CPU fails to get work assignment, but GPU okay
tj3f3rsn
Post by tj3f3rsn »
Hi all.
I've been running fah for years. I started running on my work machine a few weeks ago. For a week or two both the CPU and GPU work units ran as expected.
About a week ago (I think) the CPU began failing to get work assignments, although the GPU continues to run great.
When I check the assignment servers in my browser the "assign" server fails to load but the "gpu" servers gets OK (as expected from my symptoms).
I suspect it is a firewall/antivirus issue, but the confusing part for me is that the cpu WAS getting assignments and the gpu still IS getting assignments.
Any ideas?
*********************** Log Started 2014-02-26T23:49:46Z ***********************
23:49:46:************************* Folding@home Client *************************
23:49:46:      Website: http://folding.stanford.edu/
23:49:46:    Copyright: (c) 2009-2013 Stanford University
23:49:46:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:49:46:         Args:
23:49:46:       Config: C:/temp/FAH/FAHClient/config.xml
23:49:46:******************************** Build ********************************
23:49:46:      Version: 7.3.6
23:49:46:         Date: Feb 18 2013
23:49:46:         Time: 15:25:17
23:49:46:      SVN Rev: 3923
23:49:46:       Branch: fah/trunk/client
23:49:46:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:49:46:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:49:46:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:49:46:     Platform: win32 XP
23:49:46:         Bits: 32
23:49:46:         Mode: Release
23:49:46:******************************* System ********************************
23:49:46:          CPU: Intel(R) Core(TM) i7-3740QM CPU @ 2.70GHz
23:49:46:       CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
23:49:46:         CPUs: 4
23:49:46:       Memory: 15.88GiB
23:49:46:  Free Memory: 11.51GiB
23:49:46:      Threads: WINDOWS_THREADS
23:49:46:  Has Battery: true
23:49:46:   On Battery: false
23:49:46:   UTC offset: -8
23:49:46:          PID: 4196
23:49:46:          CWD: C:/temp/FAH/FAHClient
23:49:46:           OS: Windows 7 Enterprise
23:49:46:      OS Arch: AMD64
23:49:46:         GPUs: 1
23:49:46:        GPU 0: NVIDIA:3 GK107 [Quadro 2100M]
23:49:46:         CUDA: 3.0
23:49:46:  CUDA Driver: 5050
23:49:46:Win32 Service: false
23:49:46:***********************************************************************
23:49:46:<config>
23:49:46:  <!-- Folding Core -->
23:49:46:  <checkpoint v='10'/>
23:49:46:
23:49:46:  <!-- Folding Slot Configuration -->
23:49:46:  <power v='full'/>
23:49:46:
23:49:46:  <!-- Network -->
23:49:46:  <proxy v=':8080'/>
23:49:46:
23:49:46:  <!-- User Information -->
23:49:46:  <team v='182116'/>
23:49:46:  <user v='tj3f3rsn'/>
23:49:46:
23:49:46:  <!-- Folding Slots -->
23:49:46:  <slot id='0' type='GPU'/>
23:49:46:  <slot id='1' type='CPU'>
23:49:46:    <cpus v='-1'/>
23:49:46:  </slot>
23:49:46:</config>
23:49:46:Trying to access database...
23:49:46:Successfully acquired database lock
23:49:46:Enabled folding slot 00: READY gpu:0:GK107 [Quadro 2100M]
23:49:46:Enabled folding slot 01: READY cpu:4
23:49:46:WU01:FS00:Starting
23:49:46:WU01:FS00:Running FahCore: C:\temp\FAH\FAHClient/FAHCoreWrapper.exe C:/temp/FAH/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 703 -lifeline 4196 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
23:49:46:WU01:FS00:Started FahCore on PID 7788
23:49:46:WU01:FS00:Core PID:9316
23:49:46:WU01:FS00:FahCore 0x15 started
23:49:46:WU00:FS01:Connecting to assign3.stanford.edu:8080
23:49:46:WU01:FS00:0x15:
23:49:46:WU01:FS00:0x15:*------------------------------*
23:49:46:WU01:FS00:0x15:Folding@Home GPU Core
23:49:46:WU01:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:49:46:WU01:FS00:0x15:Build host             AmoebaRemote
23:49:46:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
23:49:46:WU01:FS00:0x15:Core                   15
23:49:46:WU01:FS00:0x15:Window's signal control handler registered.
23:49:46:WU01:FS00:0x15:Preparing to commence simulation
23:49:46:WU01:FS00:0x15:- Looking at optimizations...
23:49:46:WU01:FS00:0x15:- Files status OK
23:49:46:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:49:46:WU01:FS00:0x15:- Expanded 145724 -> 660986 (decompressed 453.5 percent)
23:49:46:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=145724 data_size=660986, decompressed_data_size=660986 diff=0
23:49:46:WU01:FS00:0x15:- Digital signature verified
23:49:46:WU01:FS00:0x15:Project: 8018 (Run 10, Clone 1, Gen 206)
23:49:46:WU01:FS00:0x15:Assembly optimizations on if available.
23:49:46:WU01:FS00:0x15:Entering M.D.
23:49:47:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
23:49:47:WU00:FS01:Connecting to assign4.stanford.edu:80
23:49:48:WU01:FS00:0x15:Will resume from checkpoint file 01/wudata_01.ckp
23:49:48:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  1272161019 2027377412 1023562327 708743017 2769342692
23:49:48:WU01:FS00:0x15:GPU device id=0
23:49:48:WU01:FS00:0x15:Working on GRowing Old MAkes el Chrono Sweat
23:49:48:WU01:FS00:0x15:Client config unavailable.
23:49:48:WU01:FS00:0x15:Starting GUI Server
23:49:49:WARNING:WU00:FS01:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
23:49:49:ERROR:WU00:FS01:Exception: Could not get an assignment
23:49:49:WU00:FS01:Connecting to assign3.stanford.edu:8080
23:49:50:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
23:49:50:WU00:FS01:Connecting to assign4.stanford.edu:80
23:49:51:WARNING:WU00:FS01:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
23:49:51:ERROR:WU00:FS01:Exception: Could not get an assignment
23:50:49:WU00:FS01:Connecting to assign3.stanford.edu:8080
23:50:50:WU01:FS00:0x15:Resuming from checkpoint
23:50:50:WU01:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
23:50:50:WU01:FS00:0x15:   0   1272161019   1272161019
23:50:50:WU01:FS00:0x15:   1   2027377412   2027377412
23:50:50:WU01:FS00:0x15:   2   1023562327   1023562327
23:50:50:WU01:FS00:0x15:   3    708743017    708743017
23:50:50:WU01:FS00:0x15:   4   2769342692   2769342692
23:50:50:WU01:FS00:0x15:fcCheckPointResume: file hashes same.
23:50:50:WU01:FS00:0x15:fcCheckPointResume: state restored.
23:50:50:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
23:50:50:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
23:50:50:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
23:50:50:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
23:50:50:WU01:FS00:0x15:fcCheckPointResume: state restored 2
23:50:50:WU01:FS00:0x15:Resumed from checkpoint
23:50:50:WU01:FS00:0x15:Setting checkpoint frequency: 250000
23:50:50:WU01:FS00:0x15:Completed   2500001 out of 25000000 steps (10%).
23:50:50:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
23:50:50:WU00:FS01:Connecting to assign4.stanford.edu:80
23:50:51:WARNING:WU00:FS01:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
23:50:51:ERROR:WU00:FS01:Exception: Could not get an assignment
23:52:26:WU00:FS01:Connecting to assign3.stanford.edu:8080
23:52:27:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
23:52:27:WU00:FS01:Connecting to assign4.stanford.edu:80
23:52:29:WARNING:WU00:FS01:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
23:52:29:ERROR:WU00:FS01:Exception: Could not get an assignment
23:55:03:WU00:FS01:Connecting to assign3.stanford.edu:8080
23:55:05:WARNING:WU00:FS01:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
23:55:05:WU00:FS01:Connecting to assign4.stanford.edu:80
23:55:06:WARNING:WU00:FS01:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
23:55:06:ERROR:WU00:FS01:Exception: Could not get an assignment
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: CPU fails to get work assignment, but GPU okay
Post by Jesse_V »
Can you open assign3.stanford.edu:8080 in your browser? If you can, it will say "OK".
tj3f3rsn
Post by tj3f3rsn »
Jesse_V wrote:Can you open assign3.stanford.edu:8080 in your browser? If you can, it will say "OK".
No, I mentioned that in the original post, but I only get "OK" for the GPU server, not the regular server. (Any of the "assign" servers get "This page can't be displayed" messages in my browser.)
Again, I suspect there is some conflict with firewall/antivirus, but that doesn't explain to me why the "assign" servers USED to work, while the GPU server STILL works.
Talking to my IT Dept is not really an option, so I was just hoping someone here might have an easy answer off the top of their head.
According to serverstat, http://assign.stanford.edu:8080 is working but http://assign2.stanford.edu:80 is not. which matches what my browser tells me. The same is true for assign3 (OK) and assign4 (not OK).
I'll find somebody at Stanford who can fix it.
tj3f3rsn
Post by tj3f3rsn »
Awesome, thanks Bruce!
My machine was able to download a CPU work unit about 5 hours or so ago, so looks like you got in touch with the right person.
