GTX770, Linux - < 50% utilization
csvanefalk
Post by csvanefalk »
UPDATE: As has been pointed out by several posters, the percentage displayed by nvidia-smi is most likely the fan utilization, NOT the GPU itself. My bad. For now I am looking to get the maximum efficiency out of the GPU itself.
I just recently returned to folding, and discovered that GPU folding on Linux is finally natively supported.
I am trying to get my GTX770 to fold - all is working fine, but nvidia-smi shows the GPU as being (seemingly) underused:
| NVIDIA-SMI 331.67     Driver Version: 331.67         |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 770     Off  | 0000:03:00.0     N/A |                  N/A |
| 43%   61C  N/A     N/A /  N/A |    407MiB /  2047MiB |     N/A      Default |
| Compute processes:                                               GPU Memory |
|  GPU       PID  Process name                                     Usage      |
|    0            Not Supported                                               |
My config is vanilla, the only change was to disable the CPU slot. The performance slider is also set to Full.
  <!-- Folding Core -->
  <core-priority v='low'/>
  <gpu v='false'/>
  <!-- Logging -->
  <verbosity v='5'/>
  <!-- Network -->
  <proxy v=':8080'/>
  <!-- Slot Control -->
  <power v='full'/>
  <!-- User Information -->
  <passkey v='xxxxxxxxxxxxxxxxxxxxxxxxxxxx'/>
  <user v='svanefalk'/>
  <!-- Folding Slots -->
  <slot id='1' type='GPU'/>
An initial thought was throttling due to temps (60C at 40% is pretty high). Another concern is that Compute Processes is not showing anything. Is that normal?
Apart from that, any ideas on how I can ramp it up?
Nicolas_orleans
Re: GTX770, Linux - < 50% utilization
Post by Nicolas_orleans »
For non GK 110 nvidia cards, drivers above 319.x and 325.x do not fold well with current core 17. There is a new core under beta testing for Windows that appears to solve the issue.
Since you are folding on linux I would recommend to install either 319.x or 325.15 (I am using this one on a dual GTX 770 Ubuntu 13.04 rig)
Please note that with 319.x or 325.15 you will need to reboot the computer every 36 hours to avoid the TDR bug of those drivers.
AORUS Elite X AX B650E- Ryzen 9 9950X - Inno3D RTX 5080 - Ubuntu 25.04 - 6.14 kernel - 580.95
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super - Ubuntu 25.04 - 6.14 kernel - 580.95
FYI, in your config.xml, you have this setting:
<!-- Logging -->
<verbosity v='5'/>
I would suggest that you change it to the default value of 3 since any higher value means that all default values will be printed in the log file which makes it harder to troubleshoot. With the default setting, only changed values will be printed in the log file which makes it easy to spot any changes and troubleshoot.
Again, the v55 beta core 17 uses a workaround for a problem in the NV driver. It should not be considered a "fix."
davidcoton
Post by davidcoton »
I think the display you have included is showing the fan at 43%. I don't see a figure for GPU utilisation. The nVidia X-server app lists GPU utilisation on the GPU page.
What PPD are you getting? (Final figure, or estimate after at least 5% of the WU is done)
If the card is not a GK110, then a pre-327 driver with regular reboots will help.
David
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
I must be missing something for the only numbers I see given below 50% is the GPU fan at 43%.
csvanefalk
I am getting around 40k/day as of now, I assume that is reasonable?
Should I be concerned about CUDA not being found on the system?
davidcoton
CUDA is not used by Core17. However it should be installed with nVidia drivers. So it should be found. Where did you get the drivers from? Try getting a version direct from nVidia, one of the versions referenced above. And posting the full log (from the beginning to folding started) would help too.
David
Nicolas_orleans
csvanefalk wrote:I am getting around 40k/day as of now, I assume that is reasonable?
Based on my experience, with proper drivers and Core 17 (with QRB), a GTX770 will get in average 90-95k PPD, depending on WU and project, it can actually vary between 78k and 124k PPD.
(edit : added information regarding the core)
Last edited by Nicolas_orleans on Thu Jun 05, 2014 6:03 am, edited 1 time in total.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
The PPD can vary drastically depending on the individual project being folded. The best examples for your video card would be folding a QRB Core_17 WU which gives lots of bonus points for quick return and a Core_11 or Core_15 project that do not give bonus points. With folding running perfectly, I can easily see you getting 1/2 the normal Core_17 points by merely running a Core_15 project.
You have little control over what project you receive. It is just the luck of the draw and everyone is in the same boat in this respect.
rwh202
3x GTX 1080 Ti
3x GTX 1060
Various other bits and pieces
Post by rwh202 »
P5-133XL wrote:The PPD can vary drastically depending on the individual project being folded. The best examples for your video card would be folding a QRB Core_17 WU which gives lots of bonus points for quick return and a Core_11 or Core_15 project that do not give bonus points. With folding running perfectly, I can easily see you getting 1/2 the normal Core_17 points by merely running a Core_15 project.
But linux is core_17 only so something else is halving the ppd.
Core_17 typically requires a full cpu's utilisation - you've removed the CPU folding slot but is anything else compute heavy running?
csvanefalk
Thanks to everyone for the replies and help so far. As has been pointed out by several posters, the percentage displayed by nvidia-smi is most likely the fan utilization, NOT the GPU itself. My bad. For now I am looking to get the maximum efficiency out of the GPU itself.
A small update: after letting the card chew away uninterruptedly for the last 12 hours, FAHControl is estimating 50k PPD (I am aware that FAHControl is not really the best way to estimate PPD, but its where I got the last value as well).
davidcoton wrote: CUDA is not used by Core17. However it should be installed with nVidia drivers. So it should be found. Where did you get the drivers from? Try getting a version direct from nVidia, one of the versions referenced above.
The drivers are from rpmfusion, I am running Fedora 20, and from what I can see that is the best way to get them. Normally I would be using Nouveau - I got the prop drivers to fold on the card.
rwh202 wrote:Core_17 typically requires a full cpu's utilisation - you've removed the CPU folding slot but is anything else compute heavy running?
Apart from my IDE running regular builds etc, nothing else is eating too much of the CPU. Top shows FahCore_17 occupying one of the cores constantly, so that should be alright.
davidcoton wrote: And posting the full log (from the beginning to folding started) would help too.
Here goes.
*********************** Log Started 2014-06-04T16:26:45Z ***********************
16:26:45:Started thread 1 on PID 1620
16:26:45:************************* Folding@home Client *************************
16:26:45:    Website: http://folding.stanford.edu/
16:26:45:  Copyright: (c) 2009-2014 Stanford University
16:26:45:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:26:45:       Args: --child --lifeline 1617 /etc/fahclient/config.xml --run-as
16:26:45:             fahclient --pid-file=/var/run/fahclient.pid --daemon
16:26:45:     Config: /etc/fahclient/config.xml
16:26:45:******************************** Build ********************************
16:26:45:    Version: 7.4.4
16:26:45:       Date: Mar 4 2014
16:26:45:       Time: 12:01:17
16:26:45:    SVN Rev: 4130
16:26:45:     Branch: fah/trunk/client
16:26:45:   Compiler: GNU 4.1.2 20080704 (Red Hat 4.1.2-46)
16:26:45:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
16:26:45:             -fno-unsafe-math-optimizations -msse2
16:26:45:   Platform: linux2 2.6.18-164.11.1.el5
16:26:45:       Bits: 64
16:26:45:       Mode: Release
16:26:45:******************************* System ********************************
16:26:45:        CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
16:26:45:     CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
16:26:45:       CPUs: 12
16:26:45:     Memory: 15.62GiB
16:26:45:Free Memory: 14.81GiB
16:26:45:    Threads: POSIX_THREADS
16:26:45: OS Version: 3.14
16:26:45:Has Battery: false
16:26:45: On Battery: false
16:26:45: UTC Offset: 2
16:26:45:        PID: 1620
16:26:45:        CWD: /var/lib/fahclient
16:26:45:         OS: Linux 3.14.4-200.fc20.x86_64 x86_64
16:26:45:    OS Arch: AMD64
16:26:45:       GPUs: 1
16:26:45:      GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
16:26:45:       CUDA: Not detected
16:26:45:***********************************************************************
16:26:45:<config>
16:26:45:  <!-- Client Control -->
16:26:45:  <client-threads v='6'/>
16:26:45:  <cycle-rate v='4'/>
16:26:45:  <cycles v='-1'/>
16:26:45:  <data-directory v='.'/>
16:26:45:  <disable-sleep-when-active v='true'/>
16:26:45:  <exec-directory v='/usr/bin'/>
16:26:45:  <exit-when-done v='false'/>
16:26:45:  <fold-anon v='false'/>
16:26:45:  <idle-seconds v='300'/>
16:26:45:  <open-web-control v='false'/>
16:26:45:
16:26:45:  <!-- Configuration -->
16:26:45:  <config-rotate v='true'/>
16:26:45:  <config-rotate-dir v='configs'/>
16:26:45:  <config-rotate-max v='16'/>
16:26:45:
16:26:45:  <!-- Debugging -->
16:26:45:  <assignment-servers>
16:26:45:    assign3.stanford.edu:8080 assign4.stanford.edu:80
16:26:45:  </assignment-servers>
16:26:45:  <auth-as v='true'/>
16:26:45:  <capture-directory v='capture'/>
16:26:45:  <capture-on-error v='false'/>
16:26:45:  <capture-packets v='false'/>
16:26:45:  <capture-requests v='false'/>
16:26:45:  <capture-responses v='false'/>
16:26:45:  <capture-sockets v='false'/>
16:26:45:  <core-exec v='FahCore_$type'/>
16:26:45:  <core-wrapper-exec v='FAHCoreWrapper'/>
16:26:45:  <debug-sockets v='false'/>
16:26:45:  <exception-locations v='true'/>
16:26:45:  <gpu-assignment-servers>
16:26:45:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
16:26:45:  </gpu-assignment-servers>
16:26:45:  <stack-traces v='false'/>
16:26:45:
16:26:45:  <!-- Error Handling -->
16:26:45:  <max-slot-errors v='10'/>
16:26:45:  <max-unit-errors v='5'/>
16:26:45:
16:26:45:  <!-- Folding Core -->
16:26:45:  <checkpoint v='15'/>
16:26:45:  <core-dir v='cores'/>
16:26:45:  <core-priority v='low'/>
16:26:45:  <cpu-affinity v='false'/>
16:26:45:  <cpu-usage v='100'/>
16:26:45:  <gpu-usage v='100'/>
16:26:45:  <no-assembly v='false'/>
16:26:45:
16:26:45:  <!-- Folding Slot Configuration -->
16:26:45:  <cause v='ANY'/>
16:26:45:  <client-subtype v='LINUX'/>
16:26:45:  <client-type v='normal'/>
16:26:45:  <cpu-species v='X86_PENTIUM_II'/>
16:26:45:  <cpu-type v='AMD64'/>
16:26:45:  <cpus v='-1'/>
16:26:45:  <gpu v='false'/>
16:26:45:  <max-packet-size v='normal'/>
16:26:45:  <os-species v='UNKNOWN'/>
16:26:45:  <os-type v='LINUX'/>
16:26:45:  <project-key v='0'/>
16:26:45:  <smp v='true'/>
16:26:45:
16:26:45:  <!-- GUI -->
16:26:45:  <gui-enabled v='true'/>
16:26:45:
16:26:45:  <!-- HTTP Server -->
16:26:45:  <allow v='127.0.0.1'/>
16:26:45:  <connection-timeout v='60'/>
16:26:45:  <deny v='0/0'/>
16:26:45:  <http-addresses v='0:7396'/>
16:26:45:  <https-addresses v=''/>
16:26:45:  <max-connect-time v='900'/>
16:26:45:  <max-connections v='800'/>
16:26:45:  <max-request-length v='52428800'/>
16:26:45:  <min-connect-time v='300'/>
16:26:45:  <threads v='12'/>
16:26:45:
16:26:45:  <!-- Logging -->
16:26:45:  <log v='log.txt'/>
16:26:45:  <log-color v='true'/>
16:26:45:  <log-crlf v='false'/>
16:26:45:  <log-date v='false'/>
16:26:45:  <log-date-periodically v='21600'/>
16:26:45:  <log-debug v='true'/>
16:26:45:  <log-domain v='false'/>
16:26:45:  <log-header v='true'/>
16:26:45:  <log-level v='true'/>
16:26:45:  <log-no-info-header v='true'/>
16:26:45:  <log-redirect v='false'/>
16:26:45:  <log-rotate v='true'/>
16:26:45:  <log-rotate-dir v='logs'/>
16:26:45:  <log-rotate-max v='16'/>
16:26:45:  <log-short-level v='false'/>
16:26:45:  <log-simple-domains v='true'/>
16:26:45:  <log-thread-id v='false'/>
16:26:45:  <log-thread-prefix v='true'/>
16:26:45:  <log-time v='true'/>
16:26:45:  <log-to-screen v='true'/>
16:26:45:  <log-truncate v='false'/>
16:26:45:  <verbosity v='5'/>
16:26:45:
16:26:45:  <!-- Network -->
16:26:45:  <proxy v=':8080'/>
16:26:45:  <proxy-enable v='false'/>
16:26:45:  <proxy-pass v=''/>
16:26:45:  <proxy-user v=''/>
16:26:45:
16:26:45:  <!-- Process Control -->
16:26:45:  <child v='true'/>
16:26:45:  <daemon v='true'/>
16:26:45:  <fork v='false'/>
16:26:45:  <pid v='false'/>
16:26:45:  <pid-file v='/var/run/fahclient.pid'/>
16:26:45:  <respawn v='false'/>
16:26:45:  <service v='false'/>
16:26:45:
16:26:45:  <!-- Remote Command Server -->
16:26:45:  <command-address v='0.0.0.0'/>
16:26:45:  <command-allow-no-pass v='127.0.0.1'/>
16:26:45:  <command-deny-no-pass v='0/0'/>
16:26:45:  <command-enable v='true'/>
16:26:45:  <command-port v='36330'/>
16:26:45:
16:26:45:  <!-- Slot Control -->
16:26:45:  <idle v='false'/>
16:26:45:  <max-shutdown-wait v='60'/>
16:26:45:  <pause-on-battery v='true'/>
16:26:45:  <pause-on-start v='false'/>
16:26:45:  <paused v='false'/>
16:26:45:  <power v='full'/>
16:26:45:
16:26:45:  <!-- User Information -->
16:26:45:  <machine-id v='0'/>
16:26:45:  <passkey v='********************************'/>
16:26:45:  <team v='0'/>
16:26:45:  <user v='svanefalk'/>
16:26:45:
16:26:45:  <!-- Web Server -->
16:26:45:  <web-allow v='127.0.0.1'/>
16:26:45:  <web-deny v='0/0'/>
16:26:45:  <web-enable v='true'/>
16:26:45:
16:26:45:  <!-- Web Server Sessions -->
16:26:45:  <session-cookie v='sid'/>
16:26:45:  <session-lifetime v='86400'/>
16:26:45:  <session-timeout v='3600'/>
16:26:45:
16:26:45:  <!-- Work Unit Control -->
16:26:45:  <dump-after-deadline v='true'/>
16:26:45:  <max-queue v='16'/>
16:26:45:  <max-units v='0'/>
16:26:45:  <next-unit-percentage v='99'/>
16:26:45:  <stall-detection-enabled v='false'/>
16:26:45:  <stall-percent v='5'/>
16:26:45:  <stall-timeout v='1800'/>
16:26:45:
16:26:45:  <!-- Folding Slots -->
16:26:45:  <slot id='1' type='GPU'>
16:26:45:    <paused v='true'/>
16:26:45:  </slot>
16:26:45:</config>
16:26:45:Switching to user fahclient
16:26:45:Trying to access database...
16:26:45:Successfully acquired database lock
16:26:45:Enabled folding slot 01: PAUSED gpu:0:GK104 [GeForce GTX 770] (by user)
16:26:45:Started thread 5 on PID 1620
16:26:45:Started thread 6 on PID 1620
16:26:45:Started thread 7 on PID 1620
16:26:45:Started thread 8 on PID 1620
16:26:45:Started thread 9 on PID 1620
16:26:45:Started thread 10 on PID 1620
16:36:46:Started thread 11 on PID 1620
16:36:51:FS01:Unpaused
16:36:51:WU00:FS01:Starting
16:36:51:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 1620 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:36:51:WU00:FS01:Started FahCore on PID 1858
16:36:51:Started thread 12 on PID 1620
16:36:51:WU00:FS01:Core PID:1862
16:36:51:WU00:FS01:FahCore 0x17 started
16:36:52:WU00:FS01:0x17:*********************** Log Started 2014-06-04T16:36:51Z ***********************
16:36:52:WU00:FS01:0x17:Project: 9406 (Run 838, Clone 0, Gen 48)
16:36:52:WU00:FS01:0x17:Unit: 0x0000004b0a3b1e5c533e80d68bedd79a
16:36:52:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
16:36:52:WU00:FS01:0x17:Machine: 1
16:36:52:WU00:FS01:0x17:Digital signatures verified
16:36:52:WU00:FS01:0x17:  Found a checkpoint file
16:36:55:Saving configuration to /etc/fahclient/config.xml
16:36:55:<config>
16:36:55:  <!-- Folding Core -->
16:36:55:  <core-priority v='low'/>
16:36:55:
16:36:55:  <!-- Folding Slot Configuration -->
16:36:55:  <gpu v='false'/>
16:36:55:
16:36:55:  <!-- Logging -->
16:36:55:  <verbosity v='5'/>
16:36:55:
16:36:55:  <!-- Network -->
16:36:55:  <proxy v=':8080'/>
16:36:55:
16:36:55:  <!-- Slot Control -->
16:36:55:  <power v='full'/>
16:36:55:
16:36:55:  <!-- User Information -->
16:36:55:  <passkey v='********************************'/>
16:36:55:  <user v='svanefalk'/>
16:36:55:
16:36:55:  <!-- Folding Slots -->
16:36:55:  <slot id='1' type='GPU'/>
16:36:55:</config>
16:39:19:WU00:FS01:0x17:Completed 400000 out of 2000000 steps (20%)
16:47:51:WU00:FS01:0x17:Completed 420000 out of 2000000 steps (21%)
16:56:10:WU00:FS01:0x17:Completed 440000 out of 2000000 steps (22%)
17:04:35:WU00:FS01:0x17:Completed 460000 out of 2000000 steps (23%)
17:12:53:WU00:FS01:0x17:Completed 480000 out of 2000000 steps (24%)
17:21:12:WU00:FS01:0x17:Completed 500000 out of 2000000 steps (25%)
17:29:36:WU00:FS01:0x17:Completed 520000 out of 2000000 steps (26%)
17:37:54:WU00:FS01:0x17:Completed 540000 out of 2000000 steps (27%)
17:46:19:WU00:FS01:0x17:Completed 560000 out of 2000000 steps (28%)
17:54:37:WU00:FS01:0x17:Completed 580000 out of 2000000 steps (29%)
18:02:56:WU00:FS01:0x17:Completed 600000 out of 2000000 steps (30%)
18:11:20:WU00:FS01:0x17:Completed 620000 out of 2000000 steps (31%)
18:19:39:WU00:FS01:0x17:Completed 640000 out of 2000000 steps (32%)
18:28:03:WU00:FS01:0x17:Completed 660000 out of 2000000 steps (33%)
18:36:22:WU00:FS01:0x17:Completed 680000 out of 2000000 steps (34%)
18:44:41:WU00:FS01:0x17:Completed 700000 out of 2000000 steps (35%)
18:53:05:WU00:FS01:0x17:Completed 720000 out of 2000000 steps (36%)
19:01:24:WU00:FS01:0x17:Completed 740000 out of 2000000 steps (37%)
19:09:48:WU00:FS01:0x17:Completed 760000 out of 2000000 steps (38%)
19:18:07:WU00:FS01:0x17:Completed 780000 out of 2000000 steps (39%)
19:26:26:WU00:FS01:0x17:Completed 800000 out of 2000000 steps (40%)
19:34:50:WU00:FS01:0x17:Completed 820000 out of 2000000 steps (41%)
19:43:08:WU00:FS01:0x17:Completed 840000 out of 2000000 steps (42%)
19:51:33:WU00:FS01:0x17:Completed 860000 out of 2000000 steps (43%)
19:59:51:WU00:FS01:0x17:Completed 880000 out of 2000000 steps (44%)
20:08:10:WU00:FS01:0x17:Completed 900000 out of 2000000 steps (45%)
20:16:35:WU00:FS01:0x17:Completed 920000 out of 2000000 steps (46%)
20:24:54:WU00:FS01:0x17:Completed 940000 out of 2000000 steps (47%)
20:33:18:WU00:FS01:0x17:Completed 960000 out of 2000000 steps (48%)
20:41:36:WU00:FS01:0x17:Completed 980000 out of 2000000 steps (49%)
20:49:55:WU00:FS01:0x17:Completed 1000000 out of 2000000 steps (50%)
20:58:19:WU00:FS01:0x17:Completed 1020000 out of 2000000 steps (51%)
21:06:38:WU00:FS01:0x17:Completed 1040000 out of 2000000 steps (52%)
21:15:02:WU00:FS01:0x17:Completed 1060000 out of 2000000 steps (53%)
21:23:21:WU00:FS01:0x17:Completed 1080000 out of 2000000 steps (54%)
21:31:40:WU00:FS01:0x17:Completed 1100000 out of 2000000 steps (55%)
21:40:04:WU00:FS01:0x17:Completed 1120000 out of 2000000 steps (56%)
21:48:23:WU00:FS01:0x17:Completed 1140000 out of 2000000 steps (57%)
21:56:47:WU00:FS01:0x17:Completed 1160000 out of 2000000 steps (58%)
22:05:06:WU00:FS01:0x17:Completed 1180000 out of 2000000 steps (59%)
22:13:25:WU00:FS01:0x17:Completed 1200000 out of 2000000 steps (60%)
22:21:49:WU00:FS01:0x17:Completed 1220000 out of 2000000 steps (61%)
******************************* Date: 2014-06-04 *******************************
22:30:08:WU00:FS01:0x17:Completed 1240000 out of 2000000 steps (62%)
22:38:32:WU00:FS01:0x17:Completed 1260000 out of 2000000 steps (63%)
22:46:51:WU00:FS01:0x17:Completed 1280000 out of 2000000 steps (64%)
22:55:10:WU00:FS01:0x17:Completed 1300000 out of 2000000 steps (65%)
23:03:34:WU00:FS01:0x17:Completed 1320000 out of 2000000 steps (66%)
23:11:53:WU00:FS01:0x17:Completed 1340000 out of 2000000 steps (67%)
23:20:16:WU00:FS01:0x17:Completed 1360000 out of 2000000 steps (68%)
23:28:35:WU00:FS01:0x17:Completed 1380000 out of 2000000 steps (69%)
23:36:54:WU00:FS01:0x17:Completed 1400000 out of 2000000 steps (70%)
23:45:18:WU00:FS01:0x17:Completed 1420000 out of 2000000 steps (71%)
23:53:37:WU00:FS01:0x17:Completed 1440000 out of 2000000 steps (72%)
00:02:01:WU00:FS01:0x17:Completed 1460000 out of 2000000 steps (73%)
00:10:20:WU00:FS01:0x17:Completed 1480000 out of 2000000 steps (74%)
00:18:39:WU00:FS01:0x17:Completed 1500000 out of 2000000 steps (75%)
00:27:03:WU00:FS01:0x17:Completed 1520000 out of 2000000 steps (76%)
00:35:21:WU00:FS01:0x17:Completed 1540000 out of 2000000 steps (77%)
00:43:45:WU00:FS01:0x17:Completed 1560000 out of 2000000 steps (78%)
00:52:04:WU00:FS01:0x17:Completed 1580000 out of 2000000 steps (79%)
01:00:23:WU00:FS01:0x17:Completed 1600000 out of 2000000 steps (80%)
01:08:47:WU00:FS01:0x17:Completed 1620000 out of 2000000 steps (81%)
01:17:05:WU00:FS01:0x17:Completed 1640000 out of 2000000 steps (82%)
01:25:30:WU00:FS01:0x17:Completed 1660000 out of 2000000 steps (83%)
01:33:48:WU00:FS01:0x17:Completed 1680000 out of 2000000 steps (84%)
01:42:07:WU00:FS01:0x17:Completed 1700000 out of 2000000 steps (85%)
01:50:31:WU00:FS01:0x17:Completed 1720000 out of 2000000 steps (86%)
01:58:50:WU00:FS01:0x17:Completed 1740000 out of 2000000 steps (87%)
02:07:14:WU00:FS01:0x17:Completed 1760000 out of 2000000 steps (88%)
02:15:32:WU00:FS01:0x17:Completed 1780000 out of 2000000 steps (89%)
02:23:51:WU00:FS01:0x17:Completed 1800000 out of 2000000 steps (90%)
02:32:15:WU00:FS01:0x17:Completed 1820000 out of 2000000 steps (91%)
02:40:34:WU00:FS01:0x17:Completed 1840000 out of 2000000 steps (92%)
02:48:58:WU00:FS01:0x17:Completed 1860000 out of 2000000 steps (93%)
02:57:16:WU00:FS01:0x17:Completed 1880000 out of 2000000 steps (94%)
03:05:35:WU00:FS01:0x17:Completed 1900000 out of 2000000 steps (95%)
03:13:59:WU00:FS01:0x17:Completed 1920000 out of 2000000 steps (96%)
03:22:18:WU00:FS01:0x17:Completed 1940000 out of 2000000 steps (97%)
03:30:42:WU00:FS01:0x17:Completed 1960000 out of 2000000 steps (98%)
03:39:01:WU00:FS01:0x17:Completed 1980000 out of 2000000 steps (99%)
03:47:19:WU00:FS01:0x17:Completed 2000000 out of 2000000 steps (100%)
03:47:21:WU01:FS01:Connecting to 171.67.108.201:80
03:47:21:WU01:FS01:Assigned to work server 171.64.65.56
03:47:21:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GK104 [GeForce GTX 770] from 171.64.65.56
03:47:21:WU01:FS01:Connecting to 171.64.65.56:8080
03:47:22:WU01:FS01:Downloading 3.42MiB
03:47:25:WU00:FS01:0x17:Saving result file logfile_01.txt
03:47:25:WU00:FS01:0x17:Saving result file checkpointState.xml
03:47:25:WU01:FS01:Download complete
03:47:25:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9408 run:2249 clone:0 gen:28 core:0x17 unit:0x000000230a3b1e5c53433de2c3a84fbd
03:47:26:WU00:FS01:0x17:Saving result file checkpt.crc
03:47:26:WU00:FS01:0x17:Saving result file log.txt
03:47:26:WU00:FS01:0x17:Saving result file positions.xtc
03:47:27:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
03:47:28:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:47:28:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9406 run:838 clone:0 gen:48 core:0x17 unit:0x0000004b0a3b1e5c533e80d68bedd79a
03:47:28:WU00:FS01:Uploading 14.45MiB to 171.64.65.56
03:47:28:WU00:FS01:Connecting to 171.64.65.56:8080
03:47:28:WU01:FS01:Starting
03:47:28:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 1620 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:47:28:WU01:FS01:Started FahCore on PID 9907
03:47:28:Started thread 13 on PID 1620
03:47:28:WU01:FS01:Core PID:9911
03:47:28:WU01:FS01:FahCore 0x17 started
03:47:28:WU01:FS01:0x17:*********************** Log Started 2014-06-05T03:47:28Z ***********************
03:47:28:WU01:FS01:0x17:Project: 9408 (Run 2249, Clone 0, Gen 28)
03:47:28:WU01:FS01:0x17:Unit: 0x000000230a3b1e5c53433de2c3a84fbd
03:47:28:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
03:47:28:WU01:FS01:0x17:Machine: 1
03:47:28:WU01:FS01:0x17:Reading tar file state.xml
03:47:28:WU01:FS01:0x17:Reading tar file system.xml
03:47:29:WU01:FS01:0x17:Reading tar file integrator.xml
03:47:29:WU01:FS01:0x17:Reading tar file core.xml
03:47:29:WU01:FS01:0x17:Digital signatures verified
03:47:34:WU00:FS01:Upload 35.03%
03:47:40:WU00:FS01:Upload 84.76%
03:47:43:WU00:FS01:Upload complete
03:47:43:WU00:FS01:Server responded WORK_ACK (400)
03:47:43:WU00:FS01:Final credit estimate, 23297.00 points
03:47:43:WU00:FS01:Cleaning up
03:48:18:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
04:01:12:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
04:14:06:WU01:FS01:0x17:Completed 100000 out of 5000000 steps (2%)
04:27:00:WU01:FS01:0x17:Completed 150000 out of 5000000 steps (3%)
******************************* Date: 2014-06-05 *******************************
04:39:55:WU01:FS01:0x17:Completed 200000 out of 5000000 steps (4%)
04:52:49:WU01:FS01:0x17:Completed 250000 out of 5000000 steps (5%)
05:05:43:WU01:FS01:0x17:Completed 300000 out of 5000000 steps (6%)
05:18:37:WU01:FS01:0x17:Completed 350000 out of 5000000 steps (7%)
05:31:32:WU01:FS01:0x17:Completed 400000 out of 5000000 steps (8%)
05:44:26:WU01:FS01:0x17:Completed 450000 out of 5000000 steps (9%)
05:57:20:WU01:FS01:0x17:Completed 500000 out of 5000000 steps (10%)
06:10:15:WU01:FS01:0x17:Completed 550000 out of 5000000 steps (11%)
06:23:09:WU01:FS01:0x17:Completed 600000 out of 5000000 steps (12%)
06:36:04:WU01:FS01:0x17:Completed 650000 out of 5000000 steps (13%)
06:48:59:WU01:FS01:0x17:Completed 700000 out of 5000000 steps (14%)
davidcoton
You almost certainly need to get a driver from nVidia's website and figure out how to install it. You do NOT want Nouveau drivers.
Please set log verbosity back to default (3) asnd re-post as above, the extra information at 5 obscures changes from default and is rarely helpful.
David
csvanefalk
As explained, I am not using Nouveau, I am using the 331.67 official drivers, installed via rpmfusion.
Nicolas_orleans
csvanefalk, as explained in this thread, the official drivers 327 and above do not yield best PPD for non GK110 GPU. Roughly, based on your figures, they deliver around 60% less folding performance for Core_17 units (my personal findings were around 50% less performance)
you have currently two options on linux :
- keep low ppd with 331.67, but no need to restart
- downgrade to 319.x or 325.15, that will boost your Core_17 PPD to 90-95k, but you will need to reboot at least every 36 hours
(edit : add non GK110 info + linux info)
Last edited by Nicolas_orleans on Thu Jun 05, 2014 9:35 am, edited 1 time in total.
