*********************** Log Started 2014-03-17T19:27:25Z ***********************
19:27:25:************************* Folding@home Client *************************
19:27:25: Website: http://folding.stanford.edu/
19:27:25: Copyright: (c) 2009-2013 Stanford University
19:27:25: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:27:25: Args: --open-web-control
19:27:25: Config: C:/Users/Clinton/AppData/Roaming/FAHClient/config.xml
19:27:25:******************************** Build ********************************
19:27:25: Version: 7.3.6
19:27:25: Date: Feb 18 2013
19:27:25: Time: 15:25:17
19:27:25: SVN Rev: 3923
19:27:25: Branch: fah/trunk/client
19:27:25: Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:27:25: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:27:25: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:27:25: Platform: win32 XP
19:27:25: Bits: 32
19:27:25: Mode: Release
19:27:25:******************************* System ********************************
19:27:25: CPU: Intel(R) Core(TM) i7-4702MQ CPU @ 2.20GHz
19:27:25: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:27:25: CPUs: 8
19:27:25: Memory: 7.66GiB
19:27:25: Free Memory: 5.02GiB
19:27:25: Threads: WINDOWS_THREADS
19:27:25: Has Battery: true
19:27:25: On Battery: false
19:27:25: UTC offset: -4
19:27:25: PID: 2424
19:27:25: CWD: C:/Users/Clinton/AppData/Roaming/FAHClient
19:27:25: OS: Windows 8
19:27:25: OS Arch: AMD64
19:27:25: GPUs: 1
19:27:25: GPU 0: NVIDIA:3 GK107 [GeForce GT 750M]
19:27:25: CUDA: 3.0
19:27:25: CUDA Driver: 5000
19:27:25:Win32 Service: false
19:27:25:***********************************************************************
19:27:26:<config>
19:27:26: <!-- Folding Slot Configuration -->
19:27:26: <power v='full'/>
19:27:26:
19:27:26: <!-- HTTP Server -->
19:27:26: <allow v='10.1.10.65 127.0.0.1 10.1.10.165'/>
19:27:26:
19:27:26: <!-- Network -->
19:27:26: <proxy v=':8080'/>
19:27:26:
19:27:26: <!-- Remote Command Server -->
19:27:26: <password v='*'/>
19:27:26:
19:27:26: <!-- User Information -->
19:27:26: <passkey v='********************************'/>
19:27:26: <team v='226052'/>
19:27:26: <user v='tymorus'/>
19:27:26:
19:27:26: <!-- Folding Slots -->
19:27:26: <slot id='0' type='GPU'>
19:27:26: <client-type v='advanced'/>
19:27:26: </slot>
19:27:26: <slot id='1' type='CPU'/>
19:27:26:</config>Code: Select all
******************************* Date: 2014-03-19 *******************************
02:22:29:WU01:FS00:0x17:Completed 3250000 out of 5000000 steps (65%)
02:28:47:WU00:FS01:0xa3:Completed 400000 out of 500000 steps (80%)
02:51:03:WU01:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
02:53:19:WU00:FS01:0xa3:Completed 405000 out of 500000 steps (81%)
03:18:00:WU00:FS01:0xa3:Completed 410000 out of 500000 steps (82%)
03:19:33:WU01:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
03:42:31:WU00:FS01:0xa3:Completed 415000 out of 500000 steps (83%)
03:48:08:WU01:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
04:07:00:WU00:FS01:0xa3:Completed 420000 out of 500000 steps (84%)
04:11:46:WU01:FS00:0x17:ERROR:exception: bad allocation
04:11:47:WU01:FS00:0x17:Saving result file logfile_01.txt
04:11:47:WU01:FS00:0x17:Saving result file log.txt
04:11:49:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
04:11:50:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:11:51:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9401 run:1202 clone:0 gen:21 core:0x17 unit:0x0000001d6652edaf52eb0b0f425286c9
04:11:52:WU01:FS00:Uploading 3.54KiB to 171.67.108.31
04:11:52:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
04:11:52:WU01:FS00:Connecting to 171.67.108.31:8080
04:11:53:WU01:FS00:Upload complete
04:11:53:WU02:FS00:News: Welcome to Folding@Home
04:11:53:WU02:FS00:Assigned to work server 140.163.4.231
04:11:53:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GK107 [GeForce GT 750M] from 140.163.4.231
04:11:53:WU02:FS00:Connecting to 140.163.4.231:8080
04:11:53:WU01:FS00:Server responded WORK_ACK (400)
04:11:53:WU01:FS00:Cleaning up
04:11:55:WU02:FS00:Downloading 5.22MiB
04:12:01:WU02:FS00:Download 56.25%
04:12:05:WU02:FS00:Download complete
04:12:05:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13001 run:322 clone:0 gen:0 core:0x17 unit:0x00000000538b3db75328aaf19e1f1db8
04:12:05:WU02:FS00:Starting
04:12:05:WU02:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Clinton/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 2424 -checkpoint 3 -gpu 0 -gpu-vendor nvidia
04:12:06:WU02:FS00:Started FahCore on PID 2900
04:12:06:WU02:FS00:Core PID:4784
04:12:06:WU02:FS00:FahCore 0x17 started
04:12:11:WU02:FS00:0x17:*********************** Log Started 2014-03-19T04:12:11Z ***********************
04:12:11:WU02:FS00:0x17:Project: 13001 (Run 322, Clone 0, Gen 0)
04:12:11:WU02:FS00:0x17:Unit: 0x00000000538b3db75328aaf19e1f1db8
04:12:11:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
04:12:11:WU02:FS00:0x17:Machine: 0
04:12:11:WU02:FS00:0x17:Reading tar file system.xml
04:12:13:WU02:FS00:0x17:Reading tar file integrator.xml
04:12:13:WU02:FS00:0x17:Reading tar file state.xml
04:12:16:WU02:FS00:0x17:Reading tar file core.xml
04:12:16:WU02:FS00:0x17:Digital signatures verified
04:12:16:WU02:FS00:0x17:Folding@home GPU core17
04:12:16:WU02:FS00:0x17:Version 0.0.52
04:12:30:WU02:FS00:0x17:ERROR:exception: bad allocation
04:12:30:WU02:FS00:0x17:Saving result file logfile_01.txt
04:12:30:WU02:FS00:0x17:Saving result file log.txt
04:12:30:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
04:12:31:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:12:32:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:13001 run:322 clone:0 gen:0 core:0x17 unit:0x00000000538b3db75328aaf19e1f1db8
04:12:32:WU02:FS00:Uploading 2.08KiB to 140.163.4.231
04:12:32:WU02:FS00:Connecting to 140.163.4.231:8080
04:12:32:WU02:FS00:Upload complete
04:12:32:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:12:33:WU02:FS00:Server responded WORK_ACK (400)
04:12:33:WU02:FS00:Cleaning up
04:12:34:WU01:FS00:News: Welcome to Folding@Home
04:12:34:WU01:FS00:Assigned to work server 140.163.4.231
04:12:34:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK107 [GeForce GT 750M] from 140.163.4.231
04:12:34:WU01:FS00:Connecting to 140.163.4.231:8080
04:12:35:WU01:FS00:Downloading 4.84MiB
04:12:41:WU01:FS00:Download 41.36%
04:12:46:WU01:FS00:Download complete
04:12:46:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13000 run:843 clone:6 gen:2 core:0x17 unit:0x00000002538b3db7531089b63f3399d0
04:12:46:WU01:FS00:Starting
04:12:46:WU01:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/Users/Clinton/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2424 -checkpoint 3 -gpu 0 -gpu-vendor nvidia
04:12:46:WU01:FS00:Started FahCore on PID 5116
04:12:49:WU01:FS00:Core PID:1712
04:12:49:WU01:FS00:FahCore 0x17 started
04:12:55:WU01:FS00:0x17:*********************** Log Started 2014-03-19T04:12:53Z ***********************
04:12:55:WU01:FS00:0x17:Project: 13000 (Run 843, Clone 6, Gen 2)
04:12:55:WU01:FS00:0x17:Unit: 0x00000002538b3db7531089b63f3399d0
04:12:55:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
04:12:55:WU01:FS00:0x17:Machine: 0
04:12:55:WU01:FS00:0x17:Reading tar file state.xml
04:12:57:WU01:FS00:0x17:Reading tar file system.xml
04:12:58:WU01:FS00:0x17:Reading tar file integrator.xml
04:12:58:WU01:FS00:0x17:Reading tar file core.xml
04:12:59:WU01:FS00:0x17:Digital signatures verified
04:12:59:WU01:FS00:0x17:Folding@home GPU core17
04:12:59:WU01:FS00:0x17:Version 0.0.52
04:21:25:WU01:FS00:0x17:Completed 0 out of 5000000 steps (0%)
04:21:25:WU01:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:22:03:FS01:Finishing
04:22:14:FS00:Finishing
04:29:43:WU00:FS01:0xa3:Completed 425000 out of 500000 steps (85%)
04:45:12:WU01:FS00:0x17:ERROR:exception: bad allocation
04:45:13:WU01:FS00:0x17:Saving result file logfile_01.txt
04:45:13:WU01:FS00:0x17:Saving result file log.txt
04:45:13:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
04:45:15:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:45:16:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:13000 run:843 clone:6 gen:2 core:0x17 unit:0x00000002538b3db7531089b63f3399d0
04:45:16:WU01:FS00:Uploading 2.48KiB to 140.163.4.231
04:45:17:WU01:FS00:Connecting to 140.163.4.231:8080
04:45:17:WU01:FS00:Upload complete
04:45:18:WU01:FS00:Server responded WORK_ACK (400)
04:45:18:WU01:FS00:Cleaning up
EDIT: changed failure percentage to 63%, after closer reading in the log the cpu was the one at 84%.
