Bad WU: Project: 9401 (214,0,14) and (1213,0,1)
folding_hoomer
Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300
Post by folding_hoomer »
Sys: i7 875K@3808MHz, GPU0: HD5870 (not folding), GPU1: HD7870@1200MHz (Log: called as HD5780), Win7 64Bit, Catalyst 14.1 BetaV1.6, GPU-Temp while folding: 58°C
Got an error while starting WU9401 (214, 0, 14) and - after downloading WU(1213,0,1) while finishing 38%
Initial Log and Config:
*********************** Log Started 2014-02-19T13:06:28Z ***********************
13:06:28:************************* Folding@home Client *************************
13:06:28:      Website: http://folding.stanford.edu/
13:06:28:    Copyright: (c) 2009-2013 Stanford University
13:06:28:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:06:28:         Args:
13:06:28:       Config: C:/Users/Markus/AppData/Roaming/FAHClient/config.xml
13:06:28:******************************** Build ********************************
13:06:28:      Version: 7.3.6
13:06:28:         Date: Feb 18 2013
13:06:28:         Time: 15:25:17
13:06:28:      SVN Rev: 3923
13:06:28:       Branch: fah/trunk/client
13:06:28:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
13:06:28:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
13:06:28:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
13:06:28:     Platform: win32 XP
13:06:28:         Bits: 32
13:06:28:         Mode: Release
13:06:28:******************************* System ********************************
13:06:28:          CPU: Intel(R) Core(TM) i7 CPU K 875 @ 2.93GHz
13:06:28:       CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
13:06:28:         CPUs: 8
13:06:28:       Memory: 7.99GiB
13:06:28:  Free Memory: 5.61GiB
13:06:28:      Threads: WINDOWS_THREADS
13:06:28:  Has Battery: false
13:06:28:   On Battery: false
13:06:28:   UTC offset: 1
13:06:28:          PID: 4472
13:06:28:          CWD: C:/Users/Markus/AppData/Roaming/FAHClient
13:06:28:           OS: Windows 7 Professional
13:06:28:      OS Arch: AMD64
13:06:28:         GPUs: 2
13:06:28:        GPU 0: ATI:5 PITCAIRN [Radeon HD 7800]
13:06:28:        GPU 1: ATI:4 Radeon HD 5870 (Cypress)
13:06:28:         CUDA: Not detected
13:06:28:Win32 Service: false
13:06:28:***********************************************************************
06:37:01:<config>
06:37:01:  <!-- Error Handling -->
06:37:01:  <max-slot-errors v='3'/>
06:37:01:  <max-unit-errors v='3'/>
06:37:01:
06:37:01:  <!-- Folding Core -->
06:37:01:  <core-priority v='low'/>
06:37:01:
06:37:01:  <!-- Folding Slot Configuration -->
06:37:01:  <power v='full'/>
06:37:01:
06:37:01:  <!-- HTTP Server -->
06:37:01:  <allow v='192.168.2.100-192.168.2.110  127.0.0.1'/>
06:37:01:
06:37:01:  <!-- Logging -->
06:37:01:  <log-rotate-max v='50'/>
06:37:01:
06:37:01:  <!-- Network -->
06:37:01:  <proxy v=':8080'/>
06:37:01:
06:37:01:  <!-- Remote Command Server -->
06:37:01:  <command-allow-no-pass v='192.168.2.100-192.168.2.110  127.0.0.1'/>
06:37:01:
06:37:01:  <!-- Slot Control -->
06:37:01:  <pause-on-battery v='false'/>
06:37:01:
06:37:01:  <!-- User Information -->
06:37:01:  <passkey v='********************************'/>
06:37:01:  <team v='70335'/>
06:37:01:  <user v='folding_hoomer'/>
06:37:01:
06:37:01:  <!-- Folding Slots -->
06:37:01:  <slot id='1' type='GPU'>
06:37:01:    <client-type v='internal'/>
06:37:01:    <cuda-index v='1'/>
06:37:01:    <next-unit-percentage v='100'/>
06:37:01:    <opencl-index v='1'/>
06:37:01:    <pause-on-start v='true'/>
06:37:01:    <project-key v='**********'/>
06:37:01:  </slot>
06:37:01:  <slot id='0' type='CPU'>
06:37:01:    <client-type v='beta'/>
06:37:01:    <cpus v='6'/>
06:37:01:  </slot>
06:37:01:  <slot id='2' type='GPU'>
06:37:01:    <cuda-index v='0'/>
06:37:01:    <opencl-index v='0'/>
06:37:01:  </slot>
06:37:01:</config>
Error Log:
08:21:30:WU00:FS02:0x17:Completed 1000000 out of 1000000 steps (100%)
08:21:31:WU01:FS02:Connecting to assign-GPU.stanford.edu:80
08:21:32:WU01:FS02:News: Welcome to Folding@Home
08:21:32:WU01:FS02:Assigned to work server 171.67.108.31
08:21:32:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Radeon HD 5870 (Cypress) from 171.67.108.31
08:21:32:WU01:FS02:Connecting to 171.67.108.31:8080
08:21:36:WU01:FS02:Downloading 3.76MiB
08:21:40:WU01:FS02:Download complete
08:21:40:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9401 run:214 clone:0 gen:14 core:0x17 unit:0x000000176652edaf52eae82c4f14ae03
08:21:56:WU01:FS02:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4472 -checkpoint 15 -gpu 0 -gpu-vendor ati
08:21:56:WU01:FS02:Started FahCore on PID 9920
08:21:56:WU01:FS02:Core PID:9044
08:21:56:WU01:FS02:FahCore 0x17 started
08:21:57:WU01:FS02:0x17:*********************** Log Started 2014-02-23T08:21:56Z ***********************
08:21:57:WU01:FS02:0x17:Project: 9401 (Run 214, Clone 0, Gen 14)
08:21:57:WU01:FS02:0x17:Unit: 0x000000176652edaf52eae82c4f14ae03
08:21:57:WU01:FS02:0x17:CPU: 0x00000000000000000000000000000000
08:21:57:WU01:FS02:0x17:Machine: 2
08:21:57:WU01:FS02:0x17:Reading tar file state.xml
08:21:57:WU01:FS02:0x17:Reading tar file system.xml
08:21:57:WU01:FS02:0x17:Reading tar file integrator.xml
08:21:57:WU01:FS02:0x17:Reading tar file core.xml
08:21:57:WU01:FS02:0x17:Digital signatures verified
08:22:04:WU00:FS02:Upload 3.87%
08:24:15:WU00:FS02:Upload 57.35%
08:24:20:WU01:FS02:0x17:ERROR:exception: Potential energy error of 38.2414, threshold of 10
08:24:20:WU01:FS02:0x17:ERROR:Reference Potential Energy: -650643 | Given Potential Energy: -650681
08:24:20:WU01:FS02:0x17:Saving result file logfile_01.txt
08:24:20:WU01:FS02:0x17:Saving result file badStateCheckpoint_41
08:24:21:WU01:FS02:0x17:Saving result file badStateForceGroup0_41Core.xml
08:24:23:WU01:FS02:0x17:Saving result file badStateForceGroup0_41Ref.xml
08:24:24:WU00:FS02:Upload 61.86%
08:24:26:WU01:FS02:0x17:Saving result file badStateForceGroup1_41Core.xml
08:24:28:WU01:FS02:0x17:Saving result file badStateForceGroup1_41Ref.xml
08:24:29:WU01:FS02:0x17:Saving result file badStateForceGroup2_41Core.xml
08:24:31:WU01:FS02:0x17:Saving result file badStateForceGroup2_41Ref.xml
08:24:32:WU00:FS02:Upload 65.08%
08:24:33:WU01:FS02:0x17:Saving result file log.txt
08:24:33:WU01:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
08:24:33:WARNING:WU01:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:24:33:WU01:FS02:Sending unit results: id:01 state:SEND error:FAULTY project:9401 run:214 clone:0 gen:14 core:0x17 unit:0x000000176652edaf52eae82c4f14ae03
08:24:33:WU01:FS02:Uploading 18.51MiB to 171.67.108.31
08:24:33:WU01:FS02:Connecting to 171.67.108.31:8080
08:24:33:WU02:FS02:Connecting to assign-GPU.stanford.edu:80
08:24:34:WU02:FS02:News: Welcome to Folding@Home
08:24:34:WU02:FS02:Assigned to work server 171.67.108.31
08:24:34:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:Radeon HD 5870 (Cypress) from 171.67.108.31
08:24:34:WU02:FS02:Connecting to 171.67.108.31:8080
08:24:38:WU02:FS02:Downloading 3.43MiB
08:24:42:WU02:FS02:Download complete
08:24:42:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9401 run:1213 clone:0 gen:1 core:0x17 unit:0x000000016652edaf52eb0b6a8f5b4ba2
08:24:42:WU02:FS02:Starting
08:24:42:WU02:FS02:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4472 -checkpoint 15 -gpu 0 -gpu-vendor ati
08:24:42:WU02:FS02:Started FahCore on PID 1408
08:24:43:WU02:FS02:Core PID:6304
08:24:43:WU02:FS02:FahCore 0x17 started
08:24:43:WU02:FS02:0x17:*********************** Log Started 2014-02-23T08:24:43Z ***********************
08:24:43:WU02:FS02:0x17:Project: 9401 (Run 1213, Clone 0, Gen 1)
08:24:43:WU02:FS02:0x17:Unit: 0x000000016652edaf52eb0b6a8f5b4ba2
08:24:43:WU02:FS02:0x17:CPU: 0x00000000000000000000000000000000
08:24:43:WU02:FS02:0x17:Machine: 2
08:24:43:WU02:FS02:0x17:Reading tar file state.xml
08:24:43:WU02:FS02:0x17:Reading tar file system.xml
08:24:44:WU02:FS02:0x17:Reading tar file integrator.xml
08:24:44:WU02:FS02:0x17:Reading tar file core.xml
08:24:44:WU02:FS02:0x17:Digital signatures verified
08:24:45:WU01:FS02:Upload 1.69%
08:24:46:WU00:FS02:Upload 67.66%
08:26:18:WU02:FS02:0x17:Completed 0 out of 5000000 steps (0%)
08:26:20:WU01:FS02:Upload 21.60%
08:26:22:WU00:FS02:Upload complete
08:26:22:WU00:FS02:Server responded WORK_ACK (400)
08:26:22:WU00:FS02:Final credit estimate, 17614.00 points
08:26:22:WU00:FS02:Cleaning up
08:26:32:WU01:FS02:Upload 24.64%
08:32:13:WU01:FS02:Upload 99.58%
08:32:18:WU01:FS02:Upload complete
08:32:18:WU01:FS02:Server responded WORK_ACK (400)
08:32:18:WU01:FS02:Cleaning up
08:34:03:WU02:FS02:0x17:Completed 50000 out of 5000000 steps (1%)
08:41:49:WU02:FS02:0x17:Completed 100000 out of 5000000 steps (2%)
08:49:36:WU02:FS02:0x17:Completed 150000 out of 5000000 steps (3%)
08:57:22:WU02:FS02:0x17:Completed 200000 out of 5000000 steps (4%)
09:05:09:WU02:FS02:0x17:Completed 250000 out of 5000000 steps (5%)
09:12:55:WU02:FS02:0x17:Completed 300000 out of 5000000 steps (6%)
09:20:42:WU02:FS02:0x17:Completed 350000 out of 5000000 steps (7%)
09:28:28:WU02:FS02:0x17:Completed 400000 out of 5000000 steps (8%)
09:36:15:WU02:FS02:0x17:Completed 450000 out of 5000000 steps (9%)
09:44:01:WU02:FS02:0x17:Completed 500000 out of 5000000 steps (10%)
09:51:48:WU02:FS02:0x17:Completed 550000 out of 5000000 steps (11%)
09:59:34:WU02:FS02:0x17:Completed 600000 out of 5000000 steps (12%)
10:07:21:WU02:FS02:0x17:Completed 650000 out of 5000000 steps (13%)
10:15:07:WU02:FS02:0x17:Completed 700000 out of 5000000 steps (14%)
10:22:54:WU02:FS02:0x17:Completed 750000 out of 5000000 steps (15%)
10:30:40:WU02:FS02:0x17:Completed 800000 out of 5000000 steps (16%)
10:38:27:WU02:FS02:0x17:Completed 850000 out of 5000000 steps (17%)
10:46:13:WU02:FS02:0x17:Completed 900000 out of 5000000 steps (18%)
10:54:00:WU02:FS02:0x17:Completed 950000 out of 5000000 steps (19%)
11:01:47:WU02:FS02:0x17:Completed 1000000 out of 5000000 steps (20%)
11:09:34:WU02:FS02:0x17:Completed 1050000 out of 5000000 steps (21%)
11:17:20:WU02:FS02:0x17:Completed 1100000 out of 5000000 steps (22%)
11:25:07:WU02:FS02:0x17:Completed 1150000 out of 5000000 steps (23%)
11:32:54:WU02:FS02:0x17:Completed 1200000 out of 5000000 steps (24%)
11:40:41:WU02:FS02:0x17:Completed 1250000 out of 5000000 steps (25%)
11:48:27:WU02:FS02:0x17:Completed 1300000 out of 5000000 steps (26%)
11:56:14:WU02:FS02:0x17:Completed 1350000 out of 5000000 steps (27%)
12:04:01:WU02:FS02:0x17:Completed 1400000 out of 5000000 steps (28%)
12:11:48:WU02:FS02:0x17:Completed 1450000 out of 5000000 steps (29%)
12:19:34:WU02:FS02:0x17:Completed 1500000 out of 5000000 steps (30%)
12:27:21:WU02:FS02:0x17:Completed 1550000 out of 5000000 steps (31%)
12:35:08:WU02:FS02:0x17:Completed 1600000 out of 5000000 steps (32%)
12:42:55:WU02:FS02:0x17:Completed 1650000 out of 5000000 steps (33%)
12:50:41:WU02:FS02:0x17:Completed 1700000 out of 5000000 steps (34%)
12:58:28:WU02:FS02:0x17:Completed 1750000 out of 5000000 steps (35%)
13:06:15:WU02:FS02:0x17:Completed 1800000 out of 5000000 steps (36%)
13:14:01:WU02:FS02:0x17:Completed 1850000 out of 5000000 steps (37%)
13:21:48:WU02:FS02:0x17:Completed 1900000 out of 5000000 steps (38%)
13:25:43:WU02:FS02:0x17:ERROR:exception: Error creating array interactingTiles: clCreateBuffer (-61)
13:25:43:WU02:FS02:0x17:Saving result file logfile_01.txt
13:25:43:WU02:FS02:0x17:Saving result file log.txt
13:25:43:WU02:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
13:25:44:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:25:44:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:9401 run:1213 clone:0 gen:1 core:0x17 unit:0x000000016652edaf52eb0b6a8f5b4ba2
13:25:44:WU02:FS02:Uploading 2.79KiB to 171.67.108.31
13:25:44:WU02:FS02:Connecting to 171.67.108.31:8080
13:25:44:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
13:25:44:WU02:FS02:Upload complete
13:25:45:WU02:FS02:Server responded WORK_ACK (400)
13:25:45:WU02:FS02:Cleaning up
bollix47
Re: Bad WU: Project: 9401 (214,0,14) and (1213,0,1)
Post by bollix47 »
Project: 9401 (Run 214, Clone 0, Gen 14) ... numerous failures:
The WU (P9401,R214,C0,G14) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
Partial credit:
Hi folding_hoomer (team 70335),
Your WU (P9401 R1213 C0 G1) was added to the stats database on 2014-02-23 06:03:26 for 4940 points of credit.
Your return is the only one so far in the database. Marked for followup.
folding_hoomer
Optional:
Thanks a lot for your fast reply, bollix47
Jim Saunders
Hardware configuration: A: i5 + 2 GTX 660
B: i5 + 2 GTX 670
C: i7 + GTX670
Post by Jim Saunders »
One thing I noticed is that the Windows updates from a week or two ago, applied to one computer out of four, have made it unable to run core 17 WUs where it could before. Core 15 WUs still run, and I've seen that the GPU is solid.
Jim
Good science and heat for my basement you say?
bollix47
Post by bollix47 »
I remember seeing that update on one of my systems (normally I tell windows update to hide that type of update but I didn't this time) and yes it did mess with the GPU drivers and caused some problems. I re-installed the appropriate drivers from the manufacturer's site and all was good after that.
I have had troubles with a variety of devices after I accepted drivers recommended by Windows Update. Typically, when Windows tells me that I need new drivers, I use that as a reminder to go to the manufacturer's site and download their latest non-beta driver for things like a mouse or network adapters. If it's a GPU, I also rely on the recommendations of FAH Donors that have been published here on foldingforum.org.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
General rule: Don't ever auto-update drivers!
If it isn't broken, then don't allow anyone to blindly fix it for the only outcome that produces change is to break it.
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Post by billford »
P5-133XL wrote:General rule: Don't ever auto-update drivers!
I prefer a slight variation on that:
Don't ever auto-update!
:wink:
bollix47
Post by bollix47 »
Another folder was able to complete the work unit successfully:
Hi xxxxx (team xxxxx),
Your WU (P9401 R1213 C0 G1) was added to the stats database on 2014-02-23 19:03:05 for 57928 points of credit.
Followup report closed.
