Project: 13000 (Run 1066, Clone 0, Gen 0
GentleGiant
Post by GentleGiant »
Here's the failure trace from my machine; This is with FaH Client 7.3.6, Windows 8.1 64-bit, and the most recent Nvidia drivers 335.23. The time to the core getting the error is consistantly about 2.5 minutes, and the out-of bounds force number is always in the 450 range.
20:51:00:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Warren/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4032 -checkpoint 5 -gpu 0 -gpu-vendor nvidia
20:51:00:WU01:FS00:Started FahCore on PID 7396
20:51:00:WU01:FS00:Core PID:6172
20:51:00:WU01:FS00:FahCore 0x17 started
20:51:01:WU01:FS00:0x17:*********************** Log Started 2014-03-24T20:51:00Z ***********************
20:51:01:WU01:FS00:0x17:Project: 13000 (Run 1066, Clone 0, Gen 0)
20:51:01:WU01:FS00:0x17:Unit: 0x00000003538b3db75310c8b90f8debfb
20:51:01:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
20:51:01:WU01:FS00:0x17:Machine: 0
20:51:01:WU01:FS00:0x17:Reading tar file system.xml
20:51:01:WU01:FS00:0x17:Reading tar file integrator.xml
20:51:01:WU01:FS00:0x17:Reading tar file state.xml
20:51:03:WU01:FS00:0x17:Reading tar file core.xml
20:51:03:WU01:FS00:0x17:Digital signatures verified
20:51:03:WU01:FS00:0x17:Folding@home GPU core17
20:51:03:WU01:FS00:0x17:Version 0.0.52
20:51:25:FS00:Finishing
20:54:39:WU01:FS00:0x17:ERROR:exception: Force RMSE error of 451.615 with threshold of 5
20:54:39:WU01:FS00:0x17:Saving result file logfile_01.txt
20:54:39:WU01:FS00:0x17:Saving result file log.txt
20:54:39:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:54:39:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:54:40:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:1066 clone:0 gen:0 core:0x17 unit:0x00000003538b3db75310c8b90f8debfb
20:54:40:WU01:FS00:Uploading 2.34KiB to 140.163.4.231
20:54:40:WU01:FS00:Connecting to 140.163.4.231:8080
20:54:40:WU01:FS00:Upload complete
20:54:40:WU01:FS00:Server responded WORK_ACK (400)
20:54:40:WU01:FS00:Cleaning up
Re: Project: 13000 (Run 1066, Clone 0, Gen 0)
The WU Project: 13000 (Run 1066, Clone 0, Gen 0) has been reissued and it seems to be a bad WU since everybody has reported a failure.
I'm moving these two posts to the proper forum for a report of a single bad WU. It has nothing to do with Maxwell problems on P9401.
