171.64.65.56
jimerickson
- Hardware configuration: Parts:
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16) - Location: ames, iowa
171.64.65.56
getting failed transfers when attempting to upload to this server. and when they do finally upload they are dumped. p9406 &p9408.
Re: 171.64.65.56
The server has been regularly receiving WUs. Even without the PRCG, I was able to locate several WUs which were successfully completed recently and another which was not, though they were not your WUs. Please report which specific WUs you're talking about and when this happened. What was the error message in your log?
jimerickson
Re: 171.64.65.56
project 9406, run 659, clone 0, gen 10
server responded GOT_ALREADY (434)
server did not like results, dumping
P5-133XL
Machine #2:
Machine 3:
Re: 171.64.65.56
Check your logs for a previous failed return. A "Got Already" message means that the server has already received that particular WU from that specific machine. Very commonly the cause is an internet interruption that prevented the client from receiving the servers acknowledgement so the client waits a while and re-sends. Of course, since the WU was previously received you will not get credit for it again and there is no need to resend it so the client dumps the WU and continues on.
Re: 171.64.65.56
Never mind. Killed FahControl and restarted it. The upload went through fine this time.
Hi,
I'm seeing a similar problem when uploading result. Here is a sample of the error messages in the log file:
Hi,
05:15:16:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:15:17:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:7627 run:60 clone:0 gen:57 core:0x15 unit:0x00000047664f2dd152a3c43c475b123c
05:15:17:WU00:FS00:Uploading 800.60KiB to 171.64.65.105
05:15:17:WU00:FS00:Connecting to 171.64.65.105:8080
05:15:32:Server connection id=2 ended
05:15:38:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:15:38:WU00:FS00:Connecting to 171.64.65.105:80
05:15:39:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
05:15:59:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:15:59:WU00:FS00:Trying to send results to collection server
05:15:59:WU00:FS00:Uploading 800.60KiB to 171.65.103.160
05:15:59:WU00:FS00:Connecting to 171.65.103.160:8080
05:16:09:Server connection id=3 ended
05:16:20:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:16:20:WU00:FS00:Connecting to 171.65.103.160:80
05:16:41:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:16:41:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:7627 run:60 clone:0 gen:57 core:0x15 unit:0x00000047664f2dd152a3c43c475b123c
05:16:41:WU00:FS00:Uploading 800.60KiB to 171.64.65.105
05:16:41:WU00:FS00:Connecting to 171.64.65.105:8080
05:17:01:Server connection id=4 on 0.0.0.0:36330 from 127.0.0.1
05:17:02:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
05:17:02:WU00:FS00:Connecting to 171.64.65.105:80
05:17:23:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.105:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:17:23:WU00:FS00:Trying to send results to collection server-
P5-133XL
Machine #2:
Machine 3:
Re: 171.64.65.56
Sam-I-Am, I do not see a similar problem at all. As far as I can tell from your log, you have no network connection because everything is blocked. Commonly you see that when your firewall blocks folding traffic or you have an internet security suite that is blocking folding but it can also happen if your network goes totally down.
jimerickson
Re: 171.64.65.56
p9408 run 56 clone 0 gen 17
exception transfer failed: 10002: recieved short response expected 512 bytes got 0
this unit has been attempting to upload for an over an hour.
can someone please look into it?
edit typo
edit typo
Re: 171.64.65.56
Server 171.64.65.56 has accepted over 100 WUs during the past hour plus 33 between 20:00 and 20:10:11 PDT. Neither Net Load nor CPU Load seem to be excessive. I'll check with the server's owner and see if he can see anything that I don't see.
Please post enough of your log that we can see what's going on.
(Yep. Your typo had me searching high and low.)
jimerickson
Re: 171.64.65.56
it finally uploaded
02:58:36:WU01:FS01:Upload 50.90%
02:58:36:ERROR:WU01:FS01:Exception: Transfer failed
02:58:36:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9408 run:56 clone:0 gen:17 core:0x17 unit:0x000000140a3b1e5c53424cb8953a033f
02:58:36:WU01:FS01:Uploading 21.61MiB to 171.64.65.56
02:58:36:WU01:FS01:Connecting to 171.64.65.56:8080
02:58:38:WU06:FS01:0x17:Completed 140000 out of 2000000 steps (7%)
02:58:42:WU01:FS01:Upload 7.81%
02:58:48:WU01:FS01:Upload 12.72%
02:58:54:WU01:FS01:Upload 15.90%
02:59:00:WU01:FS01:Upload 19.95%
02:59:06:WU01:FS01:Upload 24.00%
02:59:13:WU01:FS01:Upload 27.47%
02:59:19:WU01:FS01:Upload 28.34%
02:59:29:WU01:FS01:Upload 36.15%
02:59:37:WU01:FS01:Upload 42.51%
02:59:44:WU01:FS01:Upload 46.85%
02:59:50:WU01:FS01:Upload 50.03%
02:59:56:WU01:FS01:Upload 54.08%
03:00:03:WU01:FS01:Upload 57.84%
03:00:10:WU01:FS01:Upload 62.46%
03:00:17:WU01:FS01:Upload 66.51%
03:00:20:WU03:FS03:0x17:Completed 300000 out of 2000000 steps (15%)
03:00:23:WU01:FS01:Upload 70.85%
03:00:30:WU01:FS01:Upload 74.90%
03:00:35:WU02:FS02:0x17:Completed 1980000 out of 2000000 steps (99%)
03:00:37:WU01:FS01:Upload 79.23%
03:00:44:WU01:FS01:Upload 82.99%
03:00:50:WU01:FS01:Upload 87.04%
03:00:56:WU01:FS01:Upload 91.09%
03:01:03:WU01:FS01:Upload 95.14%
03:01:10:WU01:FS01:Upload 99.48%
03:01:18:WU04:FS04:0x17:Completed 1250000 out of 5000000 steps (25%)
03:01:37:WU06:FS01:0x17:Completed 160000 out of 2000000 steps (8%)
03:02:14:WARNING:WU01:FS01:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
03:02:14:WU01:FS01:Trying to send results to collection server
03:02:14:WU01:FS01:Uploading 21.61MiB to 171.65.103.160
03:02:14:WU01:FS01:Connecting to 171.65.103.160:8080
03:02:20:WU01:FS01:Upload 8.39%
03:02:26:WU01:FS01:Upload 11.86%
03:02:32:WU01:FS01:Upload 14.75%
03:02:38:WU01:FS01:Upload 18.22%
03:02:44:WU01:FS01:Upload 21.69%
03:02:50:WU01:FS01:Upload 25.45%
03:02:56:WU01:FS01:Upload 28.92%
03:03:02:WU01:FS01:Upload 32.97%
03:03:08:WU01:FS01:Upload 36.15%
03:03:25:WU05:FS00:0xa3:Completed 400000 out of 500000 steps (80%)
03:03:41:WU03:FS03:0x17:Completed 320000 out of 2000000 steps (16%)
03:04:18:WU01:FS01:Upload 39.62%
03:04:29:WU06:FS01:0x17:Completed 180000 out of 2000000 steps (9%)
03:04:40:WU02:FS02:0x17:Completed 2000000 out of 2000000 steps (100%)
03:04:41:WU00:FS02:Connecting to 171.67.108.201:80
03:04:41:WU00:FS02:Assigned to work server 171.64.65.56
03:04:41:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GK110 [GeForce GTX 780] from 171.64.65.56
03:04:41:WU00:FS02:Connecting to 171.64.65.56:8080
03:04:42:WU00:FS02:Downloading 5.06MiB
03:04:47:WU00:FS02:Download complete
03:04:48:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9406 run:345 clone:0 gen:26 core:0x17 unit:0x000000280a3b1e5c533e0850a4d4dc9f
03:04:49:WU02:FS02:0x17:Saving result file logfile_01.txt
03:04:49:WU02:FS02:0x17:Saving result file checkpointState.xml
03:04:51:WU02:FS02:0x17:Saving result file checkpt.crc
03:04:51:WU02:FS02:0x17:Saving result file log.txt
03:04:51:WU02:FS02:0x17:Saving result file positions.xtc
03:04:54:WU02:FS02:0x17:Folding@home Core Shutdown: FINISHED_UNIT
03:04:54:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:04:54:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9406 run:878 clone:0 gen:13 core:0x17 unit:0x000000130a3b1e5c533e88deb301737d
03:04:54:WU02:FS02:Uploading 15.54MiB to 171.64.65.56
03:04:54:WU02:FS02:Connecting to 171.64.65.56:8080
03:04:54:WU00:FS02:Starting
03:04:54:WU00:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /home/jim/fah/cores/www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 2423 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
03:04:54:WU00:FS02:Started FahCore on PID 31460
03:04:54:WU00:FS02:Core PID:31464
03:04:54:WU00:FS02:FahCore 0x17 started
03:04:55:WU00:FS02:0x17:*********************** Log Started 2014-05-13T03:04:54Z ***********************
03:04:55:WU00:FS02:0x17:Project: 9406 (Run 345, Clone 0, Gen 26)
03:04:55:WU00:FS02:0x17:Unit: 0x000000280a3b1e5c533e0850a4d4dc9f
03:04:55:WU00:FS02:0x17:CPU: 0x00000000000000000000000000000000
03:04:55:WU00:FS02:0x17:Machine: 2
03:04:55:WU00:FS02:0x17:Reading tar file state.xml
03:04:55:WU00:FS02:0x17:Reading tar file system.xml
03:04:55:WU00:FS02:0x17:Reading tar file integrator.xml
03:04:55:WU00:FS02:0x17:Reading tar file core.xml
03:04:55:WU00:FS02:0x17:Digital signatures verified
03:05:00:WU02:FS02:Upload 10.86%
03:05:06:WU02:FS02:Upload 17.30%
03:05:14:WU02:FS02:Upload 22.52%
03:05:20:WU02:FS02:Upload 23.73%
03:05:30:WU02:FS02:Upload 35.40%
03:05:38:WU02:FS02:Upload 44.24%
03:05:44:WU02:FS02:Upload 50.28%
03:05:50:WU02:FS02:Upload 54.70%
03:05:57:WU02:FS02:Upload 60.33%
03:06:04:WU02:FS02:Upload 66.37%
03:06:11:WU02:FS02:Upload 72.00%
03:06:18:WU02:FS02:Upload 77.63%
03:06:24:WU02:FS02:Upload 83.26%
03:06:31:WU02:FS02:Upload 88.89%
03:06:37:WU02:FS02:Upload 93.32%
03:06:43:WU02:FS02:Upload 99.35%
03:06:56:WU03:FS03:0x17:Completed 340000 out of 2000000 steps (17%)
03:07:01:WU00:FS02:0x17:Completed 0 out of 2000000 steps (0%)
03:07:02:WU02:FS02:Upload complete
03:07:02:WU02:FS02:Server responded WORK_ACK (400)
03:07:02:WU02:FS02:Final credit estimate, 35735.00 points
03:07:02:WU02:FS02:Cleaning up
03:07:21:WU06:FS01:0x17:Completed 200000 out of 2000000 steps (10%)
03:08:09:WU04:FS04:0x17:Completed 1300000 out of 5000000 steps (26%)
03:10:16:WU05:FS00:0xa3:Completed 405000 out of 500000 steps (81%)
03:10:17:WU03:FS03:0x17:Completed 360000 out of 2000000 steps (18%)
03:10:20:WU06:FS01:0x17:Completed 220000 out of 2000000 steps (11%)
03:10:35:WU00:FS02:0x17:Completed 20000 out of 2000000 steps (1%)
03:13:12:WU06:FS01:0x17:Completed 240000 out of 2000000 steps (12%)
03:13:29:WU03:FS03:0x17:Completed 380000 out of 2000000 steps (19%)
03:14:07:WU00:FS02:0x17:Completed 40000 out of 2000000 steps (2%)
03:14:58:WU04:FS04:0x17:Completed 1350000 out of 5000000 steps (27%)
03:16:12:WU06:FS01:0x17:Completed 260000 out of 2000000 steps (13%)
03:16:41:WU03:FS03:0x17:Completed 400000 out of 2000000 steps (20%)
03:17:06:WU05:FS00:0xa3:Completed 410000 out of 500000 steps (82%)
03:17:45:WU00:FS02:0x17:Completed 60000 out of 2000000 steps (3%)
03:19:03:WU06:FS01:0x17:Completed 280000 out of 2000000 steps (14%)
03:20:03:WU03:FS03:0x17:Completed 420000 out of 2000000 steps (21%)
03:21:17:WU00:FS02:0x17:Completed 80000 out of 2000000 steps (4%)
03:21:49:WU04:FS04:0x17:Completed 1400000 out of 5000000 steps (28%)
03:21:49:WU01:FS01:Upload 40.49%
03:21:49:ERROR:WU01:FS01:Exception: Transfer failed
03:21:50:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9408 run:56 clone:0 gen:17 core:0x17 unit:0x000000140a3b1e5c53424cb8953a033f
03:21:50:WU01:FS01:Uploading 21.61MiB to 171.64.65.56
03:21:50:WU01:FS01:Connecting to 171.64.65.56:8080
03:21:55:WU06:FS01:0x17:Completed 300000 out of 2000000 steps (15%)
03:21:57:WU01:FS01:Upload 8.96%
03:22:03:WU01:FS01:Upload 13.01%
03:22:09:WU01:FS01:Upload 16.77%
03:22:15:WU01:FS01:Upload 20.53%
03:22:21:WU01:FS01:Upload 24.00%
03:22:27:WU01:FS01:Upload 27.76%
03:22:33:WU01:FS01:Upload 31.23%
03:22:39:WU01:FS01:Upload 34.99%
03:22:45:WU01:FS01:Upload 38.17%
03:22:51:WU01:FS01:Upload 42.80%
03:22:58:WU01:FS01:Upload 46.27%
03:23:04:WU01:FS01:Upload 50.90%
03:23:10:WU01:FS01:Upload 54.37%
03:23:16:WU01:FS01:Upload 55.81%
03:23:17:WU03:FS03:0x17:Completed 440000 out of 2000000 steps (22%)
03:23:54:WU05:FS00:0xa3:Completed 415000 out of 500000 steps (83%)
03:24:17:WU01:FS01:Upload 56.39%
03:24:17:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
03:24:17:WU01:FS01:Trying to send results to collection server
03:24:17:WU01:FS01:Uploading 21.61MiB to 171.65.103.160
03:24:17:WU01:FS01:Connecting to 171.65.103.160:8080
03:24:23:WU01:FS01:Upload 8.68%
03:24:29:WU01:FS01:Upload 12.43%
03:24:35:WU01:FS01:Upload 16.19%
03:24:41:WU01:FS01:Upload 19.66%
03:24:47:WU01:FS01:Upload 23.42%
03:24:50:WU00:FS02:0x17:Completed 100000 out of 2000000 steps (5%)
03:24:53:WU01:FS01:Upload 27.18%
03:24:55:WU06:FS01:0x17:Completed 320000 out of 2000000 steps (16%)
03:24:59:WU01:FS01:Upload 30.65%
03:25:05:WU01:FS01:Upload 34.41%
03:25:11:WU01:FS01:Upload 38.17%
03:26:16:WU01:FS01:Upload 39.62%
03:26:39:WU03:FS03:0x17:Completed 460000 out of 2000000 steps (23%)
03:27:47:WU06:FS01:0x17:Completed 340000 out of 2000000 steps (17%)
03:28:30:WU00:FS02:0x17:Completed 120000 out of 2000000 steps (6%)
03:28:40:WU04:FS04:0x17:Completed 1450000 out of 5000000 steps (29%)
03:29:54:WU03:FS03:0x17:Completed 480000 out of 2000000 steps (24%)
03:30:46:WU06:FS01:0x17:Completed 360000 out of 2000000 steps (18%)
03:30:46:WU05:FS00:0xa3:Completed 420000 out of 500000 steps (84%)
03:32:04:WU00:FS02:0x17:Completed 140000 out of 2000000 steps (7%)
03:33:08:WU03:FS03:0x17:Completed 500000 out of 2000000 steps (25%)
03:33:38:WU06:FS01:0x17:Completed 380000 out of 2000000 steps (19%)
03:35:32:WU04:FS04:0x17:Completed 1500000 out of 5000000 steps (30%)
03:35:44:WU00:FS02:0x17:Completed 160000 out of 2000000 steps (8%)
03:36:30:WU03:FS03:0x17:Completed 520000 out of 2000000 steps (26%)
03:36:30:WU06:FS01:0x17:Completed 400000 out of 2000000 steps (20%)
03:37:36:WU05:FS00:0xa3:Completed 425000 out of 500000 steps (85%)
03:39:18:WU00:FS02:0x17:Completed 180000 out of 2000000 steps (9%)
03:39:29:WU06:FS01:0x17:Completed 420000 out of 2000000 steps (21%)
03:39:45:WU03:FS03:0x17:Completed 540000 out of 2000000 steps (27%)
03:42:21:WU06:FS01:0x17:Completed 440000 out of 2000000 steps (22%)
03:42:24:WU04:FS04:0x17:Completed 1550000 out of 5000000 steps (31%)
03:42:52:WU00:FS02:0x17:Completed 200000 out of 2000000 steps (10%)
03:43:06:WU03:FS03:0x17:Completed 560000 out of 2000000 steps (28%)
03:43:45:WU01:FS01:Upload 40.20%
03:43:45:ERROR:WU01:FS01:Exception: Transfer failed
03:43:45:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9408 run:56 clone:0 gen:17 core:0x17 unit:0x000000140a3b1e5c53424cb8953a033f
03:43:45:WU01:FS01:Uploading 21.61MiB to 171.64.65.56
03:43:45:WU01:FS01:Connecting to 171.64.65.56:8080
03:43:52:WU01:FS01:Upload 8.68%
03:43:58:WU01:FS01:Upload 12.72%
03:44:04:WU01:FS01:Upload 16.48%
03:44:10:WU01:FS01:Upload 20.24%
03:44:16:WU01:FS01:Upload 24.00%
03:44:22:WU01:FS01:Upload 27.76%
03:44:27:WU05:FS00:0xa3:Completed 430000 out of 500000 steps (86%)
03:44:28:WU01:FS01:Upload 31.23%
03:44:34:WU01:FS01:Upload 34.70%
03:44:40:WU01:FS01:Upload 37.88%
03:44:47:WU01:FS01:Upload 41.93%
03:44:53:WU01:FS01:Upload 46.27%
03:44:59:WU01:FS01:Upload 49.45%
03:45:05:WU01:FS01:Upload 52.92%
03:45:11:WU01:FS01:Upload 56.39%
03:45:18:WU01:FS01:Upload 57.84%
03:45:20:WU06:FS01:0x17:Completed 460000 out of 2000000 steps (23%)
03:45:25:WU01:FS01:Upload 64.78%
03:45:31:WU01:FS01:Upload 67.38%
03:45:37:WU01:FS01:Upload 72.29%
03:45:44:WU01:FS01:Upload 76.34%
03:45:50:WU01:FS01:Upload 80.68%
03:45:56:WU01:FS01:Upload 84.15%
03:46:03:WU01:FS01:Upload 88.20%
03:46:09:WU01:FS01:Upload 92.54%
03:46:15:WU01:FS01:Upload 95.72%
03:46:21:WU01:FS01:Upload 99.48%
03:46:21:WU03:FS03:0x17:Completed 580000 out of 2000000 steps (29%)
03:46:32:WU00:FS02:0x17:Completed 220000 out of 2000000 steps (11%)
03:46:36:WU01:FS01:Upload complete
03:46:36:WU01:FS01:Server responded WORK_ACK (400)
03:46:36:WU01:FS01:Final credit estimate, 60727.00 points
03:46:36:WU01:FS01:Cleaning up
03:48:12:WU06:FS01:0x17:Completed 480000 out of 2000000 steps (24%)
jimerickson
Re: 171.64.65.56
project:9408 run:914 clone:0 gen:15 was this unit uploaded successfully? am i missing the uploaded message some how?
17:29:12:WU01:FS03:Sending unit results: id:01 state:SEND error:NO_ERROR project:9408 run:914 clone:0 gen:15 core:0x17 unit:0x000000110a3b1e5c5342e8a81d871a45
17:29:12:WU01:FS03:Uploading 23.30MiB to 171.64.65.56
17:29:12:WU01:FS03:Connecting to 171.64.65.56:8080
17:29:12:WU02:FS03:Starting
17:29:12:WU02:FS03:Running FahCore: /usr/bin/FAHCoreWrapper /home/jim/fah/cores/www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 02 -suffix 01 -version 704 -lifeline 2421 -checkpoint 15 -gpu 2 -gpu-vendor nvidia
17:29:12:WU02:FS03:Started FahCore on PID 16635
17:29:12:WU02:FS03:Core PID:16639
17:29:12:WU02:FS03:FahCore 0x17 started
17:29:12:WU02:FS03:0x17:*********************** Log Started 2014-05-13T17:29:12Z ***********************
17:29:12:WU02:FS03:0x17:Project: 9406 (Run 295, Clone 0, Gen 40)
17:29:12:WU02:FS03:0x17:Unit: 0x000000340a3b1e5c533dff634ca27ef2
17:29:12:WU02:FS03:0x17:CPU: 0x00000000000000000000000000000000
17:29:12:WU02:FS03:0x17:Machine: 3
17:29:12:WU02:FS03:0x17:Reading tar file state.xml
17:29:12:WU02:FS03:0x17:Reading tar file system.xml
17:29:13:WU02:FS03:0x17:Reading tar file integrator.xml
17:29:13:WU02:FS03:0x17:Reading tar file core.xml
17:29:13:WU02:FS03:0x17:Digital signatures verified
17:29:13:WU03:FS02:0x17:Completed 380000 out of 2000000 steps (19%)
17:29:19:WU01:FS03:Upload 8.32%
17:29:29:WU01:FS03:Upload 11.80%
17:29:35:WU01:FS03:Upload 17.17%
17:29:41:WU01:FS03:Upload 20.65%
17:29:46:WU04:FS04:0x17:Completed 1080000 out of 2000000 steps (54%)
17:29:47:WU01:FS03:Upload 23.07%
17:29:53:WU01:FS03:Upload 26.02%
17:29:59:WU01:FS03:Upload 28.97%
17:30:05:WU01:FS03:Upload 32.46%
17:30:11:WU01:FS03:Upload 35.94%
17:30:17:WU01:FS03:Upload 39.43%
17:30:24:WU01:FS03:Upload 42.38%
17:30:30:WU01:FS03:Upload 46.14%
17:30:36:WU01:FS03:Upload 49.62%
17:30:42:WU01:FS03:Upload 52.57%
17:30:47:WU02:FS03:0x17:Completed 0 out of 2000000 steps (0%)
17:30:48:WU01:FS03:Upload 56.06%
17:30:54:WU01:FS03:Upload 59.55%
17:30:55:WU00:FS01:0x17:Completed 2000000 out of 5000000 steps (40%)
17:31:00:WU01:FS03:Upload 62.77%
17:31:06:WU01:FS03:Upload 66.52%
17:31:12:WU01:FS03:Upload 69.47%
17:31:18:WU01:FS03:Upload 73.50%
17:31:25:WU01:FS03:Upload 76.45%
17:31:32:WU01:FS03:Upload 77.25%
17:31:39:WU06:FS00:0xa3:Completed 240000 out of 500000 steps (48%)
17:31:41:WU01:FS03:Upload 86.64%
17:31:47:WU01:FS03:Upload 91.47%
17:31:53:WU01:FS03:Upload 94.95%
17:31:59:WU01:FS03:Upload 98.17%
17:32:30:WU03:FS02:0x17:Completed 400000 out of 2000000 steps (20%)
17:33:16:WU04:FS04:0x17:Completed 1100000 out of 2000000 steps (55%)
17:33:43:WU02:FS03:0x17:Completed 20000 out of 2000000 steps (1%)
17:35:53:WU03:FS02:0x17:Completed 420000 out of 2000000 steps (21%)
17:36:31:WU02:FS03:0x17:Completed 40000 out of 2000000 steps (2%)
17:36:54:WU04:FS04:0x17:Completed 1120000 out of 2000000 steps (56%)
17:37:19:WU00:FS01:0x17:Completed 2050000 out of 5000000 steps (41%)
17:38:25:WU06:FS00:0xa3:Completed 245000 out of 500000 steps (49%)
17:39:10:WU03:FS02:0x17:Completed 440000 out of 2000000 steps (22%)
17:39:26:WU02:FS03:0x17:Completed 60000 out of 2000000 steps (3%)
17:40:24:WU04:FS04:0x17:Completed 1140000 out of 2000000 steps (57%)
17:42:14:WU02:FS03:0x17:Completed 80000 out of 2000000 steps (4%)
17:42:33:WU03:FS02:0x17:Completed 460000 out of 2000000 steps (23%)
17:43:43:WU00:FS01:0x17:Completed 2100000 out of 5000000 steps (42%)
17:44:02:WU04:FS04:0x17:Completed 1160000 out of 2000000 steps (58%)
17:45:02:WU02:FS03:0x17:Completed 100000 out of 2000000 steps (5%)
17:45:12:WU06:FS00:0xa3:Completed 250000 out of 500000 steps (50%)
17:45:50:WU03:FS02:0x17:Completed 480000 out of 2000000 steps (24%)
17:47:35:WU04:FS04:0x17:Completed 1180000 out of 2000000 steps (59%)
17:47:56:WU02:FS03:0x17:Completed 120000 out of 2000000 steps (6%)
17:49:08:WU03:FS02:0x17:Completed 500000 out of 2000000 steps (25%)
17:50:07:WU00:FS01:0x17:Completed 2150000 out of 5000000 steps (43%)
17:50:44:WU02:FS03:0x17:Completed 140000 out of 2000000 steps (7%)
17:51:07:WU04:FS04:0x17:Completed 1200000 out of 2000000 steps (60%)
17:51:57:WU06:FS00:0xa3:Completed 255000 out of 500000 steps (51%)
17:52:31:WU03:FS02:0x17:Completed 520000 out of 2000000 steps (26%)
17:53:39:WU02:FS03:0x17:Completed 160000 out of 2000000 steps (8%)
17:54:45:WU04:FS04:0x17:Completed 1220000 out of 2000000 steps (61%)
17:55:49:WU03:FS02:0x17:Completed 540000 out of 2000000 steps (27%)
17:56:27:WU02:FS03:0x17:Completed 180000 out of 2000000 steps (9%)
17:56:31:WU00:FS01:0x17:Completed 2200000 out of 5000000 steps (44%)
17:58:14:WU04:FS04:0x17:Completed 1240000 out of 2000000 steps (62%)
17:58:45:WU06:FS00:0xa3:Completed 260000 out of 500000 steps (52%)
17:59:12:WU03:FS02:0x17:Completed 560000 out of 2000000 steps (28%)
17:59:15:WU02:FS03:0x17:Completed 200000 out of 2000000 steps (10%)
18:01:53:WU04:FS04:0x17:Completed 1260000 out of 2000000 steps (63%)
18:02:09:WU02:FS03:0x17:Completed 220000 out of 2000000 steps (11%)
18:02:30:WU03:FS02:0x17:Completed 580000 out of 2000000 steps (29%)
18:02:55:WU00:FS01:0x17:Completed 2250000 out of 5000000 steps (45%)
18:04:57:WU02:FS03:0x17:Completed 240000 out of 2000000 steps (12%)
18:05:25:WU04:FS04:0x17:Completed 1280000 out of 2000000 steps (64%)
18:05:33:WU06:FS00:0xa3:Completed 265000 out of 500000 steps (53%)
18:05:47:WU03:FS02:0x17:Completed 600000 out of 2000000 steps (30%)
18:07:52:WU02:FS03:0x17:Completed 260000 out of 2000000 steps (13%)
18:08:57:WU04:FS04:0x17:Completed 1300000 out of 2000000 steps (65%)
18:09:11:WU03:FS02:0x17:Completed 620000 out of 2000000 steps (31%)
18:09:19:WU00:FS01:0x17:Completed 2300000 out of 5000000 steps (46%)
18:10:40:WU02:FS03:0x17:Completed 280000 out of 2000000 steps (14%)
18:12:21:WU06:FS00:0xa3:Completed 270000 out of 500000 steps (54%)
18:12:28:WU03:FS02:0x17:Completed 640000 out of 2000000 steps (32%)
18:12:35:WU04:FS04:0x17:Completed 1320000 out of 2000000 steps (66%)
18:13:28:WU02:FS03:0x17:Completed 300000 out of 2000000 steps (15%)
18:15:42:WU00:FS01:0x17:Completed 2350000 out of 5000000 steps (47%)
18:15:52:WU03:FS02:0x17:Completed 660000 out of 2000000 steps (33%)
18:16:04:WU04:FS04:0x17:Completed 1340000 out of 2000000 steps (67%)
18:16:22:WU02:FS03:0x17:Completed 320000 out of 2000000 steps (16%)
18:19:09:WU06:FS00:0xa3:Completed 275000 out of 500000 steps (55%)
18:19:09:WU03:FS02:0x17:Completed 680000 out of 2000000 steps (34%)
18:19:10:WU02:FS03:0x17:Completed 340000 out of 2000000 steps (17%)
18:19:43:WU04:FS04:0x17:Completed 1360000 out of 2000000 steps (68%)
18:22:05:WU02:FS03:0x17:Completed 360000 out of 2000000 steps (18%)
18:22:06:WU00:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
18:22:27:WU03:FS02:0x17:Completed 700000 out of 2000000 steps (35%)
18:23:16:WU04:FS04:0x17:Completed 1380000 out of 2000000 steps (69%)
18:24:52:WU02:FS03:0x17:Completed 380000 out of 2000000 steps (19%)
P5-133XL
Machine #2:
Machine 3:
Re: 171.64.65.56
Hi jimerickson (team 172800),
Your WU (P9408 R914 C0 G15) was added to the stats database on 2014-05-13 11:03:23 for 61178 points of credit.
jimerickson
Re: 171.64.65.56
well thats reassuring. but i would still like to figure out whats going on. this unit is still trying to upload. shall i dump it now that it is in the database?
P5-133XL
Machine #2:
Machine 3:
Re: 171.64.65.56
You can safely dump it. If it does upload, the client will give a "Got already" error and dump it anyway.
Re: 171.64.65.56
Not getting the acknowledgement message at the end of the upload points to a network problem. Something between the folding server and your system is blocking the response that the full WU has been uploaded. It could be a simple as a change in a firewall setting, or something more complicated to diagnose.
Re: 171.64.65.56
Do you connect through a proxy server or is it a direct connection?
The earlier remarks by "jimerickson"
suggest that the problem is at the server end, but we also need to eliminate the possiblities (including something on your end) leaving only one option that needs to be fixed.it finally uploaded
