Project: 9101 (R 128, C 1, G 35)
folding_hoomer
Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300
Post by folding_hoomer »
BAD_WORK_UNIT
875K@3826MHz, HD5870 (not folding), HD7870@1200MHz, Cat. 14.1 Beta, Win7 64 Bit
Initial Log and config:
*********************** Log Started 2014-04-27T19:55:06Z ***********************
19:55:06:************************* Folding@home Client *************************
19:55:06:      Website: http://folding.stanford.edu/
19:55:06:    Copyright: (c) 2009-2014 Stanford University
19:55:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:55:06:         Args:
19:55:06:       Config: C:/Users/Markus/AppData/Roaming/FAHClient/config.xml
19:55:06:******************************** Build ********************************
19:55:06:      Version: 7.4.4
19:55:06:         Date: Mar 4 2014
19:55:06:         Time: 20:26:54
19:55:06:      SVN Rev: 4130
19:55:06:       Branch: fah/trunk/client
19:55:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:55:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:55:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:55:06:     Platform: win32 XP
19:55:06:         Bits: 32
19:55:06:         Mode: Release
19:55:06:******************************* System ********************************
19:55:06:          CPU: Intel(R) Core(TM) i7 CPU K 875 @ 2.93GHz
19:55:06:       CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
19:55:06:         CPUs: 8
19:55:06:       Memory: 7.99GiB
19:55:06:  Free Memory: 6.50GiB
19:55:06:      Threads: WINDOWS_THREADS
19:55:06:   OS Version: 6.1
19:55:06:  Has Battery: false
19:55:06:   On Battery: false
19:55:06:   UTC Offset: 2
19:55:06:          PID: 3208
19:55:06:          CWD: C:/Users/Markus/AppData/Roaming/FAHClient
19:55:06:           OS: Windows 7 Professional
19:55:06:      OS Arch: AMD64
19:55:06:         GPUs: 2
19:55:06:        GPU 0: ATI:5 Pitcairn [Radeon HD 7800]
19:55:06:        GPU 1: ATI:4 Cypress [Radeon HD 5800/6800]
19:55:06:         CUDA: Not detected
19:55:06:Win32 Service: false
19:55:06:***********************************************************************
19:55:06:<config>
19:55:06:  <!-- Error Handling -->
19:55:06:  <max-slot-errors v='3'/>
19:55:06:  <max-unit-errors v='3'/>
19:55:06:
19:55:06:  <!-- Folding Core -->
19:55:06:  <core-priority v='low'/>
19:55:06:
19:55:06:  <!-- HTTP Server -->
19:55:06:  <allow v='192.168.2.100-192.168.2.110 127.0.0.1'/>
19:55:06:
19:55:06:  <!-- Logging -->
19:55:06:  <log-rotate-max v='50'/>
19:55:06:
19:55:06:  <!-- Network -->
19:55:06:  <proxy v=':8080'/>
19:55:06:
19:55:06:  <!-- Remote Command Server -->
19:55:06:  <command-allow-no-pass v='192.168.2.100-192.168.2.110 127.0.0.1'/>
19:55:06:
19:55:06:  <!-- Slot Control -->
19:55:06:  <power v='full'/>
19:55:06:
19:55:06:  <!-- User Information -->
19:55:06:  <passkey v='********************************'/>
19:55:06:  <team v='70335'/>
19:55:06:  <user v='folding_hoomer'/>
19:55:06:
19:55:06:  <!-- Folding Slots -->
19:55:06:  <slot id='0' type='GPU'>
19:55:06:    <client-type v='advanced'/>
19:55:06:    <next-unit-percentage v='100'/>
19:55:06:    <pause-on-start v='true'/>
19:55:06:  </slot>
19:55:06:  <slot id='1' type='CPU'>
19:55:06:    <client-type v='beta'/>
19:55:06:    <cpus v='6'/>
19:55:06:  </slot>
19:55:06:  <slot id='2' type='GPU'>
19:55:06:  </slot>
19:55:06:</config>
Error-Log:
14:50:35:WU01:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
14:50:36:WU00:FS00:Connecting to 171.67.108.201:80
14:50:37:WU00:FS00:Assigned to work server 171.64.65.93
14:50:37:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Pitcairn [Radeon HD 7800] from 171.64.65.93
14:50:37:WU00:FS00:Connecting to 171.64.65.93:8080
14:50:42:WU00:FS00:Downloading 2.90MiB
14:50:46:WU01:FS00:0x17:Saving result file logfile_01.txt
14:50:46:WU01:FS00:0x17:Saving result file checkpointState.xml
14:50:47:WU00:FS00:Download complete
14:50:47:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9101 run:128 clone:1 gen:35 core:0x17 unit:0x000000240a3b1e81533f3c57f8ca2459
14:50:49:WU00:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 3208 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:50:49:WU00:FS00:Started FahCore on PID 5712
14:50:49:WU00:FS00:Core PID:2608
14:50:49:WU00:FS00:FahCore 0x17 started
14:50:50:WU00:FS00:0x17:*********************** Log Started 2014-04-29T14:50:49Z ***********************
14:50:50:WU00:FS00:0x17:Project: 9101 (Run 128, Clone 1, Gen 35)
14:50:50:WU00:FS00:0x17:Unit: 0x000000240a3b1e81533f3c57f8ca2459
14:50:50:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
14:50:50:WU00:FS00:0x17:Machine: 0
14:50:50:WU00:FS00:0x17:Reading tar file state.xml
14:50:50:WU00:FS00:0x17:Reading tar file system.xml
14:50:50:WU00:FS00:0x17:Reading tar file integrator.xml
14:50:50:WU00:FS00:0x17:Reading tar file core.xml
14:50:50:WU00:FS00:0x17:Digital signatures verified
14:50:50:WU00:FS00:0x17:Folding@home GPU core17
14:50:50:WU00:FS00:0x17:Version 0.0.52
14:51:00:WU01:FS00:Upload 6.58%
14:51:55:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
14:51:55:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:55:29:WU00:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
14:56:15:WU01:FS00:Upload 98.64%
14:56:26:WU01:FS00:Upload complete
14:56:26:WU01:FS00:Server responded WORK_ACK (400)
14:56:26:WU01:FS00:Final credit estimate, 21151.00 points
14:56:26:WU01:FS00:Cleaning up
14:58:55:WU00:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
18:50:49:WU00:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
18:54:24:WU00:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
18:56:40:WU00:FS00:0x17:ERROR:exception: Error creating array interactingTiles: clCreateBuffer (-61)
18:56:40:WU00:FS00:0x17:Saving result file logfile_01.txt
18:56:40:WU00:FS00:0x17:Saving result file log.txt
18:56:40:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
18:56:40:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:56:40:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9101 run:128 clone:1 gen:35 core:0x17 unit:0x000000240a3b1e81533f3c57f8ca2459
18:56:40:WU00:FS00:Uploading 3.02KiB to 171.64.65.93
18:56:40:WU00:FS00:Connecting to 171.64.65.93:8080
18:56:41:WU00:FS00:Upload complete
18:56:41:WU01:FS00:Connecting to 171.67.108.201:80
18:56:42:WU00:FS00:Server responded WORK_ACK (400)
18:56:42:WU00:FS00:Cleaning up
Re: Project: 9101 (R 128, C 1, G 35)
folding_hoomer wrote:BAD_WORK_UNIT
Nope. This WU was reassigned and was successfully completed by the next person.
Hi folding_hoomer (team 70335),
Your WU (P9101 R128 C1 G35) was added to the stats database on 2014-04-29 12:02:54 for 2760 points of credit.
Days taken to complete WU: 0.17
(Error)
Hi xxxxx (team xxxx),
Your WU (P9101 R128 C1 G35) was added to the stats database on 2014-04-29 18:02:04 for 22848 points of credit.
Days taken to complete WU: 0.25
(No error)
You probably need to reduce your overclocking.
folding_hoomer
Optional:
Maybe this WU is much more sensitiv using an OC´d GPU than others.
WUs are not sensitive to OC. WUs are sensitive to data corruption.
Past stability is no guarantee of future stability as FAH continues to optimize it's code to get as much science out of our hardware donations as it can.
One project may be more efficient that the previous project. When you set your overclocking, you assumed that the project you're running at that time was using 100.00000% of your resources, not merely 99.99999% (or some other slightly smaller number). You also assumed that that day was the hottest day your computer will ever encounter.
