Project: 13000 (Run 876, Clone 0, Gen 12)
czeski
Post by czeski »
It was first P13000 on my computer and it failed.
*********************** Log Started 2014-03-25T16:56:06Z ***********************
16:56:06:************************* Folding@home Client *************************
16:56:06:      Website: http://folding.stanford.edu/
16:56:06:    Copyright: (c) 2009-2014 Stanford University
16:56:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:56:06:         Args:
16:56:06:       Config: C:/Users/Czeski/AppData/Roaming/FAHClient/config.xml
16:56:06:******************************** Build ********************************
16:56:06:      Version: 7.4.4
16:56:06:         Date: Mar 4 2014
16:56:06:         Time: 20:26:54
16:56:06:      SVN Rev: 4130
16:56:06:       Branch: fah/trunk/client
16:56:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:56:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:56:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:56:06:     Platform: win32 XP
16:56:06:         Bits: 32
16:56:06:         Mode: Release
16:56:06:******************************* System ********************************
16:56:06:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
16:56:06:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:56:06:         CPUs: 8
16:56:06:       Memory: 15.87GiB
16:56:06:  Free Memory: 14.24GiB
16:56:06:      Threads: WINDOWS_THREADS
16:56:06:   OS Version: 6.2
16:56:06:  Has Battery: false
16:56:06:   On Battery: false
16:56:06:   UTC Offset: 1
16:56:06:          PID: 4520
16:56:06:          CWD: C:/Users/Czeski/AppData/Roaming/FAHClient
16:56:06:           OS: Windows 8.1 Pro
16:56:06:      OS Arch: AMD64
16:56:06:         GPUs: 1
16:56:06:        GPU 0: NVIDIA:2 GF104 [GeForce GTX 460]
16:56:06:         CUDA: 2.1
16:56:06:  CUDA Driver: 6000
16:56:06:Win32 Service: false
16:56:06:***********************************************************************
16:56:06:<config>
16:56:06:  <!-- Network -->
16:56:06:  <proxy v=':8080'/>
16:56:06:
16:56:06:  <!-- Remote Command Server -->
16:56:06:  <password v='********'/>
16:56:06:
16:56:06:  <!-- Slot Control -->
16:56:06:  <power v='full'/>
16:56:06:
16:56:06:  <!-- User Information -->
16:56:06:  <passkey v='********************************'/>
16:56:06:  <team v='276'/>
16:56:06:  <user v='Czeski'/>
16:56:06:
16:56:06:  <!-- Folding Slots -->
16:56:06:  <slot id='0' type='CPU'>
16:56:06:    <cpus v='6'/>
16:56:06:    <pause-on-start v='true'/>
16:56:06:  </slot>
16:56:06:  <slot id='1' type='GPU'>
16:56:06:    <paused v='true'/>
16:56:06:  </slot>
16:56:06:</config>
23:13:21:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13000 run:876 clone:0 gen:12 core:0x17 unit:0x00000015538b3db7531092e9914b6f3e
23:13:21:WU01:FS01:Starting
23:13:21:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Czeski/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 4520 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:13:21:WU01:FS01:Started FahCore on PID 5748
23:13:21:WU01:FS01:Core PID:188
23:13:21:WU01:FS01:FahCore 0x17 started
23:13:22:WU01:FS01:0x17:*********************** Log Started 2014-03-26T23:13:21Z ***********************
23:13:22:WU01:FS01:0x17:Project: 13000 (Run 876, Clone 0, Gen 12)
23:13:22:WU01:FS01:0x17:Unit: 0x00000015538b3db7531092e9914b6f3e
23:13:22:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
23:13:22:WU01:FS01:0x17:Machine: 1
23:13:22:WU01:FS01:0x17:Reading tar file state.xml
23:13:22:WU01:FS01:0x17:Reading tar file system.xml
23:13:23:WU01:FS01:0x17:Reading tar file integrator.xml
23:13:23:WU01:FS01:0x17:Reading tar file core.xml
23:13:23:WU01:FS01:0x17:Digital signatures verified
23:13:23:WU01:FS01:0x17:Folding@home GPU core17
23:13:23:WU01:FS01:0x17:Version 0.0.52
23:15:59:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
23:15:59:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:03:39:WU01:FS01:0x17:Completed 50000 out of 5000000 steps (1%)
00:23:58:WU01:FS01:0x17:ERROR:exception: The periodic box size has decreased to less than twice the nonbonded cutoff.
00:23:58:WU01:FS01:0x17:Saving result file logfile_01.txt
00:23:58:WU01:FS01:0x17:Saving result file log.txt
00:23:58:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:23:58:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:23:58:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:876 clone:0 gen:12 core:0x17 unit:0x00000015538b3db7531092e9914b6f3e
00:23:58:WU01:FS01:Uploading 2.54KiB to 140.163.4.231
00:23:58:WU01:FS01:Connecting to 140.163.4.231:8080
00:23:58:WU01:FS01:Upload complete
00:23:58:WU01:FS01:Server responded WORK_ACK (400)
00:23:58:WU01:FS01:Cleaning up
Next p13000 WU (2263,0,2) so far (8%) is folding ok.
Re: Project: 13000 (Run 876, Clone 0, Gen 12)
A small percentage of WU can be unstable. The failure of a single WU doesn't necessarily implicate your system but a series of failures would.
At this point, we can't tell if this is a "bad WU" or if you have some kind of local problem such as a hardware issue. The WU will be reissued and may be completed by others, suggesting your system is unusual in some way or it may fail on other systems, too.
So far, there is a single report in the WU Database which is yours. I have marked it for a follow up.
bollix47
Post by bollix47 »
Another folder was able to complete this WU successfully:
Hi **** (team ****),
Your WU (P13000 R876 C0 G12) was added to the stats database on 2014-03-27 13:03:16 for 60632.5 points of credit.
Followup report closed.
