WU 2665 Run 0 Clone 129 Gen 0
Running this on my E8400 OC'd to 3.96ghz, GA-P35-DS3L, Vista Home Premium 64bit, 4 gig ram.
My computer keeps crashing. Never had this problem with any other WU.
Doesn't crash at the same spot in the processing. I've seen 23%, 32%, 39% and the last time it crashed was a restart from a EUE that then crashed at 9%.
This computer is used for other things but it crashes at any time whether or not I'm doing anything else or just letting it fold.
WU keeps crashing my folder
Re: WU keeps crashing my folder
In my experience, when a work unit ends in the same place each time, the WU is bad. When a work unit ends in different places, it tells me it's not the WU causing data corruption.
What else do you think might be causing the data corruption?
Overclocking not as stable as you thought ?
I had the OC higher than the 3.96 ghz I have it at now. Had no problems with other WU's. Played Crysis, Far Cry and COD4 without any problems at 4.05 ghz. But as soon as it got that 2665 crashes started.toTOW wrote:Overclocking not as stable as you thought ?
This weekend I'll swap in a quad from one of my linux folders and hope to get a 2665 again so I can see if that will make a difference (maybe even tonight if I get home and it's crashed again).
I have no idea. Like I said, it crashes whether I'm there doing something else or not. I don't have any other stuff running in the background.7im wrote: What else do you think might be causing the data corruption?
I've had my anti-V do it's sweep while folding that 2665 and nothing happens.
I've got FahMon 2.3.2 to moniter my linux folders and it's crashed with it running and with it not running. No calls to the network printer from computer either.
That new work unit uses twice as much memory as previous work units. That might be something to check. Memtest v2.x pass all tests at that speed?
As we always say, being stable in other application (stress tests, games or benchmarks) doesn't mean being FAH stable ... FAH is pushing the hardware to its limits, and as 7im said, p2665 use a lot of memory, and is very demanding with the chipset and memory subsystem ...dedgar wrote:I had the OC higher than the 3.96 ghz I have it at now. Had no problems with other WU's. Played Crysis, Far Cry and COD4 without any problems at 4.05 ghz. But as soon as it got that 2665 crashes started.toTOW wrote:Overclocking not as stable as you thought ?
Memory test is done with no errors.
Got the quad swapped in and it seems to be chugging along fine. It's been running thru the night without a crash so far.
Guess the dual core just couldn't handle the 2665. But I'll keep an eye on it anyway.
Hi guys,
Thanks for the heads up. The person in charge of this server has been notified.
Thanks and happy weekend.
paula
paula
