CPU Shows Progress but GPU does not
I have my computer setup and registered with Folding@home... it has been churning for about 5-6 days now... the CPU part seems to be running on the left side, and has hit 100% already and started again, however the GPU side has not moved from 0 the whole time... is it working correctly?
Is anyone available for a phone conversation?
Jamie
Mod Edit: Removed Identifying Information - PantherX
Jamie
Re: CPU Shows Progress but GPU does not
Welcome to the F@H Forum stelllarapparel,
Could you please post the log file which contains the system configuration and F@H settings (viewtopic.php?f=61&t=26036)? Also, by default, the GPU folds only when the system is idle (http://folding.stanford.edu/home/faq/fa ... ion/#ntoc3). Was your system idle over those days?
FYI, the support system here relies on donors posting messages as opposed to phone calls. While there isn't any official helpline number, you could find some donors willing to help you out by direct communication methods (Skype, IRC, IM, etc) and is commonly observed on Team Forums.
The system has been idle 99% of the time, thats why I chose to work with this computer... however I will have to read the instructions on the log file and see how to get you the information you require...
So I can post my skype account but not a telephone number? ok...
If you had posted the information requested, you would have been help by now.
If your team website chooses to provide support via skype or phone, that's up to them and you can post that information there.
Are your power-savings settigns set to sleep/hibernate? If so, that's a common reason for lack of GPU progress, but without the information in your log, that's just a guess.
*********************** Log Started 2014-05-19T20:26:01Z ***********************
20:26:01:************************* Folding@home Client *************************
20:26:01: Website: http://folding.stanford.edu/
20:26:01: Copyright: (c) 2009-2014 Stanford University
20:26:01: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:26:01: Args: --open-web-control
20:26:01: Config: <none>
20:26:01:******************************** Build ********************************
20:26:01: Version: 7.4.4
20:26:01: Date: Mar 4 2014
20:26:01: Time: 20:26:54
20:26:01: SVN Rev: 4130
20:26:01: Branch: fah/trunk/client
20:26:01: Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:26:01: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:26:01: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:26:01: Platform: win32 XP
20:26:01: Bits: 32
20:26:01: Mode: Release
20:26:01:******************************* System ********************************
20:26:01: CPU: AMD E1-1200 APU with Radeon(tm) HD Graphics
20:26:01: CPU ID: AuthenticAMD Family 20 Model 2 Stepping 0
20:26:01: CPUs: 2
20:26:01: Memory: 3.57GiB
20:26:01: Free Memory: 2.18GiB
20:26:01: Threads: WINDOWS_THREADS
20:26:01: OS Version: 6.2
20:26:01: Has Battery: false
20:26:01: On Battery: false
20:26:01: UTC Offset: -4
20:26:01: PID: 5012
20:26:01: CWD: C:/Users/Stellar Apparel/AppData/Roaming/FAHClient
20:26:01: OS: Windows 8
20:26:01: OS Arch: AMD64
20:26:01: GPUs: 1
20:26:01: GPU 0: ATI:4 Wrestler [Radeon HD 7310]
20:26:01: CUDA: Not detected
20:26:01:Win32 Service: false
20:26:01:***********************************************************************
20:26:01:<config>
20:26:01: <!-- Folding Slots -->
20:26:01:</config>
20:26:01:Connecting to assign-GPU.stanford.edu:80
20:26:05:Updated GPUs.txt
20:26:05:Read GPUs.txt
20:26:05:Trying to access database...
20:26:06:Successfully acquired database lock
20:26:06:Enabled folding slot 00: PAUSED cpu:1 (not configured)
20:26:06:Enabled folding slot 01: PAUSED gpu:0:Wrestler [Radeon HD 7310] (not configured)
20:26:18:10:127.0.0.1:New Web connection
20:27:07:Saving configuration to config.xml
20:27:07:<config>
20:27:07: <!-- Folding Slots -->
20:27:07: <slot id='0' type='CPU'/>
20:27:07: <slot id='1' type='GPU'/>
20:27:07:</config>
20:27:07:Set client configured
20:27:07:WU00:FS00:Connecting to 171.67.108.200:8080
20:27:07:WU01:FS01:Connecting to 171.67.108.200:8080
20:27:10:WU01:FS01:Connecting to 171.67.108.201:80
20:27:10:WU00:FS00:Connecting to 171.67.108.200:8080
20:27:10:WU01:FS01:Assigned to work server 140.163.4.231
20:27:10:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:27:10:WU01:FS01:Connecting to 140.163.4.231:8080
20:27:10:WU00:FS00:Assigned to work server 171.64.65.124
20:27:10:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 171.64.65.124
20:27:10:WU00:FS00:Connecting to 171.64.65.124:8080
20:27:10:WU01:FS01:Downloading 4.84MiB
20:27:11:WU01:FS01:Download complete
20:27:11:WU00:FS00:Downloading 855.12KiB
20:27:11:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13000 run:516 clone:1 gen:1 core:0x17 unit:0x00000005538b3db753102d773064c16f
20:27:11:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah
20:27:11:WU01:FS01:Connecting to web.stanford.edu:80
20:27:13:WU01:FS01:FahCore 17: Downloading 2.55MiB
20:27:13:WU00:FS00:Download complete
20:27:13:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9006 run:303 clone:0 gen:95 core:0xa4 unit:0x0000006c664f2de45327893b23ef4baa
20:27:14:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
20:27:14:WU00:FS00:Connecting to web.stanford.edu:80
20:27:14:WU00:FS00:FahCore a4: Downloading 2.89MiB
20:27:19:WU01:FS01:FahCore 17: 58.81%
20:27:20:WU00:FS00:FahCore a4: 51.94%
20:27:22:WU01:FS01:FahCore 17: Download complete
20:27:22:WU01:FS01:Valid core signature
20:27:22:WU01:FS01:Unpacked 8.60MiB to cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe
20:27:22:WU01:FS01:Starting
20:27:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:27:22:WU01:FS01:Started FahCore on PID 2012
20:27:24:WU00:FS00:FahCore a4: Download complete
20:27:26:WU01:FS01:Core PID:680
20:27:26:WU01:FS01:FahCore 0x17 started
20:27:27:WU00:FS00:Valid core signature
20:27:27:WU00:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
20:27:27:WU00:FS00:Starting
20:27:27:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15
20:27:27:WU00:FS00:Started FahCore on PID 4896
20:27:28:WU01:FS01:0x17:*********************** Log Started 2014-05-19T20:27:28Z ***********************
20:27:28:WU01:FS01:0x17:Project: 13000 (Run 516, Clone 1, Gen 1)
20:27:28:WU01:FS01:0x17:Unit: 0x00000005538b3db753102d773064c16f
20:27:28:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:27:28:WU01:FS01:0x17:Machine: 1
20:27:28:WU01:FS01:0x17:Reading tar file state.xml
20:27:31:WU00:FS00:Core PID:4872
20:27:31:WU00:FS00:FahCore 0xa4 started
20:27:32:WU00:FS00:0xa4:
20:27:32:WU00:FS00:0xa4:*------------------------------*
20:27:32:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
20:27:32:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
20:27:32:WU00:FS00:0xa4:Preparing to commence simulation
20:27:32:WU00:FS00:0xa4:- Looking at optimizations...
20:27:33:WU00:FS00:0xa4:- Created dyn
20:27:33:WU00:FS00:0xa4:- Files status OK
20:27:33:WU00:FS00:0xa4:- Expanded 875131 -> 1434864 (decompressed 163.9 percent)
20:27:34:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=875131 data_size=1434864, decompressed_data_size=1434864 diff=0
20:27:34:WU00:FS00:0xa4:- Digital signature verified
20:27:34:WU00:FS00:0xa4:Project: 9006 (Run 303, Clone 0, Gen 95)
20:27:34:WU00:FS00:0xa4:Assembly optimizations on if available.
20:27:34:WU00:FS00:0xa4:Entering M.D.
20:27:34:WU01:FS01:0x17:Reading tar file system.xml
20:27:36:WU01:FS01:0x17:Reading tar file integrator.xml
20:27:36:WU01:FS01:0x17:Reading tar file core.xml
20:27:36:WU01:FS01:0x17:Digital signatures verified
20:27:36:WU01:FS01:0x17:Folding@home GPU core17
20:27:36:WU01:FS01:0x17:Version 0.0.52
20:27:44:WU00:FS00:0xa4:Mapping NT from 1 to 1
20:27:56:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
20:28:56:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:28:57:WU01:FS01:0x17:Saving result file logfile_01.txt
20:28:57:WU01:FS01:0x17:Saving result file log.txt
20:28:57:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:28:57:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:28:57:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:516 clone:1 gen:1 core:0x17 unit:0x00000005538b3db753102d773064c16f
20:28:57:WU01:FS01:Uploading 2.28KiB to 140.163.4.231
20:28:57:WU01:FS01:Connecting to 140.163.4.231:8080
20:28:57:WU01:FS01:Upload complete
20:28:57:WU01:FS01:Server responded WORK_ACK (400)
20:28:57:WU01:FS01:Cleaning up
20:28:58:WU02:FS01:Connecting to 171.67.108.201:80
20:28:58:WU02:FS01:Assigned to work server 140.163.4.231
20:28:58:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:28:58:WU02:FS01:Connecting to 140.163.4.231:8080
20:28:58:WU02:FS01:Downloading 4.83MiB
20:28:59:WU02:FS01:Download complete
20:28:59:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13001 run:400 clone:3 gen:1 core:0x17 unit:0x00000007538b3db75328c127dfee0af5
20:28:59:WU02:FS01:Starting
20:28:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 02 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:28:59:WU02:FS01:Started FahCore on PID 6096
20:28:59:WU02:FS01:Core PID:5168
20:28:59:WU02:FS01:FahCore 0x17 started
20:29:00:WU02:FS01:0x17:*********************** Log Started 2014-05-19T20:29:00Z ***********************
20:29:00:WU02:FS01:0x17:Project: 13001 (Run 400, Clone 3, Gen 1)
20:29:00:WU02:FS01:0x17:Unit: 0x00000007538b3db75328c127dfee0af5
20:29:00:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:29:00:WU02:FS01:0x17:Machine: 1
20:29:00:WU02:FS01:0x17:Reading tar file state.xml
20:29:03:WU02:FS01:0x17:Reading tar file system.xml
20:29:05:WU02:FS01:0x17:Reading tar file integrator.xml
20:29:05:WU02:FS01:0x17:Reading tar file core.xml
20:29:05:WU02:FS01:0x17:Digital signatures verified
20:29:05:WU02:FS01:0x17:Folding@home GPU core17
20:29:05:WU02:FS01:0x17:Version 0.0.52
20:29:55:WU02:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:29:55:WU02:FS01:0x17:Saving result file logfile_01.txt
20:29:55:WU02:FS01:0x17:Saving result file log.txt
20:29:55:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:29:55:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:29:55:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13001 run:400 clone:3 gen:1 core:0x17 unit:0x00000007538b3db75328c127dfee0af5
20:29:55:WU02:FS01:Uploading 2.28KiB to 140.163.4.231
20:29:55:WU02:FS01:Connecting to 140.163.4.231:8080
20:29:55:WU02:FS01:Upload complete
20:29:55:WU02:FS01:Server responded WORK_ACK (400)
20:29:55:WU02:FS01:Cleaning up
20:29:56:WU01:FS01:Connecting to 171.67.108.201:80
20:29:56:WU01:FS01:Assigned to work server 140.163.4.231
20:29:56:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:29:56:WU01:FS01:Connecting to 140.163.4.231:8080
20:29:56:WU01:FS01:Downloading 4.84MiB
20:29:57:WU01:FS01:Download complete
20:29:57:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:445 clone:3 gen:1 core:0x17 unit:0x00000007538b3db7532c7a426335b735
20:29:57:WU01:FS01:Starting
20:29:57:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:29:57:WU01:FS01:Started FahCore on PID 5236
20:29:57:WU01:FS01:Core PID:6116
20:29:57:WU01:FS01:FahCore 0x17 started
20:29:58:WU01:FS01:0x17:*********************** Log Started 2014-05-19T20:29:57Z ***********************
20:29:58:WU01:FS01:0x17:Project: 13001 (Run 445, Clone 3, Gen 1)
20:29:58:WU01:FS01:0x17:Unit: 0x00000007538b3db7532c7a426335b735
20:29:58:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:29:58:WU01:FS01:0x17:Machine: 1
20:29:58:WU01:FS01:0x17:Reading tar file state.xml
20:30:01:WU01:FS01:0x17:Reading tar file system.xml
20:30:03:WU01:FS01:0x17:Reading tar file integrator.xml
20:30:03:WU01:FS01:0x17:Reading tar file core.xml
20:30:03:WU01:FS01:0x17:Digital signatures verified
20:30:03:WU01:FS01:0x17:Folding@home GPU core17
20:30:03:WU01:FS01:0x17:Version 0.0.52
20:31:03:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:31:03:WU01:FS01:0x17:Saving result file logfile_01.txt
20:31:03:WU01:FS01:0x17:Saving result file log.txt
20:31:03:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:31:03:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:31:03:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:445 clone:3 gen:1 core:0x17 unit:0x00000007538b3db7532c7a426335b735
20:31:03:WU01:FS01:Uploading 2.28KiB to 140.163.4.231
20:31:03:WU01:FS01:Connecting to 140.163.4.231:8080
20:31:03:WU01:FS01:Upload complete
20:31:04:WU01:FS01:Server responded WORK_ACK (400)
20:31:04:WU01:FS01:Cleaning up
20:31:04:WU02:FS01:Connecting to 171.67.108.201:80
20:31:04:WU02:FS01:Assigned to work server 140.163.4.231
20:31:04:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:31:04:WU02:FS01:Connecting to 140.163.4.231:8080
20:31:04:WU02:FS01:Downloading 4.84MiB
20:31:05:WU02:FS01:Download complete
20:31:05:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13000 run:553 clone:1 gen:1 core:0x17 unit:0x00000006538b3db7531037f53893b149
20:31:05:WU02:FS01:Starting
20:31:05:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 02 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:31:06:WU02:FS01:Started FahCore on PID 6132
20:31:06:WU02:FS01:Core PID:5456
20:31:06:WU02:FS01:FahCore 0x17 started
20:31:06:WU02:FS01:0x17:*********************** Log Started 2014-05-19T20:31:06Z ***********************
20:31:06:WU02:FS01:0x17:Project: 13000 (Run 553, Clone 1, Gen 1)
20:31:06:WU02:FS01:0x17:Unit: 0x00000006538b3db7531037f53893b149
20:31:06:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:31:06:WU02:FS01:0x17:Machine: 1
20:31:06:WU02:FS01:0x17:Reading tar file state.xml
20:31:11:Saving configuration to config.xml
20:31:11:<config>
20:31:11: <!-- Slot Control -->
20:31:11: <power v='FULL'/>
20:31:11:
20:31:11: <!-- User Information -->
20:31:11: <passkey v='********************************'/>
20:31:11: <user v='StellarApparel'/>
20:31:11:
20:31:11: <!-- Folding Slots -->
20:31:11: <slot id='0' type='CPU'/>
20:31:11: <slot id='1' type='GPU'/>
20:31:11:</config>
20:31:11:WU02:FS01:0x17:Reading tar file system.xml
20:31:14:WU02:FS01:0x17:Reading tar file integrator.xml
20:31:14:WU02:FS01:0x17:Reading tar file core.xml
20:31:14:WU02:FS01:0x17:Digital signatures verified
20:31:14:WU02:FS01:0x17:Folding@home GPU core17
20:31:14:WU02:FS01:0x17:Version 0.0.52
20:32:09:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:32:09:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:553 clone:1 gen:1 core:0x17 unit:0x00000006538b3db7531037f53893b149
20:32:09:WU02:FS01:Uploading 2.29KiB to 140.163.4.231
20:32:09:WU02:FS01:Connecting to 140.163.4.231:8080
20:32:09:WU02:FS01:Upload complete
20:32:10:WU02:FS01:Server responded WORK_ACK (400)
20:32:10:WU02:FS01:Cleaning up
20:32:10:WU01:FS01:Connecting to 171.67.108.201:80
20:32:10:WU01:FS01:Assigned to work server 140.163.4.231
20:32:10:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:32:10:WU01:FS01:Connecting to 140.163.4.231:8080
20:32:10:WU01:FS01:Downloading 4.84MiB
20:32:11:WU01:FS01:Download complete
20:32:11:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:539 clone:3 gen:1 core:0x17 unit:0x00000008538b3db7532c95071134f8cf
20:32:11:WU01:FS01:Starting
20:32:11:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:32:11:WU01:FS01:Started FahCore on PID 5316
20:32:11:WU01:FS01:Core PID:5820
20:32:11:WU01:FS01:FahCore 0x17 started
20:32:12:WU01:FS01:0x17:*********************** Log Started 2014-05-19T20:32:12Z ***********************
20:32:12:WU01:FS01:0x17:Project: 13001 (Run 539, Clone 3, Gen 1)
20:32:12:WU01:FS01:0x17:Unit: 0x00000008538b3db7532c95071134f8cf
20:32:12:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:32:12:WU01:FS01:0x17:Machine: 1
20:32:12:WU01:FS01:0x17:Reading tar file state.xml
20:32:15:WU01:FS01:0x17:Reading tar file system.xml
20:32:17:WU01:FS01:0x17:Reading tar file integrator.xml
20:32:17:WU01:FS01:0x17:Reading tar file core.xml
20:32:17:WU01:FS01:0x17:Digital signatures verified
20:32:17:WU01:FS01:0x17:Folding@home GPU core17
20:32:17:WU01:FS01:0x17:Version 0.0.52
20:33:13:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:33:13:WU01:FS01:0x17:Saving result file logfile_01.txt
20:33:13:WU01:FS01:0x17:Saving result file log.txt
20:33:13:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:33:14:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:33:14:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:539 clone:3 gen:1 core:0x17 unit:0x00000008538b3db7532c95071134f8cf
20:33:14:WU01:FS01:Uploading 2.28KiB to 140.163.4.231
20:33:14:WU01:FS01:Connecting to 140.163.4.231:8080
20:33:14:WU01:FS01:Upload complete
20:33:14:WU01:FS01:Server responded WORK_ACK (400)
20:33:14:WU01:FS01:Cleaning up
20:33:14:WU02:FS01:Connecting to 171.67.108.201:80
20:33:15:WU02:FS01:Assigned to work server 140.163.4.231
20:33:15:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:33:15:WU02:FS01:Connecting to 140.163.4.231:8080
20:33:16:WU02:FS01:Downloading 4.83MiB
20:33:16:WU02:FS01:Download complete
20:33:16:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13001 run:13 clone:4 gen:1 core:0x17 unit:0x00000005538b3db753285386fa247090
20:33:17:WU02:FS01:Starting
20:33:17:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 02 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:33:17:WU02:FS01:Started FahCore on PID 4668
20:33:17:WU02:FS01:Core PID:2568
20:33:17:WU02:FS01:FahCore 0x17 started
20:33:17:WU02:FS01:0x17:*********************** Log Started 2014-05-19T20:33:17Z ***********************
20:33:17:WU02:FS01:0x17:Project: 13001 (Run 13, Clone 4, Gen 1)
20:33:17:WU02:FS01:0x17:Unit: 0x00000005538b3db753285386fa247090
20:33:17:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:33:17:WU02:FS01:0x17:Machine: 1
20:33:17:WU02:FS01:0x17:Reading tar file state.xml
20:33:22:WU02:FS01:0x17:Reading tar file system.xml
20:33:25:WU02:FS01:0x17:Reading tar file integrator.xml
20:33:25:WU02:FS01:0x17:Reading tar file core.xml
20:33:25:WU02:FS01:0x17:Digital signatures verified
20:33:25:WU02:FS01:0x17:Folding@home GPU core17
20:33:25:WU02:FS01:0x17:Version 0.0.52
20:34:32:WU02:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:34:32:WU02:FS01:0x17:Saving result file logfile_01.txt
20:34:32:WU02:FS01:0x17:Saving result file log.txt
20:34:32:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:34:32:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:34:32:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13001 run:13 clone:4 gen:1 core:0x17 unit:0x00000005538b3db753285386fa247090
20:34:32:WU02:FS01:Uploading 2.28KiB to 140.163.4.231
20:34:32:WU02:FS01:Connecting to 140.163.4.231:8080
20:34:32:WU02:FS01:Upload complete
20:34:32:WU02:FS01:Server responded WORK_ACK (400)
20:34:33:WU02:FS01:Cleaning up
20:34:33:WU01:FS01:Connecting to 171.67.108.201:80
20:34:33:WU01:FS01:Assigned to work server 140.163.4.231
20:34:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:34:33:WU01:FS01:Connecting to 140.163.4.231:8080
20:34:33:WU01:FS01:Downloading 4.83MiB
20:34:34:WU01:FS01:Download complete
20:34:34:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:155 clone:4 gen:8 core:0x17 unit:0x00000013538b3db753287babfecf2896
20:34:34:WU01:FS01:Starting
20:34:34:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:34:34:WU01:FS01:Started FahCore on PID 5320
20:34:34:WU01:FS01:Core PID:6048
20:34:34:WU01:FS01:FahCore 0x17 started
20:34:35:WU01:FS01:0x17:*********************** Log Started 2014-05-19T20:34:34Z ***********************
20:34:35:WU01:FS01:0x17:Project: 13001 (Run 155, Clone 4, Gen 8)
20:34:35:WU01:FS01:0x17:Unit: 0x00000013538b3db753287babfecf2896
20:34:35:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:34:35:WU01:FS01:0x17:Machine: 1
20:34:35:WU01:FS01:0x17:Reading tar file state.xml
20:34:40:WU01:FS01:0x17:Reading tar file system.xml
20:34:42:WU01:FS01:0x17:Reading tar file integrator.xml
20:34:42:WU01:FS01:0x17:Reading tar file core.xml
20:34:42:WU01:FS01:0x17:Digital signatures verified
20:34:42:WU01:FS01:0x17:Folding@home GPU core17
20:34:42:WU01:FS01:0x17:Version 0.0.52
20:35:54:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:35:54:WU01:FS01:0x17:Saving result file logfile_01.txt
20:35:54:WU01:FS01:0x17:Saving result file log.txt
20:35:54:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:35:55:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:35:55:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:155 clone:4 gen:8 core:0x17 unit:0x00000013538b3db753287babfecf2896
20:35:55:WU01:FS01:Uploading 2.28KiB to 140.163.4.231
20:35:55:WU01:FS01:Connecting to 140.163.4.231:8080
20:35:55:WU01:FS01:Upload complete
20:35:55:WU01:FS01:Server responded WORK_ACK (400)
20:35:55:WU01:FS01:Cleaning up
20:35:55:WU01:FS01:Connecting to 171.67.108.201:80
20:35:56:WU01:FS01:Assigned to work server 140.163.4.231
20:35:56:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:35:56:WU01:FS01:Connecting to 140.163.4.231:8080
20:35:56:WU01:FS01:Downloading 4.84MiB
20:35:57:WU01:FS01:Download complete
20:35:57:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:16 clone:4 gen:1 core:0x17 unit:0x00000007538b3db75328545f8c47c334
20:35:57:WU01:FS01:Starting
20:35:57:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:35:57:WU01:FS01:Started FahCore on PID 4956
20:35:57:WU01:FS01:Core PID:4620
20:35:57:WU01:FS01:FahCore 0x17 started
20:35:58:WU01:FS01:0x17:*********************** Log Started 2014-05-19T20:35:57Z ***********************
20:35:58:WU01:FS01:0x17:Project: 13001 (Run 16, Clone 4, Gen 1)
20:35:58:WU01:FS01:0x17:Unit: 0x00000007538b3db75328545f8c47c334
20:35:58:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:35:58:WU01:FS01:0x17:Machine: 1
20:35:58:WU01:FS01:0x17:Reading tar file state.xml
20:36:01:WU01:FS01:0x17:Reading tar file system.xml
20:36:03:WU01:FS01:0x17:Reading tar file integrator.xml
20:36:03:WU01:FS01:0x17:Reading tar file core.xml
20:36:03:WU01:FS01:0x17:Digital signatures verified
20:36:03:WU01:FS01:0x17:Folding@home GPU core17
20:36:03:WU01:FS01:0x17:Version 0.0.52
20:37:03:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:37:03:WU01:FS01:0x17:Saving result file logfile_01.txt
20:37:03:WU01:FS01:0x17:Saving result file log.txt
20:37:03:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:37:03:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:37:03:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:16 clone:4 gen:1 core:0x17 unit:0x00000007538b3db75328545f8c47c334
20:37:04:WU01:FS01:Uploading 2.28KiB to 140.163.4.231
20:37:04:WU01:FS01:Connecting to 140.163.4.231:8080
20:37:04:WU01:FS01:Upload complete
20:37:04:WU01:FS01:Server responded WORK_ACK (400)
20:37:04:WU01:FS01:Cleaning up
20:37:05:WU02:FS01:Connecting to 171.67.108.201:80
20:37:05:WU02:FS01:Assigned to work server 140.163.4.231
20:37:05:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:37:05:WU02:FS01:Connecting to 140.163.4.231:8080
20:37:06:WU02:FS01:Downloading 4.84MiB
20:37:06:WU02:FS01:Download complete
20:37:06:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13000 run:660 clone:1 gen:1 core:0x17 unit:0x00000006538b3db7531055f127a69e99
20:37:06:WU02:FS01:Starting
20:37:07:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 02 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:37:07:WU02:FS01:Started FahCore on PID 1732
20:37:07:WU02:FS01:Core PID:3964
20:37:07:WU02:FS01:FahCore 0x17 started
20:37:07:WU02:FS01:0x17:*********************** Log Started 2014-05-19T20:37:07Z ***********************
20:37:07:WU02:FS01:0x17:Project: 13000 (Run 660, Clone 1, Gen 1)
20:37:07:WU02:FS01:0x17:Unit: 0x00000006538b3db7531055f127a69e99
20:37:07:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:37:07:WU02:FS01:0x17:Machine: 1
20:37:07:WU02:FS01:0x17:Reading tar file state.xml
20:37:14:WU02:FS01:0x17:Reading tar file system.xml
20:37:19:WU02:FS01:0x17:Reading tar file integrator.xml
20:37:19:WU02:FS01:0x17:Reading tar file core.xml
20:37:19:WU02:FS01:0x17:Digital signatures verified
20:37:19:WU02:FS01:0x17:Folding@home GPU core17
20:37:19:WU02:FS01:0x17:Version 0.0.52
20:39:38:WU02:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:39:38:WU02:FS01:0x17:Saving result file logfile_01.txt
20:39:38:WU02:FS01:0x17:Saving result file log.txt
20:39:38:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:39:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:39:39:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:660 clone:1 gen:1 core:0x17 unit:0x00000006538b3db7531055f127a69e99
20:39:39:WU02:FS01:Uploading 2.28KiB to 140.163.4.231
20:39:39:WU02:FS01:Connecting to 140.163.4.231:8080
20:39:39:WU02:FS01:Upload complete
20:39:39:WU01:FS01:Connecting to 171.67.108.201:80
20:39:39:WU02:FS01:Server responded WORK_ACK (400)
20:39:39:WU02:FS01:Cleaning up
20:39:40:WU01:FS01:Assigned to work server 140.163.4.231
20:39:40:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:39:40:WU01:FS01:Connecting to 140.163.4.231:8080
20:39:40:WU01:FS01:Downloading 4.84MiB
20:39:41:WU01:FS01:Download complete
20:39:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:446 clone:3 gen:5 core:0x17 unit:0x0000000f538b3db7532c7a8dd9631308
20:39:42:WU01:FS01:Starting
20:39:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:39:42:WU01:FS01:Started FahCore on PID 5944
20:39:42:WU01:FS01:Core PID:2348
20:39:42:WU01:FS01:FahCore 0x17 started
20:39:42:WU01:FS01:0x17:*********************** Log Started 2014-05-19T20:39:42Z ***********************
20:39:42:WU01:FS01:0x17:Project: 13001 (Run 446, Clone 3, Gen 5)
20:39:42:WU01:FS01:0x17:Unit: 0x0000000f538b3db7532c7a8dd9631308
20:39:42:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:39:42:WU01:FS01:0x17:Machine: 1
20:39:42:WU01:FS01:0x17:Reading tar file state.xml
20:39:47:WU01:FS01:0x17:Reading tar file system.xml
20:39:50:WU01:FS01:0x17:Reading tar file integrator.xml
20:39:50:WU01:FS01:0x17:Reading tar file core.xml
20:39:50:WU01:FS01:0x17:Digital signatures verified
20:39:50:WU01:FS01:0x17:Folding@home GPU core17
20:39:50:WU01:FS01:0x17:Version 0.0.52
20:40:52:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:40:52:WU01:FS01:0x17:Saving result file logfile_01.txt
20:40:52:WU01:FS01:0x17:Saving result file log.txt
20:40:52:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:40:52:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:40:52:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:446 clone:3 gen:5 core:0x17 unit:0x0000000f538b3db7532c7a8dd9631308
20:40:52:WU01:FS01:Uploading 2.28KiB to 140.163.4.231
20:40:52:WU01:FS01:Connecting to 140.163.4.231:8080
20:40:52:WU01:FS01:Upload complete
20:40:53:WU02:FS01:Connecting to 171.67.108.201:80
20:40:53:WU01:FS01:Server responded WORK_ACK (400)
20:40:53:WU01:FS01:Cleaning up
20:40:54:WU02:FS01:Assigned to work server 140.163.4.231
20:40:54:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:40:54:WU02:FS01:Connecting to 140.163.4.231:8080
20:40:54:WU02:FS01:Downloading 4.84MiB
20:40:55:WU02:FS01:Download complete
20:40:55:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13000 run:697 clone:1 gen:1 core:0x17 unit:0x00000005538b3db75310605e1a17e81c
20:40:55:WU02:FS01:Starting
20:40:55:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 02 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:40:55:WU02:FS01:Started FahCore on PID 848
20:40:55:WU02:FS01:Core PID:5392
20:40:55:WU02:FS01:FahCore 0x17 started
20:40:56:WU02:FS01:0x17:*********************** Log Started 2014-05-19T20:40:55Z ***********************
20:40:56:WU02:FS01:0x17:Project: 13000 (Run 697, Clone 1, Gen 1)
20:40:56:WU02:FS01:0x17:Unit: 0x00000005538b3db75310605e1a17e81c
20:40:56:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:40:56:WU02:FS01:0x17:Machine: 1
20:40:56:WU02:FS01:0x17:Reading tar file state.xml
20:41:44:WU02:FS01:0x17:Reading tar file system.xml
20:42:14:WU02:FS01:0x17:Reading tar file integrator.xml
20:42:14:WU02:FS01:0x17:Reading tar file core.xml
20:42:14:WU02:FS01:0x17:Digital signatures verified
20:42:14:WU02:FS01:0x17:Folding@home GPU core17
20:42:14:WU02:FS01:0x17:Version 0.0.52
20:44:05:WU02:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:44:06:WU02:FS01:0x17:Saving result file logfile_01.txt
20:44:06:WU02:FS01:0x17:Saving result file log.txt
20:44:06:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:44:09:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:44:10:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13000 run:697 clone:1 gen:1 core:0x17 unit:0x00000005538b3db75310605e1a17e81c
20:44:11:WU02:FS01:Uploading 2.29KiB to 140.163.4.231
20:44:11:WU02:FS01:Connecting to 140.163.4.231:8080
20:44:11:WU02:FS01:Upload complete
20:44:11:WU01:FS01:Connecting to 171.67.108.201:80
20:44:12:WU02:FS01:Server responded WORK_ACK (400)
20:44:12:WU02:FS01:Cleaning up
20:44:15:WU01:FS01:Assigned to work server 140.163.4.231
20:44:16:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7310] from 140.163.4.231
20:44:16:WU01:FS01:Connecting to 140.163.4.231:8080
20:44:17:WU01:FS01:Downloading 4.84MiB
20:44:20:WU01:FS01:Download complete
20:44:22:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:234 clone:4 gen:1 core:0x17 unit:0x00000005538b3db753289219a920ff38
20:44:22:WU01:FS01:Starting
20:44:22:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:44:22:WU01:FS01:Started FahCore on PID 452
20:44:23:WU01:FS01:Core PID:3264
20:44:23:WU01:FS01:FahCore 0x17 started
20:44:23:WU01:FS01:0x17:*********************** Log Started 2014-05-19T20:44:23Z ***********************
20:44:23:WU01:FS01:0x17:Project: 13001 (Run 234, Clone 4, Gen 1)
20:44:23:WU01:FS01:0x17:Unit: 0x00000005538b3db753289219a920ff38
20:44:23:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:44:23:WU01:FS01:0x17:Machine: 1
20:44:24:WU01:FS01:0x17:Reading tar file state.xml
20:44:28:WU01:FS01:0x17:Reading tar file system.xml
20:44:31:WU01:FS01:0x17:Reading tar file integrator.xml
20:44:31:WU01:FS01:0x17:Reading tar file core.xml
20:44:31:WU01:FS01:0x17:Digital signatures verified
20:44:31:WU01:FS01:0x17:Folding@home GPU core17
20:44:31:WU01:FS01:0x17:Version 0.0.52
20:46:20:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation
20:46:20:WU01:FS01:0x17:Saving result file logfile_01.txt
20:46:21:WU01:FS01:0x17:Saving result file log.txt
20:46:26:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:46:29:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:46:29:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:234 clone:4 gen:1 core:0x17 unit:0x00000005538b3db753289219a920ff38
20:46:30:WU01:FS01:Uploading 2.28KiB to 140.163.4.231
20:46:30:WU01:FS01:Connecting to 140.163.4.231:8080
20:46:30:WU01:FS01:Upload complete
20:46:31:WU01:FS01:Server responded WORK_ACK (400)
20:46:32:WU01:FS01:Cleaning up
21:44:31:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
22:17:42:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
22:49:54:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
23:22:05:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
23:54:18:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
00:26:28:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
00:58:37:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
01:30:59:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
02:03:09:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
******************************* Date: 2014-05-20 *******************************
02:35:19:WU00:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
03:09:00:WU00:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
03:41:12:WU00:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
04:13:30:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
04:45:44:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
05:17:59:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
05:50:14:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
06:22:31:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
06:54:48:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
07:31:08:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
08:03:21:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
08:35:36:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
09:09:08:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
09:41:23:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
10:13:36:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
10:45:52:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
11:18:11:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
11:50:32:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
12:22:49:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
12:55:06:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
13:27:20:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
13:58:11:44:127.0.0.1:New Web connection
13:59:42:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
14:31:54:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
15:03:55:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
15:35:56:WU00:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
16:07:56:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
16:39:55:WU00:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
17:12:32:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
17:45:23:WU00:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
18:17:48:WU00:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
18:29:34:69:127.0.0.1:New Web connection
18:50:21:WU00:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
19:22:34:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
19:54:32:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
20:26:49:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
20:58:51:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
21:30:50:WU00:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
22:02:50:WU00:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
22:34:46:WU00:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
23:06:45:WU00:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
23:38:43:WU00:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
00:11:57:WU00:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
00:43:59:WU00:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
01:16:05:WU00:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
01:48:04:WU00:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
02:20:10:WU00:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
02:52:12:WU00:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
03:24:11:WU00:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
******************************* Date: 2014-05-21 *******************************
03:56:12:WU00:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
04:28:18:WU00:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
05:00:23:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
05:32:27:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
06:04:37:WU00:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
06:36:57:WU00:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
07:15:16:WU00:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
07:53:24:WU00:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
08:27:14:WU00:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
09:00:39:WU00:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
09:32:50:WU00:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
10:04:56:WU00:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
10:37:03:WU00:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
11:09:12:WU00:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
11:41:15:WU00:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
12:13:29:WU00:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
12:47:10:WU00:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
13:10:22:98:127.0.0.1:New Web connection
13:10:42:123:127.0.0.1:New Web connection
13:20:13:WU00:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
13:56:38:WU00:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
14:31:23:WU00:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
15:03:32:WU00:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
15:35:34:WU00:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
16:07:33:WU00:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
16:39:31:WU00:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
17:11:30:WU00:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
17:43:28:WU00:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
18:16:56:WU00:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
18:49:02:WU00:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
19:21:06:WU00:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
19:53:10:WU00:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
20:25:27:WU00:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
20:58:23:WU00:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
21:30:22:WU00:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
22:02:27:WU00:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
22:34:31:WU00:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
23:06:34:WU00:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
23:38:38:WU00:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
00:10:47:WU00:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
00:42:50:WU00:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
01:14:55:WU00:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
01:46:59:WU00:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
02:19:06:WU00:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
02:51:08:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
02:51:09:WU01:FS00:Connecting to 171.67.108.200:8080
02:51:10:WU01:FS00:Assigned to work server 171.64.65.124
02:51:10:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:1 from 171.64.65.124
02:51:10:WU01:FS00:Connecting to 171.64.65.124:8080
02:51:10:WU01:FS00:Downloading 809.63KiB
02:51:12:WU01:FS00:Download complete
02:51:12:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9007 run:982 clone:3 gen:74 core:0xa4 unit:0x00000059664f2de4533b37cc8b6fa909
03:24:37:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
03:24:38:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
03:24:48:WU00:FS00:0xa4:
03:24:48:WU00:FS00:0xa4:Finished Work Unit:
03:24:48:WU00:FS00:0xa4:- Reading up to 870480 from "00/wudata_01.trr": Read 870480
03:24:48:WU00:FS00:0xa4:trr file hash check passed.
03:24:48:WU00:FS00:0xa4:- Reading up to 800492 from "00/wudata_01.xtc": Read 800492
03:24:48:WU00:FS00:0xa4:xtc file hash check passed.
03:24:48:WU00:FS00:0xa4:edr file hash check passed.
03:24:48:WU00:FS00:0xa4:logfile size: 32937
03:24:48:WU00:FS00:0xa4:Leaving Run
03:24:50:WU00:FS00:0xa4:- Writing 1706349 bytes of core data to disk...
03:24:51:WU00:FS00:0xa4:Done: 1705837 -> 1645279 (compressed to 96.4 percent)
03:24:51:WU00:FS00:0xa4: ... Done.
03:24:53:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:24:53:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9006 run:303 clone:0 gen:95 core:0xa4 unit:0x0000006c664f2de45327893b23ef4baa
03:24:53:WU00:FS00:Uploading 1.57MiB to 171.64.65.124
03:24:53:WU00:FS00:Connecting to 171.64.65.124:8080
03:24:53:WU01:FS00:Starting
03:24:53:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Stellar Apparel/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 704 -lifeline 5012 -checkpoint 15
03:24:53:WU01:FS00:Started FahCore on PID 4796
03:24:53:WU01:FS00:Core PID:3744
03:24:53:WU01:FS00:FahCore 0xa4 started
03:24:54:WU01:FS00:0xa4:
03:24:54:WU01:FS00:0xa4:*------------------------------*
03:24:54:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
03:24:54:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:24:54:WU01:FS00:0xa4:Preparing to commence simulation
03:24:54:WU01:FS00:0xa4:- Looking at optimizations...
03:24:54:WU01:FS00:0xa4:- Created dyn
03:24:54:WU01:FS00:0xa4:- Files status OK
03:24:54:WU01:FS00:0xa4:- Expanded 828553 -> 1400900 (decompressed 169.0 percent)
03:24:54:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=828553 data_size=1400900, decompressed_data_size=1400900 diff=0
03:24:54:WU01:FS00:0xa4:- Digital signature verified
03:24:54:WU01:FS00:0xa4:Project: 9007 (Run 982, Clone 3, Gen 74)
03:24:54:WU01:FS00:0xa4:Assembly optimizations on if available.
03:24:54:WU01:FS00:0xa4:Entering M.D.
03:24:55:WU00:FS00:Upload complete
03:24:55:WU00:FS00:Server responded WORK_ACK (400)
03:24:55:WU00:FS00:Final credit estimate, 362.00 points
03:24:55:WU00:FS00:Cleaning up
03:25:00:WU01:FS00:0xa4:Mapping NT from 1 to 1
03:25:02:WU01:FS00:0xa4:Completed 0 out of 250000 steps (0%)
03:55:49:WU01:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
04:26:31:WU01:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
******************************* Date: 2014-05-22 *******************************
04:57:14:WU01:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
05:27:59:WU01:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
05:58:54:WU01:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
06:29:38:WU01:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
07:00:43:WU01:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
07:32:38:WU01:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
08:03:19:WU01:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
08:34:05:WU01:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
09:06:12:WU01:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
09:37:02:WU01:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
10:07:52:WU01:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
10:38:39:WU01:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
11:09:27:WU01:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
11:40:13:WU01:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
12:11:04:WU01:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
12:41:53:WU01:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
13:12:46:WU01:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
13:43:35:WU01:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
14:14:24:WU01:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
14:45:15:WU01:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
15:17:40:WU01:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
15:48:35:WU01:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
16:19:24:WU01:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
16:50:20:WU01:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
17:21:08:WU01:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
17:47:51:154:127.0.0.1:New Web connection
17:52:12:WU01:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
Here is the copy of the log file on the second computer I setup, its the same as the first... let me know what I did wrong?
I am not part of a team but if someone wants to take me on, I am building a computer farm out of old parts, should have 4-6 running when I am done...
Windows has detected an error 20:28:56:WU01:FS01:0x17:ERROR:Win32: 0xc0000005: Exception access violation which indicates a memory problem. This has a number of possible causes (in no particular order).
1) Your system is overclocked and is unstable
2) Your system is generating enough heat ant keeping too much of it inside, causing the hardware to fail.
3) Your RAM is defective (Run memtext86* overnight).
4) You need to get newer GPU drivers from ATI. (Driver support for the E-series iGPUs is relatively recent and I'm not sure how it handles simultaneous heavy GPU tasks if you're doing something else).
Other more obscure problems might also be present, but let's start with the 4 most likely.
Both computers I am running the app on are the same, they were bought recently 6months? and they both are exhibiting the same errors... So with the errors, is the computer still doing anything? I am gathering points... so is it doing something just not as efficiently as it could?
I have the side off, this computer and its not even warm inside?
Any help is greatly appreciated... I want to have these two computers running since they don't really get used for anything else, but I am lacking technical knowledge and need help
Machine #2:
Machine 3:
What Windows video driver are you using and where did it come from?
Preferably, you are running an AMD/ATI's 14.4 video driver and you specifically got it by downloading it from AMD/ATI. Do not use Microsoft's video driver and do not use one from an OEM for they often do not contain the required OpenCL drivers. Do not allow Microsoft to automatically update drivers for it will replace the drivers with Microsoft's. If you do have a driver issue (which I suspect) please run a driver cleaner before installing the official AMD/ATI video driver to prevent old driver files to remain and thus mess up the new install.
