gpu WUs not assigning from 171.67.108.201:80
Hi all, i installed the v7.4.4 client a few days ago, at the beginning everything was fine, but yesterday after the gpu finished its work, it got stuck in downloading the next.... 0.0% and not moving... i tried to delete the WORK folder, but all i got in return was losing the actual CPU WU...
i checked the log and the system continues to do the following :
16:37:51:ERROR:WU01:FS01:Exception: Could not get an assignment
16:47:41:FS01:Finishing
16:48:58:WU01:FS01:Connecting to 171.67.108.201:80
16:48:58:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
i'm running on w8.1, asus maximus vi hero, asus r9 280x DCU top II.... any suggestion appreciated thx..
Re: gpu WUs not downloading
The message "could not get an assignment" means the server has a problem. (You're really reporting a problem with the Assignment Server.) Deleting the work you've already downloaded wasn't going to help.)
That message from an Assignment Server means that no work is available for your configuration. We can do nothing unless we know the details of your configuration. (See my Signature for how to post that information from your log file. )
Re: gpu WUs not assigning from 171.67.108.201:80
Welcome to the F@H Forum fab@fold,
Please note that deletion of files was a method that was only useful in v6. Since V7 is a complete rewrite, that method no longer applies. The best way to get V7 out of a downloading issue is to simply restart the Client or system (which ever is easier). The restarting method is also a workaround for this bug (https://fah.stanford.edu/projects/FAHClient/ticket/983).
thanks, no luck with the restart method either.... but if i'm reading correctly the server status, it seems there are 0 WUs available....does that mean that the server just run out of GPU WUs, and that everybody else on this planet is in this situation ? is this a normally recurring situation ? ) otherwise what could be the probs ? i'd like to contribute but i really have no time to troubleshooting... i will check the many FAQs available in the forum, in order to keep up-to-date with the most recurring situations, but now i need to unlock the situation fast....thanks,
171.67.108.201 is a GPU Assignment Server. As such it does not have WU's to assign, hence the 0, but connects your client with a Work Server that has WU's based on the configuration of your system. The problem is the "short response". Something is interfering with your connection to that server, the client was expecting a 272 byte response and got nothing. The topic bruce linked to does have some suggestions for troubleshooting your connection. They should be tried first. The problem could be a change on your end, or one by your ISP, or an actual problem with the AS. The last is less likely, we would be getting many more reports from other folders not getting GPU assignments.
thx for your reply.... i tried to follow the link Bruce posted, but i couldn't get anything useful... i didn't make any particular change on my end... internet connection works fine on all my other apps, no hw change.... i'm sorry but without help i'm forced to disinstall....
p.s. i tried disinstalling and reinstalling.. now it got worse, can't get even cpu wus... here's the log :
16:26:15:WU01:FS01:Connecting to 171.67.108.201:80
16:26:15:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:26:15:WU01:FS01:Connecting to 171.64.65.160:80
16:26:15:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
16:26:15:ERROR:WU01:FS01:Exception: Could not get an assignment
16:26:19:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:26:19:WU00:FS00:Connecting to www.stanford.edu:80
16:26:19:ERROR:WU00:FS00:Exception: Failed to read stream
You now have two problems. Not being able to download a new FahCore_a4 is totally unrelated to not getting an assignment from the Assignment Server.
As Joe_H suggested, it's most likely a problem on your end. If you use a proxy server, sometimes they edit the data stream, discarding messages they believe are redundant. Intelligent routers also sometimes decide not to send all messages to the destination. Check your router for the settings associated with obscure optimizations methods. Security software also blocks connections and you may need to tell that software that FAH is authorized to contact the internet.
i'm sorry if i'm making you lose time... i'm very frustrated for all this... problem is that i didn't change the router settings.... not a bit... so why was it working and suddendly it does not ? i have a sitecom x6 n900.. is there a specific setting i should look at ? then o have win dows 64 bit 8.1, with AWG free & kaspersky AV.... something to check there ?
i have just tried to install a folding client on another pc i have in my home network... never been installed there before... after installatio, windows forewall asked for permission, and i gave it.... it doesn't start either... log file says "ERROR:WU00:FS00:Exception: Failed to read stream" after the line whre it tried to download the core_a4.fah seems a problem related to all the network.... (but my seti@home boinc client works flawlessly....)
UPDATE _ Boinc (seti@home) just finished a WU, but couldn't get a new one... in the log it says something similar to what happens in folding : "Server returned nothing(no header, no data)", that is similar to the message in the f@h log about the 0 lenght answer.... so it may be that something has happend that is inhibiting this kind of communication, in the last two days... but what the hell could it be ?
I have seen that "failed to read stream" message before in my sandbox at work. Clearly something is blocking your access out to the internet. AVG and Kaspersky update themselves automatically all the time, often more than once a day. You wouldn't have to change anything for them to take you down.
It is never a good idea to run two AV programs or two firewall programs at the same time. They can interfere with each other and cause numerous problems, one of which being networking. Remove one of them (preferably the last one installed) and then maybe we can get a better handle on what is happening.
nope... boinc was a false alarm, it just downloaded the new wus... as for the 2 av apps, just keep it present that they were both active in the last days when everything was fine...in any case, in case a recent automatic update blocked something, i just tried disabling them both, still no go....now f@h is looping in :
20:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:32:29:WU01:FS01:Connecting to 171.67.108.201:80
20:32:29:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
20:32:29:WU01:FS01:Connecting to 171.64.65.160:80
20:32:29:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
20:32:29:ERROR:WU01:FS01:Exception: Could not get an assignment
but if i open a web page with any of the above urls, it displays a white page with "OK".....
Can you please provide the F@H log file (viewtopic.php?f=24&t=26036) which includes the initial sections (system and configuration) and a few lines showing the error messages?
of course, here it is ... yhou can see that at 16:25, among the errors, it managed to download a WU...
Mod Edit: Added Code tags to log
*********************** Log Started 2014-04-15T16:24:11Z ***********************
16:24:11:************************* Folding@home Client *************************
16:24:11: Website: http://folding.stanford.edu/
16:24:11: Copyright: (c) 2009-2014 Stanford University
16:24:11: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:24:11: Args: --open-web-control
16:24:11: Config: <none>
16:24:11:******************************** Build ********************************
16:24:11: Version: 7.4.4
16:24:11: Date: Mar 4 2014
16:24:11: Time: 20:26:54
16:24:11: SVN Rev: 4130
16:24:11: Branch: fah/trunk/client
16:24:11: Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:24:11: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:24:11: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:24:11: Platform: win32 XP
16:24:11: Bits: 32
16:24:11: Mode: Release
16:24:11:******************************* System ********************************
16:24:11: CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
16:24:11: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:24:11: CPUs: 8
16:24:11: Memory: 15.94GiB
16:24:11: Free Memory: 13.07GiB
16:24:11: Threads: WINDOWS_THREADS
16:24:11: OS Version: 6.2
16:24:11: Has Battery: false
16:24:11: On Battery: false
16:24:11: UTC Offset: 2
16:24:11: PID: 6876
16:24:11: CWD: d:/ProgramData/FAHClient
16:24:11: OS: Windows 8.1
16:24:11: OS Arch: AMD64
16:24:11: GPUs: 1
16:24:11: GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
16:24:11: CUDA: Not detected
16:24:11:Win32 Service: false
16:24:11:***********************************************************************
16:24:11:<config>
16:24:11: <!-- Folding Slots -->
16:24:11:</config>
16:24:11:Connecting to assign-GPU.stanford.edu:80
16:24:12:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:24:12:Connecting to assign-GPU2.stanford.edu:80
16:24:12:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
16:24:12:Trying to access database...
16:24:12:Successfully acquired database lock
16:24:12:Enabled folding slot 00: PAUSED cpu:6 (not configured)
16:24:12:Enabled folding slot 01: PAUSED gpu:0:Tahiti XT [Radeon HD 7970] (not configured)
16:24:21:12:127.0.0.1:New Web connection
16:25:13:Saving configuration to config.xml
16:25:13:<config>
16:25:13: <!-- Folding Slots -->
16:25:13: <slot id='0' type='CPU'/>
16:25:13: <slot id='1' type='GPU'/>
16:25:13:</config>
16:25:13:Set client configured
16:25:13:WU00:FS00:Connecting to 171.67.108.200:8080
16:25:13:WU01:FS01:Connecting to 171.67.108.200:8080
16:25:14:WU00:FS00:Connecting to 171.67.108.200:8080
16:25:14:WU01:FS01:Connecting to 171.67.108.201:80
16:25:14:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:25:14:WU01:FS01:Connecting to 171.64.65.160:80
16:25:15:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
16:25:15:ERROR:WU01:FS01:Exception: Could not get an assignment
16:25:15:WU00:FS00:Assigned to work server 171.64.65.124
16:25:15:WU01:FS01:Connecting to 171.67.108.201:80
16:25:15:WU00:FS00:Requesting new work unit for slot 00: READY cpu:6 from 171.64.65.124
16:25:15:WU00:FS00:Connecting to 171.64.65.124:8080
16:25:15:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:25:15:WU01:FS01:Connecting to 171.64.65.160:80
16:25:19:WU00:FS00:Downloading 855.10KiB
16:25:19:WU00:FS00:Download complete
16:25:19:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9006 run:1150 clone:0 gen:44 core:0xa4 unit:0x0000002f664f2de453278aaf02e74a28
16:25:19:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:25:19:WU00:FS00:Connecting to http://www.stanford.edu:80
16:25:19:ERROR:WU00:FS00:Exception: Failed to read stream
16:26:14:Saving configuration to config.xml
16:26:14:<config>
16:26:14: <!-- Folding Slot Configuration -->
16:26:14: <cause v='CANCER'/>
16:26:14:
16:26:14: <!-- Slot Control -->
16:26:14: <power v='FULL'/>
16:26:14:
16:26:14: <!-- User Information -->
16:26:14: <user v='Fab'/>
16:26:14:
16:26:14: <!-- Folding Slots -->
16:26:14: <slot id='0' type='CPU'/>
16:26:14: <slot id='1' type='GPU'/>
16:26:14:</config>
16:26:19:WU00:FS00:Connecting to http://www.stanford.edu:80
16:27:52:WU01:FS01:Connecting to 171.67.108.201:80
16:27:52:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:27:52:WU01:FS01:Connecting to 171.64.65.160:80
16:27:52:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
16:27:52:ERROR:WU01:FS01:Exception: Could not get an assignment
16:27:56:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:27:56:WU00:FS00:Connecting to http://www.stanford.edu:80
16:27:57:ERROR:WU00:FS00:Exception: Failed to read stream
16:29:11:Connecting to assign-GPU.stanford.edu:80
16:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:29:11:Connecting to assign-GPU2.stanford.edu:80
16:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
16:30:29:WU01:FS01:Connecting to 171.67.108.201:80
16:30:29:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:30:29:WU01:FS01:Connecting to 171.64.65.160:80
16:30:30:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
16:30:30:ERROR:WU01:FS01:Exception: Could not get an assignment
16:30:34:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:30:34:WU00:FS00:Connecting to http://www.stanford.edu:80
16:30:34:ERROR:WU00:FS00:Exception: Failed to read stream
16:34:11:Connecting to assign-GPU.stanford.edu:80
16:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:34:11:Connecting to assign-GPU2.stanford.edu:80
16:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
16:34:44:WU01:FS01:Connecting to 171.67.108.201:80
16:34:44:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:34:44:WU01:FS01:Connecting to 171.64.65.160:80
16:34:44:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
16:34:44:ERROR:WU01:FS01:Exception: Could not get an assignment
16:34:48:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:34:48:WU00:FS00:Connecting to http://www.stanford.edu:80
16:34:48:ERROR:WU00:FS00:Exception: Failed to read stream
16:39:11:Connecting to assign-GPU.stanford.edu:80
16:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:39:11:Connecting to assign-GPU2.stanford.edu:80
16:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
16:41:35:WU01:FS01:Connecting to 171.67.108.201:80
16:41:35:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:41:35:WU01:FS01:Connecting to 171.64.65.160:80
16:41:35:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
16:41:35:ERROR:WU01:FS01:Exception: Could not get an assignment
16:41:39:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:41:39:WU00:FS00:Connecting to http://www.stanford.edu:80
16:41:39:ERROR:WU00:FS00:Exception: Failed to read stream
16:44:11:Connecting to assign-GPU.stanford.edu:80
16:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:44:11:Connecting to assign-GPU2.stanford.edu:80
16:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
16:49:11:Connecting to assign-GPU.stanford.edu:80
16:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:49:11:Connecting to assign-GPU2.stanford.edu:80
16:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
16:52:41:WU01:FS01:Connecting to 171.67.108.201:80
16:52:41:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
16:52:41:WU01:FS01:Connecting to 171.64.65.160:80
16:52:41:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
16:52:41:ERROR:WU01:FS01:Exception: Could not get an assignment
16:52:45:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:52:45:WU00:FS00:Connecting to http://www.stanford.edu:80
16:52:45:ERROR:WU00:FS00:Exception: Failed to read stream
16:54:11:Connecting to assign-GPU.stanford.edu:80
16:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:54:11:Connecting to assign-GPU2.stanford.edu:80
16:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
16:59:11:Connecting to assign-GPU.stanford.edu:80
16:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
16:59:11:Connecting to assign-GPU2.stanford.edu:80
16:59:12:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:04:11:Connecting to assign-GPU.stanford.edu:80
17:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:04:11:Connecting to assign-GPU2.stanford.edu:80
17:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:09:11:Connecting to assign-GPU.stanford.edu:80
17:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:09:11:Connecting to assign-GPU2.stanford.edu:80
17:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:10:38:WU01:FS01:Connecting to 171.67.108.201:80
17:10:38:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
17:10:38:WU01:FS01:Connecting to 171.64.65.160:80
17:10:38:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
17:10:38:ERROR:WU01:FS01:Exception: Could not get an assignment
17:10:42:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:10:42:WU00:FS00:Connecting to http://www.stanford.edu:80
17:10:42:ERROR:WU00:FS00:Exception: Failed to read stream
17:14:11:Connecting to assign-GPU.stanford.edu:80
17:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:14:11:Connecting to assign-GPU2.stanford.edu:80
17:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:19:11:Connecting to assign-GPU.stanford.edu:80
17:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:19:11:Connecting to assign-GPU2.stanford.edu:80
17:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:24:11:Connecting to assign-GPU.stanford.edu:80
17:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:24:11:Connecting to assign-GPU2.stanford.edu:80
17:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:29:11:Connecting to assign-GPU.stanford.edu:80
17:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:29:11:Connecting to assign-GPU2.stanford.edu:80
17:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:34:11:Connecting to assign-GPU.stanford.edu:80
17:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:34:11:Connecting to assign-GPU2.stanford.edu:80
17:34:12:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:39:11:Connecting to assign-GPU.stanford.edu:80
17:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:39:11:Connecting to assign-GPU2.stanford.edu:80
17:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:39:40:WU01:FS01:Connecting to 171.67.108.201:80
17:39:40:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
17:39:40:WU01:FS01:Connecting to 171.64.65.160:80
17:39:40:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
17:39:40:ERROR:WU01:FS01:Exception: Could not get an assignment
17:39:44:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
17:39:44:WU00:FS00:Connecting to http://www.stanford.edu:80
17:39:44:ERROR:WU00:FS00:Exception: Failed to read stream
17:44:11:Connecting to assign-GPU.stanford.edu:80
17:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:44:11:Connecting to assign-GPU2.stanford.edu:80
17:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:49:11:Connecting to assign-GPU.stanford.edu:80
17:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:49:11:Connecting to assign-GPU2.stanford.edu:80
17:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:54:11:Connecting to assign-GPU.stanford.edu:80
17:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:54:11:Connecting to assign-GPU2.stanford.edu:80
17:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
17:59:11:Connecting to assign-GPU.stanford.edu:80
17:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
17:59:11:Connecting to assign-GPU2.stanford.edu:80
17:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:04:11:Connecting to assign-GPU.stanford.edu:80
18:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:04:11:Connecting to assign-GPU2.stanford.edu:80
18:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:05:08:47:127.0.0.1:New Web connection
18:09:11:Connecting to assign-GPU.stanford.edu:80
18:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:09:11:Connecting to assign-GPU2.stanford.edu:80
18:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:14:11:Connecting to assign-GPU.stanford.edu:80
18:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:14:11:Connecting to assign-GPU2.stanford.edu:80
18:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:19:11:Connecting to assign-GPU.stanford.edu:80
18:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:19:11:Connecting to assign-GPU2.stanford.edu:80
18:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:24:11:Connecting to assign-GPU.stanford.edu:80
18:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:24:11:Connecting to assign-GPU2.stanford.edu:80
18:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:26:38:WU01:FS01:Connecting to 171.67.108.201:80
18:26:38:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
18:26:38:WU01:FS01:Connecting to 171.64.65.160:80
18:26:38:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
18:26:38:ERROR:WU01:FS01:Exception: Could not get an assignment
18:26:43:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
18:26:43:WU00:FS00:Connecting to http://www.stanford.edu:80
18:26:43:ERROR:WU00:FS00:Exception: Failed to read stream
18:29:11:Connecting to assign-GPU.stanford.edu:80
18:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:29:11:Connecting to assign-GPU2.stanford.edu:80
18:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:34:11:Connecting to assign-GPU.stanford.edu:80
18:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:34:11:Connecting to assign-GPU2.stanford.edu:80
18:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:39:11:Connecting to assign-GPU.stanford.edu:80
18:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:39:11:Connecting to assign-GPU2.stanford.edu:80
18:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:44:11:Connecting to assign-GPU.stanford.edu:80
18:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:44:11:Connecting to assign-GPU2.stanford.edu:80
18:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:49:11:Connecting to assign-GPU.stanford.edu:80
18:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:49:11:Connecting to assign-GPU2.stanford.edu:80
18:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:54:11:Connecting to assign-GPU.stanford.edu:80
18:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:54:11:Connecting to assign-GPU2.stanford.edu:80
18:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
18:59:11:Connecting to assign-GPU.stanford.edu:80
18:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
18:59:11:Connecting to assign-GPU2.stanford.edu:80
18:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:04:11:Connecting to assign-GPU.stanford.edu:80
19:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:04:11:Connecting to assign-GPU2.stanford.edu:80
19:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:09:11:Connecting to assign-GPU.stanford.edu:80
19:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:09:11:Connecting to assign-GPU2.stanford.edu:80
19:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:14:11:Connecting to assign-GPU.stanford.edu:80
19:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:14:11:Connecting to assign-GPU2.stanford.edu:80
19:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:19:02:FS00:Paused
19:19:02:FS01:Paused
19:19:04:Saving configuration to config.xml
19:19:04:<config>
19:19:04: <!-- Folding Slot Configuration -->
19:19:04: <cause v='CANCER'/>
19:19:04:
19:19:04: <!-- Slot Control -->
19:19:04: <power v='FULL'/>
19:19:04:
19:19:04: <!-- User Information -->
19:19:04: <user v='Fab'/>
19:19:04:
19:19:04: <!-- Folding Slots -->
19:19:04: <slot id='0' type='CPU'>
19:19:04: <paused v='true'/>
19:19:04: </slot>
19:19:04: <slot id='1' type='GPU'>
19:19:04: </slot>
19:19:04:</config>
19:19:04:FS00:Unpaused
19:19:04:FS01:Unpaused
19:19:04:WU01:FS01:Connecting to 171.67.108.201:80
19:19:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
19:19:04:WU01:FS01:Connecting to 171.64.65.160:80
19:19:04:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
19:19:04:ERROR:WU01:FS01:Exception: Could not get an assignment
19:19:11:Connecting to assign-GPU.stanford.edu:80
19:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:19:11:Connecting to assign-GPU2.stanford.edu:80
19:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:20:05:Saving configuration to config.xml
19:20:05:<config>
19:20:05: <!-- Folding Slot Configuration -->
19:20:05: <cause v='CANCER'/>
19:20:05:
19:20:05: <!-- Slot Control -->
19:20:05: <power v='FULL'/>
19:20:05:
19:20:05: <!-- User Information -->
19:20:05: <user v='Fab'/>
19:20:05:
19:20:05: <!-- Folding Slots -->
19:20:05: <slot id='0' type='CPU'/>
19:20:05: <slot id='1' type='GPU'/>
19:20:05:</config>
19:20:41:WU01:FS01:Connecting to 171.67.108.201:80
19:20:41:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
19:20:41:WU01:FS01:Connecting to 171.64.65.160:80
19:20:41:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
19:20:41:ERROR:WU01:FS01:Exception: Could not get an assignment
19:23:19:WU01:FS01:Connecting to 171.67.108.201:80
19:23:19:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
19:23:19:WU01:FS01:Connecting to 171.64.65.160:80
19:23:19:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
19:23:19:ERROR:WU01:FS01:Exception: Could not get an assignment
19:24:11:Connecting to assign-GPU.stanford.edu:80
19:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:24:11:Connecting to assign-GPU2.stanford.edu:80
19:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:27:33:WU01:FS01:Connecting to 171.67.108.201:80
19:27:33:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
19:27:33:WU01:FS01:Connecting to 171.64.65.160:80
19:27:33:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
19:27:33:ERROR:WU01:FS01:Exception: Could not get an assignment
19:29:11:Connecting to assign-GPU.stanford.edu:80
19:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:29:11:Connecting to assign-GPU2.stanford.edu:80
19:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:34:11:Connecting to assign-GPU.stanford.edu:80
19:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:34:11:Connecting to assign-GPU2.stanford.edu:80
19:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:34:24:WU01:FS01:Connecting to 171.67.108.201:80
19:34:24:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
19:34:24:WU01:FS01:Connecting to 171.64.65.160:80
19:34:24:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
19:34:24:ERROR:WU01:FS01:Exception: Could not get an assignment
19:39:11:Connecting to assign-GPU.stanford.edu:80
19:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:39:11:Connecting to assign-GPU2.stanford.edu:80
19:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:42:44:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
19:42:44:WU00:FS00:Connecting to http://www.stanford.edu:80
19:42:44:ERROR:WU00:FS00:Exception: Failed to read stream
19:44:11:Connecting to assign-GPU.stanford.edu:80
19:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:44:11:Connecting to assign-GPU2.stanford.edu:80
19:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:45:30:WU01:FS01:Connecting to 171.67.108.201:80
19:45:30:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
19:45:30:WU01:FS01:Connecting to 171.64.65.160:80
19:45:30:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
19:45:30:ERROR:WU01:FS01:Exception: Could not get an assignment
19:49:11:Connecting to assign-GPU.stanford.edu:80
19:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:49:11:Connecting to assign-GPU2.stanford.edu:80
19:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:54:11:Connecting to assign-GPU.stanford.edu:80
19:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:54:11:Connecting to assign-GPU2.stanford.edu:80
19:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
19:59:11:Connecting to assign-GPU.stanford.edu:80
19:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
19:59:11:Connecting to assign-GPU2.stanford.edu:80
19:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:03:26:WU01:FS01:Connecting to 171.67.108.201:80
20:03:27:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0
20:03:27:WU01:FS01:Connecting to 171.64.65.160:80
20:03:27:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.160:80': 10002: Received short response, expected 272 bytes, got 0
20:03:27:ERROR:WU01:FS01:Exception: Could not get an assignment
20:04:11:Connecting to assign-GPU.stanford.edu:80
20:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:04:11:Connecting to assign-GPU2.stanford.edu:80
20:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:09:11:Connecting to assign-GPU.stanford.edu:80
20:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:09:11:Connecting to assign-GPU2.stanford.edu:80
20:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:14:11:Connecting to assign-GPU.stanford.edu:80
20:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:14:11:Connecting to assign-GPU2.stanford.edu:80
20:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:19:11:Connecting to assign-GPU.stanford.edu:80
20:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:19:11:Connecting to assign-GPU2.stanford.edu:80
20:19:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:21:55:76:127.0.0.1:New Web connection
20:24:11:Connecting to assign-GPU.stanford.edu:80
20:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:24:11:Connecting to assign-GPU2.stanford.edu:80
20:24:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:29:11:Connecting to assign-GPU.stanford.edu:80
20:29:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:29:11:Connecting to assign-GPU2.stanford.edu:80
20:34:11:Connecting to assign-GPU.stanford.edu:80
20:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:34:11:Connecting to assign-GPU2.stanford.edu:80
20:34:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:39:11:Connecting to assign-GPU.stanford.edu:80
20:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:39:11:Connecting to assign-GPU2.stanford.edu:80
20:39:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:44:11:Connecting to assign-GPU.stanford.edu:80
20:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:44:11:Connecting to assign-GPU2.stanford.edu:80
20:44:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:49:11:Connecting to assign-GPU.stanford.edu:80
20:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:49:11:Connecting to assign-GPU2.stanford.edu:80
20:49:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:54:11:Connecting to assign-GPU.stanford.edu:80
20:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:54:11:Connecting to assign-GPU2.stanford.edu:80
20:54:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
20:59:11:Connecting to assign-GPU.stanford.edu:80
20:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
20:59:11:Connecting to assign-GPU2.stanford.edu:80
20:59:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:04:11:Connecting to assign-GPU.stanford.edu:80
21:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:04:11:Connecting to assign-GPU2.stanford.edu:80
21:04:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:09:11:Connecting to assign-GPU.stanford.edu:80
21:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:09:11:Connecting to assign-GPU2.stanford.edu:80
21:09:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read stream
21:14:11:Connecting to assign-GPU.stanford.edu:80
21:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to read stream
21:14:11:Connecting to assign-GPU2.stanford.edu:80
21:14:11:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to read streamRe: gpu WUs not assigning from 171.67.108.201:80
sorry i missed the part to add the code tags to the post...i kind of rushed to post it, now i got it....
davidcoton
Two things to try:
1) Reboot the PC. That should clean up any loose ends from deleting data and re-installing.
2) Reboot your router. That should clean up any passing problems that is causing incoming packets to go astray -- which could be behind both problems. But strange that the CPU client succeeded in getting a download.
David
Question for the gurus: Why is FS01 (GPU?) trying to connect to the Classic AS on 171.67.108.200:8080 ? But the port 80 attempt looks better.Code: Select all
16:25:13: <!-- Folding Slots --> 16:25:13: <slot id='0' type='CPU'/> 16:25:13: <slot id='1' type='GPU'/> 16:25:13:</config> 16:25:13:Set client configured 16:25:13:WU00:FS00:Connecting to 171.67.108.200:8080 16:25:13:WU01:FS01:Connecting to 171.67.108.200:8080 16:25:14:WU00:FS00:Connecting to 171.67.108.200:8080 16:25:14:WU01:FS01:Connecting to 171.67.108.201:80 16:25:14:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.201:80': 10002: Received short response, expected 272 bytes, got 0 16:25:14:WU01:FS01:Connecting to 171.64.65.160:80
David
