171.67.108.21
Bobby-Uschi
Hardware configuration: PC1//C2Q-Q9450,GA-X48-DS5-NinjaMini,GTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit;
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB Western Sata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"
server 171.67.108.21
Post by Bobby-Uschi »
What about server 171.67.108.21?
In last 5-6 days, about 40 WUS have completed and sent but to date
get no credit.
edit.server nr
PC1//C2Q-Q9450,GA-X48-DS5-,2xGTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB WeSata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"stern
Re: server 171.67.108.21
A mod will be along shortly to forward your feedback to the researcher using that server.
Just curious, What is the client version and OS type, and an example project number?
bollix47
Post by bollix47 »
Could you please supply a couple of the PRCG numbers for the missing credits along with a section of the log showing the upload?
Bobby-Uschi
 Windows GPU Console Edition #################################################
                       Folding@Home Client Version 6.41r2
                          http://folding.stanford.edu
Launch directory: C:\Programme\Folding@home\Folding@home-gpu
Executable: C:\Programme\Folding@home\Folding@home-gpu\Folding@home-Win32-gpu.exe
Arguments: -advmethods -forcegpu nvidia_g80
[11:43:42] - Ask before connecting: No
[11:43:42] - User name: Bobby-Uschi (Team 34361)
[11:43:42] - User ID: 9BFD3CC3642A68A
[11:43:42] - Machine ID: 2
[11:43:42]
[11:43:42] Gpu type=2 species=11.
[11:43:43] Loaded queue successfully.
[11:43:43]
[11:43:43] + Processing work unit
[11:43:43] Core required: FahCore_11.exe
[11:43:43] Core found.
[11:43:43] Working on queue slot 04 [January 16 11:43:43 UTC]
[11:43:43] + Working ...
[11:43:43]
[11:43:43] *------------------------------*
[11:43:43] Folding@Home GPU Core
[11:43:43] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[11:43:43]34:12] + Processing work unit
[23:34:12] Core required: FahCore_11.exe
[23:34:12] Core found.
[23:34:12] Working on queue slot 06 [January 16 23:34:12 UTC]
[23:34:12] + Working ...
[23:34:13]
[23:34:13] *------------------------------*
[23:34:13] Folding@Home GPU Core
[23:34:13] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:34:13]
[23:34:13] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:34:13] Build host: amoeba
[23:34:13] Board Type: Nvidia
[23:34:13] Core      :
[23:34:13] Preparing to commence simulation
[23:34:13] - Looking at optimizations...
[23:34:13] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[23:34:13] - Created dyn
[23:34:13] - Files status OK
[23:34:13] - Expanded 62955 -> 336763 (decompressed 534.9 percent)
[23:34:13] Called DecompressByteArray: compressed_data_size=62955 data_size=336763, decompressed_data_size=336763 diff=0
[23:34:13] - Digital signature verified
[23:34:13]
[23:34:13] Project: 10502 (Run 249, Clone 0, Gen 430)
[23:34:13]
[23:34:13] Assembly optimizations on if available.
[23:34:13] Entering M.D.
[23:34:19] Tpr hash work/wudata_06.tpr:  2678224454 4227184960 4061137537 3499182204 391622274
[23:34:19]
[23:34:19] Calling fah_main args: 14 usage=100
[23:34:19]
[23:34:19] Working on Protein
[23:34:20] Client config found, loading data.
[23:34:20] Starting GUI Server
[23:35:15] Completed 1%
[23:36:10] Completed 2%
[23:37:05] Completed 3%
[23:38:00] Completed 4%
[23:38:55] Completed 5%01:03:56] Completed 98%
[01:04:51] Completed 99%
[01:05:46] Completed 100%
[01:05:46] Successful run
[01:05:46] DynamicWrapper: Finished Work Unit: sleep=10000
[01:05:56] Reserved 108912 bytes for xtc file; Cosm status=0
[01:05:56] Allocated 108912 bytes for xtc file
[01:05:56] - Reading up to 108912 from "work/wudata_06.xtc": Read 108912
[01:05:56] Read 108912 bytes from xtc file; available packet space=786321552
[01:05:56] xtc file hash check passed.
[01:05:56] Reserved 21912 21912 786321552 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[01:05:56] Allocated 21912 bytes for arc file
[01:05:56] - Reading up to 21912 from "work/wudata_06.trr": Read 21912
[01:05:56] Read 21912 bytes from arc file; available packet space=786299640
[01:05:56] trr file hash check passed.
[01:05:56] Allocated 560 bytes for edr file
[01:05:56] Read bedfile
[01:05:56] edr file hash check passed.
[01:05:56] Logfile not read.
[01:05:56] GuardedRun: success in DynamicWrapper
[01:05:56] GuardedRun: done
[01:05:56] Run: GuardedRun completed.
[01:05:58] + Opened results file
[01:05:58] - Writing 131896 bytes of core data to disk...
[01:05:58] Done: 131384 -> 130365 (compressed to 99.2 percent)
[01:05:58]   ... Done.
[01:05:58] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[01:05:58] Shutting down core
[01:05:58]
[01:05:58] Folding@home Core Shutdown: FINISHED_UNIT
[01:06:01] CoreStatus = 64 (100)
[01:06:01] Sending work to server
[01:06:01] Project: 10502 (Run 249, Clone 0, Gen 430)
[01:06:01] - Read packet limit of 540015616... Set to 524286976.
[01:06:01] + Attempting to send results [January 17 01:06:01 UTC]
[01:06:01] Gpu type=2 species=11.
[01:06:03] + Results successfully sent
[01:06:03] Thank you for your contribution to Folding@Home.
[01:06:03] + Number of Units Completed: 7613
[01:06:07] - Preparing to get new work unit...
[01:06:07] Cleaning up work director
Project: 10502 (Run 252, Clone 0, Gen 361)
PrProject: 10502 (Run 177, Clone 1, Gen 35
Project: 10502 (Run 329, Clone 1, Gen 352
Project: 10502 (Run 0, Clone 1, Gen 351)
und ca.noch 40 WUs
bollix47
Post by bollix47 »
Thank you for your report ... PG notified.
VijayPande
Pande Group Member
Post by VijayPande »
Thanks for reporting this. This should be resolved in the next stats update.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Bobby-Uschi
Thank you
Bobby-Uschi
171.67.108.21
What's wrong with server-21, no new WUs from almost 12 hours
[10:06:23] - Ask before connecting: No
[10:06:23] - User name: Bobby-Uschi (Team 34361)
[10:06:23] - User ID: 9BFD3CC3642A68A
[10:06:23] - Machine ID: 2
[10:06:23]
[10:06:23] Gpu type=2 species=11.
[10:06:23] Could not open work queue, generating new queue...
[10:06:23] - Preparing to get new work unit...
[10:06:23] Cleaning up work directory
[10:06:23] + Attempting to get work packet
[10:06:23] Passkey found
[10:06:23] - Connecting to assignment server
[10:06:24] - Successful: assigned to (171.67.108.21).
[10:06:24] + News From Folding@Home: Welcome to Folding@Home
[10:06:24] Loaded queue successfully.
[10:06:24] Gpu type=2 species=11.
[10:09:57] + Could not connect to Work Server
[10:09:57] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[10:10:05] + Attempting to get work packet
[10:10:05] Passkey found
[10:10:05] Gpu type=2 species=11.
[10:10:05] - Connecting to assignment server
[10:10:05] - Successful: assigned to (171.67.108.21).
[10:10:05] + News From Folding@Home: Welcome to Folding@Home
[10:10:06] Loaded queue successfully.
[10:10:06] Gpu type=2 species=11.
[10:13:39] + Could not connect to Work Server
[10:13:39] - Attempt #2  to get work failed, and no other work to do.
[10:13:56] + Attempting to get work packet
[10:13:56] Passkey found
[10:13:56] Gpu type=2 species=11.
[10:13:56] - Connecting to assignment server
[10:13:58] - Successful: assigned to (171.67.108.21).
[10:13:58] + News From Folding@Home: Welcome to Folding@Home
[10:13:58] Loaded queue successfully.
[10:13:58] Gpu type=2 species=11.
[10:18:44] + Could not connect to Work Server
[10:18:44] - Attempt #3  to get work failed, and no other work to do.
[10:19:17] + Attempting to get work packet
[10:19:17] Passkey found
[10:19:17] Gpu type=2 species=11.
[10:19:17] - Connecting to assignment server
[10:19:18] - Successful: assigned to (171.67.108.21).
[10:19:18] + News From Folding@Home: Welcome to Folding@Home
[10:19:18] Loaded queue successfully.
[10:19:18] Gpu type=2 species=11.
[10:22:52] + Could not connect to Work Server
[10:22:52] - Attempt #4  to get work failed, and no other work to do.
[10:23:33] + Attempting to get work packet
[10:23:33] Passkey found
[10:23:33] Gpu type=2 species=11.
[10:23:33] - Connecting to assignment server
[10:23:34] - Successful: assigned to (171.67.108.21).
[10:23:34] + News From Folding@Home: Welcome to Folding@Home
[10:23:34] Loaded queue successfully.
[10:23:34] Gpu type=2 species=11.
[10:28:19] + Could not connect to Work Server
[10:28:19] - Attempt #5  to get work failed, and no other work to do.
[10:29:45] + Attempting to get work packet
[10:29:45] Passkey found
[10:29:45] Gpu type=2 species=11.
[10:29:45] - Connecting to assignment server
[10:29:46] - Successful: assigned to (171.67.108.21).
[10:29:46] + News From Folding@Home: Welcome to Folding@Home
[10:29:46] Loaded queue successfully.
[10:29:46] Gpu type=2 species=11.
[10:33:19] + Could not connect to Work Server
[10:33:19] - Attempt #6  to get work failed, and no other work to do.
[10:36:02] + Attempting to get work packet
[10:36:02] Passkey found
[10:36:02] Gpu type=2 species=11.
[10:36:02] - Connecting to assignment server
[10:36:03] - Successful: assigned to (171.67.108.21).
[10:36:03] + News From Folding@Home: Welcome to Folding@Home
[10:36:03] Loaded queue successfully.
[10:36:03] Gpu type=2 species=11.
[10:39:36] + Could not connect to Work Server
[10:39:36] - Attempt #7  to get work failed, and no other work to do.
Re: 171.67.108.21
Thanks for your report. According to the Server Status, the Net Load is high, approximately 960 which might explain the issue. Nevertheless, I have informed the appropriate PG Members.
Bobby-Uschi
Re: 171.67.108.21
for a few hours'm Assigned for 171.67.108.11 and runs well.
But server 171.67.108.21 is empty, has no new WUs.
find http://fah-web.stanford.edu/psummary.html
WUs??
Re: 171.67.108.21
The Project Summary list may need to wait on an update to show active projects of WS 171.67.108.21. The log file for that server linked from the Server Status page shows hundreds of assignments during the last few hours. There have been some gaps shown in the log where there were no assignments recorded, the most recent one ended about 1 PM Stanford time.
qdemn7
WorkServer 171.67.108.21 and CollectionServer 171.67.108.26
Post by qdemn7 »
Have 2 WU that have been done for 3 days, and the server won't accept them. Client tries every 5-15 minutes with no success. Have also been having problems getting Work from 171.67.108.21. Will get WU for a while, complete them, send them back, then no WU available for nearly a full day. No ETA or Credit ever shows up on Client for these type WU.
Windows 7 - 64 bit - all updates
GTX 260 - 216 core card - Not overclocked.
Geforce 332.21 driver
17:27:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10504 run:77 clone:1 gen:1872 core:0x11 unit:0x00000f556652eda54b75aeef00002a5e
17:27:15:WU00:FS00:Uploading 127.79KiB to 171.67.108.21
17:27:15:WU00:FS00:Connecting to 171.67.108.21:8080
17:30:15:WU00:FS00:Upload 100.00%
17:30:15:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
17:30:15:WU00:FS00:Trying to send results to collection server
17:30:15:WU00:FS00:Uploading 127.79KiB to 171.67.108.26
17:30:15:WU00:FS00:Connecting to 171.67.108.26:8080
17:30:16:WU00:FS00:Upload complete
17:30:16:WU00:FS00:Server responded PLEASE_WAIT (464)
17:30:16:WARNING:WU00:FS00:Failed to send results, will try again later
17:27:15:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10504 run:189 clone:1 gen:1910 core:0x11 unit:0x0000110f6652eda54b75b01400005621
17:27:15:WU02:FS00:Uploading 128.38KiB to 171.67.108.21
17:27:15:WU02:FS00:Connecting to 171.67.108.21:8080
17:30:15:WU02:FS00:Upload 99.70%
17:30:15:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
17:30:15:WU02:FS00:Trying to send results to collection server
17:30:15:WU02:FS00:Uploading 128.38KiB to 171.67.108.26
17:30:15:WU02:FS00:Connecting to 171.67.108.26:8080
17:30:16:WU02:FS00:Upload complete
17:30:16:WU02:FS00:Server responded PLEASE_WAIT (464)
17:30:16:WARNING:WU02:FS00:Failed to send results, will try again later
dabaerman
Re: Collection Server 171.67.108.26 problem.
Post by dabaerman »
Same here, 2 GTX285 & 2 GTX 295 @ stock clocks. I have 2 660Ti & 3 GTX460 Cyclone on different servers without issues.
I'll give the machines a rest and check on the collection server tomorrow.
Folding 24/7 with 3 nVidia GPU cores.
Collection servers are never the primary cause of a problem. The FIRST error you received was from the Work Server: 171.67.108.21 and that's where the problem needs to be fixed. That server is experiencing a trememdous amount of traffic and I have no explanation for that, but I'll see that it's reported.
I'll also edit the topic title per the guidelines shown in this topic.
jeano
Re: WorkServer 171.67.108.21 and CollectionServer 171.67.108
Post by jeano »
same here...
I'm getting 2 different responses ( 1 exception and "please_wait 464")
07:09:30:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
07:09:31:WU00:FS00:News: Welcome to Folding@Home
07:09:31:WU00:FS00:Assigned to work server 171.67.108.21
07:09:31:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:G94 [GeForce 9600 GT] from 171.67.108.21
07:09:31:WU00:FS00:Connecting to 171.67.108.21:8080
07:10:07:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
07:10:07:WU02:FS00:Trying to send results to collection server
07:10:07:WU02:FS00:Uploading 127.89KiB to 171.67.108.26
07:10:07:WU02:FS00:Connecting to 171.67.108.26:8080
07:10:10:WU02:FS00:Upload complete
07:10:10:WU02:FS00:Server responded PLEASE_WAIT (464)
07:10:10:WARNING:WU02:FS00:Failed to send results, will try again later
07:10:10:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10501 run:104 clone:1 gen:1807 core:0x11 unit:0x00000fbc6652eda54b6ea72c000028aa
07:10:10:WU02:FS00:Uploading 127.89KiB to 171.67.108.21
07:10:10:WU02:FS00:Connecting to 171.67.108.21:8080
07:11:13:WARNING:WU02:FS00:Exception: Failed to send results to work server: 10002: Received short response, expected 512 bytes, got 0
07:11:13:WU02:FS00:Trying to send results to collection server
07:11:13:WU02:FS00:Uploading 127.89KiB to 171.67.108.26
07:11:13:WU02:FS00:Connecting to 171.67.108.26:8080
07:11:17:WU02:FS00:Upload complete
07:11:17:WU02:FS00:Server responded PLEASE_WAIT (464)
07:11:17:WARNING:WU02:FS00:Failed to send results, will try again later
