Config:
*********************** Log Started 2014-01-22T12:32:40Z ***********************
12:32:40:************************* Folding@home Client *************************
12:32:40: Website: http://folding.stanford.edu/
12:32:40: Copyright: (c) 2009-2013 Stanford University
12:32:40: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:32:40: Args:
12:32:40: Config: C:/Users/Markus/AppData/Roaming/FAHClient/config.xml
12:32:40:******************************** Build ********************************
12:32:40: Version: 7.3.6
12:32:40: Date: Feb 18 2013
12:32:40: Time: 15:25:17
12:32:40: SVN Rev: 3923
12:32:40: Branch: fah/trunk/client
12:32:40: Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:32:40: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:32:40: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
12:32:40: Platform: win32 XP
12:32:40: Bits: 32
12:32:40: Mode: Release
12:32:40:******************************* System ********************************
12:32:40: CPU: Intel(R) Core(TM) i7 CPU K 875 @ 2.93GHz
12:32:40: CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
12:32:40: CPUs: 8
12:32:40: Memory: 7.99GiB
12:32:40: Free Memory: 6.63GiB
12:32:40: Threads: WINDOWS_THREADS
12:32:40: Has Battery: false
12:32:40: On Battery: false
12:32:40: UTC offset: 1
12:32:40: PID: 3456
12:32:40: CWD: C:/Users/Markus/AppData/Roaming/FAHClient
12:32:40: OS: Windows 7 Professional
12:32:40: OS Arch: AMD64
12:32:40: GPUs: 2
12:32:40: GPU 0: ATI:5 PITCAIRN [Radeon HD 7800] HD5870 is GPU 0!
12:32:40: GPU 1: ATI:4 Radeon HD 5870 (Cypress) HD7870 is GPU 1!
12:32:40: CUDA: Not detected
12:32:40:Win32 Service: false
15:57:28:<config>
15:57:28: <!-- Error Handling -->
15:57:28: <max-slot-errors v='3'/>
15:57:28: <max-unit-errors v='3'/>
15:57:28:
15:57:28: <!-- Folding Core -->
15:57:28: <core-priority v='low'/>
15:57:28:
15:57:28: <!-- Folding Slot Configuration -->
15:57:28: <extra-core-args v='forceasm'/>
15:57:28: <power v='full'/>
15:57:28:
15:57:28: <!-- HTTP Server -->
15:57:28: <allow v='192.168.2.100-192.168.2.110 127.0.0.1'/>
15:57:28:
15:57:28: <!-- Logging -->
15:57:28: <log-rotate-max v='50'/>
15:57:28:
15:57:28: <!-- Network -->
15:57:28: <proxy v=':8080'/>
15:57:28:
15:57:28: <!-- Remote Command Server -->
15:57:28: <command-allow-no-pass v='192.168.2.100-192.168.2.110 127.0.0.1'/>
15:57:28:
15:57:28: <!-- Slot Control -->
15:57:28: <pause-on-battery v='false'/>
15:57:28:
15:57:28: <!-- User Information -->
15:57:28: <passkey v='********************************'/>
15:57:28: <team v='70335'/>
15:57:28: <user v='folding_hoomer'/>
15:57:28:
15:57:28: <!-- Folding Slots -->
15:57:28: <slot id='1' type='GPU'>
15:57:28: <client-type v='beta'/>
15:57:28: <cuda-index v='1'/>
15:57:28: <next-unit-percentage v='100'/>
15:57:28: <opencl-index v='1'/>
15:57:28: <pause-on-start v='true'/>
15:57:28: <project-key v='0'/>
15:57:28: </slot>
15:57:28: <slot id='0' type='CPU'>
15:57:28: <cpus v='6'/>
15:57:28: </slot>
15:57:28: <slot id='2' type='GPU'>
15:57:28: <cuda-index v='0'/>
15:57:28: <opencl-index v='0'/>
15:57:28: </slot>
15:57:28:</config>The Client changes the names of the GPU´s:
Slot-ID1: GPU 0 HD5870 - not folding
Slot-ID2: GPU 1 HD7870 - folding
Log:
06:33:03:WU01:FS02:0x17:Completed 2475000 out of 2500000 steps (99%)
06:38:12:WU01:FS02:0x17:Completed 2500000 out of 2500000 steps (100%)
06:38:13:WU00:FS02:Connecting to assign-GPU.stanford.edu:80
06:38:14:WU00:FS02:News: Welcome to Folding@Home
06:38:14:WU00:FS02:Assigned to work server 171.64.65.69
06:38:14:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Radeon HD 5870 (Cypress) from 171.64.65.69
06:38:14:WU00:FS02:Connecting to 171.64.65.69:8080
06:38:19:WU00:FS02:Downloading 4.18MiB
06:38:26:WU00:FS02:Download 73.33%
06:38:27:WU00:FS02:Download complete
06:38:27:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:141 clone:11 gen:8 core:0x17 unit:0x0000000e028c126652b4c3c068fda6ff
06:38:28:WU01:FS02:0x17:Saving result file logfile_01.txt
06:38:28:WU01:FS02:0x17:Saving result file checkpointState.xml
06:38:30:WU01:FS02:0x17:Saving result file checkpt.crc
06:38:30:WU01:FS02:0x17:Saving result file log.txt
06:38:30:WU01:FS02:0x17:Saving result file positions.xtc
06:38:32:WU01:FS02:0x17:Folding@home Core Shutdown: FINISHED_UNIT
06:38:32:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:38:32:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:507 clone:2 gen:111 core:0x17 unit:0x000000a6028c126651a6977c1bca9670
06:38:32:WU01:FS02:Uploading 12.96MiB to 171.64.65.69
06:38:32:WU01:FS02:Connecting to 171.64.65.69:8080
06:38:32:WU00:FS02:Starting
06:38:32:WU00:FS02:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Markus/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/beta/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 3456 -checkpoint 15 -gpu 0 -gpu-vendor ati forceasm
06:38:32:WU00:FS02:Started FahCore on PID 16868
06:38:32:WU00:FS02:Core PID:9136
06:38:32:WU00:FS02:FahCore 0x17 started
06:38:33:WU00:FS02:0x17:*********************** Log Started 2014-02-08T06:38:33Z ***********************
06:38:33:WU00:FS02:0x17:Project: 8900 (Run 141, Clone 11, Gen 8)
06:38:33:WU00:FS02:0x17:Unit: 0x0000000e028c126652b4c3c068fda6ff
06:38:33:WU00:FS02:0x17:CPU: 0x00000000000000000000000000000000
06:38:33:WU00:FS02:0x17:Machine: 2
06:38:33:WU00:FS02:0x17:Reading tar file state.xml
06:38:33:WU00:FS02:0x17:Reading tar file system.xml
06:38:34:WU00:FS02:0x17:Reading tar file integrator.xml
06:38:34:WU00:FS02:0x17:Reading tar file core.xml
06:38:34:WU00:FS02:0x17:Digital signatures verified
06:38:40:WU01:FS02:Upload 3.37%
06:40:43:WU01:FS02:Upload 32.78%
06:40:54:WU00:FS02:0x17:Completed 0 out of 2500000 steps (0%)
06:40:54:WU01:FS02:Upload 35.19%
06:45:39:WU01:FS02:Upload 100.00%
06:45:50:WU01:FS02:Upload complete
06:45:50:WU01:FS02:Server responded WORK_ACK (400)
06:45:50:WU01:FS02:Final credit estimate, 25197.00 points
06:45:50:WU01:FS02:Cleaning up
06:46:17:WU00:FS02:0x17:Completed 25000 out of 2500000 steps (1%)
06:51:26:WU00:FS02:0x17:Completed 50000 out of 2500000 steps (2%)
06:56:52:WU00:FS02:0x17:Completed 75000 out of 2500000 steps (3%)
07:02:02:WU00:FS02:0x17:Completed 100000 out of 2500000 steps (4%)
07:03:12:FS02:Finishing
07:07:27:WU00:FS02:0x17:Completed 125000 out of 2500000 steps (5%)
******************************* Date: 2014-02-08 *******************************
07:12:37:WU00:FS02:0x17:Completed 150000 out of 2500000 steps (6%)
07:18:02:WU00:FS02:0x17:Completed 175000 out of 2500000 steps (7%)
07:23:11:WU00:FS02:0x17:Completed 200000 out of 2500000 steps (8%)
07:28:37:WU00:FS02:0x17:Completed 225000 out of 2500000 steps (9%)
07:33:46:WU00:FS02:0x17:Completed 250000 out of 2500000 steps (10%)
07:39:12:WU00:FS02:0x17:Completed 275000 out of 2500000 steps (11%)
07:44:21:WU00:FS02:0x17:Completed 300000 out of 2500000 steps (12%)
07:49:47:WU00:FS02:0x17:Completed 325000 out of 2500000 steps (13%)
07:54:56:WU00:FS02:0x17:Completed 350000 out of 2500000 steps (14%)
08:00:22:WU00:FS02:0x17:Completed 375000 out of 2500000 steps (15%)
08:05:31:WU00:FS02:0x17:Completed 400000 out of 2500000 steps (16%)
08:10:56:WU00:FS02:0x17:Completed 425000 out of 2500000 steps (17%)
08:16:06:WU00:FS02:0x17:Completed 450000 out of 2500000 steps (18%)
08:21:32:WU00:FS02:0x17:Completed 475000 out of 2500000 steps (19%)
08:26:41:WU00:FS02:0x17:Completed 500000 out of 2500000 steps (20%)
08:32:07:WU00:FS02:0x17:Completed 525000 out of 2500000 steps (21%)
08:37:16:WU00:FS02:0x17:Completed 550000 out of 2500000 steps (22%)
08:42:42:WU00:FS02:0x17:Completed 575000 out of 2500000 steps (23%)
08:47:51:WU00:FS02:0x17:Completed 600000 out of 2500000 steps (24%)
08:53:16:WU00:FS02:0x17:Completed 625000 out of 2500000 steps (25%)
08:58:26:WU00:FS02:0x17:Completed 650000 out of 2500000 steps (26%)
09:03:51:WU00:FS02:0x17:Completed 675000 out of 2500000 steps (27%)
09:09:01:WU00:FS02:0x17:Completed 700000 out of 2500000 steps (28%)
09:14:27:WU00:FS02:0x17:Completed 725000 out of 2500000 steps (29%)
09:19:37:WU00:FS02:0x17:Completed 750000 out of 2500000 steps (30%)
09:25:02:WU00:FS02:0x17:Completed 775000 out of 2500000 steps (31%)
09:30:11:WU00:FS02:0x17:Completed 800000 out of 2500000 steps (32%)
09:35:37:WU00:FS02:0x17:Completed 825000 out of 2500000 steps (33%)
09:40:46:WU00:FS02:0x17:Completed 850000 out of 2500000 steps (34%)
09:46:11:WU00:FS02:0x17:Completed 875000 out of 2500000 steps (35%)
09:51:21:WU00:FS02:0x17:Completed 900000 out of 2500000 steps (36%)
09:56:46:WU00:FS02:0x17:Completed 925000 out of 2500000 steps (37%)
09:57:58:WU00:FS02:0x17:ERROR:exception: Error creating array interactingTiles: clCreateBuffer (-61)
09:57:58:WU00:FS02:0x17:Saving result file logfile_01.txt
09:57:58:WU00:FS02:0x17:Saving result file log.txt
09:57:58:WU00:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
09:57:58:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
09:57:58:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:141 clone:11 gen:8 core:0x17 unit:0x0000000e028c126652b4c3c068fda6ff
09:57:58:WU00:FS02:Uploading 2.78KiB to 171.64.65.69
09:57:58:WU00:FS02:Connecting to 171.64.65.69:8080
09:57:59:WU00:FS02:Upload complete
09:57:59:WU00:FS02:Server responded WORK_ACK (400)
09:57:59:WU00:FS02:Cleaning up
