I have been folding in the project 13001 for about an hour. The status is 0.00% and when I try to look up the project I get a message that says, Error: A description for this project does not yet exist. What can I to do about this?
Sorry if this is not the correct place for this topic, I could not find an under-forum that matched my problem better.
Project does not exist
Re: Project does not exist
I think it is a beta, then no help?
Edit: Sorry it is not beta
Welcome to folding forum
Project 13001 was created yesterday and I'm sure there will be a description soon. The project is an extension of P13000 so the description will almost certainly be the same as Project 13000
... and no, the project is not beta, although if you used the beta flag you may run into other problems that we won't be able to help you with except in the beta forum. REMOVE the beta flag if you're using it.
Thank you for your reply. I was getting a bit anxious about not being able to fold with my GPU.
Edit: The server is up now so I can continue folding. That time remaining though, 4.19 days.
