folding.stanford.edu
Rel25917
Post by Rel25917 »
Is folding.stanford.edu down for everyone else? Can't get to it from any of my computers/browsers. It is also keeping the NaCl client from loading.
Re: folding.stanford.edu
Working fine for me from my home computer. What is your ISP, and has there been any changes to your system and connection recently?
smackiethefrog
Post by smackiethefrog »
Appears down for me. This is affecting both NaCl client as well as Web Control for the normal client. My browsers with the NaCl client already running are continuing to get work, so it seems to be only affecting the web servers. At one point I was eventually served a Stanford access forbidden page, but now it seems to be back to infini-loading.
I am on Comcast, by the way.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
Works for me, I'm at USU.
You can always check these websites:
http://www.downforeveryoneorjustme.com/
http://www.isitdownrightnow.com/
http://doj.me/
smackiethefrog
downforeveryoneorjustme was saying it was down about 15 minutes ago, but has said up ever since I got that access forbidden page.
Rel25917
Post by Rel25917 »
I am also on comcast.
edit- I can get the main www.stanford.edu site. trace routes and pings to folding.stanford resolve to the main site. just folding.stanford.edu that wont come up.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
Ok, is it down for anyone not on Comcast, or up for anyone who is on Comcast?
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
I'm on Comcast and am having no problems.
smackiethefrog
All of my connectivity issues to folding.stanford.edu have now resolved.
Is it possible that this could have been an IPv6 issue? I ask because ping commands to folding.stanford.edu replace that url with www-v6.stanford.edu. Also, because this sounds exactly like what was happening for me.
C:\Users\Scott>ping stanford.edu
Pinging stanford.edu [171.67.215.200] with 32 bytes of data:
Reply from 171.67.215.200: bytes=32 time=98ms TTL=237
Reply from 171.67.215.200: bytes=32 time=93ms TTL=237
Reply from 171.67.215.200: bytes=32 time=97ms TTL=237
Reply from 171.67.215.200: bytes=32 time=94ms TTL=237
Ping statistics for 171.67.215.200:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 93ms, Maximum = 98ms, Average = 95ms
C:\Users\Scott>ping folding.stanford.edu
Pinging www-v6.stanford.edu [171.67.215.200] with 32 bytes of data:
Reply from 171.67.215.200: bytes=32 time=95ms TTL=237
Reply from 171.67.215.200: bytes=32 time=92ms TTL=237
    Minimum = 92ms, Maximum = 95ms, Average = 93ms
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
I would say so, that seems a reasonable diagnostic.
For comparison, here is my ping:
jesse@jesse-N61Vn ~ $ ping stanford.edu
PING stanford.edu (171.67.215.200) 56(84) bytes of data.
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=1 ttl=243 time=29.0 ms
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=2 ttl=243 time=29.2 ms
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=3 ttl=243 time=29.5 ms
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=4 ttl=243 time=29.7 ms
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=5 ttl=243 time=29.3 ms
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=6 ttl=243 time=29.1 ms
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=7 ttl=243 time=29.2 ms
64 bytes from www.Stanford.EDU (171.67.215.200): icmp_seq=8 ttl=243 time=28.7 ms
^C
--- stanford.edu ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time 7008ms
rtt min/avg/max/mdev = 28.791/29.273/29.766/0.281 ms
Rel25917
Post by Rel25917 »
Whatever it is I'm still affected. Tried using googles dns instead of comcast. I can get the webpage by using https://folding.stanford.edu but still fails without the s. Tried disabling ipv6 with no change, and my xp comps don't even know what ipv6 is.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
Rel25917 wrote:Whatever it is I'm still affected. Tried using googles dns instead of comcast. I can get the webpage by using https://folding.stanford.edu but still fails without the s. Tried disabling ipv6 with no change, and my xp comps don't even know what ipv6 is.
Interesting. Do you have a Linux box that you could try, or a distro on a flashdrive? Could you try unplugging your router, waiting 30 seconds, and then plugging it back in? Sorry for the stereotypical IT response there, but I don't have any other ideas at this point.
I wasn't aware that they had HTTPS available, that's news to me. Their crypto is a bit behind though: TLS 1.0, RC4, and 3DES? Come come.
https://www.ssllabs.com/ssltest/analyze ... anford.edu
Rel25917
Post by Rel25917 »
Already tried reseting the router and modem, didn't help. No linux available, didn't think to try my phone over wifi then try over 4g, will go try that. I have tried 2 win xp boxes 1 win 7 and 1 win 8.1. All seem to be acting the same.
Edit- Tried the phone, same behavior over wifi, http fails https works. turned off wifi it pulled up http just fine over 4g.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
Rel25917 wrote:Already tried reseting the router and modem, didn't help. No linux available, didn't think to try my phone over wifi then try over 4g, will go try that. I have tried 2 win xp boxes 1 win 7 and 1 win 8.1. All seem to be acting the same.
Appropriate XKCD for you: https://www.xkcd.com/806/
Rel25917
Post by Rel25917 »
Well whatever it was it seems to have resolved itself finally. Webpage comes up fine and NaCl client started up fine.
