P9407 BAD WU?
Locked
crawlers
P9407 BAD WU?
Post by crawlers »
14:53:24:WU02:FS01:0x17:Folding@home GPU core17
14:53:24:WU02:FS01:0x17:Version 0.0.55
14:54:50:WU02:FS01:0x17:ERROR:exception: Called setPositions() on a Context with the wrong number of positions
14:54:50:WU02:FS01:0x17:Saving result file logfile_01.txt
14:54:50:WU02:FS01:0x17:Saving result file log.txt
14:54:50:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
14:54:50:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:54:50:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9407 run:643 clone:0 gen:0 core:0x17 unit:0x000000040a3b1e5c533efb80213c60d2
Error occurred at 99.9% at HD7870 on catalyst 14.3. Can report multiple bad WU at given project at multiple cards and users.
ChristianVirtual
Re: P9407 BAD WU?
Post by ChristianVirtual »
You would need to join the beta team to get help or remove the beta setting in config (which right now is a good idea) ... That can happen with beta WU.
viewtopic.php?nomobile=1&f=16&t=8
Last edited by ChristianVirtual on Sat Apr 05, 2014 5:26 pm, edited 1 time in total.
folding_hoomer
Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300
Re: P9407 BAD WU?
Post by folding_hoomer »
Hello and welcome to the Folding Forum, crawlers.
As ChristianVirtual said, there is no help folding Beta-WU´s while not being a Beta-Tester.
So - please delete flag: beta or join the Beta-Tester-Team.
Info: viewtopic.php?f=66&t=18031
Locked
