2 Clients on one machine?
Hey guys!
Now here's my question:
Can I run 2 clients at the same time on the same machine and manage them from advanced control?
Basically, I want to continue folding on my CPU for Team 32, but I want to fold on my 270x and 7850 for team 224497 to get some coins.
Obviously you can't fold for 2 teams at once, so I thought running 2 clients (and using a new username on one of the clients) would solve this issue.
Thanks for the help guys!
P.s For those who helped in my first topic 7.4.4 won't run, I re-installed Windows and 7.4.4 works like a charm now!
Mod Edit: Post Edited To Adhere To Forum Policy - PantherX
Machine #2:
Machine 3:
Re: 2 Clients on one machine?
You can run the NaCl client (CPU-only) with v7 (GPU); or you can run v6 with v7; The last option is to run multiple v6 clients together.
I have not tried it, nor have I heard of anyone trying, but in v7 it may be possible to specify the user, team, and passkey at the slot level as an extra client option like is done with client-type.
Wasn't it possible to set a different team number in slots ?
Last edited by ChristianVirtual on Sun May 11, 2014 2:44 am, edited 1 time in total.
NaCl client?P5-133XL wrote:You can run the NaCl client (CPU-only) with v7 (GPU); or you can run v6 with v7; The last option is to run multiple v6 clients together.
The Chrome folding thingy?
Yes, the NaCl client is the Chrome folding thingy. P.S. My observation is that the Chrome thingy WU's generally give a little more PPD than the average v7 project.
Glad to hear that V7.4.4 is functioning correctly on your system now.
Last I checked (several versions ago), there was the ability to configure each Slot with different username, passkey and team number. I am pretty sure that the feature still exists so maybe you can now test it out. Do note that I am not sure how FAHControl and Web Control will handle this. My best guess is that it will display the first username/team combination. To configure it:
1) Open up Advanced Control (AKA FAHControl)
2) Click Configure
3) Select the Slots Tab
4) Select the appropriate Slot
5) Click Edit
6) Under Extra slot options (expert only), click Add:
Value: YOURUSERNAME
7) Click OK
8) Repeat steps 6 to 7 but using these values:
Value: YOURTEAMNUMBER
Value: YOURPASSKEY
9) Click OK
10) Click Save
11) Your new configuration should look something like this:
Do note that you can use the same username for different teams and the same applies for the passkey. However, if either the passkey or the username changes, then that new username/passkey combination must qualify again for QRB.
If this doesn't work, then running a combination of Clients as P5-133XL suggested would be the alternative.
2) Click Configure
5) Click Edit
Value: YOURUSERNAME
7) Click OK
Value: YOURPASSKEY
9) Click OK
10) Click Save
05:57:30:<config>
05:57:30: <!-- Folding Core -->
05:57:30: <core-priority v='low'/>
05:57:30:
05:57:30: <!-- HTTP Server -->
05:57:30: <allow v='127.0.0.1 192.168.1.1-192.168.1.10'/>
05:57:30:
05:57:30: <!-- Network -->
05:57:30: <proxy v=':8080'/>
05:57:30:
05:57:30: <!-- Remote Command Server -->
05:57:30: <password v='*********'/>
05:57:30:
05:57:30: <!-- Slot Control -->
05:57:30: <power v='full'/>
05:57:30:
05:57:30: <!-- User Information -->
05:57:30: <passkey v='********************************'/>
05:57:30: <team v='69411'/>
05:57:30: <user v='PantherX'/>
05:57:30:
05:57:30: <!-- Folding Slots -->
05:57:30: <slot id='0' type='CPU'>
05:57:30: <cpus v='6'/>
05:57:30: <max-slot-errors v='1'/>
05:57:30: <max-unit-errors v='1'/>
05:57:30: <next-unit-percentage v='100'/>
05:57:30: <pause-on-start v='true'/>
05:57:30: </slot>
05:57:30: <slot id='1' type='GPU'>
05:57:30: <passkey v='YOURPASSKEY'/>
05:57:30: <team v='YOURTEAMNUMBER'/>
05:57:30: <user v='YOURUSERNAME'/>
05:57:30: </slot>
05:57:30: <slot id='2' type='GPU'>
05:57:30: </slot>
05:57:30:</config>
Awesome!PantherX wrote:Glad to hear that V7.4.4 is functioning correctly on your system now.
2) Click Configure
5) Click Edit
Value: YOURUSERNAME
7) Click OK
Value: YOURPASSKEY
9) Click OK
10) Click Save
11) Your new configuration should look something like this:Do note that you can use the same username for different teams and the same applies for the passkey. However, if either the passkey or the username changes, then that new username/passkey combination must qualify again for QRB.Code: Select all
05:57:30:<config> 05:57:30: <!-- Folding Core --> 05:57:30: <core-priority v='low'/> 05:57:30: 05:57:30: <!-- HTTP Server --> 05:57:30: <allow v='127.0.0.1 192.168.1.1-192.168.1.10'/> 05:57:30: 05:57:30: <!-- Network --> 05:57:30: <proxy v=':8080'/> 05:57:30: 05:57:30: <!-- Remote Command Server --> 05:57:30: <password v='*********'/> 05:57:30: 05:57:30: <!-- Slot Control --> 05:57:30: <power v='full'/> 05:57:30: 05:57:30: <!-- User Information --> 05:57:30: <passkey v='********************************'/> 05:57:30: <team v='69411'/> 05:57:30: <user v='PantherX'/> 05:57:30: 05:57:30: <!-- Folding Slots --> 05:57:30: <slot id='0' type='CPU'> 05:57:30: <cpus v='6'/> 05:57:30: <max-slot-errors v='1'/> 05:57:30: <max-unit-errors v='1'/> 05:57:30: <next-unit-percentage v='100'/> 05:57:30: <pause-on-start v='true'/> 05:57:30: </slot> 05:57:30: <slot id='1' type='GPU'> 05:57:30: <passkey v='YOURPASSKEY'/> 05:57:30: <team v='YOURTEAMNUMBER'/> 05:57:30: <user v='YOURUSERNAME'/> 05:57:30: <max-slot-errors v='1'/> 05:57:30: <max-unit-errors v='1'/> 05:57:30: <next-unit-percentage v='100'/> 05:57:30: <pause-on-start v='true'/> 05:57:30: </slot> 05:57:30: <slot id='2' type='GPU'> 05:57:30: <passkey v='YOURPASSKEY'/> 05:57:30: <team v='YOURTEAMNUMBER'/> 05:57:30: <user v='YOURUSERNAME'/> 05:57:30: <max-slot-errors v='1'/> 05:57:30: <max-unit-errors v='1'/> 05:57:30: <next-unit-percentage v='100'/> 05:57:30: <pause-on-start v='true'/> 05:57:30: </slot> 05:57:30:</config>
I will test this now.
Whether you configure multiple slots in V7 to credit different accounts or you use multiple clients to accomplish the same thing, you run into the same resource limitations and you need to manage them yourself. If you have N CPUs (or multiple GPUs) and you allocate some to one account an the rest to another account, be careful not to over-allocate what your machine can actually do. QRB will be reduced, of course but more slots or more clients doesn't increase production and may, in fact, reduce it. Scrutinize the overall effects of whatever changes you make.
Yes, I was thinking of this.bruce wrote:Whether you configure multiple slots in V7 to credit different accounts or you use multiple clients to accomplish the same thing, you run into the same resource limitations and you need to manage them yourself. If you have N CPUs (or multiple GPUs) and you allocate some to one account an the rest to another account, be careful not to over-allocate what your machine can actually do. QRB will be reduced, of course but more slots or more clients doesn't increase production and may, in fact, reduce it. Scrutinize the overall effects of whatever changes you make.
Looking at ~81K PPD.
A 6850, 270x and my CPU combined.
I have no idea if that's low.
But I'm glad everything is running smoothly. Although, the 6850 has an ETA of 3 days!
17 hours for the 270x
