i've lost 4 in a row 2665 ...turned my oc way down , E-8400 oc at 3.6 now .I have folded this rig for 2 months without a problem .both my rigs are getting all 2665 which is ok but not if I keep loosing them .please let me know if you thing I should run without oc till we get done with these 2665's please it will take a few days to fold one with my e-8400 .my q6600 is not being affected as bad for your info .Thanks for any help/advise... never seen a log like the one just got below?
Folding@Home Gromacs SMP Core
[17:58:06] Version 1.74 (March 10, 2007)
[17:58:06]
[17:58:06] Preparing to commence simulation
[17:58:06] - Ensuring status. Please wait.
[17:58:23] - Assembly optimizations manually forced on.
[17:58:23] - Not checking prior termination.
[17:58:27] - Expanded 2430318 -> 12883625 (decompressed 530.1 percent)
[17:58:27] - Checksums don't match (work/wudata_04.xtc)
[17:58:27] - Failed to delete work/wudata_04.chk
[17:58:27] - Failed to delete - Failed to delete work/wudata_04.pdo
[17:58:27] - Failed to delete - Failed to delete Warning:ata_04kxvgrWsrnayg: ch
[17:58:27] c Sfarting f files
[17:58:27] - Startikgpfckmti
[17:58:27] Project: 2653 (Run
[17:58:27] Project: 2653 (Ren 102)
[17:58:27]
[17:58:27] one 150, Gen 102)
[17:58:27]
[17:58:28] Assembly optimizations on if available.
[17:58:28] Entering M.D.
[17:58:34] Rejecting checkpoint
[17:58:34] Protein: Protein in POPC
[17:58:34] Writing local files
[17:58:35] Extra SSE boost OK.
[17:58:35] Writing local files
[17:58:35] Completed 0 out of 500000 steps (0 percent)
same as dedgar wu 2665
Re: same as dedgar wu 2665
This log doesn't show loss of the work unit--the core is successfully starting work. Can you post a log snippet with loss of the work unit?
Also, what operating system are you running? Are you running the client "as-is" or using any 3rd party utilities?
I went back and looked again and I haven't lost work
.I have been in and out all day .My computer has shut down 4 times ,it was off when I came in but when I really looked at the log you are right I didn't loose the wu .Sorry about my false report .I turned off my oc till I can figure out why my rig keeps shutting down .I'm just using fahmon ..
still my fault but my 14 year old son told me we lost the wu ,he meant well but I should have checked it out for myself .sorry again...
