Lost QRB Points
Lost QRB Points
I recently upgraded the motherboard and CPU in my folding computer and have lost receipt of QRB points. Not only have my points gone down significantly, my base points and estimated credit are the same. I have successfully completed 166 WUs and accumulated 1.4 million points for my team. I don't believe I've dropped below the 80% threshold for successful WUs. Any idea what could be causing this?
I installed an AsRock Z87 Extreme 6 motherboard with Intel 4770k CPU, overclocked to 4.4Ghz, stable. The GPU is the GTX770, running Windows 8.1.
Any suggestions appreciated.
Thanks.
Thanks.
Re: Lost QRB Points
The first thing to check is whether your passkey is entered into the client. The fact that the estimated and base points are the same usually points to no passkey having been entered.
Re: Lost QRB Points
I guess it was the same one that has been there all the time, but to be safe I just re-entered it.
Re: Lost QRB Points
When you do, make certain there are no extra blank characters before or after the passkey in the field. That is one of the more common problems we see.
If after the current WU you still don't get QRB, please post your log showing the initial part with system information and configuration as well as the WU being processed.
Re: Lost QRB Points
Wow! Since my last post my (estimated PPD) has dropped another 20,000. I was averaging over 70,000 a day before the "upgrade" in equipment. Now it estimates 13,000.
Re: Lost QRB Points
Post your log showing the system and config section.
Re: Lost QRB Points
************************* Folding@home Client *************************
05:57:58: Website: http://folding.stanford.edu/
05:57:58: Copyright: (c) 2009-2014 Stanford University
05:57:58: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:57:58: Args:
05:57:58: Config: C:/Users/Myke/AppData/Roaming/FAHClient/config.xml
05:57:58:******************************** Build ********************************
05:57:58: Version: 7.4.4
05:57:58: Date: Mar 4 2014
05:57:58: Time: 20:26:54
05:57:58: SVN Rev: 4130
05:57:58: Branch: fah/trunk/client
05:57:58: Compiler: Intel(R) C++ MSVC 1500 mode 1200
05:57:58: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
05:57:58: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
05:57:58: Platform: win32 XP
05:57:58: Bits: 32
05:57:58: Mode: Release
05:57:58:******************************* System ********************************
05:57:58: CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
05:57:58: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
05:57:58: CPUs: 8
05:57:58: Memory: 15.93GiB
05:57:58: Free Memory: 14.70GiB
05:57:58: Threads: WINDOWS_THREADS
05:57:58: OS Version: 6.2
05:57:58: Has Battery: false
05:57:58: On Battery: false
05:57:58: UTC Offset: -4
05:57:58: PID: 2528
05:57:58: CWD: C:/Users/Myke/AppData/Roaming/FAHClient
05:57:58: OS: Windows 8.1 Pro with Media Center
05:57:58: OS Arch: AMD64
05:57:58: GPUs: 1
05:57:58: GPU 0: NVIDIA:3 GK104 [GeForce GTX 770]
05:57:58: CUDA: 3.0
05:57:58: CUDA Driver: 5050
05:57:58:Win32 Service: false
05:57:58:***********************************************************************
05:57:58:<config>
05:57:58: <!-- HTTP Server -->
05:57:58: <allow v='192.168.1.100-192.168.1.255'/>
05:57:58:
05:57:58: <!-- Network -->
05:57:58: <proxy v=':8080'/>
05:57:58:
05:57:58: <!-- Remote Command Server -->
05:57:58: <command-allow-no-pass v='192.168.1.100-192.168.1.255'/>
05:57:58: <password v='********'/>
05:57:58:
05:57:58: <!-- Slot Control -->
05:57:58: <power v='FULL'/>
05:57:58:
05:57:58: <!-- User Information -->
05:57:58: <passkey v='********************************'/>
05:57:58: <team v='223274'/>
05:57:58: <user v='jazzi'/>
05:57:58:
05:57:58: <!-- Folding Slots -->
05:57:58: <slot id='0' type='CPU'>
05:57:58: <client-type v='advanced'/>
05:57:58: <cpus v='6'/>
05:57:58: <next-unit-percentage v='100'/>
05:57:58: </slot>
05:57:58: <slot id='1' type='GPU'>
05:57:58: </slot>
05:57:58:</config>
05:57:58:Trying to access database...
05:57:58:Successfully acquired database lock
05:57:58:Enabled folding slot 00: READY cpu:6
05:57:58:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 770]
05:57:58:WU01:FS01:Starting
05:57:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Myke/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2528 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:57:58:WU01:FS01:Started FahCore on PID 5252
05:57:58:WU01:FS01:Core PID:5264
05:57:58:WU01:FS01:FahCore 0x17 started
05:57:58:WU00:FS00:Starting
05:57:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Myke/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2528 -checkpoint 15 -np 6
05:57:58:WU00:FS00:Started FahCore on PID 5272
05:57:58:WU00:FS00:Core PID:5284
05:57:58:WU00:FS00:FahCore 0xa4 started
05:57:59:WU01:FS01:0x17:*********************** Log Started 2014-04-17T05:57:58Z ***********************
05:57:59:WU01:FS01:0x17:Project: 9406 (Run 130, Clone 0, Gen 7)
05:57:59:WU01:FS01:0x17:Unit: 0x0000000a0a3b1e5c533de04d16939598
05:57:59:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
05:57:59:WU01:FS01:0x17:Machine: 1
05:57:59:WU01:FS01:0x17:Digital signatures verified
05:57:59:WU01:FS01:0x17:Folding@home GPU core17
05:57:59:WU01:FS01:0x17:Version 0.0.52
05:57:59:WU01:FS01:0x17: Found a checkpoint file
05:57:59:WU00:FS00:0xa4:
05:57:59:WU00:FS00:0xa4:*------------------------------*
05:57:59:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
05:57:59:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:57:59:WU00:FS00:0xa4:Preparing to commence simulation
05:57:59:WU00:FS00:0xa4:- Looking at optimizations...
05:57:59:WU00:FS00:0xa4:- Files status OK
05:57:59:WU00:FS00:0xa4:- Expanded 2346931 -> 3311344 (decompressed 141.0 percent)
05:57:59:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=2346931 data_size=3311344, decompressed_data_size=3311344 diff=0
05:57:59:WU00:FS00:0xa4:- Digital signature verified
05:57:59:WU00:FS00:0xa4:Project: 7520 (Run 29, Clone 3, Gen 155)
05:57:59:WU00:FS00:0xa4:Assembly optimizations on if available.
05:57:59:WU00:FS00:0xa4:Entering M.D.
05:58:05:WU00:FS00:0xa4:Using Gromacs checkpoints
05:58:05:WU00:FS00:0xa4:Mapping NT from 6 to 6
05:58:05:WU00:FS00:0xa4:Resuming from checkpoint
05:58:05:WU00:FS00:0xa4:Verified 00/wudata_01.log
05:58:05:WU00:FS00:0xa4:Verified 00/wudata_01.trr
05:58:05:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
05:58:05:WU00:FS00:0xa4:Verified 00/wudata_01.edr
05:58:05:WU00:FS00:0xa4:Completed 205870 out of 500000 steps (41%)
06:01:10:WU01:FS01:0x17:Completed 100000 out of 2000000 steps (5%)
06:01:10:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:02:54:WU00:FS00:0xa4:Completed 210000 out of 500000 steps (42%)Re: Lost QRB Points
Not sure what happened, but all of a sudden my (estimated) PPD shows 108,000. CPU however still shows no QRB.
Kurtis200200
Re: Lost QRB Points
I've noticed that you have While that won't alone account for the PPD drop you mentioned, it will introduce several minutes of idle time each day between completing the previous work unit and downloading the next.
<next-unit-percentage v='100'/>-
rwh202
3x GTX 1080 Ti
3x GTX 1060
Re: Lost QRB Points
Depending on the WU, it's actually preferable to do that rather than have a downloaded WU sat for 10+ minutes not being worked on, all the time during which any QRB is being reduced...Kurtis200200 wrote:I've noticed that you haveWhile that won't alone account for the PPD drop you mentioned, it will introduce several minutes of idle time each day between completing the previous work unit and downloading the next.Code: Select all
Jazzi, if your username is the same as your folding name, then EOC stats are showing 16 WUs for no points in a recent update - if they were all failures and not an artefact of the stats server downtime, then that might have damaged your eligibility for bonus. Any sign of failures at your end?
If everything looks OK but still no bonus, then I guess you could get a new passkey, rack up 10 units in an hour or so on the NaCl and see if bonus starts again?
P5-133XL
Machine #2:
Machine 3:
Re: Lost QRB Points
I've also calculated PPD with a variety of projects and next-unit-percentages and found my highest was universally 100%. The amount of time waiting for one frame to complete (i.e. getting the WU at 99%) invariably was longer than the download + upload time used. I suppose that if the frame times were fast enough and the transfer times were slow enough then it could change. For me, that just wasn't happening. My frame times typically were between 3-12 minutes and transfer time would be less than 1 minute so 100% was best..
Re: Lost QRB Points
If that's the case, once the percentage of completed WUs returns to the 80% level, will the QRB return or is this passkey permanently prevented from further QRBs?rwh202 wrote:Kurtis200200 wrote: Jazzi, if your username is the same as your folding name, then EOC stats are showing 16 WUs for no points in a recent update - if they were all failures and not an artefact of the stats server downtime, then that might have damaged your eligibility for bonus. Any sign of failures at your end?
And yes, user name and folding name are the same.
Thanks.
Re: Lost QRB Points
Although I don't have the research to support my suspicion, I assumed the 100% was more efficient.P5-133XL wrote:I've also calculated PPD with a variety of projects and next-unit-percentages and found my highest was universally 100%. The amount of time waiting for one frame to complete (i.e. getting the WU at 99%) invariably was longer than the download + upload time used. I suppose that if the frame times were fast enough and the transfer times were slow enough then it could change. For me, that just wasn't happening. My frame times typically were between 3-12 minutes and transfer time would be less than 1 minute so 100% was best..
Thanks for confirming my suspicion.
rwh202
3x GTX 1080 Ti
3x GTX 1060
Re: Lost QRB Points
My understanding is that bonus will return once 80% is again reached. (That is, 80% successful completion of eligible units. ie. excluding core_15 WUs)jazzi wrote:
Is there any sign of failed WUs from your end? If not, then just keep folding and it is likely the bonus points will return shortly through qualification of whatever passkey is entered
P5-133XL
Machine #2:
Machine 3:
Re: Lost QRB Points
If there is a potential issue with the 80% return rate, anyone can PM any moderator with the folding username and passkey and the moderator will check to see if the passkey is below 80% or not.
