I know this question may have been asked before but, I will ask anyway.
I started folding about a month ago after a long hiatus, am using the beta client and it seems to be going good.
What I would like to know is why in the statistics page http://fah-web.stanford.edu/cgi-bin/mai ... num=226025
it shows that only 7 CPUs have been active in the last 50 days. Well, I added two new machines this week (1 was 2days ago and the other yesterday)
why does it NOT reflect the fact that there have been 17 CPUs?
It might sound like I am being prissy and I know the work is more important than points but, I wondered if something I have done is the reason
the stats only show 7 active CPU's? if it IS normal then that is ok.
I just don't want to screw this up as I have lost 2 Family and 2 close friends to Cancer and I want to make a difference so that there sacrifice is not forgotten.
Team Statistics
- Hardware configuration: Gigabyte Z68 UDR3H
i7 2600K @3.40ghz
2 x GTX660 Ti Gigabyte
32gb DDRIII 1600mhz
128gb Intel SSD
2 x 2.TB drives
Windows 7 64 Ultimate
Cable Net
Folding CPU and GPU 24/7 - Location: Sydney NSW Australia
Team Statistics
I lost 2 Family members to cancer, no more.
- Hardware configuration: Full Time:
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop - Location: Near Oxford, United Kingdom
Re: Team Statistics
The stats page only indicates a new client when it gets a WU returned, not when you download it.
Have any been successfully completed and returned yet on the new kit?
By the way- it's now showing 9 CPUs, so it's noticed something
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: Team Statistics
Looked a bit closer- although your link says Active CPUs I suspect it actually means Active Clients.
On your "personal" stats page (http://fah-web.stanford.edu/cgi-bin/mai ... zPapaSmurf) it says 9 Active Clients, which sounds right if you've just added 2 new computers.
i7 2600K @3.40ghz
32gb DDRIII 1600mhz
128gb Intel SSD
2 x 2.TB drives
Cable Net
Re: Team Statistics
Thanks fellas. I guess I should have looked a little closer.
I am sure I will get the hang of it soon.
I have one system with AMD 955, GTX 560Ti and 8gb ram, another with AMD FX8150, GTX650 Ti and 16gb, main system, Intel i7 2600K O/C to 4ghz, GTX 660Ti and 32gb ram.
They are all running 24/7 right now.
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Re: Team Statistics
Let me know when you do, I'll know who to askOzPapaSmurf wrote: I am sure I will get the hang of it soon.
