Missing credit for a Core 17 Work Unit
kwerboom
Post by kwerboom »
Hi, my user name and FAH client name is kwerboom and I have a problem. At 08:53:45z on 2014-07-13 my R9 280 finished a work unit for an estimated 48,232.00 points. Yet when I went to http://fah-web.stanford.edu/cgi-bin/mai ... e=kwerboom, it says my last work unit was at 12:21:08z on 2014-07-12. Could someone look into what limbo the WU I sent ended up in and what happened to those points? Thank you.
Here is the log file:
*********************** Log Started 2014-07-12T23:56:48Z ***********************
23:56:48:************************* Folding@home Client *************************
23:56:48:      Website: http://folding.stanford.edu/
23:56:48:    Copyright: (c) 2009-2014 Stanford University
23:56:48:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:56:48:         Args:
23:56:48:       Config: C:/Users/Keith/AppData/Roaming/FAHClient/config.xml
23:56:48:******************************** Build ********************************
23:56:48:      Version: 7.4.4
23:56:48:         Date: Mar 4 2014
23:56:48:         Time: 20:26:54
23:56:48:      SVN Rev: 4130
23:56:48:       Branch: fah/trunk/client
23:56:48:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:56:48:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:56:48:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:56:48:     Platform: win32 XP
23:56:48:         Bits: 32
23:56:48:         Mode: Release
23:56:48:******************************* System ********************************
23:56:48:          CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
23:56:48:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:56:48:         CPUs: 8
23:56:48:       Memory: 15.94GiB
23:56:48:  Free Memory: 13.69GiB
23:56:48:      Threads: WINDOWS_THREADS
23:56:48:   OS Version: 6.1
23:56:48:  Has Battery: false
23:56:48:   On Battery: false
23:56:48:   UTC Offset: -5
23:56:48:          PID: 5504
23:56:48:          CWD: C:/Users/Keith/AppData/Roaming/FAHClient
23:56:48:           OS: Windows 7 Professional
23:56:48:      OS Arch: AMD64
23:56:48:         GPUs: 1
23:56:48:        GPU 0: ATI:5 Tahiti PRO [Radeon R9 280/HD 7900/8950]
23:56:48:         CUDA: Not detected
23:56:48:Win32 Service: false
23:56:48:***********************************************************************
23:56:48:<config>
23:56:48:  <service-description v='Folding@home Client'/>
23:56:48:  <service-restart v='true'/>
23:56:48:  <service-restart-delay v='5000'/>
23:56:48:
23:56:48:  <!-- Client Control -->
23:56:48:  <client-threads v='6'/>
23:56:48:  <cycle-rate v='4'/>
23:56:48:  <cycles v='-1'/>
23:56:48:  <data-directory v='.'/>
23:56:48:  <disable-sleep-when-active v='true'/>
23:56:48:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
23:56:48:  <exit-when-done v='false'/>
23:56:48:  <fold-anon v='false'/>
23:56:48:  <open-web-control v='false'/>
23:56:48:
23:56:48:  <!-- Configuration -->
23:56:48:  <config-rotate v='true'/>
23:56:48:  <config-rotate-dir v='configs'/>
23:56:48:  <config-rotate-max v='16'/>
23:56:48:
23:56:48:  <!-- Debugging -->
23:56:48:  <assignment-servers>
23:56:48:    assign3.stanford.edu:8080 assign4.stanford.edu:80
23:56:48:  </assignment-servers>
23:56:48:  <auth-as v='true'/>
23:56:48:  <capture-directory v='capture'/>
23:56:48:  <capture-on-error v='false'/>
23:56:48:  <capture-packets v='false'/>
23:56:48:  <capture-requests v='false'/>
23:56:48:  <capture-responses v='false'/>
23:56:48:  <capture-sockets v='false'/>
23:56:48:  <core-exec v='FahCore_$type'/>
23:56:48:  <core-wrapper-exec v='FAHCoreWrapper'/>
23:56:48:  <debug-sockets v='false'/>
23:56:48:  <exception-locations v='true'/>
23:56:48:  <gpu-assignment-servers>
23:56:48:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
23:56:48:  </gpu-assignment-servers>
23:56:48:  <stack-traces v='false'/>
23:56:48:
23:56:48:  <!-- Error Handling -->
23:56:48:  <max-slot-errors v='10'/>
23:56:48:  <max-unit-errors v='5'/>
23:56:48:
23:56:48:  <!-- Folding Core -->
23:56:48:  <checkpoint v='9'/>
23:56:48:  <core-dir v='cores'/>
23:56:48:  <core-priority v='low'/>
23:56:48:  <cpu-affinity v='false'/>
23:56:48:  <cpu-usage v='100'/>
23:56:48:  <gpu-usage v='100'/>
23:56:48:  <no-assembly v='false'/>
23:56:48:
23:56:48:  <!-- Folding Slot Configuration -->
23:56:48:  <cause v='ANY'/>
23:56:48:  <client-subtype v='STDCLI'/>
23:56:48:  <client-type v='normal'/>
23:56:48:  <cpu-species v='X86_PENTIUM_II'/>
23:56:48:  <cpu-type v='AMD64'/>
23:56:48:  <cpus v='-1'/>
23:56:48:  <gpu v='true'/>
23:56:48:  <max-packet-size v='normal'/>
23:56:48:  <os-species v='UNKNOWN'/>
23:56:48:  <os-type v='WIN32'/>
23:56:48:  <project-key v='0'/>
23:56:48:  <smp v='true'/>
23:56:48:
23:56:48:  <!-- GUI -->
23:56:48:  <gui-enabled v='true'/>
23:56:48:
23:56:48:  <!-- HTTP Server -->
23:56:48:  <allow v='127.0.0.1'/>
23:56:48:  <connection-timeout v='60'/>
23:56:48:  <deny v='0/0'/>
23:56:48:  <http-addresses v='0:7396'/>
23:56:48:  <https-addresses v=''/>
23:56:48:  <max-connect-time v='900'/>
23:56:48:  <max-connections v='800'/>
23:56:48:  <max-request-length v='52428800'/>
23:56:48:  <min-connect-time v='300'/>
23:56:48:  <threads v='8'/>
23:56:48:
23:56:48:  <!-- Logging -->
23:56:48:  <log v='log.txt'/>
23:56:48:  <log-color v='false'/>
23:56:48:  <log-crlf v='true'/>
23:56:48:  <log-date v='false'/>
23:56:48:  <log-date-periodically v='21600'/>
23:56:48:  <log-debug v='true'/>
23:56:48:  <log-domain v='false'/>
23:56:48:  <log-header v='true'/>
23:56:48:  <log-level v='true'/>
23:56:48:  <log-no-info-header v='true'/>
23:56:48:  <log-redirect v='false'/>
23:56:48:  <log-rotate v='true'/>
23:56:48:  <log-rotate-dir v='logs'/>
23:56:48:  <log-rotate-max v='16'/>
23:56:48:  <log-short-level v='false'/>
23:56:48:  <log-simple-domains v='true'/>
23:56:48:  <log-thread-id v='false'/>
23:56:48:  <log-thread-prefix v='true'/>
23:56:48:  <log-time v='true'/>
23:56:48:  <log-to-screen v='true'/>
23:56:48:  <log-truncate v='false'/>
23:56:48:  <verbosity v='5'/>
23:56:48:
23:56:48:  <!-- Network -->
23:56:48:  <proxy v=':8080'/>
23:56:48:  <proxy-enable v='false'/>
23:56:48:  <proxy-pass v=''/>
23:56:48:  <proxy-user v=''/>
23:56:48:
23:56:48:  <!-- Process Control -->
23:56:48:  <child v='false'/>
23:56:48:  <daemon v='false'/>
23:56:48:  <pid v='false'/>
23:56:48:  <pid-file v='Folding@home Client.pid'/>
23:56:48:  <respawn v='false'/>
23:56:48:  <service v='false'/>
23:56:48:
23:56:48:  <!-- Remote Command Server -->
23:56:48:  <command-address v='0.0.0.0'/>
23:56:48:  <command-allow-no-pass v='127.0.0.1'/>
23:56:48:  <command-deny-no-pass v='0/0'/>
23:56:48:  <command-enable v='true'/>
23:56:48:  <command-port v='36330'/>
23:56:48:
23:56:48:  <!-- Slot Control -->
23:56:48:  <idle v='false'/>
23:56:48:  <max-shutdown-wait v='60'/>
23:56:48:  <pause-on-battery v='false'/>
23:56:48:  <pause-on-start v='false'/>
23:56:48:  <paused v='false'/>
23:56:48:  <power v='medium'/>
23:56:48:
23:56:48:  <!-- User Information -->
23:56:48:  <machine-id v='0'/>
23:56:48:  <passkey v='********************************'/>
23:56:48:  <team v='50959'/>
23:56:48:  <user v='kwerboom'/>
23:56:48:
23:56:48:  <!-- Web Server -->
23:56:48:  <web-allow v='127.0.0.1'/>
23:56:48:  <web-deny v='0/0'/>
23:56:48:  <web-enable v='true'/>
23:56:48:
23:56:48:  <!-- Web Server Sessions -->
23:56:48:  <session-cookie v='sid'/>
23:56:48:  <session-lifetime v='86400'/>
23:56:48:  <session-timeout v='3600'/>
23:56:48:
23:56:48:  <!-- Work Unit Control -->
23:56:48:  <dump-after-deadline v='true'/>
23:56:48:  <max-queue v='16'/>
23:56:48:  <max-units v='0'/>
23:56:48:  <next-unit-percentage v='99'/>
23:56:48:  <stall-detection-enabled v='false'/>
23:56:48:  <stall-percent v='5'/>
23:56:48:  <stall-timeout v='1800'/>
23:56:48:
23:56:48:  <!-- Folding Slots -->
23:56:48:  <slot id='1' type='GPU'/>
23:56:48:</config>
23:56:48:Trying to access database...
23:56:48:Successfully acquired database lock
23:56:48:Enabled folding slot 01: READY gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950]
23:56:48:Started thread 7 on PID 5504
23:56:48:Started thread 8 on PID 5504
23:56:48:Started thread 5 on PID 5504
23:56:48:Started thread 4 on PID 5504
23:56:48:Started thread 6 on PID 5504
23:56:48:Started thread 9 on PID 5504
23:56:48:WU01:FS01:Starting
23:56:48:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Keith/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 5504 -checkpoint 9 -gpu 0 -gpu-vendor ati
23:56:48:WU01:FS01:Started FahCore on PID 6020
23:56:48:Started thread 10 on PID 5504
23:56:48:WU01:FS01:Core PID:1972
23:56:48:WU01:FS01:FahCore 0x17 started
23:56:48:WU01:FS01:0x17:*********************** Log Started 2014-07-12T23:56:48Z ***********************
23:56:48:WU01:FS01:0x17:Project: 13000 (Run 15, Clone 4, Gen 34)
23:56:48:WU01:FS01:0x17:Unit: 0x0000003d538b3db7530fa06fc1eaa90f
23:56:48:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
23:56:48:WU01:FS01:0x17:Machine: 1
23:56:48:WU01:FS01:0x17:Digital signatures verified
23:56:48:WU01:FS01:0x17:Folding@home GPU core17
23:56:48:WU01:FS01:0x17:Version 0.0.52
23:56:48:WU01:FS01:0x17:  Found a checkpoint file
23:58:40:WU01:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
23:58:40:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:59:44:Started thread 11 on PID 5504
00:01:11:2:127.0.0.1 GET /ping?_=1405209669587&callback=jQuery19009492090874755137_1405209669586
00:01:11:3:127.0.0.1 GET /?nocache=0.003306499834745069
00:01:16:4:127.0.0.1 GET /api/updates/set?_=1405209674804&sid=5a7f03caa42e44079887dd2ae7bb39b1&update_id=0&update_path=/api/basic&update_rate=1
00:01:16:5:127.0.0.1 GET /api/updates/set?_=1405209674805&sid=5a7f03caa42e44079887dd2ae7bb39b1&update_id=1&update_path=/api/slots&update_rate=1
00:01:16:6:127.0.0.1 GET /api/configured?_=1405209674806&sid=5a7f03caa42e44079887dd2ae7bb39b1
00:01:17:7:127.0.0.1 GET /?nocache=0.003306499834745069
00:01:17:8:127.0.0.1 GET /api/updates?_=1405209674807&sid=5a7f03caa42e44079887dd2ae7bb39b1
00:01:18:9:127.0.0.1 GET /css/normalize.css
00:01:18:10:127.0.0.1 GET /css/main.css
00:01:19:11:127.0.0.1 GET /js/jquery-1.10.2.min.js
00:01:19:12:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
00:01:19:13:127.0.0.1 GET /js/intercom.min.js
00:01:19:14:127.0.0.1 GET /js/main.js
00:01:19:14:127.0.0.1:New Web connection
00:01:19:15:127.0.0.1 GET /images/mail.png
00:01:19:16:127.0.0.1 GET /images/facebook.png
00:01:19:18:127.0.0.1 GET /images/twitter.png
00:01:19:19:127.0.0.1 GET /images/report-bug.png
00:01:21:20:127.0.0.1 GET /images/template/bg.jpg
00:01:21:21:127.0.0.1 GET /images/template/input_radio.png
00:01:21:22:127.0.0.1 GET /images/template/button_bg.png
00:01:21:23:127.0.0.1 GET /images/template/logo_folding_home.png
00:01:22:17:127.0.0.1 GET /api/updates/set?_=1405209680317&sid=9f69205a13f73e495b3ed076d864febe&update_id=0&update_path=/api/basic&update_rate=1
00:01:22:24:127.0.0.1 GET /api/updates/set?_=1405209680318&sid=9f69205a13f73e495b3ed076d864febe&update_id=1&update_path=/api/slots&update_rate=1
00:01:22:25:127.0.0.1 GET /api/configured?_=1405209680319&sid=9f69205a13f73e495b3ed076d864febe
00:01:22:26:127.0.0.1 GET /images/template/ui-progress-bg.png
00:01:22:27:127.0.0.1 GET /images/template/ui-icon-slider.png
00:01:23:28:127.0.0.1 GET /images/template/ui-bg-slider.png
00:01:23:29:127.0.0.1 GET /api/updates?_=1405209680320&sid=9f69205a13f73e495b3ed076d864febe
00:01:24:30:127.0.0.1 GET /images/template/select-icons.png
00:01:24:31:127.0.0.1 GET /images/template/anim_arrow.gif
00:01:25:29:127.0.0.1 GET /api/updates?_=1405209680324&sid=9f69205a13f73e495b3ed076d864febe
00:01:27:32:127.0.0.1 GET /api/updates?_=1405209680325&sid=9f69205a13f73e495b3ed076d864febe
00:01:29:32:127.0.0.1 GET /api/updates?_=1405209680326&sid=9f69205a13f73e495b3ed076d864febe
00:01:31:32:127.0.0.1 GET /api/updates?_=1405209680327&sid=9f69205a13f73e495b3ed076d864febe
00:01:36:32:127.0.0.1 GET /api/updates?_=1405209680328&sid=9f69205a13f73e495b3ed076d864febe
00:01:39:29:127.0.0.1 GET /api/updates?_=1405209680329&sid=9f69205a13f73e495b3ed076d864febe
00:01:43:32:127.0.0.1 GET /api/updates?_=1405209680330&sid=9f69205a13f73e495b3ed076d864febe
00:01:48:32:127.0.0.1 GET /api/updates?_=1405209680331&sid=9f69205a13f73e495b3ed076d864febe
00:01:53:29:127.0.0.1 GET /api/updates?_=1405209680332&sid=9f69205a13f73e495b3ed076d864febe
00:01:55:32:127.0.0.1 GET /api/updates?_=1405209680333&sid=9f69205a13f73e495b3ed076d864febe
00:02:00:29:127.0.0.1 GET /api/updates?_=1405209680334&sid=9f69205a13f73e495b3ed076d864febe
00:02:05:32:127.0.0.1 GET /api/updates?_=1405209680335&sid=9f69205a13f73e495b3ed076d864febe
00:02:10:32:127.0.0.1 GET /api/updates?_=1405209680336&sid=9f69205a13f73e495b3ed076d864febe
00:02:15:29:127.0.0.1 GET /api/updates?_=1405209680337&sid=9f69205a13f73e495b3ed076d864febe
00:02:17:32:127.0.0.1 GET /api/updates?_=1405209680338&sid=9f69205a13f73e495b3ed076d864febe
00:02:22:32:127.0.0.1 GET /api/updates?_=1405209680339&sid=9f69205a13f73e495b3ed076d864febe
00:02:27:29:127.0.0.1 GET /api/updates?_=1405209680340&sid=9f69205a13f73e495b3ed076d864febe
00:02:32:29:127.0.0.1 GET /api/updates?_=1405209680341&sid=9f69205a13f73e495b3ed076d864febe
00:02:34:29:127.0.0.1 GET /api/updates?_=1405209680342&sid=9f69205a13f73e495b3ed076d864febe
00:02:38:32:127.0.0.1 GET /api/updates?_=1405209680343&sid=9f69205a13f73e495b3ed076d864febe
00:02:43:32:127.0.0.1 GET /api/updates?_=1405209680344&sid=9f69205a13f73e495b3ed076d864febe
00:02:47:29:127.0.0.1 GET /api/updates?_=1405209680345&sid=9f69205a13f73e495b3ed076d864febe
00:02:52:29:127.0.0.1 GET /api/updates?_=1405209680346&sid=9f69205a13f73e495b3ed076d864febe
00:02:54:32:127.0.0.1 GET /api/updates?_=1405209680347&sid=9f69205a13f73e495b3ed076d864febe
00:02:55:29:127.0.0.1 GET /api/updates?_=1405209680348&sid=9f69205a13f73e495b3ed076d864febe
00:02:59:32:127.0.0.1 GET /api/updates?_=1405209680349&sid=9f69205a13f73e495b3ed076d864febe
00:03:05:32:127.0.0.1 GET /api/updates?_=1405209680350&sid=9f69205a13f73e495b3ed076d864febe
00:03:09:29:127.0.0.1 GET /api/updates?_=1405209680351&sid=9f69205a13f73e495b3ed076d864febe
00:03:14:29:127.0.0.1 GET /api/updates?_=1405209680352&sid=9f69205a13f73e495b3ed076d864febe
00:03:19:29:127.0.0.1 GET /api/updates?_=1405209680353&sid=9f69205a13f73e495b3ed076d864febe
00:08:19:WU01:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
00:17:48:WU01:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
00:27:33:WU01:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
00:31:24:Started thread 12 on PID 5504
00:37:07:WU01:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
00:46:43:WU01:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
00:56:27:WU01:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
01:05:21:Started thread 13 on PID 5504
01:06:02:WU01:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
01:09:13:35:127.0.0.1 GET /ping?_=1405213752481&callback=jQuery19005281929771354444_1405213752480
01:09:14:36:127.0.0.1 GET /?nocache=0.5265709152255603
01:09:15:37:127.0.0.1 GET /api/updates/set?_=1405213755017&sid=9f69205a13f73e495b3ed076d864febe&update_id=0&update_path=/api/basic&update_rate=1
01:09:15:38:127.0.0.1 GET /api/updates/set?_=1405213755018&sid=9f69205a13f73e495b3ed076d864febe&update_id=1&update_path=/api/slots&update_rate=1
01:09:15:39:127.0.0.1 GET /api/configured?_=1405213755019&sid=9f69205a13f73e495b3ed076d864febe
01:09:17:41:127.0.0.1 GET /api/updates?_=1405213755020&sid=9f69205a13f73e495b3ed076d864febe
01:09:17:42:127.0.0.1 GET /?nocache=0.5265709152255603
01:09:17:44:127.0.0.1 GET /?nocache=0.5265709152255603
01:09:18:45:127.0.0.1 GET /css/normalize.css
01:09:18:46:127.0.0.1 GET /css/main.css
01:09:19:47:127.0.0.1 GET /js/jquery-1.10.2.min.js
01:09:19:48:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
01:09:19:49:127.0.0.1 GET /js/intercom.min.js
01:09:19:50:127.0.0.1 GET /js/main.js
01:09:19:50:127.0.0.1:New Web connection
01:09:19:51:127.0.0.1 GET /images/mail.png
01:09:20:52:127.0.0.1 GET /images/facebook.png
01:09:20:54:127.0.0.1 GET /images/twitter.png
01:09:20:55:127.0.0.1 GET /images/report-bug.png
01:09:23:56:127.0.0.1 GET /images/template/bg.jpg
01:09:23:53:127.0.0.1 GET /api/updates/set?_=1405213761561&sid=c1f3566189c96ec14aedaada1274c154&update_id=0&update_path=/api/basic&update_rate=1
01:09:23:57:127.0.0.1 GET /images/template/input_radio.png
01:09:23:58:127.0.0.1 GET /images/template/button_bg.png
01:09:23:59:127.0.0.1 GET /images/template/logo_folding_home.png
01:09:23:60:127.0.0.1 GET /api/updates/set?_=1405213761562&sid=c1f3566189c96ec14aedaada1274c154&update_id=1&update_path=/api/slots&update_rate=1
01:09:24:61:127.0.0.1 GET /api/configured?_=1405213761563&sid=c1f3566189c96ec14aedaada1274c154
01:09:24:62:127.0.0.1 GET /images/template/ui-progress-bg.png
01:09:24:63:127.0.0.1 GET /images/template/ui-icon-slider.png
01:09:25:64:127.0.0.1 GET /api/updates?_=1405213761564&sid=c1f3566189c96ec14aedaada1274c154
01:09:25:65:127.0.0.1 GET /images/template/ui-bg-slider.png
01:09:26:64:127.0.0.1 GET /api/updates?_=1405213761568&sid=c1f3566189c96ec14aedaada1274c154
01:09:26:66:127.0.0.1 GET /images/template/select-icons.png
01:09:26:67:127.0.0.1 GET /images/template/anim_arrow.gif
01:09:27:68:127.0.0.1 GET /api/updates?_=1405213761569&sid=c1f3566189c96ec14aedaada1274c154
01:09:31:64:127.0.0.1 GET /api/updates?_=1405213761570&sid=c1f3566189c96ec14aedaada1274c154
01:09:32:64:127.0.0.1 GET /api/updates?_=1405213761571&sid=c1f3566189c96ec14aedaada1274c154
01:09:37:68:127.0.0.1 GET /api/updates?_=1405213761572&sid=c1f3566189c96ec14aedaada1274c154
01:09:42:68:127.0.0.1 GET /api/updates?_=1405213761573&sid=c1f3566189c96ec14aedaada1274c154
01:09:43:68:127.0.0.1 GET /api/updates?_=1405213761574&sid=c1f3566189c96ec14aedaada1274c154
01:09:48:64:127.0.0.1 GET /api/updates?_=1405213761575&sid=c1f3566189c96ec14aedaada1274c154
01:09:53:64:127.0.0.1 GET /api/updates?_=1405213761576&sid=c1f3566189c96ec14aedaada1274c154
01:09:54:64:127.0.0.1 GET /api/updates?_=1405213761577&sid=c1f3566189c96ec14aedaada1274c154
01:09:59:64:127.0.0.1 GET /api/updates?_=1405213761578&sid=c1f3566189c96ec14aedaada1274c154
01:10:04:68:127.0.0.1 GET /api/updates?_=1405213761579&sid=c1f3566189c96ec14aedaada1274c154
01:10:09:64:127.0.0.1 GET /api/updates?_=1405213761580&sid=c1f3566189c96ec14aedaada1274c154
01:10:14:68:127.0.0.1 GET /api/updates?_=1405213761581&sid=c1f3566189c96ec14aedaada1274c154
01:10:16:68:127.0.0.1 GET /api/updates?_=1405213761582&sid=c1f3566189c96ec14aedaada1274c154
01:10:21:64:127.0.0.1 GET /api/updates?_=1405213761583&sid=c1f3566189c96ec14aedaada1274c154
01:10:25:68:127.0.0.1 GET /api/updates?_=1405213761584&sid=c1f3566189c96ec14aedaada1274c154
01:10:30:68:127.0.0.1 GET /api/updates?_=1405213761585&sid=c1f3566189c96ec14aedaada1274c154
01:10:35:64:127.0.0.1 GET /api/updates?_=1405213761586&sid=c1f3566189c96ec14aedaada1274c154
01:10:40:64:127.0.0.1 GET /api/updates?_=1405213761587&sid=c1f3566189c96ec14aedaada1274c154
01:10:45:64:127.0.0.1 GET /api/updates?_=1405213761588&sid=c1f3566189c96ec14aedaada1274c154
01:10:50:64:127.0.0.1 GET /api/updates?_=1405213761589&sid=c1f3566189c96ec14aedaada1274c154
01:10:55:64:127.0.0.1 GET /api/updates?_=1405213761590&sid=c1f3566189c96ec14aedaada1274c154
01:11:00:64:127.0.0.1 GET /api/updates?_=1405213761591&sid=c1f3566189c96ec14aedaada1274c154
01:11:01:69:127.0.0.1 GET /api/updates?_=1405213761592&sid=c1f3566189c96ec14aedaada1274c154
01:11:05:64:127.0.0.1 GET /api/updates?_=1405213761593&sid=c1f3566189c96ec14aedaada1274c154
01:11:06:64:127.0.0.1 GET /api/updates?_=1405213761594&sid=c1f3566189c96ec14aedaada1274c154
01:11:11:69:127.0.0.1 GET /api/updates?_=1405213761595&sid=c1f3566189c96ec14aedaada1274c154
01:11:16:69:127.0.0.1 GET /api/updates?_=1405213761596&sid=c1f3566189c96ec14aedaada1274c154
01:11:22:64:127.0.0.1 GET /api/updates?_=1405213761597&sid=c1f3566189c96ec14aedaada1274c154
01:15:47:WU01:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
01:25:29:WU01:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
01:35:11:WU01:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
01:45:04:WU01:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
01:54:45:WU01:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
01:57:42:Started thread 14 on PID 5504
02:04:32:WU01:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
02:14:05:WU01:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
02:23:47:WU01:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
02:33:37:WU01:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
02:43:06:WU01:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
02:44:58:71:127.0.0.1 GET /ping?_=1405219497087&callback=jQuery19004684686954314281_1405219497086
02:44:59:72:127.0.0.1 GET /?nocache=0.04565565435487373
02:45:03:73:127.0.0.1 GET /api/updates/set?_=1405219501410&sid=c1f3566189c96ec14aedaada1274c154&update_id=0&update_path=/api/basic&update_rate=1
02:45:03:74:127.0.0.1 GET /api/updates/set?_=1405219501411&sid=c1f3566189c96ec14aedaada1274c154&update_id=1&update_path=/api/slots&update_rate=1
02:45:03:75:127.0.0.1 GET /api/configured?_=1405219501412&sid=c1f3566189c96ec14aedaada1274c154
02:45:04:76:127.0.0.1 GET /?nocache=0.04565565435487373
02:45:04:77:127.0.0.1 GET /api/updates?_=1405219501413&sid=c1f3566189c96ec14aedaada1274c154
02:45:05:78:127.0.0.1 GET /?nocache=0.04565565435487373
02:45:06:79:127.0.0.1 GET /api/updates?_=1405219501414&sid=c1f3566189c96ec14aedaada1274c154
02:45:06:80:127.0.0.1 GET /css/normalize.css
02:45:06:81:127.0.0.1 GET /css/main.css
02:45:07:82:127.0.0.1 GET /js/jquery-1.10.2.min.js
02:45:08:83:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
02:45:08:84:127.0.0.1 GET /js/intercom.min.js
02:45:08:85:127.0.0.1 GET /js/main.js
02:45:08:85:127.0.0.1:New Web connection
02:45:08:86:127.0.0.1 GET /images/mail.png
02:45:08:87:127.0.0.1 GET /images/facebook.png
02:45:09:88:127.0.0.1 GET /images/twitter.png
02:45:09:89:127.0.0.1 GET /images/report-bug.png
02:45:11:90:127.0.0.1 GET /images/template/bg.jpg
02:45:11:91:127.0.0.1 GET /images/template/input_radio.png
02:45:11:92:127.0.0.1 GET /images/template/button_bg.png
02:45:11:93:127.0.0.1 GET /images/template/logo_folding_home.png
02:45:11:94:127.0.0.1 GET /api/updates/set?_=1405219510117&sid=128497847ae50df7910ccab9ad397d99&update_id=0&update_path=/api/basic&update_rate=1
02:45:11:95:127.0.0.1 GET /api/updates/set?_=1405219510118&sid=128497847ae50df7910ccab9ad397d99&update_id=1&update_path=/api/slots&update_rate=1
02:45:11:96:127.0.0.1 GET /api/configured?_=1405219510119&sid=128497847ae50df7910ccab9ad397d99
02:45:11:97:127.0.0.1 GET /images/template/ui-progress-bg.png
02:45:11:98:127.0.0.1 GET /images/template/ui-icon-slider.png
02:45:12:99:127.0.0.1 GET /api/updates?_=1405219510120&sid=128497847ae50df7910ccab9ad397d99
02:45:12:100:127.0.0.1 GET /images/template/ui-bg-slider.png
02:45:13:99:127.0.0.1 GET /api/updates?_=1405219510121&sid=128497847ae50df7910ccab9ad397d99
02:45:13:102:127.0.0.1 GET /images/template/select-icons.png
02:45:14:103:127.0.0.1 GET /images/template/anim_arrow.gif
02:45:14:101:127.0.0.1 GET /api/updates?_=1405219510125&sid=128497847ae50df7910ccab9ad397d99
02:45:17:101:127.0.0.1 GET /api/updates?_=1405219510126&sid=128497847ae50df7910ccab9ad397d99
02:45:20:99:127.0.0.1 GET /api/updates?_=1405219510127&sid=128497847ae50df7910ccab9ad397d99
02:45:22:101:127.0.0.1 GET /api/updates?_=1405219510128&sid=128497847ae50df7910ccab9ad397d99
02:45:25:101:127.0.0.1 GET /api/updates?_=1405219510129&sid=128497847ae50df7910ccab9ad397d99
02:45:30:99:127.0.0.1 GET /api/updates?_=1405219510130&sid=128497847ae50df7910ccab9ad397d99
02:45:35:101:127.0.0.1 GET /api/updates?_=1405219510131&sid=128497847ae50df7910ccab9ad397d99
02:45:36:101:127.0.0.1 GET /api/updates?_=1405219510132&sid=128497847ae50df7910ccab9ad397d99
02:45:41:101:127.0.0.1 GET /api/updates?_=1405219510133&sid=128497847ae50df7910ccab9ad397d99
02:45:46:99:127.0.0.1 GET /api/updates?_=1405219510134&sid=128497847ae50df7910ccab9ad397d99
02:45:48:101:127.0.0.1 GET /api/updates?_=1405219510135&sid=128497847ae50df7910ccab9ad397d99
02:45:53:101:127.0.0.1 GET /api/updates?_=1405219510136&sid=128497847ae50df7910ccab9ad397d99
02:45:58:99:127.0.0.1 GET /api/updates?_=1405219510137&sid=128497847ae50df7910ccab9ad397d99
02:46:00:101:127.0.0.1 GET /api/updates?_=1405219510138&sid=128497847ae50df7910ccab9ad397d99
02:46:05:101:127.0.0.1 GET /api/updates?_=1405219510139&sid=128497847ae50df7910ccab9ad397d99
02:46:10:99:127.0.0.1 GET /api/updates?_=1405219510140&sid=128497847ae50df7910ccab9ad397d99
02:46:13:101:127.0.0.1 GET /api/updates?_=1405219510141&sid=128497847ae50df7910ccab9ad397d99
02:46:17:99:127.0.0.1 GET /api/updates?_=1405219510142&sid=128497847ae50df7910ccab9ad397d99
02:46:23:99:127.0.0.1 GET /api/updates?_=1405219510143&sid=128497847ae50df7910ccab9ad397d99
02:46:26:99:127.0.0.1 GET /api/updates?_=1405219510144&sid=128497847ae50df7910ccab9ad397d99
02:46:29:99:127.0.0.1 GET /api/updates?_=1405219510145&sid=128497847ae50df7910ccab9ad397d99
02:46:34:101:127.0.0.1 GET /api/updates?_=1405219510146&sid=128497847ae50df7910ccab9ad397d99
02:46:36:99:127.0.0.1 GET /api/updates?_=1405219510147&sid=128497847ae50df7910ccab9ad397d99
02:46:41:99:127.0.0.1 GET /api/updates?_=1405219510148&sid=128497847ae50df7910ccab9ad397d99
02:46:46:99:127.0.0.1 GET /api/updates?_=1405219510149&sid=128497847ae50df7910ccab9ad397d99
02:46:48:99:127.0.0.1 GET /api/updates?_=1405219510150&sid=128497847ae50df7910ccab9ad397d99
02:46:52:101:127.0.0.1 GET /api/updates?_=1405219510151&sid=128497847ae50df7910ccab9ad397d99
02:46:55:101:127.0.0.1 GET /api/updates?_=1405219510152&sid=128497847ae50df7910ccab9ad397d99
02:47:00:99:127.0.0.1 GET /api/updates?_=1405219510153&sid=128497847ae50df7910ccab9ad397d99
02:47:05:101:127.0.0.1 GET /api/updates?_=1405219510154&sid=128497847ae50df7910ccab9ad397d99
02:47:09:99:127.0.0.1 GET /api/updates?_=1405219510155&sid=128497847ae50df7910ccab9ad397d99
02:52:44:WU01:FS01:0x17:Completed 3150000 out of 5000000 steps (63%)
03:02:13:WU01:FS01:0x17:Completed 3200000 out of 5000000 steps (64%)
03:11:42:WU01:FS01:0x17:Completed 3250000 out of 5000000 steps (65%)
03:21:24:WU01:FS01:0x17:Completed 3300000 out of 5000000 steps (66%)
03:30:51:WU01:FS01:0x17:Completed 3350000 out of 5000000 steps (67%)
03:40:36:WU01:FS01:0x17:Completed 3400000 out of 5000000 steps (68%)
03:50:11:WU01:FS01:0x17:Completed 3450000 out of 5000000 steps (69%)
03:54:33:104:127.0.0.1 GET /ping?_=1405223672824&callback=jQuery19007489045665618207_1405223672823
03:54:36:105:127.0.0.1 GET /?nocache=0.4959685653168643
03:54:36:106:127.0.0.1 GET /api/updates/set?_=1405223674073&sid=128497847ae50df7910ccab9ad397d99&update_id=0&update_path=/api/basic&update_rate=1
03:54:36:107:127.0.0.1 GET /api/updates/set?_=1405223674074&sid=128497847ae50df7910ccab9ad397d99&update_id=1&update_path=/api/slots&update_rate=1
03:54:36:108:127.0.0.1 GET /api/configured?_=1405223674075&sid=128497847ae50df7910ccab9ad397d99
03:54:41:112:127.0.0.1 GET /api/updates/set?_=1405223678459&sid=128497847ae50df7910ccab9ad397d99&update_id=0&update_path=/api/basic&update_rate=1
03:54:41:113:127.0.0.1 GET /api/updates/set?_=1405223678460&sid=128497847ae50df7910ccab9ad397d99&update_id=1&update_path=/api/slots&update_rate=1
03:54:41:114:127.0.0.1 GET /api/configured?_=1405223678461&sid=128497847ae50df7910ccab9ad397d99
03:54:43:116:127.0.0.1 GET /api/updates?_=1405223678462&sid=128497847ae50df7910ccab9ad397d99
03:54:44:118:127.0.0.1 GET /?nocache=0.4959685653168643
03:54:44:119:127.0.0.1 GET /?nocache=0.4959685653168643
03:54:44:120:127.0.0.1 GET /api/updates?_=1405223678463&sid=128497847ae50df7910ccab9ad397d99
03:54:45:121:127.0.0.1 GET /css/normalize.css
03:54:45:122:127.0.0.1 GET /css/main.css
03:54:46:123:127.0.0.1 GET /js/jquery-1.10.2.min.js
03:54:46:124:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
03:54:46:125:127.0.0.1 GET /js/intercom.min.js
03:54:46:126:127.0.0.1 GET /js/main.js
03:54:46:126:127.0.0.1:New Web connection
03:54:46:127:127.0.0.1 GET /images/mail.png
03:54:46:128:127.0.0.1 GET /images/facebook.png
03:54:47:130:127.0.0.1 GET /images/twitter.png
03:54:47:131:127.0.0.1 GET /images/report-bug.png
03:54:48:129:127.0.0.1 GET /api/updates/set?_=1405223687668&sid=5cc9b2899c164582563e68961ac356e7&update_id=0&update_path=/api/basic&update_rate=1
03:54:48:132:127.0.0.1 GET /images/template/bg.jpg
03:54:48:133:127.0.0.1 GET /images/template/input_radio.png
03:54:48:134:127.0.0.1 GET /images/template/button_bg.png
03:54:48:135:127.0.0.1 GET /images/template/logo_folding_home.png
03:54:48:136:127.0.0.1 GET /api/updates/set?_=1405223687669&sid=5cc9b2899c164582563e68961ac356e7&update_id=1&update_path=/api/slots&update_rate=1
03:54:48:137:127.0.0.1 GET /api/configured?_=1405223687670&sid=5cc9b2899c164582563e68961ac356e7
03:54:48:138:127.0.0.1 GET /images/template/ui-progress-bg.png
03:54:48:139:127.0.0.1 GET /images/template/ui-icon-slider.png
03:54:49:140:127.0.0.1 GET /api/updates?_=1405223687671&sid=5cc9b2899c164582563e68961ac356e7
03:54:49:141:127.0.0.1 GET /images/template/ui-bg-slider.png
03:54:50:140:127.0.0.1 GET /api/updates?_=1405223687675&sid=5cc9b2899c164582563e68961ac356e7
03:54:50:142:127.0.0.1 GET /images/template/select-icons.png
03:54:50:143:127.0.0.1 GET /images/template/anim_arrow.gif
03:54:52:144:127.0.0.1 GET /api/updates?_=1405223687676&sid=5cc9b2899c164582563e68961ac356e7
03:54:55:144:127.0.0.1 GET /api/updates?_=1405223687677&sid=5cc9b2899c164582563e68961ac356e7
03:54:58:140:127.0.0.1 GET /api/updates?_=1405223687678&sid=5cc9b2899c164582563e68961ac356e7
03:55:00:144:127.0.0.1 GET /api/updates?_=1405223687679&sid=5cc9b2899c164582563e68961ac356e7
03:55:03:144:127.0.0.1 GET /api/updates?_=1405223687680&sid=5cc9b2899c164582563e68961ac356e7
03:55:05:144:127.0.0.1 GET /api/updates?_=1405223687681&sid=5cc9b2899c164582563e68961ac356e7
03:55:08:140:127.0.0.1 GET /api/updates?_=1405223687682&sid=5cc9b2899c164582563e68961ac356e7
03:55:09:140:127.0.0.1 GET /api/updates?_=1405223687683&sid=5cc9b2899c164582563e68961ac356e7
03:55:10:144:127.0.0.1 GET /api/updates?_=1405223687684&sid=5cc9b2899c164582563e68961ac356e7
03:55:12:140:127.0.0.1 GET /api/updates?_=1405223687685&sid=5cc9b2899c164582563e68961ac356e7
03:55:14:144:127.0.0.1 GET /api/updates?_=1405223687686&sid=5cc9b2899c164582563e68961ac356e7
03:55:15:144:127.0.0.1 GET /api/updates?_=1405223687687&sid=5cc9b2899c164582563e68961ac356e7
03:55:17:140:127.0.0.1 GET /api/updates?_=1405223687688&sid=5cc9b2899c164582563e68961ac356e7
03:55:20:140:127.0.0.1 GET /api/updates?_=1405223687689&sid=5cc9b2899c164582563e68961ac356e7
03:55:23:144:127.0.0.1 GET /api/updates?_=1405223687690&sid=5cc9b2899c164582563e68961ac356e7
03:55:25:144:127.0.0.1 GET /api/updates?_=1405223687691&sid=5cc9b2899c164582563e68961ac356e7
03:55:30:140:127.0.0.1 GET /api/updates?_=1405223687692&sid=5cc9b2899c164582563e68961ac356e7
03:55:32:144:127.0.0.1 GET /api/updates?_=1405223687693&sid=5cc9b2899c164582563e68961ac356e7
03:55:35:144:127.0.0.1 GET /api/updates?_=1405223687694&sid=5cc9b2899c164582563e68961ac356e7
03:55:38:140:127.0.0.1 GET /api/updates?_=1405223687695&sid=5cc9b2899c164582563e68961ac356e7
03:55:40:144:127.0.0.1 GET /api/updates?_=1405223687696&sid=5cc9b2899c164582563e68961ac356e7
03:55:43:144:127.0.0.1 GET /api/updates?_=1405223687697&sid=5cc9b2899c164582563e68961ac356e7
03:55:46:140:127.0.0.1 GET /api/updates?_=1405223687698&sid=5cc9b2899c164582563e68961ac356e7
03:55:47:140:127.0.0.1 GET /api/updates?_=1405223687699&sid=5cc9b2899c164582563e68961ac356e7
03:55:52:140:127.0.0.1 GET /api/updates?_=1405223687700&sid=5cc9b2899c164582563e68961ac356e7
03:55:55:140:127.0.0.1 GET /api/updates?_=1405223687701&sid=5cc9b2899c164582563e68961ac356e7
03:55:57:144:127.0.0.1 GET /api/updates?_=1405223687702&sid=5cc9b2899c164582563e68961ac356e7
03:56:00:144:127.0.0.1 GET /api/updates?_=1405223687703&sid=5cc9b2899c164582563e68961ac356e7
03:56:05:140:127.0.0.1 GET /api/updates?_=1405223687704&sid=5cc9b2899c164582563e68961ac356e7
03:56:09:144:127.0.0.1 GET /api/updates?_=1405223687705&sid=5cc9b2899c164582563e68961ac356e7
03:56:12:144:127.0.0.1 GET /api/updates?_=1405223687706&sid=5cc9b2899c164582563e68961ac356e7
03:56:15:140:127.0.0.1 GET /api/updates?_=1405223687707&sid=5cc9b2899c164582563e68961ac356e7
03:56:16:140:127.0.0.1 GET /api/updates?_=1405223687708&sid=5cc9b2899c164582563e68961ac356e7
03:56:21:140:127.0.0.1 GET /api/updates?_=1405223687709&sid=5cc9b2899c164582563e68961ac356e7
03:56:24:140:127.0.0.1 GET /api/updates?_=1405223687710&sid=5cc9b2899c164582563e68961ac356e7
03:56:26:144:127.0.0.1 GET /api/updates?_=1405223687711&sid=5cc9b2899c164582563e68961ac356e7
03:56:29:144:127.0.0.1 GET /api/updates?_=1405223687712&sid=5cc9b2899c164582563e68961ac356e7
03:56:32:140:127.0.0.1 GET /api/updates?_=1405223687713&sid=5cc9b2899c164582563e68961ac356e7
03:56:33:140:127.0.0.1 GET /api/updates?_=1405223687714&sid=5cc9b2899c164582563e68961ac356e7
03:56:38:140:127.0.0.1 GET /api/updates?_=1405223687715&sid=5cc9b2899c164582563e68961ac356e7
03:56:43:140:127.0.0.1 GET /api/updates?_=1405223687716&sid=5cc9b2899c164582563e68961ac356e7
03:56:45:144:127.0.0.1 GET /api/updates?_=1405223687717&sid=5cc9b2899c164582563e68961ac356e7
03:59:44:WU01:FS01:0x17:Completed 3500000 out of 5000000 steps (70%)
04:09:31:WU01:FS01:0x17:Completed 3550000 out of 5000000 steps (71%)
04:19:07:WU01:FS01:0x17:Completed 3600000 out of 5000000 steps (72%)
04:28:54:WU01:FS01:0x17:Completed 3650000 out of 5000000 steps (73%)
04:38:32:WU01:FS01:0x17:Completed 3700000 out of 5000000 steps (74%)
04:48:10:WU01:FS01:0x17:Completed 3750000 out of 5000000 steps (75%)
04:57:57:WU01:FS01:0x17:Completed 3800000 out of 5000000 steps (76%)
05:07:34:WU01:FS01:0x17:Completed 3850000 out of 5000000 steps (77%)
05:17:22:WU01:FS01:0x17:Completed 3900000 out of 5000000 steps (78%)
05:27:00:WU01:FS01:0x17:Completed 3950000 out of 5000000 steps (79%)
05:36:37:WU01:FS01:0x17:Completed 4000000 out of 5000000 steps (80%)
05:46:26:WU01:FS01:0x17:Completed 4050000 out of 5000000 steps (81%)
05:56:05:WU01:FS01:0x17:Completed 4100000 out of 5000000 steps (82%)
******************************* Date: 2014-07-13 *******************************
06:05:56:WU01:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
06:15:33:WU01:FS01:0x17:Completed 4200000 out of 5000000 steps (84%)
06:25:11:WU01:FS01:0x17:Completed 4250000 out of 5000000 steps (85%)
06:34:59:WU01:FS01:0x17:Completed 4300000 out of 5000000 steps (86%)
06:44:36:WU01:FS01:0x17:Completed 4350000 out of 5000000 steps (87%)
06:54:29:WU01:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
07:04:07:WU01:FS01:0x17:Completed 4450000 out of 5000000 steps (89%)
07:13:44:WU01:FS01:0x17:Completed 4500000 out of 5000000 steps (90%)
07:23:38:WU01:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
07:33:17:WU01:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
07:43:05:WU01:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
07:52:42:WU01:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
08:02:18:WU01:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
08:12:11:WU01:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
08:21:47:WU01:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
08:31:40:WU01:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
08:41:18:WU01:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
08:50:55:WU01:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
08:50:56:WU00:FS01:Connecting to 171.67.108.201:80
08:50:56:WU00:FS01:Assigned to work server 140.163.4.231
08:50:56:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] from 140.163.4.231
08:50:56:WU00:FS01:Connecting to 140.163.4.231:8080
08:50:57:WU00:FS01:Downloading 4.84MiB
08:51:01:WU00:FS01:Download complete
08:51:01:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13001 run:520 clone:0 gen:20 core:0x17 unit:0x00000032538b3db7532c8f8dc74b711b
08:51:05:WU01:FS01:0x17:Saving result file logfile_01.txt
08:51:06:WU01:FS01:0x17:Saving result file checkpointState.xml
08:51:07:WU01:FS01:0x17:Saving result file checkpt.crc
08:51:07:WU01:FS01:0x17:Saving result file log.txt
08:51:07:WU01:FS01:0x17:Saving result file positions.xtc
08:51:08:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
08:51:11:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:51:11:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:13000 run:15 clone:4 gen:34 core:0x17 unit:0x0000003d538b3db7530fa06fc1eaa90f
08:51:11:WU01:FS01:Uploading 12.83MiB to 140.163.4.231
08:51:11:WU01:FS01:Connecting to 140.163.4.231:8080
08:51:11:WU00:FS01:Starting
08:51:11:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Keith/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5504 -checkpoint 9 -gpu 0 -gpu-vendor ati
08:51:11:WU00:FS01:Started FahCore on PID 7688
08:51:11:Started thread 15 on PID 5504
08:51:11:WU00:FS01:Core PID:6276
08:51:11:WU00:FS01:FahCore 0x17 started
08:51:12:WU00:FS01:0x17:*********************** Log Started 2014-07-13T08:51:11Z ***********************
08:51:12:WU00:FS01:0x17:Project: 13001 (Run 520, Clone 0, Gen 20)
08:51:12:WU00:FS01:0x17:Unit: 0x00000032538b3db7532c8f8dc74b711b
08:51:12:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
08:51:12:WU00:FS01:0x17:Machine: 1
08:51:12:WU00:FS01:0x17:Reading tar file state.xml
08:51:12:WU00:FS01:0x17:Reading tar file system.xml
08:51:12:WU00:FS01:0x17:Reading tar file integrator.xml
08:51:12:WU00:FS01:0x17:Reading tar file core.xml
08:51:12:WU00:FS01:0x17:Digital signatures verified
08:51:12:WU00:FS01:0x17:Folding@home GPU core17
08:51:12:WU00:FS01:0x17:Version 0.0.52
08:51:17:WU01:FS01:Upload 7.79%
08:51:23:WU01:FS01:Upload 11.69%
08:51:29:WU01:FS01:Upload 16.07%
08:51:35:WU01:FS01:Upload 20.46%
08:51:41:WU01:FS01:Upload 24.35%
08:51:47:WU01:FS01:Upload 28.74%
08:51:53:WU01:FS01:Upload 32.64%
08:51:59:WU01:FS01:Upload 37.02%
08:52:05:WU01:FS01:Upload 41.40%
08:52:11:WU01:FS01:Upload 45.30%
08:52:17:WU01:FS01:Upload 49.20%
08:52:23:WU01:FS01:Upload 53.58%
08:52:29:WU01:FS01:Upload 57.96%
08:52:35:WU01:FS01:Upload 61.86%
08:52:41:WU01:FS01:Upload 66.24%
08:52:47:WU01:FS01:Upload 70.63%
08:52:53:WU01:FS01:Upload 74.52%
08:52:59:WU01:FS01:Upload 78.91%
08:53:05:WU01:FS01:Upload 82.81%
08:53:11:WU01:FS01:Upload 87.19%
08:53:17:WU01:FS01:Upload 91.57%
08:53:23:WU01:FS01:Upload 95.47%
08:53:29:WU01:FS01:Upload 99.85%
08:53:45:WU01:FS01:Upload complete
08:53:45:WU01:FS01:Server responded WORK_ACK (400)
08:53:45:WU01:FS01:Final credit estimate, 48232.00 points
08:53:45:WU01:FS01:Cleaning up
09:19:54:WU00:FS01:0x17:Completed 0 out of 5000000 steps (0%)
09:19:54:WU00:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:29:37:WU00:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
09:39:11:WU00:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
09:48:54:WU00:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
09:58:27:WU00:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
10:07:55:WU00:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
10:11:04:FS01:Paused
10:11:04:FS01:Shutting core down
10:11:04:WU00:FS01:0x17:WARNING:Console control signal 1 on PID 6276
10:11:04:WU00:FS01:0x17:Exiting, please wait. . .
10:11:05:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:11:53:Removing old file 'configs/config-20140708-090619.xml'
10:11:53:Saving configuration to config.xml
10:11:53:<config>
10:11:53:  <!-- Folding Core -->
10:11:53:  <checkpoint v='9'/>
10:11:53:  <core-priority v='low'/>
10:11:53:
10:11:53:  <!-- Logging -->
10:11:53:  <verbosity v='5'/>
10:11:53:
10:11:53:  <!-- Network -->
10:11:53:  <proxy v=':8080'/>
10:11:53:
10:11:53:  <!-- Slot Control -->
10:11:53:  <pause-on-battery v='false'/>
10:11:53:
10:11:53:  <!-- User Information -->
10:11:53:  <passkey v='********************************'/>
10:11:53:  <team v='50959'/>
10:11:53:  <user v='kwerboom'/>
10:11:53:
10:11:53:  <!-- Folding Slots -->
10:11:53:  <slot id='1' type='GPU'>
10:11:53:    <paused v='true'/>
10:11:53:  </slot>
10:11:53:</config>
bollix47
Re: Missing credit for a Core 17 Work Unit
Post by bollix47 »
No points are being credited at this time due to a problem with the stats system:
viewtopic.php?p=266974#p266974
kwerboom
Post by kwerboom »
bollix47 wrote:No points are being credited at this time due to a problem with the stats system:
Thanks for the info. I hope everything updates OK when server is fixed.
