Does anyone sucessfully managed to use that driver for folding?
I tried it and F@H rejected to fold.
Sorry, I forgot to copy the error message and reverted to 327.23.
Heiko
Driver 337.50 beta & 337.61 beta
- Hardware configuration: i7-3930K@4.1GHz
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz - Location: Essen, Germany
Reason: Changed topic title, adding 337.61
Re: Driver 337.50 beta
I've been running them on my 780s since the day they were released without any issues. Of course, being GK110, they are not affected by the low-PPD issues that GK104 has seen since 331.xx.
I am using it with a 780 and haven't had any problems and it seems like a small improvement in PPD but I haven't had the time to really look at the numbers in HFM. Then I tried it out on one of my GT 640's and the PPD on project 13001 went from ~17,000 to 4000 so I went back to 320.18.
GTX680@1.275GHz
Q9300@2.4GHz
Today I gave it a second (and third) try. Result:heikosch wrote:Does anyone sucessfully managed to use that driver for folding?
Despite a previous uninstall of the older driver and use of DDU utility Geforce 337.50 beta doesn´t install correctly.
So the generic Microsoft driver is used, which can´t be used for folding.
EDIT: The problem is fixed with Geforce 337.61 beta (installation problem with active Hyper-V fixed).
Heiko
