Since April 10th I have been getting off and Bad Work Units. The WU will generally complete (one didn't) I have attached a section of the log showing a GPU WU that just completed within the past hour. If necessary, I might be able to recover some of the other log files.
I have checked my GPU temp and I am well under what I have run in the past.
Please help if you can.
*********************** Log Started 2014-04-26T03:16:53Z ***********************
03:16:53:************************* Folding@home Client *************************
03:16:53: Website: http://folding.stanford.edu/
03:16:53: Copyright: (c) 2009-2013 Stanford University
03:16:53: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:16:53: Args:
03:16:53: Config: C:/Users/ER/AppData/Roaming/FAHClient/config.xml
03:16:53:******************************** Build ********************************
03:16:53: Version: 7.3.6
03:16:53: Date: Feb 18 2013
03:16:53: Time: 15:25:17
03:16:53: SVN Rev: 3923
03:16:53: Branch: fah/trunk/client
03:16:53: Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:16:53: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:16:53: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:16:53: Platform: win32 XP
03:16:53: Bits: 32
03:16:53: Mode: Release
03:16:53:******************************* System ********************************
03:16:53: CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
03:16:53: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
03:16:53: CPUs: 8
03:16:53: Memory: 7.96GiB
03:16:53: Free Memory: 6.33GiB
03:16:53: Threads: WINDOWS_THREADS
03:16:53: Has Battery: false
03:16:53: On Battery: false
03:16:53: UTC offset: -4
03:16:53: PID: 4648
03:16:53: CWD: C:/Users/ER/AppData/Roaming/FAHClient
03:16:53: OS: Windows 7 Professional
03:16:53: OS Arch: AMD64
03:16:53: GPUs: 1
03:16:53: GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
03:16:53: CUDA: Not detected
03:16:53:Win32 Service: false
03:16:53:***********************************************************************
03:16:53:<config>
03:16:53: <!-- Folding Core -->
03:16:53: <core-priority v='low'/>
03:16:53:
03:16:53: <!-- Folding Slot Configuration -->
03:16:53: <power v='full'/>
03:16:53:
03:16:53: <!-- Network -->
03:16:53: <proxy v=':8080'/>
03:16:53:
03:16:53: <!-- User Information -->
03:16:53: <passkey v='********************************'/>
03:16:53: <team v='36120'/>
03:16:53: <user v='LonePalm'/>
03:16:53:
03:16:53: <!-- Folding Slots -->
03:16:53: <slot id='0' type='GPU'>
03:16:53: <next-unit-percentage v='98'/>
03:16:53: </slot>
03:16:53: <slot id='1' type='CPU'>
03:16:53: <cpus v='8'/>
03:16:53: </slot>
03:16:53:</config>
03:16:53:Trying to access database...
03:16:53:Successfully acquired database lock
03:16:53:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
03:16:53:Enabled folding slot 01: READY cpu:8
03:16:53:WU00:FS00:Starting
03:16:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:16:54:WU00:FS00:Started FahCore on PID 6060
03:16:55:WU00:FS00:Core PID:5644
03:16:55:WU00:FS00:FahCore 0x17 started
03:16:57:WU01:FS01:Connecting to assign3.stanford.edu:8080
03:16:59:WU01:FS01:News: Welcome to Folding@Home
03:16:59:WU01:FS01:Assigned to work server 128.143.231.202
03:16:59:WU01:FS01:Requesting new work unit for slot 01: READY cpu:8 from 128.143.231.202
03:16:59:WU01:FS01:Connecting to 128.143.231.202:8080
03:17:01:WU01:FS01:Downloading 3.67MiB
03:17:03:WU01:FS01:Download complete
03:17:03:WU00:FS00:0x17:*********************** Log Started 2014-04-26T03:17:03Z ***********************
03:17:03:WU00:FS00:0x17:Project: 13000 (Run 743, Clone 0, Gen 10)
03:17:03:WU00:FS00:0x17:Unit: 0x00000020538b3db753106d50fc64e03b
03:17:03:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:17:03:WU00:FS00:0x17:Machine: 0
03:17:03:WU00:FS00:0x17:Digital signatures verified
03:17:03:WU00:FS00:0x17:Folding@home GPU core17
03:17:03:WU00:FS00:0x17:Version 0.0.52
03:17:03:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8578 run:1 clone:4 gen:364 core:0xa3 unit:0x0000115b0a3b1e59522888abcaea86d2
03:17:04:WU01:FS01:Starting
03:17:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 01 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -np 8
03:17:04:WU01:FS01:Started FahCore on PID 5548
03:17:04:WU00:FS00:0x17: Found a checkpoint file
03:17:04:WU01:FS01:Core PID:236
03:17:04:WU01:FS01:FahCore 0xa3 started
03:17:05:WU01:FS01:0xa3:
03:17:05:WU01:FS01:0xa3:*------------------------------*
03:17:05:WU01:FS01:0xa3:Folding@Home Gromacs SMP Core
03:17:05:WU01:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
03:17:05:WU01:FS01:0xa3:Preparing to commence simulation
03:17:05:WU01:FS01:0xa3:- Looking at optimizations...
03:17:05:WU01:FS01:0xa3:- Created dyn
03:17:05:WU01:FS01:0xa3:- Files status OK
03:17:05:WU01:FS01:0xa3:- Expanded 3850896 -> 4394468 (decompressed 114.1 percent)
03:17:05:WU01:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3850896 data_size=4394468, decompressed_data_size=4394468 diff=0
03:17:05:WU01:FS01:0xa3:- Digital signature verified
03:17:05:WU01:FS01:0xa3:Project: 8578 (Run 1, Clone 4, Gen 364)
03:17:05:WU01:FS01:0xa3:Assembly optimizations on if available.
03:17:05:WU01:FS01:0xa3:Entering M.D.
03:17:11:WU01:FS01:0xa3:Mapping NT from 8 to 8
03:17:12:WU01:FS01:0xa3:Completed 0 out of 500000 steps (0%)
03:21:16:WU00:FS00:0x17:Completed 3500000 out of 5000000 steps (70%)
03:21:16:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:30:52:WU01:FS01:0xa3:Completed 5000 out of 500000 steps (1%)
03:31:18:WU00:FS00:0x17:Completed 3550000 out of 5000000 steps (71%)
03:41:03:WU00:FS00:0x17:Completed 3600000 out of 5000000 steps (72%)
03:41:37:WU01:FS01:0xa3:Completed 10000 out of 500000 steps (2%)
03:51:10:WU00:FS00:0x17:Completed 3650000 out of 5000000 steps (73%)
03:52:25:WU01:FS01:0xa3:Completed 15000 out of 500000 steps (3%)
04:01:02:WU00:FS00:0x17:Completed 3700000 out of 5000000 steps (74%)
04:03:01:WU01:FS01:0xa3:Completed 20000 out of 500000 steps (4%)
04:10:53:WU00:FS00:0x17:Completed 3750000 out of 5000000 steps (75%)
04:13:03:WU01:FS01:0xa3:Completed 25000 out of 500000 steps (5%)
04:21:03:WU00:FS00:0x17:Completed 3800000 out of 5000000 steps (76%)
04:22:56:WU01:FS01:0xa3:Completed 30000 out of 500000 steps (6%)
04:30:55:WU00:FS00:0x17:Completed 3850000 out of 5000000 steps (77%)
04:32:37:WU01:FS01:0xa3:Completed 35000 out of 500000 steps (7%)
04:41:05:WU00:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
04:42:23:WU01:FS01:0xa3:Completed 40000 out of 500000 steps (8%)
04:50:59:WU00:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
04:52:20:WU01:FS01:0xa3:Completed 45000 out of 500000 steps (9%)
05:00:50:WU00:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
05:02:13:WU01:FS01:0xa3:Completed 50000 out of 500000 steps (10%)
05:11:01:WU00:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
05:11:53:WU01:FS01:0xa3:Completed 55000 out of 500000 steps (11%)
05:20:52:WU00:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
05:21:34:WU01:FS01:0xa3:Completed 60000 out of 500000 steps (12%)
05:31:01:WU00:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
05:31:25:WU01:FS01:0xa3:Completed 65000 out of 500000 steps (13%)
05:40:55:WU00:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
05:41:08:WU01:FS01:0xa3:Completed 70000 out of 500000 steps (14%)
05:50:44:WU00:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
05:51:19:WU01:FS01:0xa3:Completed 75000 out of 500000 steps (15%)
06:00:52:WU00:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
06:01:00:WU01:FS01:0xa3:Completed 80000 out of 500000 steps (16%)
06:10:42:WU00:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
06:10:42:WU01:FS01:0xa3:Completed 85000 out of 500000 steps (17%)
06:20:39:WU01:FS01:0xa3:Completed 90000 out of 500000 steps (18%)
06:20:51:WU00:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
06:30:23:WU01:FS01:0xa3:Completed 95000 out of 500000 steps (19%)
06:30:41:WU00:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
06:40:05:WU01:FS01:0xa3:Completed 100000 out of 500000 steps (20%)
06:40:30:WU00:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
06:50:06:WU01:FS01:0xa3:Completed 105000 out of 500000 steps (21%)
06:50:36:WU00:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
06:59:54:WU01:FS01:0xa3:Completed 110000 out of 500000 steps (22%)
07:00:27:WU00:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
07:10:00:WU01:FS01:0xa3:Completed 115000 out of 500000 steps (23%)
07:10:37:WU00:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
07:19:46:WU01:FS01:0xa3:Completed 120000 out of 500000 steps (24%)
07:20:28:WU00:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
07:29:30:WU01:FS01:0xa3:Completed 125000 out of 500000 steps (25%)
07:30:20:WU00:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
07:39:24:WU01:FS01:0xa3:Completed 130000 out of 500000 steps (26%)
07:40:30:WU00:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
07:49:26:WU01:FS01:0xa3:Completed 135000 out of 500000 steps (27%)
07:50:20:WU00:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
07:59:24:WU01:FS01:0xa3:Completed 140000 out of 500000 steps (28%)
08:00:29:WU00:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
08:00:29:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
08:00:29:WU02:FS00:News: Welcome to Folding@Home
08:00:29:WU02:FS00:Assigned to work server 140.163.4.231
08:00:29:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
08:00:29:WU02:FS00:Connecting to 140.163.4.231:8080
08:00:32:ERROR:WU02:FS00:Exception: Server did not assign work unit
08:00:32:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
08:00:32:WU02:FS00:News: Welcome to Folding@Home
08:00:32:WU02:FS00:Assigned to work server 140.163.4.231
08:00:32:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
08:00:32:WU02:FS00:Connecting to 140.163.4.231:8080
08:00:32:WU02:FS00:Downloading 4.84MiB
08:00:34:WU02:FS00:Download complete
08:00:34:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13001 run:413 clone:0 gen:9 core:0x17 unit:0x00000019538b3db75328c4c19be522b1
08:09:06:WU01:FS01:0xa3:Completed 145000 out of 500000 steps (29%)
08:10:21:WU00:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
08:18:50:WU01:FS01:0xa3:Completed 150000 out of 500000 steps (30%)
08:20:12:WU00:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
08:20:31:WU00:FS00:0x17:Saving result file logfile_01.txt
08:20:31:WU00:FS00:0x17:Saving result file checkpointState.xml
08:20:33:WU00:FS00:0x17:Saving result file checkpt.crc
08:20:33:WU00:FS00:0x17:Saving result file log.txt
08:20:33:WU00:FS00:0x17:Saving result file positions.xtc
08:20:36:WU00:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
08:20:36:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:20:36:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13000 run:743 clone:0 gen:10 core:0x17 unit:0x00000020538b3db753106d50fc64e03b
08:20:36:WU00:FS00:Uploading 12.83MiB to 140.163.4.231
08:20:36:WU02:FS00:Starting
08:20:36:WU00:FS00:Connecting to 140.163.4.231:8080
08:20:36:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 02 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -gpu 0 -gpu-vendor ati
08:20:36:WU02:FS00:Started FahCore on PID 3440
08:20:37:WU02:FS00:Core PID:6476
08:20:37:WU02:FS00:FahCore 0x17 started
08:20:38:WU02:FS00:0x17:*********************** Log Started 2014-04-26T08:20:37Z ***********************
08:20:38:WU02:FS00:0x17:Project: 13001 (Run 413, Clone 0, Gen 9)
08:20:38:WU02:FS00:0x17:Unit: 0x00000019538b3db75328c4c19be522b1
08:20:38:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
08:20:38:WU02:FS00:0x17:Machine: 0
08:20:38:WU02:FS00:0x17:Reading tar file state.xml
08:20:39:WU02:FS00:0x17:Reading tar file system.xml
08:20:39:WU02:FS00:0x17:Reading tar file integrator.xml
08:20:39:WU02:FS00:0x17:Reading tar file core.xml
08:20:39:WU02:FS00:0x17:Digital signatures verified
08:20:39:WU02:FS00:0x17:Folding@home GPU core17
08:20:39:WU02:FS00:0x17:Version 0.0.52
08:20:42:WU00:FS00:Upload 19.97%
08:20:48:WU00:FS00:Upload 40.92%
08:20:54:WU00:FS00:Upload 61.87%
08:21:00:WU00:FS00:Upload 82.82%
08:21:15:WU00:FS00:Upload complete
08:21:15:WU00:FS00:Server responded WORK_ACK (400)
08:21:15:WU00:FS00:Final credit estimate, 64003.00 points
08:21:15:WU00:FS00:Cleaning up
08:24:09:WU02:FS00:0x17:Completed 0 out of 5000000 steps (0%)
08:24:09:WU02:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:31:01:WU01:FS01:0xa3:Completed 155000 out of 500000 steps (31%)
08:33:57:WU02:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
08:40:56:WU01:FS01:0xa3:Completed 160000 out of 500000 steps (32%)
08:43:29:WU02:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
08:51:15:WU01:FS01:0xa3:Completed 165000 out of 500000 steps (33%)
08:53:19:WU02:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
09:01:04:WU01:FS01:0xa3:Completed 170000 out of 500000 steps (34%)
09:02:52:WU02:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
09:10:52:WU01:FS01:0xa3:Completed 175000 out of 500000 steps (35%)
09:12:25:WU02:FS00:0x17:Completed 250000 out of 5000000 steps (5%)
******************************* Date: 2014-04-26 *******************************
09:20:55:WU01:FS01:0xa3:Completed 180000 out of 500000 steps (36%)
09:22:15:WU02:FS00:0x17:Completed 300000 out of 5000000 steps (6%)
09:30:51:WU01:FS01:0xa3:Completed 185000 out of 500000 steps (37%)
09:31:48:WU02:FS00:0x17:Completed 350000 out of 5000000 steps (7%)
09:41:44:WU02:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
09:42:38:WU01:FS01:0xa3:Completed 190000 out of 500000 steps (38%)
09:51:16:WU02:FS00:0x17:Completed 450000 out of 5000000 steps (9%)
09:52:36:WU01:FS01:0xa3:Completed 195000 out of 500000 steps (39%)
10:00:48:WU02:FS00:0x17:Completed 500000 out of 5000000 steps (10%)
10:02:44:WU01:FS01:0xa3:Completed 200000 out of 500000 steps (40%)
10:10:38:WU02:FS00:0x17:Completed 550000 out of 5000000 steps (11%)
10:12:39:WU01:FS01:0xa3:Completed 205000 out of 500000 steps (41%)
10:20:10:WU02:FS00:0x17:Completed 600000 out of 5000000 steps (12%)
10:22:32:WU01:FS01:0xa3:Completed 210000 out of 500000 steps (42%)
10:30:01:WU02:FS00:0x17:Completed 650000 out of 5000000 steps (13%)
10:32:31:WU01:FS01:0xa3:Completed 215000 out of 500000 steps (43%)
10:39:34:WU02:FS00:0x17:Completed 700000 out of 5000000 steps (14%)
10:42:19:WU01:FS01:0xa3:Completed 220000 out of 500000 steps (44%)
10:49:11:WU02:FS00:0x17:Completed 750000 out of 5000000 steps (15%)
10:52:39:WU01:FS01:0xa3:Completed 225000 out of 500000 steps (45%)
10:59:02:WU02:FS00:0x17:Completed 800000 out of 5000000 steps (16%)
11:02:34:WU01:FS01:0xa3:Completed 230000 out of 500000 steps (46%)
11:08:34:WU02:FS00:0x17:Completed 850000 out of 5000000 steps (17%)
11:12:25:WU01:FS01:0xa3:Completed 235000 out of 500000 steps (47%)
11:18:24:WU02:FS00:0x17:Completed 900000 out of 5000000 steps (18%)
11:22:53:WU01:FS01:0xa3:Completed 240000 out of 500000 steps (48%)
11:27:57:WU02:FS00:0x17:Completed 950000 out of 5000000 steps (19%)
11:32:45:WU01:FS01:0xa3:Completed 245000 out of 500000 steps (49%)
11:37:30:WU02:FS00:0x17:Completed 1000000 out of 5000000 steps (20%)
11:43:01:WU01:FS01:0xa3:Completed 250000 out of 500000 steps (50%)
11:47:20:WU02:FS00:0x17:Completed 1050000 out of 5000000 steps (21%)
11:53:00:WU01:FS01:0xa3:Completed 255000 out of 500000 steps (51%)
11:56:52:WU02:FS00:0x17:Completed 1100000 out of 5000000 steps (22%)
12:03:13:WU01:FS01:0xa3:Completed 260000 out of 500000 steps (52%)
12:06:43:WU02:FS00:0x17:Completed 1150000 out of 5000000 steps (23%)
12:13:12:WU01:FS01:0xa3:Completed 265000 out of 500000 steps (53%)
12:16:15:WU02:FS00:0x17:Completed 1200000 out of 5000000 steps (24%)
12:23:09:WU01:FS01:0xa3:Completed 270000 out of 500000 steps (54%)
12:25:48:WU02:FS00:0x17:Completed 1250000 out of 5000000 steps (25%)
12:33:27:WU01:FS01:0xa3:Completed 275000 out of 500000 steps (55%)
12:35:39:WU02:FS00:0x17:Completed 1300000 out of 5000000 steps (26%)
12:43:30:WU01:FS01:0xa3:Completed 280000 out of 500000 steps (56%)
12:45:10:WU02:FS00:0x17:Completed 1350000 out of 5000000 steps (27%)
12:53:57:WU01:FS01:0xa3:Completed 285000 out of 500000 steps (57%)
12:55:05:WU02:FS00:0x17:Completed 1400000 out of 5000000 steps (28%)
13:03:54:WU01:FS01:0xa3:Completed 290000 out of 500000 steps (58%)
13:04:38:WU02:FS00:0x17:Completed 1450000 out of 5000000 steps (29%)
13:13:57:WU01:FS01:0xa3:Completed 295000 out of 500000 steps (59%)
13:14:11:WU02:FS00:0x17:Completed 1500000 out of 5000000 steps (30%)
13:24:02:WU02:FS00:0x17:Completed 1550000 out of 5000000 steps (31%)
13:24:23:WU01:FS01:0xa3:Completed 300000 out of 500000 steps (60%)
13:33:34:WU02:FS00:0x17:Completed 1600000 out of 5000000 steps (32%)
13:34:17:WU01:FS01:0xa3:Completed 305000 out of 500000 steps (61%)
13:43:25:WU02:FS00:0x17:Completed 1650000 out of 5000000 steps (33%)
13:44:23:WU01:FS01:0xa3:Completed 310000 out of 500000 steps (62%)
13:52:58:WU02:FS00:0x17:Completed 1700000 out of 5000000 steps (34%)
13:54:45:WU01:FS01:0xa3:Completed 315000 out of 500000 steps (63%)
14:02:29:WU02:FS00:0x17:Completed 1750000 out of 5000000 steps (35%)
14:05:01:WU01:FS01:0xa3:Completed 320000 out of 500000 steps (64%)
14:12:20:WU02:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
14:15:17:WU01:FS01:0xa3:Completed 325000 out of 500000 steps (65%)
14:21:53:WU02:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
14:26:25:WU01:FS01:0xa3:Completed 330000 out of 500000 steps (66%)
14:31:48:WU02:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
14:37:42:WU01:FS01:0xa3:Completed 335000 out of 500000 steps (67%)
14:41:22:WU02:FS00:0x17:Completed 1950000 out of 5000000 steps (39%)
14:48:33:WU01:FS01:0xa3:Completed 340000 out of 500000 steps (68%)
14:50:57:WU02:FS00:0x17:Completed 2000000 out of 5000000 steps (40%)
14:59:24:WU01:FS01:0xa3:Completed 345000 out of 500000 steps (69%)
15:00:49:WU02:FS00:0x17:Completed 2050000 out of 5000000 steps (41%)
15:09:37:WU01:FS01:0xa3:Completed 350000 out of 500000 steps (70%)
15:10:24:WU02:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
15:20:19:WU02:FS00:0x17:Completed 2150000 out of 5000000 steps (43%)
15:20:37:WU01:FS01:0xa3:Completed 355000 out of 500000 steps (71%)
15:29:53:WU02:FS00:0x17:Completed 2200000 out of 5000000 steps (44%)
15:31:29:WU01:FS01:0xa3:Completed 360000 out of 500000 steps (72%)
15:39:29:WU02:FS00:0x17:Completed 2250000 out of 5000000 steps (45%)
15:43:36:WU01:FS01:0xa3:Completed 365000 out of 500000 steps (73%)
15:49:27:WU02:FS00:0x17:Completed 2300000 out of 5000000 steps (46%)
15:54:29:WU01:FS01:0xa3:Completed 370000 out of 500000 steps (74%)
15:59:04:WU02:FS00:0x17:Completed 2350000 out of 5000000 steps (47%)
16:05:03:WU01:FS01:0xa3:Completed 375000 out of 500000 steps (75%)
16:08:55:WU02:FS00:0x17:Completed 2400000 out of 5000000 steps (48%)
16:17:47:WU01:FS01:0xa3:Completed 380000 out of 500000 steps (76%)
16:18:28:WU02:FS00:0x17:Completed 2450000 out of 5000000 steps (49%)
16:27:59:WU02:FS00:0x17:Completed 2500000 out of 5000000 steps (50%)
16:30:55:WU01:FS01:0xa3:Completed 385000 out of 500000 steps (77%)
16:37:51:WU02:FS00:0x17:Completed 2550000 out of 5000000 steps (51%)
16:42:06:WU01:FS01:0xa3:Completed 390000 out of 500000 steps (78%)
16:47:24:WU02:FS00:0x17:Completed 2600000 out of 5000000 steps (52%)
16:53:01:WU01:FS01:0xa3:Completed 395000 out of 500000 steps (79%)
16:57:16:WU02:FS00:0x17:Completed 2650000 out of 5000000 steps (53%)
17:03:51:WU01:FS01:0xa3:Completed 400000 out of 500000 steps (80%)
17:06:53:WU02:FS00:0x17:Completed 2700000 out of 5000000 steps (54%)
17:15:03:WU01:FS01:0xa3:Completed 405000 out of 500000 steps (81%)
17:16:26:WU02:FS00:0x17:Completed 2750000 out of 5000000 steps (55%)
17:26:18:WU01:FS01:0xa3:Completed 410000 out of 500000 steps (82%)
17:26:18:WU02:FS00:0x17:Completed 2800000 out of 5000000 steps (56%)
17:35:52:WU02:FS00:0x17:Completed 2850000 out of 5000000 steps (57%)
17:37:17:WU01:FS01:0xa3:Completed 415000 out of 500000 steps (83%)
17:45:42:WU02:FS00:0x17:Completed 2900000 out of 5000000 steps (58%)
17:49:30:WU01:FS01:0xa3:Completed 420000 out of 500000 steps (84%)
17:55:13:WU02:FS00:0x17:Completed 2950000 out of 5000000 steps (59%)
18:01:00:WU01:FS01:0xa3:Completed 425000 out of 500000 steps (85%)
18:04:45:WU02:FS00:0x17:Completed 3000000 out of 5000000 steps (60%)
18:13:51:WU01:FS01:0xa3:Completed 430000 out of 500000 steps (86%)
18:14:38:WU02:FS00:0x17:Completed 3050000 out of 5000000 steps (61%)
18:24:11:WU02:FS00:0x17:Completed 3100000 out of 5000000 steps (62%)
18:25:26:WU01:FS01:0xa3:Completed 435000 out of 500000 steps (87%)
18:34:02:WU02:FS00:0x17:Completed 3150000 out of 5000000 steps (63%)
18:37:01:WU01:FS01:0xa3:Completed 440000 out of 500000 steps (88%)
18:43:34:WU02:FS00:0x17:Completed 3200000 out of 5000000 steps (64%)
18:48:48:WU01:FS01:0xa3:Completed 445000 out of 500000 steps (89%)
18:53:14:WU02:FS00:0x17:Completed 3250000 out of 5000000 steps (65%)
19:01:08:WU01:FS01:0xa3:Completed 450000 out of 500000 steps (90%)
19:03:12:WU02:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
19:12:59:WU02:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
19:13:39:WU01:FS01:0xa3:Completed 455000 out of 500000 steps (91%)
19:23:28:WU02:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
19:29:48:WU01:FS01:0xa3:Completed 460000 out of 500000 steps (92%)
19:33:40:WU02:FS00:0x17:Completed 3450000 out of 5000000 steps (69%)
19:43:42:WU02:FS00:0x17:Completed 3500000 out of 5000000 steps (70%)
19:46:15:WU01:FS01:0xa3:Completed 465000 out of 500000 steps (93%)
19:54:26:WU02:FS00:0x17:Completed 3550000 out of 5000000 steps (71%)
20:02:18:WU01:FS01:0xa3:Completed 470000 out of 500000 steps (94%)
20:04:25:WU02:FS00:0x17:Completed 3600000 out of 5000000 steps (72%)
20:14:45:WU02:FS00:0x17:Completed 3650000 out of 5000000 steps (73%)
20:16:29:WU01:FS01:0xa3:Completed 475000 out of 500000 steps (95%)
20:24:44:WU02:FS00:0x17:Completed 3700000 out of 5000000 steps (74%)
20:32:07:WU01:FS01:0xa3:Completed 480000 out of 500000 steps (96%)
20:34:43:WU02:FS00:0x17:Completed 3750000 out of 5000000 steps (75%)
20:45:12:WU02:FS00:0x17:Completed 3800000 out of 5000000 steps (76%)
20:48:15:WU01:FS01:0xa3:Completed 485000 out of 500000 steps (97%)
20:48:16:WU00:FS01:Connecting to assign3.stanford.edu:8080
20:48:17:WU00:FS01:News: Welcome to Folding@Home
20:48:17:WU00:FS01:Assigned to work server 128.143.231.202
20:48:17:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:8 from 128.143.231.202
20:48:17:WU00:FS01:Connecting to 128.143.231.202:8080
20:48:18:ERROR:WU00:FS01:Exception: Server did not assign work unit
20:48:18:WU00:FS01:Connecting to assign3.stanford.edu:8080
20:48:19:WU00:FS01:News: Welcome to Folding@Home
20:48:19:WU00:FS01:Assigned to work server 128.143.231.202
20:48:19:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:8 from 128.143.231.202
20:48:19:WU00:FS01:Connecting to 128.143.231.202:8080
20:48:22:ERROR:WU00:FS01:Exception: Server did not assign work unit
20:49:19:WU00:FS01:Connecting to assign3.stanford.edu:8080
20:49:19:WU00:FS01:News: Welcome to Folding@Home
20:49:19:WU00:FS01:Assigned to work server 128.143.231.202
20:49:19:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:8 from 128.143.231.202
20:49:19:WU00:FS01:Connecting to 128.143.231.202:8080
20:49:20:WU00:FS01:Downloading 3.67MiB
20:49:22:WU00:FS01:Download complete
20:49:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8566 run:1 clone:2 gen:351 core:0xa3 unit:0x000010430a3b1e595227886df29deee7
20:55:17:WU02:FS00:0x17:Completed 3850000 out of 5000000 steps (77%)
21:04:07:WU01:FS01:0xa3:Completed 490000 out of 500000 steps (98%)
21:05:41:WU02:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
21:15:42:WU02:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
21:19:38:WU01:FS01:0xa3:Completed 495000 out of 500000 steps (99%)
21:25:23:WU02:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
21:31:19:WU01:FS01:0xa3:Completed 500000 out of 500000 steps (100%)
21:31:21:WU01:FS01:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
21:31:31:WU01:FS01:0xa3:
21:31:31:WU01:FS01:0xa3:Finished Work Unit:
21:31:31:WU01:FS01:0xa3:- Reading up to 8059248 from "01/wudata_01.trr": Read 8059248
21:31:31:WU01:FS01:0xa3:trr file hash check passed.
21:31:31:WU01:FS01:0xa3:edr file hash check passed.
21:31:31:WU01:FS01:0xa3:logfile size: 61668
21:31:31:WU01:FS01:0xa3:Leaving Run
21:31:31:WU01:FS01:0xa3:- Writing 8157748 bytes of core data to disk...
21:31:33:WU01:FS01:0xa3:Done: 8157236 -> 7532331 (compressed to 92.3 percent)
21:31:33:WU01:FS01:0xa3: ... Done.
21:31:36:WU01:FS01:0xa3:- Shutting down core
21:31:36:WU01:FS01:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
21:31:37:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:31:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:8578 run:1 clone:4 gen:364 core:0xa3 unit:0x0000115b0a3b1e59522888abcaea86d2
21:31:37:WU01:FS01:Uploading 7.18MiB to 128.143.231.202
21:31:37:WU00:FS01:Starting
21:31:37:WU01:FS01:Connecting to 128.143.231.202:8080
21:31:37:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -np 8
21:31:37:WU00:FS01:Started FahCore on PID 7220
21:31:37:WU00:FS01:Core PID:7676
21:31:37:WU00:FS01:FahCore 0xa3 started
21:31:38:WU00:FS01:0xa3:
21:31:38:WU00:FS01:0xa3:*------------------------------*
21:31:38:WU00:FS01:0xa3:Folding@Home Gromacs SMP Core
21:31:38:WU00:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
21:31:38:WU00:FS01:0xa3:Preparing to commence simulation
21:31:38:WU00:FS01:0xa3:- Looking at optimizations...
21:31:38:WU00:FS01:0xa3:- Created dyn
21:31:38:WU00:FS01:0xa3:- Files status OK
21:31:38:WU00:FS01:0xa3:Couldn't Decompress
21:31:38:WU00:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3850464 data_size=4392332, decompressed_data_size=0 diff=4392332
21:31:38:WU00:FS01:0xa3:- Fatal: Could not decompress work unit data
21:31:38:WU00:FS01:0xa3:Error: Could not open work file
21:31:38:WU00:FS01:0xa3:Folding@home Core Shutdown: FILE_IO_ERROR
21:31:38:WARNING:WU00:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
21:31:38:WARNING:WU00:FS01:Fatal error, dumping
21:31:38:WU00:FS01:Sending unit results: id:00 state:SEND error:DUMPED project:8566 run:1 clone:2 gen:351 core:0xa3 unit:0x000010430a3b1e595227886df29deee7
21:31:38:WU00:FS01:Connecting to 128.143.231.202:8080
21:31:39:WU03:FS01:Connecting to assign3.stanford.edu:8080
21:31:39:WU00:FS01:Server responded WORK_ACK (400)
21:31:39:WU00:FS01:Cleaning up
21:31:39:WU03:FS01:News: Welcome to Folding@Home
21:31:39:WU03:FS01:Assigned to work server 128.143.231.202
21:31:39:WU03:FS01:Requesting new work unit for slot 01: READY cpu:8 from 128.143.231.202
21:31:39:WU03:FS01:Connecting to 128.143.231.202:8080
21:31:41:WU03:FS01:Downloading 3.64MiB
21:31:43:ERROR:WU03:FS01:Exception: Transfer failed
21:31:43:WU01:FS01:Upload 24.36%
21:31:43:WU03:FS01:Connecting to assign3.stanford.edu:8080
21:31:43:WU03:FS01:News: Welcome to Folding@Home
21:31:43:WU03:FS01:Assigned to work server 128.143.231.202
21:31:43:WU03:FS01:Requesting new work unit for slot 01: READY cpu:8 from 128.143.231.202
21:31:43:WU03:FS01:Connecting to 128.143.231.202:8080
21:31:45:WU03:FS01:Downloading 3.64MiB
21:31:46:WU03:FS01:Download complete
21:31:47:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:6099 run:1 clone:46 gen:391 core:0xa3 unit:0x0000028c0a3b1e594e889f7730c55165
21:31:47:WU03:FS01:Starting
21:31:47:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 03 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -np 8
21:31:47:WU03:FS01:Started FahCore on PID 8936
21:31:47:WU03:FS01:Core PID:1124
21:31:47:WU03:FS01:FahCore 0xa3 started
21:31:48:WARNING:WU03:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
21:31:48:WARNING:WU03:FS01:Fatal error, dumping
21:31:48:WU03:FS01:Sending unit results: id:03 state:SEND error:DUMPED project:6099 run:1 clone:46 gen:391 core:0xa3 unit:0x0000028c0a3b1e594e889f7730c55165
21:31:48:WU03:FS01:Connecting to 128.143.231.202:8080
21:31:48:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:31:48:WU03:FS01:Server responded WORK_ACK (400)
21:31:48:WU03:FS01:Cleaning up
21:31:49:WU01:FS01:Upload 61.77%
21:31:49:WU00:FS01:News: Welcome to Folding@Home
21:31:49:WU00:FS01:Assigned to work server 128.143.231.202
21:31:49:WU00:FS01:Requesting new work unit for slot 01: READY cpu:8 from 128.143.231.202
21:31:49:WU00:FS01:Connecting to 128.143.231.202:8080
21:31:50:WU00:FS01:Downloading 3.67MiB
21:31:52:ERROR:WU00:FS01:Exception: Transfer failed
21:31:52:WU00:FS01:Connecting to assign3.stanford.edu:8080
21:31:52:WU00:FS01:News: Welcome to Folding@Home
21:31:52:WU00:FS01:Assigned to work server 128.143.231.202
21:31:52:WU00:FS01:Requesting new work unit for slot 01: READY cpu:8 from 128.143.231.202
21:31:52:WU00:FS01:Connecting to 128.143.231.202:8080
21:31:54:WU00:FS01:Downloading 3.67MiB
21:31:55:WU01:FS01:Upload 93.96%
21:31:56:WU00:FS01:Download complete
21:31:56:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8575 run:1 clone:8 gen:367 core:0xa3 unit:0x000014b10a3b1e59522885aeafae055e
21:31:56:WU00:FS01:Starting
21:31:56:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -np 8
21:31:56:WU00:FS01:Started FahCore on PID 4460
21:31:56:WU00:FS01:Core PID:6448
21:31:56:WU00:FS01:FahCore 0xa3 started
21:31:57:WARNING:WU00:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
21:31:57:WARNING:WU00:FS01:Fatal error, dumping
21:31:57:WU00:FS01:Sending unit results: id:00 state:SEND error:DUMPED project:8575 run:1 clone:8 gen:367 core:0xa3 unit:0x000014b10a3b1e59522885aeafae055e
21:31:57:WU00:FS01:Connecting to 128.143.231.202:8080
21:31:57:WU01:FS01:Upload complete
21:31:57:WU03:FS01:Connecting to assign3.stanford.edu:8080
21:31:57:WU01:FS01:Server responded WORK_QUIT (404)
21:31:57:WARNING:WU01:FS01:Server did not like results, dumping
21:31:57:WU01:FS01:Cleaning up
21:31:58:WU00:FS01:Server responded WORK_ACK (400)
21:31:58:WU00:FS01:Cleaning up
21:31:58:WU03:FS01:News: Welcome to Folding@Home
21:31:58:WU03:FS01:Assigned to work server 128.143.231.202
21:31:58:WU03:FS01:Requesting new work unit for slot 01: READY cpu:8 from 128.143.231.202
21:31:58:WU03:FS01:Connecting to 128.143.231.202:8080
21:32:00:WU03:FS01:Downloading 3.67MiB
21:32:01:ERROR:WU03:FS01:Exception: Transfer failed
21:32:01:WU03:FS01:Connecting to assign3.stanford.edu:8080
21:32:02:WU03:FS01:News: Welcome to Folding@Home
21:32:02:WU03:FS01:Assigned to work server 128.143.231.202
21:32:02:WU03:FS01:Requesting new work unit for slot 01: READY cpu:8 from 128.143.231.202
21:32:02:WU03:FS01:Connecting to 128.143.231.202:8080
21:32:03:WU03:FS01:Downloading 3.67MiB
21:32:05:WU03:FS01:Download complete
21:32:05:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8583 run:1 clone:3 gen:346 core:0xa3 unit:0x000010a30a3b1e5952288a0e3c66d2a2
21:32:05:WU03:FS01:Starting
21:32:05:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 03 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -np 8
21:32:05:WU03:FS01:Started FahCore on PID 3740
21:32:05:WU03:FS01:Core PID:2260
21:32:05:WU03:FS01:FahCore 0xa3 started
21:32:06:WU03:FS01:0xa3:
21:32:06:WU03:FS01:0xa3:*------------------------------*
21:32:06:WU03:FS01:0xa3:Folding@Home Gromacs SMP Core
21:32:06:WU03:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
21:32:06:WU03:FS01:0xa3:Preparing to commence simulation
21:32:06:WU03:FS01:0xa3:- Looking at optimizations...
21:32:06:WU03:FS01:0xa3:- Created dyn
21:32:06:WU03:FS01:0xa3:- Files status OK
21:32:06:WU03:FS01:0xa3:- Expanded 3848684 -> 4382484 (decompressed 113.8 percent)
21:32:06:WU03:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3848684 data_size=4382484, decompressed_data_size=4382484 diff=0
21:32:06:WU03:FS01:0xa3:- Digital signature verified
21:32:06:WU03:FS01:0xa3:Project: 8583 (Run 1, Clone 3, Gen 346)
21:32:06:WU03:FS01:0xa3:Assembly optimizations on if available.
21:32:06:WU03:FS01:0xa3:Entering M.D.
21:32:12:WU03:FS01:0xa3:Mapping NT from 8 to 8
21:32:12:WU03:FS01:0xa3:Completed 0 out of 500000 steps (0%)
21:35:15:WU02:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
21:42:57:WU03:FS01:0xa3:Completed 5000 out of 500000 steps (1%)
21:44:48:WU02:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
21:54:37:WU02:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
21:54:58:WU03:FS01:0xa3:Completed 10000 out of 500000 steps (2%)
22:04:10:WU02:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
22:06:38:WU03:FS01:0xa3:Completed 15000 out of 500000 steps (3%)
22:13:44:WU02:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
22:17:26:WU03:FS01:0xa3:Completed 20000 out of 500000 steps (4%)
22:23:37:WU02:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
22:28:01:WU03:FS01:0xa3:Completed 25000 out of 500000 steps (5%)
22:33:12:WU02:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
22:38:32:WU03:FS01:0xa3:Completed 30000 out of 500000 steps (6%)
22:43:03:WU02:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
22:48:49:WU03:FS01:0xa3:Completed 35000 out of 500000 steps (7%)
22:52:35:WU02:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
22:59:13:WU03:FS01:0xa3:Completed 40000 out of 500000 steps (8%)
23:02:09:WU02:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
23:09:49:WU03:FS01:0xa3:Completed 45000 out of 500000 steps (9%)
23:12:00:WU02:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
23:20:05:WU03:FS01:0xa3:Completed 50000 out of 500000 steps (10%)
23:21:33:WU02:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
23:30:35:WU03:FS01:0xa3:Completed 55000 out of 500000 steps (11%)
23:31:24:WU02:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
23:40:57:WU02:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
23:41:02:WU03:FS01:0xa3:Completed 60000 out of 500000 steps (12%)
23:50:30:WU02:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
23:51:40:WU03:FS01:0xa3:Completed 65000 out of 500000 steps (13%)
00:00:22:WU02:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
00:01:59:WU03:FS01:0xa3:Completed 70000 out of 500000 steps (14%)
00:09:57:WU02:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
00:12:54:WU03:FS01:0xa3:Completed 75000 out of 500000 steps (15%)
00:19:49:WU02:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
00:19:49:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
00:19:49:WU00:FS00:News: Welcome to Folding@Home
00:19:49:WU00:FS00:Assigned to work server 140.163.4.231
00:19:49:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:19:49:WU00:FS00:Connecting to 140.163.4.231:8080
00:19:50:WU00:FS00:Downloading 4.84MiB
00:19:53:ERROR:WU00:FS00:Exception: Transfer failed
00:19:53:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
00:19:54:WU00:FS00:News: Welcome to Folding@Home
00:19:54:WU00:FS00:Assigned to work server 140.163.4.231
00:19:54:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:19:54:WU00:FS00:Connecting to 140.163.4.231:8080
00:19:54:WU00:FS00:Downloading 4.84MiB
00:19:56:ERROR:WU00:FS00:Exception: Transfer failed
00:20:53:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
00:20:54:WU00:FS00:News: Welcome to Folding@Home
00:20:54:WU00:FS00:Assigned to work server 140.163.4.231
00:20:54:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:20:54:WU00:FS00:Connecting to 140.163.4.231:8080
00:20:54:WU00:FS00:Downloading 4.83MiB
00:20:56:ERROR:WU00:FS00:Exception: Transfer failed
00:22:31:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
00:22:31:WU00:FS00:News: Welcome to Folding@Home
00:22:31:WU00:FS00:Assigned to work server 140.163.4.231
00:22:31:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:22:31:WU00:FS00:Connecting to 140.163.4.231:8080
00:22:31:WU00:FS00:Downloading 4.84MiB
00:22:34:WU00:FS00:Download complete
00:22:34:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13000 run:448 clone:0 gen:11 core:0x17 unit:0x0000001e538b3db753101a51b44583db
00:24:53:WU03:FS01:0xa3:Completed 80000 out of 500000 steps (16%)
00:29:21:WU02:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
00:35:57:WU03:FS01:0xa3:Completed 85000 out of 500000 steps (17%)
00:38:54:WU02:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
00:39:13:WU02:FS00:0x17:Saving result file logfile_01.txt
00:39:13:WU02:FS00:0x17:Saving result file checkpointState.xml
00:39:16:WU02:FS00:0x17:Saving result file checkpt.crc
00:39:16:WU02:FS00:0x17:Saving result file log.txt
00:39:16:WU02:FS00:0x17:Saving result file positions.xtc
00:39:18:WU02:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
00:39:18:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:39:18:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13001 run:413 clone:0 gen:9 core:0x17 unit:0x00000019538b3db75328c4c19be522b1
00:39:18:WU02:FS00:Uploading 12.83MiB to 140.163.4.231
00:39:18:WU02:FS00:Connecting to 140.163.4.231:8080
00:39:19:WU00:FS00:Starting
00:39:19:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:39:19:WU00:FS00:Started FahCore on PID 5200
00:39:19:WU00:FS00:Core PID:1772
00:39:19:WU00:FS00:FahCore 0x17 started
00:39:20:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:39:21:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:13000 run:448 clone:0 gen:11 core:0x17 unit:0x0000001e538b3db753101a51b44583db
00:39:21:WU00:FS00:Uploading 1019B to 140.163.4.231
00:39:21:WU00:FS00:Connecting to 140.163.4.231:8080
00:39:21:WU00:FS00:Upload complete
00:39:21:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
00:39:21:WU00:FS00:Server responded WORK_ACK (400)
00:39:21:WU00:FS00:Cleaning up
00:39:22:WU01:FS00:News: Welcome to Folding@Home
00:39:22:WU01:FS00:Assigned to work server 140.163.4.231
00:39:22:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:39:22:WU01:FS00:Connecting to 140.163.4.231:8080
00:39:22:WU01:FS00:Downloading 4.84MiB
00:39:24:WU02:FS00:Upload 15.10%
00:39:25:ERROR:WU01:FS00:Exception: Transfer failed
00:39:25:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
00:39:25:WU01:FS00:News: Welcome to Folding@Home
00:39:25:WU01:FS00:Assigned to work server 140.163.4.231
00:39:25:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:39:25:WU01:FS00:Connecting to 140.163.4.231:8080
00:39:26:WU01:FS00:Downloading 4.84MiB
00:39:27:ERROR:WU01:FS00:Exception: Transfer failed
00:39:30:WU02:FS00:Upload 33.60%
00:39:36:WU02:FS00:Upload 58.92%
00:39:42:WU02:FS00:Upload 94.96%
00:39:43:WU02:FS00:Upload complete
00:39:43:WU02:FS00:Server responded WORK_QUIT (404)
00:39:43:WARNING:WU02:FS00:Server did not like results, dumping
00:39:43:WU02:FS00:Cleaning up
00:40:25:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
00:40:25:WU01:FS00:News: Welcome to Folding@Home
00:40:25:WU01:FS00:Assigned to work server 140.163.4.231
00:40:26:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:40:26:WU01:FS00:Connecting to 140.163.4.231:8080
00:40:26:WU01:FS00:Downloading 4.83MiB
00:40:29:ERROR:WU01:FS00:Exception: Transfer failed
00:42:02:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
00:42:03:WU01:FS00:News: Welcome to Folding@Home
00:42:03:WU01:FS00:Assigned to work server 140.163.4.231
00:42:03:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:42:03:WU01:FS00:Connecting to 140.163.4.231:8080
00:42:03:WU01:FS00:Downloading 4.83MiB
00:42:05:ERROR:WU01:FS00:Exception: Transfer failed
00:44:39:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
00:44:40:WU01:FS00:News: Welcome to Folding@Home
00:44:40:WU01:FS00:Assigned to work server 140.163.4.231
00:44:40:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:44:40:WU01:FS00:Connecting to 140.163.4.231:8080
00:44:40:WU01:FS00:Downloading 4.84MiB
00:44:42:WU01:FS00:Download complete
00:44:42:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13000 run:522 clone:0 gen:11 core:0x17 unit:0x00000018538b3db753102f252c88c9d5
00:44:42:WU01:FS00:Starting
00:44:42:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:44:42:WU01:FS00:Started FahCore on PID 9092
00:44:43:WU01:FS00:Core PID:5356
00:44:43:WU01:FS00:FahCore 0x17 started
00:44:43:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:44:43:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:522 clone:0 gen:11 core:0x17 unit:0x00000018538b3db753102f252c88c9d5
00:44:43:WU01:FS00:Uploading 885B to 140.163.4.231
00:44:43:WU01:FS00:Connecting to 140.163.4.231:8080
00:44:43:WU01:FS00:Upload complete
00:44:43:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
00:44:44:WU01:FS00:Server responded WORK_ACK (400)
00:44:44:WU01:FS00:Cleaning up
00:44:44:WU00:FS00:News: Welcome to Folding@Home
00:44:44:WU00:FS00:Assigned to work server 140.163.4.231
00:44:44:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:44:44:WU00:FS00:Connecting to 140.163.4.231:8080
00:44:47:ERROR:WU00:FS00:Exception: Server did not assign work unit
00:44:47:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
00:44:48:WU00:FS00:News: Welcome to Folding@Home
00:44:48:WU00:FS00:Assigned to work server 140.163.4.231
00:44:48:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:44:48:WU00:FS00:Connecting to 140.163.4.231:8080
00:44:48:WU00:FS00:Downloading 4.84MiB
00:44:51:WU00:FS00:Download complete
00:44:51:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13000 run:172 clone:0 gen:10 core:0x17 unit:0x00000016538b3db7530fcc8686b077df
00:44:51:WU00:FS00:Starting
00:44:51:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:44:51:WU00:FS00:Started FahCore on PID 8288
00:44:51:WU00:FS00:Core PID:7720
00:44:51:WU00:FS00:FahCore 0x17 started
00:44:52:WU00:FS00:0x17:*********************** Log Started 2014-04-27T00:44:51Z ***********************
00:44:52:WU00:FS00:0x17:Project: 13000 (Run 172, Clone 0, Gen 10)
00:44:52:WU00:FS00:0x17:Unit: 0x00000016538b3db7530fcc8686b077df
00:44:52:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:44:52:WU00:FS00:0x17:Machine: 0
00:44:52:WU00:FS00:0x17:ERROR:112: calculated hash = 1aa53983-ecc45380-88b667df-c7a45a38-553da852
00:44:52:WU00:FS00:0x17:ERROR:work unit hash = a23401af-77ecba39-21015be0-3b213fb1-6a5345e0
00:44:52:WU00:FS00:0x17:ERROR:Bad work unit. Digital signatures don't match
00:44:52:WU00:FS00:0x17:Saving result file logfile_01.txt
00:44:52:WU00:FS00:0x17:Saving result file log.txt
00:44:52:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:44:52:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:44:52:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:13000 run:172 clone:0 gen:10 core:0x17 unit:0x00000016538b3db7530fcc8686b077df
00:44:52:WU00:FS00:Uploading 1020B to 140.163.4.231
00:44:52:WU00:FS00:Connecting to 140.163.4.231:8080
00:44:52:WU00:FS00:Upload complete
00:44:52:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
00:44:52:WU00:FS00:Server responded WORK_ACK (400)
00:44:52:WU00:FS00:Cleaning up
00:44:53:WU01:FS00:News: Welcome to Folding@Home
00:44:53:WU01:FS00:Assigned to work server 140.163.4.231
00:44:53:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:44:53:WU01:FS00:Connecting to 140.163.4.231:8080
00:44:54:WU01:FS00:Downloading 4.83MiB
00:44:55:ERROR:WU01:FS00:Exception: Transfer failed
00:44:55:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
00:44:55:WU01:FS00:News: Welcome to Folding@Home
00:44:55:WU01:FS00:Assigned to work server 140.163.4.231
00:44:55:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:44:55:WU01:FS00:Connecting to 140.163.4.231:8080
00:44:56:WU01:FS00:Downloading 4.84MiB
00:44:58:WU01:FS00:Download complete
00:44:58:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13000 run:1694 clone:0 gen:9 core:0x17 unit:0x0000001f538b3db753117a9f9f1b6d8a
00:44:58:WU01:FS00:Starting
00:44:58:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 01 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:44:58:WU01:FS00:Started FahCore on PID 5432
00:44:59:WU01:FS00:Core PID:8456
00:44:59:WU01:FS00:FahCore 0x17 started
00:44:59:WU01:FS00:0x17:*********************** Log Started 2014-04-27T00:44:59Z ***********************
00:44:59:WU01:FS00:0x17:Project: 13000 (Run 1694, Clone 0, Gen 9)
00:44:59:WU01:FS00:0x17:Unit: 0x0000001f538b3db753117a9f9f1b6d8a
00:44:59:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:44:59:WU01:FS00:0x17:Machine: 0
00:44:59:WU01:FS00:0x17:Reading tar file state.xml
00:44:59:WU01:FS00:0x17:ERROR:Error reading tar file
00:44:59:WU01:FS00:0x17:Saving result file logfile_01.txt
00:44:59:WU01:FS00:0x17:Saving result file log.txt
00:44:59:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:44:59:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:44:59:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:1694 clone:0 gen:9 core:0x17 unit:0x0000001f538b3db753117a9f9f1b6d8a
00:44:59:WU01:FS00:Uploading 888B to 140.163.4.231
00:44:59:WU01:FS00:Connecting to 140.163.4.231:8080
00:45:00:WU01:FS00:Upload complete
00:45:00:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
00:45:00:WU01:FS00:Server responded WORK_ACK (400)
00:45:00:WU01:FS00:Cleaning up
00:45:01:WU00:FS00:News: Welcome to Folding@Home
00:45:01:WU00:FS00:Assigned to work server 140.163.4.231
00:45:01:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 140.163.4.231
00:45:01:WU00:FS00:Connecting to 140.163.4.231:8080
00:45:02:WU00:FS00:Downloading 4.84MiB
00:45:04:WU00:FS00:Download complete
00:45:04:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13001 run:268 clone:0 gen:6 core:0x17 unit:0x00000017538b3db753289ba4dfd50d87
00:45:04:WU00:FS00:Starting
00:45:04:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:45:04:WU00:FS00:Started FahCore on PID 4792
00:45:04:WU00:FS00:Core PID:2840
00:45:04:WU00:FS00:FahCore 0x17 started
00:45:04:WU00:FS00:0x17:*********************** Log Started 2014-04-27T00:45:04Z ***********************
00:45:04:WU00:FS00:0x17:Project: 13001 (Run 268, Clone 0, Gen 6)
00:45:04:WU00:FS00:0x17:Unit: 0x00000017538b3db753289ba4dfd50d87
00:45:04:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:45:04:WU00:FS00:0x17:Machine: 0
00:45:04:WU00:FS00:0x17:Reading tar file state.xml
00:45:04:WU00:FS00:0x17:ERROR:Error reading tar file
00:45:04:WU00:FS00:0x17:Saving result file logfile_01.txt
00:45:04:WU00:FS00:0x17:Saving result file log.txt
00:45:04:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:45:04:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:45:05:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:13001 run:268 clone:0 gen:6 core:0x17 unit:0x00000017538b3db753289ba4dfd50d87
00:45:05:WU00:FS00:Uploading 881B to 140.163.4.231
00:45:05:WU00:FS00:Connecting to 140.163.4.231:8080
00:45:05:WU00:FS00:Upload complete
00:45:05:WU00:FS00:Server responded WORK_ACK (400)
00:45:05:WU00:FS00:Cleaning up
00:47:31:WU03:FS01:0xa3:Completed 90000 out of 500000 steps (18%)
00:58:44:WU03:FS01:0xa3:Completed 95000 out of 500000 steps (19%)
01:01:50:WARNING:WU03:FS01:FahCore crashed with Windows unhandled exception code 0xUNKNOWN_ENUM, searching for this code online may provide more information
01:01:50:WARNING:WU03:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
01:01:50:WU03:FS01:Starting
01:01:50:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/ER/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 03 -suffix 01 -version 703 -lifeline 4648 -checkpoint 15 -np 8
01:01:50:WU03:FS01:Started FahCore on PID 5844
