I know the TPF for some projects can change quite markedly along the trajectory, is this one of them? I noticed that an earlier run 106 was up to about 9 minutes, but a jump to 15 seems a bit drastic!
Log:
19:12:04:WU00:FS00:Connecting to assign3.stanford.edu:8080
19:12:05:WU00:FS00:News: Welcome to Folding@Home
19:12:05:WU00:FS00:Assigned to work server 128.143.199.97
19:12:05:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.143.199.97
19:12:05:WU00:FS00:Connecting to 128.143.199.97:8080
19:12:06:WU00:FS00:Downloading 1.80MiB
19:12:12:WU00:FS00:Download 93.77%
19:12:12:WU00:FS00:Download complete
19:12:12:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7520 run:120 clone:6 gen:0 core:0xa4 unit:0x00000000fbcb017d51229ad3ef03ca12
19:12:12:WU00:FS00:Starting
19:12:12:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 703 -lifeline 1312 -checkpoint 15 -np 3
19:12:12:WU00:FS00:Started FahCore on PID 2104
19:12:12:WU00:FS00:Core PID:2108
19:12:12:WU00:FS00:FahCore 0xa4 started
19:12:13:WU00:FS00:0xa4:
19:12:13:WU00:FS00:0xa4:*------------------------------*
19:12:13:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
19:12:13:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
19:12:13:WU00:FS00:0xa4:Preparing to commence simulation
19:12:13:WU00:FS00:0xa4:- Looking at optimizations...
19:12:13:WU00:FS00:0xa4:- Created dyn
19:12:13:WU00:FS00:0xa4:- Files status OK
19:12:13:WU00:FS00:0xa4:- Expanded 1886562 -> 3322796 (decompressed 176.1 percent)
19:12:13:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1886562 data_size=3322796, decompressed_data_size=3322796 diff=0
19:12:13:WU00:FS00:0xa4:- Digital signature verified
19:12:13:WU00:FS00:0xa4:Project: 7520 (Run 120, Clone 6, Gen 0)
19:12:13:WU00:FS00:0xa4:Assembly optimizations on if available.
19:12:13:WU00:FS00:0xa4:Entering M.D.
19:12:19:WU00:FS00:0xa4:Completed 0 out of 1000000 steps (0%)
19:27:54:WU00:FS00:0xa4:Completed 10000 out of 1000000 steps (1%)
19:43:21:WU00:FS00:0xa4:Completed 20000 out of 1000000 steps (2%)System and config:
*********************** Log Started 2014-03-27T18:50:44Z ***********************
18:50:44:************************* Folding@home Client *************************
18:50:44: Website: http://folding.stanford.edu/
18:50:44: Copyright: (c) 2009-2013 Stanford University
18:50:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:50:44: Args: --child --lifeline 1095 /etc/fahclient/config.xml --run-as
18:50:44: fahclient --pid-file=/var/run/fahclient.pid --daemon
18:50:44: Config: /etc/fahclient/config.xml
18:50:44:******************************** Build ********************************
18:50:44: Version: 7.3.6
18:50:44: Date: Feb 18 2013
18:50:44: Time: 07:24:08
18:50:44: SVN Rev: 3923
18:50:44: Branch: fah/trunk/client
18:50:44: Compiler: GNU 4.4.7
18:50:44: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
18:50:44: -fno-unsafe-math-optimizations -msse2
18:50:44: Platform: linux2 3.2.0-1-amd64
18:50:44: Bits: 64
18:50:44: Mode: Release
18:50:44:******************************* System ********************************
18:50:44: CPU: Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz
18:50:44: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:50:44: CPUs: 4
18:50:44: Memory: 3.82GiB
18:50:44:Free Memory: 3.57GiB
18:50:44: Threads: POSIX_THREADS
18:50:44:Has Battery: false
18:50:44: On Battery: false
18:50:44: UTC offset: 0
18:50:44: PID: 1312
18:50:44: CWD: /var/lib/fahclient
18:50:44: OS: Linux 3.11.0-12-generic x86_64
18:50:44: OS Arch: AMD64
18:50:44: GPUs: 1
18:50:44: GPU 0: NVIDIA:3 GK106 [GeForce GTX 650 Ti]
18:50:44: CUDA: 3.0
18:50:44:CUDA Driver: 5050
18:50:44:***********************************************************************
18:50:44:<config>
18:50:44: <!-- Client Control -->
18:50:44: <fold-anon v='true'/>
18:50:44:
18:50:44: <!-- Folding Slot Configuration -->
18:50:44: <power v='full'/>
18:50:44:
18:50:44: <!-- HTTP Server -->
18:50:44: <allow v='127.0.0.1 192.168.1.0/24'/>
18:50:44:
18:50:44: <!-- Network -->
18:50:44: <proxy v=':8080'/>
18:50:44:
18:50:44: <!-- Remote Command Server -->
18:50:44: <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
18:50:44:
18:50:44: <!-- Slot Control -->
18:50:44: <pause-on-start v='true'/>
18:50:44:
18:50:44: <!-- User Information -->
18:50:44: <passkey v='********************************'/>
18:50:44: <user v='<removed>'/>
18:50:44:
18:50:44: <!-- Folding Slots -->
18:50:44: <slot id='0' type='CPU'>
18:50:44: <client-type v='advanced'/>
18:50:44: <cpus v='3'/>
18:50:44: <next-unit-percentage v='100'/>
18:50:44: </slot>
18:50:44: <slot id='1' type='GPU'>
18:50:44: </slot>
18:50:44:</config>
