folding@home Core Shutdown: CLIENT_DIED
21:23:37:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:23:41:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
21:23:41:WU01:FS01:0x17:Lost lifeline PID 3320, exiting
21:23:41:WU01:FS01:0x17:ERROR:103: Lost client lifeline
21:23:41:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
21:23:42:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:23:42:WU01:FS01:Starting
21:23:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:23:42:WU01:FS01:Started FahCore on PID 8104
21:23:42:WU01:FS01:Core PID:4812
21:23:42:WU01:FS01:FahCore 0x17 started
21:23:42:WU01:FS01:0x17:*********************** Log Started 2014-07-27T21:23:42Z ***********************
21:23:42:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
21:23:42:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
21:23:42:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
21:23:42:WU01:FS01:0x17:Machine: 1
21:23:42:WU01:FS01:0x17:Digital signatures verified
21:23:42:WU01:FS01:0x17:Folding@home GPU core17
21:23:42:WU01:FS01:0x17:Version 0.0.52
21:23:43:WU00:FS00:Starting
21:23:43:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
21:23:43:WU00:FS00:Started FahCore on PID 5208
21:23:43:WU00:FS00:Core PID:4236
21:23:43:WU00:FS00:FahCore 0xa3 started
21:23:44:WU00:FS00:0xa3:
21:23:44:WU00:FS00:0xa3:*------------------------------*
21:23:44:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
21:23:44:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
21:23:44:WU00:FS00:0xa3:Preparing to commence simulation
21:23:44:WU00:FS00:0xa3:- Looking at optimizations...
21:23:44:WU00:FS00:0xa3:- Files status OK
21:23:44:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
21:23:44:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
21:23:44:WU00:FS00:0xa3:- Digital signature verified
21:23:44:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
21:23:44:WU00:FS00:0xa3:Assembly optimizations on if available.
21:23:44:WU00:FS00:0xa3:Entering M.D.
21:23:45:FS00:Paused
21:23:45:FS01:Paused
21:23:45:FS00:Shutting core down
21:23:45:FS01:Shutting core down
21:23:45:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 4812
21:23:45:WU01:FS01:0x17:Exiting, please wait. . .
21:23:50:WU00:FS00:0xa3:Using Gromacs checkpoints
21:23:50:WU00:FS00:0xa3:Mapping NT from 3 to 3
21:23:50:WU00:FS00:0xa3:Resuming from checkpoint
21:23:50:WU00:FS00:0xa3:Verified 00/wudata_01.log
21:23:50:WU00:FS00:0xa3:Verified 00/wudata_01.trr
21:23:50:WU00:FS00:0xa3:Verified 00/wudata_01.edr
21:23:50:WU00:FS00:0xa3:Completed 4805 out of 500000 steps (0%)
21:23:54:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:24:25:Saving configuration to config.xml
21:24:25:<config>
21:24:25: <!-- Folding Slot Configuration -->
21:24:25: <cause v='CANCER'/>
21:24:25:
21:24:25: <!-- Slot Control -->
21:24:25: <power v='FULL'/>
21:24:25:
21:24:25: <!-- User Information -->
21:24:25: <passkey v='********************************'/>
21:24:25: <team v='223518'/>
21:24:25: <user v='shd0w2'/>
21:24:25:
21:24:25: <!-- Folding Slots -->
21:24:25: <slot id='0' type='CPU'>
21:24:25: <paused v='true'/>
21:24:25: </slot>
21:24:25: <slot id='1' type='GPU'>
21:24:25: </slot>
21:24:25:</config>
21:24:46:WARNING:FS01:Killing WU01
21:24:46:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
22:10:20:FS00:Unpaused
22:10:20:FS01:Unpaused
22:10:20:WU00:FS00:Starting
22:10:20:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
22:10:20:WU00:FS00:Started FahCore on PID 5948
22:10:20:WU00:FS00:Core PID:4148
22:10:20:WU00:FS00:FahCore 0xa3 started
22:10:20:WU01:FS01:Starting
22:10:20:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
22:10:20:WU01:FS01:Started FahCore on PID 4132
22:10:20:WU01:FS01:Core PID:7740
22:10:20:WU01:FS01:FahCore 0x17 started
22:10:21:WU00:FS00:0xa3:
22:10:21:WU00:FS00:0xa3:*------------------------------*
22:10:21:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
22:10:21:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
22:10:21:WU00:FS00:0xa3:Preparing to commence simulation
22:10:21:WU00:FS00:0xa3:- Looking at optimizations...
22:10:21:WU00:FS00:0xa3:- Files status OK
22:10:21:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
22:10:21:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
22:10:21:WU00:FS00:0xa3:- Digital signature verified
22:10:21:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
22:10:21:WU00:FS00:0xa3:Assembly optimizations on if available.
22:10:21:WU00:FS00:0xa3:Entering M.D.
22:10:21:WU01:FS01:0x17:*********************** Log Started 2014-07-27T22:10:20Z ***********************
22:10:21:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
22:10:21:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
22:10:21:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
22:10:21:WU01:FS01:0x17:Machine: 1
22:10:21:WU01:FS01:0x17:Digital signatures verified
22:10:21:WU01:FS01:0x17:Folding@home GPU core17
22:10:21:WU01:FS01:0x17:Version 0.0.52
22:10:27:WU00:FS00:0xa3:Using Gromacs checkpoints
22:10:27:WU00:FS00:0xa3:Mapping NT from 3 to 3
22:10:27:WU00:FS00:0xa3:Resuming from checkpoint
22:10:27:WU00:FS00:0xa3:Verified 00/wudata_01.log
22:10:27:WU00:FS00:0xa3:Verified 00/wudata_01.trr
22:10:27:WU00:FS00:0xa3:Verified 00/wudata_01.edr
22:10:28:WU00:FS00:0xa3:Completed 4805 out of 500000 steps (0%)
22:11:02:WU00:FS00:0xa3:Completed 5000 out of 500000 steps (1%)
22:11:11:Saving configuration to config.xml
22:11:11:<config>
22:11:11: <!-- Folding Slot Configuration -->
22:11:11: <cause v='CANCER'/>
22:11:11:
22:11:11: <!-- Slot Control -->
22:11:11: <power v='FULL'/>
22:11:11:
22:11:11: <!-- User Information -->
22:11:11: <passkey v='********************************'/>
22:11:11: <team v='223518'/>
22:11:11: <user v='shd0w2'/>
22:11:11:
22:11:11: <!-- Folding Slots -->
22:11:11: <slot id='0' type='CPU'/>
22:11:11: <slot id='1' type='GPU'/>
22:11:11:</config>
22:12:10:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
22:12:10:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:26:19:Saving configuration to config.xml
22:26:19:<config>
22:26:19: <!-- Network -->
22:26:19: <proxy v=':8080'/>
22:26:19:
22:26:19: <!-- Slot Control -->
22:26:19: <power v='FULL'/>
22:26:19:
22:26:19: <!-- User Information -->
22:26:19: <passkey v='********************************'/>
22:26:19: <team v='223518'/>
22:26:19: <user v='shd0w2'/>
22:26:19:
22:26:19: <!-- Folding Slots -->
22:26:19: <slot id='0' type='CPU'/>
22:26:19: <slot id='1' type='GPU'/>
22:26:19:</config>
22:26:26:Saving configuration to config.xml
22:26:26:<config>
22:26:26: <!-- Network -->
22:26:26: <proxy v=':8080'/>
22:26:26:
22:26:26: <!-- Slot Control -->
22:26:26: <power v='FULL'/>
22:26:26:
22:26:26: <!-- User Information -->
22:26:26: <passkey v='********************************'/>
22:26:26: <team v='223518'/>
22:26:26: <user v='shd0w2'/>
22:26:26:
22:26:26: <!-- Folding Slots -->
22:26:26: <slot id='0' type='CPU'/>
22:26:26: <slot id='1' type='GPU'/>
22:26:26:</config>
22:27:52:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
22:27:58:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
22:43:35:WU01:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
22:45:17:WU00:FS00:0xa3:Completed 15000 out of 500000 steps (3%)
22:59:12:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
23:00:09:FS00:Finishing
23:00:09:FS01:Finishing
23:00:11:FS00:Paused
23:00:11:FS01:Paused
23:00:11:FS00:Shutting core down
23:00:11:FS01:Shutting core down
23:00:11:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 7740
23:00:11:WU01:FS01:0x17:Exiting, please wait. . .
23:00:12:WU01:FS01:0x17:Lost lifeline PID 4132, exiting
23:00:12:WU01:FS01:0x17:ERROR:103: Lost client lifeline
23:00:12:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
23:00:12:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
23:00:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:00:35:FS00:Unpaused
23:00:35:FS01:Unpaused
23:00:35:WU00:FS00:Starting
23:00:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -np 3
23:00:35:WU00:FS00:Started FahCore on PID 6684
23:00:35:WU00:FS00:Core PID:2524
23:00:35:WU00:FS00:FahCore 0xa3 started
23:00:35:WU01:FS01:Starting
23:00:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cyrus/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8172 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:00:35:WU01:FS01:Started FahCore on PID 2920
23:00:35:WU01:FS01:Core PID:7536
23:00:35:WU01:FS01:FahCore 0x17 started
23:00:36:WU00:FS00:0xa3:
23:00:36:WU00:FS00:0xa3:*------------------------------*
23:00:36:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
23:00:36:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
23:00:36:WU00:FS00:0xa3:Preparing to commence simulation
23:00:36:WU00:FS00:0xa3:- Looking at optimizations...
23:00:36:WU00:FS00:0xa3:- Files status OK
23:00:36:WU00:FS00:0xa3:- Expanded 3813877 -> 4169428 (decompressed 109.3 percent)
23:00:36:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3813877 data_size=4169428, decompressed_data_size=4169428 diff=0
23:00:36:WU00:FS00:0xa3:- Digital signature verified
23:00:36:WU00:FS00:0xa3:Project: 6099 (Run 4, Clone 90, Gen 491)
23:00:36:WU00:FS00:0xa3:Assembly optimizations on if available.
23:00:36:WU00:FS00:0xa3:Entering M.D.
23:00:36:WU01:FS01:0x17:*********************** Log Started 2014-07-27T23:00:35Z ***********************
23:00:36:WU01:FS01:0x17:Project: 10468 (Run 0, Clone 202, Gen 16)
23:00:36:WU01:FS01:0x17:Unit: 0x0000001d538b3db9538cafab84d18080
23:00:36:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
23:00:36:WU01:FS01:0x17:Machine: 1
23:00:36:WU01:FS01:0x17:Digital signatures verified
23:00:36:WU01:FS01:0x17:Folding@home GPU core17
23:00:36:WU01:FS01:0x17:Version 0.0.52
23:00:36:WU01:FS01:0x17: Found a checkpoint file
23:00:42:WU00:FS00:0xa3:Using Gromacs checkpoints
23:00:42:WU00:FS00:0xa3:Mapping NT from 3 to 3
23:00:42:WU00:FS00:0xa3:Resuming from checkpoint
23:00:42:WU00:FS00:0xa3:Verified 00/wudata_01.log
23:00:42:WU00:FS00:0xa3:Verified 00/wudata_01.trr
23:00:42:WU00:FS00:0xa3:Verified 00/wudata_01.edr
23:00:43:WU00:FS00:0xa3:Completed 18150 out of 500000 steps (3%)
23:01:00:FS00:Paused
23:01:00:FS01:Paused
23:01:00:FS00:Shutting core down
23:01:00:FS01:Shutting core down
23:01:00:WU01:FS01:0x17:WARNING:Console control signal 1 on PID 7536
23:01:00:WU01:FS01:0x17:Exiting, please wait. . .
23:01:06:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:02:01:Saving configuration to config.xml
23:02:01:<config>
23:02:01: <!-- Network -->
23:02:01: <proxy v=':8080'/>
23:02:01:
23:02:01: <!-- Slot Control -->
23:02:01: <power v='FULL'/>
23:02:01:
23:02:01: <!-- User Information -->
23:02:01: <passkey v='********************************'/>
23:02:01: <team v='223518'/>
23:02:01: <user v='shd0w2'/>
23:02:01:
23:02:01: <!-- Folding Slots -->
23:02:01: <slot id='0' type='CPU'>
23:02:01: <paused v='true'/>
23:02:01: </slot>
23:02:01: <slot id='1' type='GPU'>
23:02:01: </slot>
23:02:01:</config>
23:02:01:WARNING:FS01:Killing WU01
23:02:01:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)This is the log file I got, sorry if I did it the wrong way or something.
Mod edit: Added Code tags to log
P5-133XL
Machine #2:
Machine 3:
You will not get accurate PPD estimates till you complete 3-5% of the WU. Even then, if you want to get high PPD, you have to let it fold and not interrupt it constantly. Each time it is interrupted it starts over at the last checkpoint losing all the time spent folding after that checkpoint. Most of the PPD comes from the Quick return bonus points (QRB) and the more time not running, the less PPD you will get and it is not linear. Looking at the log, you let it run 32 minutes out of 3 hours to get 3% done so it estimates PPD based on the 3 hours it took you to get the 3% done.
I understand that this is new and you were fiddling. Once you get into the swing of things, you should be getting better PPD.
When your computer is used jointly for your normal activities and for FAH, if you happen to have a slow GPU, a short delay may be noticed for your GPU to finish the current block of FAH work and proceed to processing inputs from your keyboard or mouse. (This is not noticeable if you have a fast GPU or if the processing is being done by your CPU.) To avoid these delays, the GPU is normally configured to suspend FAH processing when your mouse/keyboard are being used. GPU processing resumes when the mouse/kb are idle.
In this context, I would classify your GTX 770 as "fast" and would expect that you won't notice any lags if you configure your GPU to fold continuously rather than only when idle. If performance is acceptable, your GPU would have gotten closer to 3 hours work done rather than half an hour. You'd need to be the judge of that so it's probably worth trying, but I'd wait a day or two until you get a feel for how your foreground activities share with FAH in the background with the current configuration.
FYI, The default settings are the best settings for most people by design. As noted above, the client does very little folding while having to save changes and restart every few minutes.
If there is something you want the client to do and don't know how, just ask. Otherwise the Configuration FAQ is a good way to learn.
