Project: 6369 (Run 7, Clone 16, Gen 10)
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
Post by SKeptical_Thinker »
This WU failed within seconds of starting. I tried restarting the client, but nothing changed. I had to dump it to move on to the next WU.
*********************** Log Started 2014-05-28T10:41:01Z ***********************
10:41:01:************************* Folding@home Client *************************
10:41:01:    Website: http://folding.stanford.edu/
10:41:01:  Copyright: (c) 2009-2014 Stanford University
10:41:01:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:41:01:       Args: --child --lifeline 1575 /etc/fahclient/config.xml --run-as
10:41:01:             fahclient --pid-file=/var/run/fahclient.pid --daemon
10:41:01:     Config: /etc/fahclient/config.xml
10:41:01:******************************** Build ********************************
10:41:01:    Version: 7.4.2
10:41:01:       Date: Jan 24 2014
10:41:01:       Time: 06:33:47
10:41:01:    SVN Rev: 4112
10:41:01:     Branch: fah/trunk/client
10:41:01:   Compiler: GNU 4.4.7
10:41:01:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
10:41:01:             -fno-unsafe-math-optimizations -msse2
10:41:01:   Platform: linux2 3.2.0-1-amd64
10:41:01:       Bits: 64
10:41:01:       Mode: Release
10:41:01:******************************* System ********************************
10:41:01:        CPU: AMD FX(tm)-8120 Eight-Core Processor
10:41:01:     CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
10:41:01:       CPUs: 8
10:41:01:     Memory: 7.75GiB
10:41:01:Free Memory: 7.31GiB
10:41:01:    Threads: POSIX_THREADS
10:41:01: OS Version: 3.13
10:41:01:Has Battery: false
10:41:01: On Battery: false
10:41:01: UTC Offset: -4
10:41:01:        PID: 1577
10:41:01:        CWD: /var/lib/fahclient
10:41:01:         OS: Linux 3.13.0-24-generic x86_64
10:41:01:    OS Arch: AMD64
10:41:01:       GPUs: 0
10:41:01:       CUDA: Not detected
10:41:01:***********************************************************************
10:41:01:<config>
10:41:01:  <!-- Folding Slot Configuration -->
10:41:01:  <client-type v='advanced'/>
10:41:01:
10:41:01:  <!-- HTTP Server -->
10:41:01:  <allow v='127.0.0.1 192.168.0.0/16'/>
10:41:01:
10:41:01:  <!-- Network -->
10:41:01:  <proxy v=':8080'/>
10:41:01:
10:41:01:  <!-- Remote Command Server -->
10:41:01:  <command-allow-no-pass v='127.0.0.1 192.168.0.0/16'/>
10:41:01:
10:41:01:  <!-- Slot Control -->
10:41:01:  <power v='full'/>
10:41:01:
10:41:01:  <!-- User Information -->
10:41:01:  <passkey v='********************************'/>
10:41:01:  <team v='31574'/>
10:41:01:  <user v='SKeptical_Thinker'/>
10:41:01:
10:41:01:  <!-- Work Unit Control -->
10:41:01:  <next-unit-percentage v='100'/>
10:41:01:
10:41:01:  <!-- Folding Slots -->
10:41:01:  <slot id='0' type='CPU'>
10:41:01:    <cpus v='8'/>
10:41:01:  </slot>
10:41:01:</config>
10:41:01:Switching to user fahclient
10:41:01:Trying to access database...
10:41:01:Successfully acquired database lock
10:41:01:Enabled folding slot 00: READY cpu:8
10:41:01:WU00:FS00:Starting
10:41:01:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
10:41:01:WU00:FS00:Started FahCore on PID 1586
10:41:01:WU00:FS00:Core PID:1590
10:41:01:WU00:FS00:FahCore 0xa4 started
10:41:02:WU00:FS00:0xa4:
10:41:02:WU00:FS00:0xa4:*------------------------------*
10:41:02:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
10:41:02:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:41:02:WU00:FS00:0xa4:Preparing to commence simulation
10:41:02:WU00:FS00:0xa4:- Looking at optimizations...
10:41:02:WU00:FS00:0xa4:- Files status OK
10:41:02:WU00:FS00:0xa4:- Expanded 2312631 -> 3276000 (decompressed 141.6 percent)
10:41:02:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=2312631 data_size=3276000, decompressed_data_size=3276000 diff=0
10:41:02:WU00:FS00:0xa4:- Digital signature verified
10:41:02:WU00:FS00:0xa4:Project: 7520 (Run 28, Clone 1, Gen 350)
10:41:02:WU00:FS00:0xa4:Assembly optimizations on if available.
10:41:02:WU00:FS00:0xa4:Entering M.D.
10:41:08:WU00:FS00:0xa4:Using Gromacs checkpoints
10:41:09:WU00:FS00:0xa4:Resuming from checkpoint
10:41:09:WU00:FS00:0xa4:Verified 00/wudata_01.log
10:41:09:WU00:FS00:0xa4:Verified 00/wudata_01.trr
10:41:09:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
10:41:09:WU00:FS00:0xa4:Verified 00/wudata_01.edr
10:41:09:WU00:FS00:0xa4:Completed 47380 out of 500000 steps  (9%)
10:43:39:WU00:FS00:0xa4:Completed 50000 out of 500000 steps  (10%)
10:48:26:WU00:FS00:0xa4:Completed 55000 out of 500000 steps  (11%)
******************************* Date: 2014-05-28 *******************************
				Many WUs completed
******************************* Date: 2014-06-05 *******************************
23:00:49:WU01:FS00:0xa4:Completed 490000 out of 500000 steps  (98%)
23:05:53:WU01:FS00:0xa4:Completed 495000 out of 500000 steps  (99%)
23:10:57:WU01:FS00:0xa4:Completed 500000 out of 500000 steps  (100%)
23:10:58:WU00:FS00:Connecting to assign3.stanford.edu:8080
23:10:58:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
23:11:08:WU01:FS00:0xa4:
23:11:08:WU01:FS00:0xa4:Finished Work Unit:
23:11:08:WU01:FS00:0xa4:- Reading up to 7067808 from "01/wudata_01.trr": Read 7067808
23:11:08:WU01:FS00:0xa4:trr file hash check passed.
23:11:08:WU01:FS00:0xa4:- Reading up to 7578436 from "01/wudata_01.xtc": Read 7578436
23:11:08:WU01:FS00:0xa4:xtc file hash check passed.
23:11:08:WU01:FS00:0xa4:edr file hash check passed.
23:11:08:WU01:FS00:0xa4:logfile size: 337845
23:11:08:WU01:FS00:0xa4:Leaving Run
23:11:09:WU01:FS00:0xa4:- Writing 15017117 bytes of core data to disk...
23:11:11:WU01:FS00:0xa4:Done: 15016605 -> 14328995 (compressed to 95.4 percent)
23:11:11:WU01:FS00:0xa4:  ... Done.
[93m23:13:10:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:13:10:WU00:FS00:Connecting to assign4.stanford.edu:80
23:14:59:WU01:FS00:0xa4:- Shutting down core
23:14:59:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
[93m23:15:17:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:15:17:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
23:15:18:WU00:FS00:Connecting to assign3.stanford.edu:8080
23:15:19:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:15:19:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
23:15:19:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
23:15:19:WU01:FS00:Connecting to 128.143.199.97:8080
[93m23:17:25:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:17:25:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m23:17:26:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:17:26:WU01:FS00:Connecting to 128.143.199.97:80
[93m23:19:33:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:19:33:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
23:19:33:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m23:19:34:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
23:19:34:WU01:FS00:Trying to send results to collection server
23:19:34:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
23:19:34:WU01:FS00:Connecting to 128.143.231.202:8080
[93m23:21:40:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:21:40:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m23:21:41:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:21:41:WU01:FS00:Connecting to 128.143.231.202:80
[93m23:23:47:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:23:47:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
23:23:48:WU00:FS00:Connecting to assign3.stanford.edu:8080
[91m23:23:48:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
23:23:48:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
23:23:48:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
23:23:48:WU01:FS00:Connecting to 128.143.199.97:8080
[93m23:25:55:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:25:55:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m23:25:56:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:25:56:WU01:FS00:Connecting to 128.143.199.97:80
[93m23:28:02:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:28:02:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
23:28:03:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m23:28:03:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
23:28:03:WU01:FS00:Trying to send results to collection server
23:28:03:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
23:28:03:WU01:FS00:Connecting to 128.143.231.202:8080
[93m23:30:10:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:30:10:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m23:30:10:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:30:10:WU01:FS00:Connecting to 128.143.231.202:80
[91m23:32:18:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
23:32:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
23:32:18:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
23:32:18:WU01:FS00:Connecting to 128.143.199.97:8080
[93m23:32:23:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:32:23:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
23:32:23:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m23:34:25:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:34:25:WU01:FS00:Connecting to 128.143.199.97:80
[93m23:34:35:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:34:35:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m23:36:33:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
23:36:33:WU01:FS00:Trying to send results to collection server
23:36:33:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
23:36:33:WU01:FS00:Connecting to 128.143.231.202:8080
[93m23:36:42:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:36:42:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
[93m23:38:40:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:38:40:WU01:FS00:Connecting to 128.143.231.202:80
23:39:14:WU00:FS00:Connecting to assign3.stanford.edu:8080
[91m23:40:47:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
23:40:48:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
23:40:48:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
23:40:48:WU01:FS00:Connecting to 128.143.199.97:8080
[93m23:41:21:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:41:21:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m23:42:55:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:42:55:WU01:FS00:Connecting to 128.143.199.97:80
[93m23:43:29:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:43:29:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
[93m23:45:02:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
23:45:02:WU01:FS00:Trying to send results to collection server
23:45:02:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
23:45:02:WU01:FS00:Connecting to 128.143.231.202:8080
[93m23:47:10:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:47:10:WU01:FS00:Connecting to 128.143.231.202:80
[91m23:49:17:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
23:49:17:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
23:49:17:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
23:49:17:WU01:FS00:Connecting to 128.143.199.97:8080
23:50:20:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m23:51:24:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:51:24:WU01:FS00:Connecting to 128.143.199.97:80
[93m23:52:27:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
23:52:27:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m23:53:32:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
23:53:32:WU01:FS00:Trying to send results to collection server
23:53:32:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
23:53:32:WU01:FS00:Connecting to 128.143.231.202:8080
[93m23:54:34:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m23:54:34:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
[93m23:55:39:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:55:39:WU01:FS00:Connecting to 128.143.231.202:80
[91m23:57:46:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
23:57:47:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
23:57:47:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
23:57:47:WU01:FS00:Connecting to 128.143.199.97:8080
[93m23:59:54:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
23:59:54:WU01:FS00:Connecting to 128.143.199.97:80
[93m00:02:01:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
00:02:01:WU01:FS00:Trying to send results to collection server
00:02:01:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
00:02:01:WU01:FS00:Connecting to 128.143.231.202:8080
[93m00:04:08:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
00:04:08:WU01:FS00:Connecting to 128.143.231.202:80
[91m00:06:16:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
00:06:16:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
00:06:16:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
00:06:16:WU01:FS00:Connecting to 128.143.199.97:8080
00:08:17:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m00:08:23:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
00:08:23:WU01:FS00:Connecting to 128.143.199.97:80
[93m00:10:24:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
00:10:24:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m00:10:31:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
00:10:31:WU01:FS00:Trying to send results to collection server
00:10:31:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
00:10:31:WU01:FS00:Connecting to 128.143.231.202:8080
[93m00:12:31:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m00:12:31:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
[93m00:12:38:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
00:12:38:WU01:FS00:Connecting to 128.143.231.202:80
[91m00:14:45:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
00:17:21:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
00:17:21:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
00:17:21:WU01:FS00:Connecting to 128.143.199.97:8080
[93m00:19:29:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
00:19:29:WU01:FS00:Connecting to 128.143.199.97:80
[93m00:21:36:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
00:21:36:WU01:FS00:Trying to send results to collection server
00:21:36:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
00:21:36:WU01:FS00:Connecting to 128.143.231.202:8080
[93m00:23:43:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
00:23:43:WU01:FS00:Connecting to 128.143.231.202:80
[91m00:25:51:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
00:35:18:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
00:35:18:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
00:35:18:WU01:FS00:Connecting to 128.143.199.97:8080
00:37:19:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m00:37:26:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
00:37:26:WU01:FS00:Connecting to 128.143.199.97:80
[93m00:39:26:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
00:39:26:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m00:39:33:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
00:39:33:WU01:FS00:Trying to send results to collection server
00:39:33:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
00:39:33:WU01:FS00:Connecting to 128.143.231.202:8080
[93m00:41:34:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m00:41:34:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
[93m00:41:40:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
00:41:40:WU01:FS00:Connecting to 128.143.231.202:80
[91m00:43:48:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
01:04:21:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
01:04:21:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
01:04:21:WU01:FS00:Connecting to 128.143.199.97:8080
[93m01:06:28:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
01:06:28:WU01:FS00:Connecting to 128.143.199.97:80
[93m01:08:35:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.143.199.97:80: Connection timed out[0m
01:08:35:WU01:FS00:Trying to send results to collection server
01:08:35:WU01:FS00:Uploading 13.67MiB to 128.143.231.202
01:08:35:WU01:FS00:Connecting to 128.143.231.202:8080
[93m01:10:42:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80[0m
01:10:42:WU01:FS00:Connecting to 128.143.231.202:80
[91m01:12:50:ERROR:WU01:FS00:Exception: Failed to connect to 128.143.231.202:80: Connection timed out[0m
01:24:18:WU00:FS00:Connecting to assign3.stanford.edu:8080
[93m01:26:25:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: Connection timed out[0m
01:26:25:WU00:FS00:Connecting to assign4.stanford.edu:80
[93m01:28:32:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: Connection timed out[0m
[91m01:28:32:ERROR:WU00:FS00:Exception: Could not get an assignment[0m
01:50:58:FS00:Paused
01:51:03:FS00:Unpaused
01:51:03:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:7520 run:107 clone:5 gen:48 core:0xa4 unit:0x00000035fbcb017d51229ad31b73828d
01:51:04:WU01:FS00:Uploading 13.67MiB to 128.143.199.97
01:51:04:WU01:FS00:Connecting to 128.143.199.97:8080
01:51:04:WU00:FS00:Connecting to assign3.stanford.edu:8080
01:51:16:WU00:FS00:Assigned to work server 155.247.166.219
01:51:16:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 155.247.166.219
01:51:16:WU00:FS00:Connecting to 155.247.166.219:8080
01:51:19:WU01:FS00:Upload 0.46%
01:51:23:WU00:FS00:Downloading 15.25KiB
01:51:25:WU01:FS00:Upload 1.37%
01:51:31:WU01:FS00:Upload 2.74%
01:51:39:WU00:FS00:Download 100.00%
01:51:39:WU00:FS00:Download complete
01:51:39:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6369 run:7 clone:16 gen:10 core:0xa4 unit:0x0000000d0002894b532766c08f5826c6
01:51:39:WU00:FS00:Starting
01:51:39:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:51:39:WU00:FS00:Started FahCore on PID 6480
01:51:39:WU00:FS00:Core PID:6484
01:51:39:WU00:FS00:FahCore 0xa4 started
01:51:40:WU00:FS00:0xa4:
01:51:40:WU00:FS00:0xa4:*------------------------------*
01:51:40:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:51:40:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:51:40:WU00:FS00:0xa4:Preparing to commence simulation
01:51:40:WU00:FS00:0xa4:- Looking at optimizations...
01:51:40:WU00:FS00:0xa4:- Created dyn
01:51:40:WU00:FS00:0xa4:- Files status OK
01:51:40:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:51:40:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:51:40:WU00:FS00:0xa4:- Digital signature verified
01:51:40:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:51:40:WU00:FS00:0xa4:Assembly optimizations on if available.
01:51:40:WU00:FS00:0xa4:Entering M.D.
01:51:40:WU01:FS00:Upload 4.57%
01:51:46:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:51:46:WU00:FS00:Starting
01:51:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:51:46:WU00:FS00:Started FahCore on PID 6496
01:51:46:WU00:FS00:Core PID:6500
01:51:46:WU00:FS00:FahCore 0xa4 started
01:51:47:WU00:FS00:0xa4:
01:51:47:WU00:FS00:0xa4:*------------------------------*
01:51:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:51:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:51:47:WU00:FS00:0xa4:Preparing to commence simulation
01:51:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
01:51:47:WU01:FS00:Upload 5.95%
01:51:53:WU01:FS00:Upload 7.32%
01:51:56:WU00:FS00:0xa4:- Looking at optimizations...
01:51:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
01:51:56:WU00:FS00:0xa4:- Previous termination of core was improper.
01:51:56:WU00:FS00:0xa4:- Files status OK
01:51:56:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:51:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:51:56:WU00:FS00:0xa4:- Digital signature verified
01:51:56:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:51:56:WU00:FS00:0xa4:Entering M.D.
01:52:00:WU01:FS00:Upload 9.15%
01:52:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:52:06:WU01:FS00:Upload 11.43%
01:52:12:WU01:FS00:Upload 13.72%
01:52:18:WU01:FS00:Upload 16.92%
01:52:25:WU01:FS00:Upload 19.21%
01:52:31:WU01:FS00:Upload 21.50%
01:52:37:WU01:FS00:Upload 24.24%
01:52:43:WU01:FS00:Upload 26.53%
01:52:46:WU00:FS00:Starting
01:52:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:52:46:WU00:FS00:Started FahCore on PID 6513
01:52:46:WU00:FS00:Core PID:6517
01:52:46:WU00:FS00:FahCore 0xa4 started
01:52:47:WU00:FS00:0xa4:
01:52:47:WU00:FS00:0xa4:*------------------------------*
01:52:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:52:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:52:47:WU00:FS00:0xa4:Preparing to commence simulation
01:52:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
01:52:49:WU01:FS00:Upload 28.81%
01:52:56:WU00:FS00:0xa4:- Looking at optimizations...
01:52:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
01:52:56:WU00:FS00:0xa4:- Previous termination of core was improper.
01:52:56:WU00:FS00:0xa4:- Going to use standard loops.
01:52:56:WU00:FS00:0xa4:- Files status OK
01:52:56:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:52:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:52:56:WU00:FS00:0xa4:- Digital signature verified
01:52:56:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:52:56:WU00:FS00:0xa4:Entering M.D.
01:52:57:WU01:FS00:Upload 31.10%
01:53:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:53:03:WU01:FS00:Upload 33.39%
01:53:09:WU01:FS00:Upload 35.67%
01:53:17:WU01:FS00:Upload 37.50%
01:53:23:WU01:FS00:Upload 38.87%
01:53:29:WU01:FS00:Upload 40.25%
01:53:35:WU01:FS00:Upload 41.62%
01:53:42:WU01:FS00:Upload 43.45%
01:53:46:WU00:FS00:Starting
01:53:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:53:46:WU00:FS00:Started FahCore on PID 6530
01:53:46:WU00:FS00:Core PID:6534
01:53:46:WU00:FS00:FahCore 0xa4 started
01:53:47:WU00:FS00:0xa4:
01:53:47:WU00:FS00:0xa4:*------------------------------*
01:53:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:53:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:53:47:WU00:FS00:0xa4:Preparing to commence simulation
01:53:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
01:53:48:WU01:FS00:Upload 45.28%
01:53:55:WU01:FS00:Upload 46.65%
01:53:56:WU00:FS00:0xa4:- Looking at optimizations...
01:53:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
01:53:56:WU00:FS00:0xa4:- Previous termination of core was improper.
01:53:56:WU00:FS00:0xa4:- Going to use standard loops.
01:53:56:WU00:FS00:0xa4:- Files status OK
01:53:56:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:53:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:53:56:WU00:FS00:0xa4:- Digital signature verified
01:53:56:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:53:56:WU00:FS00:0xa4:Entering M.D.
01:54:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:54:04:WU01:FS00:Upload 48.94%
01:54:11:WU01:FS00:Upload 51.22%
01:54:17:WU01:FS00:Upload 53.05%
01:54:23:WU01:FS00:Upload 54.42%
01:54:29:WU01:FS00:Upload 55.80%
01:54:35:WU01:FS00:Upload 57.17%
01:54:41:WU01:FS00:Upload 60.83%
01:54:46:WU00:FS00:Starting
01:54:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:54:46:WU00:FS00:Started FahCore on PID 6548
01:54:46:WU00:FS00:Core PID:6552
01:54:46:WU00:FS00:FahCore 0xa4 started
01:54:47:WU00:FS00:0xa4:
01:54:47:WU00:FS00:0xa4:*------------------------------*
01:54:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:54:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:54:47:WU00:FS00:0xa4:Preparing to commence simulation
01:54:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
01:54:49:WU01:FS00:Upload 65.86%
01:54:55:WU01:FS00:Upload 69.52%
01:54:56:WU00:FS00:0xa4:- Looking at optimizations...
01:54:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
01:54:56:WU00:FS00:0xa4:- Previous termination of core was improper.
01:54:56:WU00:FS00:0xa4:- Going to use standard loops.
01:54:56:WU00:FS00:0xa4:- Files status OK
01:54:56:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:54:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:54:56:WU00:FS00:0xa4:- Digital signature verified
01:54:56:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:54:56:WU00:FS00:0xa4:Entering M.D.
01:55:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:55:03:WU01:FS00:Upload 74.09%
01:55:10:WU01:FS00:Upload 79.12%
01:55:18:WU01:FS00:Upload 83.24%
01:55:24:WU01:FS00:Upload 87.35%
01:55:30:WU01:FS00:Upload 91.93%
01:55:36:WU01:FS00:Upload 94.67%
01:55:42:WU01:FS00:Upload 97.87%
01:55:46:WU00:FS00:Starting
01:55:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:55:46:WU00:FS00:Started FahCore on PID 6565
01:55:46:WU00:FS00:Core PID:6569
01:55:46:WU00:FS00:FahCore 0xa4 started
01:55:47:WU00:FS00:0xa4:
01:55:47:WU00:FS00:0xa4:*------------------------------*
01:55:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:55:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:55:47:WU00:FS00:0xa4:Preparing to commence simulation
01:55:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
01:55:49:WU01:FS00:Upload complete
01:55:49:WU01:FS00:Server responded WORK_ACK (400)
01:55:49:WU01:FS00:Final credit estimate, 5850.00 points
01:55:49:WU01:FS00:Cleaning up
01:55:56:WU00:FS00:0xa4:- Looking at optimizations...
01:55:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
01:55:56:WU00:FS00:0xa4:- Previous termination of core was improper.
01:55:56:WU00:FS00:0xa4:- Going to use standard loops.
01:55:56:WU00:FS00:0xa4:- Files status OK
01:55:56:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:55:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:55:56:WU00:FS00:0xa4:- Digital signature verified
01:55:56:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:55:56:WU00:FS00:0xa4:Entering M.D.
01:56:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:56:46:WU00:FS00:Starting
01:56:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:56:46:WU00:FS00:Started FahCore on PID 6583
01:56:46:WU00:FS00:Core PID:6587
01:56:46:WU00:FS00:FahCore 0xa4 started
01:56:47:WU00:FS00:0xa4:
01:56:47:WU00:FS00:0xa4:*------------------------------*
01:56:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:56:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:56:47:WU00:FS00:0xa4:Preparing to commence simulation
01:56:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
01:56:56:WU00:FS00:0xa4:- Looking at optimizations...
01:56:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
01:56:56:WU00:FS00:0xa4:- Previous termination of core was improper.
01:56:56:WU00:FS00:0xa4:- Going to use standard loops.
01:56:56:WU00:FS00:0xa4:- Files status OK
01:56:56:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:56:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:56:56:WU00:FS00:0xa4:- Digital signature verified
01:56:56:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:56:56:WU00:FS00:0xa4:Entering M.D.
01:57:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
01:57:46:WU00:FS00:Starting
01:57:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
01:57:46:WU00:FS00:Started FahCore on PID 6604
01:57:46:WU00:FS00:Core PID:6608
01:57:46:WU00:FS00:FahCore 0xa4 started
01:57:47:WU00:FS00:0xa4:
01:57:47:WU00:FS00:0xa4:*------------------------------*
01:57:47:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:57:47:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:57:47:WU00:FS00:0xa4:Preparing to commence simulation
01:57:47:WU00:FS00:0xa4:- Ensuring status. Please wait.
01:57:56:WU00:FS00:0xa4:- Looking at optimizations...
01:57:56:WU00:FS00:0xa4:- Working with standard loops on this execution.
01:57:56:WU00:FS00:0xa4:- Previous termination of core was improper.
01:57:56:WU00:FS00:0xa4:- Going to use standard loops.
01:57:56:WU00:FS00:0xa4:- Files status OK
01:57:56:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
01:57:56:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
01:57:56:WU00:FS00:0xa4:- Digital signature verified
01:57:56:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
01:57:56:WU00:FS00:0xa4:Entering M.D.
01:58:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
******************************* Date: 2014-06-06 *******************************
******************************* Date: 2014-06-07 *******************************
04:59:00:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:59:44:WU00:FS00:Starting
04:59:44:WU00:FS00:Removing old file './work/00/logfile_01-20140607-042743.txt'
04:59:44:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1577 -checkpoint 15 -np 8
04:59:44:WU00:FS00:Started FahCore on PID 3301
04:59:44:WU00:FS00:Core PID:3305
04:59:44:WU00:FS00:FahCore 0xa4 started
04:59:45:WU00:FS00:0xa4:
04:59:45:WU00:FS00:0xa4:*------------------------------*
04:59:45:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
04:59:45:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
04:59:45:WU00:FS00:0xa4:Preparing to commence simulation
04:59:45:WU00:FS00:0xa4:- Ensuring status. Please wait.
04:59:54:WU00:FS00:0xa4:- Looking at optimizations...
04:59:54:WU00:FS00:0xa4:- Working with standard loops on this execution.
04:59:54:WU00:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
04:59:54:WU00:FS00:0xa4:- Expanded 15109 -> 266072 (decompressed 1761.0 percent)
04:59:54:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=15109 data_size=266072, decompressed_data_size=266072 diff=0
04:59:54:WU00:FS00:0xa4:- Digital signature verified
04:59:54:WU00:FS00:0xa4:Project: 6369 (Run 7, Clone 16, Gen 10)
04:59:54:WU00:FS00:0xa4:Entering M.D.
05:00:00:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
bollix47
Re: Project: 6369 (Run 7, Clone 16, Gen 10)
Post by bollix47 »
Another folder was able to complete the WU successfully:
Hi xxxx (team xxxx),
Your WU (P6369 R7 C16 G10) was added to the stats database on 2014-06-16 12:10:53 for 1173.39 points of credit.
