Can't connect
KF6FVV
Unable to get assigned a new work order
Post by KF6FVV »
I've been running fine for the last 4 months but as of two days ago, I just stopped getting any work units. Figured I'd wait a while to see if it was just temporary but still nothing. I uninstalled and re-installed with the public beta 7.4.2 hoping that would help, but I still keep getting the error "Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0"
I don't appear to be having trouble pinging any of the active assignment servers but I just don't know enough about whats going on to figure out where the problem is.
Other things I've tried hoping it would help get an assigned work unit but doesn't seem to help.
- Changed client-type to advanced
- Changed max-packet-size to big
*********************** Log Started 2014-02-22T22:09:23Z ***********************
22:09:23:************************* Folding@home Client *************************
22:09:23:      Website: http://folding.stanford.edu/
22:09:23:    Copyright: (c) 2009-2014 Stanford University
22:09:23:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:09:23:         Args: --open-web-control
22:09:23:       Config: C:/Users/Eric/AppData/Roaming/FAHClient/config.xml
22:09:23:******************************** Build ********************************
22:09:23:      Version: 7.4.2
22:09:23:         Date: Jan 24 2014
22:09:23:         Time: 13:51:17
22:09:23:      SVN Rev: 4112
22:09:23:       Branch: fah/trunk/client
22:09:23:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:09:23:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:09:23:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:09:23:     Platform: win32 XP
22:09:23:         Bits: 32
22:09:23:         Mode: Release
22:09:23:******************************* System ********************************
22:09:23:          CPU: AMD Phenom(tm) II X6 1090T Processor
22:09:23:       CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
22:09:23:         CPUs: 6
22:09:23:       Memory: 15.99GiB
22:09:23:  Free Memory: 11.96GiB
22:09:23:      Threads: WINDOWS_THREADS
22:09:23:   OS Version: 6.1
22:09:23:  Has Battery: false
22:09:23:   On Battery: false
22:09:23:   UTC Offset: -8
22:09:23:          PID: 8824
22:09:23:          CWD: C:/Users/Eric/AppData/Roaming/FAHClient
22:09:23:           OS: Windows 7 Ultimate
22:09:23:      OS Arch: AMD64
22:09:23:         GPUs: 1
22:09:23:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 670]
22:09:23:         CUDA: 3.0
22:09:23:  CUDA Driver: 5050
22:09:23:Win32 Service: false
22:09:23:***********************************************************************
22:09:23:<config>
22:09:23:  <service-description v='Folding@home Client'/>
22:09:23:  <service-restart v='true'/>
22:09:23:  <service-restart-delay v='5000'/>
22:09:23:
22:09:23:  <!-- Client Control -->
22:09:23:  <client-threads v='6'/>
22:09:23:  <cycle-rate v='4'/>
22:09:23:  <cycles v='-1'/>
22:09:23:  <data-directory v='.'/>
22:09:23:  <disable-sleep-when-active v='true'/>
22:09:23:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
22:09:23:  <exit-when-done v='false'/>
22:09:23:  <fold-anon v='false'/>
22:09:23:  <open-web-control v='true'/>
22:09:23:
22:09:23:  <!-- Configuration -->
22:09:23:  <config-rotate v='true'/>
22:09:23:  <config-rotate-dir v='configs'/>
22:09:23:  <config-rotate-max v='16'/>
22:09:23:
22:09:23:  <!-- Debugging -->
22:09:23:  <assignment-servers>
22:09:23:    assign3.stanford.edu:8080 assign4.stanford.edu:80
22:09:23:  </assignment-servers>
22:09:23:  <auth-as v='true'/>
22:09:23:  <capture-directory v='capture'/>
22:09:23:  <capture-on-error v='false'/>
22:09:23:  <capture-packets v='false'/>
22:09:23:  <capture-requests v='false'/>
22:09:23:  <capture-responses v='false'/>
22:09:23:  <capture-sockets v='false'/>
22:09:23:  <core-exec v='FahCore_$type'/>
22:09:23:  <core-wrapper-exec v='FAHCoreWrapper'/>
22:09:23:  <debug-sockets v='false'/>
22:09:23:  <exception-locations v='true'/>
22:09:23:  <gpu-assignment-servers>
22:09:23:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
22:09:23:  </gpu-assignment-servers>
22:09:23:  <stack-traces v='false'/>
22:09:23:
22:09:23:  <!-- Error Handling -->
22:09:23:  <max-slot-errors v='10'/>
22:09:23:  <max-unit-errors v='5'/>
22:09:23:
22:09:23:  <!-- Folding Core -->
22:09:23:  <checkpoint v='10'/>
22:09:23:  <core-dir v='cores'/>
22:09:23:  <core-priority v='low'/>
22:09:23:  <cpu-affinity v='false'/>
22:09:23:  <cpu-usage v='100'/>
22:09:23:  <gpu-usage v='100'/>
22:09:23:  <no-assembly v='false'/>
22:09:23:
22:09:23:  <!-- Folding Slot Configuration -->
22:09:23:  <cause v='ANY'/>
22:09:23:  <client-subtype v='STDCLI'/>
22:09:23:  <client-type v='normal'/>
22:09:23:  <cpu-species v='X86_AMD'/>
22:09:23:  <cpu-type v='AMD64'/>
22:09:23:  <cpus v='-1'/>
22:09:23:  <cuda-index v='0'/>
22:09:23:  <gpu v='true'/>
22:09:23:  <max-packet-size v='normal'/>
22:09:23:  <opencl-index v='0'/>
22:09:23:  <os-species v='UNKNOWN'/>
22:09:23:  <os-type v='WIN32'/>
22:09:23:  <project-key v='0'/>
22:09:23:  <smp v='true'/>
22:09:23:
22:09:23:  <!-- GUI -->
22:09:23:  <gui-enabled v='true'/>
22:09:23:
22:09:23:  <!-- HTTP Server -->
22:09:23:  <allow v='127.0.0.1'/>
22:09:23:  <connection-timeout v='60'/>
22:09:23:  <deny v='0/0'/>
22:09:23:  <http-addresses v='0:7396'/>
22:09:23:  <https-addresses v=''/>
22:09:23:  <max-connect-time v='900'/>
22:09:23:  <max-connections v='800'/>
22:09:23:  <max-request-length v='52428800'/>
22:09:23:  <min-connect-time v='300'/>
22:09:23:  <threads v='6'/>
22:09:23:
22:09:23:  <!-- Logging -->
22:09:23:  <log v='log.txt'/>
22:09:23:  <log-color v='false'/>
22:09:23:  <log-crlf v='true'/>
22:09:23:  <log-date v='false'/>
22:09:23:  <log-date-periodically v='21600'/>
22:09:23:  <log-debug v='true'/>
22:09:23:  <log-domain v='false'/>
22:09:23:  <log-header v='true'/>
22:09:23:  <log-level v='true'/>
22:09:23:  <log-no-info-header v='true'/>
22:09:23:  <log-redirect v='false'/>
22:09:23:  <log-rotate v='true'/>
22:09:23:  <log-rotate-dir v='logs'/>
22:09:23:  <log-rotate-max v='16'/>
22:09:23:  <log-short-level v='false'/>
22:09:23:  <log-simple-domains v='true'/>
22:09:23:  <log-thread-id v='false'/>
22:09:23:  <log-thread-prefix v='true'/>
22:09:23:  <log-time v='true'/>
22:09:23:  <log-to-screen v='true'/>
22:09:23:  <log-truncate v='false'/>
22:09:23:  <verbosity v='5'/>
22:09:23:
22:09:23:  <!-- Network -->
22:09:23:  <proxy v=':8080'/>
22:09:23:  <proxy-enable v='false'/>
22:09:23:  <proxy-pass v=''/>
22:09:23:  <proxy-user v=''/>
22:09:23:
22:09:23:  <!-- Process Control -->
22:09:23:  <child v='false'/>
22:09:23:  <daemon v='false'/>
22:09:23:  <pid v='false'/>
22:09:23:  <pid-file v='Folding@home Client.pid'/>
22:09:23:  <respawn v='false'/>
22:09:23:  <service v='false'/>
22:09:23:
22:09:23:  <!-- Remote Command Server -->
22:09:23:  <command-address v='0.0.0.0'/>
22:09:23:  <command-allow-no-pass v='127.0.0.1'/>
22:09:23:  <command-deny-no-pass v='0/0'/>
22:09:23:  <command-enable v='true'/>
22:09:23:  <command-port v='36330'/>
22:09:23:
22:09:23:  <!-- Slot Control -->
22:09:23:  <idle v='false'/>
22:09:23:  <max-shutdown-wait v='60'/>
22:09:23:  <pause-on-battery v='false'/>
22:09:23:  <pause-on-start v='false'/>
22:09:23:  <power v='full'/>
22:09:23:
22:09:23:  <!-- User Information -->
22:09:23:  <machine-id v='0'/>
22:09:23:  <passkey v='********************************'/>
22:09:23:  <team v='32'/>
22:09:23:  <user v='kf6fvv'/>
22:09:23:
22:09:23:  <!-- Web Server -->
22:09:23:  <web-allow v='127.0.0.1'/>
22:09:23:  <web-deny v='0/0'/>
22:09:23:  <web-enable v='true'/>
22:09:23:
22:09:23:  <!-- Web Server Sessions -->
22:09:23:  <session-cookie v='sid'/>
22:09:23:  <session-lifetime v='86400'/>
22:09:23:  <session-timeout v='3600'/>
22:09:23:
22:09:23:  <!-- Work Unit Control -->
22:09:23:  <dump-after-deadline v='true'/>
22:09:23:  <max-queue v='16'/>
22:09:23:  <max-units v='0'/>
22:09:23:  <next-unit-percentage v='99'/>
22:09:23:  <stall-detection-enabled v='false'/>
22:09:23:  <stall-percent v='5'/>
22:09:23:  <stall-timeout v='1800'/>
22:09:23:
22:09:23:  <!-- Folding Slots -->
22:09:23:  <slot id='0' type='CPU'>
22:09:23:    <client-type v='advanced'/>
22:09:23:    <max-packet-size v='big'/>
22:09:23:  </slot>
22:09:23:  <slot id='1' type='GPU'>
22:09:23:  </slot>
22:09:23:</config>
22:09:23:Trying to access database...
22:09:23:Successfully acquired database lock
22:09:23:FS00:Set client configured
22:09:23:Enabled folding slot 00: READY cpu:5
22:09:23:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 670]
22:09:23:Started thread 4 on PID 8824
22:09:23:Started thread 7 on PID 8824
22:09:23:Started thread 9 on PID 8824
22:09:23:Started thread 5 on PID 8824
22:09:23:Started thread 8 on PID 8824
22:09:23:Started thread 6 on PID 8824
22:09:24:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:09:24:WU01:FS01:Connecting to assign3.stanford.edu:8080
22:09:24:WARNING:WU00:FS00:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:09:24:WU00:FS00:Connecting to assign4.stanford.edu:80
22:09:24:WARNING:WU01:FS01:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:09:24:WU01:FS01:Connecting to assign4.stanford.edu:80
22:09:24:1:127.0.0.1 GET /ping?_=1393106964402&callback=jQuery19005119601501404998_1393106964401
22:09:25:2:127.0.0.1 GET /?nocache=0.7767084431648503
22:09:26:3:127.0.0.1 GET /api/updates/set?_=1393106965673&sid=03046a7300cb4dff3b955c2eca624781&update_id=0&update_path=/api/basic&update_rate=1
22:09:26:4:127.0.0.1 GET /api/updates/set?_=1393106965674&sid=03046a7300cb4dff3b955c2eca624781&update_id=1&update_path=/api/slots&update_rate=1
22:09:26:5:127.0.0.1 GET /api/configured?_=1393106965675&sid=03046a7300cb4dff3b955c2eca624781
22:09:27:WARNING:WU00:FS00:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:09:27:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:09:27:6:127.0.0.1 GET /?nocache=0.7767084431648503
22:09:27:7:127.0.0.1 GET /api/updates?_=1393106965676&sid=03046a7300cb4dff3b955c2eca624781
22:09:27:WARNING:WU01:FS01:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:09:27:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:09:27:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:09:27:WU01:FS01:Connecting to assign3.stanford.edu:8080
22:09:27:WARNING:WU00:FS00:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:09:27:WU00:FS00:Connecting to assign4.stanford.edu:80
22:09:27:WARNING:WU01:FS01:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:09:27:WU01:FS01:Connecting to assign4.stanford.edu:80
22:09:27:8:127.0.0.1 GET /css/normalize.css
22:09:27:9:127.0.0.1 GET /css/main.css
22:09:28:10:127.0.0.1 GET /js/jquery-1.10.2.min.js
22:09:28:11:127.0.0.1 GET /js/libs/jquery.selectbox-0.2.js
22:09:28:12:127.0.0.1 GET /js/intercom.min.js
22:09:28:13:127.0.0.1 GET /js/main.js
22:09:28:13:127.0.0.1:New Web connection
22:09:28:14:127.0.0.1 GET /images/report-bug.png
22:09:28:15:127.0.0.1 GET /images/template/bg.jpg
22:09:29:17:127.0.0.1 GET /images/template/input_radio.png
22:09:29:18:127.0.0.1 GET /images/template/button_bg.png
22:09:29:19:127.0.0.1 GET /images/template/logo_folding_home.png
22:09:29:20:127.0.0.1 GET /images/template/share_sprite.png
22:09:29:WARNING:WU00:FS00:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:09:29:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:09:29:WARNING:WU01:FS01:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:09:29:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:09:35:21:127.0.0.1 GET /api/updates/set?_=1393106968883&sid=d46b07a3a455bde96eade44de3a4da20&update_id=0&update_path=/api/basic&update_rate=1
22:09:35:22:127.0.0.1 GET /api/updates/set?_=1393106968884&sid=d46b07a3a455bde96eade44de3a4da20&update_id=1&update_path=/api/slots&update_rate=1
22:09:35:23:127.0.0.1 GET /api/configured?_=1393106968885&sid=d46b07a3a455bde96eade44de3a4da20
22:09:35:24:127.0.0.1 GET /images/template/ui-progress-bg.png
22:09:35:25:127.0.0.1 GET /images/template/ui-icon-slider.png
22:09:35:26:127.0.0.1 GET /images/template/ui-bg-slider.png
22:09:36:27:127.0.0.1 GET /images/template/select-icons.png
22:09:36:28:127.0.0.1 GET /api/updates?_=1393106968886&sid=d46b07a3a455bde96eade44de3a4da20
22:09:37:28:127.0.0.1 GET /api/updates?_=1393106968889&sid=d46b07a3a455bde96eade44de3a4da20
22:09:39:29:127.0.0.1 GET /api/updates?_=1393106968890&sid=d46b07a3a455bde96eade44de3a4da20
22:09:41:29:127.0.0.1 GET /api/updates?_=1393106968891&sid=d46b07a3a455bde96eade44de3a4da20
22:09:43:29:127.0.0.1 GET /api/updates?_=1393106968892&sid=d46b07a3a455bde96eade44de3a4da20
22:09:45:29:127.0.0.1 GET /api/updates?_=1393106968893&sid=d46b07a3a455bde96eade44de3a4da20
22:09:47:28:127.0.0.1 GET /api/updates?_=1393106968894&sid=d46b07a3a455bde96eade44de3a4da20
22:09:49:29:127.0.0.1 GET /api/updates?_=1393106968895&sid=d46b07a3a455bde96eade44de3a4da20
22:09:51:29:127.0.0.1 GET /api/updates?_=1393106968896&sid=d46b07a3a455bde96eade44de3a4da20
22:09:53:29:127.0.0.1 GET /api/updates?_=1393106968897&sid=d46b07a3a455bde96eade44de3a4da20
22:09:55:29:127.0.0.1 GET /api/updates?_=1393106968898&sid=d46b07a3a455bde96eade44de3a4da20
22:09:56:29:127.0.0.1 GET /api/updates?_=1393106968899&sid=d46b07a3a455bde96eade44de3a4da20
22:09:58:28:127.0.0.1 GET /api/updates?_=1393106968900&sid=d46b07a3a455bde96eade44de3a4da20
22:10:00:28:127.0.0.1 GET /api/updates?_=1393106968901&sid=d46b07a3a455bde96eade44de3a4da20
22:10:01:28:127.0.0.1 GET /api/updates?_=1393106968902&sid=d46b07a3a455bde96eade44de3a4da20
22:10:03:28:127.0.0.1 GET /api/updates?_=1393106968903&sid=d46b07a3a455bde96eade44de3a4da20
22:10:05:29:127.0.0.1 GET /api/updates?_=1393106968904&sid=d46b07a3a455bde96eade44de3a4da20
22:10:07:29:127.0.0.1 GET /api/updates?_=1393106968905&sid=d46b07a3a455bde96eade44de3a4da20
22:10:08:29:127.0.0.1 GET /api/start/control?_=1393106968906&sid=d46b07a3a455bde96eade44de3a4da20
22:10:09:30:127.0.0.1 GET /api/updates?_=1393106968907&sid=d46b07a3a455bde96eade44de3a4da20
22:10:10:Started thread 10 on PID 8824
22:10:11:30:127.0.0.1 GET /api/updates?_=1393106968908&sid=d46b07a3a455bde96eade44de3a4da20
22:10:12:30:127.0.0.1 GET /api/updates?_=1393106968909&sid=d46b07a3a455bde96eade44de3a4da20
22:10:14:30:127.0.0.1 GET /api/updates?_=1393106968910&sid=d46b07a3a455bde96eade44de3a4da20
22:10:15:30:127.0.0.1 GET /api/updates?_=1393106968911&sid=d46b07a3a455bde96eade44de3a4da20
22:10:17:28:127.0.0.1 GET /api/updates?_=1393106968912&sid=d46b07a3a455bde96eade44de3a4da20
22:10:19:30:127.0.0.1 GET /api/updates?_=1393106968913&sid=d46b07a3a455bde96eade44de3a4da20
22:10:21:30:127.0.0.1 GET /api/updates?_=1393106968914&sid=d46b07a3a455bde96eade44de3a4da20
22:10:22:30:127.0.0.1 GET /api/updates?_=1393106968915&sid=d46b07a3a455bde96eade44de3a4da20
22:10:25:28:127.0.0.1 GET /api/updates?_=1393106968916&sid=d46b07a3a455bde96eade44de3a4da20
22:10:27:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:10:27:WARNING:WU00:FS00:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:10:27:WU00:FS00:Connecting to assign4.stanford.edu:80
22:10:27:WU01:FS01:Connecting to assign3.stanford.edu:8080
22:10:27:WARNING:WU01:FS01:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:10:27:WU01:FS01:Connecting to assign4.stanford.edu:80
22:10:27:28:127.0.0.1 GET /api/updates?_=1393106968917&sid=d46b07a3a455bde96eade44de3a4da20
22:10:28:30:127.0.0.1 GET /api/updates?_=1393106968918&sid=d46b07a3a455bde96eade44de3a4da20
22:10:29:WARNING:WU00:FS00:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:10:29:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:10:30:WARNING:WU01:FS01:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:10:30:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:10:30:28:127.0.0.1 GET /api/updates?_=1393106968919&sid=d46b07a3a455bde96eade44de3a4da20
22:10:32:30:127.0.0.1 GET /api/updates?_=1393106968920&sid=d46b07a3a455bde96eade44de3a4da20
22:10:34:28:127.0.0.1 GET /api/updates?_=1393106968921&sid=d46b07a3a455bde96eade44de3a4da20
22:10:36:28:127.0.0.1 GET /api/updates?_=1393106968922&sid=d46b07a3a455bde96eade44de3a4da20
22:10:38:28:127.0.0.1 GET /api/updates?_=1393106968923&sid=d46b07a3a455bde96eade44de3a4da20
22:10:40:28:127.0.0.1 GET /api/updates?_=1393106968924&sid=d46b07a3a455bde96eade44de3a4da20
22:10:42:28:127.0.0.1 GET /api/updates?_=1393106968925&sid=d46b07a3a455bde96eade44de3a4da20
22:10:43:30:127.0.0.1 GET /api/updates?_=1393106968926&sid=d46b07a3a455bde96eade44de3a4da20
22:10:44:30:127.0.0.1 GET /api/updates?_=1393106968927&sid=d46b07a3a455bde96eade44de3a4da20
22:10:45:28:127.0.0.1 GET /api/updates?_=1393106968928&sid=d46b07a3a455bde96eade44de3a4da20
22:10:47:30:127.0.0.1 GET /api/updates?_=1393106968929&sid=d46b07a3a455bde96eade44de3a4da20
22:10:48:28:127.0.0.1 GET /api/updates?_=1393106968930&sid=d46b07a3a455bde96eade44de3a4da20
22:10:50:30:127.0.0.1 GET /api/updates?_=1393106968931&sid=d46b07a3a455bde96eade44de3a4da20
22:10:52:28:127.0.0.1 GET /api/updates?_=1393106968932&sid=d46b07a3a455bde96eade44de3a4da20
22:10:54:28:127.0.0.1 GET /api/updates?_=1393106968933&sid=d46b07a3a455bde96eade44de3a4da20
22:10:56:28:127.0.0.1 GET /api/updates?_=1393106968934&sid=d46b07a3a455bde96eade44de3a4da20
22:10:58:28:127.0.0.1 GET /api/updates?_=1393106968935&sid=d46b07a3a455bde96eade44de3a4da20
22:11:00:28:127.0.0.1 GET /api/updates?_=1393106968936&sid=d46b07a3a455bde96eade44de3a4da20
22:11:02:28:127.0.0.1 GET /api/updates?_=1393106968937&sid=d46b07a3a455bde96eade44de3a4da20
22:11:04:28:127.0.0.1 GET /api/updates?_=1393106968938&sid=d46b07a3a455bde96eade44de3a4da20
22:11:06:28:127.0.0.1 GET /api/updates?_=1393106968939&sid=d46b07a3a455bde96eade44de3a4da20
22:11:08:28:127.0.0.1 GET /api/updates?_=1393106968940&sid=d46b07a3a455bde96eade44de3a4da20
22:11:09:30:127.0.0.1 GET /api/updates?_=1393106968941&sid=d46b07a3a455bde96eade44de3a4da20
22:11:11:28:127.0.0.1 GET /api/updates?_=1393106968942&sid=d46b07a3a455bde96eade44de3a4da20
22:11:13:30:127.0.0.1 GET /api/updates?_=1393106968943&sid=d46b07a3a455bde96eade44de3a4da20
22:11:15:28:127.0.0.1 GET /api/updates?_=1393106968944&sid=d46b07a3a455bde96eade44de3a4da20
22:11:17:28:127.0.0.1 GET /api/updates?_=1393106968945&sid=d46b07a3a455bde96eade44de3a4da20
22:11:19:28:127.0.0.1 GET /api/updates?_=1393106968946&sid=d46b07a3a455bde96eade44de3a4da20
22:11:21:28:127.0.0.1 GET /api/updates?_=1393106968947&sid=d46b07a3a455bde96eade44de3a4da20
22:11:23:28:127.0.0.1 GET /api/updates?_=1393106968948&sid=d46b07a3a455bde96eade44de3a4da20
22:11:25:28:127.0.0.1 GET /api/updates?_=1393106968949&sid=d46b07a3a455bde96eade44de3a4da20
22:11:27:28:127.0.0.1 GET /api/updates?_=1393106968950&sid=d46b07a3a455bde96eade44de3a4da20
22:11:29:28:127.0.0.1 GET /api/updates?_=1393106968951&sid=d46b07a3a455bde96eade44de3a4da20
22:11:31:28:127.0.0.1 GET /api/updates?_=1393106968952&sid=d46b07a3a455bde96eade44de3a4da20
22:11:33:28:127.0.0.1 GET /api/updates?_=1393106968953&sid=d46b07a3a455bde96eade44de3a4da20
22:11:35:28:127.0.0.1 GET /api/updates?_=1393106968954&sid=d46b07a3a455bde96eade44de3a4da20
22:11:36:28:127.0.0.1 GET /api/updates?_=1393106968955&sid=d46b07a3a455bde96eade44de3a4da20
22:11:37:28:127.0.0.1 GET /api/updates?_=1393106968956&sid=d46b07a3a455bde96eade44de3a4da20
22:11:39:28:127.0.0.1 GET /api/updates?_=1393106968957&sid=d46b07a3a455bde96eade44de3a4da20
22:11:40:30:127.0.0.1 GET /api/updates?_=1393106968958&sid=d46b07a3a455bde96eade44de3a4da20
22:11:42:28:127.0.0.1 GET /api/updates?_=1393106968959&sid=d46b07a3a455bde96eade44de3a4da20
22:11:43:30:127.0.0.1 GET /api/updates?_=1393106968960&sid=d46b07a3a455bde96eade44de3a4da20
22:11:45:28:127.0.0.1 GET /api/updates?_=1393106968961&sid=d46b07a3a455bde96eade44de3a4da20
22:11:47:30:127.0.0.1 GET /api/updates?_=1393106968962&sid=d46b07a3a455bde96eade44de3a4da20
22:11:48:28:127.0.0.1 GET /api/updates?_=1393106968963&sid=d46b07a3a455bde96eade44de3a4da20
22:11:50:30:127.0.0.1 GET /api/updates?_=1393106968964&sid=d46b07a3a455bde96eade44de3a4da20
22:11:53:28:127.0.0.1 GET /api/updates?_=1393106968965&sid=d46b07a3a455bde96eade44de3a4da20
22:11:55:30:127.0.0.1 GET /api/updates?_=1393106968966&sid=d46b07a3a455bde96eade44de3a4da20
22:11:58:28:127.0.0.1 GET /api/updates?_=1393106968967&sid=d46b07a3a455bde96eade44de3a4da20
22:12:00:30:127.0.0.1 GET /api/updates?_=1393106968968&sid=d46b07a3a455bde96eade44de3a4da20
22:12:03:28:127.0.0.1 GET /api/updates?_=1393106968969&sid=d46b07a3a455bde96eade44de3a4da20
22:12:04:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:12:04:WARNING:WU00:FS00:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:12:04:WU00:FS00:Connecting to assign4.stanford.edu:80
22:12:05:WU01:FS01:Connecting to assign3.stanford.edu:8080
22:12:05:WARNING:WU01:FS01:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:12:05:WU01:FS01:Connecting to assign4.stanford.edu:80
22:12:05:30:127.0.0.1 GET /api/updates?_=1393106968970&sid=d46b07a3a455bde96eade44de3a4da20
22:12:07:WARNING:WU00:FS00:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:12:07:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:12:07:WARNING:WU01:FS01:Failed to get ID from 'assign4.stanford.edu:80': 10002: Received short response, expected 8 bytes, got 0
22:12:07:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:12:08:28:127.0.0.1 GET /api/updates?_=1393106968971&sid=d46b07a3a455bde96eade44de3a4da20
22:12:10:30:127.0.0.1 GET /api/updates?_=1393106968972&sid=d46b07a3a455bde96eade44de3a4da20
22:12:13:28:127.0.0.1 GET /api/updates?_=1393106968973&sid=d46b07a3a455bde96eade44de3a4da20
22:12:15:30:127.0.0.1 GET /api/updates?_=1393106968974&sid=d46b07a3a455bde96eade44de3a4da20
22:12:18:28:127.0.0.1 GET /api/updates?_=1393106968975&sid=d46b07a3a455bde96eade44de3a4da20
22:12:20:30:127.0.0.1 GET /api/updates?_=1393106968976&sid=d46b07a3a455bde96eade44de3a4da20
22:12:22:28:127.0.0.1 GET /api/updates?_=1393106968977&sid=d46b07a3a455bde96eade44de3a4da20
22:12:24:28:127.0.0.1 GET /api/updates?_=1393106968978&sid=d46b07a3a455bde96eade44de3a4da20
22:12:25:28:127.0.0.1 GET /api/updates?_=1393106968979&sid=d46b07a3a455bde96eade44de3a4da20
22:12:26:28:127.0.0.1 GET /api/updates?_=1393106968980&sid=d46b07a3a455bde96eade44de3a4da20
22:12:28:28:127.0.0.1 GET /api/updates?_=1393106968981&sid=d46b07a3a455bde96eade44de3a4da20
22:12:29:28:127.0.0.1 GET /api/updates?_=1393106968982&sid=d46b07a3a455bde96eade44de3a4da20
22:12:31:28:127.0.0.1 GET /api/updates?_=1393106968983&sid=d46b07a3a455bde96eade44de3a4da20
22:12:32:30:127.0.0.1 GET /api/updates?_=1393106968984&sid=d46b07a3a455bde96eade44de3a4da20
22:12:34:30:127.0.0.1 GET /api/updates?_=1393106968985&sid=d46b07a3a455bde96eade44de3a4da20
22:12:36:28:127.0.0.1 GET /api/updates?_=1393106968986&sid=d46b07a3a455bde96eade44de3a4da20
22:12:37:30:127.0.0.1 GET /api/updates?_=1393106968987&sid=d46b07a3a455bde96eade44de3a4da20
22:12:39:28:127.0.0.1 GET /api/updates?_=1393106968988&sid=d46b07a3a455bde96eade44de3a4da20
22:12:41:30:127.0.0.1 GET /api/updates?_=1393106968989&sid=d46b07a3a455bde96eade44de3a4da20
22:12:42:30:127.0.0.1 GET /api/updates?_=1393106968990&sid=d46b07a3a455bde96eade44de3a4da20
22:12:43:30:127.0.0.1 GET /api/updates?_=1393106968991&sid=d46b07a3a455bde96eade44de3a4da20
22:12:44:30:127.0.0.1 GET /api/updates?_=1393106968992&sid=d46b07a3a455bde96eade44de3a4da20
22:12:46:28:127.0.0.1 GET /api/updates?_=1393106968993&sid=d46b07a3a455bde96eade44de3a4da20
22:12:48:30:127.0.0.1 GET /api/updates?_=1393106968994&sid=d46b07a3a455bde96eade44de3a4da20
22:12:50:30:127.0.0.1 GET /api/updates?_=1393106968995&sid=d46b07a3a455bde96eade44de3a4da20
22:12:52:30:127.0.0.1 GET /api/updates?_=1393106968996&sid=d46b07a3a455bde96eade44de3a4da20
22:12:54:30:127.0.0.1 GET /api/updates?_=1393106968997&sid=d46b07a3a455bde96eade44de3a4da20
22:12:55:30:127.0.0.1 GET /api/updates?_=1393106968998&sid=d46b07a3a455bde96eade44de3a4da20
22:12:57:28:127.0.0.1 GET /api/updates?_=1393106968999&sid=d46b07a3a455bde96eade44de3a4da20
22:13:00:28:127.0.0.1 GET /api/updates?_=1393106969000&sid=d46b07a3a455bde96eade44de3a4da20
22:13:02:30:127.0.0.1 GET /api/updates?_=1393106969001&sid=d46b07a3a455bde96eade44de3a4da20
22:13:03:28:127.0.0.1 GET /api/updates?_=1393106969002&sid=d46b07a3a455bde96eade44de3a4da20
22:13:05:30:127.0.0.1 GET /api/updates?_=1393106969003&sid=d46b07a3a455bde96eade44de3a4da20
22:13:07:28:127.0.0.1 GET /api/updates?_=1393106969004&sid=d46b07a3a455bde96eade44de3a4da20
Anyone have an idea of what I might try? I usually fold all winter then stop when the weather warms up here and I hate seeing the computer just sit here doing nothing. :)
Re: Unable to get assigned a new work order
Could you please lower the verbosity level to 3 (the default) since with verbosity level 5, it prints all values which makes it very difficult to see what values were changed. With verbosity level 3, only the values changed from the default settings are printed so it makes it very easy to troubleshoot.
What happens when you enter http://assign3.stanford.edu:8080/ into your browser? A white page with OK should show up (it does on my system). Also, have you configured the Firewalls and/or Anti-malware/spyware/adware applications to allow F@H to communicate to the servers? A recent update in any of the security applications could cause an issue so you may want to recheck it.
KF6FVV
Post by KF6FVV »
When I try to go to the assign3 webpage, I get some kind of airOS login screen. on port 80 I get an OK but 8080 gets the login prompt.
I've always run with the firewall off but after disabling avast I did get a change in the error. Now I get the " No connection could be made because the target machine actively refused it." so maybe we're heading the right direction.
Here's the log without all the other data in it. Sorry, I figured that more was better. :)
*********************** Log Started 2014-02-22T22:55:05Z ***********************
22:55:05:************************* Folding@home Client *************************
22:55:05:      Website: http://folding.stanford.edu/
22:55:05:    Copyright: (c) 2009-2014 Stanford University
22:55:05:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:55:05:         Args: --open-web-control
22:55:05:       Config: C:/Users/Eric/AppData/Roaming/FAHClient/config.xml
22:55:05:******************************** Build ********************************
22:55:05:      Version: 7.4.2
22:55:05:         Date: Jan 24 2014
22:55:05:         Time: 13:51:17
22:55:05:      SVN Rev: 4112
22:55:05:       Branch: fah/trunk/client
22:55:05:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
22:55:05:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
22:55:05:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
22:55:05:     Platform: win32 XP
22:55:05:         Bits: 32
22:55:05:         Mode: Release
22:55:05:******************************* System ********************************
22:55:05:          CPU: AMD Phenom(tm) II X6 1090T Processor
22:55:05:       CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
22:55:05:         CPUs: 6
22:55:05:       Memory: 15.99GiB
22:55:05:  Free Memory: 11.98GiB
22:55:05:      Threads: WINDOWS_THREADS
22:55:05:   OS Version: 6.1
22:55:05:  Has Battery: false
22:55:05:   On Battery: false
22:55:05:   UTC Offset: -8
22:55:05:          PID: 4984
22:55:05:          CWD: C:/Users/Eric/AppData/Roaming/FAHClient
22:55:05:           OS: Windows 7 Ultimate
22:55:05:      OS Arch: AMD64
22:55:05:         GPUs: 1
22:55:05:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 670]
22:55:05:         CUDA: 3.0
22:55:05:  CUDA Driver: 5050
22:55:05:Win32 Service: false
22:55:05:***********************************************************************
22:55:05:<config>
22:55:05:  <!-- Folding Core -->
22:55:05:  <checkpoint v='10'/>
22:55:05:  <core-priority v='low'/>
22:55:05:
22:55:05:  <!-- Network -->
22:55:05:  <proxy v=':8080'/>
22:55:05:
22:55:05:  <!-- Slot Control -->
22:55:05:  <pause-on-battery v='false'/>
22:55:05:  <power v='full'/>
22:55:05:
22:55:05:  <!-- User Information -->
22:55:05:  <passkey v='********************************'/>
22:55:05:  <team v='32'/>
22:55:05:  <user v='kf6fvv'/>
22:55:05:
22:55:05:  <!-- Folding Slots -->
22:55:05:  <slot id='0' type='CPU'>
22:55:05:    <client-type v='advanced'/>
22:55:05:    <max-packet-size v='big'/>
22:55:05:  </slot>
22:55:05:  <slot id='1' type='GPU'>
22:55:05:  </slot>
22:55:05:</config>
22:55:05:Trying to access database...
22:55:05:Successfully acquired database lock
22:55:05:Enabled folding slot 00: READY cpu:5
22:55:05:Enabled folding slot 01: READY gpu:0:GK104 [GeForce GTX 670]
22:55:05:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:55:05:WU01:FS01:Connecting to assign3.stanford.edu:8080
22:55:05:WARNING:WU00:FS00:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:55:05:WU00:FS00:Connecting to assign4.stanford.edu:80
22:55:05:WARNING:WU01:FS01:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:55:05:WU01:FS01:Connecting to assign4.stanford.edu:80
22:55:06:WARNING:WU01:FS01:Failed to get ID from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
22:55:06:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:55:07:WARNING:WU00:FS00:Failed to get ID from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
22:55:07:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:55:07:WU01:FS01:Connecting to assign3.stanford.edu:8080
22:55:07:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:55:07:WARNING:WU01:FS01:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:55:07:WU01:FS01:Connecting to assign4.stanford.edu:80
22:55:07:WARNING:WU00:FS00:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:55:07:WU00:FS00:Connecting to assign4.stanford.edu:80
22:55:08:WARNING:WU00:FS00:Failed to get ID from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
22:55:08:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:55:08:WARNING:WU01:FS01:Failed to get ID from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
22:55:08:ERROR:WU01:FS01:Exception: Could not get an assignment ID
22:55:09:13:127.0.0.1:New Web connection
22:56:07:WU00:FS00:Connecting to assign3.stanford.edu:8080
22:56:07:WARNING:WU00:FS00:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:56:07:WU00:FS00:Connecting to assign4.stanford.edu:80
22:56:07:WU01:FS01:Connecting to assign3.stanford.edu:8080
22:56:07:WARNING:WU01:FS01:Failed to get ID from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_FOUND
22:56:07:WU01:FS01:Connecting to assign4.stanford.edu:80
22:56:08:WARNING:WU00:FS00:Failed to get ID from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
22:56:08:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:56:08:WARNING:WU01:FS01:Failed to get ID from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
22:56:08:ERROR:WU01:FS01:Exception: Could not get an assignment ID
KF6FVV
Post by KF6FVV »
Could be something our ISP did recently... My wife tried the same assign3.stanford.edu page while tethered through her phone and she gets the OK on port 8080.
Ripshod
Post by Ripshod »
Open a command prompt and enter: ipconfig /flushdns
If that doesn't fix it reboot your router?
1090T / HD5770 / HD7950
KF6FVV
Post by KF6FVV »
Re-booting the router and flushing the DNS didn't work but I was able to re-route through a public proxy and get things working that way. Its a little slow but won't effect things that much.
Thanks for the suggestions but I'm betting my ISP did it to me since there was no changes made here locally that I know of. This will get me by while I wait for them to get things fixed.
Windows auto updates unless you turn it off, same with many AV programs. The next update of any of those could suddenly start interfering with FAH. Apps suddenly start running in sandbox mode and can't connect. Not often, but it happens. Even home networking hardware updates itself now.
Reinstalling fah is rarely the fix because it's rarely the problem, so no need to waste time doing that. ;)
Grandpa_01
Post by Grandpa_01 »
I am not sure would say that, from personal experiance if a reboot of the computer does not fix fah when I have a connection problem with v7 a complete removal and renstall then reboot will fix the problem. But that is just my personal experiance others may be diffrent.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
RLHay
Hardware configuration: Intel i5 650, 4GB RAM, Win 7 Pro 64-bit
Post by RLHay »
I've also been getting a similar response for several days now. I've tried excluding the Stanford addresses from my AV software with no luck.
I get a white screen with "OK" from http://assign3.stanford.edu/, but no connection from http://assign4.stanford.edu/ or http://assign3.stanford.edu:8080/
Here is the log after having restarted the system...
*********************** Log Started 2014-02-24T00:32:45Z ***********************
00:32:45:************************* Folding@home Client *************************
00:32:45:      Website: http://folding.stanford.edu/
00:32:45:    Copyright: (c) 2009-2014 Stanford University
00:32:45:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:32:45:         Args: --open-web-control
00:32:45:       Config: C:/Users/rob/AppData/Roaming/FAHClient/config.xml
00:32:45:******************************** Build ********************************
00:32:45:      Version: 7.4.2
00:32:45:         Date: Jan 24 2014
00:32:45:         Time: 13:51:17
00:32:45:      SVN Rev: 4112
00:32:45:       Branch: fah/trunk/client
00:32:45:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:32:45:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:32:45:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:32:45:     Platform: win32 XP
00:32:45:         Bits: 32
00:32:45:         Mode: Release
00:32:45:******************************* System ********************************
00:32:45:          CPU: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
00:32:45:       CPU ID: GenuineIntel Family 6 Model 37 Stepping 2
00:32:45:         CPUs: 4
00:32:45:       Memory: 3.80GiB
00:32:45:  Free Memory: 1.79GiB
00:32:45:      Threads: WINDOWS_THREADS
00:32:45:   OS Version: 6.1
00:32:45:  Has Battery: false
00:32:45:   On Battery: false
00:32:45:   UTC Offset: 13
00:32:45:          PID: 6964
00:32:45:          CWD: C:/Users/rob/AppData/Roaming/FAHClient
00:32:45:           OS: Windows 7 Professional
00:32:45:      OS Arch: AMD64
00:32:45:         GPUs: 0
00:32:45:         CUDA: Not detected
00:32:45:Win32 Service: false
00:32:45:***********************************************************************
00:32:45:<config>
00:32:45:  <!-- Folding Core -->
00:32:45:  <checkpoint v='30'/>
00:32:45:  <cpu-affinity v='true'/>
00:32:45:
00:32:45:  <!-- HTTP Server -->
00:32:45:  <allow v='0.0.0.0/0'/>
00:32:45:
00:32:45:  <!-- Network -->
00:32:45:  <proxy v=':8080'/>
00:32:45:
00:32:45:  <!-- Remote Command Server -->
00:32:45:  <command-allow-no-pass v='0.0.0.0/0'/>
00:32:45:
00:32:45:  <!-- Slot Control -->
00:32:45:  <power v='full'/>
00:32:45:
00:32:45:  <!-- User Information -->
00:32:45:  <passkey v='********************************'/>
00:32:45:  <user v='RLHay'/>
00:32:45:
00:32:45:  <!-- Folding Slots -->
00:32:45:  <slot id='0' type='CPU'/>
00:32:45:</config>
00:32:45:Trying to access database...
00:32:45:Successfully acquired database lock
00:32:45:Enabled folding slot 00: READY cpu:4
00:32:45:WU00:FS00:Connecting to assign3.stanford.edu:8080
00:32:54:13:127.0.0.1:New Web connection
00:33:09:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:33:09:WU00:FS00:Connecting to assign4.stanford.edu:80
00:33:11:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
00:33:11:ERROR:WU00:FS00:Exception: Could not get an assignment
00:33:11:WU00:FS00:Connecting to assign3.stanford.edu:8080
00:33:32:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:33:32:WU00:FS00:Connecting to assign4.stanford.edu:80
00:33:34:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
00:33:34:ERROR:WU00:FS00:Exception: Could not get an assignment
00:34:11:WU00:FS00:Connecting to assign3.stanford.edu:8080
00:34:32:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:34:32:WU00:FS00:Connecting to assign4.stanford.edu:80
00:34:34:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
00:34:34:ERROR:WU00:FS00:Exception: Could not get an assignment
00:35:48:WU00:FS00:Connecting to assign3.stanford.edu:8080
00:36:10:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
00:36:10:WU00:FS00:Connecting to assign4.stanford.edu:80
00:36:11:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
00:36:11:ERROR:WU00:FS00:Exception: Could not get an assignment
I get a white page with "OK" when visiting:
I am unable to connect to http://assign4.stanford.edu/
Have you tried rebooting the router? Did anything change on your end when the problem showed up, updated an application, installed a new one, etc?
PantherX wrote:I am unable to connect to http://assign4.stanford.edu/
Don't worry about assign4. It is a new server which is still being outfitted for future use. The latest versions of client have been prepared to support it whenever it's ready to be enabled but there's still work to be done on the back-end.
RLHay
Post by RLHay »
Changes to the system...
There was a bunch of Win7 updates around 3 days before the problem surfaced, but I did pick up work units after those were installed. NOD32 updates the virus definitions a couple of times a day, but I have tried both white listing Stanford sites and also disabling NOD32 with no success.
In a browser I still get OK from assign3 on 80 but an error from assign3 on 8080.
In FAH I'm still getting the same error as in the log above.
Very puzzling
BuiesCreek847
Post by BuiesCreek847 »
I believe some of my rigs are seeing the same thing;
(Typical)
*********************** Log Started 2014-02-24T12:44:36Z ***********************
12:44:36:************************* Folding@home Client *************************
12:44:36:      Website: http://folding.stanford.edu/
12:44:36:    Copyright: (c) 2009-2012 Stanford University
12:44:36:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:44:36:         Args:
12:44:36:       Config: C:/Documents and Settings/dlivesay/Application
12:44:36:               Data/FAHClient/config.xml
12:44:36:******************************** Build ********************************
12:44:36:      Version: 7.2.9
12:44:36:         Date: Oct 3 2012
12:44:36:         Time: 18:05:48
12:44:36:      SVN Rev: 3578
12:44:36:       Branch: fah/trunk/client
12:44:36:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:44:36:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:44:36:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
12:44:36:     Platform: win32 XP
12:44:36:         Bits: 32
12:44:36:         Mode: Release
12:44:36:******************************* System ********************************
12:44:36:          CPU: Intel(R) Pentium(R) CPU G850 @ 2.90GHz
12:44:36:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:44:36:         CPUs: 2
12:44:36:       Memory: 3.17GiB
12:44:36:  Free Memory: 2.75GiB
12:44:36:      Threads: WINDOWS_THREADS
12:44:36:   On Battery: false
12:44:36:   UTC offset: -5
12:44:36:          PID: 808
12:44:36:          CWD: C:/WINDOWS/system32
12:44:36:           OS: Microsoft Windows XP Service Pack 3
12:44:36:      OS Arch: X86
12:44:36:         GPUs: 0
12:44:36:         CUDA: Not detected
12:44:36:Win32 Service: true
12:44:36:***********************************************************************
12:44:36:<config>
12:44:36:  <service-description v='Folding@home Client'/>
12:44:36:  <service-restart v='true'/>
12:44:36:  <service-restart-delay v='5000'/>
12:44:36:
12:44:36:  <!-- Client Control -->
12:44:36:  <cycle-rate v='4'/>
12:44:36:  <cycles v='-1'/>
12:44:36:  <data-directory v='.'/>
12:44:36:  <disable-project-lookup v='false'/>
12:44:36:  <exec-directory v='C:\Program Files\FAHClient'/>
12:44:36:  <exit-when-done v='false'/>
12:44:36:  <threads v='4'/>
12:44:36:
12:44:36:  <!-- Configuration -->
12:44:36:  <config-rotate v='true'/>
12:44:36:  <config-rotate-dir v='configs'/>
12:44:36:  <config-rotate-max v='16'/>
12:44:36:
12:44:36:  <!-- Debugging -->
12:44:36:  <assignment-servers>
12:44:36:    assign3.stanford.edu:8080 assign4.stanford.edu:80
12:44:36:  </assignment-servers>
12:44:36:  <capture-directory v='capture'/>
12:44:36:  <capture-sockets v='false'/>
12:44:36:  <debug-sockets v='false'/>
12:44:36:  <exception-locations v='true'/>
12:44:36:  <gpu-assignment-servers>
12:44:36:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
12:44:36:  </gpu-assignment-servers>
12:44:36:  <stack-traces v='false'/>
12:44:36:
12:44:36:  <!-- Error Handling -->
12:44:36:  <max-slot-errors v='5'/>
12:44:36:  <max-unit-errors v='5'/>
12:44:36:
12:44:36:  <!-- FahCore Control -->
12:44:36:  <checkpoint v='15'/>
12:44:36:  <core-dir v='cores'/>
12:44:36:  <core-priority v='idle'/>
12:44:36:  <cpu-affinity v='false'/>
12:44:36:  <cpu-usage v='100'/>
12:44:36:  <no-assembly v='false'/>
12:44:36:
12:44:36:  <!-- Folding Slot Configuration -->
12:44:36:  <cause-pref v='ANY'/>
12:44:36:  <client-subtype v='STDCLI'/>
12:44:36:  <client-type v='normal'/>
12:44:36:  <cpu-species v='X86_PENTIUM_II'/>
12:44:36:  <cpu-type v='X86'/>
12:44:36:  <cpus v='-1'/>
12:44:36:  <cuda-index v='0'/>
12:44:36:  <gpu v='true'/>
12:44:36:  <gpu-usage v='100'/>
12:44:36:  <max-packet-size v='normal'/>
12:44:36:  <opencl-index v='0'/>
12:44:36:  <os-species v='WIN_XP'/>
12:44:36:  <os-type v='WIN32'/>
12:44:36:  <project-key v='0'/>
12:44:36:  <smp v='true'/>
12:44:36:
12:44:36:  <!-- Logging -->
12:44:36:  <log v='log.txt'/>
12:44:36:  <log-color v='false'/>
12:44:36:  <log-crlf v='true'/>
12:44:36:  <log-date v='false'/>
12:44:36:  <log-date-periodically v='21600'/>
12:44:36:  <log-debug v='true'/>
12:44:36:  <log-domain v='false'/>
12:44:36:  <log-header v='true'/>
12:44:36:  <log-level v='true'/>
12:44:36:  <log-no-info-header v='true'/>
12:44:36:  <log-redirect v='false'/>
12:44:36:  <log-rotate v='true'/>
12:44:36:  <log-rotate-dir v='logs'/>
12:44:36:  <log-rotate-max v='16'/>
12:44:36:  <log-short-level v='false'/>
12:44:36:  <log-simple-domains v='true'/>
12:44:36:  <log-thread-id v='false'/>
12:44:36:  <log-thread-prefix v='true'/>
12:44:36:  <log-time v='true'/>
12:44:36:  <log-to-screen v='true'/>
12:44:36:  <log-truncate v='false'/>
12:44:36:  <verbosity v='5'/>
12:44:36:
12:44:36:  <!-- Network -->
12:44:36:  <proxy v=':8080'/>
12:44:36:  <proxy-enable v='false'/>
12:44:36:  <proxy-pass v=''/>
12:44:36:  <proxy-user v=''/>
12:44:36:
12:44:36:  <!-- Process Control -->
12:44:36:  <child v='false'/>
12:44:36:  <daemon v='false'/>
12:44:36:  <pid v='false'/>
12:44:36:  <pid-file v='Folding@home Client.pid'/>
12:44:36:  <respawn v='false'/>
12:44:36:  <service v='true'/>
12:44:36:
12:44:36:  <!-- Remote Command Server -->
12:44:36:  <command-address v='0.0.0.0'/>
12:44:36:  <command-allow v='127.0.0.1'/>
12:44:36:  <command-allow-no-pass v='127.0.0.1'/>
12:44:36:  <command-deny v='0.0.0.0/0'/>
12:44:36:  <command-deny-no-pass v='0.0.0.0/0'/>
12:44:36:  <command-port v='36330'/>
12:44:36:
12:44:36:  <!-- Slot Control -->
12:44:36:  <max-shutdown-wait v='60'/>
12:44:36:  <pause-on-battery v='false'/>
12:44:36:  <pause-on-start v='false'/>
12:44:36:
12:44:36:  <!-- User Information -->
12:44:36:  <machine-id v='0'/>
12:44:36:  <passkey v='********************************'/>
12:44:36:  <team v='734'/>
12:44:36:  <user v='BuiesCreek847'/>
12:44:36:
12:44:36:  <!-- Work Unit Control -->
12:44:36:  <dump-after-deadline v='true'/>
12:44:36:  <max-queue v='16'/>
12:44:36:  <max-units v='0'/>
12:44:36:  <next-unit-percentage v='99'/>
12:44:36:
12:44:36:  <!-- Folding Slots -->
12:44:36:  <slot id='0' type='SMP'/>
12:44:36:</config>
12:44:36:Trying to access database...
12:44:36:Successfully acquired database lock
12:44:36:Enabled folding slot 00: READY smp:2
12:44:36:Started thread 3 on PID 808
12:44:36:Started thread 4 on PID 808
12:44:36:Started thread 6 on PID 808
12:44:36:Started thread 1 on PID 808
12:44:36:Started thread 5 on PID 808
12:44:36:WU00:FS00:Connecting to assign3.stanford.edu:8080
12:44:37:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
12:44:37:WU00:FS00:Connecting to assign4.stanford.edu:80
12:44:39:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
12:44:39:ERROR:WU00:FS00:Exception: Could not get an assignment
12:44:39:WU00:FS00:Connecting to assign3.stanford.edu:8080
12:44:40:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
12:44:40:WU00:FS00:Connecting to assign4.stanford.edu:80
12:44:41:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
12:44:41:ERROR:WU00:FS00:Exception: Could not get an assignment
12:45:39:WU00:FS00:Connecting to assign3.stanford.edu:8080
12:45:40:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
12:45:40:WU00:FS00:Connecting to assign4.stanford.edu:80
12:45:41:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
12:45:41:ERROR:WU00:FS00:Exception: Could not get an assignment
12:47:16:WU00:FS00:Connecting to assign3.stanford.edu:8080
12:47:17:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
12:47:17:WU00:FS00:Connecting to assign4.stanford.edu:80
12:47:18:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
12:47:18:ERROR:WU00:FS00:Exception: Could not get an assignment
12:49:53:WU00:FS00:Connecting to assign3.stanford.edu:8080
12:49:54:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
12:49:54:WU00:FS00:Connecting to assign4.stanford.edu:80
12:49:55:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
12:49:55:ERROR:WU00:FS00:Exception: Could not get an assignment
12:51:50:Started thread 7 on PID 808
12:51:50:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
12:54:07:WU00:FS00:Connecting to assign3.stanford.edu:8080
12:54:08:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
12:54:08:WU00:FS00:Connecting to assign4.stanford.edu:80
12:54:09:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
12:54:09:ERROR:WU00:FS00:Exception: Could not get an assignment
13:00:59:WU00:FS00:Connecting to assign3.stanford.edu:8080
13:01:02:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
13:01:02:WU00:FS00:Connecting to assign4.stanford.edu:80
13:01:03:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
13:01:03:ERROR:WU00:FS00:Exception: Could not get an assignment
13:12:04:WU00:FS00:Connecting to assign3.stanford.edu:8080
13:12:05:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
13:12:05:WU00:FS00:Connecting to assign4.stanford.edu:80
13:12:08:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
13:12:08:ERROR:WU00:FS00:Exception: Could not get an assignment
13:30:01:WU00:FS00:Connecting to assign3.stanford.edu:8080
13:30:04:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
13:30:04:WU00:FS00:Connecting to assign4.stanford.edu:80
13:30:05:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
13:30:05:ERROR:WU00:FS00:Exception: Could not get an assignment
13:59:03:WU00:FS00:Connecting to assign3.stanford.edu:8080
13:59:06:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
13:59:06:WU00:FS00:Connecting to assign4.stanford.edu:80
13:59:07:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
13:59:07:ERROR:WU00:FS00:Exception: Could not get an assignment
14:46:02:WU00:FS00:Connecting to assign3.stanford.edu:8080
14:46:06:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
14:46:06:WU00:FS00:Connecting to assign4.stanford.edu:80
14:46:09:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
14:46:09:ERROR:WU00:FS00:Exception: Could not get an assignment
16:02:03:WU00:FS00:Connecting to assign3.stanford.edu:8080
16:02:04:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
16:02:04:WU00:FS00:Connecting to assign4.stanford.edu:80
16:02:05:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
16:02:05:ERROR:WU00:FS00:Exception: Could not get an assignment
18:05:03:WU00:FS00:Connecting to assign3.stanford.edu:8080
18:05:04:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Failed to connect to assign3.stanford.edu:8080: No connection could be made because the target machine actively refused it.
18:05:04:WU00:FS00:Connecting to assign4.stanford.edu:80
18:05:09:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Failed to connect to assign4.stanford.edu:80: No connection could be made because the target machine actively refused it.
18:05:09:ERROR:WU00:FS00:Exception: Could not get an assignment
Welcome to the F@H Forum BuiesCreek847,
I can access http://assign3.stanford.edu:8080/ without any issue (white page with "OK" in black colour). Has anything recently changed on your system, an application updated, you installed a new software, etc? Have you rebooted the router?
NOD32 is well known to interfere with folding from time to time. Just search the forum for the many threads that mention it.
